  4. Admin Problem
    5.6k
Admin Problem
admin
70 Beiträge 8 Kommentatoren 10.2k Aufrufe 7 Beobachtet
  • N nullfreizeit
    Das kam jetzt raus. So wie ich lese sind die Verzeichnisse ok, oder? Hab einen re-install gemacht aber bei list instances bekomme ich wieder einen disabled admin. Und wenn ich manuell admin starte ist dieser weiter disabled?
    pi@raspberrypi:~ $ for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%/}; done
    pi@raspberrypi:~ $ node -v
    v18.12.1
    pi@raspberrypi:~ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt-get update &> /dev/null && sudo apt-get update && apt-cache policy nodejs
    armv7l
    /usr/bin/nodejs
    /usr/bin/node
    /usr/bin/npm
    v18.12.1
    v18.12.1
    8.19.2
    4.0.23
    pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
    tty
    /home/pi
    Hit:1 http://archive.raspberrypi.org/debian buster InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
    Hit:3 https://deb.nodesource.com/node_18.x buster InRelease
    Reading package lists... Done
    nodejs:
      Installed: 18.12.1-deb-1nodesource1
      Candidate: 18.12.1-deb-1nodesource1
      Version table:
     *** 18.12.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x buster/main armhf Packages
         10.24.0~dfsg-1~deb10u2 500
    pi@raspberrypi:~ $ sudo apt install nodejs --reinstall
    Building dependency tree
    The following packages were automatically installed and are no longer required:
      libdrm-etnaviv1 libllvm6.0
    Use 'sudo apt autoremove' to remove them.
    0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 0 not upgraded.
    Need to get 0 B/25.1 MB of archives.
    After this operation, 0 B of additional disk space will be used.
    (Reading database ... 57598 files and directories currently installed.)
    Preparing to unpack .../nodejs_18.12.1-deb-1nodesource1_armhf.deb ...
    Unpacking nodejs (18.12.1-deb-1nodesource1) over (18.12.1-deb-1nodesource1) ...
    Setting up nodejs (18.12.1-deb-1nodesource1) ...
    Processing triggers for man-db (2.8.5-2) ...
    DJMarc75D Offline
    DJMarc75D Offline
    DJMarc75
    @nullfreizeit
    https://forum.iobroker.net/topic/61353/admin-problem/12?_=1671956831150
    wenn das nicht genutzt wird bin ich raus !
    https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
    Lehrling seit 1975 !!!
    N 1 Antwort Letzte Antwort
    • DJMarc75D DJMarc75
      @nullfreizeit
      N Offline
      N Offline
      nullfreizeit
      @djmarc75 sagte in Admin Problem:
      @nullfreizeit
      Hallo Marc,
      Sorry, aber das hab ich doch gemacht. Oder hab ich was übersprungen. Danke für eure Hilfe.
      • N nullfreizeit
        v18.12.1
        armv7l
        /usr/bin/nodejs
        /usr/bin/node
        /usr/bin/npm
        v18.12.1
        v18.12.1
        8.19.2
        4.0.23
        pi
        tty
        /home/pi
        nodejs:
          Version table:
        Jan1
        @nullfreizeit
        Node ist zumindest jetzt mal gerade, aber immer noch 18 und eigentlich ist 16 empfohlen. Wenn alles wieder läuft, dann lass das so. Sonst die Anleitung durchziehen, bis Du auf Node 16 bist.
        @DJMarc75
        Du willst dass er die Anleitung abarbeitet und wenn ich vorschlage das über ein Restor zu lösen, bei dem der IOBroker vorher immer gelöscht sein sollte, kommst Du mit Neuaufsetzten des System?
        Im Zweifel ist dass, das Beste und Sauberste, aber bis jetzt nicht nötig. Wenn er die verbogene Node deinstalliert und dann restort, kommt er genau auf das Selbe raus, wenn am OS nicht auch schon ein paar Dinge verbogen sind .
        Da er aber noch Buster laufen hat, würde ich auch zu einem aktuelle Debian Bullseye raten ;)
        Danach den IOBroker Restor und in einer Stunde ist das Ding sauber gelutscht.
        • N nullfreizeit
          @nullfreizeit
          Hallo Marc,
          DJMarc75D Offline
          DJMarc75D Offline
          DJMarc75
          @nullfreizeit sagte in Admin Problem:
          Naja, um es mal beim Namen zu nennen: Du hast in Teil 2 ja nur den ersten Befehl ausgeführt... da gibts ja noch mehr...
          • J Jan1
            @nullfreizeit
            @DJMarc75
            DJMarc75D Offline
            DJMarc75D Offline
            DJMarc75
            @jan1
            @jan1 sagte in Admin Problem:
            Na das war ja der Punkt 😀 👍
            • N Offline
              N Offline
              nullfreizeit
              Hallo ihr zwei. Danke für eure Geduld mit mir. Habe jetzt alles noch einmal gemacht gem. der Beschreibung Teil 2.
