Probleme nach Update
@crunchip
Habe aber nur das Fix ausgeführt -
Kann das sein, das hier Berechtigungen fehlen??at Function.Module.runMain (internal/modules/cjs/loader.js:831:12) at startup (internal/bootstrap/node.js:283:19) at bootstrapNodeJSCore (internal/bootstrap/node.js:623:3) pi@raspberry:~ $ > /usr/local/bin/node v12.16.2 -bash: /usr/local/bin/node: Keine Berechtigung pi@raspberry:~ $ > /usr/local/bin/npm 6.14.4 -bash: /usr/local/bin/npm: Keine Berechtigung pi@raspberry:~ $ > -bash: Syntaxfehler beim unerwarteten Wort `newline' pi@raspberry:~ $ > ioBroker Core: js-controller 2.2.9 -bash: Core:: Kommando nicht gefunden. pi@raspberry:~ $ > admin 4.0.10 -bash: 4.0.10: Kommando nicht gefunden. pi@raspberry:~ $ > -bash: Syntaxfehler beim unerwarteten Wort `newline' pi@raspberry:~ $ > ioBroker Status: iobroker is running on this host. -bash: Status:: Kommando nicht gefunden. pi@raspberry:~ $ > -bash: Syntaxfehler beim unerwarteten Wort `newline' pi@raspberry:~ $ > At least one iobroker host is running. -bash: least: Kommando nicht gefunden. pi@raspberry:~ $ > -bash: Syntaxfehler beim unerwarteten Wort `newline' pi@raspberry:~ $ > Objects type: file -bash: type:: Kommando nicht gefunden. pi@raspberry:~ $ > States type: file -bash: type:: Kommando nicht gefunden. pi@raspberry:~ $ > -bash: Syntaxfehler beim unerwarteten Wort `newline' pi@raspberry:~ $ > Pending iob updates: 45 Commands: iobroker setup [--objects <host>] [--states <host>] [custom] iobroker start iobroker stop iobroker start <adapter> iobroker stop <adapter> iobroker start all iobroker restart iobroker restart <adapter> iobroker info iobroker logs [adapter] [--watch] [--lines=1000] iobroker add <adapter> [desiredNumber] [--enabled] [--host <host>] [--port <port>] iobroker install <adapter> iobroker url <url> [<name>] iobroker del <adapter> iobroker del <adapter>.<instance> iobroker update [repository url] [--updatable/--u] [--installed/--i] iobroker upgrade [repository url] iobroker upgrade self [repository url] iobroker upgrade <adapter> [repository url] iobroker upload <pathToLocalFile> <pathIniobroker> iobroker upload all iobroker upload <adapter> iobroker object get <id> iobroker object set <id> <json-value> iobroker object set <id> propertyname=value iobroker object del <id|pattern> [--yes] iobroker object chmod <object-mode> [state-mode] <id> iobroker object chown <user> <group> <id> iobroker object list <id> iobroker state get <id> iobroker state getplain <id> [--pretty] iobroker state getvalue <id> iobroker state set <id> <value> [ack] iobroker state del <id> iobroker message <adapter>[.instanceid] <command> [<message>] iobroker list <type> [filter] iobroker chmod <mode> <file> iobroker chown <user> <group> <file> iobroker touch <file> iobroker rm <file> iobroker file read <iobroker-path-to-read> [<filesystem-path-to-write>] iobroker file write <filesystem-path-to-read> <iobroker-path-to-write> iobroker file rm <iobroker-path-to-delete> iobroker file sync iobroker user add <user> [--ingroup group] [--password pass] iobroker user del <user> iobroker user passwd <user> [--password pass] iobroker user enable <user> iobroker user disable <user> iobroker user get <user> iobroker user check <user> [--password pass] iobroker group add <group> iobroker group del <group> iobroker group list <group> iobroker group enable <group> iobroker group disable <group> iobroker group get <group> iobroker group adduser <group> <user> iobroker group deluser <group> <user> iobroker host this iobroker host <hostname> iobroker host set <hostname> iobroker host remove <hostname> iobroker set <adapter>.