  4. [iot] iot-Adapter verbindet sich nicht bzw Verbindung ist "gelb"
    5.3k
cloud
415 Beiträge 76 Kommentatoren 109.3k Aufrufe 44 Beobachtet
  • A Australier
    @Thomas-Braun said in [iot] iot-Adapter verbindet sich nicht bzw Verbindung ist "gelb":
    iobroker fix
    root@20c8e6bb5f55:/opt/iobroker# iobroker fix
    Commands:
    iobroker setup [--objects <host>] [--states <host>] [custom]
    iobroker start
    iobroker stop
    iobroker start <adapter>
    iobroker stop <adapter>
    iobroker start all
    iobroker restart
    iobroker restart <adapter>
    iobroker info
    iobroker logs [adapter] [--watch] [--lines=1000]
    iobroker add <adapter> [desiredNumber] [--enabled] [--host <host>] [--port <port>]
    iobroker install <adapter>
    iobroker url <url> [<name>]
    iobroker del <adapter>
    iobroker del <adapter>.<instance>
    iobroker update [repository url] [--updatable/--u] [--installed/--i]
    iobroker upgrade [repository url]
    iobroker upgrade self [repository url]
    iobroker upgrade <adapter> [repository url]
    iobroker upload <pathToLocalFile> <pathIniobroker>
    iobroker upload all
    iobroker upload <adapter>
    iobroker object get <id>
    iobroker object set <id> <json-value>
    iobroker object set <id> propertyname=value
    iobroker object del <id|pattern> [--yes]
    iobroker object chmod <object-mode> [state-mode] <id>
    iobroker object chown <user> <group> <id>
    iobroker object list <id>
    iobroker state get <id>
    iobroker state getplain <id> [--pretty]
    iobroker state getvalue <id>
    iobroker state set <id> <value> [ack]
    iobroker state del <id>
    iobroker message <adapter>[.instanceid] <command> [<message>]
    iobroker list <type> [filter]
    iobroker chmod <mode> <file>
    iobroker chown <user> <group> <file>
    iobroker touch <file>
    iobroker rm <file>
    iobroker file read <iobroker-path-to-read> [<filesystem-path-to-write>]
    iobroker file write <filesystem-path-to-read> <iobroker-path-to-write>
    iobroker file rm <iobroker-path-to-delete>
    iobroker file sync
    iobroker user add <user> [--ingroup group] [--password pass]
    iobroker user del <user>
    iobroker user passwd <user> [--password pass]
    iobroker user enable <user>
    iobroker user disable <user>
    iobroker user get <user>
    iobroker user check <user> [--password pass]
    iobroker group add <group>
    iobroker group del <group>
    iobroker group list <group>
    iobroker group enable <group>
    iobroker group disable <group>
    iobroker group get <group>
    iobroker group adduser <group> <user>
    iobroker group deluser <group> <user>
    iobroker host this
    iobroker host <hostname>
    iobroker host set <hostname>
    iobroker host remove <hostname>
    iobroker set <adapter>.<instance> [--port port] [--ip address] [--ssl true|false]
    iobroker license <license.file or license.text>
    iobroker cert create
    iobroker cert view [<certificate name>]
    iobroker clean
    iobroker backup
    iobroker restore <backup name or path>
    iobroker validate <backup name or path>
    iobroker <command> --timeout 5000
    iobroker status [all]
    iobroker repo [name]
    iobroker repo add <name> <path or url>
    iobroker repo set <name>
    iobroker repo del <name>
    iobroker uuid
    iobroker unsetup
    iobroker fix
    iobroker multihost <enable|disable> [--secure true|false]
    iobroker multihost browse
    iobroker multihost connect
    iobroker compact status
    iobroker compact <enable|on|disable|off>
    iobroker compact <adapter>.<instance> status
    iobroker compact <adapter>.<instance> group <group-id>
    iobroker compact <adapter>.<instance> <disable|off>
    iobroker compact <adapter>.<instance> <enable|on> [group-id]
    iobroker version [adapter]
    iobroker [adapter] -v
    Optionen:
      --help     Hilfe anzeigen  [boolean]
      --version  Version anzeigen  [boolean]
    harrymH Offline
    harrymH Offline
    harrym
    #181
    @Australier zuerst ..... iobroker stop ;)
    ASRock FM2A88X-ITX+ mit 32GB RAM, 128GB SSD mit Proxmox, 3x1 TB SSD als RAID mit CT und VMs.
