  3. Off Topic
  4. Proxmox
  5. Proxmox / Influxdb V1 zu V2... wie?
    1.0k
Geplant Angeheftet Gesperrt Verschoben Proxmox
221 Beiträge 20 Kommentatoren 56.2k Aufrufe 24 Beobachtet
  • BoronsbruderB Boronsbruder
    @massiveattack
    Posted doch bitte die cmdline die den Fehler auslöst immer mit dazu
    MassiveAttackM Offline
    MassiveAttack
    #108
    @boronsbruder
    root@QNAP:/# influx_inspect export -database iobroker -out /tmp/test.lp -lponly
    flag provided but not defined: -lponly
    Exports TSM files into InfluxDB line protocol format.
    BoronsbruderB 1 Antwort Letzte Antwort
    • MassiveAttackM MassiveAttack
      @boronsbruder
      BoronsbruderB Online
      Boronsbruder
      #109
      @massiveattack
      poste doch mal bitte
      influx -v
      MassiveAttackM 1 Antwort Letzte Antwort
        @massiveattack
        influx -v
        MassiveAttack
        #110
        @boronsbruder
        root@QNAP:/# influx -v
        flag provided but not defined: -v
        Usage of influx:
          -version
                                Display the version and exit.
          -path-prefix 'url path'
                                Path that follows the host and port
          -host 'host name'
                                Host to connect to.
          -port 'port #'
                                Port to connect to.
          -socket 'unix domain socket'
                                Unix socket to connect to.
          -database 'database name'
                                Database to connect to the server.
          -password 'password'
                                Password to connect to the server.  Leaving blank will prompt for password (--password '').
          -username 'username'
                                Username to connect to the server.
          -ssl
                                Use https for requests.
          -unsafeSsl
                                Set this when connecting to the cluster using https and not use SSL verification.
          -execute 'command'
                                Execute command and quit.
          -type 'influxql|flux'
                                Type specifies the query language for executing commands or when invoking the REPL.
          -format 'json|csv|column'
                                Format specifies the format of the server responses:  json, csv, or column.
          -precision 'rfc3339|h|m|s|ms|u|ns'
                                Precision specifies the format of the timestamp:  rfc3339, h, m, s, ms, u or ns.
          -consistency 'any|one|quorum|all'
                                Set write consistency level: any, one, quorum, or all
          -pretty
                                Turns on pretty print for the json format.
          -import
                                Import a previous database export from file
          -pps
                                How many points per second the import will allow.  By default it is zero and will not throttle importing.
          -path
                                Path to file to import
          -compressed
                                Set to true if the import file is compressed
        Examples:
            # Use influx in a non-interactive mode to query the database "metrics" and pretty print json:
            $ influx -database 'metrics' -execute 'select * from cpu' -format 'json' -pretty
            # Connect to a specific database on startup and set database context:
            $ influx -database 'metrics' -host 'localhost' -port '8086'
          @boronsbruder
          Usage of influx:
            -version
            -host 'host name'
                                  Host to connect to.
            -port 'port #'
                                  Port to connect to.
            -ssl
            -unsafeSsl
            -execute 'command'
            -pretty
            -import
            -pps
            -path
            -compressed
          Examples:
          Boronsbruder
          #111
          @massiveattack
          influx -version
            @massiveattack
            influx -version
            MassiveAttack
            #112
            @boronsbruder
            root@QNAP:/# influx -version
            InfluxDB shell version: 1.8.0
              @boronsbruder
              Boronsbruder
              #113
              @massiveattack
              okay ist nicht zu alt...
              was sagt influx_inspect export --help
              MassiveAttackM Marc BergM 2 Antworten Letzte Antwort
                @massiveattack
                MassiveAttack
                #114
                @boronsbruder sagte in Proxmox / Influxdb V1 zu V2... wie?:
                root@QNAP:/# influx_inspect export --help
                Usage: influx_inspect export [flags]
                  -compress
                        Compress the output
                  -database string
                        Optional: the database to export
                  -datadir string
                        Data storage path (default "/root/.influxdb/data")
                  -end string
                        Optional: the end time to export (RFC3339 format)
                  -out string
                        Destination file to export to (default "/root/.influxdb/export")
                  -retention string
                        Optional: the retention policy to export (requires -database)
                  -start string
                        Optional: the start time to export (RFC3339 format)
                  -waldir string
                        WAL storage path (default "/root/.influxdb/wal")
                  @massiveattack
                  Marc BergM Offline
                  Marc BergM Offline
                  Marc Berg
                  #115
                  @massiveattack
                  Doch, ist zu alt
                  • Marc BergM Marc Berg
                    @massiveattack
                    Doch, ist zu alt
                    MassiveAttack
                    #116
                    @marc-berg
                    d.h. ich bekomme die Daten nicht aus der v1 in die v2?
