  4. Adapter: SMA SEMP
    apollon77A
Adapter: SMA SEMP
264 Beiträge 30 Kommentatoren 83.6k Aufrufe 28 Beobachtet
  • W Webwanze
    @rene_hm
    die Instanz wird jetzt grün:
    2023-03-11 09:55:55.393 - info: host.ioBroker "system.adapter.semp.0" enabled
    2023-03-11 09:55:55.426 - info: host.ioBroker instance system.adapter.semp.0 started with pid 53629
    2023-03-11 09:55:56.057 - debug: semp.0 (53629) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2023-03-11 09:55:56.076 - debug: semp.0 (53629) Objects client ready ... initialize now
    2023-03-11 09:55:56.078 - debug: semp.0 (53629) Objects create System PubSub Client
    2023-03-11 09:55:56.078 - debug: semp.0 (53629) Objects create User PubSub Client
    2023-03-11 09:55:56.099 - debug: semp.0 (53629) Objects client initialize lua scripts
    2023-03-11 09:55:56.103 - debug: semp.0 (53629) Objects connected to redis: 127.0.0.1:9001
    2023-03-11 09:55:56.114 - debug: semp.0 (53629) Redis States: Use Redis connection: 127.0.0.1:9000
    2023-03-11 09:55:56.120 - debug: semp.0 (53629) States create System PubSub Client
    2023-03-11 09:55:56.121 - debug: semp.0 (53629) States create User PubSub Client
    2023-03-11 09:55:56.128 - debug: semp.0 (53629) States connected to redis: 127.0.0.1:9000
    2023-03-11 09:55:56.154 - debug: semp.0 (53629) Plugin sentry Initialize Plugin (enabled=true)
    2023-03-11 09:55:56.299 - info: semp.0 (53629) starting. Version 0.3.1 (non-npm: rg-engineering/ioBroker.semp#6225ab9cb4be90b2b25f1f20179f6e884e287309) in /opt/iobroker/node_modules/iobroker.semp, node: v16.19.0, js-controller: 4.0.24
    2023-03-11 09:55:56.317 - debug: semp.0 (53629) SSDPServer created: http://192.168.1.2:9765/description.xml ba7895e3-74c6-47ee-a912-e544105b6f50
    2023-03-11 09:55:56.322 - debug: semp.0 (53629) SEMPServer created
    2023-03-11 09:55:56.322 - debug: semp.0 (53629) gateway created...
    2023-03-11 09:55:56.325 - debug: semp.0 (53629) SEMP server listening on 9765
    2023-03-11 09:55:56.328 - debug: semp.0 (53629) SSDPServer started
    2023-03-11 09:55:56.328 - debug: semp.0 (53629) gateway started...
    2023-03-11 09:55:56.328 - debug: semp.0 (53629) Started all!
    2023-03-11 09:55:56.328 - debug: semp.0 (53629) add device {"IsActive":true,"ID":"F-0-000000000001-00","Name":"newDevice0","Vendor":"ACME","Type":"Heater","SerialNr":"1234","MaxPower":"1000","MinPower":"0","InterruptionsAllowed":false,"MinOnTime":"","MaxOnTime":"","MinOffTime":"","MaxOffTime":"","MeasurementMethod":"Measurement","OID_Power":"0_userdata.0.DEVICES.ECENTRALHEATING_P","MeasurementUnit":"W","BatteryCapacity":"","WallboxHas3phaseEnabler":false,"StatusDetection":"AlwaysOn","StatusDetectionLimit":0,"StatusDetectionLimitTimeOn":0,"StatusDetectionLimitTimeOff":0,"StatusDetectionMinRunTime":0,"OID_Status":"","HasOIDSwitch":false,"OID_Switch":"","SwitchOffAtEndOfTimer":false,"TimerActive":false,"TimerCancelIfNotOn":false,"TimerCancelIfNotOnTime":0,"EnergyRequestPeriods":[{"ID":"1","Days":"","EarliestStartTime":"","LatestEndTime":"","MinRunTime":"","MaxRunTime":""}],"WallboxOIDs":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"","Type":"Boolean","SetValue":"true"},{"active":false,"must":"optional","Name":"DeviceOIDIsCharging","OID":"","Type":"Boolean","SetValue":"true"},{"active":false,"must":"optional","Name":"DeviceOIDIsError","OID":"","Type":"Boolean","SetValue":"true"},{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"","Type":"Number","SetValue":"0"},{"active":false,"must":"optional","Name":"DeviceOIDStartCharge","OID":"","Type":"Boolean","SetValue":"true"},{"active":false,"must":"optional","Name":"DeviceOIDStopCharge","OID":"","Type":"Boolean","SetValue":"true"}]}
    2023-03-11 09:55:56.329 - debug: semp.0 (53629) add device F-0-000000000001-00
    2023-03-11 09:55:56.330 - error: semp.0 (53629) newDevice0 wrong device id F-0-000000000001-00! must follow F-xxxxxxxx-yyyyyyyyyyyy-zz
    2023-03-11 09:55:56.330 - debug: semp.0 (53629) can use optional energy: false
    2023-03-11 09:55:56.330 - debug: semp.0 (53629) subscribe OID_Power 0_userdata.0.DEVICES.ECENTRALHEATING_P
    2023-03-11 09:55:56.332 - info: semp.0 (53629) device created F-0-000000000001-00 newDevice0
    2023-03-11 09:55:56.333 - debug: semp.0 (53629) set device
    2023-03-11 09:55:56.333 - debug: semp.0 (53629) newDevice0 setState On
    2023-03-11 09:55:56.334 - debug: semp.0 (53629) UpdateData
    2023-03-11 09:55:56.334 - debug: semp.0 (53629) device {"IsActive":true,"ID":"F-0-000000000001-00","Name":"newDevice0","Vendor":"ACME","Type":"Heater","SerialNr":"1234","MaxPower":"1000","MinPower":"0","InterruptionsAllowed":false,"MinOnTime":"","MaxOnTime":"","MinOffTime":"","MaxOffTime":"","MeasurementMethod":"Measurement","OID_Power":"0_userdata.0.DEVICES.ECENTRALHEATING_P","MeasurementUnit":"W","BatteryCapacity":"","WallboxHas3phaseEnabler":false,"StatusDetection":"AlwaysOn","StatusDetectionLimit":0,"StatusDetectionLimitTimeOn":0,"StatusDetectionLimitTimeOff":0,"StatusDetectionMinRunTime":0,"OID_Status":"","HasOIDSwitch":false,"OID_Switch":"","SwitchOffAtEndOfTimer":false,"TimerActive":false,"TimerCancelIfNotOn":false,"TimerCancelIfNotOnTime":0,"EnergyRequestPeriods":[{"ID":"1","Days":"","EarliestStartTime":"","LatestEndTime":"","MinRunTime":"","MaxRunTime":""}],"WallboxOIDs":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"","Type":"Boolean","SetValue":"true"},{"active":false,"must":"optional","Name":"DeviceOIDIsCharging","OID":"","Type":"Boolean","SetValue":"true"},{"active":false,"must":"optional","Name":"DeviceOIDIsError","OID":"","Type":"Boolean","SetValue":"true"},{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"","Type":"Number","SetValue":"0"},{"active":false,"must":"optional","Name":"DeviceOIDStartCharge","OID":"","Type":"Boolean","SetValue":"true"},{"active":false,"must":"optional","Name":"DeviceOIDStopCharge","OID":"","Type":"Boolean","SetValue":"true"}],"OptionalEnergy":false}
