  3. Off Topic
  4. Proxmox
  5. Proxmox VM friert ein
    2.7k
    4.8k
    4.0k
Geplant Angeheftet Gesperrt Verschoben Proxmox
186 Beiträge 20 Kommentatoren 45.4k Aufrufe 14 Beobachtet
  • 9 900icarD
    @glasfaser
    ok, here we go. Gehen nur 100.000 Zeichen.
    Wie gesagt, einige Adapter sind noch nicht fertig konfiguriert.
    2023-01-18 08:00:00.033 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 started with pid 13044
    2023-01-18 08:00:01.413 - info: sbfspot.0 (13044) starting. Version 4.1.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v16.19.0, js-controller: 4.0.24
    2023-01-18 08:00:01.543 - info: sbfspot.0 (13044) start with mySQL
    2023-01-18 08:00:01.590 - info: sbfspot.0 (13044) got data from with ID 0
    2023-01-18 08:00:02.250 - info: sbfspot.0 (13044) got data from SB 4000TL-20 with ID 2100101691
    2023-01-18 08:00:02.771 - info: sbfspot.0 (13044) got data from SB 4000TL-20 with ID 2100111075
    2023-01-18 08:00:03.224 - info: sbfspot.0 (13044) all done ...
    2023-01-18 08:00:03.225 - info: sbfspot.0 (13044) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-01-18 08:00:03.741 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-01-18 08:07:03.460 - warn: wled.0 (11253) State attribute definition missing for : liveseg with value : -1
    2023-01-18 08:07:06.719 - warn: wled.0 (11253) State attribute definition missing for : liveseg with value : -1
    2023-01-18 08:07:08.737 - warn: wled.0 (11253) State attribute definition missing for : liveseg with value : -1
    2023-01-18 08:10:00.590 - warn: wled.0 (11253) State attribute definition missing for : liveseg with value : -1
    2023-01-18 08:10:02.603 - warn: wled.0 (11253) State attribute definition missing for : liveseg with value : -1
    2023-01-18 08:10:05.119 - warn: wled.0 (11253) State attribute definition missing for : liveseg with value : -1
    2023-01-18 08:10:18.130 - warn: wled.0 (11253) State attribute definition missing for : liveseg with value : -1
    2023-01-18 08:10:22.100 - warn: wled.0 (11253) State attribute definition missing for : liveseg with value : -1
    2023-01-18 08:10:24.108 - warn: wled.0 (11253) State attribute definition missing for : liveseg with value : -1
    2023-01-18 08:15:00.035 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 started with pid 13064
    2023-01-18 08:15:01.474 - info: sbfspot.0 (13064) starting. Version 4.1.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v16.19.0, js-controller: 4.0.24
    2023-01-18 08:15:01.618 - info: sbfspot.0 (13064) start with mySQL
    2023-01-18 08:15:01.665 - info: sbfspot.0 (13064) got data from with ID 0
    2023-01-18 08:15:01.948 - info: sbfspot.0 (13064) got data from SB 4000TL-20 with ID 2100101691
    2023-01-18 08:15:02.280 - info: sbfspot.0 (13064) got data from SB 4000TL-20 with ID 2100111075
    2023-01-18 08:15:02.565 - info: sbfspot.0 (13064) all done ...
    2023-01-18 08:15:02.567 - info: sbfspot.0 (13064) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-01-18 08:15:03.103 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-01-18 08:30:00.038 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 started with pid 13087
    2023-01-18 08:30:01.459 - info: sbfspot.0 (13087) starting. Version 4.1.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v16.19.0, js-controller: 4.0.24
    2023-01-18 08:30:01.595 - info: sbfspot.0 (13087) start with mySQL
    2023-01-18 08:30:01.634 - info: sbfspot.0 (13087) got data from with ID 0
    2023-01-18 08:30:02.040 - info: sbfspot.0 (13087) got data from SB 4000TL-20 with ID 2100101691
    2023-01-18 08:30:02.484 - info: sbfspot.0 (13087) got data from SB 4000TL-20 with ID 2100111075
    2023-01-18 08:30:02.786 - info: sbfspot.0 (13087) all done ...
    2023-01-18 08:30:02.788 - info: sbfspot.0 (13087) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-01-18 08:30:03.309 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-01-18 08:45:00.028 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 started with pid 13106
    2023-01-18 08:45:01.407 - info: sbfspot.0 (13106) starting. Version 4.1.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v16.19.0, js-controller: 4.0.24
    2023-01-18 08:45:01.565 - info: sbfspot.0 (13106) start with mySQL
    2023-01-18 08:45:01.614 - info: sbfspot.0 (13106) got data from with ID 0
    2023-01-18 08:45:01.922 - info: sbfspot.0 (13106) got data from SB 4000TL-20 with ID 2100101691
    2023-01-18 08:45:02.280 - info: sbfspot.0 (13106) got data from SB 4000TL-20 with ID 2100111075
    2023-01-18 08:45:02.615 - info: sbfspot.0 (13106) all done ...
    2023-01-18 08:45:02.617 - info: sbfspot.0 (13106) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-01-18 08:45:03.146 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-01-18 08:50:51.822 - warn: wled.0 (11253) State attribute definition missing for : liveseg with value : -1
    2023-01-18 08:50:59.143 - warn: wled.0 (11253) State attribute definition missing for : liveseg with value : -1
    2023-01-18 08:51:01.156 - warn: wled.0 (11253) State attribute definition missing for : liveseg with value : -1
    2023-01-18 09:00:00.035 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 started with pid 13126
    2023-01-18 09:00:01.502 - info: sbfspot.0 (13126) starting. Version 4.1.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v16.19.0, js-controller: 4.0.24
    2023-01-18 09:00:01.642 - info: sbfspot.0 (13126) start with mySQL
    2023-01-18 09:00:01.691 - info: sbfspot.0 (13126) got data from with ID 0
    2023-01-18 09:00:02.019 - info: sbfspot.0 (13126) got data from SB 4000TL-20 with ID 2100101691
    2023-01-18 09:00:02.340 - info: sbfspot.0 (13126) got data from SB 4000TL-20 with ID 2100111075
    2023-01-18 09:00:02.664 - info: sbfspot.0 (13126) all done ...
    2023-01-18 09:00:02.665 - info: sbfspot.0 (13126) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-01-18 09:00:03.209 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-01-18 09:15:00.021 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 started with pid 13143
    2023-01-18 09:15:01.166 - info: sbfspot.0 (13143) starting. Version 4.1.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v16.19.0, js-controller: 4.0.24
    2023-01-18 09:15:01.277 - info: sbfspot.0 (13143) start with mySQL
    2023-01-18 09:15:01.313 - info: sbfspot.0 (13143) got data from with ID 0
    2023-01-18 09:15:01.551 - info: sbfspot.0 (13143) got data from SB 4000TL-20 with ID 2100101691
    2023-01-18 09:15:01.810 - info: sbfspot.0 (13143) got data from SB 4000TL-20 with ID 2100111075
    2023-01-18 09:15:02.057 - info: sbfspot.0 (13143) all done ...
    2023-01-18 09:15:02.058 - info: sbfspot.0 (13143) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-01-18 09:15:02.578 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-01-18 09:17:56.764 - warn: wled.0 (11253) State attribute definition missing for : liveseg with value : -1
    2023-01-18 09:17:56.814 - warn: wled.0 (11253) State attribute definition missing for : cpalcount with value : 0
    2023-01-18 09:17:56.815 - warn: wled.0 (11253) State attribute definition missing for : 0 with value : 0
    2023-01-18 09:17:56.900 - warn: wled.0 (11253) State attribute definition missing for : c1 with value : 128
    2023-01-18 09:17:56.900 - warn: wled.0 (11253) State attribute definition missing for : c2 with value : 128
    2023-01-18 09:17:56.944 - warn: wled.0 (11253) State attribute definition missing for : c3 with value : 16
    2023-01-18 09:17:56.990 - warn: wled.0 (11253) State attribute definition missing for : o1 with value : false
    2023-01-18 09:17:56.991 - warn: wled.0 (11253) State attribute definition missing for : o2 with value : false
    2023-01-18 09:17:57.036 - warn: wled.0 (11253) State attribute definition missing for : o3 with value : false
    2023-01-18 09:17:57.037 - warn: wled.0 (11253) State attribute definition missing for : si with value : 0
    2023-01-18 09:17:57.080 - warn: wled.0 (11253) State attribute definition missing for : m12 with value : 0
    2023-01-18 09:17:59.263 - warn: wled.0 (11253) State attribute definition missing for : liveseg with value : -1
    2023-01-18 09:17:59.310 - warn: wled.0 (11253) State attribute definition missing for : cpalcount with value : 0
    2023-01-18 09:17:59.311 - warn: wled.0 (11253) State attribute definition missing for : 0 with value : 0
    2023-01-18 09:17:59.395 - warn: wled.0 (11253) State attribute definition missing for : c1 with value : 128
    2023-01-18 09:17:59.396 - warn: wled.0 (11253) State attribute definition missing for : c2 with value : 128
    2023-01-18 09:17:59.440 - warn: wled.0 (11253) State attribute definition missing for : c3 with value : 16
    2023-01-18 09:17:59.486 - warn: wled.0 (11253) State attribute definition missing for : o1 with value : false
    2023-01-18 09:17:59.487 - warn: wled.0 (11253) State attribute definition missing for : o2 with value : false
    2023-01-18 09:17:59.490 - warn: wled.0 (11253) State attribute definition missing for : o3 with value : false
    2023-01-18 09:17:59.532 - warn: wled.0 (11253) State attribute definition missing for : si with value : 0
    2023-01-18 09:17:59.533 - warn: wled.0 (11253) State attribute definition missing for : m12 with value : 0
    2023-01-18 09:30:00.021 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 started with pid 13167
    2023-01-18 09:30:01.093 - info: sbfspot.0 (13167) starting. Version 4.1.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v16.19.0, js-controller: 4.0.24
    2023-01-18 09:30:01.202 - info: sbfspot.0 (13167) start with mySQL
    2023-01-18 09:30:01.246 - info: sbfspot.0 (13167) got data from with ID 0
    2023-01-18 09:30:01.503 - info: sbfspot.0 (13167) got data from SB 4000TL-20 with ID 2100101691
    2023-01-18 09:30:01.768 - info: sbfspot.0 (13167) got data from SB 4000TL-20 with ID 2100111075
    2023-01-18 09:30:02.018 - info: sbfspot.0 (13167) all done ...
    2023-01-18 09:30:02.019 - info: sbfspot.0 (13167) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-01-18 09:30:02.537 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-01-18 09:45:00.023 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 started with pid 13185
    2023-01-18 09:45:01.079 - info: sbfspot.0 (13185) starting. Version 4.1.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v16.19.0, js-controller: 4.0.24
    2023-01-18 09:45:01.204 - info: sbfspot.0 (13185) start with mySQL
    2023-01-18 09:45:01.260 - info: sbfspot.0 (13185) got data from with ID 0
    2023-01-18 09:45:01.526 - info: sbfspot.0 (13185) got data from SB 4000TL-20 with ID 2100101691
    2023-01-18 09:45:01.788 - info: sbfspot.0 (13185) got data from SB 4000TL-20 with ID 2100111075
    2023-01-18 09:45:02.051 - info: sbfspot.0 (13185) all done ...
    2023-01-18 09:45:02.052 - info: sbfspot.0 (13185) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-01-18 09:45:02.571 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-01-18 10:00:00.045 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 started with pid 13204
    2023-01-18 10:00:01.194 - info: sbfspot.0 (13204) starting. Version 4.1.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v16.19.0, js-controller: 4.0.24
    2023-01-18 10:00:01.302 - info: sbfspot.0 (13204) start with mySQL
    2023-01-18 10:00:01.334 - info: sbfspot.0 (13204) got data from with ID 0
    2023-01-18 10:00:01.567 - info: sbfspot.0 (13204) got data from SB 4000TL-20 with ID 2100101691
    2023-01-18 10:00:01.798 - info: sbfspot.0 (13204) got data from SB 4000TL-20 with ID 2100111075
    2023-01-18 10:00:02.059 - info: sbfspot.0 (13204) all done ...
    2023-01-18 10:00:02.060 - info: sbfspot.0 (13204) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-01-18 10:00:02.579 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-01-18 10:15:00.022 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 started with pid 13222
    2023-01-18 10:15:01.121 - info: sbfspot.0 (13222) starting. Version 4.1.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v16.19.0, js-controller: 4.0.24
    2023-01-18 10:15:01.265 - info: sbfspot.0 (13222) start with mySQL
    2023-01-18 10:15:01.313 - info: sbfspot.0 (13222) got data from with ID 0
    2023-01-18 10:15:01.547 - info: sbfspot.0 (13222) got data from SB 4000TL-20 with ID 2100101691
    2023-01-18 10:15:01.765 - info: sbfspot.0 (13222) got data from SB 4000TL-20 with ID 2100111075
    2023-01-18 10:15:01.982 - info: sbfspot.0 (13222) all done ...
    2023-01-18 10:15:01.984 - info: sbfspot.0 (13222) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-01-18 10:15:02.505 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-01-18 10:30:00.021 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 started with pid 13247
    2023-01-18 10:30:01.154 - info: sbfspot.0 (13247) starting. Version 4.1.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v16.19.0, js-controller: 4.0.24
    2023-01-18 10:30:01.266 - info: sbfspot.0 (13247) start with mySQL
    2023-01-18 10:30:01.310 - info: sbfspot.0 (13247) got data from with ID 0
    2023-01-18 10:30:01.567 - info: sbfspot.0 (13247) got data from SB 4000TL-20 with ID 2100101691
    2023-01-18 10:30:01.815 - info: sbfspot.0 (13247) got data from SB 4000TL-20 with ID 2100111075
    2023-01-18 10:30:02.061 - info: sbfspot.0 (13247) all done ...
