  4. Tradfri Tutorial
    2.8k
    4.9k
    4.1k
Tradfri Tutorial
171 Beiträge 21 Kommentatoren 43.4k Aufrufe 4 Beobachtet
  • Z Abwesend
    Z Abwesend
    zahnheinrich
    #121
    Hmm, immer noch der selbe Fehler oder?
    ! host.iobrokerBosaca 2018-06-28 21:44:12.854 error instance system.adapter.tradfri.0 terminated with code 1 ()
    ! Caught 2018-06-28 21:44:12.853 error by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.tradfri/node_modules/node-dtls-client/node_modules/node-aead-crypto/index.js:4:15)
    ! Caught 2018-06-28 21:44:12.852 error by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.tradfri/node_modules/node-dtls-client/node_modules/node-aead-crypto/build/Release/node-v48-linux-x64/node_aead_crypto.
    ! host.iobrokerBosaca 2018-06-28 21:44:12.118 info instance system.adapter.tradfri.0 started with pid 26240
    ! host.iobrokerBosaca 2018-06-28 21:44:12.100 info object change system.adapter.tradfri.0
    ! host.iobrokerBosaca 2018-06-28 21:44:06.528 info Restart adapter system.adapter.tradfri.0 because enabled</anonymous>
    Edit: Nach Neustart ioBroker im log:
    ! host.iobrokerBosaca 2018-06-28 21:57:09.826 error instance system.adapter.tradfri.0 terminated with code 1 ()
    ! host.iobrokerBosaca 2018-06-28 21:57:09.826 error Caught by controller[0]: at Function.Module._load (module.js:445:3)
    ! host.iobrokerBosaca 2018-06-28 21:57:09.826 error Caught by controller[0]: at tryModuleLoad (module.js:453:12)
    ! host.iobrokerBosaca 2018-06-28 21:57:09.826 error Caught by controller[0]: at Module.load (module.js:494:32)
    ! host.iobrokerBosaca 2018-06-28 21:57:09.826 error Caught by controller[0]: at Object.Module._extensions..js (module.js:586:10)
    ! host.iobrokerBosaca 2018-06-28 21:57:09.826 error Caught by controller[0]: at Module._compile (module.js:577:32)
    ! host.iobrokerBosaca 2018-06-28 21:57:09.825 error Caught by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.tradfri/node_modules/node-dtls-client/node_modules/node-aead-crypto/index.js:4:15)
    ! host.iobrokerBosaca 2018-06-28 21:57:09.825 error Caught by controller[0]: at require (internal/module.js:20:19)
    ! host.iobrokerBosaca 2018-06-28 21:57:09.825 error Caught by controller[0]: at Module.require (module.js:504:17)
    ! host.iobrokerBosaca 2018-06-28 21:57:09.825 error Caught by controller[0]: at Function.Module._load (module.js:424:25)
    ! host.iobrokerBosaca 2018-06-28 21:57:09.825 error Caught by controller[0]: at Function.Module._resolveFilename (module.js:476:15)
    ! host.iobrokerBosaca 2018-06-28 21:57:09.824 error Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.tradfri/node_modules/node-dtls-client/node_modules/node-aead-crypto/build/Release/node-v48-linux-x64/node_aead_c
    ! host.iobrokerBosaca 2018-06-28 21:57:09.824 error Caught by controller[0]: ^
    ! host.iobrokerBosaca 2018-06-28 21:57:09.824 error Caught by controller[0]: throw err;
    ! host.iobrokerBosaca 2018-06-28 21:57:09.824 error Caught by controller[0]: module.js:478
    ! host.iobrokerBosaca 2018-06-28 21:57:09.082 info instance system.adapter.tradfri.0 started with pid 411</anonymous>
    MfG Ulrich
    • AlCalzoneA Offline
      AlCalzoneA Offline
      AlCalzone
      #122
      Ahh, hast du vor kurzem ein NodeJS-Upgrade gemacht? Beim Kompilieren wird eine v59 erstellt (dürfte Node 10 sein?), beim Ausführen aber eine v48 gesucht.