                      @marc-berg
                      Marc BergM Offline
                      Marc BergM Offline
                      Marc Berg
                      #117
                      @massiveattack sagte in Proxmox / Influxdb V1 zu V2... wie?:
                      @marc-berg
                      So, wie ich das sehe, mit dieser Methode erst nach einem Update auf mindestens 1.8.3
                        @marc-berg
                        MassiveAttack
                        #118
                        @marc-berg
                        wie ich diese useability liebe 😥 😢
                            -compress
                                  Compress the output
                            -database string
                            -datadir string
                            -end string
                            -out string
                            -retention string
                            -start string
                            -waldir string
                          Boronsbruder
                          schrieb am zuletzt editiert von Boronsbruder
                          #119
                          @massiveattack
                          ja, da fehlt -lponly
                          Jetzt hast du 2 Möglichkeiten...
                          1. Eine für dein Betriebsystem passende influx_inspect finden
                          oder
                          Einen Texteditor benutzen um den Header (die ersten paar Zeile mit #)
                          # INFLUXDB EXPORT: 2023-01-01T01:59:59+01:00 - 2262-04-12T00:47:16+01:00
                          # DDL
                          CREATE DATABASE iobroker WITH NAME autogen
                          # DML
                          # CONTEXT-DATABASE:iobroker
                          # CONTEXT-RETENTION-POLICY:autogen
                          # writing tsm data
                          0_userdata.0.Wetter.Mittel.1 ack=false 1672617060016000000
                          entfernen und dann importieren. Vorher natürlich entpacken.
                          Der Editor muss aber die riesige Datei verkraften und linux-kompatibles Format benutzen. Nicht dass Windows-Sonderzeichen für Zeilenumbrüche usw. Probleme machen.
                          BoronsbruderB Marc BergM 2 Antworten Letzte Antwort
                            @massiveattack
                            oder
                            # DDL
                            # DML
                            # writing tsm data
                            Boronsbruder
                            #120
                            ich benutze hier auf Windows Notepad++
                              @massiveattack
                              oder
                              # DDL
                              # DML
                              # writing tsm data
                              Marc BergM Offline
                              Marc BergM Offline
                              Marc Berg
                              #121
                              Hier https://dl.influxdata.com/influxdb/releases/influxdb-1.8.10_linux_amd64.tar.gz
                              wäre eine aktuellere influx_inspect enthalten. Aber ob die mit der 1.8.0 DB läuft?
                                Boronsbruder
                                #122
                                @marc-berg
                                ich würde erst die variante mit Zeilen entfernen versuchen ;)
                                z.B. entpacken und
                                sed '/^[#]/d' DATEINAME > NEUER_DATEINAME
                                (entfernt alle Zeilen beginnend mit # und schreibt das Resultat in eine neue Datei)
                                danach mit
                                gzip NEUER_DATEINAME
                                wieder packen
                                  @marc-berg
                                  z.B. entpacken und
                                  danach mit
                                  wieder packen
                                  Marc BergM Offline
                                  Marc BergM Offline
                                  Marc Berg
                                  #123
                                  Was ich nicht verstehe ist: Wenn diese Zeile hier angemeckert wird
                                  Error: failed to write data: 400 Bad Request: unable to parse 'CREATE DATABASE iobroker WITH NAME autogen': invalid field format
                                  und vor dieser Zeile kein "#" steht, was bringt das denn?
                                    Boronsbruder
                                    #124
                                    @marc-berg
                                    Hast natürlich recht...
                                    Copy und paste...
                                    EDIT
                                    besser noch
                                    sed -e '/^[#]/d' -e '/^CREATE/d' DATEINAME > NEUER_DATEINAME
                                    Sonst kann es passieren, dass er Zeilen mit löscht, die CREATE irgendwo im TEXT haben.
                                    Hier wird nur gelöscht nur wenn die Zeichen am Anfang sind...
                                      @marc-berg
                                      Copy und paste...
                                      EDIT
                                      besser noch
                                      MassiveAttack
                                      schrieb am zuletzt editiert von MassiveAttack
                                      #125
                                      @boronsbruder
                                      ich bekomme jetzt ein permission denied, ich hab keine lust mehr
                                      unexpected error writing points to database: mkdir /var: permission denied / "unexpected error writing points to database: mkdir /var: permission denied""
                                      im Verzeichnis /var habe ich schon chmod 777 gesetzt, bringt nix
                                        @boronsbruder
                                        Boronsbruder
                                        #126
                                        @massiveattack
                                        langsam...
                                        nicht unbedacht irgenwelche Berechtigungen verbiegen...
                                        Was löst den Fehler aus....
                                        Mit welchem Benutzer?
                                        Ist influxv2 sauber installiert?
                                          @massiveattack
                                          langsam...
                                          MassiveAttack
                                          #127
                                          @boronsbruder
                                          influx write -b iobroker -o universe -t KUArezBLNDbZWty0PcwTbD0rme4qIR2JZ0sffRAU8mcT2eXMB12jp6-aTRiH0Gtw0UsY4aEr1U3JXMiYWFTlWg== -f export
                                          root
                                          ja
                                          Diese v2 DB dient mir grad mal als Testobjekt, da verbiege ich alles wenn notwendig ;)
