  4. Admin Problem
    5.6k
Admin Problem
admin
70 Beiträge 8 Kommentatoren 10.2k Aufrufe 7 Beobachtet
  • N nullfreizeit
    Das kam jetzt raus. So wie ich lese sind die Verzeichnisse ok, oder? Hab einen re-install gemacht aber bei list instances bekomme ich wieder einen disabled admin. Und wenn ich manuell admin starte ist dieser weiter disabled?
    pi@raspberrypi:~ $ for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%/}; done
    pi@raspberrypi:~ $ node -v
    v18.12.1
    pi@raspberrypi:~ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt-get update &> /dev/null && sudo apt-get update && apt-cache policy nodejs
    armv7l
    /usr/bin/nodejs
    /usr/bin/node
    /usr/bin/npm
    v18.12.1
    v18.12.1
    8.19.2
    4.0.23
    pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
    tty
    /home/pi
    Hit:1 http://archive.raspberrypi.org/debian buster InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
    Hit:3 https://deb.nodesource.com/node_18.x buster InRelease
    Reading package lists... Done
    nodejs:
      Installed: 18.12.1-deb-1nodesource1
      Candidate: 18.12.1-deb-1nodesource1
      Version table:
     *** 18.12.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x buster/main armhf Packages
         10.24.0~dfsg-1~deb10u2 500
    pi@raspberrypi:~ $ sudo apt install nodejs --reinstall
    Building dependency tree
    The following packages were automatically installed and are no longer required:
      libdrm-etnaviv1 libllvm6.0
    Use 'sudo apt autoremove' to remove them.
    0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 0 not upgraded.
    Need to get 0 B/25.1 MB of archives.
    After this operation, 0 B of additional disk space will be used.
    (Reading database ... 57598 files and directories currently installed.)
    Preparing to unpack .../nodejs_18.12.1-deb-1nodesource1_armhf.deb ...
    Unpacking nodejs (18.12.1-deb-1nodesource1) over (18.12.1-deb-1nodesource1) ...
    Setting up nodejs (18.12.1-deb-1nodesource1) ...
    Processing triggers for man-db (2.8.5-2) ...
    Jan1
    @nullfreizeit
    Node ist zumindest jetzt mal gerade, aber immer noch 18 und eigentlich ist 16 empfohlen. Wenn alles wieder läuft, dann lass das so. Sonst die Anleitung durchziehen, bis Du auf Node 16 bist.
    @DJMarc75
    Du willst dass er die Anleitung abarbeitet und wenn ich vorschlage das über ein Restor zu lösen, bei dem der IOBroker vorher immer gelöscht sein sollte, kommst Du mit Neuaufsetzten des System?
    Im Zweifel ist dass, das Beste und Sauberste, aber bis jetzt nicht nötig. Wenn er die verbogene Node deinstalliert und dann restort, kommt er genau auf das Selbe raus, wenn am OS nicht auch schon ein paar Dinge verbogen sind .
    Da er aber noch Buster laufen hat, würde ich auch zu einem aktuelle Debian Bullseye raten ;)
    Danach den IOBroker Restor und in einer Stunde ist das Ding sauber gelutscht.
    • N nullfreizeit
      @djmarc75 sagte in Admin Problem:
      @nullfreizeit
      https://forum.iobroker.net/topic/61353/admin-problem/12?_=1671956831150
      wenn das nicht genutzt wird bin ich raus !
      https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
      Hallo Marc,
      Sorry, aber das hab ich doch gemacht. Oder hab ich was übersprungen. Danke für eure Hilfe.
      DJMarc75D Offline
      DJMarc75D Offline
      DJMarc75
      @nullfreizeit sagte in Admin Problem:
      Naja, um es mal beim Namen zu nennen: Du hast in Teil 2 ja nur den ersten Befehl ausgeführt... da gibts ja noch mehr...
      Lehrling seit 1975 !!!
      • J Jan1
        @nullfreizeit
        @DJMarc75
        DJMarc75D Offline
        DJMarc75D Offline
        DJMarc75
        @jan1
        @jan1 sagte in Admin Problem:
        Na das war ja der Punkt 😀 👍
        • N Offline
          N Offline
          nullfreizeit
          Hallo ihr zwei. Danke für eure Geduld mit mir. Habe jetzt alles noch einmal gemacht gem. der Beschreibung Teil 2.
          Aber auch nach einem sudo reboot komme ich nicht weiter. Könnt ihr mir bitte helfen? Danke
          armv7l
          /usr/bin/nodejs
          /usr/bin/node
          /usr/bin/npm
          v18.12.1
          v18.12.1
          8.19.2
          4.0.23
          pi
          tty
          /home/pi
            Version table:
          pi@raspberrypi:~ $ uname -a
          Linux raspberrypi 5.10.103-v7l+ #1529 SMP Tue Mar 8 12:24:00 GMT 2022 armv7l GNU/Linux
          pi@raspberrypi:~ $ lsb_release -a
          No LSB modules are available.
          Distributor ID: Raspbian
          Description:    Raspbian GNU/Linux 10 (buster)
          Release:        10
          Codename:       buster
          • N nullfreizeit
            armv7l
            /usr/bin/nodejs
            /usr/bin/node
            /usr/bin/npm
            v18.12.1
            v18.12.1
            8.19.2
            4.0.23
            pi
            tty
            /home/pi
              Version table:
            Release:        10
            Codename:       buster
            Jan1
            @nullfreizeit
            Da Du noch Buster laufen hast, macht es eh nicht so viel Sinn hier manuell was zu richten. Mach den Pi mit Bullseye frisch und restore ein IOBroker Backup. Da hast auf Dauer wesentlich mehr davon.
            Der PI Installer gibt ja mittlerweile schon alles vor was an nötiger Konfiguration zu erledigen ist und dann als OS das lite ohne Desktop. Dauert wenn es normal läuft ne Stunde von 0 bis IOBroker läuft wie vorher und es ist aktuell und sauber.
            N 1 Antwort Letzte Antwort
            • J Jan1
              @nullfreizeit
              N Offline
              N Offline
              nullfreizeit
              @jan1
              Danke Jan für deine Unterstützung. Wie gehe ich da vor. Verstehe nicht genau was du meinst. Ich muss also downgraden? Bin euch wirklich dankbar und weiß das ihr wahrscheinlich schon kurz vorm verzweifeln seid :-)
              J DJMarc75D 2 Antworten Letzte Antwort
              • N nullfreizeit
                @jan1
                Jan1
                @nullfreizeit
                Nein Du machst die SD Karte komplett frisch.
                • N nullfreizeit
                  @jan1
                  DJMarc75D Offline
                  DJMarc75D Offline
                  DJMarc75
                  da braucht es noch ne Weile und viel mehr dazu 😀
                  Trotzdem solltest Du die Anleitung vom obigen Link befolgen !
