  5. [gelöst] Ausführung trotz Triggern Zeitplan
198 Beiträge 5 Kommentatoren 40.7k Aufrufe 2 Beobachtet
    @woupi
    Doch. Aber dein System ist zu alt...
    iob stop
    iob fix
    iob start
    Wenn der ioBroker wieder läuft nochmal
    iob diag
    W Offline
    W Offline
    woupi
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Architecture    : x86_64
    Docker          : false
    Virtualization  : kvm
    Distributor ID: Ubuntu
    Description:    Ubuntu 20.04.6 LTS
    Release:        20.04
    Codename:       focal
    NAME="Ubuntu"
    VERSION="20.04.6 LTS (Focal Fossa)"
    ID=ubuntu
    ID_LIKE=debian
    PRETTY_NAME="Ubuntu 20.04.6 LTS"
    VERSION_ID="20.04"
    HOME_URL="https://www.ubuntu.com/"
    SUPPORT_URL="https://help.ubuntu.com/"
    BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
    PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
    VERSION_CODENAME=focal
    UBUNTU_CODENAME=focal
    Systemuptime and Load:
     21:24:21 up 7 days,  4:35,  1 user,  load average: 0.57, 0.76, 0.88
    CPU threads: 8
    *** Time and Time Zones ***
                   Local time: Sat 2023-05-20 21:24:21 CEST
               Universal time: Sat 2023-05-20 19:24:21 UTC
                     RTC time: Sat 2023-05-20 19:24:22
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    bernhard
    /home/bernhard
    bernhard adm cdrom sudo dip plugdev lxd iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:           8.0G        1.0G        5.0G        1.0M        2.0G        6.6G
    Swap:          1.2G          0B        1.2G
    Total:         9.2G        1.0G        6.2G
             7957 M total memory
             1032 M used memory
             1717 M active memory
              817 M inactive memory
             4954 M free memory
              267 M buffer memory
             1702 M swap cache
             1224 M total swap
                0 M used swap
             1224 M free swap
    *** FILESYSTEM ***
    Filesystem                        Type      Size  Used Avail Use% Mounted on
    udev                              devtmpfs  3.9G     0  3.9G   0% /dev
    tmpfs                             tmpfs     796M  1.2M  795M   1% /run
    /dev/mapper/ubuntu--vg-ubuntu--lv ext4       49G   13G   34G  28% /
    tmpfs                             tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs                             tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs                             tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
    /dev/sda2                         ext4      974M  209M  699M  23% /boot
    /dev/loop1                        squashfs   56M   56M     0 100% /snap/core18/2745
    /dev/loop0                        squashfs   56M   56M     0 100% /snap/core18/2721
    /dev/loop4                        squashfs   92M   92M     0 100% /snap/lxd/24061
    /dev/loop5                        squashfs   54M   54M     0 100% /snap/snapd/19122
    /dev/loop3                        squashfs   64M   64M     0 100% /snap/core20/1879
    /dev/loop6                        squashfs   92M   92M     0 100% /snap/lxd/23991
    /dev/loop7                        squashfs   54M   54M     0 100% /snap/snapd/18933
    /dev/loop8                        squashfs   64M   64M     0 100% /snap/core20/1891
    tmpfs                             tmpfs     796M     0  796M   0% /run/user/1000
    [Sat May 13 16:48:29 2023] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null)
    [Sat May 13 16:48:30 2023] EXT4-fs (dm-0): re-mounted. Opts: (null)
    [Sat May 13 16:48:32 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
    TARGET                SOURCE                            FSTYPE   OPTIONS
    /                     /dev/mapper/ubuntu--vg-ubuntu--lv ext4     rw,relatime
    |-/sys/kernel/tracing tracefs                           tracefs  rw,nosuid,nodev,noexec,relatime
    |-/boot               /dev/sda2                         ext4     rw,relatime
    |-/snap/core18/2745   /dev/loop1                        squashfs ro,nodev,relatime
    |-/snap/core18/2721   /dev/loop0                        squashfs ro,nodev,relatime
    |-/snap/lxd/24061     /dev/loop4                        squashfs ro,nodev,relatime
    |-/snap/snapd/19122   /dev/loop5                        squashfs ro,nodev,relatime
    |-/snap/core20/1879   /dev/loop3                        squashfs ro,nodev,relatime
    |-/snap/lxd/23991     /dev/loop6                        squashfs ro,nodev,relatime
    |-/snap/snapd/18933   /dev/loop7                        squashfs ro,nodev,relatime
    `-/snap/core20/1891   /dev/loop8                        squashfs ro,nodev,relatime
    /var:
    5.3G    /var/
    4.0G    /var/log/journal/b8deab8c07c0438d8db0cb002e27450e
    4.0G    /var/log
    1.2G    /var/lib
    Archived and active journals take up 3.9G in the file system.