    A 1 Antwort Letzte Antwort
    • harrymH harrym
      Australier
      #182
      @harrym
      root@20c8e6bb5f55:/opt/iobroker# iobroker stop
      iobroker controller daemon is not running
      Commands:
      iobroker start
      iobroker stop
      iobroker start all
      iobroker restart
      iobroker info
      iobroker upload all
      iobroker rm <file>
      iobroker file sync
      iobroker host this
      iobroker clean
      iobroker backup
      iobroker uuid
      iobroker unsetup
      iobroker fix
      Optionen:
      root@20c8e6bb5f55:/opt/iobroker# iobroker start
      Starting iobroker controller daemon...
      iobroker controller daemon started. PID: 2304
      A harrymH 2 Antworten Letzte Antwort
      • A Australier
        Hallo, ich bekomme den IoT-Adapter nicht mehr Gelb, geschweige denn Grün. Davor hat er monatelang ohne Probleme funktioniert, dann war er auf einmal Rot. Ich vermute das letzte oder vorletzte Update des Admin-Adapters hat dies bewirkt, bin mir aber nicht ganz sicher.
        Die nachfolgende Fehlermeldung erhalte ich immer, unabhängig davon ob ich den IoT-Adapter vorher deinstalliert habe und/oder iobroker komplett neu gestartet habe über Portainer. Bei mir läuft iobroker im Docker-Container von buanet mit aktuellem Stand (Recreate pull last image, heute durchgeführt):
        "startInstance system.adapter.iot.0: required adapter "admin" has wrong version. Installed "3.7.8", required ">=4.0.1"! ".
        Installiert ist:
        • der Admin-Adapter in der Version 4.0.10
        • der IoT-Adapter in der Version 1.4.18
        • der Js-Controller in der Version 2.2.9
        PW habe ich ebenfalls schon gewechselt und ich kann mich auch damit unter dem Pro-Account im Internet anmelden, aber soweit fährt der Adapter ja gar nicht hoch, da er der Meinung ist der Admin-Adapter ist zu niedrig. Was kann ich machen um das Problem zu beheben, hat jemand eine Idee?
        Nur den Admin-Adapter habe ich auch schon neu gestartet hat aber nichts gebracht. Ebenso die komplette Deinstallation des IoT-Adapters, mit Neustart von iobroker und Neuinstallation des IoT-Adapter danach, die Fehlermeldung und das Fehlerbild bleibt gleich.
        Beste Grüße
        Alexander
        crunchipC Offline
        crunchipC Offline
        #183
        @Australier sagte in [iot] iot-Adapter verbindet sich nicht bzw Verbindung ist "gelb":
        @Thomas-Braun siehe FAQ https://forum.iobroker.net/post/231178
        • A Australier
          @harrym
          Commands:
          iobroker start
          iobroker stop
          iobroker start all
          iobroker restart
          iobroker info
          iobroker upload all
          iobroker rm <file>
          iobroker file sync
          iobroker host this
          iobroker clean
          iobroker backup
          iobroker uuid
          iobroker unsetup
          iobroker fix
          Optionen:
          Australier
          #184
          @Australier nach Neustart ist der Admin-Adapter immer noch auf der alten Version:
          root@20c8e6bb5f55:/opt/iobroker# iobroker list adapters
          system.adapter.admin                   : admin          - v3.7.8
          system.adapter.hm-rpc                  : hm-rpc         - v1.14.2
          system.adapter.hm-rega                 : hm-rega        - v2.5.5
          system.adapte
          ich versuche jetzt noch einmal die version, update und upgrade-Kommandos, mal schauen ob er sie jetzt nimmt.
