  4. Tradfri Tutorial
Tradfri Tutorial
171 Beiträge 21 Kommentatoren 44.3k Aufrufe 4 Beobachtet
  • Z Offline
    Z Offline
    zahnheinrich
    #123
    Habe kein node update gemacht
    ! root@iobrokerBosaca:/opt/iobroker# node -v
    ! v6.14.3
    Step by step nach Deiner Anweisung die Ordner gelöscht, von der Konsole neu installiert
    ! root@iobrokerBosaca:/opt/iobroker# npm install iobroker.tradfri –unsafe-perm
    ! > node-dtls-client@0.5.4 install /opt/iobroker/node_modules/node-dtls-client
    ! > node install/postinstall.js
    ! node-dtls-client: testing NodeJS version
    ! Version < 10, installing node-aead-crypto...
    ! npm WARN deprecated github@0.2.4: 'github' has been renamed to '@octokit/rest' (https://git.io/vNB11)
    ! > node-aead-crypto@1.1.4 install /opt/iobroker/node_modules/node-dtls-client/node_modules/node-aead-crypto
    ! > node lib/install.js
    ! running default installation script
    ! > node-aead-crypto@1.1.4 install:default /opt/iobroker/node_modules/node-dtls-client/node_modules/node-aead
    ! -crypto
    ! > node-pre-gyp install --fallback-to-build
    ! node-pre-gyp WARN Tried to download(404): https://github.com/AlCalzone/node-aead- ... download/v
    ! 1.1.4/node-v59-linux-x64.tar.gz
    ! node-pre-gyp WARN Pre-built binaries not found for node-aead-crypto@1.1.4 and node@9.8.0 (node-v59 ABI, gli
    ! bc) (falling back to source compile with node-gyp)
    ! make: Verzeichnis „/opt/iobroker/node_modules/node-dtls-client/node_modules/node-aead-crypto/build“ wird b
    ! etreten
    ! CXX(target) Release/obj.target/node_aead_crypto/src/node-aes-ccm.o
    ! CXX(target) Release/obj.target/node_aead_crypto/src/node-aes-gcm.o
    ! CXX(target) Release/obj.target/node_aead_crypto/src/addon.o
    ! SOLINK_MODULE(target) Release/obj.target/node_aead_crypto.node
    ! COPY Release/node_aead_crypto.node
    ! COPY /opt/iobroker/node_modules/node-dtls-client/node_modules/node-aead-crypto/build/Release/node-v59-lin
    ! ux-x64/node_aead_crypto.node
    ! TOUCH Release/obj.target/action_after_build.stamp
    ! make: Verzeichnis „/opt/iobroker/node_modules/node-dtls-client/node_modules/node-aead-crypto/build“ wird v
    ! erlassen
    ! npm notice created a lockfile as package-lock.json. You should commit this file.
    ! + node-aead-crypto@1.1.4
    ! added 73 packages from 41 contributors and audited 103 packages in 23.899s
    ! found 0 vulnerabilities
    ! + iobroker.tradfri@1.4.1
    ! added 7 packages from 6 contributors and audited 4084 packages in 90.886s
    ! found 83 vulnerabilities (43 low, 29 moderate, 11 high)
    ! run npm audit fix to fix them, or npm audit for details
    Das log zeigt
    ! host.iobrokerBosaca 2018-06-29 16:33:45.649 error instance system.adapter.tradfri.0 terminated with code 1 ()
    ! Caught 2018-06-29 16:33:45.648 error by controller[0]: at Function.Module._load (module.js:445:3)
    ! Caught 2018-06-29 16:33:45.648 error by controller[0]: at tryModuleLoad (module.js:453:12)
    ! Caught 2018-06-29 16:33:45.648 error by controller[0]: at Module.load (module.js:494:32)
    ! Caught 2018-06-29 16:33:45.648 error by controller[0]: at Object.Module._extensions..js (module.js:586:10)
    ! Caught 2018-06-29 16:33:45.648 error by controller[0]: at Module._compile (module.js:577:32)
    ! Caught 2018-06-29 16:33:45.648 error by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/node-dtls-client/node_modules/node-aead-crypto/index.js:4:15)
