  4. [Aufruf] Neuer Adaper Google-Sharedlocations
google shared locations
512 Beiträge 52 Kommentatoren 162.1k Aufrufe 32 Beobachtet
  • dslraserD dslraser
    @jeti said in [Aufruf] Neuer Adaper Google-Sharedlocations:
    Ebenso habe ich die Anleitung per Chrome als auch per Edge probiert
    Nimm Firefox
    jeti
    schrieb am zuletzt editiert von jeti
    #281
    @dslraser per Firefox sieht der cookie anders aus:
    Cookie: NID=207=xxx; CONSENT=YES+DE.de+V14+BX; 1P_JAR=2021-01-13-15; SID=xxx.; __Secure-3PSID=xxx.; HSID=xxx; SSID=xxx; APISID=xxx; SAPISID=xxx; __Secure-3PAPISID=xxx; SIDCC=xxx; __Secure-3PSIDCC=xxx; SEARCH_SAMESITE=CgQI0JEB
    ich füge das gesamte ding also inklusive "cookie" ein, oder brauche ich davon nur einen Teil?
    Log dazu sieht so aus:
    google-sharedlocations.0	2021-01-13 16:13:03.097	error	at endReadableNT (_stream_readable.js:1241:12)
    google-sharedlocations.0	2021-01-13 16:13:03.097	error	at IncomingMessage.emit (events.js:326:22)
    google-sharedlocations.0	2021-01-13 16:13:03.097	error	at Object.onceWrapper (events.js:420:28)
    google-sharedlocations.0	2021-01-13 16:13:03.097	error	at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/request/request.js:1076:12)
    google-sharedlocations.0	2021-01-13 16:13:03.097	error	at Request.emit (events.js:314:20)
    google-sharedlocations.0	2021-01-13 16:13:03.097	error	at Request.<anonymous> (/opt/iobroker/node_modules/request/request.js:1154:10)
    google-sharedlocations.0	2021-01-13 16:13:03.097	error	at Request.self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
    google-sharedlocations.0	2021-01-13 16:13:03.097	error	at Request._callback (/opt/iobroker/node_modules/iobroker.google-sharedlocations/main.js:520:11)
    google-sharedlocations.0	2021-01-13 16:13:03.097	error	at parseLocationData (/opt/iobroker/node_modules/iobroker.google-sharedlocations/main.js:555:11)
    google-sharedlocations.0	2021-01-13 16:13:03.097	error	(5595) An error occurred during polling the locations: Error: No location data in response. Cookie expired or no users share their location with you.
    muss ich andere Google Einstellung anpassen? also zum Beispiel den Standortverlauf aktivieren?
    • J jeti
      dslraserD Offline
      dslraserD Offline
      dslraser
      #282
      @jeti
      hast Du das hier gelesen ?
      (da steht eigentlich alles)
      wichtig ist auch google.com (nicht de) zu nehmen
      https://github.com/Garfonso/ioBroker.google-sharedlocations
      • J jeti
        Hallo zusammen, ich bekomme den Adapter nicht zum verbinden...
        Ich lese den cookie nach der Anleitung aus, allerdings ist mein cookie viel länger als in der Anleitung. Muss ich also das gesamte ding (die xxx sind symbolisch):
        cookie: CONSENT=YES+DE.de+V14+BX; 1P_JAR=2021-01-13-14; SID=xxx.; __Secure-3PSID=xxx.; HSID=xxx; SSID=xxx; APISID=xxx; SAPISID=xxx; __Secure-3PAPISID=xxx; OGPC=19008535-2:; NID=207=xxx; SIDCC=xxx; __Secure-3PSIDCC=xxx
        also cookie verwenden, da bekomme ich nämlich ein "connection failed" zurück.
        Mein Rechner hängt hinter pihole, aber auch wenn dieser deaktiviert ist bekomme ich das identische verhalten.
        Ebenso habe ich die Anleitung per Chrome als auch per Edge probiert mit wieder identischem Verhalten.
        Wo liegt mein Fehler?
        Danke und Gruß
        dslraserD Offline
        dslraserD Offline
        dslraser
        #283
        Hast Du denn schon die grundlegenden Dinge eingerichtet. Also z.B. die Standortfreigabe von z.B. Deinem Account für den ioBroker Account freigegeben ?
        Lief der Adapter bei Dir schon mal, oder ist es Deine Ersteinrichtung ?
        Wenn Ersteinrichtung, dann halte Dich an die Anleitung. Ist auch hier im Forum zu finden.
        J 1 Antwort Letzte Antwort
          jeti
          #284
          @dslraser 😥 habe den Absatz mit meiner Standortfreigabe überlesen, jetzt gehts, danke!
          • J jeti
            dslraserD Offline
            dslraserD Offline
            dslraser
            #285
            okay, sonst ist es hier auch ganz gut erklärt.
            https://forum.iobroker.net/post/445570
            • J Offline
              Jan1
              #286
              Ist was bekannt, dass der Adapter aktuell nach einem versehentlichen Logout im betreffenden Google Konto wieder nicht läuft und der Cookie nicht mehr will?
              nik82N 1 Antwort Letzte Antwort
              • J Jan1
                nik82N Offline
                nik82N Offline
                nik82
                #287
                @jan1
                Habe heute um 8:36 auch einen Error bekommen, hat sich aber dann von selber erledigt, ist jetzt wieder mit dem alten Cookie online bei mir.
