  4. Test Adapter iQontrol 2.0.x Vis (Entwicklungs-Thread)
    apollon77A
appdark-modeiqontrolresponsivevisvisualisierungvisualizationwidget
7.6k Beiträge 296 Kommentatoren 8.6m Aufrufe 201 Beobachtet
  • B buchner51
    @s-bormann
      "nuki-extended.0.smartlocks": {
        "common": {
          "name": "Nuki Smartlocks",
          "write": false
        "type": "channel",
        "native": {},
        "from": "system.adapter.nuki-extended.0",
        "user": "system.user.admin",
        "ts": 1622990362526,
        "_id": "nuki-extended.0.smartlocks",
        "acl": {
          "object": 1636,
          "owner": "system.user.admin",
      "nuki-extended.0.smartlocks.haustür_": {
        "common": {
          "name": "Haustür ",
          "write": false
        "type": "channel",
        "native": {},
        "ts": 1622990362528,
        "_id": "nuki-extended.0.smartlocks.haustür_",
        "acl": {
          "object": 1636,
      "nuki-extended.0.smartlocks.haustür_._ACTION": {
        "common": {
          "name": "Trigger an action",
          "role": "value",
          "type": "number",
          "write": true,
          "states": {
            "0": "NO_ACTION",
            "1": "UNLOCK",
            "2": "LOCK",
            "3": "UNLATCH",
            "4": "LOCK_N_GO",
            "5": "LOCK_N_GO_WITH_UNLATCH"
        "type": "state",
        "native": {},
        "_id": "nuki-extended.0.smartlocks.haustür_._ACTION",
        "acl": {
          "object": 1636,
          "state": 1636,
      "nuki-extended.0.smartlocks.haustür_._ACTION.LOCK": {
        "common": {
          "name": "Trigger LOCK action",
          "role": "button",
          "type": "boolean",
          "write": true,
          "read": false
        "type": "state",
        "native": {},
        "_id": "nuki-extended.0.smartlocks.haustür_._ACTION.LOCK",
        "acl": {
          "object": 1636,
          "state": 1636,
      "nuki-extended.0.smartlocks.haustür_._ACTION.LOCK_N_GO": {
        "common": {
          "name": "Trigger LOCK_N_GO action",
          "role": "button",
          "type": "boolean",
          "write": true,
          "read": false
        "type": "state",
        "native": {},
        "_id": "nuki-extended.0.smartlocks.haustür_._ACTION.LOCK_N_GO",
        "acl": {
          "object": 1636,
          "state": 1636,
      "nuki-extended.0.smartlocks.haustür_._ACTION.LOCK_N_GO_WITH_UNLATCH": {
        "common": {
          "name": "Trigger LOCK_N_GO_WITH_UNLATCH action",
          "role": "button",
          "type": "boolean",
          "write": true,
          "read": false
        "type": "state",
        "native": {},
        "_id": "nuki-extended.0.smartlocks.haustür_._ACTION.LOCK_N_GO_WITH_UNLATCH",
        "acl": {
          "object": 1636,
          "state": 1636,
      "nuki-extended.0.smartlocks.haustür_._ACTION.UNLATCH": {
        "common": {
          "name": "Trigger UNLATCH action",
          "role": "button",
          "type": "boolean",
          "write": true,
          "read": false
        "type": "state",
        "native": {},
        "_id": "nuki-extended.0.smartlocks.haustür_._ACTION.UNLATCH",
        "acl": {
          "object": 1636,
          "state": 1636,
      "nuki-extended.0.smartlocks.haustür_._ACTION.UNLOCK": {
        "common": {
          "name": "Trigger UNLOCK action",
          "role": "button",
          "type": "boolean",
          "write": true,
          "read": false
        "type": "state",
        "native": {},
        "_id": "nuki-extended.0.smartlocks.haustür_._ACTION.UNLOCK",
        "acl": {
          "object": 1636,
          "state": 1636,
      "nuki-extended.0.smartlocks.haustür_.bridgeId": {
        "common": {
          "name": "Bridge ID of the Nuki",
          "role": "value",
          "type": "number",
          "write": false
        "type": "state",
        "native": {},
        "ts": 1622990362529,
        "_id": "nuki-extended.0.smartlocks.haustür_.bridgeId",
        "acl": {
          "object": 1636,
          "state": 1636,
      "nuki-extended.0.smartlocks.haustür_.hex": {
        "common": {
          "name": "Hex ID of the Nuki",
          "role": "text",
          "type": "string",
          "write": false
        "type": "state",
        "native": {},
        "ts": 1622990362563,
        "_id": "nuki-extended.0.smartlocks.haustür_.hex",
        "acl": {
          "object": 1636,
          "state": 1636,
      "nuki-extended.0.smartlocks.haustür_.id": {
        "common": {
          "name": "ID of the Nuki",
          "role": "value",
          "type": "number",
          "write": false
        "type": "state",
        "native": {},
        "_id": "nuki-extended.0.smartlocks.haustür_.id",
        "acl": {
          "object": 1636,
          "state": 1636,
      "nuki-extended.0.smartlocks.haustür_.info": {
        "common": {
          "name": "Additional Information",
          "write": false
        "type": "channel",
        "native": {},
        "_id": "nuki-extended.0.smartlocks.haustür_.info",
        "acl": {
          "object": 1636,
      "nuki-extended.0.smartlocks.haustür_.info.firmwareVersion": {
        "common": {
          "name": "The firmware version",
          "role": "value",
          "type": "number",
          "write": false
        "type": "state",
        "native": {},
        "_id": "nuki-extended.0.smartlocks.haustür_.info.firmwareVersion",
        "acl": {
          "object": 1636,
          "state": 1636,
      "nuki-extended.0.smartlocks.haustür_.name": {
        "common": {
          "name": "Name of the Bridge / Nuki",
          "role": "text",
          "type": "string",
          "write": false
        "type": "state",
        "native": {},
        "_id": "nuki-extended.0.smartlocks.haustür_.name",
        "acl": {
          "object": 1636,
          "state": 1636,
