  3. Einsteigerfragen
  4. Installation
  5. IOBroker backup auf neue Rasperry übertragen
65 Beiträge 5 Kommentatoren 5.0k Aufrufe 3 Beobachtet
  • M Metzid
    pi@piiobroker:/opt/iobroker $ iob fix
    library: loaded
    Library version=2022-12-09
        Welcome to the ioBroker installation fixer!
        Script version: 2023-04-02
        You might need to enter your password a couple of times.
        Installing prerequisites (1/5)
    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Get:3 http://deb.debian.org/debian bullseye-updates InRelease [44.1 kB]
    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:5 https://deb.nodesource.com/node_18.x bullseye InRelease
    Reading package lists... Done
    Installed gcc-c++
        Checking ioBroker user and directory permissions (2/5)
        Check and cleanup npm temporary directories (3/5)
    Done.
        Database maintenance (4/5)
    Checking for uncompressed JSONL databases... This might take a while!
    Compressing /opt/iobroker/iobroker-data/states.jsonl
    Compressing /opt/iobroker/iobroker-data/objects.jsonl
    Compressed 2 JSONL files. Done
        Checking autostart (5/5)
    Enabling autostart...
    Autostart enabled!
        Your installation was fixed successfully
        Run iobroker start to start ioBroker again!
    pi@piiobroker:/opt/iobroker $ iob start
    leider über browser nicht erreichbar
    crunchipC Abwesend
    crunchipC Abwesend
    @metzid sagte in IOBroker backup auf neue Rasperry übertragen:
    iob list instances
    M 2 Antworten Letzte Antwort
    • M Metzid
      @thomas-braun aber Fehler hat er beim fix nicht gebracht
      Der Fixer gibt auch keine Fehlerdiagnose aus, der fixt es einfach.
        iob list instances
        Metzid
        @crunchip
        pi@piiobroker:/opt/iobroker $ iobroker setup custom
        Current configuration:
        - Objects database:
          - Type: jsonl
          - Host/Unix Socket: 127.0.0.1
          - Port: 9001
        - States database:
          - Type: jsonl
          - Port: 9000
        - Data Directory: ../../iobroker-data/
        Type of objects DB [(j)sonl, (f)ile, (r)edis, ...], default [jsonl]: f
        Host / Unix Socket of objects DB(file), default[127.0.0.1]: f
        Port of objects DB(file), default[9001]:
        Type of states DB [(j)sonl, (f)file, (r)edis, ...], default [file]: f
        Host / Unix Socket of states DB (file), default[f]: f
        Port of states DB (file), default[9000]:
        Host name of this machine [piiobroker]: piiobroker
        Please choose if this is a Master/single host (enter "m") or a Slave host (enter "S") you are about to edit. For Slave hosts the data migration will be skipped. [S/m]: m
        Do you want to migrate objects and states from "jsonl/jsonl" to "file/file" [y/N]: y
        Migrating the objects database will overwrite all objects! Are you sure that this is not a slave host and you want to migrate the data? [y/N]: y
        Connecting to previous DB "jsonl"...
        Creating backup ...
        This can take some time ... please be patient!
        host.piiobroker 1626 states saved
        host.piiobroker 2188 objects saved
        Backup created: /opt/iobroker/backups/2023_04_26-22_38_38_backupiobroker-migration.tar.gz
        updating conf/iobroker.json
        Connecting to new DB "file" (can take up to 20s) ...
        Server Cannot load /opt/iobroker/iobroker-data/objects.json: Database file /opt/iobroker/iobroker-data/objects.json does not exists.. We try last Backup!
        Server Cannot load /opt/iobroker/iobroker-data/objects.json.bak: Database file /opt/iobroker/iobroker-data/objects.json.bak does not exists.. Continue with empty dataset!
        Server If this is no Migration or initial start please restore the last backup from /opt/iobroker/iobroker-data/backup-objects
        No connection to databases possible ...