    2023-03-11 09:55:56.334 - debug: semp.0 (53629) result [{"ID":"1","Days":"","EarliestStartTime":"","LatestEndTime":"","MinRunTime":"","MaxRunTime":""}]
    2023-03-11 09:55:56.334 - debug: semp.0 (53629) result [{"IsActive":true,"ID":"F-0-000000000001-00","Name":"newDevice0","Vendor":"ACME","Type":"Heater","SerialNr":"1234","MaxPower":"1000","MinPower":"0","InterruptionsAllowed":false,"MinOnTime":"","MaxOnTime":"","MinOffTime":"","MaxOffTime":"","MeasurementMethod":"Measurement","OID_Power":"0_userdata.0.DEVICES.ECENTRALHEATING_P","MeasurementUnit":"W","BatteryCapacity":"","WallboxHas3phaseEnabler":false,"StatusDetection":"AlwaysOn","StatusDetectionLimit":0,"StatusDetectionLimitTimeOn":0,"StatusDetectionLimitTimeOff":0,"StatusDetectionMinRunTime":0,"OID_Status":"","HasOIDSwitch":false,"OID_Switch":"","SwitchOffAtEndOfTimer":false,"TimerActive":false,"TimerCancelIfNotOn":false,"TimerCancelIfNotOnTime":0,"EnergyRequestPeriods":[{"ID":"1","Days":"","EarliestStartTime":"","LatestEndTime":"","MinRunTime":"","MaxRunTime":""}],"WallboxOIDs":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"","Type":"Boolean","SetValue":"true"},{"active":false,"must":"optional","Name":"DeviceOIDIsCharging","OID":"","Type":"Boolean","SetValue":"true"},{"active":false,"must":"optional","Name":"DeviceOIDIsError","OID":"","Type":"Boolean","SetValue":"true"},{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"","Type":"Number","SetValue":"0"},{"active":false,"must":"optional","Name":"DeviceOIDStartCharge","OID":"","Type":"Boolean","SetValue":"true"},{"active":false,"must":"optional","Name":"DeviceOIDStopCharge","OID":"","Type":"Boolean","SetValue":"true"}],"OptionalEnergy":false}]
    2023-03-11 09:55:56.348 - debug: semp.0 (53629) newDevice0 setLastPower 117 number AlwaysOn W
    2023-03-11 09:55:56.350 - debug: semp.0 (53629) newDevice0 got null from Devices.newDevice0.State
    2023-03-11 09:55:56.351 - error: semp.0 (53629) newDevice0 could not set state waiting on Devices.newDevice0.State
    2023-03-11 09:55:56.354 - debug: semp.0 (53629) newDevice0 got null from Devices.newDevice0.State
    2023-03-11 09:55:56.355 - error: semp.0 (53629) newDevice0 could not set state on on Devices.newDevice0.State
    2023-03-11 09:55:56.357 - debug: semp.0 (53629) newDevice0 got object {"type":"state","common":{"name":"recommended state from SHM","type":"boolean","role":"state","read":true,"write":false},"from":"system.adapter.semp.0","user":"system.user.admin","ts":1678524926725,"_id":"semp.0.Devices.newDevice0.RecommendedState","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    2023-03-11 09:55:56.381 - debug: semp.0 (53629) newDevice0 got object {"type":"state","common":{"name":"last time recommendation changed","type":"string","role":"value.time","read":true,"write":false},"from":"system.adapter.semp.0","user":"system.user.admin","ts":1678524926734,"_id":"semp.0.Devices.newDevice0.Changed","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    2023-03-11 09:55:56.385 - debug: semp.0 (53629) newDevice0 got object {"type":"state","common":{"name":"current State","type":"string","role":"state","read":true,"write":false},"from":"system.adapter.semp.0","user":"system.user.admin","ts":1678524926738,"_id":"semp.0.Devices.newDevice0.State","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    2023-03-11 09:55:56.386 - debug: semp.0 (53629) newDevice0 got object {"type":"state","common":{"name":"Energy used","type":"number","unit":"Wh","role":"value","read":true,"write":false},"from":"system.adapter.semp.0","user":"system.user.admin","ts":1678524926744,"_id":"semp.0.Devices.newDevice0.Energy","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    2023-03-11 09:55:59.376 - debug: semp.0 (53629) SHM requested description
    2023-03-11 09:55:59.377 - info: semp.0 (53629) adapter discovered by SHM
    2023-03-11 09:56:00.033 - debug: semp.0 (53629) newDevice0 setLastPower 117 number AlwaysOn W
    2023-03-11 09:56:00.033 - debug: semp.0 (53629) newDevice0 calc energy 117 1678524956349 = 0.11973000000000002Wh
    2023-03-11 09:56:15.007 - debug: semp.0 (53629) newDevice0 setLastPower 117 number AlwaysOn W
    2023-03-11 09:56:15.008 - debug: semp.0 (53629) newDevice0 calc energy 117 1678524960033 = 0.6064175Wh
    2023-03-11 09:56:16.376 - debug: semp.0 (53629) SHM requested description
    2023-03-11 09:56:30.009 - debug: semp.0 (53629) newDevice0 setLastPower 117 number AlwaysOn W
    2023-03-11 09:56:30.009 - debug: semp.0 (53629) newDevice0 calc energy 117 1678524975008 = 1.09395Wh
    2023-03-11 09:56:36.377 - debug: semp.0 (53629) SHM requested description
    2023-03-11 09:56:45.007 - debug: semp.0 (53629) newDevice0 setLastPower 122 number AlwaysOn W
    2023-03-11 09:56:45.007 - debug: semp.0 (53629) newDevice0 calc energy 122 1678524990009 = 1.6022155555555555Wh
    Bei den Objekten finden sich immer noch die (null)s.
