  3. Einsteigerfragen
  4. Einbindung von Geräten
  5. Adapter für Ecoflow Einbindung
212 Beiträge 42 Kommentatoren 113.2k Aufrufe 41 Beobachtet
  • M mattenausohz
    Hallo! Ich bekomme neuerdings folgendes, ca. 10 Sekunden nach dem "subscribe" der Topics:
    Disconnected from mqtt.ecoflow.com: undefined
    Log:
    mqtt.1
    2023-02-06 11:08:59.891 info Disconnected from mqtt.ecoflow.com: undefined
    mqtt.1
    2023-02-06 11:08:49.506 info All states published
    mqtt.1
    2023-02-06 11:08:49.495 info Subscribe on "/app/15707484745384XXXXX/R331ZEB4ZE8XXXXX/thing/property/get"
    mqtt.1
    2023-02-06 11:08:49.494 info Subscribe on "/app/15707484745384XXXXX/R331ZEB4ZE8XXXX/thing/property/set"
    mqtt.1
    2023-02-06 11:08:49.493 info Subscribe on "/app/device/property/R331ZEB4ZEXXXXX"
    mqtt.1
    2023-02-06 11:08:49.492 info Subscribe on "#"
    mqtt.1
    2023-02-06 11:08:49.491 info Connected to mqtt.ecoflow.com
    mqtt.1
    2023-02-06 11:08:49.038 info Reconnected to mqtt.ecoflow.com
    mqtt.1
    2023-02-06 11:08:39.038 info Disconnected from mqtt.ecoflow.com: undefined
    mqtt.1
    2023-02-06 11:08:28.608 info All states published
    mqtt.1
    2023-02-06 11:08:28.580 info Subscribe on "/app/1570748474538XXXXX/R331ZEB4ZEXXXXX/thing/property/get"
    mqtt.1
    2023-02-06 11:08:28.579 info Subscribe on "/app/1570748474538XXXXX/R331ZEB4ZEXXXXX/thing/property/set"
    mqtt.1
    2023-02-06 11:08:28.577 info Subscribe on "/app/device/property/R331ZEB4ZE8XXXXX"
    mqtt.1
    2023-02-06 11:08:28.572 info Subscribe on "#"
    mqtt.1
    2023-02-06 11:08:28.569 info Connected to mqtt.ecoflow.com
    mqtt.1
    2023-02-06 11:08:27.931 info Try to connect to mqtts://mqtt.ecoflow.com:8883 with clientId=mqtt.mqtt.1and credentials app-632768efb1f54b13a8c719ed98xxxxx:*******************
    mqtt.1
    2023-02-06 11:08:27.363 info starting. Version 4.0.7 in /opt/iobroker/node_modules/iobroker.mqtt, node: v18.6.0, js-controller: 4.0.24
    Kann mir jemand etwas dazu sagen?
    Matthias
    Ivan AndricI
    Ivan AndricI
    Ivan Andric
    schrieb am zuletzt editiert von Ivan Andric
    @mattenausohz
    Ich habe das identische Verhalten. Habe mich jetzt mit dem MQTT Explorer statt dem ioBroker verbunden und der meldet auch "Disconnected from server". Es scheint wohl an ecoflow zu liegen.
    • Ivan AndricI
      Ivan AndricI
      Ivan Andric
      Wird die user-id hier mit "app-xxx" eingetragen?
      /app/<userid>/R6XXXXXXXXXXXXXXX/thing/property/set
      Ich habe es mit und ohne versucht, sehe aber keine Nachrichten wenn ich etwas mit der APP ändere.
      (DELTA 2 und Android-App)
      • M
        M
        Maxtor62
        schrieb am zuletzt editiert von Maxtor62
        Same here,
        (Delta Max und iOS)
        Wer meint er ist was, hat aufgehört was zu werden
        • Ivan AndricI Ivan Andric
          @mattenausohz
          haus-automatisierungH
          @ivan-andric Läuft der EcoFlow denn durch und ist weiterhin per Wlan verbunden? Ich habe das seit Wochen laufen und keinen einzigen Verbindungsabbruch.