          • A Australier
            @harrym
            Commands:
            iobroker start
            iobroker stop
            iobroker start all
            iobroker restart
            iobroker info
            iobroker upload all
            iobroker rm <file>
            iobroker file sync
            iobroker host this
            iobroker clean
            iobroker backup
            iobroker uuid
            iobroker unsetup
            iobroker fix
            Optionen:
            harrymH Offline
            harrymH Offline
            harrym
            #185
            @Australier du musst de "alte" variante vom fixer benutzen !
            • harrymH harrym
              Australier
              #186
              @harrym said in [iot] iot-Adapter verbindet sich nicht bzw Verbindung ist "gelb":
              system.adapter.web                     : web            - v3.0.8
              system.adapter.icons-mfd-png           : icons-mfd-png  - v1.0.2
              system.adapter.dwd                     : dwd            - v2.4.6
              system.adapter.icons-fatcow-hosting    : icons-fatcow-hosting - v0.1.0
              system.adapter.icons-ultimate-png      : icons-ultimate-png - v1.0.1
              system.adapter.icons-addictive-flavour-png: icons-addictive-flavour-png - v0.1.0
              system.adapter.icons-open-icon-library-png: icons-open-icon-library-png - v0.1.3
              system.adapter.icons-icons8            : icons-icons8   - v0.0.1
              system.adapter.tankerkoenig            : tankerkoenig   - v1.0.4
              system.adapter.hue                     : hue            - v3.2.3
              system.adapter.fritzbox                : fritzbox       - v0.2.1
              system.adapter.yamaha                  : yamaha         - v0.3.19
              system.adapter.samsung                 : samsung        - v0.2.9
              system.adapter.telegram                : telegram       - v1.5.9
              system.adapter.flot                    : flot           - v1.9.2
              system.adapter.scenes                  : scenes         - v1.1.0
              system.adapter.yr                      : yr             - v2.0.3
              system.adapter.find-my-iphone          : find-my-iphone - v0.2.15
              system.adapter.rickshaw                : rickshaw       - v1.0.0
              system.adapter.icons-material-png      : icons-material-png - v0.1.0
              system.adapter.weatherunderground      : weatherunderground - v3.1.6
              system.adapter.icons-material-svg      : icons-material-svg - v0.1.0
              system.adapter.sayit                   : sayit          - v1.9.4
              system.adapter.email                   : email          - v1.0.5
              system.adapter.socketio                : socketio       - v3.0.7
              system.adapter.simple-api              : simple-api     - v2.4.5
              system.adapter.javascript              : javascript     - v4.3.4
              system.adapter.text2command            : text2command   - v1.3.0
              system.adapter.ping                    : ping           - v1.4.7
              system.adapter.node-red                : node-red       - v1.13.0
              system.adapter.sql                     : sql            - v1.12.5
              system.adapter.history                 : history        - v1.9.6
              system.adapter.icons-mfd-svg           : icons-mfd-svg  - v1.0.2
              system.adapter.feiertage               : feiertage      - v1.0.17
              system.adapter.parser                  : parser         - v1.0.7
              system.adapter.tvspielfilm             : tvspielfilm    - v1.0.4
              system.adapter.upnp                    : upnp           - v1.0.16
              system.adapter.mobile                  : mobile         - v0.5.0
              system.adapter.discovery               : discovery      - v2.3.5
              system.adapter.geofency                : geofency       - v0.3.2
              system.adapter.vis-beta                : vis-beta       - v0.14.1
              system.adapter.vis                     : vis            - v1.2.4