    Danke für deine Unterstützung!!!
    Rene_HMR
    Rene_HMR
    Rene_HM
    schrieb am zuletzt editiert von Rene_HM
    #151
    @webwanze sagte in Adapter: SMA SEMP:
    Der Fehler ist noch nicht behoben, nur ignoriert. Ich schaue das log nochmal genauer an. Irgendetwas passt noch nicht...
    und den Fehler darfst du auch nicht ignorieren...
    W 1 Antwort Letzte Antwort
    • Rene_HMR Rene_HM
      W
      W
      Webwanze
      #152
      @rene_hm sagte in Adapter: SMA SEMP:
      Ich habe da nichts geändert. Die ID wurde beim Hinzufügen des Devices automatisch generiert. Habe es aber jetzt mal geändert. Macht natürlich keinen Unterschied.
      Über Java-Script
      setState("semp.0.Devices.newDevice0.State", "test")
      kann ich den State übrigens ändern.
      Rene_HMR 1 Antwort Letzte Antwort
      • W Webwanze
        Über Java-Script
        Rene_HMR
        Rene_HMR
        Rene_HM
        #153
        für o.g. Problem macht es keinen Unterschied, funktionell ist das wichtig.
        • Rene_HMR Rene_HM
          W
          W
          Webwanze
          schrieb am zuletzt editiert von Webwanze
          #154
          @rene_hm
          Ich habe noch etwas herumgespielt und auch was herausgefunden:
          Adapter installieren
          Device anlegen
          -> kein Update State
          Host neu starten
          State von Hand oder Script ändern
          -> Fehler verschwunden, allerdings wird mein String "test" nicht upgedated
          -> ich nehme an, weil sich der State für die Instanz nicht geändert hat, erfolgt kein Update. OK.
          Instanz neu starten
          -> Alles i.O.
          -> State wird auf "on" gesetzt.
          • W Webwanze
            @rene_hm
            Device anlegen
            Host neu starten
            Instanz neu starten
            -> Alles i.O.
            W
            W
            Webwanze
            #155
            Wenn ich nun ein weiteres Device hinzufüge, wird der State ebenfalls nicht upgedated.
            State von Hand auf z.B. "off" setzen.
            Instanz neu starten
            funktioniert.
            Die Were für "Changed" und "RecommendedState" werden übrigens nicht gesetzt. Evtl. wird das auch nicht von der Instanz versucht ...
            Rene_HMR 2 Antworten Letzte Antwort
            • W Webwanze
              Instanz neu starten
              funktioniert.
              Rene_HMR
              Rene_HMR
              Rene_HM
              #156
              Die Werte für "Changed" und "RecommendedState" werden übrigens nicht gesetzt
              Die werden erst gesetzt, wenn eine Energieanforderung vom SHM beantwortet wurde. Solange du dein Gerät auf "immer an" hast und keine Energieanforderung stellst, reagiert der SHM nicht. Das Gerät wird dann nur im Portal dargestellt und zur Berechnung der Prognose herangezogen...
              • W Webwanze
                Instanz neu starten
                funktioniert.
                Rene_HMR
                Rene_HMR
                Rene_HM
                #157
                Instanz neu starten
                funktioniert.
                Habe die Reihenfolge des startups vom Adapter geändert. Außerdem schreibe ich jetzt default-Werte auf die DP. Hoffe, das löst das Problem...
                • Rene_HMR Rene_HM
                  Instanz neu starten
                  funktioniert.
                  W
                  W
                  Webwanze
                  #158
                  @rene_hm
                  Scheint jetzt zu funkionieren:
                  2023-03-11 14:33:46.618 - info: host.ioBroker "system.adapter.semp.0" enabled
                  2023-03-11 14:33:46.650 - info: host.ioBroker instance system.adapter.semp.0 started with pid 4472
                  2023-03-11 14:33:47.283 - debug: semp.0 (4472) Redis Objects: Use Redis connection: 127.0.0.1:9001
                  2023-03-11 14:33:47.302 - debug: semp.0 (4472) Objects client ready ... initialize now
                  2023-03-11 14:33:47.303 - debug: semp.0 (4472) Objects create System PubSub Client
                  2023-03-11 14:33:47.304 - debug: semp.0 (4472) Objects create User PubSub Client
                  2023-03-11 14:33:47.317 - debug: semp.0 (4472) Objects client initialize lua scripts
                  2023-03-11 14:33:47.321 - debug: semp.0 (4472) Objects connected to redis: 127.0.0.1:9001
                  2023-03-11 14:33:47.332 - debug: semp.0 (4472) Redis States: Use Redis connection: 127.0.0.1:9000
                  2023-03-11 14:33:47.337 - debug: semp.0 (4472) States create System PubSub Client
                  2023-03-11 14:33:47.338 - debug: semp.0 (4472) States create User PubSub Client
                  2023-03-11 14:33:47.347 - debug: semp.0 (4472) States connected to redis: 127.0.0.1:9000
                  2023-03-11 14:33:47.370 - debug: semp.0 (4472) Plugin sentry Initialize Plugin (enabled=true)
                  2023-03-11 14:33:47.546 - info: semp.0 (4472) starting. Version 0.3.1 (non-npm: rg-engineering/ioBroker.semp#ba417263657375badc4c456e5859f8b0e308da66) in /opt/iobroker/node_modules/iobroker.semp, node: v16.19.0, js-controller: 4.0.24
                  2023-03-11 14:33:47.563 - debug: semp.0 (4472) SSDPServer created: http://192.168.1.2:9765/description.xml 58ee6313-b746-46aa-aae2-954018429865
                  2023-03-11 14:33:47.568 - debug: semp.0 (4472) SEMPServer created
                  2023-03-11 14:33:47.568 - debug: semp.0 (4472) gateway created...
