  3. Einsteigerfragen
  4. Backup Adapter hängt System auf
84 Beiträge 5 Kommentatoren 10.2k Aufrufe 3 Beobachtet
    @thomas-braun sagte in Backup Adapter hängt System auf:
    @gezi70
    Das Mounten funktioniert aber.
    Das muss woanders klemmen.
    Schau mit
    iob log --watch | uniq
    über die Kommandozeile zu, wenn ein Backup gefahren wird.
    biete noch ein s an!
    iob logs --watch | uniq
    Gezi70
    Jetzt lief es auch wieder durch. Das Log davon:
    2023-01-22 20:10:20.049  - info: weatherunderground.0 (32763) State value to set for "weatherunderground.0.forecastHourly.32h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-01-22 20:10:20.166  - info: weatherunderground.0 (32763) State value to set for "weatherunderground.0.forecastHourly.33h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-01-22 20:10:20.282  - info: weatherunderground.0 (32763) State value to set for "weatherunderground.0.forecastHourly.34h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-01-22 20:10:20.397  - info: weatherunderground.0 (32763) State value to set for "weatherunderground.0.forecastHourly.35h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-01-22 20:10:22.510  - info: weatherunderground.0 (32763) Terminated (NO_ERROR): Without reason
    2023-01-22 20:10:23.066  - info: host.raspberrypi instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
    2023-01-22 20:10:25.073  - info: netatmo.0 (2054) Websocket error: websocket error,  Error: websocket error
        at WS.Transport.onError (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:64:13)
        at WebSocket.ws.onerror (/opt/iobroker/node_modules/engine.io-client/lib/transports/websocket.js:149:10)
        at WebSocket.onError (/opt/iobroker/node_modules/engine.io-client/node_modules/ws/lib/WebSocket.js:452:14)
        at WebSocket.emit (node:events:513:28)
        at WebSocket.emit (node:domain:489:12)
        at ClientRequest.response (/opt/iobroker/node_modules/engine.io-client/node_modules/ws/lib/WebSocket.js:721:12)
        at Object.onceWrapper (node:events:628:26)
        at ClientRequest.emit (node:events:525:35)
        at ClientRequest.emit (node:domain:489:12)
        at HTTPParser.parserOnIncomingClient [as onIncoming] (node:_http_client:693:27)
    2023-01-22 20:10:30.305  - info: netatmo.0 (2054) Websocket error: websocket error,  Error: websocket error
    2023-01-22 20:10:35.491  - info: netatmo.0 (2054) Websocket error: websocket error,  Error: websocket error
    2023-01-22 20:10:40.669  - info: netatmo.0 (2054) Websocket error: websocket error,  Error: websocket error
    2023-01-22 20:10:45.848  - info: netatmo.0 (2054) Websocket error: websocket error,  Error: websocket error
    2023-01-22 20:10:46.886  - info: openweathermap.0 (32782) Terminated (NO_ERROR): Without reason
    2023-01-22 20:10:47.418  - info: host.raspberrypi instance system.adapter.openweathermap.0 terminated with code 0 (NO_ERROR)
    2023-01-22 20:10:51.055  - info: netatmo.0 (2054) Websocket error: websocket error,  Error: websocket error
    2023-01-22 20:10:56.242  - info: netatmo.0 (2054) Websocket error: websocket error,  Error: websocket error
    2023-01-22 20:11:01.435  - info: netatmo.0 (2054) Websocket error: websocket error,  Error: websocket error
    2023-01-22 20:11:06.631  - info: netatmo.0 (2054) Websocket error: websocket error,  Error: websocket error
    2023-01-22 20:11:11.821  - info: netatmo.0 (2054) Websocket error: websocket error,  Error: websocket error
    2023-01-22 20:11:17.020  - info: netatmo.0 (2054) Websocket error: websocket error,  Error: websocket error
    2023-01-22 20:11:22.222  - info: netatmo.0 (2054) Websocket error: websocket error,  Error: websocket error
