    6.5k
7.6k Beiträge 296 Kommentatoren 7.8m Aufrufe 201 Beobachtet
  • R Offline
    Rookie50
    #7455
    Hi, falls es jemanden interessiert. Ich habe es nun geschafft meine Kameras mit RTSPtoWeb in iQontrol darzustellen. Man muss einfach ein neues Geräte als Widget erstellen und unter Background_HTML folgenden Code einfügen:
    <input type="hidden" name="webrtc-url" id="webrtc-url" value="http://192.168.2.2:8083/stream/a34525d7-6d13-421d-9127-2cd7bc4323dc/channel/0/webrtc" />
    <video id="webrtc-video" autoplay muted playsinline controls style="max-width: 100%; max-height: 100%;" />
    <script>
    setTimeout(function () {
      function startPlay(videoEl, url) {
        const webrtc = new RTCPeerConnection({
          iceServers: [
              urls: ["stun:stun.l.google.com:19302"],
          sdpSemantics: "unified-plan",
        webrtc.ontrack = function (event) {
          console.log(event.streams.length + " track is delivered");
          videoEl.srcObject = event.streams[0];
          videoEl.play();
        webrtc.addTransceiver("video", { direction: "sendrecv" });
        webrtc.onnegotiationneeded = async function handleNegotiationNeeded() {
          const offer = await webrtc.createOffer();
          await webrtc.setLocalDescription(offer);
          fetch(url, {
            method: "POST",
            body: new URLSearchParams({ data: btoa(webrtc.localDescription.sdp) }),
            .then((response) => response.text())
            .then((data) => {
              try {
                webrtc.setRemoteDescription(new RTCSessionDescription({ type: "answer", sdp: atob(data) }));
              } catch (e) {
                console.warn(e);
        const webrtcSendChannel = webrtc.createDataChannel("rtsptowebSendChannel");
        webrtcSendChannel.onopen = (event) => {
          console.log(`${webrtcSendChannel.label} has opened`);
          webrtcSendChannel.send("ping");
        webrtcSendChannel.onclose = (_event) => {
          console.log(`${webrtcSendChannel.label} has closed`);
          startPlay(videoEl, url);
        webrtcSendChannel.onmessage = (event) => console.log(event.data);
      const videoEl = document.querySelector("#webrtc-video");
      const webrtcUrl = document.querySelector("#webrtc-url").value;
      startPlay(videoEl, webrtcUrl);
    }, 1000);
    </script>
    In der erste Zeile muss nur die IP addresse und die Kamera ID angepasst werden:
    Sobald die Ansicht geladen wird startet der Player mit Videobild.
    s.bormannS B 2 Antworten Letzte Antwort
    • R Rookie50
      <script>
            iceServers: [
            videoEl.play();
            fetch(url, {
              method: "POST",
              .then((data) => {
                try {
                } catch (e) {
                  console.warn(e);
      }, 1000);
      </script>
      s.bormannS Offline
      s.bormannS Offline
      s.bormann
      #7456
      @rookie50 sagte in Test Adapter iQontrol 2.0.x Vis (Entwicklungs-Thread):
      <script>
            iceServers: [
            videoEl.play();
            fetch(url, {
              method: "POST",
              .then((data) => {
                try {
                } catch (e) {
                  console.warn(e);
      }, 1000);
      </script>
      Klasse!
      Könntest Du ggf. einen kurzen Wiki-Artikel erstellen? Also im Prinzip dieser Beitrag + ganz kurz, wie das mit rtsptoweb geht.
      Das wäre echt klasse!
      R 1 Antwort Letzte Antwort
      • s.bormannS s.bormann
        <script>
              iceServers: [
              videoEl.play();
              fetch(url, {
                method: "POST",
                .then((data) => {
                  try {
                  } catch (e) {
                    console.warn(e);
        }, 1000);
        </script>
        Klasse!
        Rookie50
        #7457
        @s-bormann Hi, ist im Wiki :-D Habe ein bisschen von tombox geklaut ;-) Bitte geht mal durch, ob es so verständlich ist.
        • R Rookie50
          s.bormannS Offline
          s.bormannS Offline
          s.bormann
          #7458
          Klasse!! Sieht super aus, vielen Dank!!