                  2023-03-11 14:33:47.571 - debug: semp.0 (4472) SEMP server listening on 9765
                  2023-03-11 14:33:47.574 - debug: semp.0 (4472) SSDPServer started
                  2023-03-11 14:33:47.574 - debug: semp.0 (4472) gateway started...
                  2023-03-11 14:33:47.574 - debug: semp.0 (4472) Started all!
                  2023-03-11 14:33:47.575 - debug: semp.0 (4472) add device {"IsActive":true,"ID":"F-12345678-123456789012-12","Name":"newDevice0","Vendor":"ACME","Type":"Dryer","SerialNr":"1234","MaxPower":"1000","MinPower":"0","InterruptionsAllowed":false,"MinOnTime":"","MaxOnTime":"","MinOffTime":"","MaxOffTime":"","MeasurementMethod":"Measurement","OID_Power":"0_userdata.0.DEVICES.ECENTRALHEATING_P","MeasurementUnit":"W","BatteryCapacity":"","WallboxHas3phaseEnabler":false,"StatusDetection":"AlwaysOn","StatusDetectionLimit":0,"StatusDetectionLimitTimeOn":0,"StatusDetectionLimitTimeOff":0,"StatusDetectionMinRunTime":0,"OID_Status":"","HasOIDSwitch":false,"OID_Switch":"","SwitchOffAtEndOfTimer":false,"TimerActive":false,"TimerCancelIfNotOn":false,"TimerCancelIfNotOnTime":0,"EnergyRequestPeriods":[{"ID":"1","Days":"","EarliestStartTime":"","LatestEndTime":"","MinRunTime":"","MaxRunTime":""}],"WallboxOIDs":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"","Type":"Boolean","SetValue":"true"},{"active":false,"must":"optional","Name":"DeviceOIDIsCharging","OID":"","Type":"Boolean","SetValue":"true"},{"active":false,"must":"optional","Name":"DeviceOIDIsError","OID":"","Type":"Boolean","SetValue":"true"},{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"","Type":"Number","SetValue":"0"},{"active":false,"must":"optional","Name":"DeviceOIDStartCharge","OID":"","Type":"Boolean","SetValue":"true"},{"active":false,"must":"optional","Name":"DeviceOIDStopCharge","OID":"","Type":"Boolean","SetValue":"true"}]}
                  2023-03-11 14:33:47.575 - debug: semp.0 (4472) add device F-12345678-123456789012-12
                  2023-03-11 14:33:47.576 - debug: semp.0 (4472) can use optional energy: false
                  2023-03-11 14:33:47.577 - info: semp.0 (4472) device created F-12345678-123456789012-12 newDevice0
                  2023-03-11 14:33:47.577 - debug: semp.0 (4472) set device
                  2023-03-11 14:33:47.577 - debug: semp.0 (4472) newDevice0 setState On
                  2023-03-11 14:33:47.578 - debug: semp.0 (4472) UpdateData
                  2023-03-11 14:33:47.579 - debug: semp.0 (4472) device {"IsActive":true,"ID":"F-12345678-123456789012-12","Name":"newDevice0","Vendor":"ACME","Type":"Dryer","SerialNr":"1234","MaxPower":"1000","MinPower":"0","InterruptionsAllowed":false,"MinOnTime":"","MaxOnTime":"","MinOffTime":"","MaxOffTime":"","MeasurementMethod":"Measurement","OID_Power":"0_userdata.0.DEVICES.ECENTRALHEATING_P","MeasurementUnit":"W","BatteryCapacity":"","WallboxHas3phaseEnabler":false,"StatusDetection":"AlwaysOn","StatusDetectionLimit":0,"StatusDetectionLimitTimeOn":0,"StatusDetectionLimitTimeOff":0,"StatusDetectionMinRunTime":0,"OID_Status":"","HasOIDSwitch":false,"OID_Switch":"","SwitchOffAtEndOfTimer":false,"TimerActive":false,"TimerCancelIfNotOn":false,"TimerCancelIfNotOnTime":0,"EnergyRequestPeriods":[{"ID":"1","Days":"","EarliestStartTime":"","LatestEndTime":"","MinRunTime":"","MaxRunTime":""}],"WallboxOIDs":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"","Type":"Boolean","SetValue":"true"},{"active":false,"must":"optional","Name":"DeviceOIDIsCharging","OID":"","Type":"Boolean","SetValue":"true"},{"active":false,"must":"optional","Name":"DeviceOIDIsError","OID":"","Type":"Boolean","SetValue":"true"},{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"","Type":"Number","SetValue":"0"},{"active":false,"must":"optional","Name":"DeviceOIDStartCharge","OID":"","Type":"Boolean","SetValue":"true"},{"active":false,"must":"optional","Name":"DeviceOIDStopCharge","OID":"","Type":"Boolean","SetValue":"true"}],"OptionalEnergy":false}
                  2023-03-11 14:33:47.579 - debug: semp.0 (4472) result [{"ID":"1","Days":"","EarliestStartTime":"","LatestEndTime":"","MinRunTime":"","MaxRunTime":""}]
                  2023-03-11 14:33:47.579 - debug: semp.0 (4472) result [{"IsActive":true,"ID":"F-12345678-123456789012-12","Name":"newDevice0","Vendor":"ACME","Type":"Dryer","SerialNr":"1234","MaxPower":"1000","MinPower":"0","InterruptionsAllowed":false,"MinOnTime":"","MaxOnTime":"","MinOffTime":"","MaxOffTime":"","MeasurementMethod":"Measurement","OID_Power":"0_userdata.0.DEVICES.ECENTRALHEATING_P","MeasurementUnit":"W","BatteryCapacity":"","WallboxHas3phaseEnabler":false,"StatusDetection":"AlwaysOn","StatusDetectionLimit":0,"StatusDetectionLimitTimeOn":0,"StatusDetectionLimitTimeOff":0,"StatusDetectionMinRunTime":0,"OID_Status":"","HasOIDSwitch":false,"OID_Switch":"","SwitchOffAtEndOfTimer":false,"TimerActive":false,"TimerCancelIfNotOn":false,"TimerCancelIfNotOnTime":0,"EnergyRequestPeriods":[{"ID":"1","Days":"","EarliestStartTime":"","LatestEndTime":"","MinRunTime":"","MaxRunTime":""}],"WallboxOIDs":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"","Type":"Boolean","SetValue":"true"},{"active":false,"must":"optional","Name":"DeviceOIDIsCharging","OID":"","Type":"Boolean","SetValue":"true"},{"active":false,"must":"optional","Name":"DeviceOIDIsError","OID":"","Type":"Boolean","SetValue":"true"},{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"","Type":"Number","SetValue":"0"},{"active":false,"must":"optional","Name":"DeviceOIDStartCharge","OID":"","Type":"Boolean","SetValue":"true"},{"active":false,"must":"optional","Name":"DeviceOIDStopCharge","OID":"","Type":"Boolean","SetValue":"true"}],"OptionalEnergy":false}]