    ! Caught 2018-06-29 16:33:45.648 error by controller[0]: at require (internal/module.js:20:19)
    ! Caught 2018-06-29 16:33:45.648 error by controller[0]: at Module.require (module.js:504:17)
    ! Caught 2018-06-29 16:33:45.648 error by controller[0]: at Function.Module._load (module.js:424:25)
    ! Caught 2018-06-29 16:33:45.647 error by controller[0]: at Function.Module._resolveFilename (module.js:476:15)
    ! Caught 2018-06-29 16:33:45.647 error by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/node-dtls-client/node_modules/node-aead-crypto/build/Release/node-v48-linux-x64/node_aead_crypto.node'
    ! Caught 2018-06-29 16:33:45.647 error by controller[0]: ^
    ! Caught 2018-06-29 16:33:45.647 error by controller[0]: throw err;
    ! Caught 2018-06-29 16:33:45.647 error by controller[0]: module.js:478
    ! host.iobrokerBosaca 2018-06-29 16:33:44.915 info instance system.adapter.tradfri.0 started with pid 17958</anonymous>
    Ich hoffe Du bist nicht genauso gefrustet wie ich 😢
    Ulrich
    Edit: nach Neustart des Docker Containers im log:
    ! host.iobrokerBosaca 2018-06-29 18:05:02.698 error instance system.adapter.tradfri.0 terminated with code 1 ()
    ! host.iobrokerBosaca 2018-06-29 18:05:01.959 info instance system.adapter.tradfri.0 started with pid 1569
    ! host.iobrokerBosaca 2018-06-29 18:05:01.941 info object change system.adapter.tradfri.0
    ! host.iobrokerBosaca 2018-06-29 18:05:00.603 info Restart adapter system.adapter.tradfri.0 because enabled
    MfG Ulrich
    • AlCalzoneA Offline
      AlCalzoneA Offline
      AlCalzone
      #124
      Dann verstehe ich diesen Log-Output nicht. Sicher, dass du da nicht doch irgendwie NodeJS 9 eingeschleust hast, welches Reste hinterlassen hat?
      • Z Offline
        Z Offline
        zahnheinrich
        #125
        Wie kann ich das feststellen/beseitigen?
        wenn ich versuche upzudaten kommt
        ! root@iobrokerBosaca:/opt/iobroker# apt-get install -y nodejs
        ! Paketlisten werden gelesen… Fertig
        ! Abhängigkeitsbaum wird aufgebaut.
        ! Statusinformationen werden eingelesen.... Fertig
        ! nodejs ist schon die neueste Version (6.14.3-1nodesource1).
        ! 0 aktualisiert, 0 neu installiert, 0 zu entfernen und 3 nicht aktualisiert.
        MfG Ulrich
        • paul53P Offline
          #126
          Es sollte erst einmal festgestellt werden, wo welche Version von node.js installiert ist.
          ls -l /usr/bin/node*
          /usr/bin/node -v
          ls -l /usr/local/bin/node*
          /usr/local/bin/node -v
          und mit welcher Version ioBroker beim Boot automatisch gestartet wird: Datei /etc/init.d/iobroker.sh, Zeile 13 so ?
          NODECMD=/usr/bin/node
          • P Offline
            podruzjasne
            #127
            @Paul53
            Ich freue mich total, dass ich noch einen Tip bekomme.
            Diese Woche bin ich ortsabwesend und kann daher erst nach meiner Rückkehr Deine Hinweise abarbeiten, dann aber sehr gerne!
            Ich melde mich dann.
            Ulrich
            Gesendet von meinem T1-A21L mit Tapatalk
            • G Offline
              garnichda
              #128
              ich hätte eine Verständnisfrage oder besser gesagt ein kleines Problem mit folgender Konstellation:
              • Raspi 3 mit ioBroker und VIS sowie Cloudadapter für Alexa
              • Tradfri Gateway mit mehreren Tradfri Lampen sowie normalen Gruppen (aus der App) bzw Virtuellen Gruppen
              • dazu einen Echo Plus sowie einen Echo Show.