      "nuki-extended.0.smartlocks.haustür_.state": {
        "common": {
          "name": "Current states",
          "write": false
        "type": "channel",
        "native": {},
        "_id": "nuki-extended.0.smartlocks.haustür_.state",
        "acl": {
          "object": 1636,
      "nuki-extended.0.smartlocks.haustür_.state.batteryChargeState": {
        "common": {
          "name": "Indicates battery charge level",
          "role": "value",
          "type": "number",
          "write": false
        "type": "state",
        "native": {},
        "ts": 1622995898502,
        "_id": "nuki-extended.0.smartlocks.haustür_.state.batteryChargeState",
        "acl": {
          "object": 1636,
          "state": 1636,
      "nuki-extended.0.smartlocks.haustür_.state.batteryCharging": {
        "common": {
          "name": "Indicates battery charging",
          "role": "indicator",
          "type": "boolean",
          "write": true,
          "read": false
        "type": "state",
        "native": {},
        "ts": 1622995898501,
        "_id": "nuki-extended.0.smartlocks.haustür_.state.batteryCharging",
        "acl": {
          "object": 1636,
          "state": 1636,
      "nuki-extended.0.smartlocks.haustür_.state.batteryCritical": {
        "common": {
          "name": "Indicates critical battery level",
          "role": "indicator.lowbat",
          "type": "boolean",
          "write": true,
          "read": false
        "type": "state",
        "native": {},
        "_id": "nuki-extended.0.smartlocks.haustür_.state.batteryCritical",
        "acl": {
          "object": 1636,
          "state": 1636,
      "nuki-extended.0.smartlocks.haustür_.state.deviceType": {
        "common": {
          "name": "Type of device",
          "role": "value",
          "type": "number",
          "write": false,
          "states": {
            "0": "Nuki Smart Lock",
            "2": "Nuki Opener"
        "type": "state",
        "native": {},
        "ts": 1622990531628,
        "_id": "nuki-extended.0.smartlocks.haustür_.state.deviceType",
        "acl": {
          "object": 1636,
          "state": 1636,
      "nuki-extended.0.smartlocks.haustür_.state.doorState": {
        "common": {
          "name": "Türsensor-DoorClosed(2)-DoorOpen(3)",
          "role": "value",
          "type": "number",
          "write": false,
          "states": {
            "0": "UNAVAILABLE",
            "1": "DEACTIVATED",
            "2": "DOOR_CLOSED",
            "3": "DOOR_OPENED",
            "4": "DOOR_STATE_UNKNOWN",
            "5": "CALIBRATING"
          "custom": {
            "iqontrol.0": {
              "0": "",
              "1": "",
              "2": "",
              "enabled": true,
              "invert": false,
              "confirm": false,
              "pincode": "",
              "step": "",
              "roundDigits": 2,
              "timeFormat": "x",
              "timeDisplayFormat": "dddd, DD.MM.YYYY HH:mm:ss",
              "targetValueId": "",
              "statesAddInput": false,
              "statesAddInputCaption": "Enter other value...",
              "showOnlyTargetValues": false,
              "readonly": false,
              "unit": "",
              "unit_zero": "LOCKED",
              "unit_one": "UNLATCHED",
              "min": "",
              "max": "",
              "type": "number",
              "role": "value",
              "targetValues": "",
              "states": {
                "DOOR_CLOSED": "true",
                "DOOR_OPENED": "false"
              "timeDisplayDontShowDistance": false
        "type": "state",
        "native": {},
        "_id": "nuki-extended.0.smartlocks.haustür_.state.doorState",
        "acl": {
          "object": 1636,
          "state": 1636,
        "ts": 1642363067003
      "nuki-extended.0.smartlocks.haustür_.state.doorStateName": {
        "common": {
          "name": "Current door-state name of the Nuki",
          "role": "text",
          "type": "string",
          "write": false
        "type": "state",
        "native": {},
        "_id": "nuki-extended.0.smartlocks.haustür_.state.doorStateName",
        "acl": {
          "object": 1636,
          "state": 1636,
      "nuki-extended.0.smartlocks.haustür_.state.lastDataUpdate": {
        "common": {
          "name": "Timestamp of last data update / refresh",
          "role": "date",
          "type": "string",
          "write": false
        "type": "state",
        "native": {},
        "_id": "nuki-extended.0.smartlocks.haustür_.state.lastDataUpdate",
        "acl": {
          "object": 1636,
          "state": 1636,
      "nuki-extended.0.smartlocks.haustür_.state.lastStateUpdate": {
        "common": {
          "name": "Timestamp of last state change",
          "role": "date",
          "type": "string",
          "write": false
        "type": "state",
        "native": {},
        "ts": 1622990362530,
        "_id": "nuki-extended.0.smartlocks.haustür_.state.lastStateUpdate",
        "acl": {
          "object": 1636,
          "state": 1636,
      "nuki-extended.0.smartlocks.haustür_.state.lockState": {
        "common": {
          "name": "Motorschloss-Locked(1)-Unlocked(3)",
          "role": "value",
          "type": "number",
          "write": false,
          "states": {
            "0": "UNCALIBRATED",
            "1": "LOCKED",
            "2": "UNLOCKING",
            "3": "UNLOCKED",
            "4": "LOCKING",
            "5": "UNLATCHED",
            "6": "UNLOCKED_LOCK_N_GO",
            "7": "UNLATCHING",
            "254": "MOTOR_BLOCKED",
            "255": "UNDEFINED"
          "custom": {
            "iqontrol.0": {
              "0": "",
              "1": "",
              "3": "",
              "enabled": true,
              "invert": false,
              "confirm": false,
              "pincode": "",