      Ich glaube da hilft nur noch die Holzhammermethode…
      aus /opt/iobroker/node_modules/ die folgenden Ordner komplett löschen, wenn sie existieren:
      iobroker.tradfri
      node-tradfri-client
      node-coap-client
      node-dtls-client
      node-aead-crypto
      Und danach den Adapter installieren, in deinem Fall am besten direkt über die Konsole
      cd /opt/iobroker
      npm install iobroker.tradfri --unsafe-perm
      • Z Abwesend
        Z Abwesend
        zahnheinrich
        #123
        Habe kein node update gemacht
        ! root@iobrokerBosaca:/opt/iobroker# node -v
        ! v6.14.3
        Step by step nach Deiner Anweisung die Ordner gelöscht, von der Konsole neu installiert
        ! root@iobrokerBosaca:/opt/iobroker# npm install iobroker.tradfri –unsafe-perm
        ! > node-dtls-client@0.5.4 install /opt/iobroker/node_modules/node-dtls-client
        ! > node install/postinstall.js
        ! node-dtls-client: testing NodeJS version
        ! Version < 10, installing node-aead-crypto...
        ! npm WARN deprecated github@0.2.4: 'github' has been renamed to '@octokit/rest' (https://git.io/vNB11)
        ! > node-aead-crypto@1.1.4 install /opt/iobroker/node_modules/node-dtls-client/node_modules/node-aead-crypto
        ! > node lib/install.js
        ! running default installation script
        ! > node-aead-crypto@1.1.4 install:default /opt/iobroker/node_modules/node-dtls-client/node_modules/node-aead
        ! -crypto
        ! > node-pre-gyp install --fallback-to-build
        ! node-pre-gyp WARN Tried to download(404): https://github.com/AlCalzone/node-aead- ... download/v
        ! 1.1.4/node-v59-linux-x64.tar.gz
        ! node-pre-gyp WARN Pre-built binaries not found for node-aead-crypto@1.1.4 and node@9.8.0 (node-v59 ABI, gli
        ! bc) (falling back to source compile with node-gyp)
        ! make: Verzeichnis „/opt/iobroker/node_modules/node-dtls-client/node_modules/node-aead-crypto/build“ wird b
        ! etreten
        ! CXX(target) Release/obj.target/node_aead_crypto/src/node-aes-ccm.o
        ! CXX(target) Release/obj.target/node_aead_crypto/src/node-aes-gcm.o
        ! CXX(target) Release/obj.target/node_aead_crypto/src/addon.o
        ! SOLINK_MODULE(target) Release/obj.target/node_aead_crypto.node
        ! COPY Release/node_aead_crypto.node
        ! COPY /opt/iobroker/node_modules/node-dtls-client/node_modules/node-aead-crypto/build/Release/node-v59-lin
        ! ux-x64/node_aead_crypto.node
        ! TOUCH Release/obj.target/action_after_build.stamp
        ! make: Verzeichnis „/opt/iobroker/node_modules/node-dtls-client/node_modules/node-aead-crypto/build“ wird v
        ! erlassen
        ! npm notice created a lockfile as package-lock.json. You should commit this file.