              Wenn ich nun mittels Alexa oder VIS die Gruppen ausschalte und sie anschließend wieder normal mit dem Schalter einschalten will werden sie immer auf eine Brightness von 0,4% gestellt. Das wieder einschalten per Schalter ist einmal normal ausschalten (Tradfri Stromlos) und anschließend wieder auf ein und mit Strom versorgen. Gibt es hier irgendwo eine Definition welche Brightness die Lampen haben, wenn sie wieder normal mit Strom versorgt werden?
              Bin ehrlich gesagt ein wenig ratlos. Wenn ich das Licht mittels VIS oder Alexa normal Einschalte ohne es zuvor am Schalter auszuschalten funktioniert alles wie es soll wobei hier der Cloudadapter bei "An" automatisch eine Brightness von 100% definiert. Das Problem besteht wirklich nur sobald das Licht über den Schalter wieder eingeschaltet werden soll und vorher über VIS bzw Alexa ausgeschaltet wurde.
              Vielen Dank für Eure Hilfe
              • P Offline
                podruzjasne
                #129
                Die Tradfri sollten NIE stromlos sein, sondern nur über die Fernbedienung oder das Gateway geschaltet werden.
                Nach stromlos einschalten befinden die sich im bootmodus eingeschaltet (also auch nach Stromausfall gehen die Lampen bei Stromwiederkehr an).
                Ulrich
                Gesendet von meinem SM-J700H mit Tapatalk
                • G Offline
                  garnichda
                  #130
                  Mir ist das ja bewusst allerdings den kleinen Damen im Hause nicht. Hier wird halt leider immernoch benötigt das die Lampen auch mit einem normalen Wippenschalter ein und ausgeschaltet werden können, was auch ohne weiteres geht solang die Brightness zuvor nicht per Alexa oder VIS auf 0% geregelt wird.
                  • P Offline
                    podruzjasne
                    #131
                    Je nach baulicher Gegebenheit könntest du den Schalter überbrücken, so dass die tradfri dauernd Spannung haben.
                    Darüber hinaus könntest du dann mit dem Schalter (nachdem er ggf. gegen einen Taster getauscht wurde) über Sonoff oder Homematic und iobroker die tradfry zusätzlich über den Taster betätigen.
                    • Z Offline
                      Z Offline
                      zahnheinrich
                      #132
                      @paul53:
                      /usr/bin/node -v
                      Am Terminal bekomme ich
                      ! root@iobrokerBosaca:/opt/iobroker# ls -l /usr/bin/node*
                      ! -rwxr-xr-x 1 root root 25379760 Jun 13 01:59 /usr/bin/node
                      ! lrwxrwxrwx 1 root root 24 Jun 18 03:35 /usr/bin/nodejs -> /etc/alternatives/nodejs
                      ! root@iobrokerBosaca:/opt/iobroker# /usr/bin/node -v
                      ! v6.14.3
                      ! root@iobrokerBosaca:/opt/iobroker# ls -l /usr/local/bin/node*
                      ! ls: Zugriff auf '/usr/local/bin/node*' nicht möglich: Datei oder Verzeichnis nicht gefunden
                      ! root@iobrokerBosaca:/opt/iobroker# /usr/local/bin/node -v
                      ! bash: /usr/local/bin/node: Datei oder Verzeichnis nicht gefunden
                      Bei mir läuft ioBroker im Docker-container, habe/finde daher keine init.d.
