  4. Einrichten Modbus Adapter / Solar X3 Gen4
147 Beiträge 19 Kommentatoren 30.5k Aufrufe 18 Beobachtet
  • GlasfaserG Glasfaser
    @mcwoolf
    Zeige doch mal was aktuell bei dir ist
    Modbus Instanz Einstellungen , Register und der Log von ioBroker
    McWoolfM Offline
    McWoolfM Offline
    McWoolf
    schrieb am zuletzt editiert von McWoolf
    @glasfaser
    2023-01-20 19:29:45.376 - error: modbus.0 (14907) Socket Error
    2023-01-20 19:29:45.376 - error: modbus.0 (14907) Client in error state.
    2023-01-20 19:29:45.377 - warn: modbus.0 (14907) On error: {"errno":-111,"code":"ECONNREFUSED","syscall":"connect","address":"192.168.1.244","port":503}
    2023-01-20 19:29:45.377 - debug: modbus.0 (14907) Socket closed with error
    2023-01-20 19:29:45.377 - debug: modbus.0 (14907) Clearing timeout of the current request.
    2023-01-20 19:29:45.377 - debug: modbus.0 (14907) Cleaning up request fifo.
    2023-01-20 19:29:46.377 - debug: modbus.0 (14907) Closing client on purpose.
    2023-01-20 19:30:46.381 - error: modbus.0 (14907) Socket Error
    2023-01-20 19:30:46.381 - error: modbus.0 (14907) Client in error state.
    2023-01-20 19:30:46.381 - warn: modbus.0 (14907) On error: {"errno":-111,"code":"ECONNREFUSED","syscall":"connect","address":"192.168.1.244","port":503}
    2023-01-20 19:30:46.382 - debug: modbus.0 (14907) Socket closed with error
    2023-01-20 19:30:46.382 - debug: modbus.0 (14907) Clearing timeout of the current request.
    2023-01-20 19:30:46.382 - debug: modbus.0 (14907) Cleaning up request fifo.
    2023-01-20 19:30:47.382 - debug: modbus.0 (14907) Closing client on purpose.
    ::ffff:192.168.1.20 modbus
    Lieben Dank an die Helfer hier.
    GLG Wolfi
    Configuration:
    Intel Nuc: 11th Gen Intel(R) Core(TM) i7-1165G7 @ 2.80GHz (1 Socket)
    RAM: 8 GB
    JS-controler: 5.0.17
    Node.js: 18.19.0
    NPM: 10.2.3
    • McWoolfM McWoolf
      @glasfaser
      GlasfaserG Offline
      GlasfaserG Offline
      @mcwoolf sagte in Einrichten Modbus Adapter / Solar X3 Gen4:
      ical.0
      entferne bitte dieses im LOG !!!!!!!!!!!!!!!!!!!!!!
      McWoolfM 1 Antwort Letzte Antwort
        ical.0
        McWoolfM Offline
        McWoolfM Offline
        McWoolf
        @glasfaser sagte in Einrichten Modbus Adapter / Solar X3 Gen4:
        ical.0
        Sorry übersehen
        GLG Wolfi
        Configuration:
        RAM: 8 GB
        Node.js: 18.19.0
        NPM: 10.2.3
          klassisch
          Habe mir mal die oben verlinkte Solax Registerliste angeschaut.
          Ich würde es mit Alias off bzw. nicht angehakt testen.
          In der Registerliste mit code 0x03 sind wohl die Input register und die 0x04 die holding register
          Wenn Alias aus ist, dann gibt man bei Adresse den Registerwert in Dezimal ein. Und ich hatte auch schon den Fall, wo man 1 dazuaddieren mußte.
          Devide ID ist die Modbus Geräteadresse des Wechselrichters. Die gibt man wahrscheinlich im Wechselrichter per Display und Tastatur ein
          • McWoolfM McWoolf
            ical.0
            Sorry übersehen
            GlasfaserG Offline
            GlasfaserG Offline
            @mcwoolf
            Er leht die Verbindung ab .
            Teste mal so , mit einem Windows Programm :
            https://forum.iobroker.net/post/749115
              @mcwoolf
              McWoolfM Offline
              McWoolfM Offline
              McWoolf
              @glasfaser
              Was sagt mir das jetzt??