        ! + node-aead-crypto@1.1.4
        ! added 73 packages from 41 contributors and audited 103 packages in 23.899s
        ! found 0 vulnerabilities
        ! + iobroker.tradfri@1.4.1
        ! added 7 packages from 6 contributors and audited 4084 packages in 90.886s
        ! found 83 vulnerabilities (43 low, 29 moderate, 11 high)
        ! run npm audit fix to fix them, or npm audit for details
        Das log zeigt
        ! host.iobrokerBosaca 2018-06-29 16:33:45.649 error instance system.adapter.tradfri.0 terminated with code 1 ()
        ! Caught 2018-06-29 16:33:45.648 error by controller[0]: at Function.Module._load (module.js:445:3)
        ! Caught 2018-06-29 16:33:45.648 error by controller[0]: at tryModuleLoad (module.js:453:12)
        ! Caught 2018-06-29 16:33:45.648 error by controller[0]: at Module.load (module.js:494:32)
        ! Caught 2018-06-29 16:33:45.648 error by controller[0]: at Object.Module._extensions..js (module.js:586:10)
        ! Caught 2018-06-29 16:33:45.648 error by controller[0]: at Module._compile (module.js:577:32)
        ! Caught 2018-06-29 16:33:45.648 error by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/node-dtls-client/node_modules/node-aead-crypto/index.js:4:15)
        ! Caught 2018-06-29 16:33:45.648 error by controller[0]: at require (internal/module.js:20:19)
        ! Caught 2018-06-29 16:33:45.648 error by controller[0]: at Module.require (module.js:504:17)
        ! Caught 2018-06-29 16:33:45.648 error by controller[0]: at Function.Module._load (module.js:424:25)
        ! Caught 2018-06-29 16:33:45.647 error by controller[0]: at Function.Module._resolveFilename (module.js:476:15)
        ! Caught 2018-06-29 16:33:45.647 error by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/node-dtls-client/node_modules/node-aead-crypto/build/Release/node-v48-linux-x64/node_aead_crypto.node'
        ! Caught 2018-06-29 16:33:45.647 error by controller[0]: ^
        ! Caught 2018-06-29 16:33:45.647 error by controller[0]: throw err;
        ! Caught 2018-06-29 16:33:45.647 error by controller[0]: module.js:478
        ! host.iobrokerBosaca 2018-06-29 16:33:44.915 info instance system.adapter.tradfri.0 started with pid 17958</anonymous>
        Ich hoffe Du bist nicht genauso gefrustet wie ich 😢
        Ulrich
        Edit: nach Neustart des Docker Containers im log:
        ! host.iobrokerBosaca 2018-06-29 18:05:02.698 error instance system.adapter.tradfri.0 terminated with code 1 ()
        ! host.iobrokerBosaca 2018-06-29 18:05:01.959 info instance system.adapter.tradfri.0 started with pid 1569
        ! host.iobrokerBosaca 2018-06-29 18:05:01.941 info object change system.adapter.tradfri.0
        ! host.iobrokerBosaca 2018-06-29 18:05:00.603 info Restart adapter system.adapter.tradfri.0 because enabled
        MfG Ulrich
          AlCalzoneA Offline
          AlCalzone
          #124
          Dann verstehe ich diesen Log-Output nicht. Sicher, dass du da nicht doch irgendwie NodeJS 9 eingeschleust hast, welches Reste hinterlassen hat?
          • Z Abwesend
            Z Abwesend
            zahnheinrich
            #125
            Wie kann ich das feststellen/beseitigen?
            wenn ich versuche upzudaten kommt
            ! root@iobrokerBosaca:/opt/iobroker# apt-get install -y nodejs
            ! Paketlisten werden gelesen… Fertig
            ! Abhängigkeitsbaum wird aufgebaut.
            ! Statusinformationen werden eingelesen.... Fertig
            ! nodejs ist schon die neueste Version (6.14.3-1nodesource1).
            ! 0 aktualisiert, 0 neu installiert, 0 zu entfernen und 3 nicht aktualisiert.
            MfG Ulrich
            • paul53P Offline
              #126
              Es sollte erst einmal festgestellt werden, wo welche Version von node.js installiert ist.
              ls -l /usr/bin/node*
              /usr/bin/node -v
              ls -l /usr/local/bin/node*
              /usr/local/bin/node -v
              und mit welcher Version ioBroker beim Boot automatisch gestartet wird: Datei /etc/init.d/iobroker.sh, Zeile 13 so ?
              NODECMD=/usr/bin/node
                podruzjasne
                #127
                @Paul53
                Ich freue mich total, dass ich noch einen Tip bekomme.
                Diese Woche bin ich ortsabwesend und kann daher erst nach meiner Rückkehr Deine Hinweise abarbeiten, dann aber sehr gerne!
                Ich melde mich dann.
                Ulrich
                Gesendet von meinem T1-A21L mit Tapatalk
                • G Offline
                  garnichda
                  #128
                  ich hätte eine Verständnisfrage oder besser gesagt ein kleines Problem mit folgender Konstellation:
                  • Raspi 3 mit ioBroker und VIS sowie Cloudadapter für Alexa
                  • Tradfri Gateway mit mehreren Tradfri Lampen sowie normalen Gruppen (aus der App) bzw Virtuellen Gruppen
                  • dazu einen Echo Plus sowie einen Echo Show.
