  4. [Aufruf] fullyBrowser Adapter
    6.3k
fullybrowserfullybrowser adapter
289 Beiträge 45 Kommentatoren 72.0k Aufrufe 26 Beobachtet
  • 0 Offline
    0 Offline
    0018
    #201
    @arteck bei Installation aus eigener URL mit "https://github.com/arteck/ioBroker.fullybrowser" bekomme ich nur die 16.
    Mfg
    0018
    • arteckA Offline
      arteckA Offline
      arteck
      #202
      mach jetzt
      • 0 Offline
        0 Offline
        0018
        #203
        @arteck Installation hat geklappt, läuft aber nicht:
        fullybrowser.0	2019-05-03 09:57:59.281	info	terminating
        fullybrowser.0	2019-05-03 09:57:59.234	error	at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
        fullybrowser.0	2019-05-03 09:57:59.234	error	at Decoder.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
        fullybrowser.0	2019-05-03 09:57:59.234	error	at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
        fullybrowser.0	2019-05-03 09:57:59.234	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
        fullybrowser.0	2019-05-03 09:57:59.234	error	at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
        fullybrowser.0	2019-05-03 09:57:59.234	error	at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
        fullybrowser.0	2019-05-03 09:57:59.234	error	at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
        fullybrowser.0	2019-05-03 09:57:59.234	error	at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.fullybrowser/main.js:369:33)
        fullybrowser.0	2019-05-03 09:57:59.234	error	at /opt/iobroker/node_modules/iobroker.fullybrowser/main.js:508:9
        fullybrowser.0	2019-05-03 09:57:59.234	error	at getHost (/opt/iobroker/node_modules/iobroker.fullybrowser/main.js:437:5)
        fullybrowser.0	2019-05-03 09:57:59.234	error	ReferenceError: stopTimer is not defined
        fullybrowser.0	2019-05-03 09:57:59.233	error	uncaught exception: stopTimer is not defined
        fullybrowser.0	2019-05-03 09:57:59.074	info	starting. Version 0.0.17 in /opt/iobroker/node_modules/iobroker.fullybrowser, node: v8.15.1
        habe versucht den Adapter zu deinstallieren und den 16er zu installieren, ohne Erfolg. Die Deinstallation scheint erfolgreich, die Adapterversion bleibt aber auf 16 stehen, obwohl sie eigentlich gelöscht ist.
        Mfg
        0018
        • arteckA Offline
          arteckA Offline
          arteck
          #204
          man sollte nix zwischendurch machen :-)
          probier mal noch mal bitte.. von GIT
          • 0 Offline
            0 Offline
            0018
            #205
            @arteck
            host.BrokerNUC	2019-05-03 10:12:18.786	error	instance system.adapter.fullybrowser.0 terminated with code 0 (OK)
            host.BrokerNUC	2019-05-03 10:12:18.786	error	Caught by controller[0]: at emitNone (events.js:111:20)
            host.BrokerNUC	2019-05-03 10:12:18.786	error	Caught by controller[0]: at Object.onceWrapper (events.js:313:30)
            host.BrokerNUC	2019-05-03 10:12:18.786	error	Caught by controller[0]: at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/request/request.js:1083:12)
            host.BrokerNUC	2019-05-03 10:12:18.786	error	Caught by controller[0]: at Request.emit (events.js:211:7)
            host.BrokerNUC	2019-05-03 10:12:18.786	error	Caught by controller[0]: at emitOne (events.js:116:13)
            host.BrokerNUC	2019-05-03 10:12:18.786	error	Caught by controller[0]: at Request.<anonymous> (/opt/iobroker/node_modules/request/request.js:1161:10)
            host.BrokerNUC	2019-05-03 10:12:18.786	error	Caught by controller[0]: at Request.emit (events.js:214:7)
            host.BrokerNUC	2019-05-03 10:12:18.786	error	Caught by controller[0]: at emitTwo (events.js:126:13)
            host.BrokerNUC	2019-05-03 10:12:18.786	error	Caught by controller[0]: at Request.self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
            host.BrokerNUC	2019-05-03 10:12:18.786	error	Caught by controller[0]: at Request._callback (/opt/iobroker/node_modules/iobroker.fullybrowser/main.js:194:24)
            host.BrokerNUC	2019-05-03 10:12:18.785	error	Caught by controller[0]: ReferenceError: leti is not defined
            fullybrowser.0	2019-05-03 10:12:18.649	error	ReferenceError: leti is not defined at Request._callback (/opt/iobroker/node_modules/iobroker.fullybrowser/main.js:194:24) at Request.self.callback (/opt/iobroker/node_modules/request/request.
            fullybrowser.0	2019-05-03 10:12:18.648	error	uncaught exception: leti is not defined
            Mfg
            0018
            • 0 0018
              @arteck
              arteckA Offline
              arteckA Offline
              arteck
              #206
              @0018 ok das wird nix.... muss ich mir am system anschauen...
              heute abend.. installiere die Stable bitte 0.0.16..
              ich mach heute Abend ein Update
              0 1 Antwort Letzte Antwort
              • arteckA arteck
                0 Offline
                0 Offline
                0018
                #207
                @arteck Ok, leider schaffe ich es nicht den Adapter zu deinstallieren. Die 0.17 bleibt immer sichtbar. Hast du einen Tipp?