          📚 Meine Dokumentation
          • M Maxtor62
            Same here,
            (Delta Max und iOS)
            @maxtor62 Lustigerweise wurde ich nun auch rausgeworfen, nachdem ich meine Config hier geteilt habe.
            Wichtiger Hinweis: Bitte denkt euch eine eigene, eindeutige Client-ID aus! Nicht aus irgendwelchen Screenshots hier abschreiben.
            Der MQTT-Broker schließt wahrscheinlich die Verbindung zu bestehenden Clients mit der gleichen ID, wenn sich jemand mit der gleichen verbindet!! Die müssen eindeutig sein.
            M C 2 Antworten Letzte Antwort
              M
              M
              Maxtor62
              @haus-automatisierung
              zwischenzeitlich hat es es mal funktioniert (gestern), jetzt habe ich eine neue Firmware drauf, jetzt geht im Moment nix. Die ändern die API wie manche Leute die Unterwäsche😊 😊
              Mal weiter probieren.
              • F
                F
                firebowl
                schrieb am zuletzt editiert von firebowl
                Ok das mit der ID erklärt das disconnecten und die ständigen mqtt Anfragen am DNS Server. 😅
                Hat jemand das ganze mit ner Delta 2 zum laufen bekommen?
                Ich kann mit @haus-automatisierung Script zwar die Werte abfragen und auch teilweise ändern aber scheinbar kann die Delta 2 kein pausieren beim Laden und weniger als 100Watt gehen auch nicht. Somit klappt das Überschussladen leider nicht. 😭
                  C
                  C
                  chka
                  @haus-automatisierung sagte in Adapter für Ecoflow Einbindung:
                  Was verstehst du unter client id? bei mir bricht die verbindung auch dauernd ab und wird neu aufgebaut.
                  ich habe in allen Skripten und im Adapter immer meine eigenen userID tokens usw genommen.
                  bei mir wird unter Objekte leider auch kein Eintrag gesetzt
                  INTEL NUC BOXNUC6I3SYH i3-6100U - Proxmox
                  Speicher: Transcend MTS800 M.2 SSD 128GB SATA III, MLC
                  RAM: 40Gig Crucial 8GB DDR4 CT2K8G4SFS824A + 32GB DDR4CT32G4SFD8266
                  F 1 Antwort Letzte Antwort
                  • C chka
                    F
                    F
                    firebowl
                    @chka sagte in Adapter für Ecoflow Einbindung:
                    Im MQTT Adapter gibts ein Feld für Client ID. Ist per default glaub leer. Da denkst dir was aus und trägst es ein, dann sollte es keine disconnects mehr geben.
                    C 1 Antwort Letzte Antwort
                    • F firebowl
                      C
                      C
                      chka
                      #66
                      @firebowl top danke jetzt setzt er auch die eintrage DANKE
                      • L
                        L
                        Loxoner86
                        #67
                        Einfach cool was hier bisher möglich gemacht wurde um die Ecoflow per ioBroker zu steuern. Ich habe die Daten nun im ioBroker und kann zum Beispiel die Ladung pausieren, drosseln etc.
                        Jedoch kriege ich es nicht hin den AC Out (Schuko) zu schalten hat jemand einen Tip für mich ?
                        Zusätzlich möchte ich wissen ob es bei verbundener Einspeisung der Ecoflow (230V AC) möglich ist per Software die Entladung zu erzwingen ohne mittels myStrom oder Shelly die Einspeisung physisch zu trennen ?
                        • L Loxoner86
                          C
                          C
                          chka
                          #68
                          @loxoner86
                          abgebildet wird er über inv.cfgAcEnabled, wie man den schaltet bin ich noch am versuchen
                          • G
                            G
                            g.polat
                            #69
                            Der Hinweis mit der Client-ID war Goldrichtig, jetzt funzt es auch bei mir, vielen Dank.
                            Kann bitte nochmal jemand für dummy's erklären wie wie genau die Schaltbefehle abgesetzt werden. Am besten mit einem Beispiel. Besten Dank.
                            • G g.polat
                              #70
                              @g-polat sagte in Adapter für Ecoflow Einbindung:
                              Es wird ein JSON-String auf dem entsprechenden Topic gepublished. Wie genau der Playload aussehen muss, findet man am besten raus, wenn man das /set topic abonniert und dann guckt, was die App macht.