                  • DJMarc75D DJMarc75
                    N Offline
                    N Offline
                    nullfreizeit
                    Hi DjMarc75,
                    Na das ist gut zu wissen. ;-)
                    Aber sag mir doch bitte was ich noch nicht gemacht habe. Habe doch den gesamten Teil 2 durch, oder?
                    • N nullfreizeit
                      Hi DjMarc75,
                      @nullfreizeit
                      Was ist denn jetzt konkret dein Problem?
                      nodeJS18 ist zwar nicht die zur Zeit empfohlene Version, aber wenn es funktioniert lass es so.
                      Allerdings solltest du den abgekündigten Buster durch Bullseye ersetzen.
                      N 2 Antworten Letzte Antwort
                        @nullfreizeit
                        N Offline
                        N Offline
                        nullfreizeit
                        Hi Thomas,
                        gestern wurde mir der Zigbee Adapter als Update vorgeschlagen. Während des Updates funktionierte dann Admin nicht mehr.
                        Jetzt konnte bis vor 5 Min nicht mehr das Admin Panel aufrufen.
                        Nachdem ich per „iobroker list instances“ manuell „iobroker start admin.0“ + „iobroker start web.0“ eingegeben habe funktioniert der aufruf des Admin Panels wieder. Wie gesagt gerade eben durch Zufall. Nun startet aber kein Adapter mehr.
                        Bin am verzweifeln. Kann ich irgendwie backitup starten und eine Wiederherstellung machen oder was wäre dein/euer Vorschlag?
                        Vielen Dank.
                          @nullfreizeit
                          N Offline
                          N Offline
                          nullfreizeit
                          @thomas-braun sagte in Admin Problem:
                          Wie kann ich das machen? Danke
                          • N nullfreizeit
                            Jan1
                            @nullfreizeit
                            Wie schon geschrieben, von Buster weg und Bullseye neu drauf, danach das Backup restoren und fertig. Hättest das heute morgen schon gemacht, hättest schon lange fertig ;)
                            • N nullfreizeit
                              Hi Thomas,
                              Vielen Dank.
                              Woran machst du das fest?
                              sagt?
                              Upgrade auf Bullseye:
                              https://forum.iobroker.net/topic/47213/upgrade-von-debian-10-buster-auf-11-bullseye
                                sagt?
                                N Offline
                                N Offline
                                nullfreizeit
                                pi@raspberrypi:~ $ iobroker list instances
                                + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 7777, bind: 0.0.0.0, run as: admin
                                  system.adapter.alarm.0                  : alarm                 : raspberrypi                              - disabled
                                + system.adapter.asterisk.0               : asterisk              : raspberrypi                              -  enabled, port: 5038
                                  system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
                                + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
                                  system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
                                  system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
                                  system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
                                  system.adapter.email.0                  : email                 : raspberrypi                              -  enabled
                                  system.adapter.eventlist.0              : eventlist             : raspberrypi                              - disabled
                                  system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
                                  system.adapter.history.0                : history               : raspberrypi                              - disabled
                                  system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
                                  system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi                              - disabled
                                  system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
                                  system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
                                  system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
                                  system.adapter.landroid.0               : landroid              : raspberrypi                              - disabled
                                  system.adapter.mihome-vacuum.0          : mihome-vacuum         : raspberrypi                              -  enabled, port: 54321
                                  system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1889, bind: 192.168.188.35
                                  system.adapter.musiccast.0              : musiccast             : raspberrypi                              -  enabled
                                  system.adapter.nina.0                   : nina                  : raspberrypi                              -  enabled
                                  system.adapter.onvif.0                  : onvif                 : raspberrypi                              - disabled
                                  system.adapter.openligadb.0             : openligadb            : raspberrypi                              -  enabled
                                  system.adapter.openweathermap.0         : openweathermap        : raspberrypi                              -  enabled
                                  system.adapter.pegelalarm.0             : pegelalarm            : raspberrypi                              -  enabled
                                  system.adapter.rssfeed.0                : rssfeed               : raspberrypi                              -  enabled
                                  system.adapter.sayit.0                  : sayit                 : raspberrypi                              - disabled, port: 0
                                  system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
                                  system.adapter.simple-api.0             : simple-api            : raspberrypi                              - disabled, port: 8087, bind: 0.0.0.0, run as: admin
                                  system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
                                  system.adapter.sony-bravia.0            : sony-bravia           : raspberrypi                              -  enabled
                                  system.adapter.telegram.0               : telegram              : raspberrypi                              - disabled, port: 8443, bind: 0.0.0.0
                                  system.adapter.terminal.0               : terminal              : raspberrypi                              - disabled, port: 8088, bind: 0.0.0.0, run as: admin
                                  system.adapter.time-switch.0            : time-switch           : raspberrypi                              - disabled
                                  system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
                                  system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
                                  system.adapter.tvspielfilm.0            : tvspielfilm           : raspberrypi                              -  enabled
                                  system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              - disabled
                                  system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              - disabled
                                  system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
                                  system.adapter.vis-history.0            : vis-history           : raspberrypi                              - disabled
                                  system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
                                  system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
                                  system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
                                  system.adapter.vis-material.0           : vis-material          : raspberrypi                              -  enabled
                                  system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              -  enabled
                                  system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
                                  system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              - disabled
                                  system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
                                  system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              - disabled
                                  system.adapter.yahka.0                  : yahka                 : raspberrypi                              -  enabled
                                  system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/ttyACM0
                                + instance is alive
                                • N nullfreizeit
                                  + instance is alive
                                  @nullfreizeit
                                  Und wenn du die Instanzen im Admin startest?
                                  • N nullfreizeit
                                    + instance is alive
                                    crunchipC Abwesend
                                    crunchipC Abwesend
                                    @nullfreizeit oder mal ein iob restart
                                    • N Offline
                                      N Offline
                                      nullfreizeit
                                      @nullfreizeit
                                      Es passiert nix. Wenn ich stoppe und neu starte bekomme ich solche Meldungen
                                      host.raspberrypi
                                      2022-12-25 12:26:58.719	info	iobroker npm-install: Installing iobroker.history@2.2.4... (System call)
                                      host.raspberrypi
                                      2022-12-25 12:26:58.716	info	iobroker npm-install: NPM version: 8.19.2
                                      email.0
                                      2022-12-25 12:26:55.950	info	starting. Version 1.1.4 in /opt/iobroker/node_modules/iobroker.email, node: v18.12.1, js-controller: 4.0.23
                                      host.raspberrypi
                                      2022-12-25 12:26:54.045	info	iobroker install history@2.2.4 using installedFrom
                                      host.raspberrypi
                                      2022-12-25 12:26:54.044	warn	startInstance cannot find adapter "history@2.2.4". Try to install it... 1 attempt
                                      • N nullfreizeit
                                        @nullfreizeit
                                        host.raspberrypi
                                        host.raspberrypi
                                        email.0
                                        host.raspberrypi
                                        host.raspberrypi
                                        @nullfreizeit
                                        iobroker stop
                                        iobroker fix
                                        iobroker start
                                        iobroker diag
                                        Poste mal die lange Ausgabe von diag.
