  4. [iot] iot-Adapter verbindet sich nicht bzw Verbindung ist "gelb"
cloud
415 Beiträge 76 Kommentatoren 115.5k Aufrufe 44 Beobachtet
  • A Australier
    @harrym
    root@20c8e6bb5f55:/opt/iobroker# iobroker stop
    iobroker controller daemon is not running
    root@20c8e6bb5f55:/opt/iobroker# iobroker fix
    Commands:
    iobroker setup [--objects <host>] [--states <host>] [custom]
    iobroker start
    iobroker stop
    iobroker start <adapter>
    iobroker stop <adapter>
    iobroker start all
    iobroker restart
    iobroker restart <adapter>
    iobroker info
    iobroker logs [adapter] [--watch] [--lines=1000]
    iobroker add <adapter> [desiredNumber] [--enabled] [--host <host>] [--port <port>]
    iobroker install <adapter>
    iobroker url <url> [<name>]
    iobroker del <adapter>
    iobroker del <adapter>.<instance>
    iobroker update [repository url] [--updatable/--u] [--installed/--i]
    iobroker upgrade [repository url]
    iobroker upgrade self [repository url]
    iobroker upgrade <adapter> [repository url]
    iobroker upload <pathToLocalFile> <pathIniobroker>
    iobroker upload all
    iobroker upload <adapter>
    iobroker object get <id>
    iobroker object set <id> <json-value>
    iobroker object set <id> propertyname=value
    iobroker object del <id|pattern> [--yes]
    iobroker object chmod <object-mode> [state-mode] <id>
    iobroker object chown <user> <group> <id>
    iobroker object list <id>
    iobroker state get <id>
    iobroker state getplain <id> [--pretty]
    iobroker state getvalue <id>
    iobroker state set <id> <value> [ack]
    iobroker state del <id>
    iobroker message <adapter>[.instanceid] <command> [<message>]
    iobroker list <type> [filter]
    iobroker chmod <mode> <file>
    iobroker chown <user> <group> <file>
    iobroker touch <file>
    iobroker rm <file>
    iobroker file read <iobroker-path-to-read> [<filesystem-path-to-write>]
    iobroker file write <filesystem-path-to-read> <iobroker-path-to-write>
    iobroker file rm <iobroker-path-to-delete>
    iobroker file sync
    iobroker user add <user> [--ingroup group] [--password pass]
    iobroker user del <user>
    iobroker user passwd <user> [--password pass]
    iobroker user enable <user>
    iobroker user disable <user>
    iobroker user get <user>
    iobroker user check <user> [--password pass]
    iobroker group add <group>
    iobroker group del <group>
    iobroker group list <group>
    iobroker group enable <group>
    iobroker group disable <group>
    iobroker group get <group>
    iobroker group adduser <group> <user>
    iobroker group deluser <group> <user>
    iobroker host this
    iobroker host <hostname>
    iobroker host set <hostname>
    iobroker host remove <hostname>
    iobroker set <adapter>.<instance> [--port port] [--ip address] [--ssl true|false]
    iobroker license <license.file or license.text>
    iobroker cert create
    iobroker cert view [<certificate name>]
    iobroker clean
    iobroker backup
    iobroker restore <backup name or path>
    iobroker validate <backup name or path>
    iobroker <command> --timeout 5000
    iobroker status [all]
    iobroker repo [name]
    iobroker repo add <name> <path or url>
    iobroker repo set <name>
    iobroker repo del <name>
    iobroker uuid
    iobroker unsetup
    iobroker fix
    iobroker multihost <enable|disable> [--secure true|false]
    iobroker multihost browse
    iobroker multihost connect
    iobroker compact status
    iobroker compact <enable|on|disable|off>
    iobroker compact <adapter>.<instance> status
    iobroker compact <adapter>.<instance> group <group-id>
    iobroker compact <adapter>.<instance> <disable|off>
    iobroker compact <adapter>.<instance> <enable|on> [group-id]
    iobroker version [adapter]
    iobroker [adapter] -v
    Optionen:
      --help     Hilfe anzeigen  [boolean]
      --version  Version anzeigen  [boolean]
    root@20c8e6bb5f55:/opt/iobroker# iobroker start
    Starting iobroker controller daemon...
    iobroker controller daemon started. PID: 2304
    Australier
    #184
    @Australier nach Neustart ist der Admin-Adapter immer noch auf der alten Version:
    root@20c8e6bb5f55:/opt/iobroker# iobroker list adapters
    system.adapter.admin                   : admin          - v3.7.8
    system.adapter.hm-rpc                  : hm-rpc         - v1.14.2
    system.adapter.hm-rega                 : hm-rega        - v2.5.5
    system.adapte
    ich versuche jetzt noch einmal die version, update und upgrade-Kommandos, mal schauen ob er sie jetzt nimmt.