              Aber auch nach einem sudo reboot komme ich nicht weiter. Könnt ihr mir bitte helfen? Danke
              armv7l
              /usr/bin/nodejs
              /usr/bin/node
              /usr/bin/npm
              v18.12.1
              v18.12.1
              8.19.2
              4.0.23
              pi
              tty
              /home/pi
                Version table:
              pi@raspberrypi:~ $ uname -a
              Linux raspberrypi 5.10.103-v7l+ #1529 SMP Tue Mar 8 12:24:00 GMT 2022 armv7l GNU/Linux
              pi@raspberrypi:~ $ lsb_release -a
              No LSB modules are available.
              Distributor ID: Raspbian
              Description:    Raspbian GNU/Linux 10 (buster)
              Release:        10
              Codename:       buster
              • N nullfreizeit
                armv7l
                /usr/bin/nodejs
                /usr/bin/node
                /usr/bin/npm
                v18.12.1
                v18.12.1
                8.19.2
                4.0.23
                pi
                tty
                /home/pi
                  Version table:
                Release:        10
                Codename:       buster
                Jan1
                @nullfreizeit
                Da Du noch Buster laufen hast, macht es eh nicht so viel Sinn hier manuell was zu richten. Mach den Pi mit Bullseye frisch und restore ein IOBroker Backup. Da hast auf Dauer wesentlich mehr davon.
                Der PI Installer gibt ja mittlerweile schon alles vor was an nötiger Konfiguration zu erledigen ist und dann als OS das lite ohne Desktop. Dauert wenn es normal läuft ne Stunde von 0 bis IOBroker läuft wie vorher und es ist aktuell und sauber.
                • J Jan1
                  @nullfreizeit
                  N Offline
                  N Offline
                  nullfreizeit
                  @jan1
                  Danke Jan für deine Unterstützung. Wie gehe ich da vor. Verstehe nicht genau was du meinst. Ich muss also downgraden? Bin euch wirklich dankbar und weiß das ihr wahrscheinlich schon kurz vorm verzweifeln seid :-)
                  J DJMarc75D 2 Antworten Letzte Antwort
                  • N nullfreizeit
                    @jan1
                    Jan1
                    @nullfreizeit
                    Nein Du machst die SD Karte komplett frisch.
                    • N nullfreizeit
                      @jan1
                      DJMarc75D Offline
                      DJMarc75D Offline
                      DJMarc75
                      da braucht es noch ne Weile und viel mehr dazu 😀
                      Trotzdem solltest Du die Anleitung vom obigen Link befolgen !
                        N Offline
                        N Offline
                        nullfreizeit
                        Hi DjMarc75,
                        Na das ist gut zu wissen. ;-)
                        Aber sag mir doch bitte was ich noch nicht gemacht habe. Habe doch den gesamten Teil 2 durch, oder?
                        • N nullfreizeit
                          Hi DjMarc75,
                          @nullfreizeit
                          Was ist denn jetzt konkret dein Problem?
                          nodeJS18 ist zwar nicht die zur Zeit empfohlene Version, aber wenn es funktioniert lass es so.
                          Allerdings solltest du den abgekündigten Buster durch Bullseye ersetzen.
                          N 2 Antworten Letzte Antwort
                            @nullfreizeit
                            N Offline
                            N Offline
                            nullfreizeit
                            Hi Thomas,
                            gestern wurde mir der Zigbee Adapter als Update vorgeschlagen. Während des Updates funktionierte dann Admin nicht mehr.
                            Jetzt konnte bis vor 5 Min nicht mehr das Admin Panel aufrufen.
                            Nachdem ich per „iobroker list instances“ manuell „iobroker start admin.0“ + „iobroker start web.0“ eingegeben habe funktioniert der aufruf des Admin Panels wieder. Wie gesagt gerade eben durch Zufall. Nun startet aber kein Adapter mehr.
                            Bin am verzweifeln. Kann ich irgendwie backitup starten und eine Wiederherstellung machen oder was wäre dein/euer Vorschlag?
                            Vielen Dank.
                              @nullfreizeit
                              N Offline
                              N Offline
                              nullfreizeit
                              @thomas-braun sagte in Admin Problem:
                              Wie kann ich das machen? Danke
                              • N nullfreizeit
                                Jan1
                                @nullfreizeit
                                Wie schon geschrieben, von Buster weg und Bullseye neu drauf, danach das Backup restoren und fertig. Hättest das heute morgen schon gemacht, hättest schon lange fertig ;)
                                • N nullfreizeit
                                  Hi Thomas,
                                  Vielen Dank.