                                          @nullfreizeit
                                          iobroker stop
                                          iobroker fix
                                          iobroker start
                                          iobroker diag
                                          N Offline
                                          N Offline
                                          nullfreizeit
                                          Danke Thomas, hier der output…
                                          *** ioBroker Diagnosis ***
                                          Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
                                          The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
                                          Just copy and paste the Summary Page, including the ``` characters at start and end.
                                          It helps us to help you!
                                          Press any key to continue
                                          Skript v.2022-12-13
                                          *** BASE SYSTEM ***
                                          Model           : Raspberry Pi 4 Model B Rev 1.1
                                          Architecture:   armv7l
                                          Docker:         false
                                          Virtualization: none
                                          Release:        10
                                          Codename:       buster
                                          PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
                                          NAME="Raspbian GNU/Linux"
                                          VERSION_ID="10"
                                          VERSION="10 (buster)"
                                          VERSION_CODENAME=buster
                                          ID=raspbian
                                          ID_LIKE=debian
                                          HOME_URL="http://www.raspbian.org/"
                                          SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
                                          BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
                                          Systemuptime and Load:
                                           12:40:40 up  2:58,  1 user,  load average: 2.90, 5.12, 7.21
                                          CPU threads: 4
                                          *** Time and Time Zones ***
                                          Sun Dec 25 11:40:40 UTC 2022
                                          Sun Dec 25 12:40:40 CET 2022
                                          CET +0100
                                          Europe/Berlin
                                          *** User and Groups ***
                                          pi
                                          /home/pi
                                          *** X-Server-Setup ***
                                          X-Server:       false
                                          Desktop:
                                          Terminal:       tty
                                          *** MEMORY ***
                                          Mem:           3.8G        132M        2.0G         16M        1.7G        3.5G
                                          Swap:           99M        5.0M         94M
                                          Total:         3.9G        137M        2.1G
                                                   3838 M total memory
                                                    133 M used memory
                                                    702 M active memory
                                                    923 M inactive memory
                                                   1991 M free memory
                                                    245 M buffer memory
                                                   1468 M swap cache
                                                     99 M total swap
                                                      5 M used swap
                                                     94 M free swap
                                          *** FILESYSTEM ***
                                          /dev/root      ext4       29G   16G   13G  57% /
                                          devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
                                          tmpfs          tmpfs     1.9G   16K  1.9G   1% /dev/shm
                                          tmpfs          tmpfs     1.9G   17M  1.9G   1% /run
                                          tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
                                          /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
                                          tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
                                          TARGET        SOURCE         FSTYPE OPTIONS
                                          /             /dev/mmcblk0p2 ext4   rw,noatime
                                          |-/sys/fs/bpf none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
                                          `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                          /var:
                                          7.6G    /var/
                                          5.9G    /var/lib
                                          5.8G    /var/lib/motioneye/Camera2
                                          3.6G    /var/lib/motioneye/Camera2/2021-08-04
                                          /opt/iobroker/backups:
                                          953M    /opt/iobroker/backups/
                                          /opt/iobroker/iobroker-data:
                                          1.8G    /opt/iobroker/iobroker-data/
                                          1.3G    /opt/iobroker/iobroker-data/history
                                          278M    /opt/iobroker/iobroker-data/files
                                          138M    /opt/iobroker/iobroker-data/backup-objects
                                          72M     /opt/iobroker/iobroker-data/files/telegram.admin
                                          15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
                                          14M     /opt/iobroker/iobroker-data/objects.jsonl
                                          8.6M    /opt/iobroker/iobroker-data/objects.json.migrated
                                          8.6M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
                                          7.4M    /opt/iobroker/iobroker-data/files/eventlist/static/js/2.fcddf06e.chunk.js.map
                                          *** NodeJS-Installation ***
                                          /usr/bin/nodejs         v18.12.1
                                          /usr/bin/node           v18.12.1
                                          /usr/bin/npm            8.19.2
                                          nodejs:
                                            Version table:
                                           *** 18.12.1-deb-1nodesource1 100
                                               16.19.0-deb-1nodesource1 500
                                                  500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
                                          Temp directories causing npm8 problem: 650
                                          *** ioBroker-Installation ***
                                          ioBroker Status
                                          node:internal/modules/cjs/loader:998
                                            throw err;
                                          Error: Cannot find module 'node-forge'
                                          Require stack:
                                          - /opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js
                                          - /opt/iobroker/node_modules/@iobroker/js-controller-common/index.js
                                          - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js
                                          - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
