  4. [Adapter] cloudfreie Auslesung von Deye-Invertern
1.2k Beiträge 114 Kommentatoren 514.7k Aufrufe 93 Beobachtet
  • JB_SullivanJ JB_Sullivan
    @w00dst0ck @Rene55
    Ich habe jetzt mal die ganzen Register aus deinem Link eingetragen. Die Objektdaten füllen sich auch mit Werten. Allerdings bekomme ich aber auch den folgenden Fehler:
    deyeidc.0
    2023-04-04 13:39:19.471	error	DB closed
    deyeidc.0
    2023-04-04 13:39:19.471	error	Error: DB closed at close (C:\ioBroker\GLT\node_modules\ioredis\built\redis\event_handler.js:184:25) at Socket.<anonymous> (C:\ioBroker\GLT\node_modules\ioredis\built\redis\event_handler.js:151:20) at Object.onceWrapper (node:events:628:26) at Socket.emit (node:events:513:28) at TCP.<anonymous> (node:net:322:12)
    deyeidc.0
    2023-04-04 13:39:19.469	error	unhandled promise rejection: DB closed
    deyeidc.0
    2023-04-04 13:39:19.469	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    deyeidc.0
    2023-04-04 13:34:25.224	error	DB closed
    deyeidc.0
    2023-04-04 13:34:25.223	error	Error: DB closed at close (C:\ioBroker\GLT\node_modules\ioredis\built\redis\event_handler.js:184:25) at Socket.<anonymous> (C:\ioBroker\GLT\node_modules\ioredis\built\redis\event_handler.js:151:20) at Object.onceWrapper (node:events:628:26) at Socket.emit (node:events:513:28) at TCP.<anonymous> (node:net:322:12)
    deyeidc.0
    2023-04-04 13:34:25.222	error	unhandled promise rejection: DB closed
    deyeidc.0
    2023-04-04 13:34:25.222	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    deyeidc.0
    2023-04-04 13:05:18.575	error	DB closed
    deyeidc.0
    2023-04-04 13:05:18.574	error	Error: DB closed at close (C:\ioBroker\GLT\node_modules\ioredis\built\redis\event_handler.js:184:25) at Socket.<anonymous> (C:\ioBroker\GLT\node_modules\ioredis\built\redis\event_handler.js:151:20) at Object.onceWrapper (node:events:628:26) at Socket.emit (node:events:513:28) at TCP.<anonymous> (node:net:322:12)
    deyeidc.0
    2023-04-04 13:05:18.573	error	unhandled promise rejection: DB closed
    deyeidc.0
    2023-04-04 13:05:18.572	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    deyeidc.0
    2023-04-04 13:02:55.677	error	DB closed
    deyeidc.0
    2023-04-04 13:02:55.676	error	Error: DB closed at close (C:\ioBroker\GLT\node_modules\ioredis\built\redis\event_handler.js:184:25) at Socket.<anonymous> (C:\ioBroker\GLT\node_modules\ioredis\built\redis\event_handler.js:151:20) at Object.onceWrapper (node:events:628:26) at Socket.emit (node:events:513:28) at TCP.<anonymous> (node:net:322:12)
    deyeidc.0
    2023-04-04 13:02:55.675	error	unhandled promise rejection: DB closed
    deyeidc.0
    2023-04-04 13:02:55.674	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    Rene55R Online
    Rene55R Online
    Rene55
    #91
    @jb_sullivan Kommen diese Meldungen häufig oder eher selten? Wann hast du den Adpater installiert?
    Sollte das länger als eine Woche her sein, dann versuch doch mal bitte, den Adapter komplett zu entfernen und wieder neu zu installieren.
      @w00dst0ck @Rene55
      deyeidc.0
      deyeidc.0
      deyeidc.0
      deyeidc.0
      deyeidc.0
      deyeidc.0
      deyeidc.0
      deyeidc.0
      deyeidc.0
      deyeidc.0
      deyeidc.0
      deyeidc.0
      deyeidc.0
      deyeidc.0
      deyeidc.0
      deyeidc.0
      JB_SullivanJ Offline
      JB_Sullivan
      #92
      @jb_sullivan sagte in [neuer Adapter] cloudfreie Auslesung von Deye-Invertern:
      https://github.com/raschy/ioBroker.deyeidc/blob/main/deyeidc.MI600.json
      Also ALLE die in dem GIT Link drin sind. Meldung kam bislang nur 1x. Vielleicht nur weil er die Erstanlage der DP`s gemacht hat?