    2023-01-18 10:30:02.062 - info: sbfspot.0 (13247) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-01-18 10:30:02.586 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-01-18 10:45:00.019 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 started with pid 13266
    2023-01-18 10:45:01.085 - info: sbfspot.0 (13266) starting. Version 4.1.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v16.19.0, js-controller: 4.0.24
    2023-01-18 10:45:01.189 - info: sbfspot.0 (13266) start with mySQL
    2023-01-18 10:45:01.229 - info: sbfspot.0 (13266) got data from with ID 0
    2023-01-18 10:45:01.452 - info: sbfspot.0 (13266) got data from SB 4000TL-20 with ID 2100101691
    2023-01-18 10:45:01.685 - info: sbfspot.0 (13266) got data from SB 4000TL-20 with ID 2100111075
    2023-01-18 10:45:01.932 - info: sbfspot.0 (13266) all done ...
    2023-01-18 10:45:01.933 - info: sbfspot.0 (13266) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-01-18 10:45:02.453 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-01-18 11:00:00.024 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 started with pid 13285
    2023-01-18 11:00:01.187 - info: sbfspot.0 (13285) starting. Version 4.1.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v16.19.0, js-controller: 4.0.24
    2023-01-18 11:00:01.291 - info: sbfspot.0 (13285) start with mySQL
    2023-01-18 11:00:01.329 - info: sbfspot.0 (13285) got data from with ID 0
    2023-01-18 11:00:01.571 - info: sbfspot.0 (13285) got data from SB 4000TL-20 with ID 2100101691
    2023-01-18 11:00:01.819 - info: sbfspot.0 (13285) got data from SB 4000TL-20 with ID 2100111075
    2023-01-18 11:00:02.038 - info: sbfspot.0 (13285) all done ...
    2023-01-18 11:00:02.039 - info: sbfspot.0 (13285) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-01-18 11:00:02.561 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-01-18 11:15:00.023 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 started with pid 13303
    2023-01-18 11:15:01.087 - info: sbfspot.0 (13303) starting. Version 4.1.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v16.19.0, js-controller: 4.0.24
    2023-01-18 11:15:01.193 - info: sbfspot.0 (13303) start with mySQL
    2023-01-18 11:15:01.229 - info: sbfspot.0 (13303) got data from with ID 0
    2023-01-18 11:15:01.487 - info: sbfspot.0 (13303) got data from SB 4000TL-20 with ID 2100101691
    2023-01-18 11:15:01.738 - info: sbfspot.0 (13303) got data from SB 4000TL-20 with ID 2100111075
    2023-01-18 11:15:01.971 - info: sbfspot.0 (13303) all done ...
    2023-01-18 11:15:01.972 - info: sbfspot.0 (13303) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-01-18 11:15:02.491 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-01-18 11:30:00.018 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 started with pid 13326
    2023-01-18 11:30:01.209 - info: sbfspot.0 (13326) starting. Version 4.1.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v16.19.0, js-controller: 4.0.24
    2023-01-18 11:30:01.318 - info: sbfspot.0 (13326) start with mySQL
    2023-01-18 11:30:01.350 - info: sbfspot.0 (13326) got data from with ID 0
    2023-01-18 11:30:01.587 - info: sbfspot.0 (13326) got data from SB 4000TL-20 with ID 2100101691
    2023-01-18 11:30:01.831 - info: sbfspot.0 (13326) got data from SB 4000TL-20 with ID 2100111075
    2023-01-18 11:30:02.044 - info: sbfspot.0 (13326) all done ...
    2023-01-18 11:30:02.045 - info: sbfspot.0 (13326) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-01-18 11:30:02.565 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-01-18 11:45:00.022 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 started with pid 13345
    2023-01-18 11:45:01.140 - info: sbfspot.0 (13345) starting. Version 4.1.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v16.19.0, js-controller: 4.0.24
    2023-01-18 11:45:01.242 - info: sbfspot.0 (13345) start with mySQL
    2023-01-18 11:45:01.284 - info: sbfspot.0 (13345) got data from with ID 0
    2023-01-18 11:45:01.500 - info: sbfspot.0 (13345) got data from SB 4000TL-20 with ID 2100101691
    2023-01-18 11:45:01.729 - info: sbfspot.0 (13345) got data from SB 4000TL-20 with ID 2100111075
    2023-01-18 11:45:01.985 - info: sbfspot.0 (13345) all done ...
    2023-01-18 11:45:01.986 - info: sbfspot.0 (13345) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-01-18 11:45:02.505 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-01-18 12:00:00.035 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 started with pid 13364
    2023-01-18 12:00:01.160 - info: sbfspot.0 (13364) starting. Version 4.1.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v16.19.0, js-controller: 4.0.24
    2023-01-18 12:00:01.269 - info: sbfspot.0 (13364) start with mySQL
    2023-01-18 12:00:01.303 - info: sbfspot.0 (13364) got data from with ID 0
    2023-01-18 12:00:01.559 - info: sbfspot.0 (13364) got data from SB 4000TL-20 with ID 2100101691
    2023-01-18 12:00:01.834 - info: sbfspot.0 (13364) got data from SB 4000TL-20 with ID 2100111075
    2023-01-18 12:00:02.076 - info: sbfspot.0 (13364) all done ...
    2023-01-18 12:00:02.077 - info: sbfspot.0 (13364) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-01-18 12:00:02.599 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-01-18 12:15:00.016 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 started with pid 13384
    2023-01-18 12:15:01.144 - info: sbfspot.0 (13384) starting. Version 4.1.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v16.19.0, js-controller: 4.0.24
    2023-01-18 12:15:01.255 - info: sbfspot.0 (13384) start with mySQL
    2023-01-18 12:15:01.289 - info: sbfspot.0 (13384) got data from with ID 0
    2023-01-18 12:15:01.519 - info: sbfspot.0 (13384) got data from SB 4000TL-20 with ID 2100101691
    2023-01-18 12:15:01.745 - info: sbfspot.0 (13384) got data from SB 4000TL-20 with ID 2100111075
    2023-01-18 12:15:01.968 - info: sbfspot.0 (13384) all done ...
    2023-01-18 12:15:01.969 - info: sbfspot.0 (13384) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-01-18 12:15:02.497 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-01-18 12:30:00.024 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 started with pid 13406
    2023-01-18 12:30:01.140 - info: sbfspot.0 (13406) starting. Version 4.1.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v16.19.0, js-controller: 4.0.24
    2023-01-18 12:30:01.244 - info: sbfspot.0 (13406) start with mySQL
    2023-01-18 12:30:01.287 - info: sbfspot.0 (13406) got data from with ID 0
    2023-01-18 12:30:01.506 - info: sbfspot.0 (13406) got data from SB 4000TL-20 with ID 2100101691
    2023-01-18 12:30:01.726 - info: sbfspot.0 (13406) got data from SB 4000TL-20 with ID 2100111075
    2023-01-18 12:30:01.961 - info: sbfspot.0 (13406) all done ...
    2023-01-18 12:30:01.962 - info: sbfspot.0 (13406) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-01-18 12:30:02.482 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-01-18 12:45:00.018 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 started with pid 13425
    2023-01-18 12:45:01.148 - info: sbfspot.0 (13425) starting. Version 4.1.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v16.19.0, js-controller: 4.0.24
    2023-01-18 12:45:01.248 - info: sbfspot.0 (13425) start with mySQL
    2023-01-18 12:45:01.290 - info: sbfspot.0 (13425) got data from with ID 0
    2023-01-18 12:45:01.535 - info: sbfspot.0 (13425) got data from SB 4000TL-20 with ID 2100101691
    2023-01-18 12:45:01.787 - info: sbfspot.0 (13425) got data from SB 4000TL-20 with ID 2100111075
    2023-01-18 12:45:02.027 - info: sbfspot.0 (13425) all done ...
    2023-01-18 12:45:02.028 - info: sbfspot.0 (13425) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-01-18 12:45:02.546 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-01-18 13:00:00.024 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 started with pid 13444
    2023-01-18 13:00:01.070 - info: sbfspot.0 (13444) starting. Version 4.1.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v16.19.0, js-controller: 4.0.24
    2023-01-18 13:00:01.177 - info: sbfspot.0 (13444) start with mySQL
    2023-01-18 13:00:01.209 - info: sbfspot.0 (13444) got data from with ID 0
    2023-01-18 13:00:01.445 - info: sbfspot.0 (13444) got data from SB 4000TL-20 with ID 2100101691
    2023-01-18 13:00:01.679 - info: sbfspot.0 (13444) got data from SB 4000TL-20 with ID 2100111075
    2023-01-18 13:00:01.945 - info: sbfspot.0 (13444) all done ...
    2023-01-18 13:00:01.946 - info: sbfspot.0 (13444) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-01-18 13:00:02.465 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-01-18 13:09:09.145 - warn: wled.0 (11253) State attribute definition missing for : liveseg with value : -1
    2023-01-18 13:09:09.196 - warn: wled.0 (11253) State attribute definition missing for : cpalcount with value : 0
    2023-01-18 13:09:09.197 - warn: wled.0 (11253) State attribute definition missing for : 0 with value : 0
    2023-01-18 13:09:09.285 - warn: wled.0 (11253) State attribute definition missing for : c1 with value : 128
    2023-01-18 13:09:09.286 - warn: wled.0 (11253) State attribute definition missing for : c2 with value : 128
    2023-01-18 13:09:09.330 - warn: wled.0 (11253) State attribute definition missing for : c3 with value : 16
    2023-01-18 13:09:09.379 - warn: wled.0 (11253) State attribute definition missing for : o1 with value : false
    2023-01-18 13:09:09.380 - warn: wled.0 (11253) State attribute definition missing for : o2 with value : false
    2023-01-18 13:09:09.424 - warn: wled.0 (11253) State attribute definition missing for : o3 with value : false
    2023-01-18 13:09:09.427 - warn: wled.0 (11253) State attribute definition missing for : si with value : 0
    2023-01-18 13:09:09.429 - warn: wled.0 (11253) State attribute definition missing for : m12 with value : 0
    2023-01-18 13:15:00.021 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 started with pid 13462
    2023-01-18 13:15:01.146 - info: sbfspot.0 (13462) starting. Version 4.1.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v16.19.0, js-controller: 4.0.24
    2023-01-18 13:15:01.271 - info: sbfspot.0 (13462) start with mySQL
    2023-01-18 13:15:01.303 - info: sbfspot.0 (13462) got data from with ID 0
    2023-01-18 13:15:01.522 - info: sbfspot.0 (13462) got data from SB 4000TL-20 with ID 2100101691
    2023-01-18 13:15:01.762 - info: sbfspot.0 (13462) got data from SB 4000TL-20 with ID 2100111075
    2023-01-18 13:15:02.029 - info: sbfspot.0 (13462) all done ...
    2023-01-18 13:15:02.030 - info: sbfspot.0 (13462) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-01-18 13:15:02.549 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-01-18 13:30:00.028 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 started with pid 13484
    2023-01-18 13:30:01.118 - info: sbfspot.0 (13484) starting. Version 4.1.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v16.19.0, js-controller: 4.0.24
    2023-01-18 13:30:01.237 - info: sbfspot.0 (13484) start with mySQL
    2023-01-18 13:30:01.280 - info: sbfspot.0 (13484) got data from with ID 0
    2023-01-18 13:30:01.560 - info: sbfspot.0 (13484) got data from SB 4000TL-20 with ID 2100101691
    2023-01-18 13:30:01.828 - info: sbfspot.0 (13484) got data from SB 4000TL-20 with ID 2100111075
    2023-01-18 13:30:02.062 - info: sbfspot.0 (13484) all done ...
    2023-01-18 13:30:02.063 - info: sbfspot.0 (13484) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-01-18 13:30:02.580 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-01-18 13:45:00.025 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 started with pid 13503
    2023-01-18 13:45:01.094 - info: sbfspot.0 (13503) starting. Version 4.1.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v16.19.0, js-controller: 4.0.24
    2023-01-18 13:45:01.213 - info: sbfspot.0 (13503) start with mySQL
    2023-01-18 13:45:01.246 - info: sbfspot.0 (13503) got data from with ID 0
    2023-01-18 13:45:01.530 - info: sbfspot.0 (13503) got data from SB 4000TL-20 with ID 2100101691
    2023-01-18 13:45:01.810 - info: sbfspot.0 (13503) got data from SB 4000TL-20 with ID 2100111075
    2023-01-18 13:45:02.062 - info: sbfspot.0 (13503) all done ...
    2023-01-18 13:45:02.063 - info: sbfspot.0 (13503) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-01-18 13:45:02.581 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-01-18 14:00:00.018 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 started with pid 13522
    2023-01-18 14:00:01.149 - info: sbfspot.0 (13522) starting. Version 4.1.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v16.19.0, js-controller: 4.0.24
    2023-01-18 14:00:01.261 - info: sbfspot.0 (13522) start with mySQL
    2023-01-18 14:00:01.296 - info: sbfspot.0 (13522) got data from with ID 0
    2023-01-18 14:00:01.544 - info: sbfspot.0 (13522) got data from SB 4000TL-20 with ID 2100101691
    2023-01-18 14:00:01.787 - info: sbfspot.0 (13522) got data from SB 4000TL-20 with ID 2100111075
    2023-01-18 14:00:02.050 - info: sbfspot.0 (13522) all done ...