    • A Australier
      @harrym
      Commands:
      iobroker start
      iobroker stop
      iobroker start all
      iobroker restart
      iobroker info
      iobroker upload all
      iobroker rm <file>
      iobroker file sync
      iobroker host this
      iobroker clean
      iobroker backup
      iobroker uuid
      iobroker unsetup
      iobroker fix
      Optionen:
      harrymH Offline
      harrymH Offline
      harrym
      #185
      @Australier du musst de "alte" variante vom fixer benutzen !
      curl -sL https://iobroker.net/fix.sh | bash -
      ASRock FM2A88X-ITX+ mit 32GB RAM, 128GB SSD mit Proxmox, 3x1 TB SSD als RAID mit CT und VMs.
      • harrymH harrym
        Australier
        #186
        @harrym said in [iot] iot-Adapter verbindet sich nicht bzw Verbindung ist "gelb":
        system.adapter.web                     : web            - v3.0.8
        system.adapter.icons-mfd-png           : icons-mfd-png  - v1.0.2
        system.adapter.dwd                     : dwd            - v2.4.6
        system.adapter.icons-fatcow-hosting    : icons-fatcow-hosting - v0.1.0
        system.adapter.icons-ultimate-png      : icons-ultimate-png - v1.0.1
        system.adapter.icons-addictive-flavour-png: icons-addictive-flavour-png - v0.1.0
        system.adapter.icons-open-icon-library-png: icons-open-icon-library-png - v0.1.3
        system.adapter.icons-icons8            : icons-icons8   - v0.0.1
        system.adapter.tankerkoenig            : tankerkoenig   - v1.0.4
        system.adapter.hue                     : hue            - v3.2.3
        system.adapter.fritzbox                : fritzbox       - v0.2.1
        system.adapter.yamaha                  : yamaha         - v0.3.19
        system.adapter.samsung                 : samsung        - v0.2.9
        system.adapter.telegram                : telegram       - v1.5.9
        system.adapter.flot                    : flot           - v1.9.2
        system.adapter.scenes                  : scenes         - v1.1.0
        system.adapter.yr                      : yr             - v2.0.3
        system.adapter.find-my-iphone          : find-my-iphone - v0.2.15
        system.adapter.rickshaw                : rickshaw       - v1.0.0
        system.adapter.icons-material-png      : icons-material-png - v0.1.0
        system.adapter.weatherunderground      : weatherunderground - v3.1.6
        system.adapter.icons-material-svg      : icons-material-svg - v0.1.0
        system.adapter.sayit                   : sayit          - v1.9.4
        system.adapter.email                   : email          - v1.0.5
        system.adapter.socketio                : socketio       - v3.0.7
        system.adapter.simple-api              : simple-api     - v2.4.5
        system.adapter.javascript              : javascript     - v4.3.4
        system.adapter.text2command            : text2command   - v1.3.0
        system.adapter.ping                    : ping           - v1.4.7
        system.adapter.node-red                : node-red       - v1.13.0
        system.adapter.sql                     : sql            - v1.12.5
        system.adapter.history                 : history        - v1.9.6
        system.adapter.icons-mfd-svg           : icons-mfd-svg  - v1.0.2
        system.adapter.feiertage               : feiertage      - v1.0.17
        system.adapter.parser                  : parser         - v1.0.7
        system.adapter.tvspielfilm             : tvspielfilm    - v1.0.4
        system.adapter.upnp                    : upnp           - v1.0.16
        system.adapter.mobile                  : mobile         - v0.5.0
        system.adapter.discovery               : discovery      - v2.3.5
        system.adapter.geofency                : geofency       - v0.3.2
        system.adapter.vis-beta                : vis-beta       - v0.14.1
