  3. Einsteigerfragen
  4. Einbindung von Geräten
  5. Adapter für Ecoflow Einbindung
    apollon77A
212 Beiträge 42 Kommentatoren 97.4k Aufrufe 41 Beobachtet
  • M mattenausohz
    Hallo! Ich bekomme neuerdings folgendes, ca. 10 Sekunden nach dem "subscribe" der Topics:
    Disconnected from mqtt.ecoflow.com: undefined
    Log:
    mqtt.1
    2023-02-06 11:08:59.891 info Disconnected from mqtt.ecoflow.com: undefined
    mqtt.1
    2023-02-06 11:08:49.506 info All states published
    mqtt.1
    2023-02-06 11:08:49.495 info Subscribe on "/app/15707484745384XXXXX/R331ZEB4ZE8XXXXX/thing/property/get"
    mqtt.1
    2023-02-06 11:08:49.494 info Subscribe on "/app/15707484745384XXXXX/R331ZEB4ZE8XXXX/thing/property/set"
    mqtt.1
    2023-02-06 11:08:49.493 info Subscribe on "/app/device/property/R331ZEB4ZEXXXXX"
    mqtt.1
    2023-02-06 11:08:49.492 info Subscribe on "#"
    mqtt.1
    2023-02-06 11:08:49.491 info Connected to mqtt.ecoflow.com
    mqtt.1
    2023-02-06 11:08:49.038 info Reconnected to mqtt.ecoflow.com
    mqtt.1
    2023-02-06 11:08:39.038 info Disconnected from mqtt.ecoflow.com: undefined
    mqtt.1
    2023-02-06 11:08:28.608 info All states published
    mqtt.1
    2023-02-06 11:08:28.580 info Subscribe on "/app/1570748474538XXXXX/R331ZEB4ZEXXXXX/thing/property/get"
    mqtt.1
    2023-02-06 11:08:28.579 info Subscribe on "/app/1570748474538XXXXX/R331ZEB4ZEXXXXX/thing/property/set"
    mqtt.1
    2023-02-06 11:08:28.577 info Subscribe on "/app/device/property/R331ZEB4ZE8XXXXX"
    mqtt.1
    2023-02-06 11:08:28.572 info Subscribe on "#"
    mqtt.1
    2023-02-06 11:08:28.569 info Connected to mqtt.ecoflow.com
    mqtt.1
    2023-02-06 11:08:27.931 info Try to connect to mqtts://mqtt.ecoflow.com:8883 with clientId=mqtt.mqtt.1and credentials app-632768efb1f54b13a8c719ed98xxxxx:*******************
    mqtt.1
    2023-02-06 11:08:27.363 info starting. Version 4.0.7 in /opt/iobroker/node_modules/iobroker.mqtt, node: v18.6.0, js-controller: 4.0.24
    Kann mir jemand etwas dazu sagen?
    Matthias
    G
    G
    g.polat
    @mattenausohz sagte in Adapter für Ecoflow Einbindung:
    Log:
    mqtt.1
    mqtt.1
    mqtt.1
    mqtt.1
    mqtt.1
    mqtt.1
    mqtt.1
    mqtt.1
    mqtt.1
    mqtt.1
    mqtt.1
    mqtt.1
    mqtt.1
    mqtt.1
    mqtt.1
    mqtt.1
    mqtt.1
    Matthias
    Konntest Du das Problem lösen, habe das gleiche Problem hier :-(
    M haus-automatisierungH 2 Antworten Letzte Antwort
    • G g.polat
      Log:
      mqtt.1
      mqtt.1
      mqtt.1
      mqtt.1
      mqtt.1
      mqtt.1
      mqtt.1
      mqtt.1
      mqtt.1
      mqtt.1
      mqtt.1
      mqtt.1
      mqtt.1
      mqtt.1
      mqtt.1
      mqtt.1
      mqtt.1
      Matthias
      M
      M
      mattenausohz
      @g-polat Hallo! Nein, es hat sich niemand dazu gemeldet leider.