                                              at Module._resolveFilename (node:internal/modules/cjs/loader:995:15)
                                              at Module._load (node:internal/modules/cjs/loader:841:27)
                                              at Module.require (node:internal/modules/cjs/loader:1061:19)
                                              at require (node:internal/modules/cjs/helpers:103:18)
                                              at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:7:15)
                                              at Module._compile (node:internal/modules/cjs/loader:1159:14)
                                              at Module._extensions..js (node:internal/modules/cjs/loader:1213:10)
                                              at Module.load (node:internal/modules/cjs/loader:1037:32)
                                              at Module._load (node:internal/modules/cjs/loader:878:12)
                                              at Module.require (node:internal/modules/cjs/loader:1061:19) {
                                            code: 'MODULE_NOT_FOUND',
                                            requireStack: [
                                              '/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js',
                                              '/opt/iobroker/node_modules/@iobroker/js-controller-common/index.js',
                                              '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js',
                                              '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                                          Node.js v18.12.1
                                          Core adapters versions
                                            throw err;
                                          Require stack:
                                            requireStack: [
                                          Node.js v18.12.1
                                          js-controller:
                                            throw err;
                                          Require stack:
                                            requireStack: [
                                          Node.js v18.12.1
                                          admin:
                                          npm ERR! code ELSPROBLEMS
                                          npm ERR! extraneous: @googleapis/drive@4.0.1 /opt/iobroker/node_modules/@googleapis/drive
                                          npm ERR! extraneous: @iobroker/ws-server@2.1.0 /opt/iobroker/node_modules/@iobroker/ws-server
                                          npm ERR! extraneous: @protobufjs/aspromise@1.1.2 /opt/iobroker/node_modules/@protobufjs/aspromise
                                          npm ERR! extraneous: @protobufjs/base64@1.1.2 /opt/iobroker/node_modules/@protobufjs/base64
                                          npm ERR! extraneous: @protobufjs/codegen@2.0.4 /opt/iobroker/node_modules/@protobufjs/codegen
                                          npm ERR! extraneous: @protobufjs/eventemitter@1.1.0 /opt/iobroker/node_modules/@protobufjs/eventemitter
                                          npm ERR! extraneous: @protobufjs/fetch@1.1.0 /opt/iobroker/node_modules/@protobufjs/fetch
                                          npm ERR! extraneous: @protobufjs/float@1.0.2 /opt/iobroker/node_modules/@protobufjs/float
                                          npm ERR! extraneous: @protobufjs/inquire@1.1.0 /opt/iobroker/node_modules/@protobufjs/inquire
                                          npm ERR! extraneous: @protobufjs/path@1.1.2 /opt/iobroker/node_modules/@protobufjs/path
                                          npm ERR! extraneous: @protobufjs/pool@1.1.0 /opt/iobroker/node_modules/@protobufjs/pool
                                          npm ERR! extraneous: @protobufjs/utf8@1.1.0 /opt/iobroker/node_modules/@protobufjs/utf8
                                          npm ERR! extraneous: @serialport/binding-mock@10.2.2 /opt/iobroker/node_modules/@serialport/binding-mock
                                          npm ERR! extraneous: @serialport/bindings-cpp@10.8.0 /opt/iobroker/node_modules/@serialport/bindings-cpp
                                          npm ERR! extraneous: @serialport/bindings-interface@1.2.2 /opt/iobroker/node_modules/@serialport/bindings-interface
                                          npm ERR! extraneous: @serialport/parser-byte-length@10.5.0 /opt/iobroker/node_modules/@serialport/parser-byte-length
                                          npm ERR! extraneous: @serialport/parser-cctalk@10.5.0 /opt/iobroker/node_modules/@serialport/parser-cctalk
                                          npm ERR! extraneous: @serialport/parser-delimiter@10.5.0 /opt/iobroker/node_modules/@serialport/parser-delimiter
                                          npm ERR! extraneous: @serialport/parser-inter-byte-timeout@10.5.0 /opt/iobroker/node_modules/@serialport/parser-inter-byte-timeout
                                          npm ERR! extraneous: @serialport/parser-packet-length@10.5.0 /opt/iobroker/node_modules/@serialport/parser-packet-length
                                          npm ERR! extraneous: @serialport/parser-readline@10.5.0 /opt/iobroker/node_modules/@serialport/parser-readline
                                          npm ERR! extraneous: @serialport/parser-ready@10.5.0 /opt/iobroker/node_modules/@serialport/parser-ready
                                          npm ERR! extraneous: @serialport/parser-regex@10.5.0 /opt/iobroker/node_modules/@serialport/parser-regex
                                          npm ERR! extraneous: @serialport/parser-slip-encoder@10.5.0 /opt/iobroker/node_modules/@serialport/parser-slip-encoder
                                          npm ERR! extraneous: @serialport/parser-spacepacket@10.5.0 /opt/iobroker/node_modules/@serialport/parser-spacepacket
                                          npm ERR! extraneous: @serialport/stream@10.5.0 /opt/iobroker/node_modules/@serialport/stream
                                          npm ERR! extraneous: @swc/helpers@0.3.17 /opt/iobroker/node_modules/@swc/helpers
                                          npm ERR! extraneous: @tootallnate/once@1.1.2 /opt/iobroker/node_modules/@tootallnate/once
                                          npm ERR! extraneous: @types/long@4.0.2 /opt/iobroker/node_modules/@types/long
                                          npm ERR! extraneous: @types/node-schedule@1.3.2 /opt/iobroker/node_modules/@types/node-schedule
                                          npm ERR! extraneous: @types/suncalc@1.9.0 /opt/iobroker/node_modules/@types/suncalc
                                          npm ERR! extraneous: acorn-walk@8.2.0 /opt/iobroker/node_modules/acorn-walk
                                          npm ERR! extraneous: acorn@8.8.1 /opt/iobroker/node_modules/acorn
                                          npm ERR! extraneous: ansi-regex@2.1.1 /opt/iobroker/node_modules/ansi-regex
                                          npm ERR! extraneous: any-promise@1.3.0 /opt/iobroker/node_modules/any-promise
                                          npm ERR! extraneous: aproba@1.2.0 /opt/iobroker/node_modules/aproba
                                          npm ERR! extraneous: are-we-there-yet@1.1.7 /opt/iobroker/node_modules/are-we-there-yet
                                          npm ERR! extraneous: array.prototype.findindex@2.2.1 /opt/iobroker/node_modules/array.prototype.findindex
                                          npm ERR! extraneous: arrify@2.0.1 /opt/iobroker/node_modules/arrify
                                          npm ERR! extraneous: ast-types@0.13.4 /opt/iobroker/node_modules/ast-types
                                          npm ERR! extraneous: async@ /opt/iobroker/node_modules/async
                                          npm ERR! extraneous: available-typed-arrays@1.0.5 /opt/iobroker/node_modules/available-typed-arrays
                                          npm ERR! extraneous: balanced-match@1.0.2 /opt/iobroker/node_modules/balanced-match
                                          npm ERR! extraneous: base-64@1.0.0 /opt/iobroker/node_modules/base-64