    2023-01-18 14:00:02.051 - info: sbfspot.0 (13522) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-01-18 14:00:02.574 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-01-18 14:15:00.025 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 started with pid 13541
    2023-01-18 14:15:01.113 - info: sbfspot.0 (13541) starting. Version 4.1.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v16.19.0, js-controller: 4.0.24
    2023-01-18 14:15:01.216 - info: sbfspot.0 (13541) start with mySQL
    2023-01-18 14:15:01.254 - info: sbfspot.0 (13541) got data from with ID 0
    2023-01-18 14:15:01.493 - info: sbfspot.0 (13541) got data from SB 4000TL-20 with ID 2100101691
    2023-01-18 14:15:01.715 - info: sbfspot.0 (13541) got data from SB 4000TL-20 with ID 2100111075
    2023-01-18 14:15:01.976 - info: sbfspot.0 (13541) all done ...
    2023-01-18 14:15:01.977 - info: sbfspot.0 (13541) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-01-18 14:15:02.497 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-01-18 14:30:00.027 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 started with pid 13565
    2023-01-18 14:30:01.127 - info: sbfspot.0 (13565) starting. Version 4.1.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v16.19.0, js-controller: 4.0.24
    2023-01-18 14:30:01.231 - info: sbfspot.0 (13565) start with mySQL
    2023-01-18 14:30:01.271 - info: sbfspot.0 (13565) got data from with ID 0
    2023-01-18 14:30:01.550 - info: sbfspot.0 (13565) got data from SB 4000TL-20 with ID 2100101691
    2023-01-18 14:30:01.800 - info: sbfspot.0 (13565) got data from SB 4000TL-20 with ID 2100111075
    2023-01-18 14:30:02.037 - info: sbfspot.0 (13565) all done ...
    2023-01-18 14:30:02.038 - info: sbfspot.0 (13565) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-01-18 14:30:02.558 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-01-18 14:45:00.021 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 started with pid 13584
    2023-01-18 14:45:01.130 - info: sbfspot.0 (13584) starting. Version 4.1.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v16.19.0, js-controller: 4.0.24
    2023-01-18 14:45:01.233 - info: sbfspot.0 (13584) start with mySQL
    2023-01-18 14:45:01.273 - info: sbfspot.0 (13584) got data from with ID 0
    2023-01-18 14:45:01.491 - info: sbfspot.0 (13584) got data from SB 4000TL-20 with ID 2100101691
    2023-01-18 14:45:01.739 - info: sbfspot.0 (13584) got data from SB 4000TL-20 with ID 2100111075
    2023-01-18 14:45:01.965 - info: sbfspot.0 (13584) all done ...
    2023-01-18 14:45:01.966 - info: sbfspot.0 (13584) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-01-18 14:45:02.484 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-01-18 15:00:00.024 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 started with pid 13603
    2023-01-18 15:00:01.144 - info: sbfspot.0 (13603) starting. Version 4.1.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v16.19.0, js-controller: 4.0.24
    2023-01-18 15:00:01.249 - info: sbfspot.0 (13603) start with mySQL
    2023-01-18 15:00:01.283 - info: sbfspot.0 (13603) got data from with ID 0
    2023-01-18 15:00:01.554 - info: sbfspot.0 (13603) got data from SB 4000TL-20 with ID 2100101691
    2023-01-18 15:00:01.804 - info: sbfspot.0 (13603) got data from SB 4000TL-20 with ID 2100111075
    2023-01-18 15:00:02.025 - info: sbfspot.0 (13603) all done ...
    2023-01-18 15:00:02.026 - info: sbfspot.0 (13603) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-01-18 15:00:02.544 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-01-18 15:08:32.588 - warn: wled.0 (11253) State attribute definition missing for : liveseg with value : -1
    2023-01-18 15:08:32.634 - warn: wled.0 (11253) State attribute definition missing for : cpalcount with value : 0
    2023-01-18 15:08:32.635 - warn: wled.0 (11253) State attribute definition missing for : 0 with value : 0
    2023-01-18 15:08:32.717 - warn: wled.0 (11253) State attribute definition missing for : c1 with value : 128
    2023-01-18 15:08:32.719 - warn: wled.0 (11253) State attribute definition missing for : c2 with value : 128
    2023-01-18 15:08:32.764 - warn: wled.0 (11253) State attribute definition missing for : c3 with value : 16
    2023-01-18 15:08:32.810 - warn: wled.0 (11253) State attribute definition missing for : o1 with value : false
    2023-01-18 15:08:32.811 - warn: wled.0 (11253) State attribute definition missing for : o2 with value : false
    2023-01-18 15:08:32.856 - warn: wled.0 (11253) State attribute definition missing for : o3 with value : false
    2023-01-18 15:08:32.857 - warn: wled.0 (11253) State attribute definition missing for : si with value : 0
    2023-01-18 15:08:32.901 - warn: wled.0 (11253) State attribute definition missing for : m12 with value : 0
    2023-01-18 15:15:00.026 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 started with pid 13622
    2023-01-18 15:15:01.146 - info: sbfspot.0 (13622) starting. Version 4.1.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v16.19.0, js-controller: 4.0.24
    2023-01-18 15:15:01.254 - info: sbfspot.0 (13622) start with mySQL
    2023-01-18 15:15:01.295 - info: sbfspot.0 (13622) got data from with ID 0
    2023-01-18 15:15:01.581 - info: sbfspot.0 (13622) got data from SB 4000TL-20 with ID 2100101691
    2023-01-18 15:15:01.805 - info: sbfspot.0 (13622) got data from SB 4000TL-20 with ID 2100111075
    2023-01-18 15:15:02.024 - info: sbfspot.0 (13622) all done ...
    2023-01-18 15:15:02.025 - info: sbfspot.0 (13622) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-01-18 15:15:02.544 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-01-18 15:30:00.019 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 started with pid 13644
    2023-01-18 15:30:01.186 - info: sbfspot.0 (13644) starting. Version 4.1.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v16.19.0, js-controller: 4.0.24
    2023-01-18 15:30:01.302 - info: sbfspot.0 (13644) start with mySQL
    2023-01-18 15:30:01.350 - info: sbfspot.0 (13644) got data from with ID 0
    2023-01-18 15:30:01.589 - info: sbfspot.0 (13644) got data from SB 4000TL-20 with ID 2100101691
    2023-01-18 15:30:01.844 - info: sbfspot.0 (13644) got data from SB 4000TL-20 with ID 2100111075
    2023-01-18 15:30:02.095 - info: sbfspot.0 (13644) all done ...
    2023-01-18 15:30:02.096 - info: sbfspot.0 (13644) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-01-18 15:30:02.618 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-01-18 15:34:21.089 - warn: hmip.0 (7979) ws connection closed (0) - code: 1006 - reason:
    2023-01-18 15:34:31.156 - warn: hmip.0 (7979) ws connection error (0): Error: connect ECONNREFUSED 62.113.249.105:8888
    2023-01-18 15:34:31.156 - warn: hmip.0 (7979) ws connection closed (2) - code: 1006 - reason:
    2023-01-18 15:34:42.457 - info: hmip.0 (7979) ws connection opened
    2023-01-18 15:34:42.543 - warn: hmip.0 (7979) ws connection closed (3) - code: 1000 - reason:
    2023-01-18 15:34:53.807 - info: hmip.0 (7979) ws connection opened
    2023-01-18 15:34:53.830 - warn: hmip.0 (7979) ws connection closed (1) - code: 1000 - reason:
    2023-01-18 15:35:05.089 - info: hmip.0 (7979) ws connection opened
    2023-01-18 15:35:05.114 - warn: hmip.0 (7979) ws connection closed (1) - code: 1000 - reason:
    2023-01-18 15:35:16.482 - info: hmip.0 (7979) ws connection opened
    2023-01-18 15:35:16.519 - warn: hmip.0 (7979) ws connection closed (1) - code: 1000 - reason:
    2023-01-18 15:35:27.845 - info: hmip.0 (7979) ws connection opened
    2023-01-18 15:35:27.886 - warn: hmip.0 (7979) ws connection closed (1) - code: 1000 - reason:
    2023-01-18 15:35:39.393 - info: hmip.0 (7979) ws connection opened
    2023-01-18 15:35:39.507 - warn: hmip.0 (7979) ws connection closed (1) - code: 1000 - reason:
    2023-01-18 15:35:50.413 - info: hmip.0 (7979) ws connection opened
    2023-01-18 15:35:50.449 - warn: hmip.0 (7979) ws connection closed (1) - code: 1000 - reason:
    2023-01-18 15:36:01.347 - info: hmip.0 (7979) ws connection opened
    2023-01-18 15:36:01.383 - warn: hmip.0 (7979) ws connection closed (1) - code: 1000 - reason:
    2023-01-18 15:36:12.284 - info: hmip.0 (7979) ws connection opened
    2023-01-18 15:36:12.310 - warn: hmip.0 (7979) ws connection closed (1) - code: 1000 - reason:
    2023-01-18 15:36:23.160 - info: hmip.0 (7979) ws connection opened
    2023-01-18 15:36:23.194 - warn: hmip.0 (7979) ws connection closed (1) - code: 1000 - reason:
    2023-01-18 15:36:34.012 - info: hmip.0 (7979) ws connection opened
    2023-01-18 15:36:34.041 - warn: hmip.0 (7979) ws connection closed (1) - code: 1000 - reason:
    2023-01-18 15:36:44.803 - info: hmip.0 (7979) ws connection opened
    2023-01-18 15:36:44.824 - warn: hmip.0 (7979) ws connection closed (1) - code: 1000 - reason:
    2023-01-18 15:36:55.562 - info: hmip.0 (7979) ws connection opened
    2023-01-18 15:36:55.615 - warn: hmip.0 (7979) ws connection closed (1) - code: 1000 - reason:
    2023-01-18 15:37:06.260 - info: hmip.0 (7979) ws connection opened
    2023-01-18 15:37:06.290 - warn: hmip.0 (7979) ws connection closed (1) - code: 1000 - reason:
    2023-01-18 15:37:16.847 - info: hmip.0 (7979) ws connection opened
    2023-01-18 15:37:16.921 - warn: hmip.0 (7979) ws connection closed (1) - code: 1000 - reason:
    2023-01-18 15:37:27.525 - info: hmip.0 (7979) ws connection opened
    2023-01-18 15:37:27.553 - warn: hmip.0 (7979) ws connection closed (1) - code: 1000 - reason:
    2023-01-18 15:37:38.103 - info: hmip.0 (7979) ws connection opened
    2023-01-18 15:37:38.127 - warn: hmip.0 (7979) ws connection closed (1) - code: 1000 - reason:
    2023-01-18 15:37:48.683 - info: hmip.0 (7979) ws connection opened
    2023-01-18 15:37:48.717 - warn: hmip.0 (7979) ws connection closed (1) - code: 1000 - reason:
    2023-01-18 15:37:59.111 - info: hmip.0 (7979) ws connection opened
    2023-01-18 15:37:59.153 - warn: hmip.0 (7979) ws connection closed (1) - code: 1000 - reason:
    2023-01-18 15:38:09.571 - info: hmip.0 (7979) ws connection opened
    2023-01-18 15:38:09.601 - warn: hmip.0 (7979) ws connection closed (1) - code: 1000 - reason:
    2023-01-18 15:38:20.572 - info: hmip.0 (7979) ws connection opened
    2023-01-18 15:38:20.645 - warn: hmip.0 (7979) ws connection closed (1) - code: 1000 - reason:
    2023-01-18 15:38:30.809 - info: hmip.0 (7979) ws connection opened
    2023-01-18 15:38:30.840 - warn: hmip.0 (7979) ws connection closed (1) - code: 1000 - reason:
    2023-01-18 15:38:40.957 - info: hmip.0 (7979) ws connection opened
    2023-01-18 15:38:41.003 - warn: hmip.0 (7979) ws connection closed (1) - code: 1000 - reason:
    2023-01-18 15:38:51.296 - info: hmip.0 (7979) ws connection opened
    2023-01-18 15:38:51.338 - warn: hmip.0 (7979) ws connection closed (1) - code: 1000 - reason:
    2023-01-18 15:39:01.772 - info: hmip.0 (7979) ws connection opened
    2023-01-18 15:39:01.808 - warn: hmip.0 (7979) ws connection closed (1) - code: 1000 - reason:
    2023-01-18 15:39:12.196 - info: hmip.0 (7979) ws connection opened
    2023-01-18 15:39:12.224 - warn: hmip.0 (7979) ws connection closed (1) - code: 1000 - reason:
    2023-01-18 15:39:22.582 - info: hmip.0 (7979) ws connection opened
    2023-01-18 15:39:22.617 - warn: hmip.0 (7979) ws connection closed (1) - code: 1000 - reason:
    2023-01-18 15:39:33.411 - info: hmip.0 (7979) ws connection opened
    2023-01-18 15:39:33.567 - warn: hmip.0 (7979) ws connection closed (1) - code: 1000 - reason:
    2023-01-18 15:39:43.701 - info: hmip.0 (7979) ws connection opened
    2023-01-18 15:39:43.727 - warn: hmip.0 (7979) ws connection closed (1) - code: 1000 - reason:
    2023-01-18 15:39:53.847 - info: hmip.0 (7979) ws connection opened
    2023-01-18 15:39:53.872 - warn: hmip.0 (7979) ws connection closed (1) - code: 1000 - reason:
    2023-01-18 15:40:04.128 - info: hmip.0 (7979) ws connection opened
    2023-01-18 15:40:04.197 - warn: hmip.0 (7979) ws connection closed (1) - code: 1000 - reason:
    2023-01-18 15:40:14.308 - info: hmip.0 (7979) ws connection opened
    2023-01-18 15:40:14.329 - warn: hmip.0 (7979) ws connection closed (1) - code: 1000 - reason:
    2023-01-18 15:40:24.462 - info: hmip.0 (7979) ws connection opened
    2023-01-18 15:45:00.029 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 started with pid 13663
    2023-01-18 15:45:01.177 - info: sbfspot.0 (13663) starting. Version 4.1.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v16.19.0, js-controller: 4.0.24
    2023-01-18 15:45:01.282 - info: sbfspot.0 (13663) start with mySQL
    2023-01-18 15:45:01.322 - info: sbfspot.0 (13663) got data from with ID 0
    2023-01-18 15:45:01.592 - info: sbfspot.0 (13663) got data from SB 4000TL-20 with ID 2100101691
    2023-01-18 15:45:01.870 - info: sbfspot.0 (13663) got data from SB 4000TL-20 with ID 2100111075
    2023-01-18 15:45:02.111 - info: sbfspot.0 (13663) all done ...