      • G g.polat
        Log:
        mqtt.1
        mqtt.1
        mqtt.1
        mqtt.1
        mqtt.1
        mqtt.1
        mqtt.1
        mqtt.1
        mqtt.1
        mqtt.1
        mqtt.1
        mqtt.1
        mqtt.1
        mqtt.1
        mqtt.1
        mqtt.1
        mqtt.1
        Matthias
        @g-polat Ich würde mal das Subscribe für die Wildcard # rausnehmen.
        Generell habe ich mich jetzt recht lange mit der River 2 Pro beschäftigt und nutze diese z.B. zum Überschuss-Laden der PV-Anlage (zu einem Teil). Alle Details habe ich hier dokumentiert:
        https://haus-automatisierung.com/hardware/2023/02/13/ecoflow-river-2-usv-batteriespeicher.html
        📚 Meine Dokumentation
        G 1 Antwort Letzte Antwort
          G
          G
          g.polat
          @haus-automatisierung sagte in Adapter für Ecoflow Einbindung:
          welche Wildecard meinst Du?
          GP
          • G g.polat
            GP
            @g-polat sagte in Adapter für Ecoflow Einbindung:
            Diese:
            mqtt.1
            Aber war ja nicht dein Log.
            Hier noch meine Einstellungen
            • M mattenausohz
              Log:
              mqtt.1
              mqtt.1
              mqtt.1
              mqtt.1
              mqtt.1
              mqtt.1
              mqtt.1
              mqtt.1
              mqtt.1
              mqtt.1
              mqtt.1
              mqtt.1
              mqtt.1
              mqtt.1
              mqtt.1
              mqtt.1
              mqtt.1
              Matthias
              Ivan AndricI
              Ivan AndricI
              Ivan Andric
              schrieb am zuletzt editiert von Ivan Andric
              @mattenausohz
              Ich habe das identische Verhalten. Habe mich jetzt mit dem MQTT Explorer statt dem ioBroker verbunden und der meldet auch "Disconnected from server". Es scheint wohl an ecoflow zu liegen.
              • Ivan AndricI
                Ivan AndricI
                Ivan Andric
                Wird die user-id hier mit "app-xxx" eingetragen?
                /app/<userid>/R6XXXXXXXXXXXXXXX/thing/property/set
                Ich habe es mit und ohne versucht, sehe aber keine Nachrichten wenn ich etwas mit der APP ändere.
                (DELTA 2 und Android-App)
                • M
                  M
                  Maxtor62
                  schrieb am zuletzt editiert von Maxtor62
                  Same here,
                  (Delta Max und iOS)
                  Wer meint er ist was, hat aufgehört was zu werden
                  • Ivan AndricI Ivan Andric
                    @mattenausohz
                    @ivan-andric Läuft der EcoFlow denn durch und ist weiterhin per Wlan verbunden? Ich habe das seit Wochen laufen und keinen einzigen Verbindungsabbruch.
                    • M Maxtor62
                      Same here,
                      (Delta Max und iOS)
                      @maxtor62 Lustigerweise wurde ich nun auch rausgeworfen, nachdem ich meine Config hier geteilt habe.
                      Wichtiger Hinweis: Bitte denkt euch eine eigene, eindeutige Client-ID aus! Nicht aus irgendwelchen Screenshots hier abschreiben.
                      Der MQTT-Broker schließt wahrscheinlich die Verbindung zu bestehenden Clients mit der gleichen ID, wenn sich jemand mit der gleichen verbindet!! Die müssen eindeutig sein.
                      M C 2 Antworten Letzte Antwort
                        M
                        M
                        Maxtor62
                        zwischenzeitlich hat es es mal funktioniert (gestern), jetzt habe ich eine neue Firmware drauf, jetzt geht im Moment nix. Die ändern die API wie manche Leute die Unterwäsche😊 😊
                        Mal weiter probieren.