<instance> [--port port] [--ip address] [--ssl true|false] iobroker license <license.file or license.text> iobroker cert create iobroker cert view [<certificate name>] iobroker clean iobroker backup iobroker restore <backup name or path> iobroker validate <backup name or path> iobroker <command> --timeout 5000 iobroker status [all] iobroker repo [name] iobroker repo add <name> <path or url> iobroker repo set <name> iobroker repo del <name> iobroker uuid iobroker unsetup iobroker fix iobroker multihost <enable|disable> [--secure true|false] iobroker multihost browse iobroker multihost connect iobroker compact status iobroker compact <enable|on|disable|off> iobroker compact <adapter>.<instance> status iobroker compact <adapter>.<instance> group <group-id> iobroker compact <adapter>.<instance> <disable|off> iobroker compact <adapter>.<instance> <enable|on> [group-id] iobroker version [adapter] iobroker [adapter] -v Optionen: --help Hilfe anzeigen [boolean] --version Version anzeigen [boolean] pi@raspberry:~ $ > -bash: Syntaxfehler beim unerwarteten Wort `newline' pi@raspberry:~ $ > Active repo: default -bash: repo:: Kommando nicht gefunden. pi@raspberry:~ $ > -bash: Copy: Kommando nicht gefunden. -bash: Copy:: Kommando nicht gefunden. pi@raspberry:~ $ > -bash: Syntaxfehler beim unerwarteten Wort `newline' pi@raspberry:~ $ > Objects: 9208 -bash: 9208: Kommando nicht gefunden. pi@raspberry:~ $ > States: 8292 -bash: 8292: Kommando nicht gefunden. pi@raspberry:~ $ > -bash: Syntaxfehler beim unerwarteten Wort `newline' pi@raspberry:~ $ > Size of iob-Database: -bash: of: Kommando nicht gefunden. pi@raspberry:~ $ > -bash: Syntaxfehler beim unerwarteten Wort `newline' pi@raspberry:~ $ > 8.1M /opt/iobroker/iobroker-data/objects.json.bak /opt/iobroker/iobroker-data/objects.json.bak: Zeile 2: zwave-js: Kommando nicht gefunden. /opt/iobroker/iobroker-data/objects.json.bak: Zeile 2: 10.0.0: Kommando nicht gefunden. /opt/iobroker/iobroker-data/objects.json.bak: Zeile 2: Supervision: Kommando nicht gefunden. /opt/iobroker/iobroker-data/objects.json.bak: Zeile 2: zwave-js: Kommando nicht gefunden. /opt/iobroker/iobroker-data/objects.json.bak: Zeile 2: 10.0.0: Kommando nicht gefunden. /opt/iobroker/iobroker-data/objects.json.bak: Zeile 2: Supervision: Kommando nicht gefunden. /opt/iobroker/iobroker-data/objects.json.bak: Zeile 2: zwave-js: Kommando nicht gefunden. /opt/iobroker/iobroker-data/objects.json.bak: Zeile 2: 10.0.0: Kommando nicht gefunden. /opt/iobroker/iobroker-data/objects.json.bak: Zeile 2: zwave-js: Kommando nicht gefunden. /opt/iobroker/iobroker-data/objects.json.bak: Zeile 2: 10.0.0: Kommando nicht gefunden. /opt/iobroker/iobroker-data/objects.json.bak: Zeile 2: Relatórios: Kommando nicht gefunden. /opt/iobroker/iobroker-data/objects.json.bak: Zeile 2: zwave-js: Kommando nicht gefunden. /opt/iobroker/iobroker-data/objects.json.bak: Zeile 2: 10.0.0: Kommando nicht gefunden. /opt/iobroker/iobroker-data/objects.json.bak: Zeile 2: Supervisie: Kommando nicht gefunden. /opt/iobroker/iobroker-data/objects.json.bak: Zeile 2: zwave-js: Kommando nicht gefunden. /opt/iobroker/iobroker-data/objects.json.bak: Zeile 2: 10.0.0: Kommando nicht gefunden. /opt/iobroker/iobroker-data/objects.json.bak: Zeile 2: zwave-js: Kommando nicht gefunden. /opt/iobroker/iobroker-data/objects.json.bak: Zeile 2: 10.0.0: Kommando nicht gefunden. /opt/iobroker/iobroker-data/objects.json.bak: Zeile 2: zwave-js: Kommando nicht gefunden. /opt/iobroker/iobroker-data/objects.json.bak: Zeile 2: 10.0.0: Kommando nicht gefunden. /opt/iobroker/iobroker-data/objects.json.bak: Zeile 2: zwave-js: Kommando nicht gefunden. /opt/iobroker/iobroker-data/objects.json.bak: Zeile 2: 10.0.0: Kommando nicht gefunden. /opt/iobroker/iobroker-data/objects.json.bak: Zeile 2: Raportów: Kommando nicht gefunden. /opt/iobroker/iobroker-data/objects.json.bak: Zeile 2: zwave-js: Kommando nicht