  4. [gelöst] Installation iobroker auf QNAP 251+ in docker
94 Beiträge 13 Kommentatoren 26.9k Aufrufe 8 Beobachtet
    piccobello
    #61
    777 /dev/ttyACM0 so ??
    • P piccobello
      GlasfaserG Offline
      GlasfaserG Offline
      Glasfaser
      #62
      @piccobello
      Du hast doch ein Auswahlmenue dafür :
        piccobello
        #63
        wieder error
        zigbee.0	2019-11-20 21:06:13.407	error	(1443) Error while starting zigbee-shepherd!. Error: Error: No such file or directory, cannot open /dev/ttyACM0
        zigbee.0	2019-11-20 21:06:13.398	info	(1443) Starting zigbee-shepherd
        zigbee.0	2019-11-20 21:05:13.395	info	(1443) Error while starting zigbee-shepherd, attempting to fix... (takes 60 seconds)
        zigbee.0	2019-11-20 21:05:13.365	info	(1443) Reset coordinator
        zigbee.0	2019-11-20 21:05:13.320	info	(1443) Queue is: true
        zigbee.0	2019-11-20 21:05:13.319	info	(1443) Start on port: /dev/ttyACM0 channel 11
        zigbee.0	2019-11-20 21:05:13.277	info	(1443) starting. Version 0.11.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v10.17.0
        host.8862f2d30733	2019-11-20 21:05:11.356	info	instance system.adapter.zigbee.0 started with pid 1443
        host.8862f2d30733	2019-11-20 21:05:09.352	info	instance system.adapter.zigbee.0 terminated with code 156 (156)
        zigbee.0	2019-11-20 21:05:08.833	info	(1404) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        zigbee.0	2019-11-20 21:05:08.832	info	(1404) terminating
        zigbee.0	2019-11-20 21:05:08.828	info	(1404) Got terminate signal TERMINATE_YOURSELF
        host.8862f2d30733	2019-11-20 21:05:08.824	info	stopInstance system.adapter.zigbee.0 send kill signal
        host.8862f2d30733	2019-11-20 21:05:08.821	info	stopInstance system.adapter.zigbee.0 (force=false, process=true)
        info.0	2019-11-20 20:50:32.271	info	(431) Popup news was read...
        • P piccobello
          wieder error
          GlasfaserG Offline
          GlasfaserG Offline
          Glasfaser
          #64
          @piccobello
          Letzer Versuch, im Container den Befehl durchführen :
          chmod 777 /dev/ttyACM0
            piccobello
            #65
            im Container macht er das
            chmod: Zugriff auf '/dev/ttyACM0' nicht möglich: Datei oder Verzeichnis nicht gefunden
            • P piccobello
              GlasfaserG Offline
              GlasfaserG Offline
              Glasfaser
              #66
              @piccobello
              Leider kenne ich den Qnap - Container nicht ,
              da kann ich dir leider nicht mehr weiterhelfen … Sorry 😌
              Da fällt mir noch etwas ein :
              Vielleicht muss man es weiterreichen , gibt es soetwas bei dir !?
                piccobello
                #67
                leicht nur so was
                ![alt text](2cf27c43-5684-4ef6-8207-94870c134209-imagem.png image url)
                  piccobello
                  #68
                  ![alt text](5bcbfe31-d14b-4eec-acc5-54977bb83587-imagem.png image url)
                  • P piccobello
                    leicht nur so was
                    GlasfaserG Offline
                    GlasfaserG Offline
                    Glasfaser
                    #69
                    @piccobello
                    Gib mal das im Container ein :
                    insmod /usr/local/modules/cdc-acm.ko
                    und dann die Ausgabe im Container
                    ls -la /dev/ttyACM0
                      piccobello
                      #70
                      @Glasfaser said in [gelöst] Installation iobroker auf QNAP 251+ in docker:
                      oci runtime error: exec failed: container_linux.go:265: starting container process caused "exec: \"insmod\": executable file not found in $PATH"
                        piccobello
                        #71
                        warum kann ich den stick mit winscp es finden und mit den Container nicht?
                        • P piccobello
                          GlasfaserG Offline
                          GlasfaserG Offline
                          Glasfaser
                          #72
                          @piccobello
                          …. mehr kann ich dir nicht helfen , da ich keine QNAP habe .. Sorry 🤔
                          P 1 Antwort Letzte Antwort
                            piccobello
                            #73
                            lsusb mit Container
                            oci runtime error: exec failed: container_linux.go:265: starting container process caused "exec: \"lsusb\": executable file not found in $PATH"
                            mit winscp
                            /$ lsusb
                            Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
                            Bus 001 Device 005: ID 0451:16a8 Texas Instruments, Inc.
                            Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
                            • GlasfaserG Glasfaser
                              @piccobello
                              piccobello
                              #74
                              @Glasfaser ok danke aus Portugal
                              • P piccobello
                                GlasfaserG Offline
                                GlasfaserG Offline
                                Glasfaser
                                #75
                                @a200
                                Kannst du vielleicht @piccobello helfen, ich komme leider nicht weiter !?
                                • a200A Offline
                                  a200A Offline
                                  a200
                                  schrieb am zuletzt editiert von a200
                                  #76
                                  @piccobello Ich kann mal versuchen. Bitte folgendes prüfen.
                                  1. privileged mode. Der Hacken muss gesetzt sein.
                                  2. Ich vermute, dass du bei winscp auf die shell der QNAP zugreifst, nicht auf den Container. Also auf das Terminal-Icon klicken, und in das Feld
                                  /bin/bash
                                  eingeben.
                                  Dann in der Shell des Containers:
                                  dmesg | grep usb
                                  eingeben und die komplette Ausgabe hier posten. Mal sehen ob dein Stick von Container erkannt wird.
                                  A 1 Antwort Letzte Antwort
                                    piccobello
                                    #77
                                    guten abend habe alles noch mal neue installiert . und sudo chmod 777 /dev/ttyACM0 gemacht und dann war 😊 grün 😊 dank a200 und Glasfaser
                                      piccobello
                                      #78
                                      Problem ist, dass bei jedem Neustart der Qnap der chmod neu durchgeführt werden muss....
                                      crw------- 1 root root 166, 0 Nov 22 01:09 /dev/ttyACM0
                                      was kann ich machen mit die recht bleiben .....??
                                      a200A 1 Antwort Letzte Antwort
                                      • P piccobello
                                        a200A Offline
                                        a200A Offline
                                        a200
                                        #79
                                        @piccobello sagte in [gelöst] Installation iobroker auf QNAP 251+ in docker:
                                        Ich habe das mit @andre besprochen. Er wird das in die nächste Version des Docker Images aufnehmen.
                                        Ansonsten viel Spaß mit dem Container
                                          piccobello
                                          #80
                                          👏 👍 danke