    2023-01-18 15:45:02.112 - info: sbfspot.0 (13663) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-01-18 15:45:02.630 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-01-18 16:00:00.037 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 started with pid 13683
    2023-01-18 16:00:01.211 - info: sbfspot.0 (13683) starting. Version 4.1.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v16.19.0, js-controller: 4.0.24
    2023-01-18 16:00:01.356 - info: sbfspot.0 (13683) start with mySQL
    2023-01-18 16:00:01.398 - info: sbfspot.0 (13683) got data from with ID 0
    2023-01-18 16:00:01.638 - info: sbfspot.0 (13683) got data from SB 4000TL-20 with ID 2100101691
    2023-01-18 16:00:01.864 - info: sbfspot.0 (13683) got data from SB 4000TL-20 with ID 2100111075
    2023-01-18 16:00:02.091 - info: sbfspot.0 (13683) all done ...
    2023-01-18 16:00:02.092 - info: sbfspot.0 (13683) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-01-18 16:00:02.612 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-01-18 16:15:00.023 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 started with pid 13701
    2023-01-18 16:15:01.230 - info: sbfspot.0 (13701) starting. Version 4.1.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v16.19.0, js-controller: 4.0.24
    2023-01-18 16:15:01.339 - info: sbfspot.0 (13701) start with mySQL
    2023-01-18 16:15:01.372 - info: sbfspot.0 (13701) got data from with ID 0
    2023-01-18 16:15:01.620 - info: sbfspot.0 (13701) got data from SB 4000TL-20 with ID 2100101691
    2023-01-18 16:15:01.851 - info: sbfspot.0 (13701) got data from SB 4000TL-20 with ID 2100111075
    2023-01-18 16:15:02.081 - info: sbfspot.0 (13701) all done ...
    2023-01-18 16:15:02.082 - info: sbfspot.0 (13701) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-01-18 16:15:02.603 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-01-18 16:30:00.026 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 started with pid 13724
    2023-01-18 16:30:01.197 - info: sbfspot.0 (13724) starting. Version 4.1.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v16.19.0, js-controller: 4.0.24
    2023-01-18 16:30:01.306 - info: sbfspot.0 (13724) start with mySQL
    2023-01-18 16:30:01.342 - info: sbfspot.0 (13724) got data from with ID 0
    2023-01-18 16:30:01.603 - info: sbfspot.0 (13724) got data from SB 4000TL-20 with ID 2100101691
    2023-01-18 16:30:01.883 - info: sbfspot.0 (13724) got data from SB 4000TL-20 with ID 2100111075
    2023-01-18 16:30:02.122 - info: sbfspot.0 (13724) all done ...
    2023-01-18 16:30:02.124 - info: sbfspot.0 (13724) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-01-18 16:30:02.647 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-01-18 16:45:00.023 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 started with pid 13742
    2023-01-18 16:45:01.138 - info: sbfspot.0 (13742) starting. Version 4.1.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v16.19.0, js-controller: 4.0.24
    2023-01-18 16:45:01.174 - info: sbfspot.0 (13742) nothing to do, because no daylight ...
    2023-01-18 16:45:01.175 - info: sbfspot.0 (13742) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-01-18 16:45:01.698 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-01-18 16:51:01.900 - info: admin.0 (484) Adapter rating updated
    2023-01-18 16:51:23.523 - info: admin.0 (484) Request actual repository...
    2023-01-18 16:51:23.721 - info: host.196-iobroker-vm-V2 Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
    2023-01-18 16:51:26.156 - info: admin.0 (484) Repository received successfully.
    2023-01-18 17:00:00.020 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 started with pid 13775
    2023-01-18 17:00:01.149 - info: sbfspot.0 (13775) starting. Version 4.1.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v16.19.0, js-controller: 4.0.24
    2023-01-18 17:00:01.189 - info: sbfspot.0 (13775) nothing to do, because no daylight ...
    2023-01-18 17:00:01.191 - info: sbfspot.0 (13775) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-01-18 17:00:01.711 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-01-18 17:15:00.034 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 started with pid 13795
    2023-01-18 17:15:01.118 - info: sbfspot.0 (13795) starting. Version 4.1.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v16.19.0, js-controller: 4.0.24
    2023-01-18 17:15:01.156 - info: sbfspot.0 (13795) nothing to do, because no daylight ...
    2023-01-18 17:15:01.157 - info: sbfspot.0 (13795) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-01-18 17:15:01.677 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-01-18 18:58:04.097 - info: host.196-iobroker-vm-V2 iobroker.js-controller version 4.0.24 js-controller starting
    2023-01-18 18:58:04.101 - info: host.196-iobroker-vm-V2 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
    2023-01-18 18:58:04.101 - info: host.196-iobroker-vm-V2 hostname: 196-iobroker-vm-V2, node: v16.19.0
    2023-01-18 18:58:04.101 - info: host.196-iobroker-vm-V2 ip addresses: 192.168.178.231 fe80::bcd2:16ff:fe39:8e82
    2023-01-18 18:58:04.728 - info: host.196-iobroker-vm-V2 connected to Objects and States
    2023-01-18 18:58:04.753 - info: host.196-iobroker-vm-V2 added notifications configuration of host
    2023-01-18 18:58:05.118 - info: host.196-iobroker-vm-V2 Delete state "system.host.196-iobroker-vm-V2.versions.nodeCurrent"
    2023-01-18 18:58:05.119 - info: host.196-iobroker-vm-V2 44 instances found
    2023-01-18 18:58:05.149 - info: host.196-iobroker-vm-V2 starting 39 instances
    2023-01-18 18:58:05.198 - info: host.196-iobroker-vm-V2 Delete state "system.host.196-iobroker-vm-V2.versions.nodeNewest"
    2023-01-18 18:58:05.250 - info: host.196-iobroker-vm-V2 instance system.adapter.admin.0 started with pid 445
    2023-01-18 18:58:05.258 - info: host.196-iobroker-vm-V2 Delete state "system.host.196-iobroker-vm-V2.versions.nodeNewestNext"
    2023-01-18 18:58:05.307 - info: host.196-iobroker-vm-V2 Delete state "system.host.196-iobroker-vm-V2.versions.npmCurrent"
    2023-01-18 18:58:05.357 - info: host.196-iobroker-vm-V2 Delete state "system.host.196-iobroker-vm-V2.versions.npmNewest"
    2023-01-18 18:58:05.412 - info: host.196-iobroker-vm-V2 Delete state "system.host.196-iobroker-vm-V2.versions.npmNewestNext"
    2023-01-18 18:58:05.478 - info: host.196-iobroker-vm-V2 Some obsolete host states deleted.
    2023-01-18 18:58:07.415 - error: admin.0 (445) admin.0 already running
    2023-01-18 18:58:07.419 - warn: admin.0 (445) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2023-01-18 18:58:07.963 - error: host.196-iobroker-vm-V2 instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2023-01-18 18:58:07.964 - info: host.196-iobroker-vm-V2 Restart adapter system.adapter.admin.0 because enabled
    2023-01-18 18:58:09.187 - info: host.196-iobroker-vm-V2 instance system.adapter.influxdb.0 started with pid 456
    2023-01-18 18:58:10.347 - error: influxdb.0 (456) influxdb.0 already running
    2023-01-18 18:58:10.349 - warn: influxdb.0 (456) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2023-01-18 18:58:10.898 - error: host.196-iobroker-vm-V2 instance system.adapter.influxdb.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2023-01-18 18:58:10.898 - info: host.196-iobroker-vm-V2 Restart adapter system.adapter.influxdb.0 because enabled
    2023-01-18 18:58:13.268 - info: host.196-iobroker-vm-V2 instance system.adapter.javascript.0 started with pid 467
    2023-01-18 18:58:16.316 - error: javascript.0 (467) javascript.0 already running
    2023-01-18 18:58:16.324 - warn: javascript.0 (467) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2023-01-18 18:58:16.897 - error: host.196-iobroker-vm-V2 instance system.adapter.javascript.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2023-01-18 18:58:16.898 - info: host.196-iobroker-vm-V2 Restart adapter system.adapter.javascript.0 because enabled
    2023-01-18 18:58:17.196 - info: host.196-iobroker-vm-V2 instance system.adapter.telegram.0 started with pid 478
    2023-01-18 18:58:18.689 - error: telegram.0 (478) telegram.0 already running
    2023-01-18 18:58:18.691 - warn: telegram.0 (478) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2023-01-18 18:58:19.225 - error: host.196-iobroker-vm-V2 instance system.adapter.telegram.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2023-01-18 18:58:19.226 - info: host.196-iobroker-vm-V2 Restart adapter system.adapter.telegram.0 because enabled
    2023-01-18 18:58:20.254 - info: host.196-iobroker-vm-V2 instance system.adapter.telegram.0 started with pid 489
    2023-01-18 18:58:21.208 - info: host.196-iobroker-vm-V2 instance system.adapter.alexa2.0 started with pid 496
    2023-01-18 18:58:22.311 - info: telegram.0 (489) starting. Version 1.15.2 in /opt/iobroker/node_modules/iobroker.telegram, node: v16.19.0, js-controller: 4.0.24
    2023-01-18 18:58:22.961 - error: alexa2.0 (496) alexa2.0 already running
    2023-01-18 18:58:22.964 - warn: alexa2.0 (496) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2023-01-18 18:58:23.514 - error: host.196-iobroker-vm-V2 instance system.adapter.alexa2.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2023-01-18 18:58:23.515 - info: host.196-iobroker-vm-V2 Restart adapter system.adapter.alexa2.0 because enabled
    2023-01-18 18:58:25.181 - info: host.196-iobroker-vm-V2 instance system.adapter.hmip.0 started with pid 515
    2023-01-18 18:58:26.061 - error: hmip.0 (515) hmip.0 already running
    2023-01-18 18:58:26.063 - warn: hmip.0 (515) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2023-01-18 18:58:26.597 - error: host.196-iobroker-vm-V2 instance system.adapter.hmip.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2023-01-18 18:58:26.597 - info: host.196-iobroker-vm-V2 Restart adapter system.adapter.hmip.0 because enabled
    2023-01-18 18:58:29.183 - info: host.196-iobroker-vm-V2 instance system.adapter.hue.0 started with pid 526
    2023-01-18 18:58:30.102 - error: hue.0 (526) hue.0 already running
    2023-01-18 18:58:30.104 - warn: hue.0 (526) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2023-01-18 18:58:30.643 - error: host.196-iobroker-vm-V2 instance system.adapter.hue.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2023-01-18 18:58:30.643 - info: host.196-iobroker-vm-V2 Restart adapter system.adapter.hue.0 because enabled
    2023-01-18 18:58:33.181 - info: host.196-iobroker-vm-V2 instance system.adapter.hue.1 started with pid 537
    2023-01-18 18:58:34.203 - error: hue.1 (537) hue.1 already running
    2023-01-18 18:58:34.205 - warn: hue.1 (537) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2023-01-18 18:58:34.758 - error: host.196-iobroker-vm-V2 instance system.adapter.hue.1 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2023-01-18 18:58:34.759 - info: host.196-iobroker-vm-V2 Restart adapter system.adapter.hue.1 because enabled
    2023-01-18 18:58:37.183 - info: host.196-iobroker-vm-V2 instance system.adapter.meross.0 started with pid 548
    2023-01-18 18:58:37.995 - info: host.196-iobroker-vm-V2 instance system.adapter.admin.0 started with pid 555
    2023-01-18 18:58:38.366 - error: meross.0 (548) meross.0 already running
    2023-01-18 18:58:38.368 - warn: meross.0 (548) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2023-01-18 18:58:38.902 - error: host.196-iobroker-vm-V2 instance system.adapter.meross.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2023-01-18 18:58:38.903 - info: host.196-iobroker-vm-V2 Restart adapter system.adapter.meross.0 because enabled
    2023-01-18 18:58:39.120 - info: admin.0 (555) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v16.19.0, js-controller: 4.0.24
    2023-01-18 18:58:39.142 - info: admin.0 (555) requesting all states
    2023-01-18 18:58:39.142 - info: admin.0 (555) requesting all objects
    2023-01-18 18:58:39.590 - info: admin.0 (555) received all objects
    2023-01-18 18:58:39.865 - info: admin.0 (555) Request actual repository...
    2023-01-18 18:58:39.883 - info: admin.0 (555) http server listening on port 8081
    2023-01-18 18:58:39.883 - info: admin.0 (555) Use link "http://localhost:8081" to configure.
    2023-01-18 18:58:39.889 - info: admin.0 (555) socket.io server listening on port 8081
    2023-01-18 18:58:40.076 - info: host.196-iobroker-vm-V2 Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
    2023-01-18 18:58:41.028 - info: host.196-iobroker-vm-V2 instance system.adapter.influxdb.0 started with pid 586
    2023-01-18 18:58:41.157 - info: admin.0 (555) Repository received successfully.
