  4. JavaScript
  5. [Vorlage] Denon HEOS Script
    6.3k
javascripttemplate
359 Beiträge 48 Kommentatoren 115.9k Aufrufe 44 Beobachtet
  • DJMarc75D DJMarc75
    @bouster sagte in [Vorlage] Denon HEOS Script:
    node: v14.21.3, js-controller: 4.0.23
    Vermutlich das System noch nie so richtig auf Stand gebracht.
    Zeig mal bitte die Ausgabe von
    iob diag
    bouster
    #311
    @djmarc75
    iob diag gibt folgendes aus:
    iobroker [command]
    Commands:
      iobroker setup                                               Setup ioBroker
      iobroker start [all|<adapter>.<instance>]                    Starts the js-controller or a specified adapter instance
      iobroker stop [<adapter>.<instance>]                         stops the js-controller or a specified adapter instance
      iobroker restart [<adapter>.<instance>]                      Restarts js-controller or a specified adapter instance  [aliases: r]
      iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
      iobroker info                                                Shows the host info
      iobroker logs [<adapter>]                                    Monitor log
      iobroker add <adapter> [desiredNumber]                       Add instance of adapter  [aliases: a]
      iobroker install <adapter>                                   Installs a specified adapter  [aliases: i]
      iobroker rebuild [<module>]                                  Rebuild all native modules or path
      iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub
      iobroker del <adapter>                                       Remove adapter and all instances from this host  [aliases: delete]
      iobroker del <adapter>.<instance>                            Remove adapter instance  [aliases: delete]
      iobroker update [<repositoryUrl>]                            Update repository and list adapters
      iobroker upgrade                                             Upgrade management
      iobroker upload [all|<adapter>]                              Upload management  [aliases: u]
      iobroker object                                              Object management  [aliases: o]
      iobroker state                                               State management  [aliases: s]
      iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
      iobroker list <type> [<filter>]                              List all entries, like objects
      iobroker chmod <mode> <file>                                 Change file rights
      iobroker chown <user> <group> <file>                         Change file ownership
      iobroker touch <file>                                        Touch file
      iobroker rm <file>                                           Remove file
      iobroker file                                                File management
      iobroker user                                                User commands
      iobroker group                                               group management
      iobroker host <hostname>                                     Set host to given hostname
      iobroker set <adapter>.<instance>                            Change settings of adapter config
      iobroker license <license.file or license.text>              Update license by given file
      iobroker cert                                                Certificate management
      iobroker clean <yes>                                         Clears all objects and states
      iobroker backup                                              Create backup
      iobroker restore <backup name or path>                       Restore a specified backup
      iobroker validate <backup name or path>                      Validate a specified backup
      iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance  [aliases: isrun]
      iobroker repo [<name>]                                       Show repo information
      iobroker uuid                                                Show uuid of the installation  [aliases: id]
      iobroker unsetup                                             Reset license, installation secret and language
      iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
      iobroker multihost                                           Multihost management
      iobroker compact                                             compact group management
      iobroker plugin                                              Plugin management
      iobroker version [<adapter>]                                 Show version of js-controller or specified adapter  [aliases: v]
    Options:
      --help  Show help  [boolean]
      bouster
      #312
      Über folgendes skirpt https://forum.iobroker.net/topic/59549/iob-diag-skript bekomme ich eine Menge sensible Informationen. Ich habe mal das was ich denke wichtig ist angehängt:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      No configuration change needed.