gefunden. /opt/iobroker/iobroker-data/objects.json.bak: Zeile 2: 9.2.2: Kommando nicht gefunden. /opt/iobroker/iobroker-data/objects.json.bak: Zeile 2: doorStatus/latchStatus/boltStatus: Datei oder Verzeichnis nicht gefunden /opt/iobroker/iobroker-data/objects.json.bak: Zeile 2: zwave-js: Kommando nicht gefunden. /opt/iobroker/iobroker-data/objects.json.bak: Zeile 2: 9.2.2: Kommando nicht gefunden. /opt/iobroker/iobroker-data/objects.json.bak: Zeile 2: doorStatus/latchStatus/boltStatus: Datei oder Verzeichnis nicht gefunden /opt/iobroker/iobroker-data/objects.json.bak: Zeile 2: zwave-js: Kommando nicht gefunden. /opt/iobroker/iobroker-data/objects.json.bak: Zeile 2: 9.2.2: Kommando nicht gefunden. /opt/iobroker/iobroker-data/objects.json.bak: Zeile 2: doorStatus/latchStatus/boltStatus: Datei oder Verzeichnis nicht gefunden /opt/iobroker/iobroker-data/objects.json.bak: Zeile 2: zwave-js: Kommando nicht gefunden. /opt/iobroker/iobroker-data/objects.json.bak: Zeile 2: 9.2.2: Kommando nicht gefunden. /opt/iobroker/iobroker-data/objects.json.bak: Zeile 2: doorStatus/latchStatus/boltStatus: Datei oder Verzeichnis nicht gefunden /opt/iobroker/iobroker-data/objects.json.bak: Zeile 2: zwave-js: Kommando nicht gefunden. /opt/iobroker/iobroker-data/objects.json.bak: Zeile 2: 9.2.2: Kommando nicht gefunden. /opt/iobroker/iobroker-data/objects.json.bak: Zeile 2: Falsche Ersetzung: Keine schlie▒ende "`" in `doorStatus/latchStatus/boltStatus' worden niet meer gemaakt als ze niet worden ondersteund door het deurslot\n* Probleem opgelost waarbij sommige controllers uit de 500-serie ten onrechte werden gedetecteerd als geen ondersteuning voor Smart Start\n* Probleem opgelost waarbij sommige inkomende rapporten niet werden verwerkt terwijl een API-opdracht aan de gang was\n* Probleem opgelost waarbij het veranderen van de kleur van sommige apparaten een willekeurige duur zou gebruiken\n* Waardewijzigingen worden nu ook geverifieerd wanneer het apparaat een tussentijds rapport verzendt\n* Probeer de eerste verbinding opnieuw met sticks die worden gehost via TCP\n* Wanneer de Z-Wave-stick wordt losgekoppeld terwijl de adapter actief is, probeert de adapter automatisch opnieuw verbinding te maken\n* Verbeteringen aan genezing en Smart Start\n* Nieuwe en bijgewerkte configuratiebestanden, zie [Z-Wave JS releases](https://github.com/zwave-js/node-zwave-js/releases) voor details". pi@raspberry:~ $ > 8.1M /opt/iobroker/iobroker-data/objects.json /opt/iobroker/iobroker-data/objects.json: Zeile 1: zwave-js: Kommando nicht gefunden. /opt/iobroker/iobroker-data/objects.json: Zeile 1: 10.0.0: Kommando nicht gefunden. /opt/iobroker/iobroker-data/objects.json: Zeile 1: Supervision: Kommando nicht gefunden. /opt/iobroker/iobroker-data/objects.json: Zeile 1: zwave-js: Kommando nicht gefunden. /opt/iobroker/iobroker-data/objects.json: Zeile 1: 10.0.0: Kommando nicht gefunden. /opt/iobroker/iobroker-data/objects.json: Zeile 1: Supervision: Kommando nicht gefunden. /opt/iobroker/iobroker-data/objects.json: Zeile 1: zwave-js: Kommando nicht gefunden. /opt/iobroker/iobroker-data/objects.json: Zeile 1: 10.0.0: Kommando nicht gefunden. /opt/iobroker/iobroker-data/objects.json: Zeile 1: zwave-js: Kommando nicht gefunden. /opt/iobroker/iobroker-data/objects.json: Zeile 1: 10.0.0: Kommando nicht gefunden. /opt/iobroker/iobroker-data/objects.json: Zeile 1: Relatórios: Kommando nicht gefunden. /opt/iobroker/iobroker-data/objects.json: Zeile 1: zwave-js: Kommando nicht gefunden. /opt/iobroker/iobroker-data/objects.json: Zeile 1: 10.0.0: Kommando nicht gefunden. /opt/iobroker/iobroker-data/objects.json: Zeile 1: Supervisie: Kommando nicht gefunden. /opt/iobroker/iobroker-data/objects.json: Zeile 1: zwave-js: Kommando nicht