              system.adapter.vis-timeandweather      : vis-timeandweather - v1.1.7
              system.adapter.amazon-dash             : amazon-dash    - v0.2.7
              system.adapter.radar                   : radar          - v1.1.3
              system.adapter.vis-bars                : vis-bars       - v0.1.4
              system.adapter.vis-canvas-gauges       : vis-canvas-gauges - v0.1.5
              system.adapter.vis-fancyswitch         : vis-fancyswitch - v1.1.0
              system.adapter.vis-history             : vis-history    - v1.0.0
              system.adapter.vis-hqwidgets           : vis-hqwidgets  - v1.1.4
              system.adapter.vis-jqui-mfd            : vis-jqui-mfd   - v1.0.12
              system.adapter.vis-justgage            : vis-justgage   - v1.0.2
              system.adapter.vis-keyboard            : vis-keyboard   - v0.0.2
              system.adapter.vis-lcars               : vis-lcars      - v1.0.4
              system.adapter.vis-map                 : vis-map        - v1.0.4
              system.adapter.vis-metro               : vis-metro      - v1.1.2
              system.adapter.vis-players             : vis-players    - v0.1.5
              system.adapter.vis-plumb               : vis-plumb      - v1.0.1
              system.adapter.vis-rgraph              : vis-rgraph     - v0.0.2
              system.adapter.solarwetter             : solarwetter    - v1.0.0
              system.adapter.homekit2                : homekit2       - v0.1.6
              system.adapter.yahka                   : yahka          - v0.7.1
              system.adapter.mihome-vacuum           : mihome-vacuum  - v1.1.5
              system.adapter.ical                    : ical           - v1.7.0
              system.adapter.unifi                   : unifi          - v0.4.3
              system.adapter.nut                     : nut            - v1.1.3
              system.adapter.vis-weather             : vis-weather    - v2.5.2
              system.adapter.pushover                : pushover       - v1.2.3
              system.adapter.backitup                : backitup       - v1.4.5
              system.adapter.daswetter               : daswetter      - v2.8.1
              system.adapter.cloud                   : cloud          - v3.0.3
              system.adapter.musiccast               : musiccast      - v0.1.3
              system.adapter.info                    : info           - v1.5.6
              system.adapter.influxdb                : influxdb       - v1.7.0
              system.adapter.pollenflug              : pollenflug     - v1.0.4
              system.adapter.alexa2                  : alexa2         - v3.0.5
              system.adapter.fullybrowser            : fullybrowser   - v1.0.0
              system.adapter.tr-064-community        : tr-064-community - v1.0.0
              system.adapter.shelly                  : shelly         - v3.1.6
              system.adapter.harmony                 : harmony        - v1.2.2
              Stopping iobroker controller daemon...
              iobroker controller daemon stopped.
              No "killall.sh" script found. Just stop.
              root@20c8e6bb5f55:/opt/iobroker# curl -sL https://iobroker.net/fix.sh | bash -
              library: loaded
              Library version=2020-04-12
              ioBroker or some processes are still running:
               io.admin.0
               io.web.0
               io.tankerkoenig.0
               io.hue.0
               io.yamaha.0
               io.telegram.0
               io.scenes.0
               io.email.0
               io.socketio.0
               io.javascript.0
               io.ping.0
               io.history.0
               io.hue.2
               io.hue.4
               io.hue.5
               io.unifi.0
               io.nut.0
               io.backitup.0
               io.influxdb.0
               io.pollenflug.0
               io.sql.0
               io.pushover.0
               io.fullybrowser.0
               io.shelly.0
               io.harmony.0
               io.alexa2.0
               io.dwd.0
              Please stop them first and try again!