                      Gestartet wird der Container mit
                      node node_modules/iobroker.js-controller/controller.js >/opt/scripts/docker_iobroker_log.txt 2>&1 &
                      wenn ich den js-controller von Hand starte bekomme ich
                      ! root@iobrokerBosaca:/opt/iobroker# node node_modules/iobroker.js-controller/controller.js
                      ! host.iobrokerBosaca check instance "system.adapter.admin.0" for host "iobrokerBosaca"
                      ! host.iobrokerBosaca check instance "system.adapter.hm-rpc.0" for host "iobrokerBosaca"
                      ! host.iobrokerBosaca check instance "system.adapter.hm-rega.0" for host "iobrokerBosaca"
                      ! host.iobrokerBosaca check instance "system.adapter.web.0" for host "iobrokerBosaca"
                      ! host.iobrokerBosaca check instance "system.adapter.vis.0" for host "iobrokerBosaca"
                      ! host.iobrokerBosaca check instance "system.adapter.vis-hqwidgets.0" for host "iobrokerBosaca"
                      ! host.iobrokerBosaca check instance "system.adapter.vis-timeandweather.0" for host "iobrokerBosaca"
                      ! host.iobrokerBosaca check instance "system.adapter.vis-metro.0" for host "iobrokerBosaca"
                      ! host.iobrokerBosaca check instance "system.adapter.hm-rpc.1" for host "iobrokerBosaca"
                      ! host.iobrokerBosaca check instance "system.adapter.hm-rpc.2" for host "iobrokerBosaca"
                      ! host.iobrokerBosaca check instance "system.adapter.nut.0" for host "iobrokerBosaca"
                      ! host.iobrokerBosaca check instance "system.adapter.tr-064.0" for host "iobrokerBosaca"
                      ! host.iobrokerBosaca check instance "system.adapter.ical.0" for host "iobrokerBosaca"
                      ! host.iobrokerBosaca check instance "system.adapter.node-red.0" for host "iobrokerBosaca"
                      ! host.iobrokerBosaca check instance "system.adapter.javascript.0" for host "iobrokerBosaca"
                      ! host.iobrokerBosaca check instance "system.adapter.dwd.0" for host "iobrokerBosaca"
                      ! host.iobrokerBosaca check instance "system.adapter.ping.0" for host "iobrokerBosaca"
                      ! host.iobrokerBosaca check instance "system.adapter.feiertage.0" for host "iobrokerBosaca"
                      ! host.iobrokerBosaca check instance "system.adapter.samsung.0" for host "iobrokerBosaca"
                      ! host.iobrokerBosaca check instance "system.adapter.rpi2.0" for host "iobrokerBosaca"
                      ! host.iobrokerBosaca check instance "system.adapter.fritzdect.0" for host "iobrokerBosaca"
                      ! host.iobrokerBosaca check instance "system.adapter.vis-jqui-mfd.0" for host "iobrokerBosaca"
                      ! host.iobrokerBosaca check instance "system.adapter.sql.0" for host "iobrokerBosaca"
                      ! host.iobrokerBosaca check instance "system.adapter.email.0" for host "iobrokerBosaca"
                      ! host.iobrokerBosaca check instance "system.adapter.tvspielfilm.0" for host "iobrokerBosaca"
                      ! host.iobrokerBosaca check instance "system.adapter.javascript.1" for host "iobrokerBosaca"
                      ! host.iobrokerBosaca check instance "system.adapter.broadlink2.0" for host "iobrokerBosaca"
                      ! host.iobrokerBosaca check instance "system.adapter.ham.0" for host "iobrokerBosaca"
                      ! host.iobrokerBosaca check instance "system.adapter.tradfri.0" for host "iobrokerBosaca"
                      ! Send diag info: {"uuid":"ab265f4a-67f9-a46a-c0b2-61e4b95cefe5","language":"de","hosts":[{"version":"1.4.2",
                      ! "platform":"Javascript/Node.js","type":"linux"}],"node":"v6.14.3","arch":"x64","adapters":{"admin":{"versio
                      ! n":"3.4.6","platform":"Javascript/Node.js"},"hm-rpc":{"version":"1.6.0","platform":"Javascript/Node.js"},"h