    2023-01-22 20:11:27.418  - info: netatmo.0 (2054) Websocket error: websocket error,  Error: websocket error
    2023-01-22 20:11:32.624  - info: netatmo.0 (2054) Websocket error: websocket error,  Error: websocket error
    2023-01-22 20:11:37.811  - info: netatmo.0 (2054) Websocket error: websocket error,  Error: websocket error
    2023-01-22 20:11:43.011  - info: netatmo.0 (2054) Websocket error: websocket error,  Error: websocket error
    2023-01-22 20:11:48.232  - info: netatmo.0 (2054) Websocket error: websocket error,  Error: websocket error
    2023-01-22 20:11:53.421  - info: netatmo.0 (2054) Websocket error: websocket error,  Error: websocket error
    2023-01-22 20:11:58.630  - info: netatmo.0 (2054) Websocket error: websocket error,  Error: websocket error
    2023-01-22 20:12:03.825  - info: netatmo.0 (2054) Websocket error: websocket error,  Error: websocket error
    2023-01-22 20:12:09.024  - info: netatmo.0 (2054) Websocket error: websocket error,  Error: websocket error
    2023-01-22 20:12:14.220  - info: netatmo.0 (2054) Websocket error: websocket error,  Error: websocket error
    2023-01-22 20:12:19.419  - info: netatmo.0 (2054) Websocket error: websocket error,  Error: websocket error
    2023-01-22 20:12:24.612  - info: netatmo.0 (2054) Websocket error: websocket error,  Error: websocket error
    2023-01-22 20:12:27.705  - info: web.0 (3499) ==> Connected system.user.admin from ::ffff:192.168.178.63
    2023-01-22 20:12:29.819  - info: netatmo.0 (2054) Websocket error: websocket error,  Error: websocket error
    2023-01-22 20:12:35.007  - info: netatmo.0 (2054) Websocket error: websocket error,  Error: websocket error
    2023-01-22 20:12:40.214  - info: netatmo.0 (2054) Websocket error: websocket error,  Error: websocket error
    2023-01-22 20:12:45.398  - info: netatmo.0 (2054) Websocket error: websocket error,  Error: websocket error
    2023-01-22 20:12:53.679  - info: netatmo.0 (2054) Websocket error: websocket error,  Error: websocket error
    2023-01-22 20:12:58.866  - info: netatmo.0 (2054) Websocket error: websocket error,  Error: websocket error
    2023-01-22 20:13:04.056  - info: netatmo.0 (2054) Websocket error: websocket error,  Error: websocket error
    2023-01-22 20:13:04.397  - info: admin.0 (1246) ==> Connected system.user.admin from ::ffff:192.168.178.60
    2023-01-22 20:13:09.244  - info: netatmo.0 (2054) Websocket error: websocket error,  Error: websocket error
    2023-01-22 20:13:14.423  - info: netatmo.0 (2054) Websocket error: websocket error,  Error: websocket error
    2023-01-22 20:13:19.612  - info: netatmo.0 (2054) Websocket error: websocket error,  Error: websocket error
    2023-01-22 20:13:24.802  - info: netatmo.0 (2054) Websocket error: websocket error,  Error: websocket error
    2023-01-22 20:13:29.979  - info: netatmo.0 (2054) Websocket error: websocket error,  Error: websocket error
    2023-01-22 20:13:35.175  - info: netatmo.0 (2054) Websocket error: websocket error,  Error: websocket error
    2023-01-22 20:13:40.380  - info: netatmo.0 (2054) Websocket error: websocket error,  Error: websocket error
    2023-01-22 20:13:42.797  - info: fritzdect.0 (2779) State value to set for "fritzdect.0.DECT_142760444335-1.lastalertchgtimestamp" has to be type "number" but received type "string"
    2023-01-22 20:13:45.569  - info: netatmo.0 (2054) Websocket error: websocket error,  Error: websocket error
    2023-01-22 20:13:50.778  - info: netatmo.0 (2054) Websocket error: websocket error,  Error: websocket error
    2023-01-22 20:13:56.693  - info: netatmo.0 (2054) Websocket error: websocket error,  Error: websocket error
    2023-01-22 20:14:01.892  - info: netatmo.0 (2054) Websocket error: websocket error,  Error: websocket error
