  4. [Aufruf] fullyBrowser Adapter
    6.6k
fullybrowserfullybrowser adapter
289 Beiträge 45 Kommentatoren 72.4k Aufrufe 26 Beobachtet
  • arteckA Offline
    arteckA Offline
    arteck
    #204
    man sollte nix zwischendurch machen :-)
    probier mal noch mal bitte.. von GIT
    • 0 Offline
      0 Offline
      0018
      #205
      @arteck
      host.BrokerNUC	2019-05-03 10:12:18.786	error	instance system.adapter.fullybrowser.0 terminated with code 0 (OK)
      host.BrokerNUC	2019-05-03 10:12:18.786	error	Caught by controller[0]: at emitNone (events.js:111:20)
      host.BrokerNUC	2019-05-03 10:12:18.786	error	Caught by controller[0]: at Object.onceWrapper (events.js:313:30)
      host.BrokerNUC	2019-05-03 10:12:18.786	error	Caught by controller[0]: at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/request/request.js:1083:12)
      host.BrokerNUC	2019-05-03 10:12:18.786	error	Caught by controller[0]: at Request.emit (events.js:211:7)
      host.BrokerNUC	2019-05-03 10:12:18.786	error	Caught by controller[0]: at emitOne (events.js:116:13)
      host.BrokerNUC	2019-05-03 10:12:18.786	error	Caught by controller[0]: at Request.<anonymous> (/opt/iobroker/node_modules/request/request.js:1161:10)
      host.BrokerNUC	2019-05-03 10:12:18.786	error	Caught by controller[0]: at Request.emit (events.js:214:7)
      host.BrokerNUC	2019-05-03 10:12:18.786	error	Caught by controller[0]: at emitTwo (events.js:126:13)
      host.BrokerNUC	2019-05-03 10:12:18.786	error	Caught by controller[0]: at Request.self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
      host.BrokerNUC	2019-05-03 10:12:18.786	error	Caught by controller[0]: at Request._callback (/opt/iobroker/node_modules/iobroker.fullybrowser/main.js:194:24)
      host.BrokerNUC	2019-05-03 10:12:18.785	error	Caught by controller[0]: ReferenceError: leti is not defined
      fullybrowser.0	2019-05-03 10:12:18.649	error	ReferenceError: leti is not defined at Request._callback (/opt/iobroker/node_modules/iobroker.fullybrowser/main.js:194:24) at Request.self.callback (/opt/iobroker/node_modules/request/request.
      fullybrowser.0	2019-05-03 10:12:18.648	error	uncaught exception: leti is not defined
      Mfg
      0018
      • 0 0018
        @arteck
        arteckA Offline
        arteckA Offline
        arteck
        #206
        @0018 ok das wird nix.... muss ich mir am system anschauen...
        heute abend.. installiere die Stable bitte 0.0.16..
        ich mach heute Abend ein Update
        0 1 Antwort Letzte Antwort
        • arteckA arteck
          0 Offline
          0 Offline
          0018
          #207
          @arteck Ok, leider schaffe ich es nicht den Adapter zu deinstallieren. Die 0.17 bleibt immer sichtbar. Hast du einen Tipp?
          Mfg
          0018
          • 0 0018
            0 Offline
            0 Offline
            0018
            #208
            @0018 sagte in [Aufruf] fullyBrowser Adapter:
            Hat sich erledigt, downgrade auf 16 mit "npm install iobroker.fullybrowser@0.0.16 --production" hat geklappt und läuft erstmal wieder
            Mfg
            0018
            • liv-in-skyL Offline
              liv-in-skyL Offline
              #209
              kurze zwischeninfo: habe 0.17 installiert. wenn ich den adapter stoppe, läuft er trotzdem noch weiter (in htop)
              • liv-in-skyL liv-in-sky
                arteckA Offline
                arteckA Offline
                arteck
                #210
                @liv-in-sky ne das wird die 0.0.16 sein die nicht beendet wurde..