                        • F
                          F
                          firebowl
                          schrieb am zuletzt editiert von firebowl
                          Ok das mit der ID erklärt das disconnecten und die ständigen mqtt Anfragen am DNS Server. 😅
                          Hat jemand das ganze mit ner Delta 2 zum laufen bekommen?
                          Ich kann mit @haus-automatisierung Script zwar die Werte abfragen und auch teilweise ändern aber scheinbar kann die Delta 2 kein pausieren beim Laden und weniger als 100Watt gehen auch nicht. Somit klappt das Überschussladen leider nicht. 😭
                            C
                            C
                            chka
                            Was verstehst du unter client id? bei mir bricht die verbindung auch dauernd ab und wird neu aufgebaut.
                            ich habe in allen Skripten und im Adapter immer meine eigenen userID tokens usw genommen.
                            bei mir wird unter Objekte leider auch kein Eintrag gesetzt
                            INTEL NUC BOXNUC6I3SYH i3-6100U - Proxmox
                            Speicher: Transcend MTS800 M.2 SSD 128GB SATA III, MLC
                            RAM: 40Gig Crucial 8GB DDR4 CT2K8G4SFS824A + 32GB DDR4CT32G4SFD8266
                            F 1 Antwort Letzte Antwort
                            • C chka
                              F
                              F
                              firebowl
                              @chka sagte in Adapter für Ecoflow Einbindung:
                              Im MQTT Adapter gibts ein Feld für Client ID. Ist per default glaub leer. Da denkst dir was aus und trägst es ein, dann sollte es keine disconnects mehr geben.
                              C 1 Antwort Letzte Antwort
                              • F firebowl
                                C
                                C
                                chka
                                #66
                                @firebowl top danke jetzt setzt er auch die eintrage DANKE
                                • L
                                  L
                                  Loxoner86
                                  #67
                                  Einfach cool was hier bisher möglich gemacht wurde um die Ecoflow per ioBroker zu steuern. Ich habe die Daten nun im ioBroker und kann zum Beispiel die Ladung pausieren, drosseln etc.
                                  Jedoch kriege ich es nicht hin den AC Out (Schuko) zu schalten hat jemand einen Tip für mich ?
                                  Zusätzlich möchte ich wissen ob es bei verbundener Einspeisung der Ecoflow (230V AC) möglich ist per Software die Entladung zu erzwingen ohne mittels myStrom oder Shelly die Einspeisung physisch zu trennen ?
                                  • L Loxoner86
                                    C
                                    C
                                    chka
                                    #68
                                    @loxoner86
                                    abgebildet wird er über inv.cfgAcEnabled, wie man den schaltet bin ich noch am versuchen
                                    • G
                                      G
                                      g.polat
                                      #69
                                      Der Hinweis mit der Client-ID war Goldrichtig, jetzt funzt es auch bei mir, vielen Dank.
                                      Kann bitte nochmal jemand für dummy's erklären wie wie genau die Schaltbefehle abgesetzt werden. Am besten mit einem Beispiel. Besten Dank.
                                      • G g.polat
                                        #70
                                        Es wird ein JSON-String auf dem entsprechenden Topic gepublished. Wie genau der Playload aussehen muss, findet man am besten raus, wenn man das /set topic abonniert und dann guckt, was die App macht.
                                        Genauer als hier kann ich es auch nicht erklären: https://www.youtube.com/watch?v=ezn0NDc9GAY
                                          C
                                          C
                                          chka
                                          #71
                                          Wieder ein Stück weiter, setzt man in der /Set folgendes schaltet er den Ausgang an.
                                          Jetzt muss es noch in das Script rein.
                                          enable = 1 AN
                                          enable = 0 AUS
                                            "params": {
                                              "enabled": 1,
                                              "out_freq": 255,
                                              "out_voltage": 4294967295,
                                              "xboost": 255
                                            "from": "iOS",
                                            "lang": "de-de",
                                            "id": "232050124",
                                            "moduleSn": "R6XXXXX",
                                            "moduleType": 5,
                                            "operateType": "acOutCfg",
                                            "version": "1.0"
                                          84.0k