      Multihost discovery server: disabled
      Discovery authentication:   enabled
      Persistent activation:      disabled
      Objects:                    jsonl on 127.xxx.xxx.xxx
      States:                     jsonl on 127.xxx.xxx.xxx
      Core adapters versions
      admin:          6.3.5
      javascript:     6.1.4
      Adapters from github:   1
      Adapter State
      + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
        system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              - disabled
      + system.adapter.heos.0                   : heos                  : raspberrypi                              -  enabled
      + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: xxxx
      + system.adapter.javascript.1             : javascript            : raspberrypi                              -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: xxxx, bind: 192.xxx.xxx.xxx
      + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
      + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
      + system.adapter.signal-cmb.0             : signal-cmb            : raspberrypi                              -  enabled
      + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: xxxx, bind: 192.xxx.xxx.xxx (SSL), run as: admin
      + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: xxxx, bind: 0.0.0.0
        system.adapter.spotify-premium.0        : spotify-premium       : raspberrypi                              - disabled
      + system.adapter.upnp.0                   : upnp                  : raspberrypi                              -  enabled
      + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: xxxx, bind: 0.0.0.0 (SSL), run as: admin
      + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Contr
      + instance is alive
      + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: xxxx, bind: 0.0.0.0 (SSL), run as: admin
      + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: xxxx, bind: 192.xxx.xxx.xxx(SSL), run as: admin
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "backitup"     : 2.6.19   , installed 2.6.19
      Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
      Adapter    "heos"         : 1.10.0   , installed 1.10.0
      Adapter    "javascript"   : 6.1.4    , installed 6.1.4
      Controller "js-controller": 4.0.24   , installed 4.0.23 [Updatable]
      Adapter    "mqtt"         : 4.0.7    , installed 2.7.4  [Updatable]
      Adapter    "signal-cmb"   : 0.3.0    , installed 0.3.0
      Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
      Adapter    "spotify-premium": 1.2.1  , installed 1.2.1
      Adapter    "upnp"         : 1.0.21   , installed 1.0.21
      Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
      • B bouster
        @djmarc75
        iobroker [command]
        Commands:
        Options:
        DJMarc75D Offline
        DJMarc75D Offline
        DJMarc75
        #313
        ok, dann bitte folgende Befehle ausführen
        iob stop
        iob fix
        iob start
        iob diag
        Um Dir helfen zu können die Ausgabe von iob diag komplett inklusive Eingabe und Ausgabe posten - sonst wird das nix :)
        Lehrling seit 1975 !!!
          iob stop
          iob fix
          iob start
          iob diag
          bouster
          #314
          @djmarc75
          ok, also das hat schonmal funktioniert. Jetzt läuft es mit dem Befehl :)
          Da ich etwas paranoid bin (evtl auch gerade weil ich mich nicht so gut auskenne) habe ich den Teil der IP adressen entfernt, wenn der auch nötig ist würde ich ihn lieber nicht ganz so öffentlich teilen.
          Ich hoffe hiermit lässt sich arbeiten.
          Skript v.2023-04-16
          *** BASE SYSTEM ***
          Model           : Raspberry Pi 4 Model B Rev 1.5
          Architecture    : aarch64
          Docker          : false
          Virtualization  : none
          Distributor ID: Raspbian
          Description:    Raspbian GNU/Linux 11 (bullseye)
          Release:        11
          Codename:       bullseye
          PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
          NAME="Raspbian GNU/Linux"
          VERSION_ID="11"
          VERSION="11 (bullseye)"
          VERSION_CODENAME=bullseye
          ID=raspbian
          ID_LIKE=debian
          HOME_URL="http://www.raspbian.org/"
          SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
          BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
          Systemuptime and Load:
           15:26:29 up 20:50,  3 users,  load average: 2.51, 1.95, 1.15
          CPU threads: 4
          Raspberry only:
          throttled=0x0
          Other values than 0x0 hint to temperature/voltage problems
          temp=43.3'C
          volt=0.8900V
          *** Time and Time Zones ***
                         Local time: Wed 2023-05-17 15:26:29 CEST
                     Universal time: Wed 2023-05-17 13:26:29 UTC
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          *** User and Groups ***
          xxxxx
          /home/xxxxx
          xxxxx adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin docker gpio i2c spi iobroker
          *** X-Server-Setup ***
          X-Server:       true
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Mem:            3.8G        1.3G        246M         40M        2.2G        2.5G
          Swap:            99M          0B         99M
          Total:          3.9G        1.3G        346M
                   3794 M total memory
                   1349 M used memory
                   1887 M active memory
                    796 M inactive memory
                    246 M free memory
                    303 M buffer memory
                   1895 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          Raspberry only:
          oom events: 0
          *** FILESYSTEM ***
          /dev/root      ext4       29G   19G  9.3G  67% /
          devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
          tmpfs          tmpfs     759M  2.7M  757M   1% /run
          /dev/loop0     squashfs   47M   47M     0 100% /snap/core18/2723
          /dev/loop2     squashfs  225M  225M     0 100% /snap/nextcloud/21522
          /dev/loop1     squashfs   47M   47M     0 100% /snap/core18/2748
          /dev/loop3     squashfs   44M   44M     0 100% /snap/snapd/18936
          /dev/loop4     squashfs   44M   44M     0 100% /snap/snapd/19124
          /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
          tmpfs          tmpfs     380M   36K  380M   1% /run/user/1000
          TARGET                  SOURCE         FSTYPE   OPTIONS
          /                       /dev/mmcblk0p2 ext4     rw,noatime
          |-/snap/core18/2723     /dev/loop0     squashfs ro,nodev,relatime,errors=continue
          |-/snap/nextcloud/21522 /dev/loop2     squashfs ro,nodev,relatime,errors=continue
          |-/snap/core18/2748     /dev/loop1     squashfs ro,nodev,relatime,errors=continue
          |-/snap/snapd/18936     /dev/loop3     squashfs ro,nodev,relatime,errors=continue
          |-/snap/snapd/19124     /dev/loop4     squashfs ro,nodev,relatime,errors=continue
          `-/boot                 /dev/mmcblk0p1 vfat     rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
          /var:
          8.4G    /var/
          6.9G    /var/lib
          4.7G    /var/lib/docker/overlay2
          1.9G    /var/lib/snapd
          Archived and active journals take up 136.0M in the file system.
