  3. Off Topic
  4. Proxmox
  5. Proxmox / Influxdb V1 zu V2... wie?
    1.0k
Geplant Angeheftet Gesperrt Verschoben Proxmox
221 Beiträge 20 Kommentatoren 56.2k Aufrufe 24 Beobachtet
  • MassiveAttackM MassiveAttack
    @boronsbruder
    root@QNAP:/# influx_inspect export -database iobroker -out /tmp/test.lp -lponly
    flag provided but not defined: -lponly
    Exports TSM files into InfluxDB line protocol format.
    BoronsbruderB Offline
    Boronsbruder
    #109
    @massiveattack
    poste doch mal bitte
    influx -v
    MassiveAttackM 1 Antwort Letzte Antwort
    • BoronsbruderB Boronsbruder
      @massiveattack
      influx -v
      MassiveAttackM Offline
      MassiveAttack
      #110
      @boronsbruder
      root@QNAP:/# influx -v
      flag provided but not defined: -v
      Usage of influx:
        -version
                              Display the version and exit.
        -path-prefix 'url path'
                              Path that follows the host and port
        -host 'host name'
                              Host to connect to.
        -port 'port #'
                              Port to connect to.
        -socket 'unix domain socket'
                              Unix socket to connect to.
        -database 'database name'
                              Database to connect to the server.
        -password 'password'
                              Password to connect to the server.  Leaving blank will prompt for password (--password '').
        -username 'username'
                              Username to connect to the server.
        -ssl
                              Use https for requests.
        -unsafeSsl
                              Set this when connecting to the cluster using https and not use SSL verification.
        -execute 'command'
                              Execute command and quit.
        -type 'influxql|flux'
                              Type specifies the query language for executing commands or when invoking the REPL.
        -format 'json|csv|column'
                              Format specifies the format of the server responses:  json, csv, or column.
        -precision 'rfc3339|h|m|s|ms|u|ns'
                              Precision specifies the format of the timestamp:  rfc3339, h, m, s, ms, u or ns.
        -consistency 'any|one|quorum|all'
                              Set write consistency level: any, one, quorum, or all
        -pretty
                              Turns on pretty print for the json format.
        -import
                              Import a previous database export from file
        -pps
                              How many points per second the import will allow.  By default it is zero and will not throttle importing.
        -path
                              Path to file to import
        -compressed
                              Set to true if the import file is compressed
      Examples:
          # Use influx in a non-interactive mode to query the database "metrics" and pretty print json:
          $ influx -database 'metrics' -execute 'select * from cpu' -format 'json' -pretty
          # Connect to a specific database on startup and set database context:
          $ influx -database 'metrics' -host 'localhost' -port '8086'
      BoronsbruderB 1 Antwort Letzte Antwort
        @boronsbruder
        Usage of influx:
          -version
          -host 'host name'
                                Host to connect to.
          -port 'port #'
                                Port to connect to.
          -ssl
          -unsafeSsl
          -execute 'command'
          -pretty
          -import
          -pps
          -path
          -compressed
        Examples:
        Boronsbruder
        #111
        @massiveattack
        influx -version
          @massiveattack
          influx -version
          MassiveAttack
          #112
          @boronsbruder
          root@QNAP:/# influx -version
          InfluxDB shell version: 1.8.0
            @boronsbruder
            Boronsbruder
            #113
            @massiveattack
            okay ist nicht zu alt...
            was sagt influx_inspect export --help
            MassiveAttackM Marc BergM 2 Antworten Letzte Antwort
              @massiveattack
              MassiveAttack
              #114
              @boronsbruder sagte in Proxmox / Influxdb V1 zu V2... wie?:
              root@QNAP:/# influx_inspect export --help
              Usage: influx_inspect export [flags]
                -compress
                      Compress the output
                -database string
                      Optional: the database to export
                -datadir string
                      Data storage path (default "/root/.influxdb/data")
                -end string
                      Optional: the end time to export (RFC3339 format)
                -out string
                      Destination file to export to (default "/root/.influxdb/export")
                -retention string
                      Optional: the retention policy to export (requires -database)
                -start string
                      Optional: the start time to export (RFC3339 format)
                -waldir string
                      WAL storage path (default "/root/.influxdb/wal")
                @massiveattack
                Marc BergM Offline
                Marc BergM Offline
                Marc Berg
                #115
                @massiveattack
                Doch, ist zu alt
                • Marc BergM Marc Berg
                  @massiveattack
                  Doch, ist zu alt
                  MassiveAttack
                  #116
                  @marc-berg
                  d.h. ich bekomme die Daten nicht aus der v1 in die v2?
                    @marc-berg
                    Marc BergM Offline
                    Marc BergM Offline
                    Marc Berg
                    #117
                    @massiveattack sagte in Proxmox / Influxdb V1 zu V2... wie?:
                    @marc-berg
                    So, wie ich das sehe, mit dieser Methode erst nach einem Update auf mindestens 1.8.3
                      @marc-berg
                      MassiveAttack
                      #118
                      @marc-berg
                      wie ich diese useability liebe 😥 😢
                          -compress
                                Compress the output
                          -database string
                          -datadir string
                          -end string
                          -out string
                          -retention string
                          -start string
                          -waldir string
                        Boronsbruder
                        schrieb am zuletzt editiert von Boronsbruder
                        #119
                        @massiveattack
                        ja, da fehlt -lponly
                        Jetzt hast du 2 Möglichkeiten...
