  4. Test Adapter Fiat Jeep v0.0.x
    6.8k
204 Beiträge 38 Kommentatoren 45.4k Aufrufe 36 Beobachtet
  • T tombox
    @det20 Ist der 12 V stand in der app oder in den adapter Objekten sichtbar?
    Det20
    #92
    @tombox status.vehicleInfo.batteryInfo.batteryVoltage
    • jwinklerJ Offline
      jwinklerJ Offline
      jwinkler
      #93
      Hallo, ich brauche mal hilfe, bei mir bleibt der Adapter rot, im Log kann ich nur sehen das der Adapter ständig neu gestartet wird, hat jemand eine Idee???
      • jwinklerJ jwinkler
        tombox
        #94
        @jwinkler wichtig wäre hier der exakte Fehler
        jwinklerJ 1 Antwort Letzte Antwort
        • jwinklerJ Offline
          jwinklerJ Offline
          jwinkler
          #95
          ich kann dir später den Logauszug zeigen, reicht das?
          • T tombox
            jwinklerJ Offline
            jwinklerJ Offline
            jwinkler
            #96
            @tombox das log:
            2022-12-20 06:57:10.420 - error: host.iobroker Caught by controller[0]: node:internal/modules/cjs/loader:528
            2022-12-20 06:57:10.420 - error: host.iobroker Caught by controller[0]: throw e;
            2022-12-20 06:57:10.420 - error: host.iobroker Caught by controller[0]: ^
            2022-12-20 06:57:10.420 - error: host.iobroker Caught by controller[0]: Error [ERR_PACKAGE_PATH_NOT_EXPORTED]: Package subpath './lib/defaults' is not defined by "exports" in /opt/iobroker/node_modules/axios/package.json
            2022-12-20 06:57:10.421 - error: host.iobroker Caught by controller[0]: at new NodeError (node:internal/errors:387:5)
            2022-12-20 06:57:10.421 - error: host.iobroker Caught by controller[0]: at throwExportsNotFound (node:internal/modules/esm/resolve:365:9)
            2022-12-20 06:57:10.421 - error: host.iobroker Caught by controller[0]: at packageExportsResolve (node:internal/modules/esm/resolve:649:3)
            2022-12-20 06:57:10.421 - error: host.iobroker Caught by controller[0]: at resolveExports (node:internal/modules/cjs/loader:522:36)
            2022-12-20 06:57:10.421 - error: host.iobroker Caught by controller[0]: at Function.Module._findPath (node:internal/modules/cjs/loader:562:31)
            2022-12-20 06:57:10.422 - error: host.iobroker Caught by controller[0]: at Function.Module._resolveFilename (node:internal/modules/cjs/loader:971:27)
            2022-12-20 06:57:10.422 - error: host.iobroker Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:833:27)
            2022-12-20 06:57:10.422 - error: host.iobroker Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1057:19)
            2022-12-20 06:57:10.422 - error: host.iobroker Caught by controller[0]: at require (node:internal/modules/cjs/helpers:103:18)
            2022-12-20 06:57:10.422 - error: host.iobroker Caught by controller[0]: at Object. (/opt/iobroker/node_modules/axios-cookiejar-support/lib/index.js:8:40) {
            2022-12-20 06:57:10.422 - error: host.iobroker Caught by controller[0]: code: 'ERR_PACKAGE_PATH_NOT_EXPORTED'
            2022-12-20 06:57:10.422 - error: host.iobroker Caught by controller[0]: }
            2022-12-20 06:57:10.423 - error: host.iobroker instance system.adapter.fiat.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
            2022-12-20 06:57:10.423 - info: host.iobroker Restart adapter system.adapter.fiat.0 because enabled
            2022-12-20 06:57:40.531 - info: host.iobroker instance system.adapter.fiat.0 started with pid 45133
              @tombox das log:
              tombox
              #97
              @jwinkler Probier mal die github version zu installieren
              jwinklerJ 2 Antworten Letzte Antwort
              • T tombox
                jwinklerJ Offline
                jwinklerJ Offline
                jwinkler
                #98
                @tombox sagte in Test Adapter Fiat Jeep v0.0.x:
                jepp, probiere ich heute abend aus
                • T tombox
                  jwinklerJ Offline
                  jwinklerJ Offline
                  jwinkler
                  #99
                  @tombox
                  Hallo, die direkte Installation von Github bring das selbe verhalten
                    @tombox
                    jwinklerJ Offline
                    jwinklerJ Offline
                    jwinkler
                    #100
                    @jwinkler sagte in Test Adapter Fiat Jeep v0.0.x:
                    @tombox
                    host.iobroker
                    2022-12-23 11:54:26.533 error instance system.adapter.fiat.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                    Thomas BraunT T 2 Antworten Letzte Antwort
                      @tombox
                      host.iobroker
                      #101
                      @jwinkler Welche nodejs-Version und ist die sauber installiert?