              "step": "",
              "roundDigits": 2,
              "timeFormat": "x",
              "readonly": false,
              "unit": "",
              "unit_zero": "",
              "unit_one": "",
              "min": "",
              "max": "",
              "type": "number",
              "role": "value",
              "targetValues": {},
              "states": {
                "1": "true",
                "3": "false"
        "type": "state",
        "native": {},
        "_id": "nuki-extended.0.smartlocks.haustür_.state.lockState",
        "acl": {
          "object": 1636,
          "state": 1636,
        "ts": 1642363118406
      "nuki-extended.0.smartlocks.haustür_.state.locked": {
        "common": {
          "name": "Indication if door is locked (boolean of lockState)",
          "role": "sensor.lock",
          "type": "boolean",
          "write": false,
          "states": {
            "0": "false",
            "1": "true",
            "2": "false",
            "3": "false",
            "4": "true",
            "5": "false",
            "6": "false",
            "7": "false",
            "254": "false",
            "255": "false"
        "type": "state",
        "native": {},
        "_id": "nuki-extended.0.smartlocks.haustür_.state.locked",
        "acl": {
          "object": 1636,
          "state": 1636,
        "ts": 1641742002315
      "nuki-extended.0.smartlocks.haustür_.state.mode": {
        "common": {
          "name": "Operation Mode of the Nuki or Opener",
          "role": "value",
          "type": "number",
          "write": false,
          "states": {
            "0": "UNINITIALIZED",
            "1": "PAIRING",
            "2": "NORMAL",
            "3": "CONTINUOUS",
            "4": "MAINTENANCE"
        "type": "state",
        "native": {},
        "_id": "nuki-extended.0.smartlocks.haustür_.state.mode",
        "acl": {
          "object": 1636,
          "state": 1636,
      "nuki-extended.0.smartlocks.haustür_.type": {
        "common": {
          "role": "value",
          "type": "number",
          "write": false,
          "states": {
            "2": "Nuki Opener"
        "type": "state",
        "native": {},
        "_id": "nuki-extended.0.smartlocks.haustür_.type",
        "acl": {
          "object": 1636,
          "state": 1636,
    meinst du so als Json?
    s.bormannS
    s.bormannS
    s.bormann
    #6841
    @buchner51 sagte in Test Adapter iQontrol 1.11.x Vis (Entwicklungs-Thread):
    @s-bormann
        "common": {
          "write": false
        "type": "channel",
        "native": {},
        "acl": {
          "object": 1636,
        "common": {
          "name": "Haustür ",
          "write": false
        "type": "channel",
        "native": {},
        "acl": {
          "object": 1636,
        "common": {
          "role": "value",
          "type": "number",
          "write": true,
          "states": {
            "0": "NO_ACTION",
            "1": "UNLOCK",
            "2": "LOCK",
            "3": "UNLATCH",
            "4": "LOCK_N_GO",
        "type": "state",
        "native": {},
        "acl": {
          "object": 1636,
          "state": 1636,
        "common": {
          "role": "button",
          "type": "boolean",
          "write": true,
          "read": false
        "type": "state",
        "native": {},
        "acl": {
          "object": 1636,
          "state": 1636,
        "common": {
          "role": "button",
          "type": "boolean",
          "write": true,
          "read": false
        "type": "state",
        "native": {},
        "acl": {
          "object": 1636,
          "state": 1636,
        "common": {
          "role": "button",
          "type": "boolean",
          "write": true,
          "read": false
        "type": "state",
        "native": {},
        "acl": {
          "object": 1636,
          "state": 1636,
        "common": {
          "role": "button",
          "type": "boolean",
          "write": true,
          "read": false
        "type": "state",
        "native": {},
        "acl": {
          "object": 1636,
          "state": 1636,
        "common": {
          "role": "button",
          "type": "boolean",
          "write": true,
          "read": false
        "type": "state",
        "native": {},
        "acl": {
          "object": 1636,
          "state": 1636,
        "common": {
          "role": "value",
          "type": "number",
          "write": false
        "type": "state",
        "native": {},
        "acl": {
          "object": 1636,
          "state": 1636,
        "common": {
          "role": "text",
          "type": "string",
          "write": false
        "type": "state",
        "native": {},
        "acl": {
          "object": 1636,
          "state": 1636,
        "common": {
          "role": "value",
          "type": "number",
          "write": false
        "type": "state",
        "native": {},
        "acl": {
          "object": 1636,
          "state": 1636,
        "common": {
          "write": false
        "type": "channel",
        "native": {},
        "acl": {
          "object": 1636,
        "common": {
          "role": "value",
          "type": "number",
          "write": false
        "type": "state",
        "native": {},
        "acl": {
          "object": 1636,
          "state": 1636,
        "common": {
          "role": "text",
          "type": "string",
          "write": false
        "type": "state",
        "native": {},
        "acl": {
          "object": 1636,
          "state": 1636,
        "common": {
          "write": false
        "type": "channel",
        "native": {},
        "acl": {
          "object": 1636,
        "common": {
          "role": "value",
          "type": "number",
          "write": false
        "type": "state",