          /opt/iobroker/backups:
          710M    /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          273M    /opt/iobroker/iobroker-data/
          128M    /opt/iobroker/iobroker-data/files
          118M    /opt/iobroker/iobroker-data/backup-objects
          51M     /opt/iobroker/iobroker-data/files/javascript.admin
          38M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js
          8.9M    /opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.7de3299d.chunk.js.map
          8.7M    /opt/iobroker/iobroker-data/objects.jsonl
          7.5M    /opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.2afdfa2c.chunk.js.map
          7.1M    /opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.21829349.chunk.js.map
          7.0M    /opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.5d4fbf6a.chunk.js.map
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v14.21.3
          /usr/bin/node           v14.21.3
          /usr/bin/npm            6.14.18
          /usr/bin/npx            6.14.18
          nodejs:
            Installed: 14.21.3-deb-1nodesource1
            Candidate: 14.21.3-deb-1nodesource1
            Version table:
           *** 14.21.3-deb-1nodesource1 500
                  500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
               12.22.12~dfsg-1~deb11u4 500
          No problems detected
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          6.3.5
          javascript:     6.1.4
          Adapter State
            system.adapter.heos.0                   : heos                  : raspberrypi                              - disabled
            system.adapter.upnp.0                   : upnp                  : raspberrypi                              - disabled
          + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Controller_2ce58c1eff92eb11b66e214f3d98b6d1-if00-port0
          + instance is alive
          Objects and States
          Objects:        5151
          States:         3396
          Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
          Hit:2 https://deb.nodesource.com/node_14.x buster InRelease
          Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
          Hit:4 https://download.docker.com/linux/raspbian bullseye InRelease
          Reading package lists...
          Pending Updates: 3
          *** Listening Ports ***
          xxx
          2023-05-17 15:25:55.948  - info: info.0 (8811) Reading/updating systemdata.
          2023-05-17 15:25:57.044  - info: info.0 (8811) State value to set for "info.0.sysinfo.cpu.info.speed" has to be type "string" but received type "number"
          2023-05-17 15:25:57.201  - info: info.0 (8811) State value to set for "info.0.sysinfo.cpu.info.cache-l3" has to be type "number" but received type "string"
          2023-05-17 15:25:57.421  - info: info.0 (8811) cpu Temp res = {"main":45.764,"cores":[],"max":45.764,"socket":[],"chipset":null}
          2023-05-17 15:25:59.584  - info: host.raspberrypi instance system.adapter.simple-api.0 started with pid 9066
          2023-05-17 15:25:59.658  - info: web.0 (8850) starting. Version 4.3.0 in /opt/iobroker/node_modules/iobroker.web, node: v14.21.3, js-controller: 4.0.23
          2023-05-17 15:26:00.277  - info: web.0 (8850) Secure socket.io server listening on port 8082
          2023-05-17 15:26:00.309  - info: web.0 (8850) https server listening on port 8082
          2023-05-17 15:26:01.923  - warn: zigbee.0 (8546) DeviceAvailability:Failed to ping 0x0017880109409518 LWA009
          2023-05-17 15:26:02.100  - warn: zigbee.0 (8546) DeviceAvailability:Failed to ping 0x001788010c3c16d7 929003046301_03
          2023-05-17 15:26:02.700  - warn: zigbee.0 (8546) DeviceAvailability:Failed to ping 0x0017880108d9874f LWA009
          2023-05-17 15:26:02.934  - warn: zigbee.0 (8546) DeviceAvailability:Failed to ping 0x001788010c429b4b 929003046301_02
          2023-05-17 15:26:03.586  - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 9141