                • arteckA Offline
                  arteckA Offline
                  arteck
                  #211
                  so 0.0.17 sollte laufen
                  • arteckA arteck
                    liv-in-skyL Offline
                    liv-in-skyL Offline
                    #212
                    @arteck
                    jup - du hattest recht - neustart und getestet(aus/eingeschaltet) - funktioniert - danke dir
                    • I Online
                      I Online
                      intruder7
                      #213
                      Moin,
                      seit zwei Tagen funktioniert der Adapter nicht mehr. Meine beiden Tabs sind leer gelaufen da die Ladeüberwachung nicht mehr funktioniert. Fully ist normal über web erreichbar. Nur der Adapter baut keine Verbindung auf. Neustart, installieren der 17er Version haben nichts gebracht. Was mir aufgefallen ist, die App auf den Tabs ist aktualisiert worden und da sind einige Neuerungen bezügliche Java drin?
                      • I intruder7
                        Moin,
                        arteckA Offline
                        arteckA Offline
                        arteck
                        #214
                        @intruder7 welche Version des Fullybrowser ??
                        I 2 Antworten Letzte Antwort
                        • arteckA arteck
                          I Online
                          I Online
                          intruder7
                          #215
                          @arteck ich habe auf beiden Tabs die Version 1.31
                          • arteckA arteck
                            I Online
                            I Online
                            intruder7
                            #216
                            @arteck Hab jetzt den Adapter nochmal komplet neu installiert. Er funktioniert trotzdem nicht. Was verwunderlich ist, Befehle sendet er. Also z.B. Sceen on. Nur sämtliche Infos erhält er nicht
                            • I intruder7
                              arteckA Offline
                              arteckA Offline
                              arteck
                              #217
                              @intruder7 muss ich mir mal anschauen.. vor WE wird das aber nix
                              I 3 Antworten Letzte Antwort
                              • arteckA arteck
                                I Online
                                I Online
                                intruder7
                                #218
                                @arteck Lass dir Zeit. Die Tabs sind im Moment am Dauerstrom. Hoffe nur du findest eine Lösung✊
                                • arteckA arteck
                                  I Online
                                  I Online
                                  intruder7
                                  #219
                                  @arteck Achso, und eins noch. Besteht die Möglichkeit in den Objekten anstatt der IP einen unter Einstellungen vergebenen Namen zu nutzen? Das wäre auch noch Klasse. ansonsten hat der Adapter von Anfang bis eben vor ein paar Tagen super funktioniert. 👍
                                  • arteckA arteck
                                    I Online
                                    I Online
                                    intruder7
                                    #220
                                    @arteck Hab mal geschaut bei Git. Unter Umständen hilft es schon wenn du das timeout von 2000 bei Abfrage der Infos etwas erhöhst. Die Abfrage über das REST Interface dauert ziemlich lange.
                                    function updateDevice(ip,port,psw) {
                                    var id = ip.replace(/[.\s]+/g, '_');
                                    var statusURL = 'http://' + ip + ':' + port + '/?cmd=deviceInfo&type=json&password=' + psw;
                                    var vari = '';
                                    var thisOptions = {
                                        uri: statusURL,
                                        method: "GET",
                                        timeout: 2000,
                                        followRedirect: false,
                                        maxRedirects: 0
                                    • I intruder7
                                      var vari = '';
                                      var thisOptions = {
                                          uri: statusURL,
                                          method: "GET",
                                          timeout: 2000,
                                          maxRedirects: 0
                                      arteckA Offline
                                      arteckA Offline
                                      arteck
                                      #221
                                      @intruder7 mach die änderung lokal bei dir und schau nach obs funktioniert
                                      I 1 Antwort Letzte Antwort
                                      • arteckA Offline
                                        arteckA Offline
                                        arteck
                                        #222
                                        also bei mir läuft alles wie es soll
                                        und ich habe 4 Tablets die ich überwache..
                                        ich aktualisiere alle 120000 milisec
                                        IssiI 1 Antwort Letzte Antwort
                                        • arteckA arteck
                                          I Online
                                          I Online
                                          intruder7
                                          #223
                                          @arteck also ich musste auf 18000 erhöhen damit es wieder funktioniert. Aber das ist doch seltsam. Hast du die selbe Fully Version(1.31)? welche tabs hast du? Ich habe jeweils ein Samsung Tab A 2016 (SM-T580) mit allen aktuellen Updates. Und der Aufruf der Device Info Seite über den Browser dauert eben ziemlich lange. Ich versteh es echt nicht. Irgendwas muss sich verändert haben weil es ja vorher funktioniert hat.