    2023-01-18 18:58:41.216 - info: host.196-iobroker-vm-V2 instance system.adapter.mqtt.0 started with pid 593
    2023-01-18 18:58:42.025 - error: mqtt.0 (593) mqtt.0 already running
    2023-01-18 18:58:42.027 - warn: mqtt.0 (593) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2023-01-18 18:58:42.260 - info: influxdb.0 (586) starting. Version 3.2.0 in /opt/iobroker/node_modules/iobroker.influxdb, node: v16.19.0, js-controller: 4.0.24
    2023-01-18 18:58:42.277 - info: influxdb.0 (586) No stored data from last exit found
    2023-01-18 18:58:42.278 - info: influxdb.0 (586) Connecting http://192.168.178.198:8086/ ...
    2023-01-18 18:58:42.278 - info: influxdb.0 (586) Influx DB Version used: 1.x
    2023-01-18 18:58:42.559 - error: host.196-iobroker-vm-V2 instance system.adapter.mqtt.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2023-01-18 18:58:42.559 - info: host.196-iobroker-vm-V2 Restart adapter system.adapter.mqtt.0 because enabled
    2023-01-18 18:58:45.182 - info: host.196-iobroker-vm-V2 instance system.adapter.shelly.0 started with pid 612
    2023-01-18 18:58:46.194 - error: shelly.0 (612) shelly.0 already running
    2023-01-18 18:58:46.195 - warn: shelly.0 (612) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2023-01-18 18:58:46.728 - error: host.196-iobroker-vm-V2 instance system.adapter.shelly.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2023-01-18 18:58:46.728 - info: host.196-iobroker-vm-V2 Restart adapter system.adapter.shelly.0 because enabled
    2023-01-18 18:58:46.929 - info: host.196-iobroker-vm-V2 instance system.adapter.javascript.0 started with pid 623
    2023-01-18 18:58:48.435 - info: javascript.0 (623) starting. Version 6.1.4 in /opt/iobroker/node_modules/iobroker.javascript, node: v16.19.0, js-controller: 4.0.24
    2023-01-18 18:58:48.773 - info: javascript.0 (623) requesting all states
    2023-01-18 18:58:48.773 - info: javascript.0 (623) requesting all objects
    2023-01-18 18:58:49.152 - info: javascript.0 (623) received all objects
    2023-01-18 18:58:49.185 - info: javascript.0 (623) received all states
    2023-01-18 18:58:49.199 - info: host.196-iobroker-vm-V2 instance system.adapter.sonoff.0 started with pid 638
    2023-01-18 18:58:50.006 - error: sonoff.0 (638) sonoff.0 already running
    2023-01-18 18:58:50.008 - warn: sonoff.0 (638) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2023-01-18 18:58:50.544 - error: host.196-iobroker-vm-V2 instance system.adapter.sonoff.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2023-01-18 18:58:50.544 - info: host.196-iobroker-vm-V2 Restart adapter system.adapter.sonoff.0 because enabled
    2023-01-18 18:58:53.193 - info: host.196-iobroker-vm-V2 instance system.adapter.sonos.0 started with pid 649
    2023-01-18 18:58:53.543 - info: host.196-iobroker-vm-V2 instance system.adapter.alexa2.0 started with pid 656
    2023-01-18 18:58:54.098 - error: sonos.0 (649) sonos.0 already running
    2023-01-18 18:58:54.099 - warn: sonos.0 (649) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2023-01-18 18:58:54.634 - error: host.196-iobroker-vm-V2 instance system.adapter.sonos.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2023-01-18 18:58:54.634 - info: host.196-iobroker-vm-V2 Restart adapter system.adapter.sonos.0 because enabled
    2023-01-18 18:58:54.684 - info: alexa2.0 (656) starting. Version 3.23.2 in /opt/iobroker/node_modules/iobroker.alexa2, node: v16.19.0, js-controller: 4.0.24
    2023-01-18 18:58:54.714 - info: alexa2.0 (656) Starting Alexa2 adapter ... it can take several minutes to initialize all data. Please be patient! A done message is logged.
    2023-01-18 18:58:56.653 - info: host.196-iobroker-vm-V2 instance system.adapter.hmip.0 started with pid 675
    2023-01-18 18:58:57.183 - info: host.196-iobroker-vm-V2 instance system.adapter.synology.0 started with pid 682
    2023-01-18 18:58:57.911 - info: hmip.0 (675) starting. Version 1.20.0 in /opt/iobroker/node_modules/iobroker.hmip, node: v16.19.0, js-controller: 4.0.24
    2023-01-18 18:58:58.393 - error: synology.0 (682) synology.0 already running
    2023-01-18 18:58:58.395 - warn: synology.0 (682) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2023-01-18 18:58:58.414 - info: alexa2.0 (656) Update cookie in adapter configuration ... restarting ...
    2023-01-18 18:58:58.474 - info: host.196-iobroker-vm-V2 stopInstance system.adapter.alexa2.0 (force=false, process=true)
    2023-01-18 18:58:58.482 - info: alexa2.0 (656) Got terminate signal TERMINATE_YOURSELF
    2023-01-18 18:58:58.489 - info: alexa2.0 (656) terminating
    2023-01-18 18:58:58.490 - info: alexa2.0 (656) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-01-18 18:58:58.535 - info: host.196-iobroker-vm-V2 stopInstance system.adapter.alexa2.0 send kill signal
    2023-01-18 18:58:58.965 - error: host.196-iobroker-vm-V2 instance system.adapter.synology.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2023-01-18 18:58:58.965 - info: host.196-iobroker-vm-V2 Restart adapter system.adapter.synology.0 because enabled
    2023-01-18 18:58:59.046 - info: host.196-iobroker-vm-V2 instance system.adapter.alexa2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-01-18 18:59:00.683 - info: host.196-iobroker-vm-V2 instance system.adapter.hue.0 started with pid 701
    2023-01-18 18:59:01.225 - info: host.196-iobroker-vm-V2 instance system.adapter.zigbee.0 started with pid 708
    2023-01-18 18:59:01.618 - info: host.196-iobroker-vm-V2 instance system.adapter.alexa2.0 started with pid 715
    2023-01-18 18:59:02.246 - info: hue.0 (701) starting. Version 3.7.1 in /opt/iobroker/node_modules/iobroker.hue, node: v16.19.0, js-controller: 4.0.24
    2023-01-18 18:59:03.036 - info: hue.0 (701) skip switch: Daylight.configured
    2023-01-18 18:59:03.037 - info: hue.0 (701) skip switch: Daylight.sunriseoffset
    2023-01-18 18:59:03.038 - info: hue.0 (701) skip switch: Daylight.sunsetoffset
    2023-01-18 18:59:03.042 - info: hue.0 (701) skip switch: BWM Gartenhaus.alert
    2023-01-18 18:59:03.042 - info: hue.0 (701) skip switch: BWM Gartenhaus.sensitivity
    2023-01-18 18:59:03.042 - info: hue.0 (701) skip switch: BWM Gartenhaus.sensitivitymax
    2023-01-18 18:59:03.043 - info: hue.0 (701) skip switch: BWM Gartenhaus.ledindication
    2023-01-18 18:59:03.043 - info: hue.0 (701) skip switch: BWM Gartenhaus.usertest
    2023-01-18 18:59:03.048 - info: hue.0 (701) skip switch: Hue outdoor light sensor 1.alert
    2023-01-18 18:59:03.049 - info: hue.0 (701) skip switch: Hue outdoor light sensor 1.tholddark
    2023-01-18 18:59:03.049 - info: hue.0 (701) skip switch: Hue outdoor light sensor 1.tholdoffset
    2023-01-18 18:59:03.050 - info: hue.0 (701) skip switch: Hue outdoor light sensor 1.ledindication
    2023-01-18 18:59:03.050 - info: hue.0 (701) skip switch: Hue outdoor light sensor 1.usertest
    2023-01-18 18:59:03.054 - info: hue.0 (701) skip switch: Hue outdoor temp. sensor 1.alert
    2023-01-18 18:59:03.054 - info: hue.0 (701) skip switch: Hue outdoor temp. sensor 1.ledindication
    2023-01-18 18:59:03.054 - info: hue.0 (701) skip switch: Hue outdoor temp. sensor 1.usertest
    2023-01-18 18:59:03.094 - info: hue.0 (701) created/updated 11 sensor channels
    2023-01-18 18:59:03.464 - info: alexa2.0 (715) starting. Version 3.23.2 in /opt/iobroker/node_modules/iobroker.alexa2, node: v16.19.0, js-controller: 4.0.24
    2023-01-18 18:59:03.651 - info: hue.0 (701) created/updated 12 light channels
    2023-01-18 18:59:03.653 - info: alexa2.0 (715) Starting Alexa2 adapter ... it can take several minutes to initialize all data. Please be patient! A done message is logged.
    2023-01-18 18:59:03.673 - warn: hue.0 (701) channel "Terrasse" already exists, using "Terrasse_Room" for group 4
    2023-01-18 18:59:03.682 - info: hue.0 (701) created/updated 8 groups channels
    2023-01-18 18:59:03.684 - info: hue.0 (701) created/updated 36 scenes
    2023-01-18 18:59:03.685 - info: hue.0 (701) creating/updating bridge device
    2023-01-18 18:59:03.796 - info: hmip.0 (675) ws connection opened
    2023-01-18 18:59:04.777 - error: zigbee.0 (708) zigbee.0 already running
    2023-01-18 18:59:04.779 - warn: zigbee.0 (708) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2023-01-18 18:59:04.825 - info: host.196-iobroker-vm-V2 instance system.adapter.hue.1 started with pid 742
    2023-01-18 18:59:05.190 - info: host.196-iobroker-vm-V2 instance system.adapter.discovery.0 started with pid 749
    2023-01-18 18:59:05.336 - error: host.196-iobroker-vm-V2 instance system.adapter.zigbee.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2023-01-18 18:59:05.336 - info: host.196-iobroker-vm-V2 Restart adapter system.adapter.zigbee.0 because enabled
    2023-01-18 18:59:06.817 - error: discovery.0 (749) discovery.0 already running
    2023-01-18 18:59:06.818 - warn: discovery.0 (749) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2023-01-18 18:59:07.002 - info: hue.1 (742) starting. Version 3.7.1 in /opt/iobroker/node_modules/iobroker.hue, node: v16.19.0, js-controller: 4.0.24
    2023-01-18 18:59:07.348 - error: host.196-iobroker-vm-V2 instance system.adapter.discovery.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2023-01-18 18:59:07.348 - info: host.196-iobroker-vm-V2 Restart adapter system.adapter.discovery.0 because enabled
    2023-01-18 18:59:07.658 - info: hmip.0 (675) hmip adapter connected and ready
    2023-01-18 18:59:07.809 - info: hue.1 (742) skip switch: Daylight.configured
    2023-01-18 18:59:07.809 - info: hue.1 (742) skip switch: Daylight.sunriseoffset
    2023-01-18 18:59:07.810 - info: hue.1 (742) skip switch: Daylight.sunsetoffset
    2023-01-18 18:59:07.811 - info: hue.1 (742) skip switch: BWM Hausflur oben.alert
    2023-01-18 18:59:07.812 - info: hue.1 (742) skip switch: BWM Hausflur oben.sensitivity
    2023-01-18 18:59:07.812 - info: hue.1 (742) skip switch: BWM Hausflur oben.sensitivitymax
    2023-01-18 18:59:07.812 - info: hue.1 (742) skip switch: BWM Hausflur oben.ledindication
    2023-01-18 18:59:07.813 - info: hue.1 (742) skip switch: BWM Hausflur oben.usertest
    2023-01-18 18:59:07.814 - info: hue.1 (742) skip switch: Hue ambient light sensor 1.alert
    2023-01-18 18:59:07.815 - info: hue.1 (742) skip switch: Hue ambient light sensor 1.tholddark
    2023-01-18 18:59:07.815 - info: hue.1 (742) skip switch: Hue ambient light sensor 1.tholdoffset
    2023-01-18 18:59:07.815 - info: hue.1 (742) skip switch: Hue ambient light sensor 1.ledindication
    2023-01-18 18:59:07.816 - info: hue.1 (742) skip switch: Hue ambient light sensor 1.usertest
    2023-01-18 18:59:07.817 - info: hue.1 (742) skip switch: Hue temperature sensor 1.alert
    2023-01-18 18:59:07.818 - info: hue.1 (742) skip switch: Hue temperature sensor 1.ledindication
    2023-01-18 18:59:07.818 - info: hue.1 (742) skip switch: Hue temperature sensor 1.usertest
    2023-01-18 18:59:07.819 - info: hue.1 (742) skip switch: BWM Hausflur unten.alert
    2023-01-18 18:59:07.819 - info: hue.1 (742) skip switch: BWM Hausflur unten.sensitivity
    2023-01-18 18:59:07.820 - info: hue.1 (742) skip switch: BWM Hausflur unten.sensitivitymax
    2023-01-18 18:59:07.820 - info: hue.1 (742) skip switch: BWM Hausflur unten.ledindication
    2023-01-18 18:59:07.820 - info: hue.1 (742) skip switch: BWM Hausflur unten.usertest
    2023-01-18 18:59:07.821 - info: hue.1 (742) skip switch: Hue ambient light sensor 2.alert
    2023-01-18 18:59:07.822 - info: hue.1 (742) skip switch: Hue ambient light sensor 2.tholddark
    2023-01-18 18:59:07.822 - info: hue.1 (742) skip switch: Hue ambient light sensor 2.tholdoffset
    2023-01-18 18:59:07.822 - info: hue.1 (742) skip switch: Hue ambient light sensor 2.ledindication
    2023-01-18 18:59:07.822 - info: hue.1 (742) skip switch: Hue ambient light sensor 2.usertest
    2023-01-18 18:59:07.823 - info: hue.1 (742) skip switch: Hue temperature sensor 2.alert
    2023-01-18 18:59:07.824 - info: hue.1 (742) skip switch: Hue temperature sensor 2.ledindication
    2023-01-18 18:59:07.824 - info: hue.1 (742) skip switch: Hue temperature sensor 2.usertest
    2023-01-18 18:59:07.825 - info: hue.1 (742) skip switch: BWM Kellertreppe.alert
    2023-01-18 18:59:07.825 - info: hue.1 (742) skip switch: BWM Kellertreppe.sensitivity
    2023-01-18 18:59:07.825 - info: hue.1 (742) skip switch: BWM Kellertreppe.sensitivitymax
    2023-01-18 18:59:07.826 - info: hue.1 (742) skip switch: BWM Kellertreppe.ledindication
    2023-01-18 18:59:07.826 - info: hue.1 (742) skip switch: BWM Kellertreppe.usertest
    2023-01-18 18:59:07.827 - info: hue.1 (742) skip switch: Hue ambient light sensor 3.alert
    2023-01-18 18:59:07.827 - info: hue.1 (742) skip switch: Hue ambient light sensor 3.tholddark
    2023-01-18 18:59:07.828 - info: hue.1 (742) skip switch: Hue ambient light sensor 3.tholdoffset
    2023-01-18 18:59:07.828 - info: hue.1 (742) skip switch: Hue ambient light sensor 3.ledindication
    2023-01-18 18:59:07.828 - info: hue.1 (742) skip switch: Hue ambient light sensor 3.usertest
    2023-01-18 18:59:07.829 - info: hue.1 (742) skip switch: Hue temperature sensor 3.alert