        "native": {},
        "acl": {
          "object": 1636,
          "state": 1636,
        "common": {
          "type": "boolean",
          "write": true,
          "read": false
        "type": "state",
        "native": {},
        "acl": {
          "object": 1636,
          "state": 1636,
        "common": {
          "type": "boolean",
          "write": true,
          "read": false
        "type": "state",
        "native": {},
        "acl": {
          "object": 1636,
          "state": 1636,
        "common": {
          "role": "value",
          "type": "number",
          "write": false,
          "states": {
            "2": "Nuki Opener"
        "type": "state",
        "native": {},
        "acl": {
          "object": 1636,
          "state": 1636,
        "common": {
          "role": "value",
          "type": "number",
          "write": false,
          "states": {
            "0": "UNAVAILABLE",
            "1": "DEACTIVATED",
            "2": "DOOR_CLOSED",
            "3": "DOOR_OPENED",
            "5": "CALIBRATING"
          "custom": {
            "iqontrol.0": {
              "0": "",
              "1": "",
              "2": "",
              "enabled": true,
              "invert": false,
              "confirm": false,
              "pincode": "",
              "step": "",
              "roundDigits": 2,
              "timeFormat": "x",
              "readonly": false,
              "unit": "",
              "min": "",
              "max": "",
              "type": "number",
              "role": "value",
              "targetValues": "",
              "states": {
        "type": "state",
        "native": {},
        "acl": {
          "object": 1636,
          "state": 1636,
        "ts": 1642363067003
        "common": {
          "role": "text",
          "type": "string",
          "write": false
        "type": "state",
        "native": {},
        "acl": {
          "object": 1636,
          "state": 1636,
        "common": {
          "role": "date",
          "type": "string",
          "write": false
        "type": "state",
        "native": {},
        "acl": {
          "object": 1636,
          "state": 1636,
        "common": {
          "role": "date",
          "type": "string",
          "write": false
        "type": "state",
        "native": {},
        "acl": {
          "object": 1636,
          "state": 1636,
        "common": {
          "role": "value",
          "type": "number",
          "write": false,
          "states": {
            "1": "LOCKED",
            "2": "UNLOCKING",
            "3": "UNLOCKED",
            "4": "LOCKING",
            "5": "UNLATCHED",
            "7": "UNLATCHING",
            "255": "UNDEFINED"
          "custom": {
            "iqontrol.0": {
              "0": "",
              "1": "",
              "3": "",
              "enabled": true,
              "invert": false,
              "confirm": false,
              "pincode": "",
              "step": "",
              "roundDigits": 2,
              "timeFormat": "x",
              "readonly": false,
              "unit": "",
              "unit_zero": "",
              "unit_one": "",
              "min": "",
              "max": "",
              "type": "number",
              "role": "value",
              "targetValues": {},
              "states": {
                "1": "true",
                "3": "false"
        "type": "state",
        "native": {},
        "acl": {
          "object": 1636,
          "state": 1636,
        "ts": 1642363118406
        "common": {
          "type": "boolean",
          "write": false,
          "states": {
            "0": "false",
            "1": "true",
            "2": "false",
            "3": "false",
            "4": "true",
            "5": "false",
            "6": "false",
            "7": "false",
            "254": "false",
            "255": "false"
        "type": "state",
        "native": {},
        "acl": {
          "object": 1636,
          "state": 1636,
        "ts": 1641742002315
        "common": {
          "role": "value",
          "type": "number",
          "write": false,
          "states": {
            "1": "PAIRING",
            "2": "NORMAL",
            "3": "CONTINUOUS",
            "4": "MAINTENANCE"
        "type": "state",
        "native": {},
        "acl": {
          "object": 1636,
          "state": 1636,
        "common": {
          "role": "value",
          "type": "number",
          "write": false,
          "states": {
            "2": "Nuki Opener"
        "type": "state",
        "native": {},
        "acl": {
          "object": 1636,
          "state": 1636,
    habe mir das jetzt mal in Ruhe angeschaut. Das Nuki implementiert das ganz anders, als es bei meiner Keymatic der Fall ist (die hatte ich als Vorlage genommen). Aber ich glaube, mit ein paar Anpassungen sollte es jetzt laufen:
    • Bitte die aktuelle Github-Version laden
    • Da sind beim Türschloss folgende neue Optionen drin, die so konfiguriert werden müssen:
    • Als Datenpunkte konfigurierst Du folgendes:
    • Beim Datenpunkt state.locked gehst Du auf den Schrabenschlüssel und konfigurierst folgendes:
      • Typ: Bool
      • Rolle: Schalter
      • Target-Value-List:
        • true -> nuki-extended.0.smartlocks.haustür_._ACTION.UNLOCK --> true
        • false -> nuki-extended.0.smartlocks.haustür_._ACTION.LOCK --> true
    Bitte probier das mal so und gib Rückmeldung. Wenn das klappt, stelle ich den Beitrag ins Wiki.
    J B 2 Antworten Letzte Antwort
    • dslraserD dslraser
      @s-bormann sagte in Test Adapter iQontrol 1.11.x Vis:
      @dslraser sagte in Test Adapter iQontrol 1.11.x Vis:
      @s-bormann , oder auch andere
      sollte ich mit dem Blockly Kram lieber einen anderen Thread eröffnen ? Ich möchte hier auch nicht damit nerven.