                                  Woran machst du das fest?
                                  sagt?
                                  Upgrade auf Bullseye:
                                  https://forum.iobroker.net/topic/47213/upgrade-von-debian-10-buster-auf-11-bullseye
                                    sagt?
                                    N Offline
                                    N Offline
                                    nullfreizeit
                                    pi@raspberrypi:~ $ iobroker list instances
                                    + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 7777, bind: 0.0.0.0, run as: admin
                                      system.adapter.alarm.0                  : alarm                 : raspberrypi                              - disabled
                                    + system.adapter.asterisk.0               : asterisk              : raspberrypi                              -  enabled, port: 5038
                                      system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
                                    + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
                                      system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
                                      system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
                                      system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
                                      system.adapter.email.0                  : email                 : raspberrypi                              -  enabled
                                      system.adapter.eventlist.0              : eventlist             : raspberrypi                              - disabled
                                      system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
                                      system.adapter.history.0                : history               : raspberrypi                              - disabled
                                      system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
                                      system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi                              - disabled
                                      system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
                                      system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
                                      system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
                                      system.adapter.landroid.0               : landroid              : raspberrypi                              - disabled
                                      system.adapter.mihome-vacuum.0          : mihome-vacuum         : raspberrypi                              -  enabled, port: 54321
                                      system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1889, bind: 192.168.188.35
                                      system.adapter.musiccast.0              : musiccast             : raspberrypi                              -  enabled
                                      system.adapter.nina.0                   : nina                  : raspberrypi                              -  enabled
                                      system.adapter.onvif.0                  : onvif                 : raspberrypi                              - disabled
                                      system.adapter.openligadb.0             : openligadb            : raspberrypi                              -  enabled
                                      system.adapter.openweathermap.0         : openweathermap        : raspberrypi                              -  enabled
                                      system.adapter.pegelalarm.0             : pegelalarm            : raspberrypi                              -  enabled
                                      system.adapter.rssfeed.0                : rssfeed               : raspberrypi                              -  enabled
                                      system.adapter.sayit.0                  : sayit                 : raspberrypi                              - disabled, port: 0
                                      system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
                                      system.adapter.simple-api.0             : simple-api            : raspberrypi                              - disabled, port: 8087, bind: 0.0.0.0, run as: admin
                                      system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
                                      system.adapter.sony-bravia.0            : sony-bravia           : raspberrypi                              -  enabled
                                      system.adapter.telegram.0               : telegram              : raspberrypi                              - disabled, port: 8443, bind: 0.0.0.0
                                      system.adapter.terminal.0               : terminal              : raspberrypi                              - disabled, port: 8088, bind: 0.0.0.0, run as: admin
                                      system.adapter.time-switch.0            : time-switch           : raspberrypi                              - disabled
                                      system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
                                      system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
                                      system.adapter.tvspielfilm.0            : tvspielfilm           : raspberrypi                              -  enabled
                                      system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              - disabled
                                      system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              - disabled
                                      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
                                      system.adapter.vis-history.0            : vis-history           : raspberrypi                              - disabled
                                      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
                                      system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
                                      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
                                      system.adapter.vis-material.0           : vis-material          : raspberrypi                              -  enabled
                                      system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              -  enabled
                                      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
                                      system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              - disabled
                                      system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
                                      system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              - disabled
                                      system.adapter.yahka.0                  : yahka                 : raspberrypi                              -  enabled
                                      system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/ttyACM0
                                    + instance is alive
                                    • N nullfreizeit
                                      + instance is alive
                                      @nullfreizeit
                                      Und wenn du die Instanzen im Admin startest?
                                      • N nullfreizeit
                                        + instance is alive
                                        crunchipC Abwesend
                                        crunchipC Abwesend
                                        @nullfreizeit oder mal ein iob restart
                                        • N Offline
                                          N Offline
                                          nullfreizeit
                                          @nullfreizeit
                                          Es passiert nix. Wenn ich stoppe und neu starte bekomme ich solche Meldungen
                                          host.raspberrypi
                                          2022-12-25 12:26:58.719	info	iobroker npm-install: Installing iobroker.history@2.2.4... (System call)
                                          host.raspberrypi
                                          2022-12-25 12:26:58.716	info	iobroker npm-install: NPM version: 8.19.2
                                          email.0
                                          2022-12-25 12:26:55.950	info	starting. Version 1.1.4 in /opt/iobroker/node_modules/iobroker.email, node: v18.12.1, js-controller: 4.0.23
                                          host.raspberrypi
                                          2022-12-25 12:26:54.045	info	iobroker install history@2.2.4 using installedFrom
                                          host.raspberrypi
                                          2022-12-25 12:26:54.044	warn	startInstance cannot find adapter "history@2.2.4". Try to install it... 1 attempt