                                          npm ERR! extraneous: base64-js@1.5.1 /opt/iobroker/node_modules/base64-js
                                          npm ERR! extraneous: bignumber.js@9.1.1 /opt/iobroker/node_modules/bignumber.js
                                          npm ERR! extraneous: bl@1.2.3 /opt/iobroker/node_modules/bl
                                          npm ERR! extraneous: bluebird@3.7.2 /opt/iobroker/node_modules/bluebird
                                          npm ERR! extraneous: brace-expansion@2.0.1 /opt/iobroker/node_modules/brace-expansion
                                          npm ERR! extraneous: brotli@1.3.3 /opt/iobroker/node_modules/brotli
                                          npm ERR! extraneous: buffer@4.9.2 /opt/iobroker/node_modules/buffer
                                          npm ERR! extraneous: busboy@1.6.0 /opt/iobroker/node_modules/busboy
                                          npm ERR! extraneous: byte-length@1.0.2 /opt/iobroker/node_modules/byte-length
                                          npm ERR! extraneous: charenc@0.0.2 /opt/iobroker/node_modules/charenc
                                          npm ERR! extraneous: clone@2.1.2 /opt/iobroker/node_modules/clone
                                          npm ERR! extraneous: code-point-at@1.1.0 /opt/iobroker/node_modules/code-point-at
                                          npm ERR! extraneous: compress-json@2.1.2 /opt/iobroker/node_modules/compress-json
                                          npm ERR! extraneous: compressible@2.0.18 /opt/iobroker/node_modules/compressible
                                          npm ERR! extraneous: compression@1.7.4 /opt/iobroker/node_modules/compression
                                          npm ERR! extraneous: console-control-strings@1.1.0 /opt/iobroker/node_modules/console-control-strings
                                          npm ERR! extraneous: copy-to@2.0.1 /opt/iobroker/node_modules/copy-to
                                          npm ERR! extraneous: crypt@0.0.2 /opt/iobroker/node_modules/crypt
                                          npm ERR! extraneous: crypto-js@4.1.1 /opt/iobroker/node_modules/crypto-js
                                          npm ERR! extraneous: data-uri-to-buffer@3.0.1 /opt/iobroker/node_modules/data-uri-to-buffer
                                          npm ERR! extraneous: decompress-response@6.0.0 /opt/iobroker/node_modules/decompress-response
                                          npm ERR! extraneous: deep-equal@2.1.0 /opt/iobroker/node_modules/deep-equal
                                          npm ERR! extraneous: deep-extend@0.6.0 /opt/iobroker/node_modules/deep-extend
                                          npm ERR! extraneous: deep-is@0.1.4 /opt/iobroker/node_modules/deep-is
                                          npm ERR! extraneous: default-user-agent@1.0.0 /opt/iobroker/node_modules/default-user-agent
                                          npm ERR! extraneous: degenerator@3.0.2 /opt/iobroker/node_modules/degenerator
                                          npm ERR! extraneous: delegates@1.0.0 /opt/iobroker/node_modules/delegates
                                          npm ERR! extraneous: detect-libc@1.0.3 /opt/iobroker/node_modules/detect-libc
                                          npm ERR! extraneous: dfa@1.2.0 /opt/iobroker/node_modules/dfa
                                          npm ERR! extraneous: dgram@1.0.1 /opt/iobroker/node_modules/dgram
                                          npm ERR! extraneous: digest-header@1.0.0 /opt/iobroker/node_modules/digest-header
                                          npm ERR! extraneous: dns-packet@1.3.4 /opt/iobroker/node_modules/dns-packet
                                          npm ERR! extraneous: dropbox-v2-api@ /opt/iobroker/node_modules/dropbox-v2-api
                                          npm ERR! extraneous: end-of-stream@1.4.4 /opt/iobroker/node_modules/end-of-stream
                                          npm ERR! extraneous: es-abstract@ /opt/iobroker/node_modules/es-abstract
                                          npm ERR! extraneous: es-get-iterator@1.1.2 /opt/iobroker/node_modules/es-get-iterator
                                          npm ERR! extraneous: es-shim-unscopables@1.0.0 /opt/iobroker/node_modules/es-shim-unscopables
                                          npm ERR! extraneous: es-to-primitive@1.2.1 /opt/iobroker/node_modules/es-to-primitive
                                          npm ERR! extraneous: escodegen@1.14.3 /opt/iobroker/node_modules/escodegen
                                          npm ERR! extraneous: esprima@4.0.1 /opt/iobroker/node_modules/esprima
                                          npm ERR! extraneous: estraverse@4.3.0 /opt/iobroker/node_modules/estraverse
                                          npm ERR! extraneous: esutils@2.0.3 /opt/iobroker/node_modules/esutils
                                          npm ERR! extraneous: eventemitter3@3.1.2 /opt/iobroker/node_modules/eventemitter3
                                          npm ERR! extraneous: events@1.1.1 /opt/iobroker/node_modules/events
                                          npm ERR! extraneous: expand-template@2.0.3 /opt/iobroker/node_modules/expand-template
                                          npm ERR! extraneous: express-fileupload@1.4.0 /opt/iobroker/node_modules/express-fileupload
                                          npm ERR! extraneous: extend-shallow@2.0.1 /opt/iobroker/node_modules/extend-shallow
                                          npm ERR! extraneous: fast-levenshtein@2.0.6 /opt/iobroker/node_modules/fast-levenshtein
                                          npm ERR! extraneous: fast-text-encoding@1.0.6 /opt/iobroker/node_modules/fast-text-encoding
                                          npm ERR! extraneous: fast-xml-parser@3.21.1 /opt/iobroker/node_modules/fast-xml-parser
                                          npm ERR! extraneous: file-type@3.9.0 /opt/iobroker/node_modules/file-type
                                          npm ERR! extraneous: file-uri-to-path@2.0.0 /opt/iobroker/node_modules/file-uri-to-path
                                          npm ERR! extraneous: fontkit@ /opt/iobroker/node_modules/fontkit
                                          npm ERR! extraneous: for-each@0.3.3 /opt/iobroker/node_modules/for-each
                                          npm ERR! extraneous: formstream@1.1.1 /opt/iobroker/node_modules/formstream
                                          npm ERR! extraneous: fs-constants@1.0.0 /opt/iobroker/node_modules/fs-constants
                                          npm ERR! extraneous: fs-extra@11.1.0 /opt/iobroker/node_modules/fs-extra
                                          npm ERR! extraneous: ftp@0.3.10 /opt/iobroker/node_modules/ftp
                                          npm ERR! extraneous: function.prototype.name@1.1.5 /opt/iobroker/node_modules/function.prototype.name
                                          npm ERR! extraneous: functions-have-names@1.2.3 /opt/iobroker/node_modules/functions-have-names
                                          npm ERR! extraneous: gauge@2.7.4 /opt/iobroker/node_modules/gauge
                                          npm ERR! extraneous: gaxios@5.0.2 /opt/iobroker/node_modules/gaxios
                                          npm ERR! extraneous: gcp-metadata@5.1.0 /opt/iobroker/node_modules/gcp-metadata
                                          npm ERR! extraneous: get-symbol-description@1.0.0 /opt/iobroker/node_modules/get-symbol-description
                                          npm ERR! extraneous: get-uri@3.0.2 /opt/iobroker/node_modules/get-uri
                                          npm ERR! extraneous: github-from-package@0.0.0 /opt/iobroker/node_modules/github-from-package
                                          npm ERR! extraneous: google-auth-library@8.7.0 /opt/iobroker/node_modules/google-auth-library
                                          npm ERR! extraneous: google-p12-pem@4.0.1 /opt/iobroker/node_modules/google-p12-pem
                                          npm ERR! extraneous: googleapis-common@6.0.4 /opt/iobroker/node_modules/googleapis-common
                                          npm ERR! extraneous: gopd@1.0.1 /opt/iobroker/node_modules/gopd
