  3. Einsteigerfragen
  4. Installation
  5. IOBroker backup auf neue Rasperry übertragen
65 Beiträge 5 Kommentatoren 5.0k Aufrufe 3 Beobachtet
  • M Metzid
    @metzid pi@piiobroker:/opt/iobroker $ sudo iobroker setup custom
    Current configuration:
    • Objects database:
      • Type: jsonl
      • Host/Unix Socket: 127.0.0.1
      • Port: 9001
    • States database:
      • Type: jsonl
      • Port: 9000
    • Data Directory: ../../iobroker-data/
    Type of objects DB [(j)sonl, (f)ile, (r)edis, ...], default [jsonl]: f
    Host / Unix Socket of objects DB(file), default[127.0.0.1]: f
    Port of objects DB(file), default[9001]: f
    Input another, please.
    Port of objects DB(file), default[9001]: 9001
    Type of states DB [(j)sonl, (f)file, (r)edis, ...], default [file]: f
    Host / Unix Socket of states DB (file), default[f]: f
    Port of states DB (file), default[9000]: 9000
    Host name of this machine [piiobroker]: piiobroker
    Please choose if this is a Master/single host (enter "m") or a Slave host (enter "S") you are about to edit. For Slave hosts the data migration will be skipped. [S/m]: m
    Do you want to migrate objects and states from "jsonl/jsonl" to "file/file" [y/N]: y
    Migrating the objects database will overwrite all objects! Are you sure that this is not a slave host and you want to migrate the data? [y/N]: y
    Connecting to previous DB "jsonl"...
    Creating backup ...
    This can take some time ... please be patient!
    host.piiobroker 1626 states saved
    host.piiobroker 2188 objects saved
    Backup created: /opt/iobroker/backups/2023_04_26-22_20_28_backupiobroker-migration.tar.gz
    updating conf/iobroker.json
    Connecting to new DB "file" (can take up to 20s) ...
    Server Cannot load /opt/iobroker/iobroker-data/objects.json: Database file /opt/iobroker/iobroker-data/objects.json does not exists.. We try last Backup!
    Server Cannot load /opt/iobroker/iobroker-data/states.json: Database file /opt/iobroker/iobroker-data/states.json does not exists.. We try last Backup!
    Server Cannot load /opt/iobroker/iobroker-data/objects.json.bak: Database file /opt/iobroker/iobroker-data/objects.json.bak does not exists.. Continue with empty dataset!
    Server If this is no Migration or initial start please restore the last backup from /opt/iobroker/iobroker-data/backup-objects
    Server Cannot load /opt/iobroker/iobroker-data/states.json.bak: Database file /opt/iobroker/iobroker-data/states.json.bak does not exists.. Continue with empty dataset!
    No connection to databases possible ...
    New Database could not be connected. Please check your settings. No settings have been changed.
    restoring conf/iobroker.json
    @metzid
    Nochmal...
    iobroker wird nie mit sudo eingeleitet.
    Fix das!
    M 2 Antworten Letzte Antwort
      @metzid
      Nochmal...
      Fix das!
      Metzid
      pi@piiobroker:/opt/iobroker $ iob fix
      library: loaded
      Library version=2022-12-09
          Welcome to the ioBroker installation fixer!
          Script version: 2023-04-02
          You might need to enter your password a couple of times.
          Installing prerequisites (1/5)
      Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:2 http://deb.debian.org/debian bullseye InRelease
      Get:3 http://deb.debian.org/debian bullseye-updates InRelease [44.1 kB]
      Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:5 https://deb.nodesource.com/node_18.x bullseye InRelease
      Reading package lists... Done
      Installed gcc-c++
          Checking ioBroker user and directory permissions (2/5)
          Check and cleanup npm temporary directories (3/5)
      Done.
          Database maintenance (4/5)
      Checking for uncompressed JSONL databases... This might take a while!
      Compressing /opt/iobroker/iobroker-data/states.jsonl
      Compressing /opt/iobroker/iobroker-data/objects.jsonl
      Compressed 2 JSONL files. Done
          Checking autostart (5/5)
      Enabling autostart...
      Autostart enabled!
          Your installation was fixed successfully
          Run iobroker start to start ioBroker again!
      pi@piiobroker:/opt/iobroker $ iob start
      leider über browser nicht erreichbar
        @metzid
        Nochmal...
        Fix das!
        Metzid
        @thomas-braun aber Fehler hat er beim fix nicht gebracht
        • M Metzid
          @crunchip pi@piiobroker:/opt/iobroker $ sudo iobroker setup custom
          • Objects database:
            • Type: jsonl
            • Port: 9001
          • States database:
            • Type: jsonl
            • Port: 9000
          Das schreibt er gerade was soll ich da einstellen was ist imput another please
          crunchipC Abwesend
          crunchipC Abwesend
          @metzid wie schon geschrieben, ohne sudo
          Du hast da ein f zu viel gedrückt, bei port einfach enter drücken, damit default übernommen wird
          • M Metzid
            library: loaded
            Installed gcc-c++
            Done.
