  3. Einsteigerfragen
  4. Installation
  5. IOBroker backup auf neue Rasperry übertragen
65 Beiträge 5 Kommentatoren 5.0k Aufrufe 3 Beobachtet
  • M Metzid
    @crunchip pi@piiobroker:/opt/iobroker $ sudo iobroker setup custom
    Current configuration:
    • Objects database:
      • Type: jsonl
      • Host/Unix Socket: 127.0.0.1
      • Port: 9001
    • States database:
      • Type: jsonl
      • Port: 9000
    • Data Directory: ../../iobroker-data/
    Type of objects DB [(j)sonl, (f)ile, (r)edis, ...], default [jsonl]: f
    Host / Unix Socket of objects DB(file), default[127.0.0.1]: f
    Port of objects DB(file), default[9001]: f
    Input another, please.
    Das schreibt er gerade was soll ich da einstellen was ist imput another please
    Metzid
    @metzid pi@piiobroker:/opt/iobroker $ sudo iobroker setup custom
    • Objects database:
      • Type: jsonl
      • Port: 9001
    • States database:
      • Type: jsonl
      • Port: 9000
    Port of objects DB(file), default[9001]: 9001
    Type of states DB [(j)sonl, (f)file, (r)edis, ...], default [file]: f
    Host / Unix Socket of states DB (file), default[f]: f
    Port of states DB (file), default[9000]: 9000
    Host name of this machine [piiobroker]: piiobroker
    Please choose if this is a Master/single host (enter "m") or a Slave host (enter "S") you are about to edit. For Slave hosts the data migration will be skipped. [S/m]: m
    Do you want to migrate objects and states from "jsonl/jsonl" to "file/file" [y/N]: y
    Migrating the objects database will overwrite all objects! Are you sure that this is not a slave host and you want to migrate the data? [y/N]: y
    Connecting to previous DB "jsonl"...
    Creating backup ...
    This can take some time ... please be patient!
    host.piiobroker 1626 states saved
    host.piiobroker 2188 objects saved
    Backup created: /opt/iobroker/backups/2023_04_26-22_20_28_backupiobroker-migration.tar.gz
    updating conf/iobroker.json
    Connecting to new DB "file" (can take up to 20s) ...
    Server Cannot load /opt/iobroker/iobroker-data/objects.json: Database file /opt/iobroker/iobroker-data/objects.json does not exists.. We try last Backup!
    Server Cannot load /opt/iobroker/iobroker-data/states.json: Database file /opt/iobroker/iobroker-data/states.json does not exists.. We try last Backup!
    Server Cannot load /opt/iobroker/iobroker-data/objects.json.bak: Database file /opt/iobroker/iobroker-data/objects.json.bak does not exists.. Continue with empty dataset!
    Server If this is no Migration or initial start please restore the last backup from /opt/iobroker/iobroker-data/backup-objects
    Server Cannot load /opt/iobroker/iobroker-data/states.json.bak: Database file /opt/iobroker/iobroker-data/states.json.bak does not exists.. Continue with empty dataset!
    No connection to databases possible ...
    New Database could not be connected. Please check your settings. No settings have been changed.
    restoring conf/iobroker.json
    • M Metzid
      • Objects database:
        • Type: jsonl
        • Port: 9001
      • States database:
        • Type: jsonl
        • Port: 9000
      Creating backup ...
      @metzid
      Nochmal...
      iobroker wird nie mit sudo eingeleitet.
      Fix das!
      M 2 Antworten Letzte Antwort
        @metzid
        Nochmal...
        Fix das!
        Metzid
        pi@piiobroker:/opt/iobroker $ iob fix
        library: loaded
        Library version=2022-12-09
            Welcome to the ioBroker installation fixer!
            Script version: 2023-04-02
            You might need to enter your password a couple of times.
            Installing prerequisites (1/5)
        Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
        Hit:2 http://deb.debian.org/debian bullseye InRelease
        Get:3 http://deb.debian.org/debian bullseye-updates InRelease [44.1 kB]
        Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:5 https://deb.nodesource.com/node_18.x bullseye InRelease
        Reading package lists... Done
        Installed gcc-c++
            Checking ioBroker user and directory permissions (2/5)
            Check and cleanup npm temporary directories (3/5)
        Done.
            Database maintenance (4/5)
        Checking for uncompressed JSONL databases... This might take a while!
        Compressing /opt/iobroker/iobroker-data/states.jsonl
        Compressing /opt/iobroker/iobroker-data/objects.jsonl
        Compressed 2 JSONL files. Done
            Checking autostart (5/5)
        Enabling autostart...
        Autostart enabled!