      Also wegen mir nicht, ist doch spannend, was Du entwickelst!
      Aber generell könnte man überlegen, einen iQontrol-Entwicklungs-Thread zu machen, in dem Github-Alpha-Tests und neue Dinge erprobt werden und einen iQontrol-Support-Thread, der dann eher für reine Anwender gedacht ist. Meinungen hierzu?
      Gern, dann mach Du die ruhig auf.
      Erledigt. Sag mal, um noch mal auf die Sortierung zurück zu kommen: Sortieren nach Wert, macht das für die NAMES und PARENTNAMES-Listen wirklich Sinn? Eigentlich macht es doch nur Sinn für die Datenpunkt-Listen, die dann weiter verarbeitet werden. Oder? Bin mir gerade selbst nicht ganz sicher, was sinnvoll ist. Hast Du ein Beispiel, wo Du die Sortierung bräuchtest?
      Die Sortierung für die Namenslisten mit Wert, also die Sortierung nach Wert und nicht alphabetisch wäre für die Alexa Ansagen und auch Telegram/E-Mail meiner Meinung nach schöner, weil dann bei z.B. mehreren leeren Batterien die mit dem schlechtesten Werten zuerst angesagt werden würden.
      Bei Listen ohne Wert ist alphabetisch hingegen genau richtig, denke ich.
      s.bormannS
      s.bormannS
      s.bormann
      #6842
      @dslraser sagte in Test Adapter iQontrol 1.11.x Vis (Entwicklungs-Thread):
      Ist jetzt auf Github zum Testen.
      • s.bormannS s.bormann
        dslraserD
        dslraserD
        dslraser
        #6843
        @s-bormann sagte in Test Adapter iQontrol 1.11.x Vis (Entwicklungs-Thread):
        funktioniert 👍
        aber
        iQontrol startet bei mir nicht mehr ?
        s.bormannS da_WoodyD 2 Antworten Letzte Antwort
          funktioniert 👍
          aber
          s.bormannS
          s.bormannS
          s.bormann
          #6844
          funktioniert 👍
          aber
          Ich befürchte, das ist doch eine Inkompatibilität wegen des neuen Sockets. Hast Du den web-Adapter schon geupdated?
            funktioniert 👍
            aber
            dslraserD
            dslraserD
            dslraser
            #6845
            @s-bormann
            nein, ich habe nicht geupdatet. Hier ist schonmal was ? (zwei Semikolon, ist aber nur LOG, oder ?)
            s.bormannS 1 Antwort Letzte Antwort
              @s-bormann
              s.bormannS
              s.bormannS
              s.bormann
              #6846
              @s-bormann
              Ich nehme die Zeile 13591 wieder raus. Die hat einen Fehler im neuen Socket abgefangen, scheint aber jetzt Probleme mit dem alten Socket zu machen. Ich eröffne ein Issue im neuen Socket-Github, dann soll der Fehler dort gefixed werden.
                @s-bormann
                s.bormannS
                s.bormannS
                s.bormann
                #6847
                @s-bormann
                Sollte jetzt wieder laufen
                  @s-bormann
                  dslraserD
                  dslraserD
                  dslraser
                  #6848
                  macht es, danke 👍
                    funktioniert 👍
                    aber
                    da_WoodyD
                    da_WoodyD
                    da_Woody
                    #6849
                    @dslraser jetzt schon egal, aber da war doch was mit siocketio und web 4.0. gestern doch zurückgenommen und dann 4.0.1 aufgetaucht.
                    ich hatte zwar keine probs, aber es gab themen dazu...
                    gruß vom Woody
                      @s-bormann
                          "common": {
                            "write": false
                          "type": "channel",
                          "native": {},
                          "acl": {
                            "object": 1636,
                          "common": {
                            "name": "Haustür ",
                            "write": false
                          "type": "channel",
                          "native": {},
                          "acl": {
                            "object": 1636,
                          "common": {
                            "role": "value",
                            "type": "number",
                            "write": true,
                            "states": {
                              "0": "NO_ACTION",
                              "1": "UNLOCK",
                              "2": "LOCK",
                              "3": "UNLATCH",
                              "4": "LOCK_N_GO",
                          "type": "state",
                          "native": {},
                          "acl": {
                            "object": 1636,
                            "state": 1636,
                          "common": {
                            "role": "button",
                            "type": "boolean",
                            "write": true,
                            "read": false
                          "type": "state",
                          "native": {},
                          "acl": {
                            "object": 1636,
                            "state": 1636,
                          "common": {
                            "role": "button",
                            "type": "boolean",
                            "write": true,
                            "read": false
                          "type": "state",
                          "native": {},
                          "acl": {
                            "object": 1636,
                            "state": 1636,
                          "common": {
                            "role": "button",
                            "type": "boolean",
                            "write": true,
                            "read": false
                          "type": "state",
                          "native": {},
                          "acl": {
                            "object": 1636,
                            "state": 1636,
                          "common": {
                            "role": "button",
                            "type": "boolean",
                            "write": true,
                            "read": false
                          "type": "state",
                          "native": {},
                          "acl": {
                            "object": 1636,
                            "state": 1636,
                          "common": {
                            "role": "button",
                            "type": "boolean",
                            "write": true,
                            "read": false
                          "type": "state",
                          "native": {},
                          "acl": {
                            "object": 1636,
                            "state": 1636,
                          "common": {
                            "role": "value",
                            "type": "number",
                            "write": false
                          "type": "state",
                          "native": {},
                          "acl": {
                            "object": 1636,
                            "state": 1636,
                          "common": {
                            "role": "text",
                            "type": "string",
                            "write": false
                          "type": "state",
                          "native": {},
                          "acl": {
                            "object": 1636,
                            "state": 1636,
                          "common": {
                            "role": "value",
                            "type": "number",
                            "write": false
                          "type": "state",
                          "native": {},
                          "acl": {
                            "object": 1636,
                            "state": 1636,
                          "common": {
                            "write": false
                          "type": "channel",
                          "native": {},
                          "acl": {
                            "object": 1636,
                          "common": {
                            "role": "value",
                            "type": "number",
                            "write": false
                          "type": "state",
                          "native": {},
                          "acl": {
                            "object": 1636,
                            "state": 1636,
                          "common": {
                            "role": "text",
                            "type": "string",
                            "write": false
                          "type": "state",
                          "native": {},
                          "acl": {
                            "object": 1636,
                            "state": 1636,
                          "common": {
                            "write": false
                          "type": "channel",
                          "native": {},
                          "acl": {
                            "object": 1636,