gefunden. /opt/iobroker/iobroker-data/objects.json: Zeile 1: 10.0.0: Kommando nicht gefunden. /opt/iobroker/iobroker-data/objects.json: Zeile 1: zwave-js: Kommando nicht gefunden. /opt/iobroker/iobroker-data/objects.json: Zeile 1: 10.0.0: Kommando nicht gefunden. /opt/iobroker/iobroker-data/objects.json: Zeile 1: zwave-js: Kommando nicht gefunden. /opt/iobroker/iobroker-data/objects.json: Zeile 1: 10.0.0: Kommando nicht gefunden. /opt/iobroker/iobroker-data/objects.json: Zeile 1: zwave-js: Kommando nicht gefunden. /opt/iobroker/iobroker-data/objects.json: Zeile 1: 10.0.0: Kommando nicht gefunden. /opt/iobroker/iobroker-data/objects.json: Zeile 1: Raportów: Kommando nicht gefunden. /opt/iobroker/iobroker-data/objects.json: Zeile 1: zwave-js: Kommando nicht gefunden. /opt/iobroker/iobroker-data/objects.json: Zeile 1: 9.2.2: Kommando nicht gefunden. /opt/iobroker/iobroker-data/objects.json: Zeile 1: doorStatus/latchStatus/boltStatus: Datei oder Verzeichnis nicht gefunden /opt/iobroker/iobroker-data/objects.json: Zeile 1: zwave-js: Kommando nicht gefunden. /opt/iobroker/iobroker-data/objects.json: Zeile 1: 9.2.2: Kommando nicht gefunden. /opt/iobroker/iobroker-data/objects.json: Zeile 1: doorStatus/latchStatus/boltStatus: Datei oder Verzeichnis nicht gefunden /opt/iobroker/iobroker-data/objects.json: Zeile 1: zwave-js: Kommando nicht gefunden. /opt/iobroker/iobroker-data/objects.json: Zeile 1: 9.2.2: Kommando nicht gefunden. /opt/iobroker/iobroker-data/objects.json: Zeile 1: doorStatus/latchStatus/boltStatus: Datei oder Verzeichnis nicht gefunden /opt/iobroker/iobroker-data/objects.json: Zeile 1: zwave-js: Kommando nicht gefunden. /opt/iobroker/iobroker-data/objects.json: Zeile 1: 9.2.2: Kommando nicht gefunden. /opt/iobroker/iobroker-data/objects.json: Zeile 1: doorStatus/latchStatus/boltStatus: Datei oder Verzeichnis nicht gefunden /opt/iobroker/iobroker-data/objects.json: Zeile 1: zwave-js: Kommando nicht gefunden. /opt/iobroker/iobroker-data/objects.json: Zeile 1: 9.2.2: Kommando nicht gefunden. /opt/iobroker/iobroker-data/objects.json: Zeile 1: Falsche Ersetzung: Keine schlie▒ende "`" in `doorStatus/latchStatus/boltStatus' worden niet meer gemaakt als ze niet worden ondersteund door het deurslot\n* Probleem opgelost waarbij sommige controllers uit de 500-serie ten onrechte werden gedetecteerd als geen ondersteuning voor Smart Start\n* Probleem opgelost waarbij sommige inkomende rapporten niet werden verwerkt terwijl een API-opdracht aan de gang was\n* Probleem opgelost waarbij het veranderen van de kleur van sommige apparaten een willekeurige duur zou gebruiken\n* Waardewijzigingen worden nu ook geverifieerd wanneer het apparaat een tussentijds rapport verzendt\n* Probeer de eerste verbinding opnieuw met sticks die worden gehost via TCP\n* Wanneer de Z-Wave-stick wordt losgekoppeld terwijl de adapter actief is, probeert de adapter automatisch opnieuw verbinding te maken\n* Verbeteringen aan genezing en Smart Start\n* Nieuwe en bijgewerkte configuratiebestanden, zie [Z-Wave JS releases](https://github.com/zwave-js/node-zwave-js/releases) voor details". pi@raspberry:~ $ > pi@raspberry:~ $ -bash: $: Kommando nicht gefunden. pi@raspberry:~ $ > pi@raspberry:~ $ ``` > -bash: =======================: Kommando nicht gefunden. > -bash: v.2022-12-13: Kommando nicht gefunden. > -bash: command substitution: Zeile 6: Syntaxfehler beim unerwarteten Wort `(' -bash: Syntaxfehler beim unerwarteten Wort `(' pi@raspberry:~ $ -bash: command substitution: Zeile 6: `Operatingsystem: Raspbian GNU/Linux 10 (buster)' >
@bobbypin du bist aber z.b. mit dem js-controller und admin Meilenweit hinterher und das macht kein Fixer rückgängig mit deiner Aussage
@bobbypin sagte in Probleme nach Update:
Hatte vor dem Fix eigentlich alles aktuell.
