  4. Test Adapter mihome-vacuum 3.8.x
    apollon77A
129 Beiträge 19 Kommentatoren 29.7k Aufrufe 20 Beobachtet
  • VumerV Vumer
    Heute Nacht
    mihome-vacuum.0 2022-11-09 05:16:50.322	error	sendMessage throws error ==>MIIO MESSAGE CANT PARSE ANSWER: error:06065064:digital envelope routines:EVP_DecryptFinal_ex:bad decrypt
    mihome-vacuum.0 2022-11-09 04:23:46.883	error	sendMessage throws error ==>MIIO MESSAGE CANT PARSE ANSWER: {"id":5047,"result":[{"msg_ver":2,"msg_seq":1535,"state":8,"battery":100,"clean_time":471,"clean_area":8785000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"fan_power":103,"dnd_enabled":1,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":207,"distance_off":60,"water_box_carriage_status":0,"mop_forbidden_enable":0,"adbumper_status":[0,0,0],"dock_type":0,"dust_collection_stat�Wiw�~ �j��r�k%���7TŕN��r��K���tA*��n9SWG f�t*U��J������vZ��p$;��j ڗ� ���k�^status":1}],"exe_time":11}
    mihome-vacuum.0 2022-11-09 04:23:46.880	error	sendMessage throws error ==>MIIO MESSAGE CANT PARSE ANSWER: {"id":5047,"result":[{"msg_ver":2,"msg_seq":1535,"state":8,"battery":100,"clean_time":471,"clean_area":8785000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"fan_power":103,"dnd_enabled":1,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":207,"distance_off":60,"water_box_carriage_status":0,"mop_forbidden_enable":0,"adbumper_status":[0,0,0],"dock_type":0,"dust_collection_stat�Wiw�~ �j��r�k%���7TŕN��r��K���tA*��n9SWG f�t*U��J������vZ��p$;��j ڗ� ���k�^status":1}],"exe_time":11}
    mihome-vacuum.0 2022-11-09 04:06:12.036	error	sendMessage throws error ==>MIIO MESSAGE CANT PARSE ANSWER: �j�>S&� �d��lt":["roboroommap%2F535262734%2F0"],"exe_time":10}
    mihome-vacuum.0 2022-11-09 04:06:12.033	error	sendMessage throws error ==>MIIO MESSAGE CANT PARSE ANSWER: �j�>S&� �d��lt":["roboroommap%2F535262734%2F0"],"exe_time":10}
    mihome-vacuum.0 2022-11-09 03:02:57.222	error	sendMessage throws error ==>MIIO MESSAGE CANT PARSE ANSWER: @50 r6�e���kVU��V7�Z�c]�l����(����������͍Y,��h���������\��L��Y�A �%�{�h⹟N��3_H0��U�xx:xx:xx:xx:xx:xx","rssi":-36},"exe_time":31}
    mihome-vacuum.0 2022-11-09 03:02:57.220	error	sendMessage throws error ==>MIIO MESSAGE CANT PARSE ANSWER: @50 r6�e���kVU��V7�Z�c]�l����(����������͍Y,��h���������\��L��Y�A �%�{�h⹟N��3_H0��U�xx:xx:xx:xx:xx:xx","rssi":-36},"exe_time":31}
    und während der Reinigung
    mihome-vacuum.0 2022-11-09 11:32:16.306	error	sendMessage throws error ==>MIIO MESSAGE CANT PARSE ANSWER: error:06065064:digital envelope routines:EVP_DecryptFinal_ex:bad decrypt
    mihome-vacuum.0 2022-11-09 11:32:16.303	error	sendMessage throws error ==>MIIO MESSAGE CANT PARSE ANSWER: error:06065064:digital envelope routines:EVP_DecryptFinal_ex:bad decrypt
    mihome-vacuum.0 2022-11-09 11:15:55.415	error	sendMessage throws error ==>MIIO MESSAGE CANT PARSE ANSWER: error:06065064:digital envelope routines:EVP_DecryptFinal_ex:bad decrypt
    mihome-vacuum.0 2022-11-09 11:15:55.412	error	sendMessage throws error ==>MIIO MESSAGE CANT PARSE ANSWER: error:06065064:digital envelope routines:EVP_DecryptFinal_ex:bad decrypt
    D
    D
    dirkhe
    #87
    @vumer ja da sind parserfehler, könnre man ggf. Auch nur ins debug schreiben, weil er macht ja weiter.... oder zumindest ins info
    @da_Woody mach mal debug an, die fehlermeldungen kommen da genauso häufig
    • VumerV
      VumerV
      Vumer
      #88
      @dirkhe sagte in Test für mihome-vacuum:
      Ich hab auf rot Allergie und gelb macht mich nervös ;)
      • C
        C
        ChrisXY
        #89
        puhhh ich verzweifel an der Pause / Resume Ich will es per GUI steuern lassen.
