    apollon77A
7.6k Beiträge 296 Kommentatoren 8.3m Aufrufe 201 Beobachtet
  • R Rookie50
    Hi, falls es jemanden interessiert. Ich habe es nun geschafft meine Kameras mit RTSPtoWeb in iQontrol darzustellen. Man muss einfach ein neues Geräte als Widget erstellen und unter Background_HTML folgenden Code einfügen:
    <input type="hidden" name="webrtc-url" id="webrtc-url" value="http://192.168.2.2:8083/stream/a34525d7-6d13-421d-9127-2cd7bc4323dc/channel/0/webrtc" />
    <video id="webrtc-video" autoplay muted playsinline controls style="max-width: 100%; max-height: 100%;" />
    <script>
    setTimeout(function () {
      function startPlay(videoEl, url) {
        const webrtc = new RTCPeerConnection({
          iceServers: [
              urls: ["stun:stun.l.google.com:19302"],
          sdpSemantics: "unified-plan",
        webrtc.ontrack = function (event) {
          console.log(event.streams.length + " track is delivered");
          videoEl.srcObject = event.streams[0];
          videoEl.play();
        webrtc.addTransceiver("video", { direction: "sendrecv" });
        webrtc.onnegotiationneeded = async function handleNegotiationNeeded() {
          const offer = await webrtc.createOffer();
          await webrtc.setLocalDescription(offer);
          fetch(url, {
            method: "POST",
            body: new URLSearchParams({ data: btoa(webrtc.localDescription.sdp) }),
            .then((response) => response.text())
            .then((data) => {
              try {
                webrtc.setRemoteDescription(new RTCSessionDescription({ type: "answer", sdp: atob(data) }));
              } catch (e) {
                console.warn(e);
        const webrtcSendChannel = webrtc.createDataChannel("rtsptowebSendChannel");
        webrtcSendChannel.onopen = (event) => {
          console.log(`${webrtcSendChannel.label} has opened`);
          webrtcSendChannel.send("ping");
        webrtcSendChannel.onclose = (_event) => {
          console.log(`${webrtcSendChannel.label} has closed`);
          startPlay(videoEl, url);
        webrtcSendChannel.onmessage = (event) => console.log(event.data);
      const videoEl = document.querySelector("#webrtc-video");
      const webrtcUrl = document.querySelector("#webrtc-url").value;
      startPlay(videoEl, webrtcUrl);
    }, 1000);
    </script>
    In der erste Zeile muss nur die IP addresse und die Kamera ID angepasst werden:
    Sobald die Ansicht geladen wird startet der Player mit Videobild.
    s.bormannS
    s.bormannS
    s.bormann
    #7456
    @rookie50 sagte in Test Adapter iQontrol 2.0.x Vis (Entwicklungs-Thread):
    <script>
          iceServers: [
          videoEl.play();
          fetch(url, {
            method: "POST",
            .then((data) => {
              try {
              } catch (e) {
                console.warn(e);
    }, 1000);
    </script>
    Klasse!
    Könntest Du ggf. einen kurzen Wiki-Artikel erstellen? Also im Prinzip dieser Beitrag + ganz kurz, wie das mit rtsptoweb geht.
    Das wäre echt klasse!
    R 1 Antwort Letzte Antwort
    • s.bormannS s.bormann
      <script>
            iceServers: [
            videoEl.play();
            fetch(url, {
              method: "POST",
              .then((data) => {
                try {
                } catch (e) {
                  console.warn(e);
      }, 1000);
      </script>
      Klasse!
      R
      R
      Rookie50
      #7457
      @s-bormann Hi, ist im Wiki :-D Habe ein bisschen von tombox geklaut ;-) Bitte geht mal durch, ob es so verständlich ist.
      • R Rookie50
        s.bormannS
        s.bormannS
        s.bormann
        #7458
        Klasse!! Sieht super aus, vielen Dank!!
        • M muuulle
          @s-bormann
          Moin Sebastian,
          die persistenten Popup sind großartig. Zwei bebilderte Fragen:
          1. Kann man die Transparenz reduzieren?
          2. Was bedeuten die Info- und Warnmeldung vom Web Adapter?
          Besten Dank
          M
          M
          muuulle
          schrieb am zuletzt editiert von muuulle
          #7459
          @muuulle said in Test Adapter iQontrol 2.0.x Vis (Entwicklungs-Thread):
          @s-bormann
          Moin Sebastian,
          Besten Dank
          @s-bormann
          Moin,
          neben den beiden hier zitierten Punkten, habe ich noch eine weitere Frage/Anregung 😊
          Kann man persistente Popup einer bestimmten ID über einen Blockly Befehl löschen?