          2023-05-17 15:26:03.915  - info: simple-api.0 (9066) starting. Version 2.7.2 in /opt/iobroker/node_modules/iobroker.simple-api, node: v14.21.3, js-controller: 4.0.23
          2023-05-17 15:26:04.063  - info: simple-api.0 (9066) Secure simpleAPI server listening on port 8087
          2023-05-17 15:26:04.064  - info: simple-api.0 (9066) Allow states only when user is owner: false
          2023-05-17 15:26:04.093  - info: simple-api.0 (9066) https server listening on port 8087
          2023-05-17 15:26:06.590  - warn: zigbee.0 (8546) DeviceAvailability:Failed to ping 0x0017880109898696 440400982841
          2023-05-17 15:26:06.912  - warn: zigbee.0 (8546) DeviceAvailability:Failed to ping 0x7cb03eaa0a0061c9 LIGHTIFY Indoor Flex RGBW
          2023-05-17 15:26:07.009  - warn: zigbee.0 (8546) DeviceAvailability:Failed to ping 0x7cb03eaa0a0091da LIGHTIFY Indoor Flex RGBW
          2023-05-17 15:26:07.373  - info: backitup.0 (9141) starting. Version 2.6.19 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.21.3, js-controller: 4.0.23
          2023-05-17 15:26:07.407  - warn: zigbee.0 (8546) DeviceAvailability:Failed to ping 0x00178801098986f7 440400982841
          2023-05-17 15:26:07.539  - info: host.raspberrypi instance system.adapter.signal-cmb.0 started with pid 9461
          2023-05-17 15:26:07.596  - info: backitup.0 (9141) [iobroker] backup will be activated at 02:40 every 1 day(s)
          2023-05-17 15:26:10.877  - info: signal-cmb.0 (9461) starting. Version 0.3.0 in /opt/iobroker/node_modules/iobroker.signal-cmb, node: v14.21.3, js-controller: 4.0.23
          W Thomas BraunT 2 Antworten Letzte Antwort
          • B bouster
            @djmarc75
            Skript v.2023-04-16
            *** BASE SYSTEM ***
            Docker          : false
            Release:        11
            Codename:       bullseye
            VERSION_ID="11"
            ID=raspbian
            ID_LIKE=debian
            CPU threads: 4
            Raspberry only:
            throttled=0x0
            temp=43.3'C
            volt=0.8900V
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            xxxxx
            /home/xxxxx
            X-Server:       true
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Swap:            99M          0B         99M
                     3794 M total memory
                     1349 M used memory
                      246 M free memory
                      303 M buffer memory
                     1895 M swap cache
                       99 M total swap
                        0 M used swap
                       99 M free swap
            Raspberry only:
            oom events: 0
            *** FILESYSTEM ***
            /var:
            8.4G    /var/
            6.9G    /var/lib
            1.9G    /var/lib/snapd
            nodejs:
              Version table:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            admin:          6.3.5
            javascript:     6.1.4
            Adapter State
            + instance is alive
            Objects and States
            Objects:        5151
            States:         3396
            Pending Updates: 3
            xxx
            W Offline
            W Offline
            withstu
            #315
            @bouster Du könntest das Logging Level der Heos Instanz mal von Info auf Debug oder Silly ändern und schauen, was der Adapter so ausgibt. Ich habe bei mir übrigens die empfohlene Node Version 18 und npm 9 laufen. Vielleicht hilft bei dir bereits ein Update.
            • W withstu
              bouster
              #316
              @withstu Das komische ist, dass es bis vor ca 2 Monaten problemlos funktioniert hat und von einem auf den anderen Tag nicht mehr. Das Update muss ich dann wohl mal angehen...
                bouster
                #317
                @withstu ich habe nun alle geupdated. Raspbian von Buster auf Bullseye. Node auf 18 und npm auf 9. Dann ging der Adapter für ca. 10 min. Dann habe ich das Skript gestartet und kurz darauf läuft es nicht mehr. Skript wieder aus HEOS adapter neu starten hilft nicht. Beides verbindet wieder nicht mehr...