                  2023-03-11 14:33:47.593 - debug: semp.0 (4472) newDevice0 got {"val":"on","ack":true,"ts":1678541192446,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1678541192446} from Devices.newDevice0.State
                  2023-03-11 14:33:47.597 - debug: semp.0 (4472) newDevice0 got object {"type":"state","common":{"name":"recommended state from SHM","type":"boolean","role":"state","read":true,"write":false},"from":"system.adapter.semp.0","user":"system.user.admin","ts":1678541192445,"_id":"semp.0.Devices.newDevice0.RecommendedState","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}} for Devices.newDevice0.RecommendedState
                  2023-03-11 14:33:47.649 - debug: semp.0 (4472) newDevice0 got object {"type":"state","common":{"name":"last time recommendation changed","type":"string","role":"value.time","read":true,"write":false},"from":"system.adapter.semp.0","user":"system.user.admin","ts":1678541192499,"_id":"semp.0.Devices.newDevice0.Changed","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}} for Devices.newDevice0.Changed
                  2023-03-11 14:33:47.650 - debug: semp.0 (4472) newDevice0 got object {"type":"state","common":{"name":"current State","type":"string","role":"state","read":true,"write":false},"from":"system.adapter.semp.0","user":"system.user.admin","ts":1678541192505,"_id":"semp.0.Devices.newDevice0.State","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}} for Devices.newDevice0.State
                  2023-03-11 14:33:47.652 - debug: semp.0 (4472) newDevice0 got object {"type":"state","common":{"name":"Energy used","type":"number","unit":"Wh","role":"value","read":true,"write":false},"from":"system.adapter.semp.0","user":"system.user.admin","ts":1678541192509,"_id":"semp.0.Devices.newDevice0.Energy","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}} for Devices.newDevice0.Energy
                  2023-03-11 14:33:47.655 - debug: semp.0 (4472) subscribe OID_Power 0_userdata.0.DEVICES.ECENTRALHEATING_P
                  2023-03-11 14:33:47.657 - debug: semp.0 (4472) newDevice0 setLastPower 33 number AlwaysOn W
                  2023-03-11 14:33:47.681 - debug: semp.0 (4472) newDevice0 got {"val":"on","ack":true,"ts":1678541192446,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1678541192446} from Devices.newDevice0.State
                  2023-03-11 14:33:50.632 - debug: semp.0 (4472) SHM requested description
                  2023-03-11 14:33:50.632 - info: semp.0 (4472) adapter discovered by SHM
                  2023-03-11 14:33:56.466 - debug: semp.0 (4472) SHM requested all devices. /semp/ ::ffff:192.168.0.49 http
                  2023-03-11 14:33:56.466 - debug: semp.0 (4472) get all devices
                  2023-03-11 14:33:56.467 - debug: semp.0 (4472) get all devices [{"deviceInfo":{"Identification":{"DeviceId":"F-12345678-123456789012-12","DeviceName":"newDevice0","DeviceType":"Dryer","DeviceSerial":"1234","DeviceVendor":"ACME"},"Characteristics":{"MaxPowerConsumption":"1000"},"Capabilities":{"CurrentPower":{"Method":"Measurement"},"Timestamps":{"AbsoluteTimestamps":false},"Interruptions":{"InterruptionsAllowed":false},"Requests":{"OptionalEnergy":false}}},"deviceStatus":{"DeviceId":"F-12345678-123456789012-12","EMSignalsAccepted":true,"Status":"On","PowerConsumption":{"PowerInfo":[{"AveragePower":33,"Timestamp":0,"AveragingInterval":60}]}},"planningRequest":{"Timeframe":[]}}]
                  2023-03-11 14:33:56.469 - debug: semp.0 (4472) response xml
                  newDevice0
                  Dryer
                  1234
                  ACME
                  1000
                  Measurement
                  false
                  false
                  false
                  true
                  On
                  33
                  2023-03-11 14:33:56.470 - debug: semp.0 (4472) response sent
                  2023-03-11 14:33:56.627 - debug: semp.0 (4472) SHM requested all devices. /semp/ ::ffff:192.168.0.49 http
                  2023-03-11 14:33:56.627 - debug: semp.0 (4472) get all devices
                  2023-03-11 14:33:56.627 - debug: semp.0 (4472) get all devices [{"deviceInfo":{"Identification":{"DeviceId":"F-12345678-123456789012-12","DeviceName":"newDevice0","DeviceType":"Dryer","DeviceSerial":"1234","DeviceVendor":"ACME"},"Characteristics":{"MaxPowerConsumption":"1000"},"Capabilities":{"CurrentPower":{"Method":"Measurement"},"Timestamps":{"AbsoluteTimestamps":false},"Interruptions":{"InterruptionsAllowed":false},"Requests":{"OptionalEnergy":false}}},"deviceStatus":{"DeviceId":"F-12345678-123456789012-12","EMSignalsAccepted":true,"Status":"On","PowerConsumption":{"PowerInfo":[{"AveragePower":33,"Timestamp":0,"AveragingInterval":60}]}},"planningRequest":{"Timeframe":[]}}]
                  2023-03-11 14:33:56.628 - debug: semp.0 (4472) response xml
                  newDevice0
                  Dryer
                  1234
                  ACME
                  1000
                  Measurement
                  false
                  false
                  false
                  true
                  On
                  33
                  2023-03-11 14:33:56.629 - debug: semp.0 (4472) response sent
                  2023-03-11 14:33:56.727 - debug: semp.0 (4472) SHM requested all devices. /semp/ ::ffff:192.168.0.49 http
                  2023-03-11 14:33:56.727 - debug: semp.0 (4472) get all devices