        Leider gibt es keine art toogle ..
        Es gibt nur Pause für Pause.. dann muss man wissen was man gemacht hat.
        Raumreinigung eines Raums läuft ..
        Dann will ich PAUSE absenden. Schalter bleibt auf True ..
        Was nun ? Für Raumreinigung weitermachen gibt es nur resumeroom
        Start= Alles wird Gereinigt ..
        Es gibt keinen toogle? Leider wird auch Pause nicht wieder auf false gesetzt. Somit ist der state von dem schalter auch immer falsch ..
        Müsste das jetzt per Blockly wohl lösen. Oder gibt es da eine bessere Möglichkeit.
        Will blos ein Schalter egal was er macht Pause/Weiter
        • C ChrisXY
          D
          D
          dirkhe
          #90
          @chrisxy conttol.pauseResume sollte das machen, der status eird sogar verändert, wenn du ssuger per hand losfährst, ist also der toggle
          C 1 Antwort Letzte Antwort
          • D dirkhe
            C
            C
            ChrisXY
            #91
            @dirkhe klappt nicht. Wenn ich ihn zu einem Raum schicke zum Reinigen. Kann ich nur mit "pause" stoppen und per "resumroom.." starten. Das pauseResume hat nie einen effekt :(
            • C ChrisXY
              D
              D
              dirkhe
              #92
              @chrisxy reden wir vom gleichen adapter? Resumeroom gibt es gar nicht.
              zeige mal ein debuglog, da kannst du dann mal psuseresum drücken, wichtig ack auf false
              • DiginixD
                DiginixD
                Diginix
                #93
                @dirkhe 3.8.5 hat heute beim Saugen von 7 Räumen mit zT 3 im queue immer den korrekten room.state angezeigt und auch die CPU Last sieht über 12 Stunden wie mit 3.6.0 aus. Denke du hast die richtige Stelle gefixt.
                Perfekt wäre es nun noch wenn man in den Instanzenstellungen die Farbwerte aus der mapcreator.js selbst einstellen könnte:
                alt bis 3.6.0
                neu seit 3.8.x (aber auf dunklem Hintergrund bei Saugern ohne Teppicherkennung nachteilig)
                ..:: So long! Tom ::..
                • DiginixD Diginix
                  alt bis 3.6.0
                  D
                  D
                  dirkhe
                  #94
                  @diginix ich würde da jetzt quasi eine farbthemen liste (mit 2 einträgen) machen wollen. Jetzt bist du gefragt, hast du einevidee, wie man jeweils die farbthemes benennen könnte? So könnte man demnächst noch weitere themes hinzufügen
                  da_WoodyD DiginixD 2 Antworten Letzte Antwort
                  • D dirkhe
                    da_WoodyD
                    da_WoodyD
                    #95
                    @dirkhe irgendwie versteh ich das nicht. da gibts im adapter ja
                    hat aber 0 auswirkung. angezeigt wird ja
                    wo bin ich da falsch abgebogen? 😵
                    • D dirkhe
                      DiginixD
                      DiginixD
                      Diginix
                      #96
                      @dirkhe Mir fällt nur "Light" und "Dark" ein für die zwei bisherigen Farbsets.
                      Farben bis v3.6.0 "Light"
                      Farben seit v3.8.0 "Dark"
                      Aber es ginge natürlich noch heller bzw. dunkler.
                      @da_woody Wenn du nur die eine feste Farbe für Boden und Wand haben willst, musst du den Haken bei "Use new Map format with room colors" entfernen. Dann haben aber eben auch alle Räume dieselbe Farbe.
                      • DiginixD Diginix
                        da_WoodyD
                        da_WoodyD
                        #97
                        @diginix warum das ding aus einem raum 2 gemacht hat, ist schon länger suspekt.
                        haken raus, gewartet bis das ding wieder grün ist, kein starten über iQontrol mehr möglich. jetzt komm ich nichtmal mehr auf die 3.6 zurück, da hatte ich die wenigsten probs... war ja eh immer ein bißchen problematisch. der s6pure stand ja nie wirklich in der liste.
                        langsam hoff ich echt auf den roborock adapter...
                        • da_WoodyD da_Woody
                          D
                          D
                          dirkhe
                          #98
                          @da_woody kann es sein, dass der eine teil teppich ist? Das ist wohl neu reingekommen.