    2023-01-18 18:59:07.829 - info: hue.1 (742) skip switch: Hue temperature sensor 3.ledindication
    2023-01-18 18:59:07.830 - info: hue.1 (742) skip switch: Hue temperature sensor 3.usertest
    2023-01-18 18:59:07.831 - info: hue.1 (742) skip switch: BWM Vorratskeller.alert
    2023-01-18 18:59:07.831 - info: hue.1 (742) skip switch: BWM Vorratskeller.sensitivity
    2023-01-18 18:59:07.831 - info: hue.1 (742) skip switch: BWM Vorratskeller.sensitivitymax
    2023-01-18 18:59:07.831 - info: hue.1 (742) skip switch: BWM Vorratskeller.ledindication
    2023-01-18 18:59:07.832 - info: hue.1 (742) skip switch: BWM Vorratskeller.usertest
    2023-01-18 18:59:07.833 - info: hue.1 (742) skip switch: Hue ambient light sensor 4.alert
    2023-01-18 18:59:07.833 - info: hue.1 (742) skip switch: Hue ambient light sensor 4.tholddark
    2023-01-18 18:59:07.833 - info: hue.1 (742) skip switch: Hue ambient light sensor 4.tholdoffset
    2023-01-18 18:59:07.834 - info: hue.1 (742) skip switch: Hue ambient light sensor 4.ledindication
    2023-01-18 18:59:07.834 - info: hue.1 (742) skip switch: Hue ambient light sensor 4.usertest
    2023-01-18 18:59:07.835 - info: hue.1 (742) skip switch: Hue temperature sensor 4.alert
    2023-01-18 18:59:07.836 - info: hue.1 (742) skip switch: Hue temperature sensor 4.ledindication
    2023-01-18 18:59:07.836 - info: hue.1 (742) skip switch: Hue temperature sensor 4.usertest
    2023-01-18 18:59:07.837 - info: hue.1 (742) skip switch: BWM Waschkeller.alert
    2023-01-18 18:59:07.837 - info: hue.1 (742) skip switch: BWM Waschkeller.sensitivity
    2023-01-18 18:59:07.837 - info: hue.1 (742) skip switch: BWM Waschkeller.sensitivitymax
    2023-01-18 18:59:07.838 - info: hue.1 (742) skip switch: BWM Waschkeller.ledindication
    2023-01-18 18:59:07.838 - info: hue.1 (742) skip switch: BWM Waschkeller.usertest
    2023-01-18 18:59:07.839 - info: hue.1 (742) skip switch: Hue ambient light sensor 5.alert
    2023-01-18 18:59:07.840 - info: hue.1 (742) skip switch: Hue ambient light sensor 5.tholddark
    2023-01-18 18:59:07.840 - info: hue.1 (742) skip switch: Hue ambient light sensor 5.tholdoffset
    2023-01-18 18:59:07.840 - info: hue.1 (742) skip switch: Hue ambient light sensor 5.ledindication
    2023-01-18 18:59:07.840 - info: hue.1 (742) skip switch: Hue ambient light sensor 5.usertest
    2023-01-18 18:59:07.844 - info: hue.1 (742) skip switch: Hue temperature sensor 5.alert
    2023-01-18 18:59:07.845 - info: hue.1 (742) skip switch: Hue temperature sensor 5.ledindication
    2023-01-18 18:59:07.845 - info: hue.1 (742) skip switch: Hue temperature sensor 5.usertest
    2023-01-18 18:59:07.846 - info: hue.1 (742) skip switch: BWM Haustür.alert
    2023-01-18 18:59:07.847 - info: hue.1 (742) skip switch: BWM Haustür.sensitivity
    2023-01-18 18:59:07.847 - info: hue.1 (742) skip switch: BWM Haustür.sensitivitymax
    2023-01-18 18:59:07.847 - info: hue.1 (742) skip switch: BWM Haustür.ledindication
    2023-01-18 18:59:07.847 - info: hue.1 (742) skip switch: BWM Haustür.usertest
    2023-01-18 18:59:07.848 - info: hue.1 (742) skip switch: Hue outdoor light sensor 1.alert
    2023-01-18 18:59:07.849 - info: hue.1 (742) skip switch: Hue outdoor light sensor 1.tholddark
    2023-01-18 18:59:07.849 - info: hue.1 (742) skip switch: Hue outdoor light sensor 1.tholdoffset
    2023-01-18 18:59:07.849 - info: hue.1 (742) skip switch: Hue outdoor light sensor 1.ledindication
    2023-01-18 18:59:07.849 - info: hue.1 (742) skip switch: Hue outdoor light sensor 1.usertest
    2023-01-18 18:59:07.850 - info: hue.1 (742) skip switch: Hue outdoor temp. sensor 1.alert
    2023-01-18 18:59:07.851 - info: hue.1 (742) skip switch: Hue outdoor temp. sensor 1.ledindication
    2023-01-18 18:59:07.851 - info: hue.1 (742) skip switch: Hue outdoor temp. sensor 1.usertest
    2023-01-18 18:59:07.852 - info: hue.1 (742) skip switch: BWM Gartentür.alert
    2023-01-18 18:59:07.852 - info: hue.1 (742) skip switch: BWM Gartentür.sensitivity
    2023-01-18 18:59:07.852 - info: hue.1 (742) skip switch: BWM Gartentür.sensitivitymax
    2023-01-18 18:59:07.852 - info: hue.1 (742) skip switch: BWM Gartentür.ledindication
    2023-01-18 18:59:07.852 - info: hue.1 (742) skip switch: BWM Gartentür.usertest
    2023-01-18 18:59:07.854 - info: hue.1 (742) skip switch: Hue outdoor light sensor 2.alert
    2023-01-18 18:59:07.854 - info: hue.1 (742) skip switch: Hue outdoor light sensor 2.tholddark
    2023-01-18 18:59:07.854 - info: hue.1 (742) skip switch: Hue outdoor light sensor 2.tholdoffset
    2023-01-18 18:59:07.854 - info: hue.1 (742) skip switch: Hue outdoor light sensor 2.ledindication
    2023-01-18 18:59:07.854 - info: hue.1 (742) skip switch: Hue outdoor light sensor 2.usertest
    2023-01-18 18:59:07.856 - info: hue.1 (742) skip switch: Hue outdoor temp. sensor 2.alert
    2023-01-18 18:59:07.856 - info: hue.1 (742) skip switch: Hue outdoor temp. sensor 2.ledindication
    2023-01-18 18:59:07.856 - info: hue.1 (742) skip switch: Hue outdoor temp. sensor 2.usertest
    2023-01-18 18:59:07.858 - info: hue.1 (742) skip switch: BWM Flur EG.alert
    2023-01-18 18:59:07.858 - info: hue.1 (742) skip switch: BWM Flur EG.sensitivity
    2023-01-18 18:59:07.858 - info: hue.1 (742) skip switch: BWM Flur EG.sensitivitymax
    2023-01-18 18:59:07.859 - info: hue.1 (742) skip switch: BWM Flur EG.ledindication
    2023-01-18 18:59:07.859 - info: hue.1 (742) skip switch: BWM Flur EG.usertest
    2023-01-18 18:59:07.860 - info: hue.1 (742) skip switch: Hue outdoor light sensor 3.alert
    2023-01-18 18:59:07.860 - info: hue.1 (742) skip switch: Hue outdoor light sensor 3.tholddark
    2023-01-18 18:59:07.860 - info: hue.1 (742) skip switch: Hue outdoor light sensor 3.tholdoffset
    2023-01-18 18:59:07.860 - info: hue.1 (742) skip switch: Hue outdoor light sensor 3.ledindication
    2023-01-18 18:59:07.861 - info: hue.1 (742) skip switch: Hue outdoor light sensor 3.usertest
    2023-01-18 18:59:07.862 - info: hue.1 (742) skip switch: Hue outdoor temp. sensor 3.alert
    2023-01-18 18:59:07.862 - info: hue.1 (742) skip switch: Hue outdoor temp. sensor 3.ledindication
    2023-01-18 18:59:07.862 - info: hue.1 (742) skip switch: Hue outdoor temp. sensor 3.usertest
    2023-01-18 18:59:07.862 - info: hue.1 (742) created/updated 25 sensor channels
    2023-01-18 18:59:08.082 - info: alexa2.0 (715) Initialize all Device states ...
    2023-01-18 18:59:08.212 - info: hue.1 (742) created/updated 9 light channels
    2023-01-18 18:59:08.215 - warn: hue.1 (742) channel "Kellergang" already exists, using "Kellergang_Room" for group 2
    2023-01-18 18:59:08.216 - warn: hue.1 (742) channel "Haustür" already exists, using "Haustür_Room" for group 3
    2023-01-18 18:59:08.217 - warn: hue.1 (742) channel "Garagentür" already exists, using "Garagentür_Room" for group 4
    2023-01-18 18:59:08.219 - warn: hue.1 (742) channel "Gartentür" already exists, using "Gartentür_Room" for group 5
    2023-01-18 18:59:08.224 - info: hue.1 (742) created/updated 9 groups channels
    2023-01-18 18:59:08.226 - info: hue.1 (742) created/updated 26 scenes
    2023-01-18 18:59:08.227 - info: hue.1 (742) creating/updating bridge device
    2023-01-18 18:59:08.930 - info: host.196-iobroker-vm-V2 instance system.adapter.meross.0 started with pid 768
    2023-01-18 18:59:09.203 - info: host.196-iobroker-vm-V2 instance system.adapter.backitup.0 started with pid 775
    2023-01-18 18:59:11.437 - error: backitup.0 (775) backitup.0 already running
    2023-01-18 18:59:11.439 - warn: backitup.0 (775) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2023-01-18 18:59:11.561 - info: meross.0 (768) starting. Version 1.14.0 in /opt/iobroker/node_modules/iobroker.meross, node: v16.19.0, js-controller: 4.0.24
    2023-01-18 18:59:11.975 - error: host.196-iobroker-vm-V2 instance system.adapter.backitup.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2023-01-18 18:59:11.976 - info: host.196-iobroker-vm-V2 Restart adapter system.adapter.backitup.0 because enabled
    2023-01-18 18:59:12.315 - info: meross.0 (768) Device 2106164874521890852648e1e97294bd initialized
    2023-01-18 18:59:12.563 - info: meross.0 (768) Device: 2106164874521890852648e1e97294bd connected
    2023-01-18 18:59:12.585 - info: host.196-iobroker-vm-V2 instance system.adapter.mqtt.0 started with pid 794
    2023-01-18 18:59:12.736 - info: meross.0 (768) Devices initialized
    2023-01-18 18:59:13.287 - info: host.196-iobroker-vm-V2 instance system.adapter.cloud.0 started with pid 801
    2023-01-18 18:59:15.646 - info: mqtt.0 (794) starting. Version 4.0.7 in /opt/iobroker/node_modules/iobroker.mqtt, node: v16.19.0, js-controller: 4.0.24
    2023-01-18 18:59:15.984 - info: mqtt.0 (794) Starting MQTT server on 0.0.0.0:1884
    2023-01-18 18:59:16.219 - error: cloud.0 (801) cloud.0 already running
    2023-01-18 18:59:16.221 - warn: cloud.0 (801) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2023-01-18 18:59:16.768 - error: host.196-iobroker-vm-V2 instance system.adapter.cloud.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2023-01-18 18:59:16.768 - info: host.196-iobroker-vm-V2 Restart adapter system.adapter.cloud.0 because enabled
    2023-01-18 18:59:16.825 - info: host.196-iobroker-vm-V2 instance system.adapter.shelly.0 started with pid 820
    2023-01-18 18:59:17.186 - info: host.196-iobroker-vm-V2 instance system.adapter.web.0 started with pid 827
    2023-01-18 18:59:18.576 - info: shelly.0 (820) starting. Version 6.0.0 in /opt/iobroker/node_modules/iobroker.shelly, node: v16.19.0, js-controller: 4.0.24
    2023-01-18 18:59:18.681 - info: shelly.0 (820) Starting in MQTT mode. Listening on 0.0.0.0:1882
    2023-01-18 18:59:18.707 - error: web.0 (827) web.0 already running
    2023-01-18 18:59:18.709 - warn: web.0 (827) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2023-01-18 18:59:19.250 - error: host.196-iobroker-vm-V2 instance system.adapter.web.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2023-01-18 18:59:19.250 - info: host.196-iobroker-vm-V2 Restart adapter system.adapter.web.0 because enabled
    2023-01-18 18:59:20.568 - info: host.196-iobroker-vm-V2 instance system.adapter.sonoff.0 started with pid 846
    2023-01-18 18:59:21.196 - info: host.196-iobroker-vm-V2 instance system.adapter.go-e.0 started with pid 853
    2023-01-18 18:59:21.724 - info: sonoff.0 (846) starting. Version 2.5.1 in /opt/iobroker/node_modules/iobroker.sonoff, node: v16.19.0, js-controller: 4.0.24
    2023-01-18 18:59:21.759 - info: sonoff.0 (846) Starting MQTT authenticated server on port 1883
    2023-01-18 18:59:22.351 - error: go-e.0 (853) go-e.0 already running
    2023-01-18 18:59:22.353 - warn: go-e.0 (853) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2023-01-18 18:59:22.885 - error: host.196-iobroker-vm-V2 instance system.adapter.go-e.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2023-01-18 18:59:22.886 - info: host.196-iobroker-vm-V2 Restart adapter system.adapter.go-e.0 because enabled
    2023-01-18 18:59:24.656 - info: host.196-iobroker-vm-V2 instance system.adapter.sonos.0 started with pid 872
    2023-01-18 18:59:25.191 - info: host.196-iobroker-vm-V2 instance system.adapter.info.0 started with pid 879
    2023-01-18 18:59:25.730 - info: sonos.0 (872) starting. Version 2.2.3 in /opt/iobroker/node_modules/iobroker.sonos, node: v16.19.0, js-controller: 4.0.24
    2023-01-18 18:59:26.974 - error: info.0 (879) info.0 already running
    2023-01-18 18:59:26.978 - warn: info.0 (879) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2023-01-18 18:59:27.514 - error: host.196-iobroker-vm-V2 instance system.adapter.info.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2023-01-18 18:59:27.515 - info: host.196-iobroker-vm-V2 Restart adapter system.adapter.info.0 because enabled
    2023-01-18 18:59:28.990 - info: host.196-iobroker-vm-V2 instance system.adapter.synology.0 started with pid 910
    2023-01-18 18:59:29.191 - info: host.196-iobroker-vm-V2 instance system.adapter.logparser.0 started with pid 917
    2023-01-18 18:59:30.322 - error: logparser.0 (917) logparser.0 already running
    2023-01-18 18:59:30.324 - warn: logparser.0 (917) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2023-01-18 18:59:30.876 - error: host.196-iobroker-vm-V2 instance system.adapter.logparser.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2023-01-18 18:59:30.877 - info: host.196-iobroker-vm-V2 Restart adapter system.adapter.logparser.0 because enabled
    2023-01-18 18:59:30.913 - info: synology.0 (910) starting. Version 2.1.13 in /opt/iobroker/node_modules/iobroker.synology, node: v16.19.0, js-controller: 4.0.24
    2023-01-18 18:59:30.947 - info: synology.0 (910) Connecting to Synology 192.168.178.107:5001
    2023-01-18 18:59:33.540 - info: synology.0 (910) DSM 7
    2023-01-18 18:59:33.541 - info: synology.0 (910) DSM 7 detected, set all to true
    2023-01-18 18:59:33.986 - info: vis.0 (936) starting. Version 1.4.15 in /opt/iobroker/node_modules/iobroker.vis, node: v16.19.0, js-controller: 4.0.24
    2023-01-18 18:59:34.011 - error: vis.0 (936) No license found for vis. Please get one on https://iobroker.net !