                        @tombox
                        host.iobroker
                        tombox
                        #102
                        @jwinkler ausführlicher log beim installieren und starten wäre hilfreich
                        • Nico HoffmannN Offline
                          Nico Hoffmann
                          #103
                          Hallo erstmal, bei mir funktioniert der Adapter an sich wie er soll. Allerdings bekomme ich im Protokoll relativ oft Meldungen nach dieser Art angezeigt: State value to set for "fiat.0."XXXXX...XX".location.latitude" has to be type "string" but received type "number". Ist das bekannt, oder nur bei mir so?
                          VG Nico
                          • Nico HoffmannN Nico Hoffmann
                            VG Nico
                            tombox
                            #104
                            @nico-hoffmann ja probier mal die Objekte zu löschen ob es dann dauerhaft nach adapter Neustart weg ist
                            Nico HoffmannN 1 Antwort Letzte Antwort
                            • T tombox
                              Nico Hoffmann
                              #105
                              @tombox Meinst du nur die Objekte bei denen der Fehler auftritt? Ich hab nämlich das Objekt latitude gerade gelöscht und nach Neustart ist es dann wieder aufgetaucht.
                              • O Offline
                                O Offline
                                oliver26316
                                #106
                                Kann man über den Adapter auch die Ladestufen einstellen, oder geht nur das Auslesen?
                                Marcus KlöstersM 1 Antwort Letzte Antwort
                                • O oliver26316
                                  Marcus KlöstersM Offline
                                  Marcus Klösters
                                  #107
                                  @tombox Vielen Dank für deinen Adapter.
                                  Die Frage von @oliver26316 interessiert mich auch sehr.
                                  Und ob bereits jemand einen Weg gefunden hat, den Ladevorgang über ioBroker wieder zu stoppen.
                                  Alle Remote Controls funktionieren bei mir, jedoch bekomme ich auch über Umwege wie z.B. RDU (Unlock) keinen Ladestopp hin.
                                  T A 2 Antworten Letzte Antwort
                                  • Marcus KlöstersM Marcus Klösters
                                    tombox
                                    #108
                                    @marcus-klösters Geht es denn über die app
                                    • T tombox
                                      Marcus Klösters
                                      #109
                                      @tombox
                                      Leider geht es auch nicht über die FIAT App.
                                      Wenn das Fahrzeug offen ist, lässt sich der Ladevorgang nur per Hardware-Knopf hinter der Ladeklappe stoppen und starten.
                                      Mein SwitchBot ist leider auch zu schwach, um diesen Knopf zu drücken, sonst hätte ich mir damit eine Konstruktion einfallen lassen. ;-)
                                      Dann werden wir wohl auf die Weiterentwicklung der Fiat API hoffen und warten müssen?
                                      Ich bin wohl zu Tesla-verwöhnt. :-)
                                        @tombox
                                        Marcus Klösters
                                        #110
                                        Inzwischen hat mir der sehr freundliche Entwickler des ioBroker.sonnen-charger Adapters die neue, gewünschte Funktionalität eingebaut, so dass ich nun mit Umweg über meine Wallbox z.B. per sonnen-charger.0.commands.connectors.1.pauseCharging das Laden pausieren kann.
                                          Det20
                                          #111
                                          inzwischen kann ich über die App sehen, ob die Türen verriegelt sind, im Adapter finde ich die Info nicht. Habe ich etwas übersehen oder kann ich einen Request dafür abgeben?
                                          Viele Grüße