                                          npm ERR! extraneous: gtoken@6.1.2 /opt/iobroker/node_modules/gtoken
                                          npm ERR! extraneous: has-bigints@1.0.2 /opt/iobroker/node_modules/has-bigints
                                          npm ERR! extraneous: has-binary2@1.0.3 /opt/iobroker/node_modules/has-binary2
                                          npm ERR! extraneous: has-tostringtag@1.0.0 /opt/iobroker/node_modules/has-tostringtag
                                          npm ERR! extraneous: has-unicode@2.0.1 /opt/iobroker/node_modules/has-unicode
                                          npm ERR! extraneous: he@1.2.0 /opt/iobroker/node_modules/he
                                          npm ERR! extraneous: hot-patcher@1.0.0 /opt/iobroker/node_modules/hot-patcher
                                          npm ERR! extraneous: http-proxy-agent@4.0.1 /opt/iobroker/node_modules/http-proxy-agent
                                          npm ERR! extraneous: humanize-ms@1.2.1 /opt/iobroker/node_modules/humanize-ms
                                          npm ERR! extraneous: ieee754@1.1.13 /opt/iobroker/node_modules/ieee754
                                          npm ERR! extraneous: ini@1.3.8 /opt/iobroker/node_modules/ini
                                          npm ERR! extraneous: internal-slot@1.0.4 /opt/iobroker/node_modules/internal-slot
                                          npm ERR! invalid: iobroker.backitup@ /opt/iobroker/node_modules/iobroker.backitup
                                          npm ERR! invalid: iobroker.eventlist@ /opt/iobroker/node_modules/iobroker.eventlist
                                          npm ERR! invalid: iobroker.flot@ /opt/iobroker/node_modules/iobroker.flot
                                          npm ERR! extraneous: iobroker.history@2.2.4 /opt/iobroker/node_modules/iobroker.history
                                          npm ERR! invalid: iobroker.js-controller@4.0.23 /opt/iobroker/node_modules/iobroker.js-controller
                                          npm ERR! invalid: iobroker.onvif@ /opt/iobroker/node_modules/iobroker.onvif
                                          npm ERR! extraneous: iobroker.simple-api@2.7.2 /opt/iobroker/node_modules/iobroker.simple-api
                                          npm ERR! extraneous: iobroker.socketio@4.2.0 /opt/iobroker/node_modules/iobroker.socketio
                                          npm ERR! invalid: iobroker.telegram@ /opt/iobroker/node_modules/iobroker.telegram
                                          npm ERR! invalid: iobroker.time-switch@ /opt/iobroker/node_modules/iobroker.time-switch
                                          npm ERR! invalid: iobroker.vis-weather@ /opt/iobroker/node_modules/iobroker.vis-weather
                                          npm ERR! invalid: iobroker.web@ /opt/iobroker/node_modules/iobroker.web
                                          npm ERR! extraneous: iobroker.ws.server@1.0.1 /opt/iobroker/node_modules/iobroker.ws.server
                                          npm ERR! extraneous: iobroker.ws@1.3.0 /opt/iobroker/node_modules/iobroker.ws
                                          npm ERR! extraneous: ip@1.1.8 /opt/iobroker/node_modules/ip
                                          npm ERR! extraneous: ipaddr.js@2.0.1 /opt/iobroker/node_modules/ipaddr.js
                                          npm ERR! extraneous: is-arguments@1.1.1 /opt/iobroker/node_modules/is-arguments
                                          npm ERR! extraneous: is-bigint@1.0.4 /opt/iobroker/node_modules/is-bigint
                                          npm ERR! extraneous: is-boolean-object@1.1.2 /opt/iobroker/node_modules/is-boolean-object
                                          npm ERR! extraneous: is-buffer@1.1.6 /opt/iobroker/node_modules/is-buffer
                                          npm ERR! extraneous: is-callable@1.2.7 /opt/iobroker/node_modules/is-callable
                                          npm ERR! extraneous: is-date-object@1.0.5 /opt/iobroker/node_modules/is-date-object
                                          npm ERR! extraneous: is-extendable@0.1.1 /opt/iobroker/node_modules/is-extendable
                                          npm ERR! extraneous: is-fullwidth-code-point@1.0.0 /opt/iobroker/node_modules/is-fullwidth-code-point
                                          npm ERR! extraneous: is-map@2.0.2 /opt/iobroker/node_modules/is-map
                                          npm ERR! extraneous: is-negative-zero@2.0.2 /opt/iobroker/node_modules/is-negative-zero
                                          npm ERR! extraneous: is-number-object@1.0.7 /opt/iobroker/node_modules/is-number-object
                                          npm ERR! extraneous: is-regex@1.1.4 /opt/iobroker/node_modules/is-regex
                                          npm ERR! extraneous: is-set@2.0.2 /opt/iobroker/node_modules/is-set
                                          npm ERR! extraneous: is-shared-array-buffer@1.0.2 /opt/iobroker/node_modules/is-shared-array-buffer
                                          npm ERR! extraneous: is-string@1.0.7 /opt/iobroker/node_modules/is-string
                                          npm ERR! extraneous: is-symbol@1.0.4 /opt/iobroker/node_modules/is-symbol
                                          npm ERR! extraneous: is-typed-array@1.1.10 /opt/iobroker/node_modules/is-typed-array
                                          npm ERR! extraneous: is-weakmap@2.0.1 /opt/iobroker/node_modules/is-weakmap
                                          npm ERR! extraneous: is-weakref@1.0.2 /opt/iobroker/node_modules/is-weakref
                                          npm ERR! extraneous: is-weakset@2.0.2 /opt/iobroker/node_modules/is-weakset
                                          npm ERR! extraneous: jmespath@0.15.0 /opt/iobroker/node_modules/jmespath
                                          npm ERR! extraneous: json-bigint@1.0.0 /opt/iobroker/node_modules/json-bigint
                                          npm ERR! extraneous: jwa@2.0.0 /opt/iobroker/node_modules/jwa
                                          npm ERR! extraneous: jws@4.0.0 /opt/iobroker/node_modules/jws
                                          npm ERR! extraneous: layerr@0.1.2 /opt/iobroker/node_modules/layerr
                                          npm ERR! extraneous: levn@0.3.0 /opt/iobroker/node_modules/levn
                                          npm ERR! extraneous: linebreak@1.1.0 /opt/iobroker/node_modules/linebreak
                                          npm ERR! extraneous: localforage@1.10.0 /opt/iobroker/node_modules/localforage
                                          npm ERR! extraneous: lodash.get@4.4.2 /opt/iobroker/node_modules/lodash.get
                                          npm ERR! extraneous: long@4.0.0 /opt/iobroker/node_modules/long
                                          npm ERR! extraneous: md5@2.3.0 /opt/iobroker/node_modules/md5
                                          npm ERR! extraneous: mdns-discovery@0.2.6 /opt/iobroker/node_modules/mdns-discovery
                                          npm ERR! extraneous: mimic-response@3.1.0 /opt/iobroker/node_modules/mimic-response
                                          npm ERR! extraneous: minimatch@5.1.2 /opt/iobroker/node_modules/minimatch
                                          npm ERR! extraneous: minimist@1.2.7 /opt/iobroker/node_modules/minimist
                                          npm ERR! extraneous: mkdirp-classic@0.5.3 /opt/iobroker/node_modules/mkdirp-classic
                                          npm ERR! extraneous: mz@2.7.0 /opt/iobroker/node_modules/mz
                                          npm ERR! extraneous: napi-build-utils@1.0.2 /opt/iobroker/node_modules/napi-build-utils
                                          npm ERR! extraneous: nested-property@4.0.0 /opt/iobroker/node_modules/nested-property
                                          npm ERR! extraneous: netmask@2.0.2 /opt/iobroker/node_modules/netmask
                                          npm ERR! extraneous: nimble@0.0.2 /opt/iobroker/node_modules/nimble
                                          npm ERR! extraneous: node-abi@2.30.1 /opt/iobroker/node_modules/node-abi