            Autostart enabled!
            crunchipC Abwesend
            crunchipC Abwesend
            @metzid sagte in IOBroker backup auf neue Rasperry übertragen:
            iob list instances
            • M Metzid
              Der Fixer gibt auch keine Fehlerdiagnose aus, der fixt es einfach.
                iob list instances
                Metzid
                @crunchip
                pi@piiobroker:/opt/iobroker $ iobroker setup custom
                - Objects database:
                  - Type: jsonl
                  - Host/Unix Socket: 127.0.0.1
                  - Port: 9001
                - States database:
                  - Type: jsonl
                  - Port: 9000
                - Data Directory: ../../iobroker-data/
                Creating backup ...
                Backup created: /opt/iobroker/backups/2023_04_26-22_38_38_backupiobroker-migration.tar.gz
                  iob list instances
                  Metzid
                  @crunchip
                  pi@piiobroker:/opt/iobroker $ iob list instances
                    system.adapter.admin.0                  : admin                 : piiobroker                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                    system.adapter.broadlink2.0             : broadlink2            : piiobroker                               - disabled
                    system.adapter.hm-rega.0                : hm-rega               : piiobroker                               - disabled
                    system.adapter.hm-rpc.0                 : hm-rpc                : piiobroker                               - disabled, port: 0
                    system.adapter.iot.0                    : iot                   : piiobroker                               - disabled
                    system.adapter.javascript.0             : javascript            : piiobroker                               - disabled
                    system.adapter.scenes.0                 : scenes                : piiobroker                               - disabled
                    system.adapter.web.0                    : web                   : piiobroker                               - disabled, port: 8082, bind: 0.0.0.0, run as: admin
                  + instance is alive
                  • M Metzid
                    @crunchip
                    - Objects database:
                      - Type: jsonl
                      - Port: 9001
                    - States database:
                      - Type: jsonl
                      - Port: 9000
                    Creating backup ...
                    crunchipC Abwesend
                    crunchipC Abwesend
                    Creating backup ...
                    Also müsste ja eigentlich eine jeweilige jsonl vorhanden sein, aber wohl nur als backup
                    • M Metzid
                      @crunchip
                      + instance is alive
                      crunchipC Abwesend
                      crunchipC Abwesend
                      @metzid da läuft kein admin, soweit man hier sehen kann
                        Metzid
                        @crunchip wie kann ich den admin
                        starten
                        • M Metzid
                          starten
                          crunchipC Abwesend
                          crunchipC Abwesend
                          @metzid
                          iob start admin
                            @metzid
                            iob start admin
                            Metzid
                            @crunchip
                            pi@piiobroker:/opt/iobroker $ iob start admin
                            + instance is alive
                            Leider über Browser nicht erreichbar
                              @metzid
                              iob start admin
                              Metzid
                              @crunchip Hallo guten Morgen. Ich habe mir heute Nacht nochmals überlegt ob es Sinn macht das Image des neuen Raspberry mit neiem OS und iobroker nochmals einzuspielen dann die datenbank auf file/file umzustellen und dann ein restore des iobrokers zu fahren. Dann dürfte doch zumindest die datenbbank auf dem Level des restores dein. Oder mache ich da einen Denkfehler.
                              Noch eine kurze Frage wenn so ein Restore gefahren wird werden dann die ganzen Module /Datenbanken auf dem raspberry auf die Versionsnummer des Altgerätes zurückgestellt. Oder gibt es eine versionsabhängigkeit wo dann nur der Inhalt der verschiedenen Datenbank und Module zurückgespielt wird so dass keine Instalation auf die alten Level erfolgt also rein Daten eingespielt werden. Sollte man da schon die ganzen Adapter die auch im alten Backup hinterlegt sind schon in der neuen Version installieren so dass das System nur noch Daten zurück spielt und keine Adapter auf alte Versionen zurücksetzt. Oder gibt es da eine versionsabhängigkeit ab wann das iobroker Backup nur Daten oder auch Versionen zurückspielt.
                              • crunchipC Abwesend
                                crunchipC Abwesend
                                nein, um ein backup zurückzuspielen, müssen keine Adapter im Vorfeld installiert werden, das beinhaltet alles das backup. Einzige Ausnahme aufgrund eines bugs, muss vis (falls genutzt wird) vor dem backup installiert werden.
                                kannst du versuchen
                                M 4 Antworten Letzte Antwort
                                  kannst du versuchen
                                  Metzid
                                  @crunchipnein habe kein vis
                                  versuche es jetzt gleich
                                    kannst du versuchen
                                    Metzid
                                    @crunchip @crunchip hier der log iobroker ist dann wieder problemlos gestartet
                                    login as: pi
                                    pi@192.168.178.172's password:
                                    Linux piiobroker 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr  3 17:24:16 BST 2023 aarch64
                                    permitted by applicable law.