    /opt/iobroker/backups:
    121M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    649M    /opt/iobroker/iobroker-data/
    380M    /opt/iobroker/iobroker-data/files
    110M    /opt/iobroker/iobroker-data/backup-objects
    78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
    76M     /opt/iobroker/iobroker-data/history
    15M     /opt/iobroker/iobroker-data/objects.jsonl
    15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
    7.2M    /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js
    6.9M    /opt/iobroker/iobroker-data/files/telegram.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.8fdf8cb7.chunk.js.map
    6.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.de0231c9.chunk.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v14.21.3
    /usr/bin/node           v14.21.3
    /usr/bin/npm            6.14.18
    /usr/bin/npx            6.14.18
    nodejs:
      Installed: 14.21.3-deb-1nodesource1
      Candidate: 14.21.3-deb-1nodesource1
      Version table:
     *** 14.21.3-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_14.x focal/main amd64 Packages
         10.19.0~dfsg-3ubuntu1 500
            500 http://de.archive.ubuntu.com/ubuntu focal/universe amd64 Packages
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.3.5
    javascript:     6.1.4
    npm ERR! peer dep missing: buffer@>=6.0.3, required by crc@4.1.1
    Adapters from github:   18
    Adapter State
      system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
      system.adapter.ble.0                    : ble                   : iobroker                                 -  enabled
      system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
      system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
      system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
      system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
      system.adapter.flot.0                   : flot                  : iobroker                                 -  enabled
      system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker                                 -  enabled
      system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iobroker                                 -  enabled
      system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 -  enabled
      system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 -  enabled
      system.adapter.icons-material-svg.0     : icons-material-svg    : iobroker                                 -  enabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 -  enabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 -  enabled
    + system.adapter.influxdb.1               : influxdb              : iobroker                                 -  enabled, port: 8086
    + system.adapter.influxdb.2               : influxdb              : iobroker                                 -  enabled, port: 8086
    + system.adapter.influxdb.3               : influxdb              : iobroker                                 -  enabled, port: 8086
      system.adapter.info.0                   : info                  : iobroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
      system.adapter.mielecloudservice.0      : mielecloudservice     : iobroker                                 -  enabled
    + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
    + system.adapter.modbus.1                 : modbus                : iobroker                                 -  enabled
      system.adapter.modbus.2                 : modbus                : iobroker                                 -  enabled
      system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.netatmo.0                : netatmo               : iobroker                                 -  enabled
    + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
      system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
      system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
      system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
      system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      system.adapter.sma-em.0                 : sma-em                : iobroker                                 -  enabled
      system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
      system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
      system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled
      system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 -  enabled
      system.adapter.vis-map.0                : vis-map               : iobroker                                 -  enabled
      system.adapter.vis-metro.0              : vis-metro             : iobroker                                 -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
      system.adapter.vis-weather.0            : vis-weather           : iobroker                                 -  enabled
      system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
      system.adapter.vw-connect.0             : vw-connect            : iobroker                                 -  enabled
      system.adapter.vw-connect.1             : vw-connect            : iobroker                                 -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
      system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.web.1                    : web                   : iobroker                                 -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker                                 -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "backitup"     : 2.6.19   , installed 2.6.19
    Adapter    "ble"          : 0.13.0   , installed 0.13.0
    Adapter    "cloud"        : 4.3.0    , installed 4.3.0
    Adapter    "daswetter"    : 3.1.8    , installed 3.1.8
    Adapter    "flot"         : 1.11.0   , installed 1.11.0
    Adapter    "fritzdect"    : 2.2.6    , installed 2.2.6
    Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
    Adapter    "javascript"   : 6.1.4    , installed 6.1.4
    Adapter    "mielecloudservice": 6.5.4, installed 6.5.4
    Adapter    "modbus"       : 5.0.11   , installed 5.0.11
    Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
    Adapter    "mqtt-client"  : 1.6.3    , installed 1.6.3
    Adapter    "netatmo"      : 2.0.5    , installed 2.0.5
    Adapter    "node-red"     : 4.0.0    , installed 4.0.0
    Adapter    "openweathermap": 0.3.3   , installed 0.3.3
    Adapter    "shelly"       : 6.3.1    , installed 6.3.1
    Adapter    "shuttercontrol": 1.4.29  , installed 1.4.29
    Adapter    "telegram"     : 1.15.2   , installed 1.15.2
    Adapter    "trashschedule": 2.2.0    , installed 2.2.0
    Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
    Adapter    "vis-icontwo"  : 0.93.0   , installed 0.93.0
    Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
    Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
    Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
    Adapter    "vw-connect"   : 0.0.67   , installed 0.0.67
    Adapter    "weatherunderground": 3.4.2, installed 3.4.2
    Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
    Objects and States
    Objects:        14226
    States:         12802
    Hit:1 http://de.archive.ubuntu.com/ubuntu focal InRelease
    Hit:2 http://de.archive.ubuntu.com/ubuntu focal-updates InRelease
    Hit:3 http://de.archive.ubuntu.com/ubuntu focal-backports InRelease
    Hit:4 https://deb.nodesource.com/node_14.x focal InRelease
    Hit:5 http://de.archive.ubuntu.com/ubuntu focal-security InRelease
    Reading package lists...