                  2023-03-11 14:33:56.727 - debug: semp.0 (4472) get all devices [{"deviceInfo":{"Identification":{"DeviceId":"F-12345678-123456789012-12","DeviceName":"newDevice0","DeviceType":"Dryer","DeviceSerial":"1234","DeviceVendor":"ACME"},"Characteristics":{"MaxPowerConsumption":"1000"},"Capabilities":{"CurrentPower":{"Method":"Measurement"},"Timestamps":{"AbsoluteTimestamps":false},"Interruptions":{"InterruptionsAllowed":false},"Requests":{"OptionalEnergy":false}}},"deviceStatus":{"DeviceId":"F-12345678-123456789012-12","EMSignalsAccepted":true,"Status":"On","PowerConsumption":{"PowerInfo":[{"AveragePower":33,"Timestamp":0,"AveragingInterval":60}]}},"planningRequest":{"Timeframe":[]}}]
                  2023-03-11 14:33:56.728 - debug: semp.0 (4472) response xml
                  newDevice0
                  Dryer
                  1234
                  ACME
                  1000
                  Measurement
                  false
                  false
                  false
                  true
                  On
                  33
                  2023-03-11 14:33:56.728 - debug: semp.0 (4472) response sent
                  2023-03-11 14:34:00.048 - debug: semp.0 (4472) newDevice0 setLastPower 33 number AlwaysOn W
                  2023-03-11 14:34:00.048 - debug: semp.0 (4472) newDevice0 calc energy 33 1678541627657 = 0.11358416666666667Wh
                  2023-03-11 14:34:07.617 - debug: semp.0 (4472) SHM requested description
                  2023-03-11 14:34:15.008 - debug: semp.0 (4472) newDevice0 setLastPower 33 number AlwaysOn W
                  2023-03-11 14:34:15.008 - debug: semp.0 (4472) newDevice0 calc energy 33 1678541640048 = 0.2507175Wh
                  2023-03-11 14:34:27.620 - debug: semp.0 (4472) SHM requested description
                  2023-03-11 14:34:30.026 - debug: semp.0 (4472) newDevice0 setLastPower 33 number AlwaysOn W
                  2023-03-11 14:34:30.027 - debug: semp.0 (4472) newDevice0 calc energy 33 1678541655008 = 0.3883916666666667Wh
                  2023-03-11 14:34:41.757 - debug: semp.0 (4472) SHM requested description
                  2023-03-11 14:34:41.795 - debug: semp.0 (4472) SHM requested description
                  2023-03-11 14:34:45.008 - debug: semp.0 (4472) newDevice0 setLastPower 33 number AlwaysOn W
                  2023-03-11 14:34:45.008 - debug: semp.0 (4472) newDevice0 calc energy 33 1678541670027 = 0.5257175000000001Wh
                  2023-03-11 14:34:47.615 - debug: semp.0 (4472) SHM requested description
                  2023-03-11 14:34:56.905 - debug: semp.0 (4472) SHM requested all devices. /semp/ ::ffff:192.168.0.49 http
                  2023-03-11 14:34:56.905 - debug: semp.0 (4472) get all devices
                  2023-03-11 14:34:56.906 - debug: semp.0 (4472) get all devices [{"deviceInfo":{"Identification":{"DeviceId":"F-12345678-123456789012-12","DeviceName":"newDevice0","DeviceType":"Dryer","DeviceSerial":"1234","DeviceVendor":"ACME"},"Characteristics":{"MaxPowerConsumption":"1000"},"Capabilities":{"CurrentPower":{"Method":"Measurement"},"Timestamps":{"AbsoluteTimestamps":false},"Interruptions":{"InterruptionsAllowed":false},"Requests":{"OptionalEnergy":false}}},"deviceStatus":{"DeviceId":"F-12345678-123456789012-12","EMSignalsAccepted":true,"Status":"On","PowerConsumption":{"PowerInfo":[{"AveragePower":33,"Timestamp":0,"AveragingInterval":60}]}},"planningRequest":{"Timeframe":[]}}]
                  2023-03-11 14:34:56.907 - debug: semp.0 (4472) response xml
                  newDevice0
                  Dryer
                  1234
                  ACME
                  1000
                  Measurement
                  false
                  false
                  false
                  true
                  On
                  33
                  2023-03-11 14:34:56.909 - debug: semp.0 (4472) response sent
                  2023-03-11 14:34:57.093 - debug: semp.0 (4472) SHM requested all devices. /semp/ ::ffff:192.168.0.49 http
                  2023-03-11 14:34:57.093 - debug: semp.0 (4472) get all devices
                  2023-03-11 14:34:57.094 - debug: semp.0 (4472) get all devices [{"deviceInfo":{"Identification":{"DeviceId":"F-12345678-123456789012-12","DeviceName":"newDevice0","DeviceType":"Dryer","DeviceSerial":"1234","DeviceVendor":"ACME"},"Characteristics":{"MaxPowerConsumption":"1000"},"Capabilities":{"CurrentPower":{"Method":"Measurement"},"Timestamps":{"AbsoluteTimestamps":false},"Interruptions":{"InterruptionsAllowed":false},"Requests":{"OptionalEnergy":false}}},"deviceStatus":{"DeviceId":"F-12345678-123456789012-12","EMSignalsAccepted":true,"Status":"On","PowerConsumption":{"PowerInfo":[{"AveragePower":33,"Timestamp":0,"AveragingInterval":60}]}},"planningRequest":{"Timeframe":[]}}]
                  2023-03-11 14:34:57.094 - debug: semp.0 (4472) response xml
                  newDevice0
                  Dryer
                  1234
                  ACME
                  1000
                  Measurement
                  false
                  false
                  false
                  true
                  On
                  33
                  2023-03-11 14:34:57.095 - debug: semp.0 (4472) response sent
                  2023-03-11 14:34:57.185 - debug: semp.0 (4472) SHM requested all devices. /semp/ ::ffff:192.168.0.49 http
                  2023-03-11 14:34:57.186 - debug: semp.0 (4472) get all devices
                  2023-03-11 14:34:57.186 - debug: semp.0 (4472) get all devices [{"deviceInfo":{"Identification":{"DeviceId":"F-12345678-123456789012-12","DeviceName":"newDevice0","DeviceType":"Dryer","DeviceSerial":"1234","DeviceVendor":"ACME"},"Characteristics":{"MaxPowerConsumption":"1000"},"Capabilities":{"CurrentPower":{"Method":"Measurement"},"Timestamps":{"AbsoluteTimestamps":false},"Interruptions":{"InterruptionsAllowed":false},"Requests":{"OptionalEnergy":false}}},"deviceStatus":{"DeviceId":"F-12345678-123456789012-12","EMSignalsAccepted":true,"Status":"On","PowerConsumption":{"PowerInfo":[{"AveragePower":33,"Timestamp":0,"AveragingInterval":60}]}},"planningRequest":{"Timeframe":[]}}]