        system.adapter.vis                     : vis            - v1.2.4
        system.adapter.vis-timeandweather      : vis-timeandweather - v1.1.7
        system.adapter.amazon-dash             : amazon-dash    - v0.2.7
        system.adapter.radar                   : radar          - v1.1.3
        system.adapter.vis-bars                : vis-bars       - v0.1.4
        system.adapter.vis-canvas-gauges       : vis-canvas-gauges - v0.1.5
        system.adapter.vis-fancyswitch         : vis-fancyswitch - v1.1.0
        system.adapter.vis-history             : vis-history    - v1.0.0
        system.adapter.vis-hqwidgets           : vis-hqwidgets  - v1.1.4
        system.adapter.vis-jqui-mfd            : vis-jqui-mfd   - v1.0.12
        system.adapter.vis-justgage            : vis-justgage   - v1.0.2
        system.adapter.vis-keyboard            : vis-keyboard   - v0.0.2
        system.adapter.vis-lcars               : vis-lcars      - v1.0.4
        system.adapter.vis-map                 : vis-map        - v1.0.4
        system.adapter.vis-metro               : vis-metro      - v1.1.2
        system.adapter.vis-players             : vis-players    - v0.1.5
        system.adapter.vis-plumb               : vis-plumb      - v1.0.1
        system.adapter.vis-rgraph              : vis-rgraph     - v0.0.2
        system.adapter.solarwetter             : solarwetter    - v1.0.0
        system.adapter.homekit2                : homekit2       - v0.1.6
        system.adapter.yahka                   : yahka          - v0.7.1
        system.adapter.mihome-vacuum           : mihome-vacuum  - v1.1.5
        system.adapter.ical                    : ical           - v1.7.0
        system.adapter.unifi                   : unifi          - v0.4.3
        system.adapter.nut                     : nut            - v1.1.3
        system.adapter.vis-weather             : vis-weather    - v2.5.2
        system.adapter.pushover                : pushover       - v1.2.3
        system.adapter.backitup                : backitup       - v1.4.5
        system.adapter.daswetter               : daswetter      - v2.8.1
        system.adapter.cloud                   : cloud          - v3.0.3
        system.adapter.musiccast               : musiccast      - v0.1.3
        system.adapter.info                    : info           - v1.5.6
        system.adapter.influxdb                : influxdb       - v1.7.0
        system.adapter.pollenflug              : pollenflug     - v1.0.4
        system.adapter.alexa2                  : alexa2         - v3.0.5
        system.adapter.fullybrowser            : fullybrowser   - v1.0.0
        system.adapter.tr-064-community        : tr-064-community - v1.0.0
        system.adapter.shelly                  : shelly         - v3.1.6
        system.adapter.harmony                 : harmony        - v1.2.2
        Stopping iobroker controller daemon...
        iobroker controller daemon stopped.
        No "killall.sh" script found. Just stop.
        root@20c8e6bb5f55:/opt/iobroker# curl -sL https://iobroker.net/fix.sh | bash -
        library: loaded
        Library version=2020-04-12
        ioBroker or some processes are still running:
         io.admin.0
         io.web.0
         io.tankerkoenig.0
         io.hue.0
         io.yamaha.0
         io.telegram.0
         io.scenes.0
         io.email.0
         io.socketio.0
         io.javascript.0
         io.ping.0
         io.history.0
         io.hue.2
         io.hue.4
         io.hue.5
         io.unifi.0
         io.nut.0
         io.backitup.0
         io.influxdb.0
         io.pollenflug.0
         io.sql.0
         io.pushover.0
         io.fullybrowser.0
         io.shelly.0
         io.harmony.0
         io.alexa2.0
         io.dwd.0
        Please stop them first and try again!
