  4. [Aufruf] fullyBrowser Adapter
    6.6k
fullybrowserfullybrowser adapter
289 Beiträge 45 Kommentatoren 72.4k Aufrufe 26 Beobachtet
  • 0 0018
    @arteck
    host.BrokerNUC	2019-05-03 10:12:18.786	error	instance system.adapter.fullybrowser.0 terminated with code 0 (OK)
    host.BrokerNUC	2019-05-03 10:12:18.786	error	Caught by controller[0]: at emitNone (events.js:111:20)
    host.BrokerNUC	2019-05-03 10:12:18.786	error	Caught by controller[0]: at Object.onceWrapper (events.js:313:30)
    host.BrokerNUC	2019-05-03 10:12:18.786	error	Caught by controller[0]: at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/request/request.js:1083:12)
    host.BrokerNUC	2019-05-03 10:12:18.786	error	Caught by controller[0]: at Request.emit (events.js:211:7)
    host.BrokerNUC	2019-05-03 10:12:18.786	error	Caught by controller[0]: at emitOne (events.js:116:13)
    host.BrokerNUC	2019-05-03 10:12:18.786	error	Caught by controller[0]: at Request.<anonymous> (/opt/iobroker/node_modules/request/request.js:1161:10)
    host.BrokerNUC	2019-05-03 10:12:18.786	error	Caught by controller[0]: at Request.emit (events.js:214:7)
    host.BrokerNUC	2019-05-03 10:12:18.786	error	Caught by controller[0]: at emitTwo (events.js:126:13)
    host.BrokerNUC	2019-05-03 10:12:18.786	error	Caught by controller[0]: at Request.self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
    host.BrokerNUC	2019-05-03 10:12:18.786	error	Caught by controller[0]: at Request._callback (/opt/iobroker/node_modules/iobroker.fullybrowser/main.js:194:24)
    host.BrokerNUC	2019-05-03 10:12:18.785	error	Caught by controller[0]: ReferenceError: leti is not defined
    fullybrowser.0	2019-05-03 10:12:18.649	error	ReferenceError: leti is not defined at Request._callback (/opt/iobroker/node_modules/iobroker.fullybrowser/main.js:194:24) at Request.self.callback (/opt/iobroker/node_modules/request/request.
    fullybrowser.0	2019-05-03 10:12:18.648	error	uncaught exception: leti is not defined
    arteckA Offline
    arteckA Offline
    arteck
    #206
    @0018 ok das wird nix.... muss ich mir am system anschauen...
    heute abend.. installiere die Stable bitte 0.0.16..
    ich mach heute Abend ein Update
    0 1 Antwort Letzte Antwort
    • arteckA arteck
      0 Offline
      0 Offline
      0018
      #207
      @arteck Ok, leider schaffe ich es nicht den Adapter zu deinstallieren. Die 0.17 bleibt immer sichtbar. Hast du einen Tipp?
      Mfg
      0018
      • 0 0018
        0 Offline
        0 Offline
        0018
        #208
        @0018 sagte in [Aufruf] fullyBrowser Adapter:
        Hat sich erledigt, downgrade auf 16 mit "npm install iobroker.fullybrowser@0.0.16 --production" hat geklappt und läuft erstmal wieder
        Mfg
        0018
        • liv-in-skyL Offline
          liv-in-skyL Offline
          #209
          kurze zwischeninfo: habe 0.17 installiert. wenn ich den adapter stoppe, läuft er trotzdem noch weiter (in htop)
          • liv-in-skyL liv-in-sky
            arteckA Offline
            arteckA Offline
            arteck
            #210
            @liv-in-sky ne das wird die 0.0.16 sein die nicht beendet wurde..
            • arteckA Offline
              arteckA Offline
              arteck
              #211
              so 0.0.17 sollte laufen
              • arteckA arteck
                liv-in-skyL Offline
                liv-in-skyL Offline
                #212
                @arteck
                jup - du hattest recht - neustart und getestet(aus/eingeschaltet) - funktioniert - danke dir
                • I Online
                  I Online
                  intruder7
                  #213
                  Moin,
                  seit zwei Tagen funktioniert der Adapter nicht mehr. Meine beiden Tabs sind leer gelaufen da die Ladeüberwachung nicht mehr funktioniert. Fully ist normal über web erreichbar. Nur der Adapter baut keine Verbindung auf. Neustart, installieren der 17er Version haben nichts gebracht. Was mir aufgefallen ist, die App auf den Tabs ist aktualisiert worden und da sind einige Neuerungen bezügliche Java drin?
                  • I intruder7
                    Moin,
                    arteckA Offline
                    arteckA Offline
                    arteck
                    #214
                    @intruder7 welche Version des Fullybrowser ??