        New Database could not be connected. Please check your settings. No settings have been changed.
        restoring conf/iobroker.json
          iob list instances
          Metzid
          @crunchip
          pi@piiobroker:/opt/iobroker $ iob list instances
            system.adapter.admin.0                  : admin                 : piiobroker                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            system.adapter.broadlink2.0             : broadlink2            : piiobroker                               - disabled
            system.adapter.hm-rega.0                : hm-rega               : piiobroker                               - disabled
            system.adapter.hm-rpc.0                 : hm-rpc                : piiobroker                               - disabled, port: 0
            system.adapter.iot.0                    : iot                   : piiobroker                               - disabled
            system.adapter.javascript.0             : javascript            : piiobroker                               - disabled
            system.adapter.scenes.0                 : scenes                : piiobroker                               - disabled
            system.adapter.web.0                    : web                   : piiobroker                               - disabled, port: 8082, bind: 0.0.0.0, run as: admin
          + instance is alive
          • M Metzid
            @crunchip
            - Objects database:
              - Type: jsonl
              - Port: 9001
            - States database:
              - Type: jsonl
              - Port: 9000
            Creating backup ...
            crunchipC Abwesend
            crunchipC Abwesend
            Creating backup ...
            Also müsste ja eigentlich eine jeweilige jsonl vorhanden sein, aber wohl nur als backup
            • M Metzid
              @crunchip
              + instance is alive
              crunchipC Abwesend
              crunchipC Abwesend
              @metzid da läuft kein admin, soweit man hier sehen kann
                Metzid
                @crunchip wie kann ich den admin
                starten
                • M Metzid
                  starten
                  crunchipC Abwesend
                  crunchipC Abwesend
                  @metzid
                  iob start admin
                    @metzid
                    iob start admin
                    Metzid
                    @crunchip
                    pi@piiobroker:/opt/iobroker $ iob start admin
                    + instance is alive
                    Leider über Browser nicht erreichbar
                      @metzid
                      iob start admin
                      Metzid
                      @crunchip Hallo guten Morgen. Ich habe mir heute Nacht nochmals überlegt ob es Sinn macht das Image des neuen Raspberry mit neiem OS und iobroker nochmals einzuspielen dann die datenbank auf file/file umzustellen und dann ein restore des iobrokers zu fahren. Dann dürfte doch zumindest die datenbbank auf dem Level des restores dein. Oder mache ich da einen Denkfehler.
                      Noch eine kurze Frage wenn so ein Restore gefahren wird werden dann die ganzen Module /Datenbanken auf dem raspberry auf die Versionsnummer des Altgerätes zurückgestellt. Oder gibt es eine versionsabhängigkeit wo dann nur der Inhalt der verschiedenen Datenbank und Module zurückgespielt wird so dass keine Instalation auf die alten Level erfolgt also rein Daten eingespielt werden. Sollte man da schon die ganzen Adapter die auch im alten Backup hinterlegt sind schon in der neuen Version installieren so dass das System nur noch Daten zurück spielt und keine Adapter auf alte Versionen zurücksetzt. Oder gibt es da eine versionsabhängigkeit ab wann das iobroker Backup nur Daten oder auch Versionen zurückspielt.
                      • crunchipC Abwesend
                        crunchipC Abwesend
                        nein, um ein backup zurückzuspielen, müssen keine Adapter im Vorfeld installiert werden, das beinhaltet alles das backup. Einzige Ausnahme aufgrund eines bugs, muss vis (falls genutzt wird) vor dem backup installiert werden.
                        kannst du versuchen
                        M 4 Antworten Letzte Antwort
                          kannst du versuchen
                          Metzid
                          @crunchipnein habe kein vis
                          versuche es jetzt gleich
                            kannst du versuchen
                            Metzid
                            @crunchip @crunchip hier der log iobroker ist dann wieder problemlos gestartet
                            login as: pi
                            pi@192.168.178.172's password:
                            Linux piiobroker 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr  3 17:24:16 BST 2023 aarch64
                            permitted by applicable law.
                            Last login: Wed Apr 26 11:31:28 2023
                            Wi-Fi is currently blocked by rfkill.
                            Use raspi-config to set the country before use.