        library: loaded
         io.admin.0
         io.web.0
         io.tankerkoenig.0
         io.hue.0
         io.yamaha.0
         io.telegram.0
         io.scenes.0
         io.email.0
         io.socketio.0
         io.javascript.0
         io.ping.0
         io.history.0
         io.hue.2
         io.hue.4
         io.hue.5
         io.unifi.0
         io.nut.0
         io.backitup.0
         io.influxdb.0
         io.pollenflug.0
         io.sql.0
         io.pushover.0
         io.fullybrowser.0
         io.shelly.0
         io.harmony.0
         io.alexa2.0
         io.ical.0
         io.ical.0
        library: loaded
         io.admin.0
         io.web.0
         io.tankerkoenig.0
         io.hue.0
         io.yamaha.0
         io.telegram.0
         io.scenes.0
         io.email.0
         io.socketio.0
         io.javascript.0
         io.ping.0
         io.history.0
         io.hue.2
         io.hue.4
         io.hue.5
         io.unifi.0
         io.nut.0
         io.backitup.0
         io.influxdb.0
         io.pollenflug.0
         io.sql.0
         io.pushover.0
         io.fullybrowser.0
         io.shelly.0
         io.harmony.0
         io.alexa2.0
         io.dwd.0
        harrymH 1 Antwort Letzte Antwort
        • A Australier
          library: loaded
           io.admin.0
           io.web.0
           io.tankerkoenig.0
           io.hue.0
           io.yamaha.0
           io.telegram.0
           io.scenes.0
           io.email.0
           io.socketio.0
           io.javascript.0
           io.ping.0
           io.history.0
           io.hue.2
           io.hue.4
           io.hue.5
           io.unifi.0
           io.nut.0
           io.backitup.0
           io.influxdb.0
           io.pollenflug.0
           io.sql.0
           io.pushover.0
           io.fullybrowser.0
           io.shelly.0
           io.harmony.0
           io.alexa2.0
           io.dwd.0
          library: loaded
           io.admin.0
           io.web.0
           io.tankerkoenig.0
           io.hue.0
           io.yamaha.0
           io.telegram.0
           io.scenes.0
           io.email.0
           io.socketio.0
           io.javascript.0
           io.ping.0
           io.history.0
           io.hue.2
           io.hue.4
           io.hue.5
           io.unifi.0
           io.nut.0
           io.backitup.0
           io.influxdb.0
           io.pollenflug.0
           io.sql.0
           io.pushover.0
           io.fullybrowser.0
           io.shelly.0
           io.harmony.0
           io.alexa2.0
           io.ical.0
           io.ical.0
          library: loaded
           io.admin.0
           io.web.0
           io.tankerkoenig.0
           io.hue.0
           io.yamaha.0
           io.telegram.0
           io.scenes.0
           io.email.0
           io.socketio.0
           io.javascript.0
           io.ping.0
           io.history.0
           io.hue.2
           io.hue.4
           io.hue.5
           io.unifi.0
           io.nut.0
           io.backitup.0
           io.influxdb.0
           io.pollenflug.0
           io.sql.0
           io.pushover.0
           io.fullybrowser.0
           io.shelly.0
           io.harmony.0
           io.alexa2.0
           io.dwd.0
          harrymH Offline
          harrymH Offline
          harrym
          schrieb am zuletzt editiert von harrym
          #187
          @Australier sagte in [iot] iot-Adapter verbindet sich nicht bzw Verbindung ist "gelb":
          iobroker stop ..... ?
          der broker sagt dir doch eh alles, was zu tun ist ..... muss man halt auch lesen ;) (ist jetzt nicht böse gemeint!)
          • harrymH harrym
            Australier
            #188
            @harrym War das das falsche Kommando?
            harrymH A 2 Antworten Letzte Antwort
            • A Australier
              harrymH Offline
              harrymH Offline
              harrym
              #189
              @Australier ne! zuerst den broker mit .... iobroker stop ... stoppen ..... DANN den fixer via curl laden und ausführen.
              • A Australier
                Australier
                #190
                @Australier D. h. alle Prozesse Einzel stoppen z. B. iobroker stop admin
                • A Australier
                  harrymH Offline
                  harrymH Offline
                  harrym
                  #191
                  @Australier NEIN!
                  einfach "iobroker stop" machen ..... dann den fixer laufen lassen .... danach wieder "iobroker start"
                  • harrymH harrym
                    @Australier NEIN!
                    Australier
                    #192
                    @harrym Das hatte ich doch mehrfach gemacht, ok ich mach es noch einmal.
                    • A Australier
                      harrymH Offline
                      harrymH Offline
                      harrym
                      #193
                      @Australier du hast aber immer versucht "iobroker fix" zu machen ^_^ nimm die ganze zeile mit dem curl ....