                          "common": {
                            "role": "value",
                            "type": "number",
                            "write": false
                          "type": "state",
                          "native": {},
                          "acl": {
                            "object": 1636,
                            "state": 1636,
                          "common": {
                            "type": "boolean",
                            "write": true,
                            "read": false
                          "type": "state",
                          "native": {},
                          "acl": {
                            "object": 1636,
                            "state": 1636,
                          "common": {
                            "type": "boolean",
                            "write": true,
                            "read": false
                          "type": "state",
                          "native": {},
                          "acl": {
                            "object": 1636,
                            "state": 1636,
                          "common": {
                            "role": "value",
                            "type": "number",
                            "write": false,
                            "states": {
                              "2": "Nuki Opener"
                          "type": "state",
                          "native": {},
                          "acl": {
                            "object": 1636,
                            "state": 1636,
                          "common": {
                            "role": "value",
                            "type": "number",
                            "write": false,
                            "states": {
                              "0": "UNAVAILABLE",
                              "1": "DEACTIVATED",
                              "2": "DOOR_CLOSED",
                              "3": "DOOR_OPENED",
                              "5": "CALIBRATING"
                            "custom": {
                              "iqontrol.0": {
                                "0": "",
                                "1": "",
                                "2": "",
                                "enabled": true,
                                "invert": false,
                                "confirm": false,
                                "pincode": "",
                                "step": "",
                                "roundDigits": 2,
                                "timeFormat": "x",
                                "readonly": false,
                                "unit": "",
                                "min": "",
                                "max": "",
                                "type": "number",
                                "role": "value",
                                "targetValues": "",
                                "states": {
                          "type": "state",
                          "native": {},
                          "acl": {
                            "object": 1636,
                            "state": 1636,
                          "ts": 1642363067003
                          "common": {
                            "role": "text",
                            "type": "string",
                            "write": false
                          "type": "state",
                          "native": {},
                          "acl": {
                            "object": 1636,
                            "state": 1636,
                          "common": {
                            "role": "date",
                            "type": "string",
                            "write": false
                          "type": "state",
                          "native": {},
                          "acl": {
                            "object": 1636,
                            "state": 1636,
                          "common": {
                            "role": "date",
                            "type": "string",
                            "write": false
                          "type": "state",
                          "native": {},
                          "acl": {
                            "object": 1636,
                            "state": 1636,
                          "common": {
                            "role": "value",
                            "type": "number",
                            "write": false,
                            "states": {
                              "1": "LOCKED",
                              "2": "UNLOCKING",
                              "3": "UNLOCKED",
                              "4": "LOCKING",
                              "5": "UNLATCHED",
                              "7": "UNLATCHING",
                              "255": "UNDEFINED"
                            "custom": {
                              "iqontrol.0": {
                                "0": "",
                                "1": "",
                                "3": "",
                                "enabled": true,
                                "invert": false,
                                "confirm": false,
                                "pincode": "",
                                "step": "",
                                "roundDigits": 2,
                                "timeFormat": "x",
                                "readonly": false,
                                "unit": "",
                                "unit_zero": "",
                                "unit_one": "",
                                "min": "",
                                "max": "",
                                "type": "number",
                                "role": "value",
                                "targetValues": {},
                                "states": {
                                  "1": "true",
                                  "3": "false"
                          "type": "state",
                          "native": {},
                          "acl": {
                            "object": 1636,
                            "state": 1636,
                          "ts": 1642363118406
                          "common": {
                            "type": "boolean",
                            "write": false,
                            "states": {
                              "0": "false",
                              "1": "true",
                              "2": "false",
                              "3": "false",
                              "4": "true",
                              "5": "false",
                              "6": "false",
                              "7": "false",
                              "254": "false",
                              "255": "false"
                          "type": "state",
                          "native": {},
                          "acl": {
                            "object": 1636,
                            "state": 1636,
                          "ts": 1641742002315
                          "common": {
                            "role": "value",
                            "type": "number",
                            "write": false,
                            "states": {
                              "1": "PAIRING",
                              "2": "NORMAL",
                              "3": "CONTINUOUS",
                              "4": "MAINTENANCE"
                          "type": "state",
                          "native": {},
                          "acl": {
                            "object": 1636,
                            "state": 1636,
                          "common": {
                            "role": "value",
                            "type": "number",
                            "write": false,
                            "states": {
                              "2": "Nuki Opener"
                          "type": "state",
                          "native": {},
                          "acl": {
                            "object": 1636,
                            "state": 1636,
                        • Typ: Bool
                        • Rolle: Schalter
                      J
                      J
                      J.M
                      #6850
                      @s-bormann Dank deiner Bilder und der Anpassung habe ich es jetzt auch hinbekommen. Habe auch ein Nuki verbaut und auch schon mehrere Sachen vorher probiert, ohne Erfolg. Endlich Zeigt er den richtigen Status an. Danke
                      • s.bormannS
                        s.bormannS
                        s.bormann
                        schrieb am zuletzt editiert von s.bormann
                        #6851
                        Soo, ich glaube die Listen nähern sich der finalen Version:
                        Als vorerst letztes geplantes Feature habe ich jetzt noch LOGs eingefügt. Damit kann man Änderungen an Datenpunkten loggen und als JSON-Table visualisieren.