          Schönes Wochenende
          • M muuulle
            @s-bormann
            Moin Sebastian,
            Besten Dank
            @s-bormann
            Moin,
            Schönes Wochenende
            s.bormannS
            s.bormannS
            s.bormann
            #7460
            @muuulle sagte in Test Adapter iQontrol 2.0.x Vis (Entwicklungs-Thread):
            @s-bormann
            Moin Sebastian,
            Besten Dank
            @s-bormann
            Moin,
            Schönes Wochenende
            Zu 1.: Transprarenz wollte ich noch als Option einbauen - bin aber gerade anderweitig beschäftigt, deshalb wird es noch ein klein wenig dauern. Bis dahin könntest Du im Benutzerdefinierten CSS folgendes eingeben:
            #popup{
            	opacity: 1 !important;
            Damit fadet es zwar nicht mehr so schön ein- und aus, aber es kann als Überbrückung bis alles user-wählbar ist genutzt werden. Ich werde dann auch noch die Hintergrundfarbe anpassbar machen.
            Zu 2.: Die Warnungen im Web-Adapter kann man erst mal ignorieren, da muss ich noch das ack-flag korrekt setzen, werde ich demnächst bearbeiten.
            Zu 3.: Das geht mit dem "steuere"-Blockly auf den Datenpunkt iqontrol.<x>.Popup.PERSISTENT_MESSAGES_DELETE_ID:
            LG!!
            • E
              E
              Easyghost
              #7461
              Hi benötige eure Hilfe
              Das ist mein Aktueller Stand
              Hätte es gerne so
              Habe aktuell das Problem das es sich nicht zu und aufklappen lässt finde einfach nicht die Einstellung dazu!
              Danke für eure Mühe
              dslraserD s.bormannS 2 Antworten Letzte Antwort
              • E Easyghost
                Hätte es gerne so
                Danke für eure Mühe
                dslraserD
                dslraserD
                dslraser
                #7462
                @easyghost sagte in Test Adapter iQontrol 2.0.x Vis (Entwicklungs-Thread):
                Hätte es gerne so
                Danke für eure Mühe
                Das ist ein altes Foto von mir. Damals hatte ich das noch so. (da ist auch eine Beschreibung)
                https://forum.iobroker.net/post/752651
                Dann hatte ich noch eine neuere Version davon gemacht.
                https://forum.iobroker.net/post/755066
                Dazu musst Du wahrscheinlich etwas Zeit zum Einlesen investieren.
                Es gibt auch noch andere Möglichkeiten so etwas umzusetzen, allerdings müsste ich dafür auch erst im Forum auf die Suche gehen…(irgendwo ist das hier im Forum schon alles beschrieben)
                E 2 Antworten Letzte Antwort
                • E Easyghost
                  Hätte es gerne so
                  Danke für eure Mühe
                  s.bormannS
                  s.bormannS
                  s.bormann
                  #7463
                  Hätte es gerne so
                  Danke für eure Mühe
                  Schau auch mal im wiki:
                  https://github.com/sbormann/ioBroker.iqontrol/wiki/Listen-Zähler
                  E 1 Antwort Letzte Antwort
                  • dslraserD dslraser
                    Hätte es gerne so
                    Danke für eure Mühe
                    E
                    E
                    Easyghost
                    #7464
                    @dslraser OK Danke Versuch es heute Abend Mal nach der neuen Version
                      Hätte es gerne so
                      Danke für eure Mühe
                      E
                      E
                      Easyghost
                      schrieb am zuletzt editiert von Easyghost
                      #7465
                      @s-bormann ja nach dem Wiki habe ich es gemacht aber leider ist das nicht mehr aktuell und bekomme es auch nicht hin das es sich aufklappt und schließt.
                      PS: und erstmal großes Lob von mir für den Adapter iQontrol.
                        Hätte es gerne so
                        Danke für eure Mühe
                        E
                        E
                        Easyghost
                        #7466
                        @dslraser Hi habe es nochmal mit der neuen Version gemacht
                        Da komme ich so weit bin nur nicht ganz sicher ob der Fehler in der Überschrift am Blockly oder am iQontrol liegt?
                        da_WoodyD dslraserD 2 Antworten Letzte Antwort
                        • E Easyghost
                          da_WoodyD
                          da_WoodyD
                          #7467
                          @easyghost du meinst 39225417-c8e3-4543-873d-342730e9ff9a-grafik.png ?