                DJMarc75D W 2 Antworten Letzte Antwort
                • B bouster
                  DJMarc75D Offline
                  DJMarc75D Offline
                  DJMarc75
                  #318
                  @bouster Ausgabe von
                  iob diag
                  nochmal bitte
                    bouster
                    #319
                    @djmarc75 said in [Vorlage] Denon HEOS Script:
                    iob diag
                    Skript v.2023-04-16
                    *** BASE SYSTEM ***
                    Docker          : false
                    Release:        11
                    Codename:       bullseye
                    VERSION_ID="11"
                    ID=raspbian
                    ID_LIKE=debian
                     20:16:29 up 58 min,  3 users,  load average: 6.77, 2.36, 1.62
                    CPU threads: 4
                    Raspberry only:
                    throttled=0x0
                    temp=40.4'C
                    volt=0.8900V
                                   Local time: Sun 2023-05-21 20:16:29 CEST
                               Universal time: Sun 2023-05-21 18:16:29 UTC
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    pi
                    /home/pi
                    pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin docker gpio i2c spi iobroker
                    X-Server:       true
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Mem:            3.8G        1.2G        707M         40M        1.9G        2.5G
                    Swap:            99M          0B         99M
                    Total:          3.9G        1.2G        807M
                             3794 M total memory
                             1200 M used memory
                             1853 M active memory
                              646 M inactive memory
                              707 M free memory
                              245 M buffer memory
                             1640 M swap cache
                               99 M total swap
                                0 M used swap
                               99 M free swap
                    Raspberry only:
                    oom events: 0
                    *** FILESYSTEM ***
                    /dev/root      ext4       29G   22G  6.7G  76% /
                    /dev/loop0     squashfs   47M   47M     0 100% /snap/core18/2748
                    /dev/loop1     squashfs   47M   47M     0 100% /snap/core18/2723
                    /dev/mmcblk0p3 ext4       88G   24K   84G   1% /media/pi/b6462cb4-edb3-a74c-b924-794fd764376a
                    |-/snap/core18/2748                                   /dev/loop0     squashfs ro,nodev,relatime,errors=continue
                    |-/snap/core18/2723                                   /dev/loop1     squashfs ro,nodev,relatime,errors=continue
                    `-/media/pi/b6462cb4-edb3-a74c-b924-794fd764376a /dev/mmcblk0p3 ext4     rw,nosuid,nodev,relatime,errors=remount-ro
                    /var:
                    11G     /var/
                    6.9G    /var/lib
                    4.8G    /var/lib/docker
                    3.8G    /var/log
                    Archived and active journals take up 1.7G in the file system.
                    737M    /opt/iobroker/backups/
                    275M    /opt/iobroker/iobroker-data/
                    119M    /opt/iobroker/iobroker-data/backup-objects
                    9.1M    /opt/iobroker/iobroker-data/objects.jsonl
                    /usr/bin/nodejs         v18.16.0
                    /usr/bin/node           v18.16.0
                    /usr/bin/npm            9.5.1
                    /usr/bin/npx            9.5.1
                    nodejs:
                      Installed: 18.16.0-deb-1nodesource1
                      Candidate: 18.16.0-deb-1nodesource1
                      Version table:
                     *** 18.16.0-deb-1nodesource1 500
                            500 https://deb.nodesource.com/node_18.x bullseye/main armhf Packages
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    js-controller:  4.0.24
                    admin:          6.3.5
                    javascript:     6.1.4
                    Adapters from github:   0
                    Adapter State
                    + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
                    + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1886, bind: 192.168.178.101
                    + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 192.168.178.101 (SSL), run as: admin
                    + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1885, bind: 0.0.0.0
                    + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0 (SSL), run as: admin
                    + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/ttyUSB0
                    + instance is alive
                    Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
                    Objects and States
                    Objects:        5151
                    States:         3385
                    Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                    Hit:3 https://deb.nodesource.com/node_18.x bullseye InRelease
                    Pending Updates: 0
                    xxx
                    2023-05-21 20:09:38.649  - info: host.raspberrypi object deleted system.adapter.heos.1
                    2023-05-21 20:09:38.653  - info: host.raspberrypi iobroker host.raspberrypi Deleting 22 state(s).