                        Als Beispiel habe ich das bei den Service-Messages mal mit eingefügt. Ein passendes Widget wird dabei auch gleich erstellt.
                        Ergebnis:
                        da_WoodyD JLegJ 2 Antworten Letzte Antwort
                          Ergebnis:
                          da_WoodyD
                          da_WoodyD
                          da_Woody
                          #6852
                          @s-bormann hehe, ich bin froh, wenn ich keine logs sehe! :D
                          gruß vom Woody
                          • dirk1962D dirk1962
                            Hallo @dslraser,
                            in den alten Blocklys hast Du zum Schluß die Versions-Nr. mit angezeigt.
                            Hat keine Eile, könnte aber für die Zukunft durchaus Sinn machen.
                            dslraserD
                            dslraserD
                            dslraser
                            #6853
                            @dirk1962 sagte in Test Adapter iQontrol 1.11.x Vis (Entwicklungs-Thread):
                            Hallo @dslraser,
                            Hallo Dirk,
                            mit der Versionsnummer hattest Du natürlich recht.
                            Ich lade nachher mal eine neue Version (0.2) hoch. In dieser Version habe ich noch einiges geändert.
                            Diese Version soll als Vorlage dienen für alle Geräte/Listen mit „zwei Zuständen“.
                            Mit zwei Zuständen meine ich z.B
                            • Steckdosen an/aus
                            • Lichter an/aus
                            • Bewegungsmelder aktiv/inaktiv
                            • Batterien LOWBAT leer/sind okay
                            • Batterien in Prozent kleiner X Prozent/sind okay
                            • Batterien in Volt kleiner X Volt/sind okay
                            • usw. usw. usw.
                            Für reine Listen wie Temperaturen/Luftfeuchtigkeit usw. mache ich noch eine kleinere Version als Vorlage.
                            Eine Version mit 3 Zuständen kommt dann später noch. Das sind z.B. Fenster/Türen oder Rollos usw.
                            Die könnten ja z.B. geschlossen/gekippt oder geöffnet sein.
                            So müsste man mit 3 Blocklys alles abdecken können. (und die Pflege wird dann für mich einfacher)
                            PS: In dieser Version habe ich noch etwas neues eingebaut, wenn Alexa verwendet wird. Wenn also Alexa_verwenden auf wahr steht, dann wird nach dem speichern bzw. beim Blockly Start der iot Adapter, wenn vorhanden die Instanz 0 und die Instanz 1 neu gestartet. Damit erübrigt sich dann das öffnen und schließen des iot Adapters vor einer neuen Geräte suche. Durch diesen Neustart sollten neue Geräte direkt gepuscht werden und von Alexa in der Amazon Gerätesuche immer gefunden werden. 22.02.2022 Erstmal wieder deaktiviert.
                            PPS: Ich habe vorhin alle meine Blockly und dazugehörigen Datenpunkte gelöscht und habe in ca. 30 Minuten mit der Vorlage (0.2) alle diese Blockly (bis auf Fenster und Türen) neu erstellt. Ich habe aber auch alles so benannt wie vorher. Alle Ansagen (Routinen) sowie Telegram/EMAIL und die schon bestehenden Widget und andere iQontrol Einstellungen funktionierten wie vorher. In der Vorlage müssen dann nur die Einstellungen (also die Variablen) angepasst werden.
                            EDIT: hier nun mal zum testen die Vorlage 2 in der Version 0.2 (in dieser Vorlage sind noch meine Einstellungen für Batterien---LOWBAT. Wenn benötigt, dann kann ich noch ein weiteres Beispiel mit meinen Voreinstellungen zum Vergleich wie ich was eingestellt habe hier rein stellen)
                            Vorlage_2_Version_0_2.zip
                            EDIT2: hier nun mal zum testen die Vorlage 1 in der Version 0.2 (in dieser Vorlage sind noch meine Einstellungen für Temperaturen)
                            Vorlage_1_Version_0_2.zip
                            EDIT: 07.02.2022
                            Bisher war hier nach dem erstellen der Listen immer ein Leerzeichen nach dem Komma oder nach dem Semikolon. Ich habe eben eine neue Liste erstellt, die scheint jetzt ohne Leerzeichen zu sein.
                            Ich habe die beiden Vorlagen (Vorlage_01 und Vorlage_02) darauf angepasst.
                            Vorlage_1_Version_0_3.zip
                            Vorlage_2_Version_0_3.zip
                            je nach dem ob mit oder ohne Leerzeichen erfolgt ein Zeilenumbruch, oder eben nicht
                            dirk1962D 1 Antwort Letzte Antwort
                            • M martinschm
                              @deifel said in [Neuer Adapter] Visualisierung iQontrol:
                              Vielen Dank für Deine Arbeit und die Weiterentwicklung bzw. Verbesserung und Behebung der Bugs! - der Adapter ist echt klasse und hat jetzt mein Material UI bzw. VIS abgelöst.