              GLG Wolfi
              Configuration:
              RAM: 8 GB
              Node.js: 18.19.0
              NPM: 10.2.3
              GlasfaserG K 2 Antworten Letzte Antwort
              • McWoolfM McWoolf
                @glasfaser
                GlasfaserG Offline
                GlasfaserG Offline
                @mcwoolf
                Keine Antwort vom Teilnehmer ..
                Fragt nur ein Client den Modbus ab !?
                • McWoolfM McWoolf
                  @glasfaser
                  klassisch
                  @mcwoolf Antwortet nicht.
                  Hatte ich schon gefragt, ob man den Modbus im Inverter freischalten muß? Beim Victron war das so.
                  Und jetzt ist anscheinend ein anderer Konverter dran, den ich nicht kenne. Ist da A und B bekannt?
                    @mcwoolf
                    McWoolfM Offline
                    McWoolfM Offline
                    McWoolf
                    #66
                    @glasfaser
                    Ich hab nur meinen WR einen Umsetzer und den iobroker
                    GLG Wolfi
                    Configuration:
                    RAM: 8 GB
                    Node.js: 18.19.0
                    NPM: 10.2.3
                    • McWoolfM McWoolf
                      @glasfaser
                      GlasfaserG Offline
                      GlasfaserG Offline
                      #67
                      @mcwoolf
                      ping 192.168.1.244
                      nc -zv 192.168.1.244 503
                      • K klassisch
                        McWoolfM Offline
                        McWoolfM Offline
                        McWoolf
                        #68
                        @klassisch
                        sieh mal.
                        GLG Wolfi
                        Configuration:
                        RAM: 8 GB
                        Node.js: 18.19.0
                        NPM: 10.2.3
                          @mcwoolf
                          ping 192.168.1.244
                          McWoolfM Offline
                          McWoolfM Offline
                          McWoolf
                          #69
                          @glasfaser
                          Solax.localdomain [192.168.1.244] 503 (?) : Connection refused
                          GLG Wolfi
                          Configuration:
                          RAM: 8 GB
                          Node.js: 18.19.0
                          NPM: 10.2.3
                          K GlasfaserG 2 Antworten Letzte Antwort
                          • McWoolfM McWoolf
                            @glasfaser
                            klassisch
                            schrieb am zuletzt editiert von klassisch
                            #70
                            @glasfaser
                            Das ist der Solax und nicht der Konverter?
                            • McWoolfM McWoolf
                              @glasfaser
                              GlasfaserG Offline
                              GlasfaserG Offline
                              #71
                              Connection refused
                              • K klassisch
                                @glasfaser
                                McWoolfM Offline
                                McWoolfM Offline
                                McWoolf
                                #72
                                @klassisch
                                Der Solax ist der Konverter oder was meinst du mit Konverter den Umsetzer??
                                GLG Wolfi
                                Configuration:
                                RAM: 8 GB
                                Node.js: 18.19.0
                                NPM: 10.2.3
                                • McWoolfM McWoolf
                                  @klassisch
                                  klassisch
                                  #73
                                  @mcwoolf Konverter ist für mich der USRIOT oder was da jetzt gerade stattdessen arbeitet
                                  • K klassisch
                                    McWoolfM Offline
                                    McWoolfM Offline
                                    McWoolf
                                    #74
                                    @klassisch
                                    Naja die Ip ist die vom Konverter und der hängt mittels R485 am Solax.
                                    GLG Wolfi
                                    Configuration:
                                    RAM: 8 GB
                                    Node.js: 18.19.0
                                    NPM: 10.2.3
                                      klassisch
                                      #75
                                      Du gibst in den Tool als Adresse 30001 und als Länge 10 ein. Die Länge ist aber 7. Und 30000 statt 30001 wäre auch schnell getestet
                                      • K klassisch
                                        McWoolfM Offline
                                        McWoolfM Offline
                                        McWoolf
                                        #76
                                        @klassisch
                                        selbes Ergebnis
                                        GLG Wolfi
                                        Configuration:
                                        RAM: 8 GB
                                        Node.js: 18.19.0
                                        NPM: 10.2.3
                                        • McWoolfM McWoolf
                                          @klassisch
                                          selbes Ergebnis
                                          GlasfaserG Offline
                                          GlasfaserG Offline
                                          #77
                                          selbes Ergebnis
                                          ip zum Rechner geändert !