                      • A Australier
                        Australier
                        #194
                        @Australier ```
                        library: loaded
                        io.admin.0
                        io.web.0
                        io.tankerkoenig.0
                        io.hue.0
                        io.yamaha.0
                        io.telegram.0
                        io.scenes.0
                        io.email.0
                        io.socketio.0
                        io.javascript.0
                        io.ping.0
                        io.history.0
                        io.hue.2
                        io.hue.4
                        io.hue.5
                        io.unifi.0
                        io.nut.0
                        io.backitup.0
                        io.influxdb.0
                        io.pollenflug.0
                        io.sql.0
                        io.pushover.0
                        io.fullybrowser.0
                        io.shelly.0
                        io.harmony.0
                        io.alexa2.0
                        • A Australier
                          @Australier ```
                          library: loaded
                          io.admin.0
                          io.web.0
                          io.tankerkoenig.0
                          io.hue.0
                          io.yamaha.0
                          io.telegram.0
                          io.scenes.0
                          io.email.0
                          io.socketio.0
                          io.javascript.0
                          io.ping.0
                          io.history.0
                          io.hue.2
                          io.hue.4
                          io.hue.5
                          io.unifi.0
                          io.nut.0
                          io.backitup.0
                          io.influxdb.0
                          io.pollenflug.0
                          io.sql.0
                          io.pushover.0
                          io.fullybrowser.0
                          io.shelly.0
                          io.harmony.0
                          io.alexa2.0
                          harrymH Offline
                          harrymH Offline
                          harrym
                          #195
                          @Australier warten! g dauert bis alles gestoppt wurde .... kommt auf die hardware an!
                          • harrymH harrym
                            #196
                            @harrym
                            Oder mit
                            pkill io
                            ran.
                              @harrym
                              Oder mit
                              pkill io
                              ran.
                              harrymH Offline
                              harrymH Offline
                              harrym
                              #197
                              @Thomas-Braun würd ich nicht tun ..... kann ja etwas noch in gewisse dateien zurückgeschrieben werden müssen .....
                              • harrymH harrym
                                #198
                                @harrym
                                Mit der 'Hardware' da werde ich eh nicht warm.
                                  @harrym
                                  Australier
                                  #199
                                  @Thomas-Braun Die Anzahl der noch laufenden Adapter ändert sich nicht, egal wie lange ich warte.
                                  library: loaded
                                   io.admin.0
                                   io.web.0
                                   io.tankerkoenig.0
                                   io.hue.0
                                   io.yamaha.0
                                   io.telegram.0
                                   io.scenes.0
                                   io.email.0
                                   io.socketio.0
                                   io.javascript.0
                                   io.ping.0
                                   io.history.0
                                   io.hue.2
                                   io.hue.4
                                   io.hue.5
                                   io.unifi.0
                                   io.nut.0
                                   io.backitup.0
                                   io.influxdb.0
                                   io.pollenflug.0
                                   io.sql.0
                                   io.pushover.0
                                   io.fullybrowser.0
                                   io.shelly.0
                                   io.harmony.0
                                   io.alexa2.0
                                   io.dwd.0
                                  library: loaded
                                   io.admin.0
                                   io.web.0
                                   io.tankerkoenig.0
                                   io.hue.0
                                   io.yamaha.0
                                   io.telegram.0
                                   io.scenes.0
                                   io.email.0
                                   io.socketio.0
                                   io.javascript.0
                                   io.ping.0
                                   io.history.0
                                   io.hue.2
                                   io.hue.4
                                   io.hue.5
                                   io.unifi.0
                                   io.nut.0
                                   io.backitup.0
                                   io.influxdb.0
                                   io.pollenflug.0
                                   io.sql.0
                                   io.pushover.0
                                   io.fullybrowser.0
                                   io.shelly.0
                                   io.harmony.0
                                   io.alexa2.0
                                   io.ical.0
                                   io.ical.0
                                  library: loaded
                                   io.admin.0
                                   io.web.0
                                   io.tankerkoenig.0
                                   io.hue.0
                                   io.yamaha.0
                                   io.telegram.0
                                   io.scenes.0
                                   io.email.0
                                   io.socketio.0
                                   io.javascript.0
                                   io.ping.0
                                   io.history.0
                                   io.hue.2
                                   io.hue.4
                                   io.hue.5
                                   io.unifi.0
                                   io.nut.0
                                   io.backitup.0
                                   io.influxdb.0
                                   io.pollenflug.0
                                   io.sql.0
                                   io.pushover.0
                                   io.fullybrowser.0
                                   io.shelly.0
                                   io.harmony.0
                                   io.alexa2.0
                                   io.dwd.0
                                  library: loaded
                                   io.admin.0
                                   io.web.0
                                   io.tankerkoenig.0
                                   io.hue.0
                                   io.yamaha.0
                                   io.telegram.0
                                   io.scenes.0
                                   io.email.0
                                   io.socketio.0
                                   io.javascript.0
                                   io.ping.0