                      ! m-rega":{"version":"1.7.0","platform":"Javascript/Node.js"},"web":{"version":"2.1.9","platform":"Javascript
                      ! /Node.js"},"vis":{"version":"1.1.2","platform":"Javascript/Node.js"},"vis-hqwidgets":{"version":"1.1.1","pl
                      ! atform":"Javascript/Node.js"},"vis-timeandweather":{"version":"1.1.7","platform":"Javascript/Node.js"},"vis
                      ! -metro":{"version":"1.1.2","platform":"Javascript/Node.js"},"nut":{"version":"1.1.3","platform":"Javascript
                      ! /Node.js"},"tr-064":{"version":"0.4.14","platform":"Javascript/Node.js"},"icons-mfd-png":{"version":"1.0.2"
                      ! ,"platform":"javascript/Node.js"},"icons-ultimate-png":{"version":"1.0.1","platform":"javascript/Node.js"},
                      ! "ical":{"version":"1.5.2","platform":"Javascript/Node.js"},"node-red":{"version":"1.5.1","platform":"Javasc
                      ! ript/Node.js"},"javascript":{"version":"3.6.4","platform":"Javascript/Node.js"},"dwd":{"version":"2.2.2","p
                      ! latform":"javascript/Node.js"},"history":{"version":"1.7.2","platform":"Javascript/Node.js"},"ping":{"versi
                      ! on":"1.3.2","platform":"Javascript/Node.js"},"feiertage":{"version":"1.0.0","platform":"javascript/Node.js"
                      ! },"samsung":{"version":"0.2.9","platform":"Javascript/Node.js"},"rpi2":{"version":"0.3.2","platform":"javas
                      ! cript/Node.js"},"fritzdect":{"version":"0.1.1","platform":"Javascript/Node.js"},"vis-jqui-mfd":{"version":"
                      ! 1.0.11","platform":"Javascript/Node.js"},"sql":{"version":"1.8.0","platform":"Javascript/Node.js"},"flot":{
                      ! "version":"1.7.9","platform":"javascript/Node.js"},"email":{"version":"1.0.4","platform":"Javascript/Node.j
                      ! s"},"tvspielfilm":{"version":"1.0.4","platform":"javascript/Node.js"},"broadlink2":{"version":"1.8.0","plat
                      ! form":"Javascript/Node.js"},"ham":{"version":"0.4.2","platform":"Javascript/Node.js"},"tradfri":{"version":
                      ! "1.4.1","platform":"Javascript/Node.js"}},"model":"Intel(R) Celeron(R) CPU N3160 @ 1.60GHz","cpus":4,"mem
                      ! ":8287760384,"ostype":"Linux","vis":594}
                      ! Cannot find module 'pg-native'
                      Hilft das weiter zu Fehlersuche?
                      MfG Ulrich
                      • paul53P Offline
                        #133
                        @zahnheinrich:
                        Am Terminal bekomme ich `
                        Das sieht doch gut aus: Offenbar existiert node.js nur in der Version 6.14.3.Woher dann diese Meldung kommt, ist rätselhaft:
                        Mit Docker kenne ich mich nicht aus. Gibt es im Suchpfad noch weitere Verzeichnisse, in denen sich eine weitere Node-Version verstecken könnte ?
                        Funktioniert etwas in ioBroker nicht ?
                        • Z Offline
                          Z Offline
                          zahnheinrich
                          #134
                          @paul53:
                          @zahnheinrich:
                          Funktioniert etwas in ioBroker nicht ? `
                          Also im ioBroker funktioniert alles bis auf den Tradfri.
                          Eine Suche nach node.js ergibt
                          MfG Ulrich
                          • paul53P Offline
                            #135
                            Die ausführbare Datei hat den Namen node.
                            • Z Offline
                              Z Offline
                              zahnheinrich
                              #136
                              @paul53:
                              Die ausführbare Datei hat den Namen node. `
                              da habe ich
                              MfG Ulrich
                              • paul53P Offline
                                #137
                                Die beiden Dateien sind offenbar identisch. Welche Version haben sie ?