                  2023-03-11 14:34:57.186 - debug: semp.0 (4472) response xml
                  newDevice0
                  Dryer
                  1234
                  ACME
                  1000
                  Measurement
                  false
                  false
                  false
                  true
                  On
                  33
                  2023-03-11 14:34:57.187 - debug: semp.0 (4472) response sent
                  2023-03-11 14:35:00.013 - debug: semp.0 (4472) newDevice0 setLastPower 33 number AlwaysOn W
                  2023-03-11 14:35:00.014 - debug: semp.0 (4472) newDevice0 calc energy 33 1678541685008 = 0.6632633333333334Wh
                  C 1 Antwort Letzte Antwort
                  • W Webwanze
                    @rene_hm
                    newDevice0
                    Dryer
                    1234
                    ACME
                    1000
                    Measurement
                    false
                    false
                    false
                    true
                    On
                    33
                    newDevice0
                    Dryer
                    1234
                    ACME
                    1000
                    Measurement
                    false
                    false
                    false
                    true
                    On
                    33
                    newDevice0
                    Dryer
                    1234
                    ACME
                    1000
                    Measurement
                    false
                    false
                    false
                    true
                    On
                    33
                    newDevice0
                    Dryer
                    1234
                    ACME
                    1000
                    Measurement
                    false
                    false
                    false
                    true
                    On
                    33
                    newDevice0
                    Dryer
                    1234
                    ACME
                    1000
                    Measurement
                    false
                    false
                    false
                    true
                    On
                    33
                    newDevice0
                    Dryer
                    1234
                    ACME
                    1000
                    Measurement
                    false
                    false
                    false
                    true
                    On
                    33
                    C
                    C
                    cb187
                    #159
                    Nutzt hier noch keiner die PV Überschussladen Funktion mit automatischer Phasenumschaltung?
                    • C cb187
                      C
                      C
                      cb187
                      #160
                      Hab jetzt mal zwei Wallbox hinzugefügt, schade er lässt nicht beide gleichzeitig laden und teilt sich das auf.Schaltet nur zwischen beiden Boxen immer um.
                      • C cb187
                        Rene_HMR
                        Rene_HMR
                        Rene_HM
                        #161
                        @cb187 reicht PV - Leistung nicht für beide?
                        • Rene_HMR Rene_HM
                          C
                          C
                          cb187
                          #162
                          @rene_hm für beide hätte es gereicht wenn es aufgeteilt wäre.Aber ka wie sma das handhabt bzw ist die frage ob das bei den überhaupt geht.
                          • C cb187
                            C
                            C
                            cb187
                            #163
                            @Rene_HM Was ich nicht verstehe beobachte ich gerade wieder wenn zb die WP eingeplant ist und genügend PV Überschusss da ist bricht immer Wallbox nach kurzer Zeit ab.Wenn die nicht existiert dann funzt das top.Ich glaub wir müssen uns mal über anydesk verbinden.Damit du da mal life siehst und besser interpretieren kannst.
                            • C cb187
                              C
                              C
                              cb187
                              #164
                              Besser machts der Evcc usw auch nicht.
                              • B
                                B
                                beender
                                #165
                                ich verstehe das Verhalten von dem Plugin oder SMA nicht, oder ich habe etwas komplett falsch konfiguriert.
                                Aktuell habe ich einen Überschuss von ca. 6000W und die Empfehlung vom Home Manager sind 0 W:
                                Ich versuche damit meine Wallbox zu steuern. Für eine halbe Stunde hat diese auch geladen, dann wurde diese gestoppt.
                                Die Wallbox ist recht minimal konfiguriert:
                                Philipp
                                • B beender
                                  Philipp
                                  C
                                  C
                                  cb187
                                  schrieb am zuletzt editiert von cb187
                                  #166
                                  @beender hey stell mal min energy und max energy auf 0 ein.Und dann sollte reiner PV Überschuss direkt gehen.
