  4. Test Adapter Fiat Jeep v0.0.x
206 Beiträge 40 Kommentatoren 56.7k Aufrufe 38 Beobachtet
  • jwinklerJ
    jwinklerJ
    jwinkler
    #93
    Hallo, ich brauche mal hilfe, bei mir bleibt der Adapter rot, im Log kann ich nur sehen das der Adapter ständig neu gestartet wird, hat jemand eine Idee???
    • jwinklerJ jwinkler
      T
      T
      tombox
      #94
      @jwinkler wichtig wäre hier der exakte Fehler
      jwinklerJ 1 Antwort Letzte Antwort
      • jwinklerJ
        jwinklerJ
        jwinkler
        #95
        ich kann dir später den Logauszug zeigen, reicht das?
        • T tombox
          jwinklerJ
          jwinklerJ
          jwinkler
          #96
          @tombox das log:
          2022-12-20 06:57:10.420 - error: host.iobroker Caught by controller[0]: node:internal/modules/cjs/loader:528
          2022-12-20 06:57:10.420 - error: host.iobroker Caught by controller[0]: throw e;
          2022-12-20 06:57:10.420 - error: host.iobroker Caught by controller[0]: ^
          2022-12-20 06:57:10.420 - error: host.iobroker Caught by controller[0]: Error [ERR_PACKAGE_PATH_NOT_EXPORTED]: Package subpath './lib/defaults' is not defined by "exports" in /opt/iobroker/node_modules/axios/package.json
          2022-12-20 06:57:10.421 - error: host.iobroker Caught by controller[0]: at new NodeError (node:internal/errors:387:5)
          2022-12-20 06:57:10.421 - error: host.iobroker Caught by controller[0]: at throwExportsNotFound (node:internal/modules/esm/resolve:365:9)
          2022-12-20 06:57:10.421 - error: host.iobroker Caught by controller[0]: at packageExportsResolve (node:internal/modules/esm/resolve:649:3)
          2022-12-20 06:57:10.421 - error: host.iobroker Caught by controller[0]: at resolveExports (node:internal/modules/cjs/loader:522:36)
          2022-12-20 06:57:10.421 - error: host.iobroker Caught by controller[0]: at Function.Module._findPath (node:internal/modules/cjs/loader:562:31)
          2022-12-20 06:57:10.422 - error: host.iobroker Caught by controller[0]: at Function.Module._resolveFilename (node:internal/modules/cjs/loader:971:27)
          2022-12-20 06:57:10.422 - error: host.iobroker Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:833:27)
          2022-12-20 06:57:10.422 - error: host.iobroker Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1057:19)
          2022-12-20 06:57:10.422 - error: host.iobroker Caught by controller[0]: at require (node:internal/modules/cjs/helpers:103:18)
          2022-12-20 06:57:10.422 - error: host.iobroker Caught by controller[0]: at Object. (/opt/iobroker/node_modules/axios-cookiejar-support/lib/index.js:8:40) {
          2022-12-20 06:57:10.422 - error: host.iobroker Caught by controller[0]: code: 'ERR_PACKAGE_PATH_NOT_EXPORTED'
          2022-12-20 06:57:10.422 - error: host.iobroker Caught by controller[0]: }
          2022-12-20 06:57:10.423 - error: host.iobroker instance system.adapter.fiat.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          2022-12-20 06:57:10.423 - info: host.iobroker Restart adapter system.adapter.fiat.0 because enabled
          2022-12-20 06:57:40.531 - info: host.iobroker instance system.adapter.fiat.0 started with pid 45133
            @tombox das log:
            T
            T
            tombox
            #97
            @jwinkler Probier mal die github version zu installieren
            jwinklerJ 2 Antworten Letzte Antwort
            • T tombox
              jwinklerJ
              jwinklerJ
              jwinkler
              #98
              @tombox sagte in Test Adapter Fiat Jeep v0.0.x:
              jepp, probiere ich heute abend aus
              • T tombox
                jwinklerJ
                jwinklerJ
                jwinkler
                #99
                @tombox
                Hallo, die direkte Installation von Github bring das selbe verhalten
                  @tombox
                  jwinklerJ
                  jwinklerJ
                  jwinkler
                  #100
                  @jwinkler sagte in Test Adapter Fiat Jeep v0.0.x:
                  @tombox
                  host.iobroker
                  2022-12-23 11:54:26.533 error instance system.adapter.fiat.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                  Thomas BraunT T 2 Antworten Letzte Antwort
                    @tombox
                    host.iobroker
                    Thomas BraunT
                    Thomas BraunT
                    Most Active Developer
                    #101
                    @jwinkler Welche nodejs-Version und ist die sauber installiert?