          • M muuulle
            @s-bormann
            Moin Sebastian,
            die persistenten Popup sind großartig. Zwei bebilderte Fragen:
            1. Kann man die Transparenz reduzieren?
            2. Was bedeuten die Info- und Warnmeldung vom Web Adapter?
            Besten Dank
            muuulle
            schrieb am zuletzt editiert von muuulle
            #7459
            @muuulle said in Test Adapter iQontrol 2.0.x Vis (Entwicklungs-Thread):
            @s-bormann
            Moin Sebastian,
            Besten Dank
            @s-bormann
            Moin,
            neben den beiden hier zitierten Punkten, habe ich noch eine weitere Frage/Anregung 😊
            Kann man persistente Popup einer bestimmten ID über einen Blockly Befehl löschen?
            Schönes Wochenende
            • M muuulle
              @s-bormann
              Moin Sebastian,
              Besten Dank
              @s-bormann
              Moin,
              Schönes Wochenende
              s.bormannS Offline
              s.bormannS Offline
              s.bormann
              #7460
              @muuulle sagte in Test Adapter iQontrol 2.0.x Vis (Entwicklungs-Thread):
              @s-bormann
              Moin Sebastian,
              Besten Dank
              @s-bormann
              Moin,
              Schönes Wochenende
              Zu 1.: Transprarenz wollte ich noch als Option einbauen - bin aber gerade anderweitig beschäftigt, deshalb wird es noch ein klein wenig dauern. Bis dahin könntest Du im Benutzerdefinierten CSS folgendes eingeben:
              #popup{
              	opacity: 1 !important;
              Damit fadet es zwar nicht mehr so schön ein- und aus, aber es kann als Überbrückung bis alles user-wählbar ist genutzt werden. Ich werde dann auch noch die Hintergrundfarbe anpassbar machen.
              Zu 2.: Die Warnungen im Web-Adapter kann man erst mal ignorieren, da muss ich noch das ack-flag korrekt setzen, werde ich demnächst bearbeiten.
              Zu 3.: Das geht mit dem "steuere"-Blockly auf den Datenpunkt iqontrol.<x>.Popup.PERSISTENT_MESSAGES_DELETE_ID:
              LG!!
              • E Offline
                Easyghost
                #7461
                Hi benötige eure Hilfe
                Das ist mein Aktueller Stand
                Hätte es gerne so
                Habe aktuell das Problem das es sich nicht zu und aufklappen lässt finde einfach nicht die Einstellung dazu!
                Danke für eure Mühe
                dslraserD s.bormannS 2 Antworten Letzte Antwort
                • E Easyghost
                  Hätte es gerne so
                  Danke für eure Mühe
                  dslraserD Offline
                  dslraserD Offline
                  dslraser
                  #7462
                  @easyghost sagte in Test Adapter iQontrol 2.0.x Vis (Entwicklungs-Thread):
                  Hätte es gerne so
                  Danke für eure Mühe
                  Das ist ein altes Foto von mir. Damals hatte ich das noch so. (da ist auch eine Beschreibung)
                  https://forum.iobroker.net/post/752651
                  Dann hatte ich noch eine neuere Version davon gemacht.
                  https://forum.iobroker.net/post/755066
                  Dazu musst Du wahrscheinlich etwas Zeit zum Einlesen investieren.
                  Es gibt auch noch andere Möglichkeiten so etwas umzusetzen, allerdings müsste ich dafür auch erst im Forum auf die Suche gehen…(irgendwo ist das hier im Forum schon alles beschrieben)
                  E 2 Antworten Letzte Antwort
                  • E Easyghost
                    Hätte es gerne so
                    Danke für eure Mühe
                    s.bormannS Offline
                    s.bormannS Offline
                    s.bormann
                    #7463
                    Hätte es gerne so
                    Danke für eure Mühe
                    Schau auch mal im wiki:
                    https://github.com/sbormann/ioBroker.iqontrol/wiki/Listen-Zähler
                    E 1 Antwort Letzte Antwort
                    • dslraserD dslraser
                      Hätte es gerne so
                      Danke für eure Mühe
                      Easyghost
                      #7464
                      @dslraser OK Danke Versuch es heute Abend Mal nach der neuen Version
                        Hätte es gerne so
                        Danke für eure Mühe
                        Easyghost
                        schrieb am zuletzt editiert von Easyghost
                        #7465
                        @s-bormann ja nach dem Wiki habe ich es gemacht aber leider ist das nicht mehr aktuell und bekomme es auch nicht hin das es sich aufklappt und schließt.
                        PS: und erstmal großes Lob von mir für den Adapter iQontrol.
                          Hätte es gerne so
                          Danke für eure Mühe
                          Easyghost
                          #7466
                          @dslraser Hi habe es nochmal mit der neuen Version gemacht
                          Da komme ich so weit bin nur nicht ganz sicher ob der Fehler in der Überschrift am Blockly oder am iQontrol liegt?