              library: loaded
               io.admin.0
               io.web.0
               io.tankerkoenig.0
               io.hue.0
               io.yamaha.0
               io.telegram.0
               io.scenes.0
               io.email.0
               io.socketio.0
               io.javascript.0
               io.ping.0
               io.history.0
               io.hue.2
               io.hue.4
               io.hue.5
               io.unifi.0
               io.nut.0
               io.backitup.0
               io.influxdb.0
               io.pollenflug.0
               io.sql.0
               io.pushover.0
               io.fullybrowser.0
               io.shelly.0
               io.harmony.0
               io.alexa2.0
               io.ical.0
               io.ical.0
              library: loaded
               io.admin.0
               io.web.0
               io.tankerkoenig.0
               io.hue.0
               io.yamaha.0
               io.telegram.0
               io.scenes.0
               io.email.0
               io.socketio.0
               io.javascript.0
               io.ping.0
               io.history.0
               io.hue.2
               io.hue.4
               io.hue.5
               io.unifi.0
               io.nut.0
               io.backitup.0
               io.influxdb.0
               io.pollenflug.0
               io.sql.0
               io.pushover.0
               io.fullybrowser.0
               io.shelly.0
               io.harmony.0
               io.alexa2.0
               io.dwd.0
              harrymH 1 Antwort Letzte Antwort
              • A Australier
                library: loaded
                 io.admin.0
                 io.web.0
                 io.tankerkoenig.0
                 io.hue.0
                 io.yamaha.0
                 io.telegram.0
                 io.scenes.0
                 io.email.0
                 io.socketio.0
                 io.javascript.0
                 io.ping.0
                 io.history.0
                 io.hue.2
                 io.hue.4
                 io.hue.5
                 io.unifi.0
                 io.nut.0
                 io.backitup.0
                 io.influxdb.0
                 io.pollenflug.0
                 io.sql.0
                 io.pushover.0
                 io.fullybrowser.0
                 io.shelly.0
                 io.harmony.0
                 io.alexa2.0
                 io.dwd.0
                library: loaded
                 io.admin.0
                 io.web.0
                 io.tankerkoenig.0
                 io.hue.0
                 io.yamaha.0
                 io.telegram.0
                 io.scenes.0
                 io.email.0
                 io.socketio.0
                 io.javascript.0
                 io.ping.0
                 io.history.0
                 io.hue.2
                 io.hue.4
                 io.hue.5
                 io.unifi.0
                 io.nut.0
                 io.backitup.0
                 io.influxdb.0
                 io.pollenflug.0
                 io.sql.0
                 io.pushover.0
                 io.fullybrowser.0
                 io.shelly.0
                 io.harmony.0
                 io.alexa2.0
                 io.ical.0
                 io.ical.0
                library: loaded
                 io.admin.0
                 io.web.0
                 io.tankerkoenig.0
                 io.hue.0
                 io.yamaha.0
                 io.telegram.0
                 io.scenes.0
                 io.email.0
                 io.socketio.0
                 io.javascript.0
                 io.ping.0
                 io.history.0
                 io.hue.2
                 io.hue.4
                 io.hue.5
                 io.unifi.0
                 io.nut.0
                 io.backitup.0
                 io.influxdb.0
                 io.pollenflug.0
                 io.sql.0
                 io.pushover.0
                 io.fullybrowser.0
                 io.shelly.0
                 io.harmony.0
                 io.alexa2.0
                 io.dwd.0
                harrymH Offline
                harrymH Offline
                harrym
                schrieb am zuletzt editiert von harrym
                #187
                iobroker stop ..... ?
                der broker sagt dir doch eh alles, was zu tun ist ..... muss man halt auch lesen ;) (ist jetzt nicht böse gemeint!)
                • harrymH harrym
                  Australier
                  #188
                  @harrym War das das falsche Kommando?
                  harrymH A 2 Antworten Letzte Antwort
                  • A Australier
                    harrymH Offline
                    harrymH Offline
                    harrym
                    #189
                    @Australier ne! zuerst den broker mit .... iobroker stop ... stoppen ..... DANN den fixer via curl laden und ausführen.
                    • A Australier
                      Australier
                      #190
                      @Australier D. h. alle Prozesse Einzel stoppen z. B. iobroker stop admin
                      • A Australier
                        harrymH Offline
                        harrymH Offline
                        harrym
                        #191
                        @Australier NEIN!
                        einfach "iobroker stop" machen ..... dann den fixer laufen lassen .... danach wieder "iobroker start"
                        • harrymH harrym
                          @Australier NEIN!
                          Australier
                          #192
                          @harrym Das hatte ich doch mehrfach gemacht, ok ich mach es noch einmal.