    Pending Updates: 1
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       12560150   53281/iobroker.js-c
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       12560149   53281/iobroker.js-c
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          15672      1/init
    tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      101        23980      706/systemd-resolve
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          27180      776/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       12558229   53440/node-red
    tcp6       0      0 :::111                  :::*                    LISTEN      0          17744      1/init
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       12560197   53316/io.admin.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          27193      776/sshd: /usr/sbin
    udp        0      0 127.0.0.53:53           0.0.0.0:*                           101        23979      706/systemd-resolve
    udp        0      0 192.168.1.133:68        0.0.0.0:*                           100        8733747    704/systemd-network
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          17741      1/init
    udp6       0      0 :::111                  :::*                                0          16735      1/init
    udp6       0      0 fe80::24bc:3cff:fe9:546 :::*                                100        23013      704/systemd-network
    2023-05-20 21:24:36.460  - info: admin.0 (53316) failed connection to socket.io from ::ffff:192.168.1.108: Passport was not initialized
    2023-05-20 21:24:37.727  - info: admin.0 (53316) failed connection to socket.io from ::ffff:192.168.1.108: Passport was not initialized
    2023-05-20 21:24:37.779  - info: admin.0 (53316) failed connection to socket.io from ::ffff:192.168.1.108: Passport was not initialized
    2023-05-20 21:24:39.334  - info: host.iobroker instance system.adapter.mielecloudservice.0 started with pid 53732
    2023-05-20 21:24:40.099  - info: mielecloudservice.0 (53732) starting. Version 6.5.4 in /opt/iobroker/node_modules/iobroker.mielecloudservice, node: v14.21.3, js-controller: 4.0.24
    2023-05-20 21:24:40.111  - info: mielecloudservice.0 (53732) Login attempt #1 @Miele-API
    2023-05-20 21:24:40.450  - info: mielecloudservice.0 (53732) Access token expires on: 19.6.2023, 21:24:00
    2023-05-20 21:24:40.450  - info: mielecloudservice.0 (53732) Registering for all appliance events at Miele API.
    2023-05-20 21:24:40.452  - info: mielecloudservice.0 (53732) Initializing SSE watchdog.
    2023-05-20 21:24:40.523  - info: mielecloudservice.0 (53732) Server Sent Events-Connection has been established @Miele-API.
    2023-05-20 21:24:40.778  - info: mielecloudservice.0 (53732) Sorry. No programs to add for device: Trockner (000125877256). Reason: Device 000125877256 is not in the correct state.