                • nik82N nik82
                  @jan1
                  Jan1
                  #288
                  @nik82
                  Willst mal testen, wenn Du dich bei Google aus loggs und danach wiedr ein, ob er dann immer noch grün wird?
                  • J Jan1
                    @nik82
                    nik82N Offline
                    nik82N Offline
                    nik82
                    schrieb am zuletzt editiert von nik82
                    #289
                    @jan1
                    Hm, eigentlich bin ich froh wenn er läuft, wenn er nach der Aktion nicht mehr läuft beiß ich mich in den Arsch:-)
                    • nik82N nik82
                      @jan1
                      Jan1
                      #290
                      @nik82
                      Deshalb ja auch die Frage, ob Du das mal testeten könntest ;)
                      Aber keine Panik @Garfonso hat das das letzte mal auch sehr schnell gefixt :)
                      • J Jan1
                        @nik82
                        nik82N Offline
                        nik82N Offline
                        nik82
                        #291
                        @jan1
                        Jo, wart mal ab was die anderen sagen, wenn sich nichts ergibt dann teste ich mal ;-)
                        • nik82N nik82
                          @jan1
                          Jan1
                          #292
                          @nik82
                          Hat sich erledigt, noch mal bei allen Google Konten abgemeldet und mit dem IOBroker Konto angemeldet, Cookie gezogen und läuft. Warum das bei den ersten 10 Versuchen nicht geklappt hat, kein Plan.
                          Ist ja nicht das erste Mal dass ich das mache ;)
                          • J Jan1
                            @nik82
                            GarfonsoG Offline
                            GarfonsoG Offline
                            Garfonso
                            #293
                            @jan1 puh ;-)
                            • David G.D Online
                              David G.D Online
                              David G.
                              #294
                              Hab den Adapter gestern installiert.
                              Scheint gut zu laufen.
                              Wo liegt der kleinste Pollinginterval der Sinn macht bzw funktioniert?
                              Würde gerne über einen so klein wie möglichen geofence meine Alarmanlage deaktivieren wenn ich nach Hause komme.
                              J M GarfonsoG 3 Antworten Letzte Antwort
                              • David G.D David G.
                                Jan1
                                #295
                                @david-g
                                Das wird so oder so nicht klappen, da Google das nicht in Echtzeit macht. Somit ist es sinnlos wenn Du den Adapter alle 5 Sekunden den falschen Standort abfragen lässt ;)
                                  maxpd
                                  #296
                                  @david-g ich wähle einen kleinen fence beim Verlassen und einen großen beim Betreten. Dann greifen die Regeln früh wenn man Weg geht und früh wenn man wieder kommt.
                                  maxpd
                                  Raspi 4 8gb | iobroker + pivccu3 | 46 Adapter | 68 Scripte, 120 Devices
                                  • M maxpd
                                    Jan1
                                    #297
                                    @maxpd
                                    kann man machen, nur dauert es bis zu 5 Minuten bis Google aktualisiert und das wären dann schon ein paar km.
                                      GarfonsoG Offline
                                      GarfonsoG Offline
                                      Garfonso
                                      #298
                                      @david-g
                                      durch experimentieren hab ich rausgefunden, dass alles unter 60 Sekunden pollen zu 429 = zu oft angefragt Fehlern führt. Daher wartet der Adapter immer mindestens 60 Sekunden und spukt ne Warnung aus, wenn du versuchst was kleineres einzustellen.
                                      Wie schnell die Handys ihre Position bei Google aktualisieren ist dann nochmal ne ganz andere Geschichte. Kommt nach meiner Erfahrung auch darauf an, wie sehr die Handys gerade in Nutzung sind oder pennen... also wenn du gerade mit Google Maps navigierst, kommen die Updates recht flott. Wenn das Gerät in der Hosentasche im Deepsleep ist um Strom zu sparen, kann es schonmal dauern.
                                      • GarfonsoG Garfonso
                                        @david-g
                                        Jan1
                                        #299
                                        @garfonso
                                        Genau deshalb ist die Geschichte nicht zuverlässig. Kommt aber auch drauf an, was man machen möchte. Wenn man die Heizung schon mal starten möchte, kann man schon ein recht großen fent wählen, was aber auch blöd wird, wenn man dann mal kurz nahe am Home vorbeifährt und die einfach so angeht. Dann hatte ich auch schon bemerkt, dass mein Aufenthaltsort, ohne die Position des Handys zu ändern ab und an mal gute 500m weiter weg ist, was je nach fent Radius auch zu unerwünschten Aktionen führen kann.
                                        • K Offline
                                          Krys
                                          #300
                                          Moin zusammen,
                                          ich hab aktuell das Problem, dass ich keine neue Location hinzufügen kann, da der "Benutzer" nicht ausgewählt werden kann. Auch wenn ich eine neue Instanz anlege, kann kein Benutzer ausgewählt werden. Als Beispiel kommt dann logischerweise "Userid of Zuhause must not be empty". Hat sich bei Google mal wieder was geändert?
                                          dslraserD GarfonsoG 2 Antworten Letzte Antwort