                    2023-05-21 20:09:39.753  - info: host.raspberrypi iobroker exit 0
                    2023-05-21 20:09:41.703  - info: admin.0 (22943) ==> Connected system.user.admin from ::ffff:192.168.178.84
                    2023-05-21 20:10:16.793  - info: admin.0 (22943) <== Disconnect system.user.admin from ::ffff:192.168.178.84
                    2023-05-21 20:10:33.806  - error: rpi2.0 (345) GPIO is not initialized!
                    2023-05-21 20:11:33.780  - error: rpi2.0 (345) GPIO is not initialized!
                    2023-05-21 20:12:33.774  - error: rpi2.0 (345) GPIO is not initialized!
                    2023-05-21 20:13:21.759  - info: admin.0 (22943) ==> Connected system.user.admin from ::ffff:192.168.178.84
                    2023-05-21 20:13:29.605  - info: admin.0 (22943) <== Disconnect system.user.admin from ::ffff:192.168.178.84
                    2023-05-21 20:13:33.772  - error: rpi2.0 (345) GPIO is not initialized!
                    2023-05-21 20:14:15.071  - info: heos.0 (3089) searching for HEOS devices ...
                    2023-05-21 20:14:23.164  - info: heos.0 (3089) searching for HEOS devices ...
                    2023-05-21 20:14:31.254  - info: heos.0 (3089) searching for HEOS devices ...
                    2023-05-21 20:14:31.272  - warn: heos.0 (3089) rebooting player 192.168.178.23
                    2023-05-21 20:14:37.186  - info: heos.0 (3089) searching for HEOS devices ...
                    2023-05-21 20:14:46.836  - info: host.raspberrypi "system.adapter.heos.0" disabled
                    2023-05-21 20:14:46.839  - info: host.raspberrypi stopInstance system.adapter.heos.0 (force=false, process=true)
                    2023-05-21 20:14:46.851  - info: heos.0 (3089) Got terminate signal TERMINATE_YOURSELF
                    2023-05-21 20:14:46.852  - info: heos.0 (3089) disconnecting from HEOS ...
                    2023-05-21 20:14:46.855  - info: heos.0 (3089) disconnected from HEOS
                    2023-05-21 20:14:46.857  - info: heos.0 (3089) terminating
                    2023-05-21 20:14:46.859  - info: heos.0 (3089) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2023-05-21 20:14:46.933  - info: host.raspberrypi stopInstance system.adapter.heos.0 send kill signal
                    2023-05-21 20:14:47.456  - info: host.raspberrypi instance system.adapter.heos.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    • B bouster
                      W Offline
                      W Offline
                      withstu
                      #320
                      @bouster welches Script startest du denn? Der Adapter ist aus dem Script aus diesem Forumseintrag entstanden. Wenn du dieses Script und den Adapter startest, hast du es doppelt laufen. Stelle das Logging Level des Adapters auf Debug und packe die Ausgabe mal hier rein.
                      • B bouster
                        @djmarc75
                        Skript v.2023-04-16
                        *** BASE SYSTEM ***
                        Docker          : false
                        Release:        11
                        Codename:       bullseye
                        VERSION_ID="11"
                        ID=raspbian
                        ID_LIKE=debian
                        CPU threads: 4
                        Raspberry only:
                        throttled=0x0
                        temp=43.3'C
                        volt=0.8900V
                                         RTC time: n/a
                                      NTP service: active
                                  RTC in local TZ: no
                        xxxxx
                        /home/xxxxx
                        X-Server:       true
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Swap:            99M          0B         99M
                                 3794 M total memory
                                 1349 M used memory
                                  246 M free memory
                                  303 M buffer memory
                                 1895 M swap cache
                                   99 M total swap
                                    0 M used swap
                                   99 M free swap
                        Raspberry only:
                        oom events: 0
                        *** FILESYSTEM ***
                        /var:
                        8.4G    /var/
                        6.9G    /var/lib
                        1.9G    /var/lib/snapd
                        nodejs:
                          Version table:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        admin:          6.3.5
                        javascript:     6.1.4
                        Adapter State
                        + instance is alive
                        Objects and States
                        Objects:        5151
                        States:         3396
                        Pending Updates: 3
                        xxx
                        #321
                        Das sind alles lokale IP-Adressen, damit kann niemand was von außen kommend anfangen.