    2023-01-18 18:59:35.328 - info: vis.0 (936) Terminated (NO_ERROR): Without reason
    2023-01-18 18:59:35.360 - info: host.196-iobroker-vm-V2 instance system.adapter.zigbee.0 started with pid 951
    2023-01-18 18:59:35.887 - info: host.196-iobroker-vm-V2 instance system.adapter.vis.0 terminated while should be started once
    2023-01-18 18:59:37.327 - info: host.196-iobroker-vm-V2 instance system.adapter.vis-inventwo.0 started with pid 962
    2023-01-18 18:59:37.426 - info: host.196-iobroker-vm-V2 instance system.adapter.discovery.0 started with pid 969
    2023-01-18 18:59:37.586 - info: zigbee.0 (951) starting. Version 1.8.10 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.19.0, js-controller: 4.0.24
    2023-01-18 18:59:37.902 - info: zigbee.0 (951) Starting Zigbee npm ...
    2023-01-18 18:59:39.290 - info: zigbee.0 (951) Installed Version: iobroker.zigbee@1.8.10
    2023-01-18 18:59:40.212 - error: vis-inventwo.0 (962) vis-inventwo.0 already running
    2023-01-18 18:59:40.214 - warn: vis-inventwo.0 (962) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2023-01-18 18:59:40.672 - info: discovery.0 (969) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.19.0, js-controller: 4.0.24
    2023-01-18 18:59:40.736 - info: zigbee.0 (951) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20210708}}
    2023-01-18 18:59:40.746 - info: zigbee.0 (951) Unable to disable LED, unsupported function.
    2023-01-18 18:59:40.757 - info: zigbee.0 (951) --> transmitPower : high+
    2023-01-18 18:59:40.775 - error: host.196-iobroker-vm-V2 instance system.adapter.vis-inventwo.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2023-01-18 18:59:40.776 - info: host.196-iobroker-vm-V2 Restart adapter system.adapter.vis-inventwo.0 because enabled
    2023-01-18 18:59:40.776 - info: zigbee.0 (951) Currently no devices.
    2023-01-18 18:59:40.777 - info: zigbee.0 (951) Zigbee started
    2023-01-18 18:59:41.182 - info: host.196-iobroker-vm-V2 instance system.adapter.proxmox.0 started with pid 992
    2023-01-18 18:59:42.012 - info: host.196-iobroker-vm-V2 instance system.adapter.backitup.0 started with pid 999
    2023-01-18 18:59:42.283 - error: proxmox.0 (992) proxmox.0 already running
    2023-01-18 18:59:42.285 - warn: proxmox.0 (992) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2023-01-18 18:59:42.852 - error: host.196-iobroker-vm-V2 instance system.adapter.proxmox.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2023-01-18 18:59:42.852 - info: host.196-iobroker-vm-V2 Restart adapter system.adapter.proxmox.0 because enabled
    2023-01-18 18:59:43.404 - info: backitup.0 (999) starting. Version 2.5.10 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.19.0, js-controller: 4.0.24
    2023-01-18 18:59:43.527 - info: backitup.0 (999) [iobroker] backup was activated at every 1 day(s)
    2023-01-18 18:59:45.188 - info: host.196-iobroker-vm-V2 instance scheduled system.adapter.sbfspot.0 */15 * * * *
    2023-01-18 18:59:46.794 - info: host.196-iobroker-vm-V2 instance system.adapter.cloud.0 started with pid 1018
    2023-01-18 18:59:47.813 - info: cloud.0 (1018) starting. Version 4.3.0 in /opt/iobroker/node_modules/iobroker.cloud, node: v16.19.0, js-controller: 4.0.24
    2023-01-18 18:59:47.847 - info: cloud.0 (1018) Connecting with https://iobroker.pro:10555 with "@pro_draci009@gmail.com_646bef80-7f06-11ed-85c5-e76fc4fe39c4"
    2023-01-18 18:59:47.983 - info: cloud.0 (1018) Trying to connect as system.user.admin to cloud
    2023-01-18 18:59:48.608 - info: cloud.0 (1018) Adapter redirected temporally to "https://iobroker.pro:10556" in 30 seconds. Reason: command from server
    2023-01-18 18:59:48.610 - info: cloud.0 (1018) Connection changed: disconnect
    2023-01-18 18:59:49.188 - info: host.196-iobroker-vm-V2 instance system.adapter.tankerkoenig.0 started with pid 1033
    2023-01-18 18:59:49.285 - info: host.196-iobroker-vm-V2 instance system.adapter.web.0 started with pid 1040
    2023-01-18 18:59:50.213 - error: tankerkoenig.0 (1033) tankerkoenig.0 already running
    2023-01-18 18:59:50.215 - warn: tankerkoenig.0 (1033) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2023-01-18 18:59:50.451 - info: web.0 (1040) starting. Version 4.3.0 in /opt/iobroker/node_modules/iobroker.web, node: v16.19.0, js-controller: 4.0.24
    2023-01-18 18:59:50.635 - info: web.0 (1040) socket.io server listening on port 8082
    2023-01-18 18:59:50.637 - info: web.0 (1040) http server listening on port 8082
    2023-01-18 18:59:50.745 - error: host.196-iobroker-vm-V2 instance system.adapter.tankerkoenig.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2023-01-18 18:59:50.745 - info: host.196-iobroker-vm-V2 Restart adapter system.adapter.tankerkoenig.0 because enabled
    2023-01-18 18:59:52.909 - info: host.196-iobroker-vm-V2 instance system.adapter.go-e.0 started with pid 1059
    2023-01-18 18:59:53.188 - info: host.196-iobroker-vm-V2 instance system.adapter.wled.0 started with pid 1066
    2023-01-18 18:59:54.666 - error: wled.0 (1066) wled.0 already running
    2023-01-18 18:59:54.669 - warn: wled.0 (1066) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2023-01-18 18:59:55.117 - info: go-e.0 (1059) starting. Version 1.0.23 in /opt/iobroker/node_modules/iobroker.go-e, node: v16.19.0, js-controller: 4.0.24
    2023-01-18 18:59:55.134 - info: go-e.0 (1059) Server: 192.168.178.206
    2023-01-18 18:59:55.135 - info: go-e.0 (1059) Intervall: 60
    2023-01-18 18:59:55.135 - warn: go-e.0 (1059) Sentry enabled. You can switch it off in settings of the adapter.
    2023-01-18 18:59:55.232 - error: host.196-iobroker-vm-V2 instance system.adapter.wled.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2023-01-18 18:59:55.232 - info: host.196-iobroker-vm-V2 Restart adapter system.adapter.wled.0 because enabled
    2023-01-18 18:59:57.170 - info: host.196-iobroker-vm-V2 instance system.adapter.yahka.0 started with pid 1085
    2023-01-18 18:59:57.551 - info: host.196-iobroker-vm-V2 instance system.adapter.info.0 started with pid 1092
    2023-01-18 18:59:58.580 - error: yahka.0 (1085) yahka.0 already running
    2023-01-18 18:59:58.582 - warn: yahka.0 (1085) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2023-01-18 18:59:59.127 - error: host.196-iobroker-vm-V2 instance system.adapter.yahka.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2023-01-18 18:59:59.127 - info: host.196-iobroker-vm-V2 Restart adapter system.adapter.yahka.0 because enabled
    2023-01-18 18:59:59.739 - info: info.0 (1092) starting. Version 1.9.19 in /opt/iobroker/node_modules/iobroker.info, node: v16.19.0, js-controller: 4.0.24
    2023-01-18 18:59:59.791 - info: info.0 (1092) Reading/updating systemdata.
    GlasfaserG Offline
    GlasfaserG Offline
    @900icard sagte in Proxmox VM friert ein:
    ab dieser Uhrzeit startet er neu ...
    aber da die Adapter schon gestartet sind kommt halt diese Meldung :
    Adapter .... already running
    Du hast relativ viele Fehlermeldungen / Meldungen im Bereich
    sbfspot.0
    hmip.0
    wled.0
    ich würde eher sagen dein Log quillt über ..
    Mehr kann ich gerade nicht erkennen ...
    9 1 Antwort Letzte Antwort
      CPU ist ein Cerleron N5105 .
      der sollte mit einem Passmark von 4000 nicht zu schwach sein.
      wie sieht es denn mit RAM aus
      oder Plattenplatz
      mehr auf die VMs verteilt, als da ist?
      Auch Proxmox benötigt Ressourcen!
      9 Offline
      9 Offline
      900icarD
      Also 16 GB RAM davon ca. 10 GB in use bei 5 VMs
      CPU Auslastung bei ca. 18% ebenfalls bei 5 VMs
      local 100GB und davon 9% in use
      local-lvm 360GB davon 40% in use
      Scheint mir auch nicht recht auffällig zu sein aber ich tendiere irgendwie in die Richtung bzgl. Fehler weil es ja Anfangs (fast) sauber lief und seit Weihnachten nicht mehr.
      Davor habe ich als letztes die 5te VM angelegt weil ich da mit PeerTube was testen will, aber noch nix gemacht.
      Die VM hab ich jetzt mal runtergefahren ... mal sehn was passiert.
      • 9 900icarD
        Hallo Zusammen,
        ich reihe mich hier mal ein in die Liste der Geplagten ein.
        Bei mir läuft Proxmox (aktuell 7.3-4) mit 3 VMS.
        Eine mit ioBroker (6.3.5 mit JS Controller 4.0.24), eine mit InfluxDB (1.8.6) und eine mit Grafana (9.3.5).
        Das ganze lief jetzt ein Jahr lang fast stabil, so aller 3-4 Monate hatte ich das Einfrierproblem und ich dachte erst, dass es (Hab jeweils Debian 11 VM mit Desktop drauf) daran liegt, dass wenn Debian sagt es wären neue Updates verfügbar, dass er dann einfriert. Die Meldung der Updates hab ich dann ausgeschalten, selbes Problem.
        Seit Weihnachten haben sich die Ausfälle stark gehäuft so dass diese nun zwischen 2 und 48 Stunden auftreten.
        Ich hab schon einiges ausprobiert, also diverse Adapter deaktiviert die ich in Verdacht hatte usw.
        Wenn "nur" die Grundinstallation von ioBroker aktiv ist, also Admin, BackitUp und Discovery läuft "scheint" es keine Probleme zu geben.