                                /docker/iobroker/node_modules/node/bin/node -v
                                • Z Offline
                                  Z Offline
                                  zahnheinrich
                                  #138
                                  Sooo,
                                  ich konnte mein Problem nun lösen:
                                  • von Hand die im log angezeigten nicht existierenden Ordner angelegt
                                  • von Hand die fehlende node_aead_crypto.node von github geladen
                                  läuft
                                  MfG Ulrich
                                    DeeJayDave
                                    #139
                                    Eine Frage hierzu:
                                    Braucht man zwangsläufig den IKEA Gateway für die Einrichtung in iobroker? Hab momentan nur den Tradfri Treiber, Tradfri Fernbedienung und natürlich Lampen. Würde das ganze mit nem C2531 Stick betreiben wollen…
                                      AlCalzoneA Offline
                                      AlCalzone
                                      #140
                                      Ja. Mit dem Stick musst du stattdessen den zigbee-Adapter verwenden
                                      • H Offline
                                        hemig
                                        #141
                                        ich habe mir die Tage auch einen Raspi zugelegt und auch gleich erfolgreich iobroker installiert. Lief alles sofort auf Anhieb. Auch die Einbindung eines XIAOMI BT Thermos hat auf Anhieb geklappt. Im Moment beschäftige ich mich damit eine VIS zu erstellen. Klappt auch schon soweit ganz gut.
                                        Leider musste ich heute früh feststellen dass der IKEA Tradfri Adapter nicht mehr läuft.
                                        Folgendes habe ich log gefunden:
                                        ! host.raspberrypi 2018-11-17 11:27:39.488 error instance system.adapter.tradfri.0 terminated with code 1 ()
                                        ! Caught 2018-11-17 11:27:39.488 error by controller[0]: at Function.Module._load (module.js:498:3)
                                        ! Caught 2018-11-17 11:27:39.488 error by controller[0]: at tryModuleLoad (module.js:506:12)
                                        ! Caught 2018-11-17 11:27:39.488 error by controller[0]: at Module.load (module.js:566:32)
                                        ! Caught 2018-11-17 11:27:39.488 error by controller[0]: at Object.Module._extensions..js (module.js:664:10)
                                        ! Caught 2018-11-17 11:27:39.487 error by controller[0]: at Module._compile (module.js:653:30)
                                        ! Caught 2018-11-17 11:27:39.487 error by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/node-dtls-client/build/lib/AEADCrypto.js:54:47)
                                        ! Caught 2018-11-17 11:27:39.487 error by controller[0]: at require (internal/module.js:11:18)
                                        ! Caught 2018-11-17 11:27:39.487 error by controller[0]: at Module.require (module.js:597:17)
                                        ! Caught 2018-11-17 11:27:39.487 error by controller[0]: at Function.Module._load (module.js:475:25)
                                        ! Caught 2018-11-17 11:27:39.487 error by controller[0]: at Function.Module._resolveFilename (module.js:548:15)
                                        ! Caught 2018-11-17 11:27:39.487 error by controller[0]: Error: Cannot find module 'node-aead-crypto'
                                        ! Caught 2018-11-17 11:27:39.487 error by controller[0]: ^
                                        ! Caught 2018-11-17 11:27:39.487 error by controller[0]: throw err;
                                        ! Caught 2018-11-17 11:27:39.486 error by controller[0]: module.js:550
                                        ! host.raspberrypi 2018-11-17 11:27:38.891 info instance system.adapter.tradfri.0 started with pid 2503
                                        ! host.raspberrypi 2018-11-17 11:27:38.869 info object change system.adapter.tradfri.0
                                        ! host.raspberrypi 2018-11-17 11:27:33.582 info Restart adapter system.adapter.tradfri.0 because enabled</anonymous>
                                        ich habe mich versucht in das Thema einzulesen, hatte bisher aber keinen Erfolg
                                        Folgende Version von Node scheint installiert:
                                        root@raspberrypi:/opt/iobroker# node -v
                                        v8.12.0
                                        Danke und Grüsse,
                                        hemig
                                          AlCalzoneA Offline
                                          AlCalzone
                                          #142
                                          @hemig:
                                          Welche Adapter-Version hast du installiert? Aktuell im latest ist die 1.5.4, bei der das Problem nicht mehr auftreten sollte. Wenn dir die nicht angeboten wird, bitte mal über die Konsole updaten:
                                          cd /opt/iobroker
                                          npm i iobroker.tradfri