und mit einem controller installed 2.2.9, gibt es auch noch keine jsonl
Jetzt bekomme ich meine Backups auch nicht über den Backupit adapter wieder hergestellt da ich diesen jetzt nicht mehr habe und er sich auch nicht installieren lässt. (Fehlercode 25)
@homoran sagte in Probleme nach Update:
nee, lass das.
Lass da erst jemanden draufsehen, der davon Ahnung hat.
Sonst besteht die Gefahr dass noch mehr verbogen wird.vllt doch zwischenzeitlich etwas verfummelt?
@crunchip
wie gesagt bisher nur iobroker fix ausgeführt sonst nichts.
Und den Anweisungen aus diesem Thread gefolgt. -
aha....
iobdiag
auch ausgeführt?
Davon die Ausgabe bitte. -
@djmarc75
5 Posts höher
Kann leider dan ganzen Code nicht einfügen bekomme dann eine Verboten Meldung des Forums -
sonst nichts.
Und den Anweisungen aus diesem Thread gefolgt.zwickt sich bisserl mit der Aussage
@djmarc75 sagte in Probleme nach Update:
auch ausgeführt?
klappt möglicherweise mit veraltetem System nicht
Da fehlt so einiges. Auch eine gescheite Installation von nodejs.
@crunchip said in Probleme nach Update:
sonst nichts.
vor dem iobroker fix
nach dem Fix war kein Backupadapter mehr da
auch ausgeführt?
iobdiag lässt sich ausführen.
Ich kann aber den code hier nicht posten da dann eine Verbotenmeldung des Forums kommt. -
üblicherweise öfters das Problem bei FF, einfach Browser neu laden(F5), dann müsste es gehen
@crunchip
SO habe das ganze System jetzt neu aufgesetzt und dann mein Backup geladen.
Danach alle Adapter nochmal aktualisiert.
Jetzt habe ich nur noch das Problem mit dem Dekonz Adapter.
Kennt jemand hier den Fehler und weiß wie ich den bebeheben kann?
@crunchip
Kann über realvnc auch nicht mehr auf den Konsolendesktop.
Obwohl ich die volle Version installiert habe -
Obwohl ich die volle Version installiert habeIst ja auch eh Bullshit. Per SSH auf ein System komplett OHNE Desktop gehen.
zwar nicht die schlechteste Idee, hate aber niemand geschrieben, sondern warteten auf die Ausgabe, die gefragt wurde.
passiert das nicht normalerweise automatisch
kann ich nix zu sagen, hat sich die IP geändert?
wurde ja schon beantwortet
Hatte schon alles gepostet was möglich war
Nach dem Rückspielen meines Backups setzen sich auch die Adapter zurück
IP ist die gleiche
@thomas-braun said in Probleme nach Update:
Brauche doch bei Deconz den screen damit man zum erstellen des API Schlüssels in der Phoscon App den Schlüssel bestätigt, sonst wird keiner generiert.
Oder liege ich da falsch? -
Man kann deconz natürlich auch 'headless' betreiben.
Ich würde aber eh den zigbee-Adapter verwenden. -
Am Anfang kannte ich den Unterschied nicht. Und danach war ich zu faul alles neu zu machen. -
Wie geht das und was muss ich dafür machen?Ich würde aber eh den zigbee-Adapter verwenden.