            Your installation was fixed successfully
            Run iobroker start to start ioBroker again!
        pi@piiobroker:/opt/iobroker $ iob start
        leider über browser nicht erreichbar
          @metzid
          Nochmal...
          Fix das!
          Metzid
          @thomas-braun aber Fehler hat er beim fix nicht gebracht
          • M Metzid
            • Objects database:
              • Type: jsonl
              • Port: 9001
            • States database:
              • Type: jsonl
              • Port: 9000
            crunchipC Offline
            crunchipC Offline
            @metzid wie schon geschrieben, ohne sudo
            Du hast da ein f zu viel gedrückt, bei port einfach enter drücken, damit default übernommen wird
            • M Metzid
              library: loaded
              Installed gcc-c++
              Done.
              Autostart enabled!
              crunchipC Offline
              crunchipC Offline
              @metzid sagte in IOBroker backup auf neue Rasperry übertragen:
              iob list instances
              • M Metzid
                Der Fixer gibt auch keine Fehlerdiagnose aus, der fixt es einfach.
                  iob list instances
                  Metzid
                  @crunchip
                  pi@piiobroker:/opt/iobroker $ iobroker setup custom
                  - Objects database:
                    - Type: jsonl
                    - Host/Unix Socket: 127.0.0.1
                    - Port: 9001
                  - States database:
                    - Type: jsonl
                    - Port: 9000
                  - Data Directory: ../../iobroker-data/
                  Creating backup ...
                  Backup created: /opt/iobroker/backups/2023_04_26-22_38_38_backupiobroker-migration.tar.gz
                    iob list instances
                    Metzid
                    @crunchip
                    pi@piiobroker:/opt/iobroker $ iob list instances
                      system.adapter.admin.0                  : admin                 : piiobroker                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                      system.adapter.broadlink2.0             : broadlink2            : piiobroker                               - disabled
                      system.adapter.hm-rega.0                : hm-rega               : piiobroker                               - disabled
                      system.adapter.hm-rpc.0                 : hm-rpc                : piiobroker                               - disabled, port: 0
                      system.adapter.iot.0                    : iot                   : piiobroker                               - disabled
                      system.adapter.javascript.0             : javascript            : piiobroker                               - disabled
                      system.adapter.scenes.0                 : scenes                : piiobroker                               - disabled
                      system.adapter.web.0                    : web                   : piiobroker                               - disabled, port: 8082, bind: 0.0.0.0, run as: admin
                    + instance is alive
                    • M Metzid
                      @crunchip
                      - Objects database:
                        - Type: jsonl
                        - Port: 9001
                      - States database:
                        - Type: jsonl
                        - Port: 9000
                      Creating backup ...
                      crunchipC Offline
                      crunchipC Offline
                      Creating backup ...
                      Also müsste ja eigentlich eine jeweilige jsonl vorhanden sein, aber wohl nur als backup
                      • M Metzid
                        @crunchip
                        + instance is alive
                        crunchipC Offline
                        crunchipC Offline
                        @metzid da läuft kein admin, soweit man hier sehen kann
                          Metzid
                          @crunchip wie kann ich den admin
                          starten
                          • M Metzid
                            starten
                            crunchipC Offline
                            crunchipC Offline
                            @metzid
                            iob start admin
                              @metzid
                              iob start admin
                              Metzid
                              @crunchip
                              pi@piiobroker:/opt/iobroker $ iob start admin
                              + instance is alive
                              Leider über Browser nicht erreichbar
                                @metzid
                                iob start admin
                                Metzid
                                @crunchip Hallo guten Morgen. Ich habe mir heute Nacht nochmals überlegt ob es Sinn macht das Image des neuen Raspberry mit neiem OS und iobroker nochmals einzuspielen dann die datenbank auf file/file umzustellen und dann ein restore des iobrokers zu fahren. Dann dürfte doch zumindest die datenbbank auf dem Level des restores dein. Oder mache ich da einen Denkfehler.
                                Noch eine kurze Frage wenn so ein Restore gefahren wird werden dann die ganzen Module /Datenbanken auf dem raspberry auf die Versionsnummer des Altgerätes zurückgestellt. Oder gibt es eine versionsabhängigkeit wo dann nur der Inhalt der verschiedenen Datenbank und Module zurückgespielt wird so dass keine Instalation auf die alten Level erfolgt also rein Daten eingespielt werden. Sollte man da schon die ganzen Adapter die auch im alten Backup hinterlegt sind schon in der neuen Version installieren so dass das System nur noch Daten zurück spielt und keine Adapter auf alte Versionen zurücksetzt. Oder gibt es da eine versionsabhängigkeit ab wann das iobroker Backup nur Daten oder auch Versionen zurückspielt.