                              Genauer als hier kann ich es auch nicht erklären: https://www.youtube.com/watch?v=ezn0NDc9GAY
                                C
                                C
                                chka
                                #71
                                Wieder ein Stück weiter, setzt man in der /Set folgendes schaltet er den Ausgang an.
                                Jetzt muss es noch in das Script rein.
                                enable = 1 AN
                                enable = 0 AUS
                                  "params": {
                                    "enabled": 1,
                                    "out_freq": 255,
                                    "out_voltage": 4294967295,
                                    "xboost": 255
                                  "from": "iOS",
                                  "lang": "de-de",
                                  "id": "232050124",
                                  "moduleSn": "R6XXXXX",
                                  "moduleType": 5,
                                  "operateType": "acOutCfg",
                                  "version": "1.0"
                                • C chka
                                  enable = 1 AN
                                  enable = 0 AUS
                                    "params": {
                                      "enabled": 1,
                                      "out_freq": 255,
                                      "xboost": 255
                                    "from": "iOS",
                                    "lang": "de-de",
                                    "id": "232050124",
                                    "moduleType": 5,
                                    "version": "1.0"
                                  #72
                                  @chka Das ist doch aber 1:1 das, was ich im Blog-Beitrag dokumentiert hatte und schon im Script bereitgestellt habe?
                                  https://haus-automatisierung.com/hardware/2023/02/13/ecoflow-river-2-usv-batteriespeicher.html
                                    C
                                    C
                                    chka
                                    #73
                                    @haus-automatisierung ja das habe ich eben auch gesehen. Es wird im script nie genutzt, oder stehe ich auf dem schlauch
                                    Bin aktuell ein Stück weiter; habe noch inv.cfgAcEnabled zu den changeableStates hinzugefügt
                                    const changeableStates = [
                                      'mppt.cfgChgWatts',
                                      'mppt.chgPauseFlag',
                                      'bms_emsStatus.maxChargeSoc',
                                      'bms_emsStatus.minDsgSoc',
                                      'inv.cfgAcEnabled'
                                    des Weiteren in Zeile 81 noch folgendes hinzugefügt:
                                    on({ id: `${prefix}.inv.cfgAcEnabled`, change: 'ne', ack: false }, async (obj) => {
                                      const newVal = obj.state.val;
                                        if (newVal >= 0 && newVal <= 1) {
                                        setAcOutput(newVal);
                                        await setStateAsync(obj.id, { val: obj.state.val, ack: true });
                                    Geschaltet wird es, aktuell aktualisiert sich der Wert von inv.cfgAcEnabled nur noch nicht.
                                    • C chka
                                        'mppt.cfgChgWatts',
                                        'inv.cfgAcEnabled'
                                      #74
                                      @chka Sieht doch richtig aus. Was fehlt Dir? Der neue Wert wird ja im Script bestätigt.
                                        C
                                        C
                                        chka
                                        #75
                                        @haus-automatisierung er hat wieso auch immer den wert nicht übernommen, obwohl geschaltet wurde. aktuell geht es. Danke dir
                                        • G
                                          G
                                          g.polat
                                          #76
                                          Vielen Dank, jetzt habe ich es hinbekommen, einziges Problem noch, das Script steigt aus, zu viele Aufrufe :-(
                                          08:06:14.076	error	javascript.0 (9315) Script script.js.common.Ecoflow.sendtomqtt is calling setState more than 1000 times per minute! Stopping Script now! Please check your script!
                                          08:06:14.076	info	javascript.0 (9315) Stop script script.js.common.Ecoflow.sendtomqtt
                                          Cron greift irgendwie nicht :
                                          '*/1 * * * *'
                                          const mqttInstance = 'mqtt.0';
                                          const serialNumber = 'R33XXXXXXXXXX';
                                          const userId = '15XXXXXXXXXXXXXXXXXX';
                                          const prefix = '0_userdata.0.EcoFlow.MQTT-Client.R33XXXXXXXXXX';
                                          const valueCache = {};
                                            'mppt.cfgChgWatts',
                                            'inv.cfgAcEnabled',
                                            'pd.carState'
                                          33.2k
                                          84.3k