                                          npm ERR! extraneous: node-addon-api@5.0.0 /opt/iobroker/node_modules/node-addon-api
                                          npm ERR! extraneous: node-fetch@2.6.7 /opt/iobroker/node_modules/node-fetch
                                          npm ERR! extraneous: node-gyp-build@4.5.0 /opt/iobroker/node_modules/node-gyp-build
                                          npm ERR! extraneous: node-mndp@0.0.3 /opt/iobroker/node_modules/node-mndp
                                          npm ERR! extraneous: node-ssdp@4.0.1 /opt/iobroker/node_modules/node-ssdp
                                          npm ERR! extraneous: node-telegram-bot-api@0.59.0 /opt/iobroker/node_modules/node-telegram-bot-api
                                          npm ERR! extraneous: node-wol@0.1.1 /opt/iobroker/node_modules/node-wol
                                          npm ERR! extraneous: noop-logger@0.1.1 /opt/iobroker/node_modules/noop-logger
                                          npm ERR! extraneous: npmlog@4.1.2 /opt/iobroker/node_modules/npmlog
                                          npm ERR! extraneous: number-is-nan@1.0.1 /opt/iobroker/node_modules/number-is-nan
                                          npm ERR! extraneous: object-is@1.1.5 /opt/iobroker/node_modules/object-is
                                          npm ERR! extraneous: object.assign@4.1.4 /opt/iobroker/node_modules/object.assign
                                          npm ERR! extraneous: onvif@0.6.7 /opt/iobroker/node_modules/onvif
                                          npm ERR! extraneous: optionator@0.8.3 /opt/iobroker/node_modules/optionator
                                          npm ERR! extraneous: os-name@1.0.3 /opt/iobroker/node_modules/os-name
                                          npm ERR! extraneous: osx-release@1.1.0 /opt/iobroker/node_modules/osx-release
                                          npm ERR! extraneous: pac-proxy-agent@5.0.0 /opt/iobroker/node_modules/pac-proxy-agent
                                          npm ERR! extraneous: pac-resolver@5.0.1 /opt/iobroker/node_modules/pac-resolver
                                          npm ERR! extraneous: path-posix@1.0.0 /opt/iobroker/node_modules/path-posix
                                          npm ERR! extraneous: pdfkit@ /opt/iobroker/node_modules/pdfkit
                                          npm ERR! extraneous: png-js@1.0.0 /opt/iobroker/node_modules/png-js
                                          npm ERR! extraneous: prebuild-install@5.3.6 /opt/iobroker/node_modules/prebuild-install
                                          npm ERR! extraneous: prelude-ls@1.1.2 /opt/iobroker/node_modules/prelude-ls
                                          npm ERR! extraneous: proxy-agent@5.0.0 /opt/iobroker/node_modules/proxy-agent
                                          npm ERR! extraneous: proxy-from-env@1.1.0 /opt/iobroker/node_modules/proxy-from-env
                                          npm ERR! extraneous: pump@2.0.1 /opt/iobroker/node_modules/pump
                                          npm ERR! extraneous: querystring@0.2.0 /opt/iobroker/node_modules/querystring
                                          npm ERR! extraneous: querystringify@2.2.0 /opt/iobroker/node_modules/querystringify
                                          npm ERR! extraneous: rc@1.2.8 /opt/iobroker/node_modules/rc
                                          npm ERR! extraneous: regexp.prototype.flags@1.4.3 /opt/iobroker/node_modules/regexp.prototype.flags
                                          npm ERR! extraneous: request-promise-core@1.1.4 /opt/iobroker/node_modules/request-promise-core
                                          npm ERR! extraneous: request-promise@4.2.6 /opt/iobroker/node_modules/request-promise
                                          npm ERR! extraneous: requires-port@1.0.0 /opt/iobroker/node_modules/requires-port
                                          npm ERR! extraneous: restructure@2.0.1 /opt/iobroker/node_modules/restructure
                                          npm ERR! extraneous: safe-regex-test@1.0.0 /opt/iobroker/node_modules/safe-regex-test
                                          npm ERR! extraneous: serialport@10.5.0 /opt/iobroker/node_modules/serialport
                                          npm ERR! extraneous: set-blocking@2.0.0 /opt/iobroker/node_modules/set-blocking
                                          npm ERR! extraneous: sharp@0.25.4 /opt/iobroker/node_modules/sharp
                                          npm ERR! extraneous: simple-concat@1.0.1 /opt/iobroker/node_modules/simple-concat
                                          npm ERR! extraneous: simple-get@4.0.1 /opt/iobroker/node_modules/simple-get
                                          npm ERR! extraneous: smart-buffer@4.2.0 /opt/iobroker/node_modules/smart-buffer
                                          npm ERR! extraneous: socks-proxy-agent@5.0.1 /opt/iobroker/node_modules/socks-proxy-agent
                                          npm ERR! extraneous: socks@2.7.1 /opt/iobroker/node_modules/socks
                                          npm ERR! extraneous: socksv5@0.0.6 /opt/iobroker/node_modules/socksv5
                                          npm ERR! extraneous: stealthy-require@1.1.1 /opt/iobroker/node_modules/stealthy-require
                                          npm ERR! extraneous: streamsearch@1.1.0 /opt/iobroker/node_modules/streamsearch
                                          npm ERR! extraneous: string-width@1.0.2 /opt/iobroker/node_modules/string-width
                                          npm ERR! extraneous: string.prototype.trimend@1.0.6 /opt/iobroker/node_modules/string.prototype.trimend
                                          npm ERR! extraneous: string.prototype.trimstart@1.0.6 /opt/iobroker/node_modules/string.prototype.trimstart
                                          npm ERR! extraneous: strip-ansi@3.0.1 /opt/iobroker/node_modules/strip-ansi
                                          npm ERR! extraneous: strip-json-comments@2.0.1 /opt/iobroker/node_modules/strip-json-comments
                                          npm ERR! extraneous: strnum@1.0.5 /opt/iobroker/node_modules/strnum
                                          npm ERR! extraneous: suncalc@1.9.0 /opt/iobroker/node_modules/suncalc
                                          npm ERR! extraneous: tar-fs@2.1.1 /opt/iobroker/node_modules/tar-fs
                                          npm ERR! extraneous: tar-stream@2.2.0 /opt/iobroker/node_modules/tar-stream
                                          npm ERR! extraneous: thenify-all@1.6.0 /opt/iobroker/node_modules/thenify-all
                                          npm ERR! extraneous: thenify@3.3.1 /opt/iobroker/node_modules/thenify
                                          npm ERR! extraneous: tiny-inflate@1.0.3 /opt/iobroker/node_modules/tiny-inflate
                                          npm ERR! extraneous: tr46@0.0.3 /opt/iobroker/node_modules/tr46
                                          npm ERR! extraneous: type-check@0.3.2 /opt/iobroker/node_modules/type-check
                                          npm ERR! extraneous: unbox-primitive@1.0.2 /opt/iobroker/node_modules/unbox-primitive
                                          npm ERR! extraneous: unescape@1.0.1 /opt/iobroker/node_modules/unescape
                                          npm ERR! extraneous: unicode-properties@1.4.1 /opt/iobroker/node_modules/unicode-properties
                                          npm ERR! extraneous: unicode-trie@2.0.0 /opt/iobroker/node_modules/unicode-trie
                                          npm ERR! extraneous: url-join@4.0.1 /opt/iobroker/node_modules/url-join
                                          npm ERR! extraneous: url-parse@1.5.10 /opt/iobroker/node_modules/url-parse
                                          npm ERR! extraneous: url-template@2.0.8 /opt/iobroker/node_modules/url-template
                                          npm ERR! extraneous: url@0.10.3 /opt/iobroker/node_modules/url
                                          npm ERR! extraneous: urllib@2.40.0 /opt/iobroker/node_modules/urllib
                                          npm ERR! extraneous: utility@1.17.0 /opt/iobroker/node_modules/utility
                                          npm ERR! extraneous: uuid@9.0.0 /opt/iobroker/node_modules/uuid