    ^[[B
    2023-01-22 20:14:07.089  - info: netatmo.0 (2054) Websocket error: websocket error,  Error: websocket error
    2023-01-22 20:14:12.279  - info: netatmo.0 (2054) Websocket error: websocket error,  Error: websocket error
    2023-01-22 20:14:17.478  - info: netatmo.0 (2054) Websocket error: websocket error,  Error: websocket error
    2023-01-22 20:14:22.669  - info: netatmo.0 (2054) Websocket error: websocket error,  Error: websocket error
    2023-01-22 20:14:27.845  - info: netatmo.0 (2054) Websocket error: websocket error,  Error: websocket error
    2023-01-22 20:14:33.034  - info: netatmo.0 (2054) Websocket error: websocket error,  Error: websocket error
    2023-01-22 20:14:38.213  - info: netatmo.0 (2054) Websocket error: websocket error,  Error: websocket error
    2023-01-22 20:14:43.399  - info: netatmo.0 (2054) Websocket error: websocket error,  Error: websocket error
    2023-01-22 20:14:48.595  - info: netatmo.0 (2054) Websocket error: websocket error,  Error: websocket error
    2023-01-22 20:14:53.784  - info: netatmo.0 (2054) Websocket error: websocket error,  Error: websocket error
    2023-01-22 20:14:58.969  - info: netatmo.0 (2054) Websocket error: websocket error,  Error: websocket error
    2023-01-22 20:15:00.135  - info: host.raspberrypi instance system.adapter.openweathermap.0 started with pid 36165
    2023-01-22 20:15:04.152  - info: netatmo.0 (2054) Websocket error: websocket error,  Error: websocket error
    2023-01-22 20:15:04.206  - info: host.raspberrypi instance system.adapter.weatherunderground.0 started with pid 36216
    2023-01-22 20:15:05.142  - info: openweathermap.0 (36165) starting. Version 0.3.3 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v16.19.0, js-controller: 4.0.24
    2023-01-22 20:15:07.984  - info: weatherunderground.0 (36216) starting. Version 3.4.2 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v16.19.0, js-controller: 4.0.24
    2023-01-22 20:15:08.272  - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 36308
    2023-01-22 20:15:09.377  - info: netatmo.0 (2054) Websocket error: websocket error,  Error: websocket error
    2023-01-22 20:15:12.354  - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 36548
    2023-01-22 20:15:12.445  - info: weatherunderground.0 (36216) State value to set for "weatherunderground.0.forecastPeriod.0p.icon" has to be type "string" but received type "number"
    2023-01-22 20:15:12.851  - info: weatherunderground.0 (36216) State value to set for "weatherunderground.0.forecastPeriod.1p.icon" has to be type "string" but received type "number"
    2023-01-22 20:15:13.188  - info: weatherunderground.0 (36216) State value to set for "weatherunderground.0.forecastPeriod.2p.icon" has to be type "string" but received type "number"
    2023-01-22 20:15:13.402  - info: weatherunderground.0 (36216) State value to set for "weatherunderground.0.forecastPeriod.3p.icon" has to be type "string" but received type "number"
    2023-01-22 20:15:13.584  - info: weatherunderground.0 (36216) State value to set for "weatherunderground.0.forecastPeriod.4p.icon" has to be type "string" but received type "number"
    2023-01-22 20:15:13.619  - info: dwd.0 (36308) starting. Version 2.8.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v16.19.0, js-controller: 4.0.24
    2023-01-22 20:15:13.833  - info: weatherunderground.0 (36216) State value to set for "weatherunderground.0.forecastPeriod.5p.icon" has to be type "string" but received type "number"
    2023-01-22 20:15:13.974  - info: weatherunderground.0 (36216) State value to set for "weatherunderground.0.forecastPeriod.6p.icon" has to be type "string" but received type "number"