                      @tombox
                      host.iobroker
                      T
                      T
                      tombox
                      #102
                      @jwinkler ausführlicher log beim installieren und starten wäre hilfreich
                      • Nico HoffmannN
                        Nico HoffmannN
                        Nico Hoffmann
                        #103
                        Hallo erstmal, bei mir funktioniert der Adapter an sich wie er soll. Allerdings bekomme ich im Protokoll relativ oft Meldungen nach dieser Art angezeigt: State value to set for "fiat.0."XXXXX...XX".location.latitude" has to be type "string" but received type "number". Ist das bekannt, oder nur bei mir so?
                        VG Nico
                        • Nico HoffmannN Nico Hoffmann
                          VG Nico
                          T
                          T
                          tombox
                          #104
                          @nico-hoffmann ja probier mal die Objekte zu löschen ob es dann dauerhaft nach adapter Neustart weg ist
                          Nico HoffmannN 1 Antwort Letzte Antwort
                          • T tombox
                            Nico HoffmannN
                            Nico HoffmannN
                            Nico Hoffmann
                            #105
                            @tombox Meinst du nur die Objekte bei denen der Fehler auftritt? Ich hab nämlich das Objekt latitude gerade gelöscht und nach Neustart ist es dann wieder aufgetaucht.
                            • O
                              O
                              oliver26316
                              #106
                              Kann man über den Adapter auch die Ladestufen einstellen, oder geht nur das Auslesen?
                              Marcus KlöstersM 1 Antwort Letzte Antwort
                              • O oliver26316
                                Marcus KlöstersM
                                Marcus KlöstersM
                                Marcus Klösters
                                #107
                                @tombox Vielen Dank für deinen Adapter.
                                Die Frage von @oliver26316 interessiert mich auch sehr.
                                Und ob bereits jemand einen Weg gefunden hat, den Ladevorgang über ioBroker wieder zu stoppen.
                                Alle Remote Controls funktionieren bei mir, jedoch bekomme ich auch über Umwege wie z.B. RDU (Unlock) keinen Ladestopp hin.
                                T A 2 Antworten Letzte Antwort
                                • Marcus KlöstersM Marcus Klösters
                                  T
                                  T
                                  tombox
                                  #108
                                  @marcus-klösters Geht es denn über die app
                                  • T tombox
                                    Marcus KlöstersM
                                    Marcus KlöstersM
                                    Marcus Klösters
                                    #109
                                    @tombox
                                    Leider geht es auch nicht über die FIAT App.
                                    Wenn das Fahrzeug offen ist, lässt sich der Ladevorgang nur per Hardware-Knopf hinter der Ladeklappe stoppen und starten.
                                    Mein SwitchBot ist leider auch zu schwach, um diesen Knopf zu drücken, sonst hätte ich mir damit eine Konstruktion einfallen lassen. ;-)
                                    Dann werden wir wohl auf die Weiterentwicklung der Fiat API hoffen und warten müssen?
                                    Ich bin wohl zu Tesla-verwöhnt. :-)
                                      @tombox
                                      Marcus KlöstersM
                                      Marcus KlöstersM
                                      Marcus Klösters
                                      #110
                                      Inzwischen hat mir der sehr freundliche Entwickler des ioBroker.sonnen-charger Adapters die neue, gewünschte Funktionalität eingebaut, so dass ich nun mit Umweg über meine Wallbox z.B. per sonnen-charger.0.commands.connectors.1.pauseCharging das Laden pausieren kann.
                                      • D
                                        D
                                        Det20
                                        #111
                                        inzwischen kann ich über die App sehen, ob die Türen verriegelt sind, im Adapter finde ich die Info nicht. Habe ich etwas übersehen oder kann ich einen Request dafür abgeben?
                                        Viele Grüße
                                        • N
                                          N
                                          nlsnbn
                                          schrieb am zuletzt editiert von nlsnbn
                                          #112
                                          In meiner Jeep App wird die km Anzeige nicht mehr, bzw verspätet aktualisiert. Ich erhalte aktuell immer den km Stand vom Vortag. Das ist aber erst sein ein paar Tagen so. Kann mir da jemand helfen?
                                          DAS PROBLEM HAT SICH VON SELBST BEHOBEN
                                          84.1k