                                   io.history.0
                                   io.hue.2
                                   io.hue.4
                                   io.hue.5
                                   io.unifi.0
                                   io.nut.0
                                   io.backitup.0
                                   io.influxdb.0
                                   io.pollenflug.0
                                   io.sql.0
                                   io.pushover.0
                                   io.fullybrowser.0
                                   io.shelly.0
                                   io.harmony.0
                                   io.alexa2.0
                                  library: loaded
                                   io.admin.0
                                   io.web.0
                                   io.tankerkoenig.0
                                   io.hue.0
                                   io.yamaha.0
                                   io.telegram.0
                                   io.scenes.0
                                   io.email.0
                                   io.socketio.0
                                   io.javascript.0
                                   io.ping.0
                                   io.history.0
                                   io.hue.2
                                   io.hue.4
                                   io.hue.5
                                   io.unifi.0
                                   io.nut.0
                                   io.backitup.0
                                   io.influxdb.0
                                   io.pollenflug.0
                                   io.sql.0
                                   io.pushover.0
                                   io.fullybrowser.0
                                   io.shelly.0
                                   io.harmony.0
                                   io.alexa2.0
                                  library: loaded
                                   io.admin.0
                                   io.web.0
                                   io.tankerkoenig.0
                                   io.hue.0
                                   io.yamaha.0
                                   io.telegram.0
                                   io.scenes.0
                                   io.email.0
                                   io.socketio.0
                                   io.javascript.0
                                   io.ping.0
                                   io.history.0
                                   io.hue.2
                                   io.hue.4
                                   io.hue.5
                                   io.unifi.0
                                   io.nut.0
                                   io.backitup.0
                                   io.influxdb.0
                                   io.pollenflug.0
                                   io.sql.0
                                   io.pushover.0
                                   io.fullybrowser.0
                                   io.shelly.0
                                   io.harmony.0
                                   io.alexa2.0
                                  Ich werde wohl gleich das Kommando mal starten oder kann ich dadurch mehr als ein paar Daten verlieren?
                                  A harrymH 2 Antworten Letzte Antwort
                                  • A Australier
                                    library: loaded
                                     io.admin.0
                                     io.web.0
                                     io.tankerkoenig.0
                                     io.hue.0
                                     io.yamaha.0
                                     io.telegram.0
                                     io.scenes.0
                                     io.email.0
                                     io.socketio.0
                                     io.javascript.0
                                     io.ping.0
                                     io.history.0
                                     io.hue.2
                                     io.hue.4
                                     io.hue.5
                                     io.unifi.0
                                     io.nut.0
                                     io.backitup.0
                                     io.influxdb.0
                                     io.pollenflug.0
                                     io.sql.0
                                     io.pushover.0
                                     io.fullybrowser.0
                                     io.shelly.0
                                     io.harmony.0
                                     io.alexa2.0
                                     io.dwd.0
                                    library: loaded
                                     io.admin.0
                                     io.web.0
                                     io.tankerkoenig.0
                                     io.hue.0
                                     io.yamaha.0
                                     io.telegram.0
                                     io.scenes.0
                                     io.email.0
                                     io.socketio.0
                                     io.javascript.0
                                     io.ping.0
                                     io.history.0
                                     io.hue.2
                                     io.hue.4
                                     io.hue.5
                                     io.unifi.0
                                     io.nut.0
                                     io.backitup.0
                                     io.influxdb.0
                                     io.pollenflug.0
                                     io.sql.0
                                     io.pushover.0
                                     io.fullybrowser.0
                                     io.shelly.0
                                     io.harmony.0
                                     io.alexa2.0
                                     io.ical.0
                                     io.ical.0
                                    library: loaded
                                     io.admin.0
                                     io.web.0
                                     io.tankerkoenig.0
                                     io.hue.0
                                     io.yamaha.0
                                     io.telegram.0
                                     io.scenes.0
                                     io.email.0
                                     io.socketio.0
                                     io.javascript.0
                                     io.ping.0
                                     io.history.0
                                     io.hue.2
                                     io.hue.4
                                     io.hue.5
                                     io.unifi.0
                                     io.nut.0
                                     io.backitup.0
                                     io.influxdb.0
                                     io.pollenflug.0
                                     io.sql.0
                                     io.pushover.0
                                     io.fullybrowser.0
                                     io.shelly.0
                                     io.harmony.0
                                     io.alexa2.0
                                     io.dwd.0
                                    library: loaded
                                     io.admin.0
                                     io.web.0
                                     io.tankerkoenig.0
                                     io.hue.0
                                     io.yamaha.0
                                     io.telegram.0
                                     io.scenes.0
                                     io.email.0
                                     io.socketio.0