                              Nachfolgend einige Bilder meiner Config.
                              Mein aktuell größtes Problem und weshalb meine Frau die alte VIS wieder haben will^^:D ist die Tatsache, dass die Kacheln leider
                              zu groß sind und die direkten Anzeigen der Kameras nicht geht (mit VIS hatten wir ein 3-Sekunden-Intervall-Live-Bild für die Cams) - gleiches gilt für unseren Kalender - den müssen wir über IQontrol über ein Popup aufrufen - eine direkte Anzeige der Termine ist aktuell nicht möglich.
                              Wir haben einen 15 Zoll TFT an der Wand. Ich habe schon diverse Browser versucht (Android), um dauerhaft zu skalieren... Aber leider gibt es da keine Lösung.
                              Auf unserer Startseite bekommen wir deshalb nicht alle Werte angezeigt, welche wir benötigen bzw. müssen ständig scrollen oder das ganze auf mehrere Seiten aufteilen.
                              Obwohl der Platz dafür eigentlich da wäre - die Kacheln würden halb so groß reichen. Das Problem mit dem großen Abstand oben haben wir ebenfalls. Bringt auch nicht, die Beschriftung oben auf Schriftgröße 1 zu stellen. Da könnte man zumindest etwas Platz "reinholen".
                              Aber für den aktuellen Stand ist das schonmal richtig top und wie man sieht, wird ja fleisig am Adapter gearbeitet - somit dürfen wir uns glaube ich noch freuen, wenn der Adapter weiterentwickelt wird:)
                              Wie misst du den Ölstand und -verbrauch?
                              A
                              A
                              Aachen1305
                              #6854
                              @martinschm
                              Kannst Du mir verraten, wie Du die Post Benachrichtigung gemacht hast?
                              Stephan
                              • A Aachen1305
                                @martinschm
                                Stephan
                                M
                                M
                                martinschm
                                #6855
                                @aachen1305 said in Test Adapter iQontrol 1.11.x Vis (Entwicklungs-Thread):
                                @martinschm
                                Stephan
                                Ich glaube du verwechselst mich. Sowas hab ich nicht umgesetzt.
                                A 1 Antwort Letzte Antwort
                                • M martinschm
                                  @martinschm
                                  Stephan
                                  A
                                  A
                                  Aachen1305
                                  #6856
                                  @martinschm
                                  Es scheint so.
                                  Bin ich bei den 6500 Beiträgen wohl durcheinander gekommen.
                                  Sorry, dacht Du hättest eine Kachel mit der Post Benachrichtigung in deiner Vis gehabt.
                                  Such ich mich nochmals durch 😀
                                    Hallo @dslraser,
                                    Hallo Dirk,
                                    • Steckdosen an/aus
                                    • Lichter an/aus
                                    • usw. usw. usw.
                                    EDIT: 07.02.2022
                                    dirk1962D
                                    dirk1962D
                                    dirk1962
                                    #6857
                                    Hallo @dslraser,
                                    die Idee mit den Vorlagen finde ich gut. Dann kann jeder selbst entscheiden, was er wie darstellen will.
                                    Außerdem ist es für Dich sicher einfacher, wenn Du nur drei Vorlagen pflegen musst.
                                    Vorlage 1 habe ich für Temperaturen, Luftfeuchtigkeit und Batterien Volt verwendet. Bei den Batterien wird mir dann die Spannung jeder Batterie angezeigt. Da ich bei LOWBAT sehe, welche Batterien leer sind reicht mir das im Moment. Vorlage 2 habe ich für Lichter, Steckdosen, Bewegungsmelder, Batterien LOWBAT, Fenster und Türen verwendet. Da ich bei Fenster und Türen nur geschlossen und geöffnet habe, komme ich mit Vorlage 2 perfekt zurecht. Alle Blocklys funktionieren und auch die Alexa-Ansagen sind okay.
                                    Was ich noch nicht hinbekomme sind die Smileys, wie Du sie bz. B. bei Bewegungsmelder und Steckdosen hast. Ich vermute, dass ich da noch was bei Icon-Replacement einstellen muss.
                                    Vielen Dank für Deine tolle Arbeit 👍 .
                                    NUC8i5 mit Proxmox; Raspberrymatic in VM, iobroker, Motioneye, infuxDB und Grafana in CT.
                                      Hallo @dslraser,
                                      dslraserD
                                      dslraserD
                                      dslraser
                                      #6858
                                      Wenn Du die Listenansicht in iQontrol meinst...?
                                      Da habe ich z.B. das hier
                                      meine alias sind so eingestellt
                                      Vielen Dank für Deine tolle Arbeit .
                                      Vielen Dank für das Feedback.👍
                                      • da_WoodyD
                                        da_WoodyD
                                        da_Woody
                                        #6859
                                        @dslraser ich weis ja nicht, wie sich das auf die blocklys auswirkt...
                                        hab gestern mal testweise den js-controler 4 installiert. das tumbnail script hat auf jeden fall nicht funktioniert. nach downgrade auf 3.3.22 ist es wieder gegangen...
                                        gruß vom Woody
                                        dslraserD dirk1962D 2 Antworten Letzte Antwort
                                        • da_WoodyD da_Woody
                                          dslraserD
                                          dslraserD
                                          dslraser
                                          #6860
                                          @da_woody sagte in Test Adapter iQontrol 1.11.x Vis (Entwicklungs-Thread):
                                          was ist das tumbnail script ?
                                          84.0k
                                          1.4m