                  Wenn ich nun mittels Alexa oder VIS die Gruppen ausschalte und sie anschließend wieder normal mit dem Schalter einschalten will werden sie immer auf eine Brightness von 0,4% gestellt. Das wieder einschalten per Schalter ist einmal normal ausschalten (Tradfri Stromlos) und anschließend wieder auf ein und mit Strom versorgen. Gibt es hier irgendwo eine Definition welche Brightness die Lampen haben, wenn sie wieder normal mit Strom versorgt werden?
                  Bin ehrlich gesagt ein wenig ratlos. Wenn ich das Licht mittels VIS oder Alexa normal Einschalte ohne es zuvor am Schalter auszuschalten funktioniert alles wie es soll wobei hier der Cloudadapter bei "An" automatisch eine Brightness von 100% definiert. Das Problem besteht wirklich nur sobald das Licht über den Schalter wieder eingeschaltet werden soll und vorher über VIS bzw Alexa ausgeschaltet wurde.
                  Vielen Dank für Eure Hilfe
                    podruzjasne
                    #129
                    Die Tradfri sollten NIE stromlos sein, sondern nur über die Fernbedienung oder das Gateway geschaltet werden.
                    Nach stromlos einschalten befinden die sich im bootmodus eingeschaltet (also auch nach Stromausfall gehen die Lampen bei Stromwiederkehr an).
                    Ulrich
                    Gesendet von meinem SM-J700H mit Tapatalk
                    • G Offline
                      garnichda
                      #130
                      Mir ist das ja bewusst allerdings den kleinen Damen im Hause nicht. Hier wird halt leider immernoch benötigt das die Lampen auch mit einem normalen Wippenschalter ein und ausgeschaltet werden können, was auch ohne weiteres geht solang die Brightness zuvor nicht per Alexa oder VIS auf 0% geregelt wird.
                        podruzjasne
                        #131
                        Je nach baulicher Gegebenheit könntest du den Schalter überbrücken, so dass die tradfri dauernd Spannung haben.
                        Darüber hinaus könntest du dann mit dem Schalter (nachdem er ggf. gegen einen Taster getauscht wurde) über Sonoff oder Homematic und iobroker die tradfry zusätzlich über den Taster betätigen.
                        • Z Abwesend
                          Z Abwesend
                          zahnheinrich
                          #132
                          @paul53:
                          /usr/bin/node -v
                          Am Terminal bekomme ich
                          ! root@iobrokerBosaca:/opt/iobroker# ls -l /usr/bin/node*
                          ! -rwxr-xr-x 1 root root 25379760 Jun 13 01:59 /usr/bin/node
                          ! lrwxrwxrwx 1 root root 24 Jun 18 03:35 /usr/bin/nodejs -> /etc/alternatives/nodejs
                          ! root@iobrokerBosaca:/opt/iobroker# /usr/bin/node -v
                          ! v6.14.3
                          ! root@iobrokerBosaca:/opt/iobroker# ls -l /usr/local/bin/node*
                          ! ls: Zugriff auf '/usr/local/bin/node*' nicht möglich: Datei oder Verzeichnis nicht gefunden
                          ! root@iobrokerBosaca:/opt/iobroker# /usr/local/bin/node -v
                          ! bash: /usr/local/bin/node: Datei oder Verzeichnis nicht gefunden
                          Bei mir läuft ioBroker im Docker-container, habe/finde daher keine init.d.