        Rene55R Online
        Rene55R Online
        Rene55
        #93
        @jb_sullivan Naja, nicht unbedingt. Mein anderer Adapter hatte wegen einem Designfehler diese Meldung auch, vor allem auf schwächeren Maschinen und dann noch viele Datenpunkte. Der Fehler sollte nach dem 29. März gefixt sein.
        • Rene55R Rene55
          JB_Sullivan
          #94
          @rene55 Ich habe den Adapter erst am 01.04. (kein Scherz ;) ) installiert. Bis jetzt ist auch keine Fehlermeldung mehr aufgepoppt und die Liste an Werten wird schön brav abgeholt.
          BtW: Ich glaube aber du kannst in den Instanz Einstellungen Standard mäßig 5 Minuten voreinstellen. Ich hatte eine Minute drin stehen, aber die Aktualisierung ist erst alle 5 Minuten, wie ab Werk vorgegeben, wirksam wie man am Diagramm sehen kann.
            Rene55R Online
            Rene55R Online
            Rene55
            schrieb am zuletzt editiert von Rene55
            #95
            @jb_sullivan Das höre ich doch gern. Die Minute ist noch von meinen Tests drin (hab es direkt geändert 😊 ) - hier sind auch 6 Minuten ausreichend. Es sei denn, es findet jemand die Stellschraube, wo die Daten dann minütlich rauspurzeln.
            • Rene55R Rene55
              JB_Sullivan
              schrieb am zuletzt editiert von JB_Sullivan
              #96
              @rene55 sagte in [neuer Adapter] cloudfreie Auslesung von Deye-Invertern:
              Ja, eigentlich ist dieser 5 Minuten Rhytmus vom DEYE nicht wirklich zu gebrauchen :(
              Ich habe jetzt noch einen Shelly in die Einspeise Phase gehängt und da sieht man, wenn lt. Deye (dunkel Orange) nur ~ 100 Watt produziert werden, das der Shelly (hell Orange) zum gleichen Zeitpunkt über 500 Watt registriert und weiter vorne genauso auch umgekehrt.
              Im Grunde ist es egal, weil ja auf Fall eingespeist wird. Bei Wolkendurchzug ist das nicht zu gebrauchen und es ist auch nicht besonders Vertrauensföhrdernd im Bezug auf die getätigte Anschaffung.
              cashC 1 Antwort Letzte Antwort
              • JB_SullivanJ Offline
                JB_Sullivan
                #97
                Als der WR sich schlafen gelegt hat, hat er in ioB diese Fehlermeldung geworfen
                deyeidc.0
                2288	2023-04-05 19:05:41.725	error	Error: ControlCode faulty!
                Kann man im Adapter ggf. die Zeit wo der WR schläft noch in irgend einer Form Error Free gestalten / abfangen?
                  cashC Offline
                  cashC Offline
                  cash
                  #98
                  @jb_sullivan Bei Deinem Diagramm passt das Verhätlnis aber nicht, da die beiden Linien unterschiedlich hoch sind. Siehe linke und rechte Watt Anzeige. Du solltes es so einstellen das beide die gleiche Beschriftung nutzen dann ist es nicht mehr ganz so schlimm aber natürlich immer noch da… Die Daten vom Wechselrichter kann man natürlich trotzdem verwenden z. B. für Vergleiche zwischen den beiden Modulen. Da meine unterschiedlich aufgestellt sind kann ich gut sehen das das erste Modul die volle Leistung morgens bringt und das andere erst 2 Stunden später dafür eben nachmittags länger…
                    JB_Sullivan
                    #99
                    @cash sagte in [neuer Adapter] cloudfreie Auslesung von Deye-Invertern:
                    Ich weiß, das war Absicht damit sich die Linien nicht so überlagern und man das besser erkennen kann. Natürlich sind im normal Betrieb die beiden Erzeugungslinien auf die gleichen Min/Max Achsendaten gelegt. ;)
                    • Rene55R Rene55
                      @fichte Ja super. Dass heißt, auch Logger mit Seriennummer < 400xxx können hiermit arbeiten .?!
                      ___manalishi_ Offline
                      ___manalishi
                      schrieb am zuletzt editiert von ___manalishi
                      #100
                      @rene55 Ich habe einen DEYE SUN-12K-SG01LP3 und eine 2er SN des Datenloggers. Bei mir geht der Adapter leider nicht. Wie kann ich das am besten debuggen?