                                    Last login: Wed Apr 26 11:31:28 2023
                                    Wi-Fi is currently blocked by rfkill.
                                    Use raspi-config to set the country before use.
                                    pi@piiobroker:~ $ cd /opt/iobroker
                                    pi@piiobroker:/opt/iobroker $ iobroker stop
                                    - Objects database:
                                      - Type: jsonl
                                      - Port: 9001
                                    - States database:
                                      - Type: jsonl
                                      - Port: 9000
                                    Host / Unix Socket of states DB (file), default[127.0.0.1]:
                                    Data directory (file), default[../../iobroker-data/]:
                                    This host appears to be a Master or a Single host system. Is this correct? [Y/n]: y
                                    Creating backup ...
                                    host.piiobroker 102 states saved
                                    host.piiobroker 143 objects saved
                                    Backup created: /opt/iobroker/backups/2023_04_27-09_30_42_backupiobroker-migration.tar.gz
                                     Cannot read system.config: null (OK when migrating or restoring)
                                    Restore backup ...
                                    iobroker controller daemon is not running
                                    host.piiobroker OK.
                                    host.piiobroker Clear all objects and states...
                                    clean 2 objects...
                                    clean 2 states...
                                    host.piiobroker done.
                                    host.piiobroker Processed 0/143 objects
                                    143 objects restored.
                                    host.piiobroker Processed 0/102 states
                                    102 states restored.
                                    upload [52] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
                                    upload [50] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/customComponents.js.map custom/customComponents.js.map application/json
                                    upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/zh-cn.json custom/i18n/zh-cn.json application/json
                                    upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js.map custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js.map application/json
                                    upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map application/json
                                    upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js application/javascript
                                    upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map application/json
                                    upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js application/javascript
                                    upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map application/json
                                    upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js application/javascript
                                    upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map application/json
                                    upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js application/javascript
                                    upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map application/json
                                    upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                    upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                    upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                    upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                    upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                    upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                    upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                    upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                    upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                    upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                                    upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                    upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5 jsonConfig.json5 application/json5
                                    upload [21] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
                                    upload [20] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
                                    upload [19] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
                                    upload [18] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                    upload [17] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                    upload [16] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                    upload [15] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                    upload [14] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                    upload [13] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                    upload [12] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                    upload [11] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                    upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                    upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                                    upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                    upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
                                    upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
                                    upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
                                    upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
                                    upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
                                    upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
                                    upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
                                    upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
                                    upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
                                    upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
                                    upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
                                    upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
                                    upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
                                    upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
                                    upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
                                    Reinstalling adapter "admin" from "iobroker.admin@6.3.5"
                                    removed 1 package, and changed 4 packages in 45s
                                    45 packages are looking for funding
                                      run `npm fund` for details
                                    Reinstalling adapter "backitup" from "iobroker.backitup@2.6.19"
                                    up to date in 6s
                                    Could not migrate objects to corresponding sets: Cannot read properties of undefined (reading 'getObjectList')
                                    Backup restored - Migration successful
                                    Important: If your system consists of multiple hosts please execute
                                    "iobroker upload all" on the master AFTER all other hosts/slaves have
                                    also been updated to this states/objects database configuration AND are
                                    running!
                                    MOD-EDIT: Code in code-tags gesetzt
                                      kannst du versuchen
                                      Metzid
                                      @crunchip nach dem restore startet der iobroker leider nicht mehr. Soll ich iobroker fix ausführen
                                      login as: pi
                                      - Objects database:
                                        - Type: jsonl
                                        - Port: 9001
                                      - States database:
                                        - Type: jsonl
                                        - Port: 9000
                                      Creating backup ...
                                      Restore backup ...
                                      host.piiobroker OK.
                                      clean 2 objects...
                                      clean 2 states...
                                      up to date in 6s
                                      running!
                                        kannst du versuchen
                                        Metzid
                                        @crunchip leider startet der ibroker jetzt nicht mehr soll ich den ibroker fix anstoßen
                                        • M Metzid
                                          login as: pi
                                          - Objects database:
                                            - Type: jsonl
                                            - Port: 9001
                                          - States database:
                                            - Type: jsonl
                                            - Port: 9000
                                          Creating backup ...
                                          Restore backup ...
                                          host.piiobroker OK.
                                          clean 2 objects...
                                          clean 2 states...
                                          up to date in 6s
                                          running!
                                          crunchipC Abwesend
                                          crunchipC Abwesend
                                          ein restore dauert auch eine Weile, wie lange hast du gewartet?
                                          und generell, auf welchem Stand ist deine alte Installation bzw das backup?
