  3. Einsteigerfragen
  4. Installation
  5. IOBroker backup auf neue Rasperry übertragen
65 Beiträge 5 Kommentatoren 5.0k Aufrufe 3 Beobachtet
    @metzid
    Nochmal...
    iobroker wird nie mit sudo eingeleitet.
    Fix das!
    Metzid
    pi@piiobroker:/opt/iobroker $ iob fix
    library: loaded
    Library version=2022-12-09
        Welcome to the ioBroker installation fixer!
        Script version: 2023-04-02
        You might need to enter your password a couple of times.
        Installing prerequisites (1/5)
    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Get:3 http://deb.debian.org/debian bullseye-updates InRelease [44.1 kB]
    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:5 https://deb.nodesource.com/node_18.x bullseye InRelease
    Reading package lists... Done
    Installed gcc-c++
        Checking ioBroker user and directory permissions (2/5)
        Check and cleanup npm temporary directories (3/5)
    Done.
        Database maintenance (4/5)
    Checking for uncompressed JSONL databases... This might take a while!
    Compressing /opt/iobroker/iobroker-data/states.jsonl
    Compressing /opt/iobroker/iobroker-data/objects.jsonl
    Compressed 2 JSONL files. Done
        Checking autostart (5/5)
    Enabling autostart...
    Autostart enabled!
        Your installation was fixed successfully
        Run iobroker start to start ioBroker again!
    pi@piiobroker:/opt/iobroker $ iob start
    leider über browser nicht erreichbar
      @metzid
      Nochmal...
      Fix das!
      Metzid
      @thomas-braun aber Fehler hat er beim fix nicht gebracht
      • M Metzid
        @crunchip pi@piiobroker:/opt/iobroker $ sudo iobroker setup custom
        Current configuration:
        • Objects database:
          • Type: jsonl
          • Host/Unix Socket: 127.0.0.1
          • Port: 9001
        • States database:
          • Type: jsonl
          • Port: 9000
        • Data Directory: ../../iobroker-data/
        Type of objects DB [(j)sonl, (f)ile, (r)edis, ...], default [jsonl]: f
        Host / Unix Socket of objects DB(file), default[127.0.0.1]: f
        Port of objects DB(file), default[9001]: f
        Input another, please.
        Das schreibt er gerade was soll ich da einstellen was ist imput another please
        crunchipC Abwesend
        crunchipC Abwesend
        @metzid wie schon geschrieben, ohne sudo
        Du hast da ein f zu viel gedrückt, bei port einfach enter drücken, damit default übernommen wird
        • M Metzid
          library: loaded
          Installed gcc-c++
          Done.
          Autostart enabled!
          crunchipC Abwesend
          crunchipC Abwesend
          @metzid sagte in IOBroker backup auf neue Rasperry übertragen:
          iob list instances
          M 2 Antworten Letzte Antwort
          • M Metzid
            Der Fixer gibt auch keine Fehlerdiagnose aus, der fixt es einfach.
              iob list instances
              Metzid
              @crunchip
              pi@piiobroker:/opt/iobroker $ iobroker setup custom
              - Objects database:
                - Type: jsonl
                - Host/Unix Socket: 127.0.0.1
                - Port: 9001
              - States database:
                - Type: jsonl
                - Port: 9000
              - Data Directory: ../../iobroker-data/
              Type of states DB [(j)sonl, (f)file, (r)edis, ...], default [file]: f
              Host / Unix Socket of states DB (file), default[f]: f
              Port of states DB (file), default[9000]:
              Host name of this machine [piiobroker]: piiobroker
              Please choose if this is a Master/single host (enter "m") or a Slave host (enter "S") you are about to edit. For Slave hosts the data migration will be skipped. [S/m]: m
              Do you want to migrate objects and states from "jsonl/jsonl" to "file/file" [y/N]: y
              Migrating the objects database will overwrite all objects! Are you sure that this is not a slave host and you want to migrate the data? [y/N]: y
              Connecting to previous DB "jsonl"...
              Creating backup ...