                          da_WoodyD dslraserD 2 Antworten Letzte Antwort
                          • E Easyghost
                            da_WoodyD Offline
                            da_WoodyD Offline
                            #7467
                            @easyghost du meinst 39225417-c8e3-4543-873d-342730e9ff9a-grafik.png ?
                            • da_WoodyD da_Woody
                              Easyghost
                              #7468
                              @da_woody ja habe eins offen eins gekippt dann sollte doch oben stehen 2 Fenster geöffnet oder ? Weiß aber nicht wo der Fehler liegt
                              • E Easyghost
                                da_WoodyD Offline
                                da_WoodyD Offline
                                #7469
                                @easyghost hab dich verstanden. ich verwende das so nicht, aber hab mir das blockly mal runtergeladen, da steht nix von okay drinnen. würde also sagen, du hast da in iQontrol was falsch eingestellt.
                                kontrolliere anhand vom wiki nochmal alles, oder machs gegebene falles komplett neu...
                                • E Easyghost
                                  dslraserD Offline
                                  dslraserD Offline
                                  dslraser
                                  #7470
                                  @easyghost
                                  ich habe Dir mal eine Chat Nachricht geschrieben.
                                  Die Überschrift macht das Blockly. Du hast wahrscheinlich im Blockly etwas nicht bzw. etwas falsch eingestellt.
                                  Bei mir laufen diese Blockly seit sehr langer Zeit Fehlerfrei.
                                    @easyghost
                                    Easyghost
                                    #7471
                                    @dslraser
                                    War eine Einstellung in der Liste im iQontrol habe es nach den Bildern gemach aus dem Wiki
                                    149938703-94bd37bb-aeca-4547-85a1-559cf6126f47.png 149938704-37e620a4-6b71-41ff-bc12-94ae801fdfb8.png 149938707-ebd82516-cb25-4fd7-afb8-6fb8f561b141.png
                                    Und so muss es bei mir sein
                                    Screenshot_20230404-222816.png Screenshot_20230404-222829.png Screenshot_20230404-222752.png
                                    • E Easyghost
                                      @dslraser
                                      dslraserD Offline
                                      dslraserD Offline
                                      dslraser
                                      #7472
                                      @easyghost
                                      Ich habe Alias in Verwendung und diese dann auf deutsch erstellt, also nicht mit CLOSED/TILTED oder OPEN.
                                      Beispiel von einem alias für ein Fenster wie ich es verwende
                                        "type": "state",
                                        "common": {
                                          "name": "Bad links",
                                          "def": 0,
                                          "type": "number",
                                          "role": "window.value",
                                          "read": true,
                                          "write": false,
                                          "min": 0,
                                          "max": 2,
                                          "states": {
                                            "0": "geschlossen",
                                            "1": "gekippt",
                                            "2": "geöffnet"
                                          "alias": {
                                            "id": "hm-rpc.xxxxxxxxxxxx.1.STATE"
                                        "native": {},
                                        "from": "system.adapter.javascript.0",
                                        "user": "system.user.admin",
                                        "ts": 1615639416752,
                                        "_id": "alias.0.Fenster.Bad_Fenster_links",
                                        "acl": {
                                          "object": 1636,
                                          "state": 1636,
                                          "owner": "system.user.admin",
                                      jetzt vielleicht nur noch "einheitliche" Schreibweisen in groß oder klein und "passende" Symbole für geschlossen/gekippt und geöffnet verwenden und vielleicht Alias anlegen ohne ".STATE" 👍 , dann sieht es noch besser aus.😊
                                        @easyghost
                                          "type": "state",
                                          "common": {
                                            "def": 0,
                                            "type": "number",
                                            "read": true,
                                            "write": false,
                                            "min": 0,
                                            "max": 2,
                                            "states": {
                                              "0": "geschlossen",
                                              "1": "gekippt",
                                              "2": "geöffnet"
                                            "alias": {
                                          "native": {},
                                          "acl": {
                                            "object": 1636,
                                            "state": 1636,
                                        Easyghost
                                        #7473
                                        @dslraser ja das muss ich später noch ändern für mich ist erst Mal die Funktion wichtig und das ich es verstehe außensehen kommt zum Schluss 😜.
                                        Das ist ne andere Aufgabe nun muss ich als nächstes erst Mal schauen wie das mit der digitalen Uhr läuft.
                                        Aber Danke für das Skript kann es dann direkt mit machen.
                                        • E Easyghost
                                          dslraserD Offline
                                          dslraserD Offline
                                          dslraser
                                          #7474
                                          ? was für’n Skript ?