    2023-05-20 21:24:43.363  - info: host.iobroker instance scheduled system.adapter.weatherunderground.0 2 * * * *
    2023-05-20 21:24:43.372  - info: host.iobroker instance system.adapter.weatherunderground.0 started with pid 53771
    2023-05-20 21:24:44.256  - info: weatherunderground.0 (53771) starting. Version 3.4.2 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v14.21.3, js-controller: 4.0.24
    2023-05-20 21:24:44.860  - info: weatherunderground.0 (53771) WUnderground API returned 204, no data available. The configured station might be offline
    2023-05-20 21:24:45.240  - error: weatherunderground.0 (53771) No current observation data found in response
    2023-05-20 21:24:47.323  - info: host.iobroker instance scheduled system.adapter.ical.0 0,30 * * * *
    2023-05-20 21:24:47.331  - info: host.iobroker instance system.adapter.ical.0 started with pid 53798
    2023-05-20 21:24:48.222  - info: ical.0 (53798) starting. Version 1.13.2 in /opt/iobroker/node_modules/iobroker.ical, node: v14.21.3, js-controller: 4.0.24
    2023-05-20 21:24:48.772  - info: weatherunderground.0 (53771) Terminated (NO_ERROR): Without reason
    2023-05-20 21:24:49.313  - info: host.iobroker instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
    2023-05-20 21:24:49.761  - info: ical.0 (53798) processing URL: Müll https://calendar.google.com/calendar/ical/s.w.bernhard%40gmail.com/private-21faa25aa0eb243313582d9996cb7327/basic.ics
    2023-05-20 21:24:51.326  - info: host.iobroker instance scheduled system.adapter.openweathermap.0 23 * * * *
    2023-05-20 21:24:51.338  - info: host.iobroker instance system.adapter.openweathermap.0 started with pid 54645
    2023-05-20 21:24:52.137  - info: openweathermap.0 (54645) starting. Version 0.3.3 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v14.21.3, js-controller: 4.0.24
    iob diag has finished.
    Press any key for a summary
    NUC10i3, Proxmox, VM Ubuntu iobroker, lxc ubuntu influxdb, grafana, lxc ubuntu SAE, lxc ubuntu MotionEye, WP Panasonic Jeisha 5kW mit Heishamon, Shelly 2.5 und 2pm Rolladensteuerung, OpenWB Wallbox
    • W woupi
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Docker          : false
      Release:        20.04
      Codename:       focal
      NAME="Ubuntu"
      ID=ubuntu
      ID_LIKE=debian
      VERSION_ID="20.04"
      CPU threads: 8
                    NTP service: active
                RTC in local TZ: no
      bernhard
      /home/bernhard
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:          1.2G          0B        1.2G
               7957 M total memory
               1032 M used memory
               4954 M free memory
                267 M buffer memory
               1702 M swap cache
               1224 M total swap
                  0 M used swap
               1224 M free swap
      *** FILESYSTEM ***
      /var:
      5.3G    /var/
      4.0G    /var/log
      1.2G    /var/lib
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.3.5
      javascript:     6.1.4
      Adapter State
      + instance is alive
      Objects and States
      Objects:        14226
      States:         12802
      Pending Updates: 1
      @woupi sagte in Ausführung trotz Triggern Zeitplan:
      Ansich nichts wirklich wildes.
      Nur
      nodejs v14.21.3
      solltest du auf nodejs@18 updaten.
      W HomoranH 2 Antworten Letzte Antwort
        Nur
        nodejs v14.21.3
        W Offline
        W Offline
        woupi
        Ok, vielen Dank, werde ich morgen Früh gleich erledigen.
        Wie oft sollte man das mit dem iob fix erledigen?
        • W woupi
          Kann man ab und an mal machen.
          W 1 Antwort Letzte Antwort
            Nur
            nodejs v14.21.3
            @thomas-braun sagte in Ausführung trotz Triggern Zeitplan:
            Nur
            nodejs v14.21.3
            ich hab auch nichts gesehen, hatte orphans vermutet oder RO
            Lediglich
              W Offline
              W Offline
              woupi
              Danke, so lernt man jeden Tag was dazu, auch in dem fast Rentenalter 😊
                Nur
                nodejs v14.21.3
                Lediglich
                W Offline
                W Offline
                woupi
                @homoran sagte in Ausführung trotz Triggern Zeitplan:
                • W woupi
                  @woupi @Homoran
                  aber die Hälfte der Adapter aus dem github geangelt...
                  Die räudige Katze ist NICHT der Standardweg um Adapter zu installieren, auch wenn das offenbar warum auch immer weit verbreitet zu sein scheint.
                  • W woupi
                    @tt-tom sagte in Ausführung trotz Triggern Zeitplan:
                    @woupi
                    Sieht ganz so aus das deine Variable Liste_PV den Wert verloren hat.
                    Starte mal deine JavaScript Instanz neu.
                    Ok, habe ich gemacht, Not found kommt aber direkt wieder.