        Hab eine komplett neue VM aufgesetzt, (Debian 11 ohne Desktop) und ioBroker installiert, lief 3 Tage durch, dann hab ich gestern alle Adapter neu installiert und die meisten konfiguriert und zack, heute abgeschmiert.
        CPU ist ein Cerleron N5105 ... keine Ahnung ob das wirklich an dem liegt, lief ja vorher auch.
        Stutzig macht mich aber, dass auch die InfluxDB VM jetzt schon 2-3 mal abgeschmiert ist und auch die Grafana VM schon einmal.
        Sehr, sehr strange.
        Das nächste was ich ausprobiere werde - wohl oder übel - ich werde mir eine AMD Kiste holen und dort Proxmox und die VMs neu aufsetzen.
        Bin gespannt was dann passiert.
        Ich werde berichten. So richtig kann ich aber an den CPU Fehler nicht glauben.
        Falls jemand schon weiter ist oder sogar das Problem schon eindeutig identifizieren konnte, gern posten ;-)
        Ärgerlich weil ich eigentlich an ioBroker weiter bauen will aber hilft nix, so kann ich damit nicht arbeiten.
        Trotzdem einen schönen Abend an alle Geplagten.
        GlasfaserG Offline
        GlasfaserG Offline
        also dann mit einem Backup ..
        aber warum danach daß !?
        • GlasfaserG Glasfaser
          sbfspot.0
          hmip.0
          wled.0
          9 Offline
          9 Offline
          900icarD
          @glasfaser
          Ja, sbfspot schaut aller 5 Min. nach neuen Daten und wled meckert (warn) schon länger wegen einem value -1 der nicht sein darf.
          Das ist aber nichts neues für mich, im Log.
          hmip konnte heute wohl mal keine Verbindung aufbauen, das ist in der tat neu.
          Ich werde mal, nur damit ich das ggf. ausschließen kann, diese drei Adapter deaktivieren und schauen was passiert.
          • 9 900icarD
            @glasfaser
            GlasfaserG Offline
            GlasfaserG Offline
            #66
            Brauchst du diese Info´s im ioBrocker Log !?
            Wenn nicht , dann stelle die Logstufe bei der Instanz auf WARN.
            • 9 900icarD
              #67
              @900icard was in use ist ist irrelevant!
              wenn du z.B 128GB Plattenplatz hast, darfst du nicht jeder VM mit 42GB zuweisen.
              Proxmox selber braucht auch noch etwas. Auch wenn die VMs ihren Platz nicht ausschöpfen!
                9 Offline
                9 Offline
                900icarD
                #68
                @glasfaser
                ich hab drei Sachen ausprobiert.
                1. die komplette VM geklont, gleiches Problem.
                2. Backup gemacht, ioB neu aufgesetzt und alles per BackItUp Adapter restored, gleiches Problem. (Davor war meine Vermutung der SourceAnalytics Adapter den ich nicht aus dem Stable hatte)
                3. Neue VM aufgesetzt, blanko, ioB Blanko installiert und alle Adapter von Hand neu installiert und konfiguriert.
                  Heute wollte ich eigentlich weitermachen mit den Javascripten, dem Vis Projekt und der Userdata Objektstruktur aber soweit bin ich nicht gekommen da war er schon wieder abgeschmiert.
                Also müsste es an einem der Adapter liegen oder generell an Proxmox oder der Hardware. Vielleicht läuft ja wirklich irgendwas voll aber es ist nichts zu erkennen, weder im ioB Log noch im Proxmox Log. Da es - scheinbar zumindest - mit der Grundinstallation des ioB (also nur Admin, Backitup und Discovery läuft) ist meine Vermutung, dass mit diesen drei Adaptern das "volllaufen" nur viel länger dauert und er erst nach 2-3 Wochen oder so abschmieren würde oder es liegt wirklich an einem der Adapter.
                Mein letztes Problem war das Ding mit dem Netatmo Adapter der keine Live Events mehr aktualiseren konnte. Hab dann aber den cloud Adapter installiert, mir eine Lizenz gekauft und dann lief das wieder. Aber wenn ich sowohl nur den Cloud Adapter alleine oder nur den Netatmo Adapter alleine oder auch beide zusammen deaktiviere, schmiert er trotzdem ab.
                Verzwickte Sache und Suche nach der Nadel im Heuhaufen grad ...
                  9 Offline
                  9 Offline
                  900icarD
                  #69
                  @glasfaser said in Proxmox VM friert ein:
                  Stimmt, brauch ich nicht, habs auf warn gestellt. Danke für den Tip, hab ich garnicht dran gedacht, dass man damit das Log etwas cleaner bekommt.
                  • 9 900icarD
                    @glasfaser
                    GlasfaserG Offline
                    GlasfaserG Offline
                    #70
                    @900icard
                    ich würde erstmal das Log aufräumen ... das ist schon recht vollgemüllt.
                    Das heißt ...wie du schon selber schreibst einzelne Adapter dazu überprüfen ,
                    aber auch eventuell läuft ein JS Script Amok !?
                      9 Offline
                      9 Offline
                      900icarD
                      #71
                      @homoran said in Proxmox VM friert ein:
                      Ok, ja das stimmt.
                      Blöde Frage, in Proxmox steht 100GB bei local und 363GB bei local-lvm als verfügbarer Platz.
                      Müssen die VMs alle mit den 100GB auskommen?
                      Ich hatte jeder 32 GB zugewiesen und x4 ergibt 128GB und da wäre ich ja drüber ... Hmmm, .... das könnte dann in der Tat das Problem sein.
                      Ich hab ja nun die PeerTube VM heruntergefahren aber vermutlich muss ich die komplett killen um den Platz wieder frei zu bekommen.
                      Das werde ich als nächsten (aber erst morgen) mal ausprobieren.
                      Aber Danke schon mal für den Hinweis!
                        @900icard
                        9 Offline
                        9 Offline
                        900icarD
                        #72
                        @900icard
                        Mach ich, gute Idee. Hat ich auch schon eher mal drauf kommen können. Danke
                        Ein Amok JS Script würde ich mal ausschließen weil ich den JS Adapter auch schon deaktiviert hatte und er trotzdem abgeschmiert ist.
                        Aber Danke Dir und @homoran schon mal für die Unterstützung hier, ich bin grad schon etwas optimistischer das Problem zu finden.
                        Morgen gehts weiter :-)
                        • 9 900icarD
                          @900icard
                          GlasfaserG Offline
                          GlasfaserG Offline
                          #73
                          es können aber trotzdem noch Zombie Prozesse laufen .
                          dann eher JS aus und Proxmox VM neu starten .
                          • 9 900icarD
                            Ok, ja das stimmt.
                            crunchipC Abwesend
                            crunchipC Abwesend
                            #74
                            Deine 100gig ist dein Root Laufwerk
                            Dein lvm ist der Platz der zur Verfügung steht für einzelne Maschinen.
                            Wie ist denn deine Ram Verteilung?
                            • 9 900icarD
                              Hallo Zusammen,
                              Sehr, sehr strange.
                              Dr. BakteriusD Online
                              Dr. Bakterius
                              #75
                              Funktioniert Proxmox mittlerweile auch mit anderen Prozessoren außer Intel?
                              W ? 2 Antworten Letzte Antwort
                                W Online
                                W Online
                                Wildbill
                                #76
                                @dr-bakterius Warum sollte es nicht? Proxmox baut auf Debian auf, das bekommst Du für so ziemlich alles, was rechnen kann. Mir wäre nicht bekannt, dass Proxmox jemals nur auf Intel lauffähig gewesen wäre. AMD und Intel sind ja beide X86 bzw. X64.
                                Gruss, Jürgen
                                  #77
                                  @dr-bakterius sagte in Proxmox VM friert ein:
                                  bei mir läuft alles auf einem uralt PC, CPU(s) 4 x AMD Phenom(tm) II X4 955 Processor (1 Socket) nur ich betreibe nur LXC Container keine VMs.
                                  Kein Glaubenskrieg, aberintel kommt mir auch nicht ins Haus :) :)
                                  Und noch ein Ansatz, um beim Thema zu bleiben, wie sieht denn die Temperatur der CPU und/oder des Mobos aus?
                                  Bernd
                                  • 9 Offline
                                    9 Offline
                                    900icarD
                                    #78
                                    Hallo Zusammen,
                                    soo, kurzes Update zur Lage der Nation.
                                    Also, gestern Abend hatte ich noch die Adapter WLED, HMIP, SBFsopt sowie Netatmo deaktiviert und die PeerTube VM die als vierte von fünf (die fünfte ist meine neu aufgesetzte ioB VM die aber schon heruntergefahren ist) lief auch heruntergefahren.
                                    Heute morgen leider das mittlerweile übliche Bild, ioB VM eingefroren.
                                    • Also lag es nicht an den o.g. Adaptern.
                                    • Bzgl. der Vermutung das JS Zombie Prozesse laufen könnten ... das würde ich auch ausschließen weil auf der neu aufgesetzten ioB VM noch keine JS Script drauf sind, nur die Adapter incl. JS Adapter und auch die ist ja schon abgeschmiert.
                                    • Also hab ich heute morgen die PeerTube VM komplett gekillt um zu überprüfen ob es ggf. an zu viel zugewiesenen Speicher liegen könnte wobei @crunchip ja sagte, dass die LVM Partition die entscheidende ist für den Platz der VMs. Hier habe ich aber noch genügend frei (363GB)
                                    RAM Verteilung ist wie folgt. 16GB hat der Rechner in Summe und jeder der noch vier vorhandenen VMs sind 4GB zugewiesen.
                                    Heute Nachmittag nach der Arbeit leider wieder, ioB VM eingefroren und zusätzlich auch noch die InfluxDB VM. Zeitlich ist die InfluxDB VM eher eingefroren und ca. 2h später die ioB VM.
                                    Dass auch die InfluxDB VM jetzt manchmal (seltener als die ioB VM) einfriert ist für mich auch eher ein Zeichen, dass es wohl nicht an ioB oder den Adaptern liegen kann.
                                    Ich vermute daher wirklich, dass es am Rechner, dem Debian 11 als Muttersystem, an Proxmox selbst oder an den VM Einstellungen oder dem Debian 11 dort liegt. (Wobei wie gesagt, es ja ein Jahr fast problemlos lief).
                                    Mir bleibt jetzt wohl erstmal nichts anderes übrig als ein Debian 11 mit Proxmox und einer einzelnen ioB VM auf einer AMD Kiste auszuprobieren. (werde mir eine auf Amazon kaufen)
                                    Ich bin mir nicht sicher ob man einen VM Klon vom aktuellen Intel Rechner auf einem anderen mit AMD zum Laufen bringt, mal sehn.
                                    Wenn der Klon dort auch abschmiert dann müsste es ja doch an der VM bzw. deren Konfig. selber liegen und falls nicht dann wohl eher am Rechner/Proxmox.
                                    Außerdem werde ich eine komplett neue VM aufsetzen und wieder alle Adapter manuell neu installieren um auch das Szenario zu testen.
                                    Falls das abschmiert dann falle ich aber vom Glauben ab. Dann könnte das Problem noch vor dem Rechner selbst sitzen ;-)
                                    Naja, stay tuned ...
                                    W crunchipC ? 3 Antworten Letzte Antwort
                                    • 9 900icarD
                                      Hallo Zusammen,
                                      W Online
                                      W Online
                                      Wildbill
                                      #79
                                      @900icard Die VMs kannst Du normalerweise 1:1 übernehmen, auch wenn sich die Architektur des Host ändert. Das ist ja das Schöne an Virtualisierung.
                                      Anstatt Debian und anschließend Proxmox zu installieren würde ich direkt von Proxmox ein fertiges Installationsimage laden. Dann hast Du direkt alles in Einem.
                                      Gruss, Jürgen
                                      9 HomoranH 2 Antworten Letzte Antwort
                                      • 9 900icarD
                                        Hallo Zusammen,
                                        crunchipC Abwesend
                                        crunchipC Abwesend
                                        #80
                                        Theoretisch, wenn jede VM den Ram ausschöpfen würde, was bleibt für Proxmox?😉
                                        Vielleicht hast du auch in den Einstellungen etwas generell falsch konfiguriert.
                                        Ansonsten seh dir das syslog und kernel log an
                                          9 Offline
                                          9 Offline
                                          900icarD
                                          #81
                                          @crunchip said in Proxmox VM friert ein:
                                          Ja mit dem RAM hast Du natürlich recht aber beim Speicherverbrauch der VMs tut sich fast nichts. Wenn die einmal laufen dann ist das recht stabil und in Summe haben die 5 VMs wenn sie denn alle liefen nicht mehr als 10GB von den 16GB verbraucht. Aber gut, ich werde das auch mal stärker im Auge behalten.
                                          Blöde Frage, wo bzw. wie kann ich mir das Kernel Log ansehen? Bisher hab ich immer nur ins Syslog geschaut.
                                          Andere Frage, bisher habe ich meinen VMs jeweils alle vier Kerne der CPU zugewiesen. Nur der letzen neuen ioB TestVM habe ich nur zwei Kerne zugewiesen.
                                          Randnotiz: Wenn die 4-Kern ioB VM eingefroren ist dann ist die CPU Auslastung auf 25% gegangen, bei der 2-Kern ioB VM auf 50%.
                                          Ist das egal wieviel Kerne man jeweils zuordnet oder machen 2 pro VM mehr Sinn?
                                          Bei den Einstellungen der VMs hab ich es eigentlich so nach einen der vielen Anleitungen gemacht, weiß nur nicht mehr welche ich befolgt habe. Aber ich hab mir letztens das Video von EddyDs SmartHome angesehen und das sah auch so aus wie ich das gemacht hab. Werde beim Neu-aufsetzen das aber auch nochmal genauer anschauen.