                          • da_WoodyD da_Woody
                            E
                            E
                            Easyghost
                            #7468
                            @da_woody ja habe eins offen eins gekippt dann sollte doch oben stehen 2 Fenster geöffnet oder ? Weiß aber nicht wo der Fehler liegt
                            • E Easyghost
                              da_WoodyD
                              da_WoodyD
                              #7469
                              @easyghost hab dich verstanden. ich verwende das so nicht, aber hab mir das blockly mal runtergeladen, da steht nix von okay drinnen. würde also sagen, du hast da in iQontrol was falsch eingestellt.
                              kontrolliere anhand vom wiki nochmal alles, oder machs gegebene falles komplett neu...
                              • E Easyghost
                                dslraserD
                                dslraserD
                                dslraser
                                #7470
                                @easyghost
                                ich habe Dir mal eine Chat Nachricht geschrieben.
                                Die Überschrift macht das Blockly. Du hast wahrscheinlich im Blockly etwas nicht bzw. etwas falsch eingestellt.
                                Bei mir laufen diese Blockly seit sehr langer Zeit Fehlerfrei.
                                  @easyghost
                                  E
                                  E
                                  Easyghost
                                  #7471
                                  @dslraser
                                  War eine Einstellung in der Liste im iQontrol habe es nach den Bildern gemach aus dem Wiki
                                  149938703-94bd37bb-aeca-4547-85a1-559cf6126f47.png 149938704-37e620a4-6b71-41ff-bc12-94ae801fdfb8.png 149938707-ebd82516-cb25-4fd7-afb8-6fb8f561b141.png
                                  Und so muss es bei mir sein
                                  Screenshot_20230404-222816.png Screenshot_20230404-222829.png Screenshot_20230404-222752.png
                                  • E Easyghost
                                    @dslraser
                                    dslraserD
                                    dslraserD
                                    dslraser
                                    #7472
                                    @easyghost
                                    Ich habe Alias in Verwendung und diese dann auf deutsch erstellt, also nicht mit CLOSED/TILTED oder OPEN.
                                    Beispiel von einem alias für ein Fenster wie ich es verwende
                                      "type": "state",
                                      "common": {
                                        "name": "Bad links",
                                        "def": 0,
                                        "type": "number",
                                        "role": "window.value",
                                        "read": true,
                                        "write": false,
                                        "min": 0,
                                        "max": 2,
                                        "states": {
                                          "0": "geschlossen",
                                          "1": "gekippt",
                                          "2": "geöffnet"
                                        "alias": {
                                          "id": "hm-rpc.xxxxxxxxxxxx.1.STATE"
                                      "native": {},
                                      "from": "system.adapter.javascript.0",
                                      "user": "system.user.admin",
                                      "ts": 1615639416752,
                                      "_id": "alias.0.Fenster.Bad_Fenster_links",
                                      "acl": {
                                        "object": 1636,
                                        "state": 1636,
                                        "owner": "system.user.admin",
                                    jetzt vielleicht nur noch "einheitliche" Schreibweisen in groß oder klein und "passende" Symbole für geschlossen/gekippt und geöffnet verwenden und vielleicht Alias anlegen ohne ".STATE" 👍 , dann sieht es noch besser aus.😊
                                      @easyghost
                                        "type": "state",
                                        "common": {
                                          "def": 0,
                                          "type": "number",
                                          "read": true,
                                          "write": false,
                                          "min": 0,
                                          "max": 2,
                                          "states": {
                                            "0": "geschlossen",
                                            "1": "gekippt",
                                            "2": "geöffnet"
                                          "alias": {
                                        "native": {},
                                        "acl": {
                                          "object": 1636,
                                          "state": 1636,
                                      E
                                      E
                                      Easyghost
                                      #7473
                                      @dslraser ja das muss ich später noch ändern für mich ist erst Mal die Funktion wichtig und das ich es verstehe außensehen kommt zum Schluss 😜.
                                      Das ist ne andere Aufgabe nun muss ich als nächstes erst Mal schauen wie das mit der digitalen Uhr läuft.
                                      Aber Danke für das Skript kann es dann direkt mit machen.
                                      • E Easyghost
                                        dslraserD
                                        dslraserD
                                        dslraser
                                        #7474
                                        ? was für’n Skript ?
                                        • E
                                          E
                                          Easyghost
                                          #7475
                                          @dslraser der Tip mit den Alias habe es auch so hinbekommen.
                                          Habe noch einige Probleme mit dem Digitalen Uhr Skript kann da jemand helfen?
                                          Kenne mich mit Java nicht aus
                                          Habe mir das Skript aus dem Beitrag Version 7 und Astro genommen Bilder Ordner im Skript eingetragen und Außenfühler geändert jetzt bekomme ich immer wieder die Fehler.
                                          Die Anzeige scheint zu funktionieren
                                          Danke für die Hilfe
                                          83.9k