    2023-01-22 20:15:14.204  - info: weatherunderground.0 (36216) State value to set for "weatherunderground.0.forecastPeriod.7p.icon" has to be type "string" but received type "number"
    2023-01-22 20:15:14.470  - info: weatherunderground.0 (36216) State value to set for "weatherunderground.0.forecast.0d.windDirectionMax" has to be type "string" but received type "number"
    2023-01-22 20:15:14.577  - info: netatmo.0 (2054) Websocket error: websocket error,  Error: websocket error
    2023-01-22 20:15:14.673  - info: weatherunderground.0 (36216) State value to set for "weatherunderground.0.forecast.1d.icon" has to be type "string" but received type "number"
    2023-01-22 20:15:15.226  - info: dwd.0 (36308) State value to set for "dwd.0.warning2.begin" has to be type "string" but received type "number"
    2023-01-22 20:15:15.285  - info: dwd.0 (36308) State value to set for "dwd.0.warning2.end" has to be type "string" but received type "number"
    2023-01-22 20:15:15.301  - info: weatherunderground.0 (36216) State value to set for "weatherunderground.0.forecast.1d.windDirectionMax" has to be type "string" but received type "number"
    • G Gezi70
      ^[[B
      @gezi70
      Schalt den netatmo und wunderground mal aus.
      Da findet sich ja keiner durch, so geschwätzig wie die sind.
      (Ich denke, die sind auch falsch eingestellt).
      G 1 Antwort Letzte Antwort
      • G Gezi70
        ^[[B
        @gezi70 hast du eine iobrojer pro Lizenz?
        sonst kannst du netatmo abschalten.
        Der bremst ja alles aus
          Gezi70
          schrieb am zuletzt editiert von Gezi70
          @homoran sagte in Backup Adapter hängt System auf:
          Ja, habe ich. Ich nehme die beiden (netatmo und WU) mal weg.
          • G Gezi70
            @gezi70 sagte in Backup Adapter hängt System auf:
            Ja, habe ich
            dann hast du das hier auch verfolgt?
            https://forum.iobroker.net/topic/60525/netatmo-websocket-error/18?_=1674415401133
              Ja, habe ich
              Gezi70
              @homoran Dort steht aber auch, dass dies für nur Wetterstationen unrelevant ist.
              Ich hatte zwar die Kameras auch drin, aber die sind in diesem System eigentlich für mich unrelevant und ich hab sie rausgenommen.
                @gezi70
                Gezi70
                Ich wollte gerade mal das Log von heute Nacht aufrufen, weil er sich da auch wieder verabschiedet hat. Dabei hing er auch wieder , und es ging nichts mehr. Ich nehme an, dass er mit der Rechenleistung am Ende ist, was aber nicht sein kann, da er nicht mit einer SD karte läuft, sondern mit SSD. Die normale Rechenleistung sieht so aus:
                pi@raspberrypi:~ $ free -ht --mega
                              gesamt       benutzt     frei      gemns.  Puffer/Cache verfügbar
                Speicher:       3,8G        2,4G        576M        1,0M        822M        1,3G
                Swap:            99M          0B         99M
                Gesamt:         3,9G        2,4G        676M
                Ich bin in den Tiefen des Forums auf das Kommando htop gestoßen, mit dem du bei jemand anderen die Leistung abfragen lassen hast (https://forum.iobroker.net/topic/54002/raspberry-pi-ein-kern-komplett-ausgelastet).
                Und da scheint es bei mir auch zu klemmen. Htop meldet:
                Dabei ist Mem immer ziemlich hoch. Ob es das ist? Und wenn ja - wie krieg ich das niedriger?
                • G Gezi70
                  Swap:            99M          0B         99M
                  @gezi70
                  Beobachte das mal länger. Wenn dauerhaft der hue-extended da so aus der Reihe tanzt musst du da mal schauen.