                                     io.javascript.0
                                     io.ping.0
                                     io.history.0
                                     io.hue.2
                                     io.hue.4
                                     io.hue.5
                                     io.unifi.0
                                     io.nut.0
                                     io.backitup.0
                                     io.influxdb.0
                                     io.pollenflug.0
                                     io.sql.0
                                     io.pushover.0
                                     io.fullybrowser.0
                                     io.shelly.0
                                     io.harmony.0
                                     io.alexa2.0
                                    library: loaded
                                     io.admin.0
                                     io.web.0
                                     io.tankerkoenig.0
                                     io.hue.0
                                     io.yamaha.0
                                     io.telegram.0
                                     io.scenes.0
                                     io.email.0
                                     io.socketio.0
                                     io.javascript.0
                                     io.ping.0
                                     io.history.0
                                     io.hue.2
                                     io.hue.4
                                     io.hue.5
                                     io.unifi.0
                                     io.nut.0
                                     io.backitup.0
                                     io.influxdb.0
                                     io.pollenflug.0
                                     io.sql.0
                                     io.pushover.0
                                     io.fullybrowser.0
                                     io.shelly.0
                                     io.harmony.0
                                     io.alexa2.0
                                    library: loaded
                                     io.admin.0
                                     io.web.0
                                     io.tankerkoenig.0
                                     io.hue.0
                                     io.yamaha.0
                                     io.telegram.0
                                     io.scenes.0
                                     io.email.0
                                     io.socketio.0
                                     io.javascript.0
                                     io.ping.0
                                     io.history.0
                                     io.hue.2
                                     io.hue.4
                                     io.hue.5
                                     io.unifi.0
                                     io.nut.0
                                     io.backitup.0
                                     io.influxdb.0
                                     io.pollenflug.0
                                     io.sql.0
                                     io.pushover.0
                                     io.fullybrowser.0
                                     io.shelly.0
                                     io.harmony.0
                                     io.alexa2.0
                                    Australier
                                    #200
                                    @Australier Oder ist es sicherer den Docker-Container noch einmal anzuhalten, dann neu zu starten und dann nach ioBroker stop und ca. 3 Minuten warten den Befehl ausführen?
                                    • A Australier
                                      library: loaded
                                       io.admin.0
                                       io.web.0
                                       io.tankerkoenig.0
                                       io.hue.0
                                       io.yamaha.0
                                       io.telegram.0
                                       io.scenes.0
                                       io.email.0
                                       io.socketio.0
                                       io.javascript.0
                                       io.ping.0
                                       io.history.0
                                       io.hue.2
                                       io.hue.4
                                       io.hue.5
                                       io.unifi.0
                                       io.nut.0
                                       io.backitup.0
                                       io.influxdb.0
                                       io.pollenflug.0
                                       io.sql.0
                                       io.pushover.0
                                       io.fullybrowser.0
                                       io.shelly.0
                                       io.harmony.0
                                       io.alexa2.0
                                       io.dwd.0
                                      library: loaded
                                       io.admin.0
                                       io.web.0
                                       io.tankerkoenig.0
                                       io.hue.0
                                       io.yamaha.0
                                       io.telegram.0
                                       io.scenes.0
                                       io.email.0
                                       io.socketio.0
                                       io.javascript.0
                                       io.ping.0
                                       io.history.0
                                       io.hue.2
                                       io.hue.4
                                       io.hue.5
                                       io.unifi.0
                                       io.nut.0
                                       io.backitup.0
                                       io.influxdb.0
                                       io.pollenflug.0
                                       io.sql.0
                                       io.pushover.0
                                       io.fullybrowser.0
                                       io.shelly.0
                                       io.harmony.0
                                       io.alexa2.0
                                       io.ical.0
                                       io.ical.0
                                      library: loaded
                                       io.admin.0
                                       io.web.0
                                       io.tankerkoenig.0
                                       io.hue.0
                                       io.yamaha.0
                                       io.telegram.0
                                       io.scenes.0
                                       io.email.0
                                       io.socketio.0
                                       io.javascript.0
                                       io.ping.0
                                       io.history.0
                                       io.hue.2
                                       io.hue.4
                                       io.hue.5
                                       io.unifi.0
                                       io.nut.0
                                       io.backitup.0
                                       io.influxdb.0
                                       io.pollenflug.0
                                       io.sql.0
                                       io.pushover.0
                                       io.fullybrowser.0
                                       io.shelly.0
                                       io.harmony.0
                                       io.alexa2.0
                                       io.dwd.0