              This can take some time ... please be patient!
              host.piiobroker 1626 states saved
              host.piiobroker 2188 objects saved
              Backup created: /opt/iobroker/backups/2023_04_26-22_38_38_backupiobroker-migration.tar.gz
              updating conf/iobroker.json
              Connecting to new DB "file" (can take up to 20s) ...
              Server Cannot load /opt/iobroker/iobroker-data/objects.json: Database file /opt/iobroker/iobroker-data/objects.json does not exists.. We try last Backup!
              Server Cannot load /opt/iobroker/iobroker-data/objects.json.bak: Database file /opt/iobroker/iobroker-data/objects.json.bak does not exists.. Continue with empty dataset!
              Server If this is no Migration or initial start please restore the last backup from /opt/iobroker/iobroker-data/backup-objects
              No connection to databases possible ...
              New Database could not be connected. Please check your settings. No settings have been changed.
              restoring conf/iobroker.json
                iob list instances
                Metzid
                @crunchip
                pi@piiobroker:/opt/iobroker $ iob list instances
                  system.adapter.admin.0                  : admin                 : piiobroker                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                  system.adapter.broadlink2.0             : broadlink2            : piiobroker                               - disabled
                  system.adapter.hm-rega.0                : hm-rega               : piiobroker                               - disabled
                  system.adapter.hm-rpc.0                 : hm-rpc                : piiobroker                               - disabled, port: 0
                  system.adapter.iot.0                    : iot                   : piiobroker                               - disabled
                  system.adapter.javascript.0             : javascript            : piiobroker                               - disabled
                  system.adapter.scenes.0                 : scenes                : piiobroker                               - disabled
                  system.adapter.web.0                    : web                   : piiobroker                               - disabled, port: 8082, bind: 0.0.0.0, run as: admin
                + instance is alive
                • M Metzid
                  @crunchip
                  - Objects database:
                    - Type: jsonl
                    - Port: 9001
                  - States database:
                    - Type: jsonl
                    - Port: 9000
                  Creating backup ...
                  crunchipC Abwesend
                  crunchipC Abwesend
                  Creating backup ...
                  Also müsste ja eigentlich eine jeweilige jsonl vorhanden sein, aber wohl nur als backup
                  • M Metzid
                    @crunchip
                    + instance is alive
                    crunchipC Abwesend
                    crunchipC Abwesend
                    @metzid da läuft kein admin, soweit man hier sehen kann
                      Metzid
                      @crunchip wie kann ich den admin
                      starten
                      • M Metzid
                        starten
                        crunchipC Abwesend
                        crunchipC Abwesend
                        @metzid
                        iob start admin
                          @metzid
                          iob start admin
                          Metzid
                          @crunchip
                          pi@piiobroker:/opt/iobroker $ iob start admin
                          + instance is alive
                          Leider über Browser nicht erreichbar
                            @metzid
                            iob start admin
                            Metzid
                            @crunchip Hallo guten Morgen. Ich habe mir heute Nacht nochmals überlegt ob es Sinn macht das Image des neuen Raspberry mit neiem OS und iobroker nochmals einzuspielen dann die datenbank auf file/file umzustellen und dann ein restore des iobrokers zu fahren. Dann dürfte doch zumindest die datenbbank auf dem Level des restores dein. Oder mache ich da einen Denkfehler.
                            Noch eine kurze Frage wenn so ein Restore gefahren wird werden dann die ganzen Module /Datenbanken auf dem raspberry auf die Versionsnummer des Altgerätes zurückgestellt. Oder gibt es eine versionsabhängigkeit wo dann nur der Inhalt der verschiedenen Datenbank und Module zurückgespielt wird so dass keine Instalation auf die alten Level erfolgt also rein Daten eingespielt werden. Sollte man da schon die ganzen Adapter die auch im alten Backup hinterlegt sind schon in der neuen Version installieren so dass das System nur noch Daten zurück spielt und keine Adapter auf alte Versionen zurücksetzt. Oder gibt es da eine versionsabhängigkeit ab wann das iobroker Backup nur Daten oder auch Versionen zurückspielt.