                        Im iob diag steht ggf. nur in den 25 Zeilen aus dem iobroker log was sensibles drin. Da sollte man nochmal drüber schauen. Aber IPs aus deinem lokalen Netzwerk sind vollkommen uninteressant für 'Hacker'.
                        • W withstu
                          bouster
                          #322
                          @withstu Da kommt leider nichts nützliches bei raus... Das folgende spukt er beim Log-Level "silly" aus: und danach geht es immer mit "searching ..." weiter. Kein anderer output.
                          heos.0
                          	14832	2023-05-31 16:51:14.263	debug	searching for HEOS devices ...
                          heos.0
                          	14832	2023-05-31 16:50:44.248	info	searching for HEOS devices ...
                          heos.0
                          	14832	2023-05-31 16:50:44.044	info	starting. Version 1.10.0 in /opt/iobroker/node_modules/iobroker.heos, node: v18.16.0, js-controller: 4.0.24
                          host.raspberrypi
                          		2023-05-31 16:50:40.075	info	instance system.adapter.heos.0 started with pid 14832
                          W 1 Antwort Letzte Antwort
                          • B bouster
                            heos.0
                            heos.0
                            heos.0
                            host.raspberrypi
                            W Offline
                            W Offline
                            withstu
                            #323
                            @bouster Dann findet der Adapter die Player nicht mehr mit dem Protokoll SSDP. Prüfe mal, ob Netzwerkseitig alles passt: https://github.com/withstu/ioBroker.heos#network-requirements
                            Alternativ könntest du die statische IP eines Players in die Adapter Konfiguration als bevorzugten IP hinzufügen.
                            • W withstu
                              bouster
                              #324
                              @withstu Hallo nochmal. Ich habe den Adapter jetzt eine weitere Nacht laufen lassen und etwas mehr output bekommen:
                              heos.0
                              	14832	2023-06-01 06:58:30.112	info	searching for HEOS devices ...
                              heos.0
                              	14832	2023-06-01 06:58:25.111	debug	disconnected from HEOS
                              heos.0
                              	14832	2023-06-01 06:58:25.109	debug	data sent: heos://system/register_for_change_events?enable=off
                              heos.0
                              	14832	2023-06-01 06:58:25.109	debug	[HEARTBEAT] reset retries
                              heos.0
                              	14832	2023-06-01 06:58:25.109	debug	[HEARTBEAT] stop interval
                              heos.0
                              	14832	2023-06-01 06:58:25.109	debug	disconnecting from HEOS ...
                              heos.0
                              	14832	2023-06-01 06:58:25.109	debug	reconnecting to HEOS ...
                              heos.0
                              	14832	2023-06-01 06:58:25.108	debug	leader failure statistics: {"192.168.178.28":94,"192.168.178.23":94}
                              heos.0
                              	14832	2023-06-01 06:58:25.108	debug	[connect] Error: connect EHOSTUNREACH 192.168.178.28:1255
                              heos.0
                              	14832	2023-06-01 06:58:22.050	info	searching for HEOS devices ...
                              heos.0
                              	14832	2023-06-01 06:58:22.050	debug	connecting to HEOS (192.168.178.28) ...
                              heos.0
                              	14832	2023-06-01 06:58:22.050	debug	try to connect to 192.168.178.28 to reboot device
                              heos.0
                              	14832	2023-06-01 06:58:22.049	debug	following ips need to be rebooted: 192.168.178.28
                              heos.0
                              	14832	2023-06-01 06:58:17.048	debug	disconnected from HEOS
                              heos.0
                              	14832	2023-06-01 06:58:17.046	debug	data sent: heos://system/register_for_change_events?enable=off
                              heos.0
                              	14832	2023-06-01 06:58:17.045	debug	[HEARTBEAT] reset retries
                              heos.0
                              	14832	2023-06-01 06:58:17.045	debug	[HEARTBEAT] stop interval
                              heos.0
                              	14832	2023-06-01 06:58:17.045	debug	disconnecting from HEOS ...
                              heos.0
                              	14832	2023-06-01 06:58:17.045	debug	reconnecting to HEOS ...
                              heos.0
                              	14832	2023-06-01 06:58:17.045	debug	leader failure statistics: {"192.168.178.28":93,"192.168.178.23":94}
                              heos.0
                              	14832	2023-06-01 06:58:17.044	debug	[connect] Error: connect EHOSTUNREACH 192.168.178.23:1255
                              heos.0
                              	14832	2023-06-01 06:58:13.971	info	searching for HEOS devices ...