                          • A Australier
                            harrymH Offline
                            harrymH Offline
                            harrym
                            #193
                            @Australier du hast aber immer versucht "iobroker fix" zu machen ^_^ nimm die ganze zeile mit dem curl ....
                            • A Australier
                              Australier
                              #194
                              @Australier ```
                              library: loaded
                              io.admin.0
                              io.web.0
                              io.tankerkoenig.0
                              io.hue.0
                              io.yamaha.0
                              io.telegram.0
                              io.scenes.0
                              io.email.0
                              io.socketio.0
                              io.javascript.0
                              io.ping.0
                              io.history.0
                              io.hue.2
                              io.hue.4
                              io.hue.5
                              io.unifi.0
                              io.nut.0
                              io.backitup.0
                              io.influxdb.0
                              io.pollenflug.0
                              io.sql.0
                              io.pushover.0
                              io.fullybrowser.0
                              io.shelly.0
                              io.harmony.0
                              io.alexa2.0
                              • A Australier
                                @Australier ```
                                library: loaded
                                io.admin.0
                                io.web.0
                                io.tankerkoenig.0
                                io.hue.0
                                io.yamaha.0
                                io.telegram.0
                                io.scenes.0
                                io.email.0
                                io.socketio.0
                                io.javascript.0
                                io.ping.0
                                io.history.0
                                io.hue.2
                                io.hue.4
                                io.hue.5
                                io.unifi.0
                                io.nut.0
                                io.backitup.0
                                io.influxdb.0
                                io.pollenflug.0
                                io.sql.0
                                io.pushover.0
                                io.fullybrowser.0
                                io.shelly.0
                                io.harmony.0
                                io.alexa2.0
                                harrymH Offline
                                harrymH Offline
                                harrym
                                #195
                                @Australier warten! g dauert bis alles gestoppt wurde .... kommt auf die hardware an!
                                • harrymH harrym
                                  #196
                                  @harrym
                                  Oder mit
                                  pkill io
                                  ran.
                                    @harrym
                                    Oder mit
                                    pkill io
                                    ran.
                                    harrymH Offline
                                    harrymH Offline
                                    harrym
                                    #197
                                    @Thomas-Braun würd ich nicht tun ..... kann ja etwas noch in gewisse dateien zurückgeschrieben werden müssen .....
                                    • harrymH harrym
                                      #198
                                      @harrym
                                      Mit der 'Hardware' da werde ich eh nicht warm.
                                        @harrym
                                        Australier
                                        #199
                                        @Thomas-Braun Die Anzahl der noch laufenden Adapter ändert sich nicht, egal wie lange ich warte.
                                        library: loaded
                                         io.admin.0
                                         io.web.0
                                         io.tankerkoenig.0
                                         io.hue.0
                                         io.yamaha.0
                                         io.telegram.0
                                         io.scenes.0
                                         io.email.0
                                         io.socketio.0
                                         io.javascript.0
                                         io.ping.0
                                         io.history.0
                                         io.hue.2
                                         io.hue.4
                                         io.hue.5
                                         io.unifi.0
                                         io.nut.0
                                         io.backitup.0
                                         io.influxdb.0
                                         io.pollenflug.0
                                         io.sql.0
                                         io.pushover.0
                                         io.fullybrowser.0
                                         io.shelly.0
                                         io.harmony.0
                                         io.alexa2.0
                                         io.dwd.0
                                        library: loaded
                                         io.admin.0
                                         io.web.0
                                         io.tankerkoenig.0
                                         io.hue.0
                                         io.yamaha.0
                                         io.telegram.0
                                         io.scenes.0
                                         io.email.0
                                         io.socketio.0
                                         io.javascript.0
                                         io.ping.0
                                         io.history.0
                                         io.hue.2