                            pi@piiobroker:~ $ cd /opt/iobroker
                            pi@piiobroker:/opt/iobroker $ iobroker stop
                            - Objects database:
                              - Type: jsonl
                              - Port: 9001
                            - States database:
                              - Type: jsonl
                              - Port: 9000
                            Host / Unix Socket of states DB (file), default[127.0.0.1]:
                            Data directory (file), default[../../iobroker-data/]:
                            This host appears to be a Master or a Single host system. Is this correct? [Y/n]: y
                            Creating backup ...
                            host.piiobroker 102 states saved
                            host.piiobroker 143 objects saved
                            Backup created: /opt/iobroker/backups/2023_04_27-09_30_42_backupiobroker-migration.tar.gz
                            Server Cannot load /opt/iobroker/iobroker-data/states.json: Database file /opt/iobroker/iobroker-data/states.json does not exists.. We try last Backup!
                            Server Cannot load /opt/iobroker/iobroker-data/states.json.bak: Database file /opt/iobroker/iobroker-data/states.json.bak does not exists.. Continue with empty dataset!
                             Cannot read system.config: null (OK when migrating or restoring)
                            Restore backup ...
                            iobroker controller daemon is not running
                            host.piiobroker OK.
                            host.piiobroker Clear all objects and states...
                            clean 2 objects...
                            clean 2 states...
                            host.piiobroker done.
                            host.piiobroker Processed 0/143 objects
                            143 objects restored.
                            host.piiobroker Processed 0/102 states
                            102 states restored.
                            upload [52] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
                            upload [50] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/customComponents.js.map custom/customComponents.js.map application/json
                            upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/zh-cn.json custom/i18n/zh-cn.json application/json
                            upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js.map custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js.map application/json
                            upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map application/json
                            upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js application/javascript
                            upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map application/json
                            upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js application/javascript
                            upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map application/json
                            upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js application/javascript
                            upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map application/json
                            upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js application/javascript
                            upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map application/json
                            upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
                            upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
                            upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
                            upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                            upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
                            upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                            upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                            upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                            upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                            upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                            upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                            upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5 jsonConfig.json5 application/json5
                            upload [21] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
                            upload [20] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
                            upload [19] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
                            upload [18] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/de/translations.json i18n/de/translations.json application/json
                            upload [17] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/en/translations.json i18n/en/translations.json application/json
                            upload [16] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/es/translations.json i18n/es/translations.json application/json
                            upload [15] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                            upload [14] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/it/translations.json i18n/it/translations.json application/json
                            upload [13] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                            upload [12] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                            upload [11] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                            upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                            upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                            upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                            upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
                            upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
                            upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
                            upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
                            upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
                            upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
                            upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
                            upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
                            upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
                            upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
                            upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
                            upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
                            upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
                            upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
                            upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
                            Reinstalling adapter "admin" from "iobroker.admin@6.3.5"
                            removed 1 package, and changed 4 packages in 45s
                            45 packages are looking for funding
                              run `npm fund` for details
                            Reinstalling adapter "backitup" from "iobroker.backitup@2.6.19"
                            up to date in 6s
                            Could not migrate objects to corresponding sets: Cannot read properties of undefined (reading 'getObjectList')
                            Backup restored - Migration successful
                            Important: If your system consists of multiple hosts please execute
                            "iobroker upload all" on the master AFTER all other hosts/slaves have
                            also been updated to this states/objects database configuration AND are
                            running!
                            MOD-EDIT: Code in code-tags gesetzt
                              kannst du versuchen
                              Metzid
                              @crunchip nach dem restore startet der iobroker leider nicht mehr. Soll ich iobroker fix ausführen
                              login as: pi
                              - Objects database:
                                - Type: jsonl
                                - Port: 9001
                              - States database:
                                - Type: jsonl
                                - Port: 9000
                              Creating backup ...
                              Restore backup ...
                              host.piiobroker OK.
                              clean 2 objects...
                              clean 2 states...
                              up to date in 6s
                              running!
                                kannst du versuchen
                                Metzid
                                @crunchip leider startet der ibroker jetzt nicht mehr soll ich den ibroker fix anstoßen
                                • M Metzid
                                  login as: pi
                                  - Objects database:
                                    - Type: jsonl
                                    - Port: 9001
                                  - States database:
                                    - Type: jsonl
                                    - Port: 9000
                                  Creating backup ...