                        1. Eine für dein Betriebsystem passende influx_inspect finden
                        oder
                        Einen Texteditor benutzen um den Header (die ersten paar Zeile mit #)
                        # INFLUXDB EXPORT: 2023-01-01T01:59:59+01:00 - 2262-04-12T00:47:16+01:00
                        # DDL
                        CREATE DATABASE iobroker WITH NAME autogen
                        # DML
                        # CONTEXT-DATABASE:iobroker
                        # CONTEXT-RETENTION-POLICY:autogen
                        # writing tsm data
                        0_userdata.0.Wetter.Mittel.1 ack=false 1672617060016000000
                        entfernen und dann importieren. Vorher natürlich entpacken.
                        Der Editor muss aber die riesige Datei verkraften und linux-kompatibles Format benutzen. Nicht dass Windows-Sonderzeichen für Zeilenumbrüche usw. Probleme machen.
                        BoronsbruderB Marc BergM 2 Antworten Letzte Antwort
                          @massiveattack
                          oder
                          # DDL
                          # DML
                          # writing tsm data
                          Boronsbruder
                          #120
                          ich benutze hier auf Windows Notepad++
                            @massiveattack
                            oder
                            # DDL
                            # DML
                            # writing tsm data
                            Marc BergM Offline
                            Marc BergM Offline
                            Marc Berg
                            #121
                            Hier https://dl.influxdata.com/influxdb/releases/influxdb-1.8.10_linux_amd64.tar.gz
                            wäre eine aktuellere influx_inspect enthalten. Aber ob die mit der 1.8.0 DB läuft?
                              Boronsbruder
                              #122
                              @marc-berg
                              ich würde erst die variante mit Zeilen entfernen versuchen ;)
                              z.B. entpacken und
                              sed '/^[#]/d' DATEINAME > NEUER_DATEINAME
                              (entfernt alle Zeilen beginnend mit # und schreibt das Resultat in eine neue Datei)
                              danach mit
                              gzip NEUER_DATEINAME
                              wieder packen
                                @marc-berg
                                z.B. entpacken und
                                danach mit
                                wieder packen
                                Marc BergM Offline
                                Marc BergM Offline
                                Marc Berg
                                #123
                                Was ich nicht verstehe ist: Wenn diese Zeile hier angemeckert wird
                                Error: failed to write data: 400 Bad Request: unable to parse 'CREATE DATABASE iobroker WITH NAME autogen': invalid field format
                                und vor dieser Zeile kein "#" steht, was bringt das denn?
                                  Boronsbruder
                                  #124
                                  @marc-berg
                                  Hast natürlich recht...
                                  Copy und paste...
                                  EDIT
                                  besser noch
                                  sed -e '/^[#]/d' -e '/^CREATE/d' DATEINAME > NEUER_DATEINAME
                                  Sonst kann es passieren, dass er Zeilen mit löscht, die CREATE irgendwo im TEXT haben.
                                  Hier wird nur gelöscht nur wenn die Zeichen am Anfang sind...
                                    @marc-berg
                                    Copy und paste...
                                    EDIT
                                    besser noch
                                    MassiveAttack
                                    schrieb am zuletzt editiert von MassiveAttack
                                    #125
                                    @boronsbruder
                                    ich bekomme jetzt ein permission denied, ich hab keine lust mehr
                                    unexpected error writing points to database: mkdir /var: permission denied / "unexpected error writing points to database: mkdir /var: permission denied""
                                    im Verzeichnis /var habe ich schon chmod 777 gesetzt, bringt nix
                                      @boronsbruder
                                      Boronsbruder
                                      #126
                                      @massiveattack
                                      langsam...
                                      nicht unbedacht irgenwelche Berechtigungen verbiegen...
                                      Was löst den Fehler aus....
                                      Mit welchem Benutzer?
                                      Ist influxv2 sauber installiert?
                                        @massiveattack
                                        langsam...
                                        MassiveAttack
                                        #127
                                        @boronsbruder
                                        influx write -b iobroker -o universe -t KUArezBLNDbZWty0PcwTbD0rme4qIR2JZ0sffRAU8mcT2eXMB12jp6-aTRiH0Gtw0UsY4aEr1U3JXMiYWFTlWg== -f export
                                        root
                                        ja
                                        Diese v2 DB dient mir grad mal als Testobjekt, da verbiege ich alles wenn notwendig ;)
                                          @boronsbruder
                                          Marc BergM Offline
                                          Marc BergM Offline
                                          Marc Berg
                                          #128
                                          @boronsbruder
                                          Ich denke mal, die V2 Installation ist völlig schief. Das kam mir mit den fehlenden Configs/Profilen schon seltsam vor. Auch wenn's nervt, fang nochmal neu an.