                                  Wenn du ne 11kw Wallbox hast solltest du dann auch bei max power 11020 einstellen.Bildschirm­foto 2023-04-03 um 12.00.18.png Bildschirm­foto 2023-04-03 um 12.00.47.png
                                  beim go musste ich noch drei script hinzufügen.
                                  • C cb187
                                    B
                                    B
                                    beender
                                    schrieb am zuletzt editiert von beender
                                    #167
                                    @cb187
                                    Ich habe noch eine Vermutung. Ich lese die Daten per Modbus von meiner ABB Terra AC aus, bekomme aber gefühlt nicht den korrekten State für "Plug Connected" raus. Das ist vermutlich auch der Grund für den Abbruch.
                                    Die 3800 W sind eher auf mein Hybrid-Auto bezogen, da dieses nur 1-phasig laden kann. Ich habe es trotzdem mal auf die 11kW gesetzt.
                                    Ich werde noch probieren den Plug Connected Status konstant auf true zu setzen. Von mir aus kann der SHM die Wallbox dauerhaft überwachen / kontrollieren. Vermutlich geht das meiste eh über die genutzte Charge Power.
                                    • B beender
                                      @cb187
                                      C
                                      C
                                      cb187
                                      #168
                                      Ok probier mal aus.ist ja schnell gemacht plug connect zuerstellen.
                                      @beender said in Adapter: SMA SEMP:
                                      @cb187
                                      • Rene_HMR
                                        Rene_HMR
                                        Rene_HM
                                        #169
                                        Ich habe die Version 1.2.0 des Adapters released.
                                        Folgende Änderungen sind enthalten:
                                        • man kann eine URL anstatt eines einfachen Datenpunktes für die Konfiguration der Schnittstelle der wallbox verwenden
                                        • bug fix: ein Gerät, welches aufgrund einer Energeianforderung durch den SHM eingeschaltet wird, wird am Ende der maximalen Einschaltdauer oder am Ende des timeframes automatisch ausgeschaltet. Die Optio diesbezüglich wurde entfernt
                                        • arteckA
                                          arteckA
                                          arteck
                                          #170
                                          @rene_hm
                                          bei mir will der Adapter auch nicht so ganz
                                          seh ich aber bekomme keine Geräte geladen auf der Übersicht...
                                          der response sieht eigentlich gut aus würde ich sagen..
                                          <?xml version="1.0" encoding="utf-8"?> <Device2EM xmlns="http://www.sma.de/communication/schema/SEMP/v1"> <DeviceInfo> <Identification> <DeviceId>F-7.442202-000000000001-00</DeviceId> <DeviceName>Waschmaschiene</DeviceName> <DeviceType>WashingMachine</DeviceType> <DeviceSerial>111111111111</DeviceSerial> <DeviceVendor>Siemens</DeviceVendor> </Identification> <Characteristics> <MaxPowerConsumption>3500</MaxPowerConsumption> </Characteristics> <Capabilities> <CurrentPower> <Method>Measurement</Method> </CurrentPower> <Timestamps> <AbsoluteTimestamps>false</AbsoluteTimestamps> </Timestamps> <Interruptions> <InterruptionsAllowed>false</InterruptionsAllowed> </Interruptions> <Requests> <OptionalEnergy>false</OptionalEnergy> </Requests> </Capabilities> </DeviceInfo> <DeviceInfo> <Identification> <DeviceId>F-7.442202-000000000002-00</DeviceId> <DeviceName>Hundi-Waschmaschiene</DeviceName> <DeviceType>WashingMachine</DeviceType> <DeviceSerial>2222222222</DeviceSerial> <DeviceVendor>Samsung</DeviceVendor> </Identification> <Characteristics> <MaxPowerConsumption>3500</MaxPowerConsumption> </Characteristics> <Capabilities> <CurrentPower> <Method>Measurement</Method> </CurrentPower> <Timestamps> <AbsoluteTimestamps>false</AbsoluteTimestamps> </Timestamps> <Interruptions> <InterruptionsAllowed>false</InterruptionsAllowed> </Interruptions> <Requests> <OptionalEnergy>false</OptionalEnergy> </Requests> </Capabilities> </DeviceInfo> <DeviceStatus> <DeviceId>F-7.442202-000000000001-00</DeviceId> <EMSignalsAccepted>true</EMSignalsAccepted> <Status>On</Status> <PowerConsumption> <PowerInfo> <AveragePower>0</AveragePower> <Timestamp>0</Timestamp> <AveragingInterval>60</AveragingInterval> </PowerInfo> </PowerConsumption> </DeviceStatus> <DeviceStatus> <DeviceId>F-7.442202-000000000002-00</DeviceId> <EMSignalsAccepted>true</EMSignalsAccepted> <Status>On</Status> <PowerConsumption> <PowerInfo> <AveragePower>0</AveragePower> <Timestamp>0</Timestamp> <AveragingInterval>60</AveragingInterval> </PowerInfo> </PowerConsumption> </DeviceStatus> </Device2EM>
                                          ausserdem bekomme ich die csv nicht geschrieben..
                                          mit welchen rechten versuchst du die zu schreiben
                                          master semp.0: exception in WriteCSVLog [Error: ENOENT: no such file or directory, open '']
                                          04 Jun 2023 19:47:11.466
                                           master semp.0: exception in CreateFilename [Error: ENOENT: no such file or directory, stat 'home/iobroker/semp.csv']
                                          egal welchen Ordner ich nehme..
                                          04 Jun 2023 19:48:03.482
                                          04 Jun 2023 19:48:03.286
                                          04 Jun 2023 19:48:03.261
                                          master semp.0: exception in CreateFilename [Error: ENOENT: no such file or directory, stat '/home/iobroker/javascript/semp.csv']
                                          hier /home/iobroker/javascript darf der iobroker user 100% schreiben da ich eine kopie meiner Script da ablege ..
                                          83.9k