                                          npm ERR! extraneous: vm2@3.9.13 /opt/iobroker/node_modules/vm2
                                          npm ERR! extraneous: webdav@4.11.2 /opt/iobroker/node_modules/webdav
                                          npm ERR! extraneous: webidl-conversions@3.0.1 /opt/iobroker/node_modules/webidl-conversions
                                          npm ERR! extraneous: whatwg-url@5.0.0 /opt/iobroker/node_modules/whatwg-url
                                          npm ERR! extraneous: which-boxed-primitive@1.0.2 /opt/iobroker/node_modules/which-boxed-primitive
                                          npm ERR! extraneous: which-collection@1.0.1 /opt/iobroker/node_modules/which-collection
                                          npm ERR! extraneous: which-pm-runs@1.1.0 /opt/iobroker/node_modules/which-pm-runs
                                          npm ERR! extraneous: which-typed-array@1.1.9 /opt/iobroker/node_modules/which-typed-array
                                          npm ERR! extraneous: wide-align@1.1.5 /opt/iobroker/node_modules/wide-align
                                          npm ERR! extraneous: win-release@1.1.1 /opt/iobroker/node_modules/win-release
                                          npm ERR! extraneous: word-wrap@1.2.3 /opt/iobroker/node_modules/word-wrap
                                          npm ERR! extraneous: xregexp@2.0.0 /opt/iobroker/node_modules/xregexp
                                          npm ERR!     /home/pi/.npm/_logs/2022-12-25T11_40_46_790Z-debug-0.log
                                          Adapters from github:   4
                                            throw err;
                                          Require stack:
                                            requireStack: [
                                          Node.js v18.12.1
                                          ioBroker-Repositories
                                            throw err;
                                          Require stack:
                                            requireStack: [
                                          Node.js v18.12.1
                                          ioBroker-Instances
                                            throw err;
                                          Require stack:
                                            requireStack: [
                                          Node.js v18.12.1
                                          Objects and States
                                          Objects:        0
                                          States:         0
                                          Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                                          Hit:2 https://deb.nodesource.com/node_16.x buster InRelease
                                          Hit:3 http://archive.raspberrypi.org/debian buster InRelease
                                          Pending Updates: 0
                                          *** Listening Ports ***
                                          tcp        0      0 0.0.0.0:8081            0.0.0.0:*               LISTEN      0          14968      500/motion
                                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17637      690/sshd
                                          tcp        0      0 0.0.0.0:8765            0.0.0.0:*               LISTEN      0          16733      371/python
                                          tcp        0      0 127.0.0.1:7999          0.0.0.0:*               LISTEN      0          14970      500/motion
                                          tcp        0      0 127.0.0.1:554           0.0.0.0:*               LISTEN      0          14969      500/motion
                                          tcp        0      0 0.0.0.0:5038            0.0.0.0:*               LISTEN      109        16032      681/asterisk
                                          tcp6       0      0 :::22                   :::*                    LISTEN      0          17639      690/sshd
                                          udp        0      0 0.0.0.0:5060            0.0.0.0:*                           109        16046      681/asterisk
                                          udp        0      0 0.0.0.0:4569            0.0.0.0:*                           109        16047      681/asterisk
                                          udp        0      0 0.0.0.0:50708           0.0.0.0:*                           108        14912      389/avahi-daemon: r
                                          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15785      680/dhcpcd
                                          udp        0      0 0.0.0.0:42178           0.0.0.0:*                           109        17779      681/asterisk
                                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14910      389/avahi-daemon: r
                                          udp6       0      0 :::546                  :::*                                0          16714      680/dhcpcd
                                          udp6       0      0 :::51309                :::*                                109        17780      681/asterisk
                                          udp6       0      0 :::5353                 :::*                                108        14911      389/avahi-daemon: r
                                          udp6       0      0 :::38784                :::*                                108        14913      389/avahi-daemon: r
                                          iob diag has finished.
                                          Press any key for a summary
                                          Copy text starting here:
        v.2022-12-13
                                          Operatingsystem:        Raspbian GNU/Linux 10 (buster)
                                          Installation:           Native
                                          Timezone:               Europe/Berlin
                                          User-ID:                1000
                                          X-Server:               false
                                          Pending OS-Updates:     0
                                          Nodejs-Installation:    /usr/bin/nodejs         v18.12.1
        /usr/bin/npm            8.19.2
                                            throw err;
                                          Require stack:
                                            requireStack: [
                                          Node.js v18.12.1
                                          ioBroker Core:          js-controller
                                            throw err;
                                          Require stack:
                                            requireStack: [
                                          Node.js v18.12.1
        admin
                                            throw err;
                                          Require stack:
                                            requireStack: [
                                          Node.js v18.12.1
                                          ioBroker Status:
                                            throw err;
                                          Require stack:
                                            requireStack: [
                                          Node.js v18.12.1
                                          Pending iob updates:    0
                                            throw err;
                                          Require stack:
                                            requireStack: [
                                          Node.js v18.12.1
                                          Objects:                0
                                          States:                 0
                                          Size of iob-Database:
                                          3.5M    /opt/iobroker/iobroker-data/states.jsonl
                                          3.0M    /opt/iobroker/iobroker-data/states.json.migrated
                                          3.0M    /opt/iobroker/iobroker-data/states.json.bak.migrated
                                          ====================== END OF SUMMARY =================