                                • crunchipC Offline
                                  crunchipC Offline
                                  nein, um ein backup zurückzuspielen, müssen keine Adapter im Vorfeld installiert werden, das beinhaltet alles das backup. Einzige Ausnahme aufgrund eines bugs, muss vis (falls genutzt wird) vor dem backup installiert werden.
                                  kannst du versuchen
                                  M 4 Antworten Letzte Antwort
                                    kannst du versuchen
                                    Metzid
                                    @crunchipnein habe kein vis
                                    versuche es jetzt gleich
                                      kannst du versuchen
                                      Metzid
                                      @crunchip @crunchip hier der log iobroker ist dann wieder problemlos gestartet
                                      login as: pi
                                      pi@192.168.178.172's password:
                                      Linux piiobroker 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr  3 17:24:16 BST 2023 aarch64
                                      permitted by applicable law.
                                      Last login: Wed Apr 26 11:31:28 2023
                                      Wi-Fi is currently blocked by rfkill.
                                      Use raspi-config to set the country before use.
                                      pi@piiobroker:~ $ cd /opt/iobroker
                                      pi@piiobroker:/opt/iobroker $ iobroker stop
                                      - Objects database:
                                        - Type: jsonl
                                        - Port: 9001
                                      - States database:
                                        - Type: jsonl
                                        - Port: 9000
                                      Host / Unix Socket of states DB (file), default[127.0.0.1]:
                                      Data directory (file), default[../../iobroker-data/]:
                                      This host appears to be a Master or a Single host system. Is this correct? [Y/n]: y
                                      Creating backup ...
                                      host.piiobroker 102 states saved
                                      host.piiobroker 143 objects saved
                                      Backup created: /opt/iobroker/backups/2023_04_27-09_30_42_backupiobroker-migration.tar.gz
                                       Cannot read system.config: null (OK when migrating or restoring)
                                      Restore backup ...
                                      iobroker controller daemon is not running
                                      host.piiobroker OK.
                                      host.piiobroker Clear all objects and states...
                                      clean 2 objects...
                                      clean 2 states...
                                      host.piiobroker done.
                                      host.piiobroker Processed 0/143 objects
                                      143 objects restored.
                                      host.piiobroker Processed 0/102 states
                                      102 states restored.
                                      upload [52] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
                                      upload [50] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/customComponents.js.map custom/customComponents.js.map application/json
                                      upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/zh-cn.json custom/i18n/zh-cn.json application/json
                                      upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js.map custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js.map application/json
                                      upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map application/json
                                      upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js application/javascript
                                      upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map application/json
                                      upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js application/javascript
                                      upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map application/json
                                      upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js application/javascript
                                      upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map application/json
                                      upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js application/javascript
                                      upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map application/json
                                      upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                      upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                      upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                      upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                      upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                      upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                      upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                      upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                      upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                      upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                                      upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                      upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5 jsonConfig.json5 application/json5
                                      upload [21] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
                                      upload [20] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
                                      upload [19] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
                                      upload [18] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                      upload [17] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                      upload [16] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                      upload [15] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                      upload [14] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                      upload [13] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                      upload [12] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                      upload [11] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                      upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                      upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                                      upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                      upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
                                      upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
                                      upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
                                      upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
                                      upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
                                      upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
                                      upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
                                      upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
                                      upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
                                      upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
                                      upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
                                      upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
                                      upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
                                      upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
                                      upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
                                      Reinstalling adapter "admin" from "iobroker.admin@6.3.5"
                                      removed 1 package, and changed 4 packages in 45s
                                      45 packages are looking for funding
                                        run `npm fund` for details
                                      Reinstalling adapter "backitup" from "iobroker.backitup@2.6.19"
                                      up to date in 6s
                                      Could not migrate objects to corresponding sets: Cannot read properties of undefined (reading 'getObjectList')
                                      Backup restored - Migration successful
                                      Important: If your system consists of multiple hosts please execute
                                      "iobroker upload all" on the master AFTER all other hosts/slaves have
                                      also been updated to this states/objects database configuration AND are
                                      running!
                                      MOD-EDIT: Code in code-tags gesetzt
                                        kannst du versuchen
                                        Metzid
                                        @crunchip nach dem restore startet der iobroker leider nicht mehr. Soll ich iobroker fix ausführen
                                        login as: pi
                                        - Objects database:
                                          - Type: jsonl
                                          - Port: 9001
                                        - States database:
                                          - Type: jsonl
                                          - Port: 9000
                                        Creating backup ...
                                        Restore backup ...
                                        host.piiobroker OK.
                                        clean 2 objects...
                                        clean 2 states...
                                        up to date in 6s
                                        running!
                                          kannst du versuchen
                                          Metzid
                                          @crunchip leider startet der ibroker jetzt nicht mehr soll ich den ibroker fix anstoßen