                          Gestartet wird der Container mit
                          node node_modules/iobroker.js-controller/controller.js >/opt/scripts/docker_iobroker_log.txt 2>&1 &
                          wenn ich den js-controller von Hand starte bekomme ich
                          ! root@iobrokerBosaca:/opt/iobroker# node node_modules/iobroker.js-controller/controller.js
                          ! host.iobrokerBosaca check instance "system.adapter.admin.0" for host "iobrokerBosaca"
                          ! host.iobrokerBosaca check instance "system.adapter.hm-rpc.0" for host "iobrokerBosaca"
                          ! host.iobrokerBosaca check instance "system.adapter.hm-rega.0" for host "iobrokerBosaca"
                          ! host.iobrokerBosaca check instance "system.adapter.web.0" for host "iobrokerBosaca"
                          ! host.iobrokerBosaca check instance "system.adapter.vis.0" for host "iobrokerBosaca"
                          ! host.iobrokerBosaca check instance "system.adapter.vis-hqwidgets.0" for host "iobrokerBosaca"
                          ! host.iobrokerBosaca check instance "system.adapter.vis-timeandweather.0" for host "iobrokerBosaca"
                          ! host.iobrokerBosaca check instance "system.adapter.vis-metro.0" for host "iobrokerBosaca"
                          ! host.iobrokerBosaca check instance "system.adapter.hm-rpc.1" for host "iobrokerBosaca"
                          ! host.iobrokerBosaca check instance "system.adapter.hm-rpc.2" for host "iobrokerBosaca"
                          ! host.iobrokerBosaca check instance "system.adapter.nut.0" for host "iobrokerBosaca"
                          ! host.iobrokerBosaca check instance "system.adapter.tr-064.0" for host "iobrokerBosaca"
                          ! host.iobrokerBosaca check instance "system.adapter.ical.0" for host "iobrokerBosaca"
                          ! host.iobrokerBosaca check instance "system.adapter.node-red.0" for host "iobrokerBosaca"
                          ! host.iobrokerBosaca check instance "system.adapter.javascript.0" for host "iobrokerBosaca"
                          ! host.iobrokerBosaca check instance "system.adapter.dwd.0" for host "iobrokerBosaca"
                          ! host.iobrokerBosaca check instance "system.adapter.ping.0" for host "iobrokerBosaca"
                          ! host.iobrokerBosaca check instance "system.adapter.feiertage.0" for host "iobrokerBosaca"
                          ! host.iobrokerBosaca check instance "system.adapter.samsung.0" for host "iobrokerBosaca"
                          ! host.iobrokerBosaca check instance "system.adapter.rpi2.0" for host "iobrokerBosaca"
                          ! host.iobrokerBosaca check instance "system.adapter.fritzdect.0" for host "iobrokerBosaca"
                          ! host.iobrokerBosaca check instance "system.adapter.vis-jqui-mfd.0" for host "iobrokerBosaca"
                          ! host.iobrokerBosaca check instance "system.adapter.sql.0" for host "iobrokerBosaca"
                          ! host.iobrokerBosaca check instance "system.adapter.email.0" for host "iobrokerBosaca"
                          ! host.iobrokerBosaca check instance "system.adapter.tvspielfilm.0" for host "iobrokerBosaca"
                          ! host.iobrokerBosaca check instance "system.adapter.javascript.1" for host "iobrokerBosaca"
                          ! host.iobrokerBosaca check instance "system.adapter.broadlink2.0" for host "iobrokerBosaca"
                          ! host.iobrokerBosaca check instance "system.adapter.ham.0" for host "iobrokerBosaca"
                          ! host.iobrokerBosaca check instance "system.adapter.tradfri.0" for host "iobrokerBosaca"
                          ! Send diag info: {"uuid":"ab265f4a-67f9-a46a-c0b2-61e4b95cefe5","language":"de","hosts":[{"version":"1.4.2",
                          ! "platform":"Javascript/Node.js","type":"linux"}],"node":"v6.14.3","arch":"x64","adapters":{"admin":{"versio
                          ! n":"3.4.6","platform":"Javascript/Node.js"},"hm-rpc":{"version":"1.6.0","platform":"Javascript/Node.js"},"h
                          ! m-rega":{"version":"1.7.0","platform":"Javascript/Node.js"},"web":{"version":"2.1.9","platform":"Javascript
                          ! /Node.js"},"vis":{"version":"1.1.2","platform":"Javascript/Node.js"},"vis-hqwidgets":{"version":"1.1.1","pl
                          ! atform":"Javascript/Node.js"},"vis-timeandweather":{"version":"1.1.7","platform":"Javascript/Node.js"},"vis
                          ! -metro":{"version":"1.1.2","platform":"Javascript/Node.js"},"nut":{"version":"1.1.3","platform":"Javascript
                          ! /Node.js"},"tr-064":{"version":"0.4.14","platform":"Javascript/Node.js"},"icons-mfd-png":{"version":"1.0.2"
                          ! ,"platform":"javascript/Node.js"},"icons-ultimate-png":{"version":"1.0.1","platform":"javascript/Node.js"},