                                  Restore backup ...
                                  host.piiobroker OK.
                                  clean 2 objects...
                                  clean 2 states...
                                  up to date in 6s
                                  running!
                                  crunchipC Abwesend
                                  crunchipC Abwesend
                                  ein restore dauert auch eine Weile, wie lange hast du gewartet?
                                  und generell, auf welchem Stand ist deine alte Installation bzw das backup?
                                    Metzid
                                    @crunchip Altsystem Raspberry 3B
                                    • Plattform: linux
                                    • Die Architektur: arm
                                    • CPUs: 4
                                    • Geschwindigkeit: 1200 MHz
                                    • Modell: ARMv7 Processor rev 4 (v7l)
                                    • RAM: 923.3 MB
                                    • System-Betriebszeit: 00:45:28
                                    • Node.js: v10.18.0
                                    • NPM: 6.13.4
                                    • Datenträgergröße: 12.9 GiB
                                    • Datenträger verfügbar: 7.5 GiB
                                    • Adapter-Anzahl: 471
                                    • Betriebszeit: 23:32:45
                                    • Aktive Instanzen: 8
                                    Betriebsystem Jessie
                                    Der Js-controller hat die Version ist 2.1.1 Jetzt wollte ich das System updaten leider scheint die installierte Raspbain GUN linux8 Jessie nicht mehr mit den neuen JS-controllern unterstützt zu werden. Wenn ich da einen update durchführen verhagelt er mir das ganze system. Leider konnte ich beim Altsystem kein Backup mit dem Backit
                                    Hier die Übersicht zum neuen System
                                    Neue System Raspberry 3B
                                    • Plattform: linux
                                    • Betriebssystem: linux
                                    • Architektur: arm64
                                    • CPUs: 4
                                    • Modell: Cortex-A53
                                    • RAM: 909.6 MB
                                    • System-Betriebszeit: 00:23:54
                                    • Node.js: v18.16.0
                                    • time: 1682502790750
                                    • timeOffset: -60
                                    • NPM: v9.5.1
                                    • Datenträgergröße: 14.3 GB
                                    • Freier Festplattenspeicher: 9.5 GB
                                    • Betriebszeit: 00:04:51
                                    • Aktive Instanzen: 3
                                    • Pfad: /opt/iobroker/
                                    • aktiv:
                                    • Der Js-controller hat die Version ist 4.0.24
                                    Betriebsystem bullseye
                                    Leider ließ sich auf dem Altsystem auch der Backitup Adapter nicht installieren.
                                    Somit habe ich über putty manuell über den command das Backup angestoßen.
                                    iobroker Backup erstellt.
                                    Das Backup habe ich dann auf das Neusystem kopiert und nach Stop des iobrokers das System versucht zurückzuspielen
                                    Welche Option habe ich jetzt noch
                                    • M Metzid
                                      • Plattform: linux
                                      • CPUs: 4
                                      • RAM: 923.3 MB
                                      • Node.js: v10.18.0
                                      • NPM: 6.13.4
                                      • Plattform: linux
                                      • CPUs: 4
                                      • RAM: 909.6 MB
                                      • Node.js: v18.16.0
                                      • timeOffset: -60
                                      • NPM: v9.5.1
                                      • aktiv:
                                      @metzid
                                      Jag mal iob diag über das System.
                                      Musst du direkt aufrufen, siehe in meiner Signatur.
                                        crunchipC Abwesend
                                        @metzid ok also immer noch auf deinem alten System der gleiche Stand wie zu Beginn im Thread.
                                        ich würde mal versuchen den controller auf die V3.3(beinhaltet jsonl) zu bringen, den admin entsprechen auf 4.1 oder größer, also bewusst bestimmte versionen installieren, müsste ja mit deiner node10 uns jessi noch funktionieren
                                        somit müsste auch der backitup adapter( auch eventuell in einer älteren version) funktionieren um ein passende backup zu erstellen, was auf einem neuen system dann eingespielt werden kann
                                          Metzid
                                          @crunchip danke für die Info gibt es eine Beschreibung wie man den controller auf die besagte Version bringt.