                    TT-Tom
                    @woupi
                    Du setzt die Variable mit dem Datenpunkt und möchtest du zwei Schritte weiter die Variable als Liste nutzen, das geht nicht. Du musst beim setzten der Variable Liste _PV eine leere Liste erzeugen. Dann kannst du die Variable auch als Liste nutzen.
                    Zum Schluss schreibt man die Liste in den Datenpunkt.
                    Gruß Tom
                    Public Transport
                    NSPanel Adapter Wiki
                    W HomoranH 3 Antworten Letzte Antwort
                      @woupi @Homoran
                      W Offline
                      W Offline
                      woupi
                      ist mir so gar nicht bewusst gewesen, also ja an 2 kann ich mich direkt erinnern, aber 18.
                      Kann ich irgendwie erkennen welche das sind?
                      • W woupi
                        cd /opt/iobroker
                        npm ls | grep github
                        • T TT-Tom
                          @woupi
                          W Offline
                          W Offline
                          woupi
                          @woupi
                          das hatte ich oben am Anfang so bekommen:
                          meins war so:
                          W T 2 Antworten Letzte Antwort
                          • W woupi
                            @woupi
                            meins war so:
                            W Offline
                            W Offline
                            woupi
                            ├─┬ iobroker.energiefluss@3.6.0 (github:SKB-CGN/ioBroker.energiefluss#53944cad71449ceaa41c275f432df5423f218054)
                            ├─┬ iobroker.icons-icons8@0.0.1 (github:ioBroker/ioBroker.icons-icons8#c0fcc9a6aa79b281951215cf86726f45622c8409)
                            ├─┬ iobroker.icons-open-icon-library-png@0.1.3 (github:ioBroker/ioBroker.icons-open-icon-library-png#0847a79d713ee6725ccb6ccfb044c025b73ec946)
                            ├─┬ iobroker.shuttercontrol@1.4.29 (github:simatec/ioBroker.shuttercontrol#2c423fe0c8b2f0e0b385abaf912e93c3e1d39f36)
                            ├─┬ iobroker.sourceanalytix@0.4.14 (github:DrozmotiX/ioBroker.sourceanalytix#42c45d3e9a581869b0ba9cf710dbecb42ca3e574)
                            │   ├── github-url-from-git@1.5.0
                            │   ├─┬ new-github-release-url@1.0.0
                            ├── iobroker.vis-map@1.0.4 (github:ioBroker/ioBroker.vis-map#b4a286f8d954e09b1b96e51914386ae73b09eecf)
                            ├── iobroker.vis-materialdesign@0.5.76 (github:Scrounger/ioBroker.vis-materialdesign#43f3a07d7b48f367612c19ef678935709f718aae)
                            bernhard@iobroker:/opt/iobroker$
                            Das sind 7, oder sehe ich das falsch und keine 18.
                            Wenn ich euch richtig verstanden habe, sollte ich die alle deinstallieren, oder?
                            • W woupi
                              Nein, aber die Herangehensweise an Installationen überdenken. Zuerst immer aus den Repos nehmen, erst wenn es einen sehr guten Grund dafür gibt (z. B. weil der Maintainer was testen will) fischt man im github.
                              • W woupi
                                @woupi
                                meins war so:
                                TT-Tom
                                @woupi
                                Dann musst du nochmal prüfen, ob in dem DP wirklich eine Liste ist.
                                Gruß Tom
                                Public Transport
                                  W Offline
                                  W Offline
                                  woupi
                                  Das habe ich auch versucht zu beachten.
                                  Shuttercontrol und energiefluss gibt es allerdings z.B. nur über die Katze.
                                  Mir war nicht klar, dass man die Adapter dann besser gar nicht installiert.
                                  • W woupi
                                    Shuttercontrol ... gibt es allerdings z.B. nur über die Katze.
                                    whattt???
                                    schon jahrelang im stable
                                    • T TT-Tom
                                      @woupi
                                      W Offline
                                      W Offline
                                      woupi
                                      @woupi
                                      Könntest Du mir sagen, wie ich das raus bekomme?
                                      Unter Wert steht (Null)
                                        whattt???
                                        W Offline
                                        W Offline
                                        woupi
                                        meine ich, also, sonst hätte ich das auch normal installiert.
                                        Ist aber auch schon wieder etwas her, kann mich da auch jetzt vertun.
                                        • W woupi