                    I 2 Antworten Letzte Antwort
                    • arteckA arteck
                      I Online
                      I Online
                      intruder7
                      #215
                      @arteck ich habe auf beiden Tabs die Version 1.31
                      • arteckA arteck
                        I Online
                        I Online
                        intruder7
                        #216
                        @arteck Hab jetzt den Adapter nochmal komplet neu installiert. Er funktioniert trotzdem nicht. Was verwunderlich ist, Befehle sendet er. Also z.B. Sceen on. Nur sämtliche Infos erhält er nicht
                        • I intruder7
                          arteckA Offline
                          arteckA Offline
                          arteck
                          #217
                          @intruder7 muss ich mir mal anschauen.. vor WE wird das aber nix
                          I 3 Antworten Letzte Antwort
                          • arteckA arteck
                            I Online
                            I Online
                            intruder7
                            #218
                            @arteck Lass dir Zeit. Die Tabs sind im Moment am Dauerstrom. Hoffe nur du findest eine Lösung✊
                            • arteckA arteck
                              I Online
                              I Online
                              intruder7
                              #219
                              @arteck Achso, und eins noch. Besteht die Möglichkeit in den Objekten anstatt der IP einen unter Einstellungen vergebenen Namen zu nutzen? Das wäre auch noch Klasse. ansonsten hat der Adapter von Anfang bis eben vor ein paar Tagen super funktioniert. 👍
                              • arteckA arteck
                                I Online
                                I Online
                                intruder7
                                #220
                                @arteck Hab mal geschaut bei Git. Unter Umständen hilft es schon wenn du das timeout von 2000 bei Abfrage der Infos etwas erhöhst. Die Abfrage über das REST Interface dauert ziemlich lange.
                                function updateDevice(ip,port,psw) {
                                var id = ip.replace(/[.\s]+/g, '_');
                                var statusURL = 'http://' + ip + ':' + port + '/?cmd=deviceInfo&type=json&password=' + psw;
                                var vari = '';
                                var thisOptions = {
                                    uri: statusURL,
                                    method: "GET",
                                    timeout: 2000,
                                    followRedirect: false,
                                    maxRedirects: 0
                                • I intruder7
                                  var vari = '';
                                  var thisOptions = {
                                      uri: statusURL,
                                      method: "GET",
                                      timeout: 2000,
                                      maxRedirects: 0
                                  arteckA Offline
                                  arteckA Offline
                                  arteck
                                  #221
                                  @intruder7 mach die änderung lokal bei dir und schau nach obs funktioniert
                                  I 1 Antwort Letzte Antwort
                                  • arteckA Offline
                                    arteckA Offline
                                    arteck
                                    #222
                                    also bei mir läuft alles wie es soll
                                    und ich habe 4 Tablets die ich überwache..
                                    ich aktualisiere alle 120000 milisec
                                    IssiI 1 Antwort Letzte Antwort
                                    • arteckA arteck
                                      I Online
                                      I Online
                                      intruder7
                                      #223
                                      @arteck also ich musste auf 18000 erhöhen damit es wieder funktioniert. Aber das ist doch seltsam. Hast du die selbe Fully Version(1.31)? welche tabs hast du? Ich habe jeweils ein Samsung Tab A 2016 (SM-T580) mit allen aktuellen Updates. Und der Aufruf der Device Info Seite über den Browser dauert eben ziemlich lange. Ich versteh es echt nicht. Irgendwas muss sich verändert haben weil es ja vorher funktioniert hat.
                                        Buddinski88
                                        #224
                                        Hallo arteck,
                                        ich bekomme leider auch keine Verbindung mehr mit meinen Tablets hin.
                                        Installiert ist Version 1.0.0 und es werden die Objekte unter "Info" gar nicht mehr angelegt.
                                        Wenn ich unter Commands z.B. ein "ExitApp" ausführen will, dann wird im Logfile folgendes angezeigt:
                                        fullybrowser.0	2019-05-26 09:44:59.308	error	Error SendCommand : Error: connect ECONNREFUSED 192.168.178.32:2323
                                        fullybrowser.0	2019-05-26 09:44:57.436	error	Error SendCommand : Error: socket hang up
                                        Mittels Browser komme ich aber auf die Fullyinstanz jedes Tablets.
                                        Hast du mir einen Tipp was da schief läuft? Brauchst du weitere Logs?
                                        Bastian
                                          Buddinski88
                                          #225
                                          @intruder7 @arteck , ich habe die Erhöhung auf 18000 auch mal getestet, aber das funktioniert bei mir leider nicht. Hast du sonst noch etwas eingestellt?
                                          Zeigt es bei dir im Logfile die IPV4 Adresse oder IPV6 Adresse an, wenn ein Zugriff von dem Tablet erfolgt (müsste glaub web.0 sein)?