                            • crunchipC Abwesend
                              crunchipC Abwesend
                              nein, um ein backup zurückzuspielen, müssen keine Adapter im Vorfeld installiert werden, das beinhaltet alles das backup. Einzige Ausnahme aufgrund eines bugs, muss vis (falls genutzt wird) vor dem backup installiert werden.
                              kannst du versuchen
                              M 4 Antworten Letzte Antwort
                                kannst du versuchen
                                Metzid
                                @crunchipnein habe kein vis
                                versuche es jetzt gleich
                                  kannst du versuchen
                                  Metzid
                                  @crunchip @crunchip hier der log iobroker ist dann wieder problemlos gestartet
                                  login as: pi
                                  pi@192.168.178.172's password:
                                  Linux piiobroker 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr  3 17:24:16 BST 2023 aarch64
                                  permitted by applicable law.
                                  Last login: Wed Apr 26 11:31:28 2023
                                  Wi-Fi is currently blocked by rfkill.
                                  Use raspi-config to set the country before use.
                                  pi@piiobroker:~ $ cd /opt/iobroker
                                  pi@piiobroker:/opt/iobroker $ iobroker stop
                                  - Objects database:
                                    - Type: jsonl
                                    - Port: 9001
                                  - States database:
                                    - Type: jsonl
                                    - Port: 9000
                                  Host / Unix Socket of states DB (file), default[127.0.0.1]:
                                  Data directory (file), default[../../iobroker-data/]:
                                  This host appears to be a Master or a Single host system. Is this correct? [Y/n]: y
                                  Creating backup ...
                                  host.piiobroker 102 states saved
                                  host.piiobroker 143 objects saved
                                  Backup created: /opt/iobroker/backups/2023_04_27-09_30_42_backupiobroker-migration.tar.gz
                                  Server Cannot load /opt/iobroker/iobroker-data/states.json: Database file /opt/iobroker/iobroker-data/states.json does not exists.. We try last Backup!
                                  Server Cannot load /opt/iobroker/iobroker-data/states.json.bak: Database file /opt/iobroker/iobroker-data/states.json.bak does not exists.. Continue with empty dataset!
                                   Cannot read system.config: null (OK when migrating or restoring)
                                  Restore backup ...
                                  iobroker controller daemon is not running
                                  host.piiobroker OK.
                                  host.piiobroker Clear all objects and states...
                                  clean 2 objects...
                                  clean 2 states...
                                  host.piiobroker done.
                                  host.piiobroker Processed 0/143 objects
                                  143 objects restored.
                                  host.piiobroker Processed 0/102 states
                                  102 states restored.
                                  upload [52] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
                                  upload [50] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/customComponents.js.map custom/customComponents.js.map application/json
                                  upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/zh-cn.json custom/i18n/zh-cn.json application/json
                                  upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js.map custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js.map application/json
                                  upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map application/json
                                  upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js application/javascript
                                  upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map application/json
                                  upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js application/javascript
                                  upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map application/json
                                  upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js application/javascript
                                  upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map application/json
                                  upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js application/javascript
                                  upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map application/json
                                  upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                  upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                  upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                  upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                  upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                  upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                  upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                  upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                  upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                  upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                                  upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                  upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5 jsonConfig.json5 application/json5
                                  upload [21] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
                                  upload [20] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
                                  upload [19] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
                                  upload [18] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                  upload [17] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                  upload [16] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                  upload [15] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                  upload [14] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                  upload [13] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                  upload [12] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                  upload [11] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                  upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                  upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                                  upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                  upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
                                  upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
                                  upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
                                  upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
                                  upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
                                  upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
                                  upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
                                  upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
                                  upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
                                  upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
                                  upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
                                  upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
                                  upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
                                  upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
                                  upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
                                  Reinstalling adapter "admin" from "iobroker.admin@6.3.5"
                                  removed 1 package, and changed 4 packages in 45s
                                  45 packages are looking for funding
                                    run `npm fund` for details
                                  Reinstalling adapter "backitup" from "iobroker.backitup@2.6.19"
                                  up to date in 6s
                                  Could not migrate objects to corresponding sets: Cannot read properties of undefined (reading 'getObjectList')
                                  Backup restored - Migration successful
                                  Important: If your system consists of multiple hosts please execute
                                  "iobroker upload all" on the master AFTER all other hosts/slaves have
                                  also been updated to this states/objects database configuration AND are
                                  running!