                                         io.hue.4
                                         io.hue.5
                                         io.unifi.0
                                         io.nut.0
                                         io.backitup.0
                                         io.influxdb.0
                                         io.pollenflug.0
                                         io.sql.0
                                         io.pushover.0
                                         io.fullybrowser.0
                                         io.shelly.0
                                         io.harmony.0
                                         io.alexa2.0
                                         io.ical.0
                                         io.ical.0
                                        library: loaded
                                         io.admin.0
                                         io.web.0
                                         io.tankerkoenig.0
                                         io.hue.0
                                         io.yamaha.0
                                         io.telegram.0
                                         io.scenes.0
                                         io.email.0
                                         io.socketio.0
                                         io.javascript.0
                                         io.ping.0
                                         io.history.0
                                         io.hue.2
                                         io.hue.4
                                         io.hue.5
                                         io.unifi.0
                                         io.nut.0
                                         io.backitup.0
                                         io.influxdb.0
                                         io.pollenflug.0
                                         io.sql.0
                                         io.pushover.0
                                         io.fullybrowser.0
                                         io.shelly.0
                                         io.harmony.0
                                         io.alexa2.0
                                         io.dwd.0
                                        library: loaded
                                         io.admin.0
                                         io.web.0
                                         io.tankerkoenig.0
                                         io.hue.0
                                         io.yamaha.0
                                         io.telegram.0
                                         io.scenes.0
                                         io.email.0
                                         io.socketio.0
                                         io.javascript.0
                                         io.ping.0
                                         io.history.0
                                         io.hue.2
                                         io.hue.4
                                         io.hue.5
                                         io.unifi.0
                                         io.nut.0
                                         io.backitup.0
                                         io.influxdb.0
                                         io.pollenflug.0
                                         io.sql.0
                                         io.pushover.0
                                         io.fullybrowser.0
                                         io.shelly.0
                                         io.harmony.0
                                         io.alexa2.0
                                        library: loaded
                                         io.admin.0
                                         io.web.0
                                         io.tankerkoenig.0
                                         io.hue.0
                                         io.yamaha.0
                                         io.telegram.0
                                         io.scenes.0
                                         io.email.0
                                         io.socketio.0
                                         io.javascript.0
                                         io.ping.0
                                         io.history.0
                                         io.hue.2
                                         io.hue.4
                                         io.hue.5
                                         io.unifi.0
                                         io.nut.0
                                         io.backitup.0
                                         io.influxdb.0
                                         io.pollenflug.0
                                         io.sql.0
                                         io.pushover.0
                                         io.fullybrowser.0
                                         io.shelly.0
                                         io.harmony.0
                                         io.alexa2.0
                                        library: loaded
                                         io.admin.0
                                         io.web.0
                                         io.tankerkoenig.0
                                         io.hue.0
                                         io.yamaha.0
                                         io.telegram.0
                                         io.scenes.0
                                         io.email.0
                                         io.socketio.0
                                         io.javascript.0
                                         io.ping.0
                                         io.history.0
                                         io.hue.2
                                         io.hue.4
                                         io.hue.5
                                         io.unifi.0
                                         io.nut.0
                                         io.backitup.0
                                         io.influxdb.0
                                         io.pollenflug.0
                                         io.sql.0
                                         io.pushover.0
                                         io.fullybrowser.0
                                         io.shelly.0
                                         io.harmony.0
                                         io.alexa2.0
                                        Ich werde wohl gleich das Kommando mal starten oder kann ich dadurch mehr als ein paar Daten verlieren?