                          ! "ical":{"version":"1.5.2","platform":"Javascript/Node.js"},"node-red":{"version":"1.5.1","platform":"Javasc
                          ! ript/Node.js"},"javascript":{"version":"3.6.4","platform":"Javascript/Node.js"},"dwd":{"version":"2.2.2","p
                          ! latform":"javascript/Node.js"},"history":{"version":"1.7.2","platform":"Javascript/Node.js"},"ping":{"versi
                          ! on":"1.3.2","platform":"Javascript/Node.js"},"feiertage":{"version":"1.0.0","platform":"javascript/Node.js"
                          ! },"samsung":{"version":"0.2.9","platform":"Javascript/Node.js"},"rpi2":{"version":"0.3.2","platform":"javas
                          ! cript/Node.js"},"fritzdect":{"version":"0.1.1","platform":"Javascript/Node.js"},"vis-jqui-mfd":{"version":"
                          ! 1.0.11","platform":"Javascript/Node.js"},"sql":{"version":"1.8.0","platform":"Javascript/Node.js"},"flot":{
                          ! "version":"1.7.9","platform":"javascript/Node.js"},"email":{"version":"1.0.4","platform":"Javascript/Node.j
                          ! s"},"tvspielfilm":{"version":"1.0.4","platform":"javascript/Node.js"},"broadlink2":{"version":"1.8.0","plat
                          ! form":"Javascript/Node.js"},"ham":{"version":"0.4.2","platform":"Javascript/Node.js"},"tradfri":{"version":
                          ! "1.4.1","platform":"Javascript/Node.js"}},"model":"Intel(R) Celeron(R) CPU N3160 @ 1.60GHz","cpus":4,"mem
                          ! ":8287760384,"ostype":"Linux","vis":594}
                          ! Cannot find module 'pg-native'
                          Hilft das weiter zu Fehlersuche?
                          MfG Ulrich
                          • paul53P Offline
                            #133
                            @zahnheinrich:
                            Am Terminal bekomme ich `
                            Das sieht doch gut aus: Offenbar existiert node.js nur in der Version 6.14.3.Woher dann diese Meldung kommt, ist rätselhaft:
                            Mit Docker kenne ich mich nicht aus. Gibt es im Suchpfad noch weitere Verzeichnisse, in denen sich eine weitere Node-Version verstecken könnte ?
                            Funktioniert etwas in ioBroker nicht ?
                            • Z Abwesend
                              Z Abwesend
                              zahnheinrich
                              #134
                              @paul53:
                              @zahnheinrich:
                              Funktioniert etwas in ioBroker nicht ? `
                              Also im ioBroker funktioniert alles bis auf den Tradfri.
                              Eine Suche nach node.js ergibt
                              MfG Ulrich
                              • paul53P Offline
                                #135
                                Die ausführbare Datei hat den Namen node.
                                • Z Abwesend
                                  Z Abwesend
                                  zahnheinrich
                                  #136
                                  @paul53:
                                  Die ausführbare Datei hat den Namen node. `
                                  da habe ich
                                  MfG Ulrich
                                  • paul53P Offline
                                    #137
                                    Die beiden Dateien sind offenbar identisch. Welche Version haben sie ?
                                    /docker/iobroker/node_modules/node/bin/node -v
                                    • Z Abwesend
                                      Z Abwesend
                                      zahnheinrich
                                      #138
                                      Sooo,
                                      ich konnte mein Problem nun lösen:
                                      • von Hand die im log angezeigten nicht existierenden Ordner angelegt
                                      • von Hand die fehlende node_aead_crypto.node von github geladen
                                      läuft
                                      MfG Ulrich
                                        DeeJayDave
                                        #139
                                        Eine Frage hierzu:
                                        Braucht man zwangsläufig den IKEA Gateway für die Einrichtung in iobroker? Hab momentan nur den Tradfri Treiber, Tradfri Fernbedienung und natürlich Lampen. Würde das ganze mit nem C2531 Stick betreiben wollen…
                                          AlCalzoneA Offline
                                          AlCalzone
                                          #140
                                          Ja. Mit dem Stick musst du stattdessen den zigbee-Adapter verwenden