                                  MOD-EDIT: Code in code-tags gesetzt
                                    kannst du versuchen
                                    Metzid
                                    @crunchip nach dem restore startet der iobroker leider nicht mehr. Soll ich iobroker fix ausführen
                                    login as: pi
                                    - Objects database:
                                      - Type: jsonl
                                      - Port: 9001
                                    - States database:
                                      - Type: jsonl
                                      - Port: 9000
                                    Creating backup ...
                                    Restore backup ...
                                    host.piiobroker OK.
                                    clean 2 objects...
                                    clean 2 states...
                                    up to date in 6s
                                    running!
                                      kannst du versuchen
                                      Metzid
                                      @crunchip leider startet der ibroker jetzt nicht mehr soll ich den ibroker fix anstoßen
                                      • M Metzid
                                        login as: pi
                                        - Objects database:
                                          - Type: jsonl
                                          - Port: 9001
                                        - States database:
                                          - Type: jsonl
                                          - Port: 9000
                                        Creating backup ...
                                        Restore backup ...
                                        host.piiobroker OK.
                                        clean 2 objects...
                                        clean 2 states...
                                        up to date in 6s
                                        running!
                                        crunchipC Abwesend
                                        crunchipC Abwesend
                                        ein restore dauert auch eine Weile, wie lange hast du gewartet?
                                        und generell, auf welchem Stand ist deine alte Installation bzw das backup?
                                          Metzid
                                          @crunchip Altsystem Raspberry 3B
                                          • Plattform: linux
                                          • Die Architektur: arm
                                          • CPUs: 4
                                          • Geschwindigkeit: 1200 MHz
                                          • Modell: ARMv7 Processor rev 4 (v7l)
                                          • RAM: 923.3 MB
                                          • System-Betriebszeit: 00:45:28
                                          • Node.js: v10.18.0
                                          • NPM: 6.13.4
                                          • Datenträgergröße: 12.9 GiB
                                          • Datenträger verfügbar: 7.5 GiB
                                          • Adapter-Anzahl: 471
                                          • Betriebszeit: 23:32:45
                                          • Aktive Instanzen: 8
                                          Betriebsystem Jessie
                                          Der Js-controller hat die Version ist 2.1.1 Jetzt wollte ich das System updaten leider scheint die installierte Raspbain GUN linux8 Jessie nicht mehr mit den neuen JS-controllern unterstützt zu werden. Wenn ich da einen update durchführen verhagelt er mir das ganze system. Leider konnte ich beim Altsystem kein Backup mit dem Backit
                                          Hier die Übersicht zum neuen System
                                          Neue System Raspberry 3B
                                          • Plattform: linux
                                          • Betriebssystem: linux
                                          • Architektur: arm64
                                          • CPUs: 4
                                          • Modell: Cortex-A53
                                          • RAM: 909.6 MB
                                          • System-Betriebszeit: 00:23:54
                                          • Node.js: v18.16.0
                                          • time: 1682502790750
                                          • timeOffset: -60
                                          • NPM: v9.5.1
                                          • Datenträgergröße: 14.3 GB
                                          • Freier Festplattenspeicher: 9.5 GB
                                          • Betriebszeit: 00:04:51
                                          • Aktive Instanzen: 3
                                          • Pfad: /opt/iobroker/
                                          • aktiv:
                                          • Der Js-controller hat die Version ist 4.0.24
                                          Betriebsystem bullseye
                                          Leider ließ sich auf dem Altsystem auch der Backitup Adapter nicht installieren.
                                          Somit habe ich über putty manuell über den command das Backup angestoßen.
                                          iobroker Backup erstellt.
                                          Das Backup habe ich dann auf das Neusystem kopiert und nach Stop des iobrokers das System versucht zurückzuspielen
                                          Welche Option habe ich jetzt noch