                                        • A Australier
                                          library: loaded
                                           io.admin.0
                                           io.web.0
                                           io.tankerkoenig.0
                                           io.hue.0
                                           io.yamaha.0
                                           io.telegram.0
                                           io.scenes.0
                                           io.email.0
                                           io.socketio.0
                                           io.javascript.0
                                           io.ping.0
                                           io.history.0
                                           io.hue.2
                                           io.hue.4
                                           io.hue.5
                                           io.unifi.0
                                           io.nut.0
                                           io.backitup.0
                                           io.influxdb.0
                                           io.pollenflug.0
                                           io.sql.0
                                           io.pushover.0
                                           io.fullybrowser.0
                                           io.shelly.0
                                           io.harmony.0
                                           io.alexa2.0
                                           io.dwd.0
                                          library: loaded
                                           io.admin.0
                                           io.web.0
                                           io.tankerkoenig.0
                                           io.hue.0
                                           io.yamaha.0
                                           io.telegram.0
                                           io.scenes.0
                                           io.email.0
                                           io.socketio.0
                                           io.javascript.0
                                           io.ping.0
                                           io.history.0
                                           io.hue.2
                                           io.hue.4
                                           io.hue.5
                                           io.unifi.0
                                           io.nut.0
                                           io.backitup.0
                                           io.influxdb.0
                                           io.pollenflug.0
                                           io.sql.0
                                           io.pushover.0
                                           io.fullybrowser.0
                                           io.shelly.0
                                           io.harmony.0
                                           io.alexa2.0
                                           io.ical.0
                                           io.ical.0
                                          library: loaded
                                           io.admin.0
                                           io.web.0
                                           io.tankerkoenig.0
                                           io.hue.0
                                           io.yamaha.0
                                           io.telegram.0
                                           io.scenes.0
                                           io.email.0
                                           io.socketio.0
                                           io.javascript.0
                                           io.ping.0
                                           io.history.0
                                           io.hue.2
                                           io.hue.4
                                           io.hue.5
                                           io.unifi.0
                                           io.nut.0
                                           io.backitup.0
                                           io.influxdb.0
                                           io.pollenflug.0
                                           io.sql.0
                                           io.pushover.0
                                           io.fullybrowser.0
                                           io.shelly.0
                                           io.harmony.0
                                           io.alexa2.0
                                           io.dwd.0
                                          library: loaded
                                           io.admin.0
                                           io.web.0
                                           io.tankerkoenig.0
                                           io.hue.0
                                           io.yamaha.0
                                           io.telegram.0
                                           io.scenes.0
                                           io.email.0
                                           io.socketio.0
                                           io.javascript.0
                                           io.ping.0
                                           io.history.0
                                           io.hue.2
                                           io.hue.4
                                           io.hue.5
                                           io.unifi.0
                                           io.nut.0
                                           io.backitup.0
                                           io.influxdb.0
                                           io.pollenflug.0
                                           io.sql.0
                                           io.pushover.0
                                           io.fullybrowser.0
                                           io.shelly.0
                                           io.harmony.0
                                           io.alexa2.0
                                          library: loaded
                                           io.admin.0
                                           io.web.0
                                           io.tankerkoenig.0
                                           io.hue.0
                                           io.yamaha.0
                                           io.telegram.0
                                           io.scenes.0
                                           io.email.0
                                           io.socketio.0
                                           io.javascript.0
                                           io.ping.0
                                           io.history.0
                                           io.hue.2
                                           io.hue.4
                                           io.hue.5
                                           io.unifi.0
                                           io.nut.0
                                           io.backitup.0
                                           io.influxdb.0
                                           io.pollenflug.0
                                           io.sql.0
                                           io.pushover.0
                                           io.fullybrowser.0
                                           io.shelly.0
                                           io.harmony.0
                                           io.alexa2.0
                                          library: loaded
                                           io.admin.0
                                           io.web.0
                                           io.tankerkoenig.0
                                           io.hue.0
                                           io.yamaha.0
                                           io.telegram.0
                                           io.scenes.0
                                           io.email.0
                                           io.socketio.0
                                           io.javascript.0
                                           io.ping.0
                                           io.history.0
                                           io.hue.2
                                           io.hue.4
                                           io.hue.5
                                           io.unifi.0
                                           io.nut.0
                                           io.backitup.0
                                           io.influxdb.0
                                           io.pollenflug.0
                                           io.sql.0
                                           io.pushover.0
                                           io.fullybrowser.0
                                           io.shelly.0
                                           io.harmony.0
                                           io.alexa2.0
                                          Australier
                                          #200
                                          @Australier Oder ist es sicherer den Docker-Container noch einmal anzuhalten, dann neu zu starten und dann nach ioBroker stop und ca. 3 Minuten warten den Befehl ausführen?