                          Wenn er dich nicht starten läßt, debug, dann kann ich mal schauen
                          da_WoodyD 2 Antworten Letzte Antwort
                            DiginixD
                            DiginixD
                            Diginix
                            #99
                            @da_woody Die automatische Raumerkennung von Xiaomi ist nicht perfekt. Ich musste bei mir auch alle Räume manuell definieren. In der MiHome App kann man Räume zusammenfügen und teilen so dass es der realen Architektur entspricht.
                            • D dirkhe
                              da_WoodyD
                              da_WoodyD
                              #100
                              @dirkhe nein, da ist definitiv kein teppich. nachdem ich den haken wieder reingetan hab, konnte ich heute wieder starten.
                              vllt brauch das ding einfach nur ewig lange bis er wieder reagiert?
                              hab den haken wieder raus und versuchs am abend nochmal.
                              ich werd berichten... :)
                              @Diginix thnx, schau ich mir an.
                              • D dirkhe
                                da_WoodyD
                                da_WoodyD
                                #101
                                war wohl falscher alarm. muss wo anders geklemmt haben. die manuelle heizungssteuerung wollte gestern auch nicht. gerade getestet, jetzt klapperts...
                                • DiginixD Diginix
                                  da_WoodyD
                                  da_WoodyD
                                  #102
                                  @diginix perfekt! jetzt klapps auch mit der nachbarin... ;)
                                    D
                                    D
                                    dirkhe
                                    #103
                                    @da_woody alles gut, iobroker ist halt ein komplexes system.
                                    Aber das mit der wartezeit ist manchmal so, besonders, wenn der adapter innerhalb kürzester zeit öfter gestartet wird, ist beim Entwickeln auch immer blöd...
                                    • D dirkhe
                                      D
                                      D
                                      dirkhe
                                      #104
                                      ich denke, ich werde die 3.8.5 jetzt mal in stable schieben und dann mit der 3.9 weiter machen, da schaue ich mich mur das mit den farben an, dann wollte ich noch den repeat dp pro raum einbauen und vkt bekomnen wir das mit dem gezielt zum reijigen in die station fahren https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/issues/679 mit rein
                                      • PeoplesP
                                        PeoplesP
                                        Peoples
                                        schrieb am zuletzt editiert von Peoples
                                        #105
                                        ich habe schon seit längerer Zeit Fehler im Log wenn ich meinen Sauger starte, dazu habe ich auch schon einiges gelesen, aber bisher nicht die Lösung des Problems gefunden. Wenn das dennoch schon irgendwo geklärt wurde, postet mir bitte den Link.
                                        Hier mein Log-Auszug:
                                        2022-12-15 11:44:27.363 - info: mihome-vacuum.0 (13374) trigger cleaning all
                                        2022-12-15 11:44:35.420 - error: host.IoBroker Caught by controller[0]: FATAL ERROR: v8::ToLocalChecked Empty MaybeLocal.
                                        2022-12-15 11:44:35.420 - error: host.IoBroker Caught by controller[1]: 1: 0xb06730 node::Abort() [io.mihome-vacuum.0]
                                        2022-12-15 11:44:35.420 - error: host.IoBroker Caught by controller[2]: 2: 0xa1b5d0 node::FatalError(char const*, char const*) [io.mihome-vacuum.0]
                                        2022-12-15 11:44:35.420 - error: host.IoBroker Caught by controller[3]: 3: 0xce1bca v8::Utils::ReportApiFailure(char const*, char const*) [io.mihome-vacuum.0]
                                        2022-12-15 11:44:35.420 - error: host.IoBroker Caught by controller[3]: 4: 0x7fe2b35e1fee Context2d::GetImageData(Nan::FunctionCallbackInfo const&) [/opt/iobroker/node_modules/canvas/build/Release/canvas.node]
                                        2022-12-15 11:44:35.420 - error: host.IoBroker Caught by controller[3]: 5: 0x7fe2b35d2e58 [/opt/iobroker/node_modules/canvas/build/Release/canvas.node]
                                        2022-12-15 11:44:35.420 - error: host.IoBroker Caught by controller[4]: 6: 0xd3e3ce [io.mihome-vacuum.0]
                                        2022-12-15 11:44:35.420 - error: host.IoBroker Caught by controller[5]: 7: 0xd3f7ef v8::internal::Builtin_HandleApiCall(int, unsigned long*, v8::internal::Isolate*) [io.mihome-vacuum.0]
                                        2022-12-15 11:44:35.421 - error: host.IoBroker Caught by controller[6]: 8: 0x15da239 [io.mihome-vacuum.0]
                                        2022-12-15 11:44:35.421 - warn: host.IoBroker instance system.adapter.mihome-vacuum.0 terminated due to SIGABRT
                                        2022-12-15 11:44:35.421 - info: host.IoBroker instance system.adapter.mihome-vacuum.0 terminated with code NaN ()
                                        2022-12-15 11:44:35.421 - info: host.IoBroker Restart adapter system.adapter.mihome-vacuum.0 because enabled
                                        2022-12-15 11:45:05.518 - info: host.IoBroker instance system.adapter.mihome-vacuum.0 started with pid 20010
                                        2022-12-15 11:45:06.615 - info: mihome-vacuum.0 (20010) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                                        2022-12-15 11:45:07.110 - info: mihome-vacuum.0 (20010) starting. Version 3.8.6 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v16.18.1, js-controller: 4.0.23
                                        2022-12-15 11:45:07.177 - info: mihome-vacuum.0 (20010) IOT enabled, create state
                                        2022-12-15 11:45:07.298 - info: mihome-vacuum.0 (20010) select standard vacuum protocol....