                                      library: loaded
                                       io.admin.0
                                       io.web.0
                                       io.tankerkoenig.0
                                       io.hue.0
                                       io.yamaha.0
                                       io.telegram.0
                                       io.scenes.0
                                       io.email.0
                                       io.socketio.0
                                       io.javascript.0
                                       io.ping.0
                                       io.history.0
                                       io.hue.2
                                       io.hue.4
                                       io.hue.5
                                       io.unifi.0
                                       io.nut.0
                                       io.backitup.0
                                       io.influxdb.0
                                       io.pollenflug.0
                                       io.sql.0
                                       io.pushover.0
                                       io.fullybrowser.0
                                       io.shelly.0
                                       io.harmony.0
                                       io.alexa2.0
                                      library: loaded
                                       io.admin.0
                                       io.web.0
                                       io.tankerkoenig.0
                                       io.hue.0
                                       io.yamaha.0
                                       io.telegram.0
                                       io.scenes.0
                                       io.email.0
                                       io.socketio.0
                                       io.javascript.0
                                       io.ping.0
                                       io.history.0
                                       io.hue.2
                                       io.hue.4
                                       io.hue.5
                                       io.unifi.0
                                       io.nut.0
                                       io.backitup.0
                                       io.influxdb.0
                                       io.pollenflug.0
                                       io.sql.0
                                       io.pushover.0
                                       io.fullybrowser.0
                                       io.shelly.0
                                       io.harmony.0
                                       io.alexa2.0
                                      library: loaded
                                       io.admin.0
                                       io.web.0
                                       io.tankerkoenig.0
                                       io.hue.0
                                       io.yamaha.0
                                       io.telegram.0
                                       io.scenes.0
                                       io.email.0
                                       io.socketio.0
                                       io.javascript.0
                                       io.ping.0
                                       io.history.0
                                       io.hue.2
                                       io.hue.4
                                       io.hue.5
                                       io.unifi.0
                                       io.nut.0
                                       io.backitup.0
                                       io.influxdb.0
                                       io.pollenflug.0
                                       io.sql.0
                                       io.pushover.0
                                       io.fullybrowser.0
                                       io.shelly.0
                                       io.harmony.0
                                       io.alexa2.0
                                      harrymH Offline
                                      harrymH Offline
                                      harrym
                                      #201
                                      @Australier start den rechner mal neu ....
                                        Australier
                                        #202
                                        Ich habe den Docker-Container und auch meinen Rechner neu gestartet, dann "iobroker stop" ausgeführt und ca. 3 Minuten gewartet, am Ergebnis hat sich nichts geändert.
                                        library: loaded
                                         io.admin.0
                                         io.web.0
                                         io.tankerkoenig.0
                                         io.hue.0
                                         io.yamaha.0
                                         io.telegram.0
                                         io.scenes.0
                                         io.email.0
                                         io.socketio.0
                                         io.javascript.0
                                         io.ping.0
                                         io.history.0
                                         io.hue.2
                                         io.hue.4
                                         io.hue.5
                                         io.unifi.0
                                         io.nut.0
                                         io.backitup.0
                                         io.influxdb.0
                                         io.pollenflug.0
                                         io.sql.0
                                         io.pushover.0
                                         io.alexa2.0
                                         io.fullybrowser.0
                                         io.shelly.0
                                         io.harmony.0
                                        Hier noch Informationen zur Version die ich vom ioBroker verwendeBildschirmfoto 2020-05-19 um 15.25.31.png
                                        • A Australier
                                          library: loaded
                                           io.admin.0
                                           io.web.0
                                           io.tankerkoenig.0
                                           io.hue.0
                                           io.yamaha.0
                                           io.telegram.0
                                           io.scenes.0
                                           io.email.0
                                           io.socketio.0
                                           io.javascript.0
                                           io.ping.0
                                           io.history.0
                                           io.hue.2
                                           io.hue.4
                                           io.hue.5
                                           io.unifi.0
                                           io.nut.0
                                           io.backitup.0
                                           io.influxdb.0
                                           io.pollenflug.0
                                           io.sql.0
                                           io.pushover.0
                                           io.alexa2.0
                                           io.fullybrowser.0
                                           io.shelly.0
                                           io.harmony.0
                                          harrymH Offline
                                          harrymH Offline
                                          harrym
                                          #203
                                          @Australier dann versuch echt mal es kill commando, das @Thomas-Braun vorgeschlagen hat ......