                              heos.0
                              	14832	2023-06-01 06:58:13.970	debug	connecting to HEOS (192.168.178.23) ...
                              heos.0
                              	14832	2023-06-01 06:58:13.970	debug	try to connect to 192.168.178.23 to reboot device
                              heos.0
                              	14832	2023-06-01 06:58:13.970	debug	following ips need to be rebooted: 192.168.178.23,192.168.178.28
                              heos.0
                              	14832	2023-06-01 06:58:08.968	debug	disconnected from HEOS
                              heos.0
                              	14832	2023-06-01 06:58:08.966	debug	[HEARTBEAT] reset retries
                              heos.0
                              	14832	2023-06-01 06:58:08.966	debug	[HEARTBEAT] stop interval
                              heos.0
                              	14832	2023-06-01 06:58:08.966	debug	disconnecting from HEOS ...
                              heos.0
                              	14832	2023-06-01 06:58:08.965	debug	reconnecting to HEOS ...
                              heos.0
                              	14832	2023-06-01 06:58:07.964	debug	add reboot ip 192.168.178.28
                              heos.0
                              	14832	2023-06-01 06:58:07.964	debug	add reboot ip 192.168.178.23
                              heos.0
                              	14832	2023-06-01 06:58:07.964	debug	rebooting all players
                              heos.0
                              	14832	2023-06-01 06:58:07.963	debug	can't find any HEOS devices. Try to connect known device IPs and reboot them to exclude device failure...
                              heos.0
                              	14832	2023-06-01 06:57:37.961	debug	searching for HEOS devices ...
                              • B bouster
                                heos.0
                                heos.0
                                heos.0
                                heos.0
                                heos.0
                                heos.0
                                heos.0
                                heos.0
                                heos.0
                                heos.0
                                heos.0
                                heos.0
                                heos.0
                                heos.0
                                heos.0
                                heos.0
                                heos.0
                                heos.0
                                heos.0
                                heos.0
                                heos.0
                                heos.0
                                heos.0
                                heos.0
                                heos.0
                                heos.0
                                heos.0
                                heos.0
                                heos.0
                                heos.0
                                heos.0
                                heos.0
                                heos.0
                                heos.0
                                heos.0
                                W Offline
                                W Offline
                                withstu
                                #325
                                @bouster Der Adapter kann keine Verbindung zu Port 1255 des Players aufbauen (EHOSTUNREACH 192.168.178.28:1255). Hast du mal versucht die Player kurz vom Strom zu nehmen?
                                • W withstu
                                  bouster
                                  #326
                                  @withstu Beide player 192.168.178.28:1255 und 192.168.178.23:1255 werden regelmäßig vom Netz genommen und nur bei bedarf gestartet.
                                  Was (soweit mein Verständnis reicht) merkwürdig ist, ist dass er die Player neustarten kann. Dann muss er den Player doch auch finden.
                                  • B bouster
                                    W Offline
                                    W Offline
                                    withstu
                                    #327
                                    @bouster nicht ganz. Der Adapter versucht die Player zu rebooten, kann sich aber nicht verbinden. Wenn der Adapter keinen Player über SSDP finden kann, versucht er sich nacheinander mit allen bereits bekannten IPs aus den Player States direkt zu verbinden und die Player neu zu starten. So wird versucht mögliche SSDP Fehler durch Reboot der Player zu beheben.
                                    • W withstu
                                      bouster
                                      #328
                                      @withstu Da das leider alles nicht geholfen hat. Frage ich mich auf welche Weise kommen sich denn das Skript und der Adapter in die Quere? Könnte da das Problem liegen, dass ich beides mal ausgeführt habe?
                                        bouster
                                        #329
                                        ich habe es final endlich hinbekommen und der Adapter läuft jetzt. Ich weiß nicht was anders ist als vorher. Es hat nun ohne andere Änderungen funktioniert den Adapter zu verbinden, jedoch nur mit direkter IP Eingabe der Player.
                                        • hg6806H Offline
                                          hg6806H Offline
                                          hg6806
                                          #330
                                          Hi, ich bin gerade hier auf den Thread gestoßen und möchte auch die Browser Funktion umsetzen.
                                          Das hat soweit geklappt, jedoch habe ich nicht die beiden Zeile "Overview" und "Back". Wie bekommt man die?