                Mfg
                0018
                • 0 0018
                  0 Offline
                  0 Offline
                  0018
                  #208
                  @0018 sagte in [Aufruf] fullyBrowser Adapter:
                  Hat sich erledigt, downgrade auf 16 mit "npm install iobroker.fullybrowser@0.0.16 --production" hat geklappt und läuft erstmal wieder
                  Mfg
                  0018
                  • liv-in-skyL Offline
                    liv-in-skyL Offline
                    liv-in-sky
                    #209
                    kurze zwischeninfo: habe 0.17 installiert. wenn ich den adapter stoppe, läuft er trotzdem noch weiter (in htop)
                    • liv-in-skyL liv-in-sky
                      arteckA Offline
                      arteckA Offline
                      arteck
                      #210
                      @liv-in-sky ne das wird die 0.0.16 sein die nicht beendet wurde..
                      • arteckA Offline
                        arteckA Offline
                        arteck
                        #211
                        so 0.0.17 sollte laufen
                        • arteckA arteck
                          liv-in-skyL Offline
                          liv-in-skyL Offline
                          liv-in-sky
                          #212
                          @arteck
                          jup - du hattest recht - neustart und getestet(aus/eingeschaltet) - funktioniert - danke dir
                          • I Online
                            I Online
                            intruder7
                            #213
                            Moin,
                            seit zwei Tagen funktioniert der Adapter nicht mehr. Meine beiden Tabs sind leer gelaufen da die Ladeüberwachung nicht mehr funktioniert. Fully ist normal über web erreichbar. Nur der Adapter baut keine Verbindung auf. Neustart, installieren der 17er Version haben nichts gebracht. Was mir aufgefallen ist, die App auf den Tabs ist aktualisiert worden und da sind einige Neuerungen bezügliche Java drin?
                            • I intruder7
                              Moin,
                              arteckA Offline
                              arteckA Offline
                              arteck
                              #214
                              @intruder7 welche Version des Fullybrowser ??
                              I 2 Antworten Letzte Antwort
                              • arteckA arteck
                                I Online
                                I Online
                                intruder7
                                #215
                                @arteck ich habe auf beiden Tabs die Version 1.31
                                • arteckA arteck
                                  I Online
                                  I Online
                                  intruder7
                                  #216
                                  @arteck Hab jetzt den Adapter nochmal komplet neu installiert. Er funktioniert trotzdem nicht. Was verwunderlich ist, Befehle sendet er. Also z.B. Sceen on. Nur sämtliche Infos erhält er nicht
                                  • I intruder7
                                    arteckA Offline
                                    arteckA Offline
                                    arteck
                                    #217
                                    @intruder7 muss ich mir mal anschauen.. vor WE wird das aber nix
                                    I 3 Antworten Letzte Antwort
                                    • arteckA arteck
                                      I Online
                                      I Online
                                      intruder7
                                      #218
                                      @arteck Lass dir Zeit. Die Tabs sind im Moment am Dauerstrom. Hoffe nur du findest eine Lösung✊
                                      • arteckA arteck
                                        I Online
                                        I Online
                                        intruder7
                                        #219
                                        @arteck Achso, und eins noch. Besteht die Möglichkeit in den Objekten anstatt der IP einen unter Einstellungen vergebenen Namen zu nutzen? Das wäre auch noch Klasse. ansonsten hat der Adapter von Anfang bis eben vor ein paar Tagen super funktioniert. 👍
                                        • arteckA arteck
                                          I Online
                                          I Online
                                          intruder7
                                          #220
                                          @arteck Hab mal geschaut bei Git. Unter Umständen hilft es schon wenn du das timeout von 2000 bei Abfrage der Infos etwas erhöhst. Die Abfrage über das REST Interface dauert ziemlich lange.
                                          function updateDevice(ip,port,psw) {
                                          var id = ip.replace(/[.\s]+/g, '_');
                                          var statusURL = 'http://' + ip + ':' + port + '/?cmd=deviceInfo&type=json&password=' + psw;
                                          var vari = '';
                                          var thisOptions = {
                                              uri: statusURL,
                                              method: "GET",
                                              timeout: 2000,
                                              followRedirect: false,
                                              maxRedirects: 0