                                        2022-12-15 11:45:07.838 - info: mihome-vacuum.0 (20010) settest next timer: not available
                                        2022-12-15 11:45:09.208 - info: mihome-vacuum.0 (20010) create state for carpet_mode
                                        • D dirkhe
                                          Aktuelle Test Version 3.8.5
                                          Veröffentlichungsdatum 30.10.2022
                                          Github Link https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum
                                          Hier Adapter Beschreibung, Changelog etc.
                                          Ich habe in letzter Zeit einige Anpassungen in dem Adapter gemacht, das meiste war für die neuen S7 Modelle.
                                          Da Meistertr, der die die Hauptarbeit an dem Adapter nicht mehr weiter macht, werde ich weiter ein Auge auf den Adapter haben. Das bezieht sich aber in der Hauptsache auf Bugfixes und ggf Kleinigkeiten, wie zum Beispiel von neueren Geräten eine neue Funktionalität einzubauen. Dazu brauche ich dann aber konkrete Hilfe, also wie der interne Befehl heißt oder welche Werte da auch angenommen werden können. Oft kann ich das dann einbauen, wenn die Kollegen zb. bei
                                          https://github.com/marcelrv/XiaomiRobotVacuumProtocol oder https://github.com/rytilahti/python-miio das schon implementiert haben.
                                          Karten
                                          Ich selber nutzte die Karten nicht, daher hatte ich mich in der Vergangenheit da auch nicht groß drum gekümmert. Da wäre es gut, wenn sich jemand finden würde, der die nutzt und sich darin einarbeiten möchte. Meistertr hat zum Abschied noch ein paar neue Features, wie Teppicherkennung und automatisches Zoom eingebaut.
                                          Dream Modelle
                                          Es gibt immer wieder zig Anfragen, die Dream Modelle mit aufzunehmen, aber die Ticken halt alle ein bisschen anders. Wer sich dazu berufen fühlt, diese alle zu implementieren, ist herzlich eingeladen, das zu tun. Ich kann da gerne unterstützen, wenn es um das Verstehen des code geht, denn der ist über die Jahre mit den vielen Modellen leider nicht immer ganz so übersichtlich. Ich habe auch eine Zeit gebraucht, mich da einzuarbeiten.
                                          So, jetzt geht es aber erst mal darum, die aktuelle Version 3.8.0 rund zu bekommen, dass wir die mal in stable bekommen.
                                          Update:
                                          So dass Logging wurde weiter angepasst, so dass das meiste jetzt im debug level landen sollte.
                                          Dann habe ich noch ein Problem festgestellt, was mit der neuen Version reingekommen ist, dass es bei einem internen reconnect dazu kam, dass er eine neue Instanz geladen hat, was dann zu Effekten führte, dass er manche Sachen mehrfach getriggert hat. Bei mir hat er die Queue vollgemacht und der robbi ist zig mal gelaufen, oder das reinigen wurde gestartet aber nicht in den Status geschrieben oder auch erhöhte CPU Last. Das ist in der 3.8.5 gelöst sein
                                          Ist mit der 3.8.8 jetzt produktiv
                                          B
                                          B
                                          bob der 1.
                                          #106
                                          Dream Modelle
                                          Darauf hin, ist es durch dieses hier nicht einfacher geworden die Dreames einzubauen?Sorry wenn ich frage, beim Adapterbau kann ich nur den Namen lesen und nicht wissen wie schwer das ganze ist.Aber es scheint ja dort zu gehen...einfach umbasten geht wohl nicht :-)
                                          84.0k