                      Log:
                      deyeidc.0
                      2023-04-08 10:44:11.192 error IP address [http://192.168.90.56/] is not valid !
                      /ioBoker auf PVE LXC
                      • ___manalishi_ ___manalishi
                        Log:
                        deyeidc.0
                        Rene55R Online
                        Rene55R Online
                        Rene55
                        #101
                        @frank70 Gib bitte mal die IP ohne "http://" ein. Dann sehen wir weiter.
                        L ___manalishi_ 2 Antworten Letzte Antwort
                        • Rene55R Rene55
                          LinusPV
                          schrieb am zuletzt editiert von LinusPV
                          #102
                          Ich habe auch den 12kw Hybrid WR.
                          Funktioniert auch nicht, bekomme folgende Fehlermeldung:
                          error Logger number seems to be wrong [22xxxxxxx]
                          Ich denke das Passwort muß noch eingegeben werden, da es bei den MicroWR ja immer 12345678 ist und bei den grossen ein individuelles ist. Kann das es sein?
                          • L LinusPV
                            Rene55R Online
                            Rene55R Online
                            Rene55
                            #103
                            @linuspv Tja, eigentlich ist der Adapter für Mikrowechselrichter entworfen worden. Bei den großen habe ich keine Ahnung, was die so anders können könnten. Statt dessen gibt es ja anscheinend hierfür die Möglichkeit, die Register direkt über einen rs232/rs485 Adapter auszulesen.
                            • Rene55R Rene55
                              ___manalishi
                              #104
                              @rene55
                              deyeidc.0
                              2023-04-10 09:51:06.210 error Logger number seems to be wrong [2744092xxxx] .
                              deyeidc.0
                              2023-04-10 09:51:06.210 debug IP address [192.168.90.56] seems to be valid.
                              ich habe in der main.js folgende Änderung vorgenommen:
                              	if (this.config.logger < 2100000000) {
                              Damit startet der Adapter und verbindet sich mit dem WR
                              Rene55R K 2 Antworten Letzte Antwort
                                @rene55
                                deyeidc.0
                                deyeidc.0
                                Rene55R Online
                                Rene55R Online
                                Rene55
                                #105
                                @frank70 Das wäre dann Stufe 2 gewesen. Und? Bringt der auch brauchbare Daten?
                                ___manalishi_ 1 Antwort Letzte Antwort
                                • Rene55R Rene55
                                  ___manalishi
                                  #106
                                  @rene55 teilweise, manche register passen nicht.
                                    Rene55R Online
                                    Rene55R Online
                                    Rene55
                                    #107
                                    @frank70 Dazu fehlt mir natürlich die Information, welche Register die 'großen' Inverter verwenden. Hast du weitergehende Infos?
                                    • ___manalishi_ Offline
                                      ___manalishi
                                      #108
                                      @rene55
                                      DEYE Modbus RTU.docx
                                      RangeError [ERR_OUT_OF_RANGE]: The value of "offset" is out of range. It must be >= 0 and <= 198. Received 200 at new NodeError (node:internal/errors:387:5) at boundsError (node:internal/buffer:86:9) at Buffer.readUInt16BE (node:internal/buffer:332:5) at idcCore.readCoils (/opt/iobroker/node_modules/iobroker.deyeidc/lib/idc-core.js:149:39) at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.deyeidc/main.js:151:31) at Socket.emit (node:events:513:28) at addChunk (node:internal/streams/readable:315:12) at readableAddChunk (node:internal/streams/readable:289:9) at Socket.Readable.push (node:internal/streams/readable:228:10) at TCP.onStreamRead (node:internal/stream_base_commons:190:23)
                                        @rene55
                                        Rene55R Online
                                        Rene55R Online
                                        Rene55
                                        #109
                                        @frank70 Ich liebe chinesische Dokus. 😠 Was hast du denn bei 'Register' und 'Coils' aktuell eingestellt?
                                        • Rene55R Rene55
                                          ___manalishi
                                          #110
                                          @rene55 ich kann leider keine attachments laden. gibt einen Fehler im Browser. Habe dir eine email gesendet
                                          Register:
                                          600 699
                                          Coils:
                                          676 3 676 PV1 Voltage V
                                          ___manalishi_ Rene55R 2 Antworten Letzte Antwort