                  Irgendein Skript, das darauf zugreift?
                  G 2 Antworten Letzte Antwort
                  • G Gezi70
                    Swap:            99M          0B         99M
                    Das hat nichts (unmittelbar) miteinander zu tun.
                    free zeigt auch nicht die 'Leistung' sondern lediglich die Speicherauslastung. Das ist aber alles nicht wirklich kritisch zum Betrachtungszeitpunkt.
                      @gezi70
                      Gezi70
                      @gezi70
                      Ja, mehrere. Ich rufe mehrere Szenen zu bestimmten Dingen und Zeitpunkten damit auf.
                      Mich wundert, dass "Mem" dauerhaft so hoch ist.
                      • G Gezi70
                        @gezi70
                        #66
                        @gezi70
                        Dann ist vermutlich in der Ecke etwas falsch.
                        Müsstest du dir die Skripte anschauen.
                          @gezi70
                          Gezi70
                          #67
                          Nach längerer Beobachtung habe ich von hue-extended nichts mehr in der Richtung festgestellt.
                          Aber was mir aufgefallen ist: Der swap steht manchmal bei htop schon von Anfang an in vollem Ausschlag (rot). Das zuckt sich auch nicht mehr über den gesamten Beobachtungszeitraum (bis zu 30min probiert). Und wenn DANN ein Backup erstellt wird, hängt er sich auf. Sonst läuft es durch.
                          Aber wodurch er so hoch getrieben wird, weiß ich nicht. Kann man das herausfinden?
                          • G Gezi70
                            #68
                            @gezi70
                            Schau dir
                            smem
                            an. Muss u. U. noch nachinstalliert werden.
                              @gezi70
                              Schau dir
                              smem
                              Gezi70
                              #69
                              pi@raspberrypi:~ $ smem
                              -bash: smem: Kommando nicht gefunden.
                              • G Gezi70
                                #70
                                @gezi70
                                  @gezi70
                                  Gezi70
                                  #71
                                  Mache ich gerade. Muss der dann erst Daten sammeln?
                                  • Thomas BraunT Online
                                    #72
                                    @gezi70
                                    Das zeigt dir die Prozesse an die gerade swappen.
                                    • G Gezi70
                                      simatecS Offline
                                      simatecS Offline
                                      simatec
                                      #73
                                      @gezi70 Mal ne grundsätzliche Klärung wäre, wie groß denn dein iobroker Backup ist, wenn es erstellt wurde
                                      • Besuche meine Github Seite
                                      • HowTo Restore ioBroker
                                      • simatecS simatec
                                        Gezi70
                                        #74
                                        @simatec Es sind ca. 72 Mb
                                          @gezi70
                                          Schau dir
                                          smem
                                          Gezi70
                                          #75
                                          @gezi70
                                          Schau dir
                                          smem
                                          Es scheint dieses Skript zu sein. Das hatte ich vorher aber auch schon. Noch nie Probleme.
                                          Der SWAP zeigt
                                            PID User     Command                         Swap      USS      PSS      RSS
                                          738597 pi       timeout 66 nc -nlvw 1 -p 10        0      144      218     1740
                                          738599 pi       nc -nlvw 1 -p 1080                 0      268      289     1688
                                          738598 pi       tail -1                            0      396      465     1908
                                          738596 pi       /bin/bash /home/pi/wetterst      648      272      912     2484
                                            420 pi       /bin/bash /home/pi/wetterst      648      272     1102     3916
                                          736910 pi       -bash                              0     1876     2274     4684
                                          736889 pi       /lib/systemd/systemd --user        0     1992     3816     8368
                                          738685 pi       /usr/bin/python3 /usr/bin/s        0    10944    11066    12920
                                          Ich habe jetzt erstmal den SWAP, da ich nicht mit Karte sondern mit SSD am Pi arbeite, auf 1000 MB vergrößert. Oder soll ich ihn lieber deaktivieren?
                                          Thomas BraunT simatecS 2 Antworten Letzte Antwort
