  4. Test Adapter mihome-vacuum 3.8.x
    6.6k
129 Beiträge 19 Kommentatoren 25.6k Aufrufe 20 Beobachtet
  • D3ltoroxpD D3ltoroxp
    @djmarc75 Sorry werde daraus nicht schlau, hatte das ja schon gelesen. Was willst du mir damit sagen ?
    dirkhe
    #83
    Ich habe mal die 3.8.4 veröffentlicht, da sollte das Log ruhiger sein....
    ? da_WoodyD 2 Antworten Letzte Antwort
    • D dirkhe
      #84
      @dirkhe sagte in Test für mihome-vacuum:
      Hallo, ja vielen Dank, ist es. Bis jetzt keine Fehler / Warnings im Log, meine vier S5 fahren nachher mal ne Runde, die Grundfunktionen hab ich getestet, gehen..
      • D dirkhe
        da_WoodyD Offline
        da_WoodyD Offline
        #85
        • VumerV Offline
          VumerV Offline
          Vumer
          #86
          Heute Nacht
          mihome-vacuum.0 2022-11-09 05:16:50.322	error	sendMessage throws error ==>MIIO MESSAGE CANT PARSE ANSWER: error:06065064:digital envelope routines:EVP_DecryptFinal_ex:bad decrypt
          mihome-vacuum.0 2022-11-09 04:23:46.883	error	sendMessage throws error ==>MIIO MESSAGE CANT PARSE ANSWER: {"id":5047,"result":[{"msg_ver":2,"msg_seq":1535,"state":8,"battery":100,"clean_time":471,"clean_area":8785000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"fan_power":103,"dnd_enabled":1,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":207,"distance_off":60,"water_box_carriage_status":0,"mop_forbidden_enable":0,"adbumper_status":[0,0,0],"dock_type":0,"dust_collection_stat�Wiw�~ �j��r�k%���7TŕN��r��K���tA*��n9SWG f�t*U��J������vZ��p$;��j ڗ� ���k�^status":1}],"exe_time":11}
          mihome-vacuum.0 2022-11-09 04:23:46.880	error	sendMessage throws error ==>MIIO MESSAGE CANT PARSE ANSWER: {"id":5047,"result":[{"msg_ver":2,"msg_seq":1535,"state":8,"battery":100,"clean_time":471,"clean_area":8785000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"fan_power":103,"dnd_enabled":1,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":207,"distance_off":60,"water_box_carriage_status":0,"mop_forbidden_enable":0,"adbumper_status":[0,0,0],"dock_type":0,"dust_collection_stat�Wiw�~ �j��r�k%���7TŕN��r��K���tA*��n9SWG f�t*U��J������vZ��p$;��j ڗ� ���k�^status":1}],"exe_time":11}
          mihome-vacuum.0 2022-11-09 04:06:12.036	error	sendMessage throws error ==>MIIO MESSAGE CANT PARSE ANSWER: �j�>S&� �d��lt":["roboroommap%2F535262734%2F0"],"exe_time":10}
          mihome-vacuum.0 2022-11-09 04:06:12.033	error	sendMessage throws error ==>MIIO MESSAGE CANT PARSE ANSWER: �j�>S&� �d��lt":["roboroommap%2F535262734%2F0"],"exe_time":10}
          mihome-vacuum.0 2022-11-09 03:02:57.222	error	sendMessage throws error ==>MIIO MESSAGE CANT PARSE ANSWER: @50 r6�e���kVU��V7�Z�c]�l����(����������͍Y,��h���������\��L��Y�A �%�{�h⹟N��3_H0��U�xx:xx:xx:xx:xx:xx","rssi":-36},"exe_time":31}
          mihome-vacuum.0 2022-11-09 03:02:57.220	error	sendMessage throws error ==>MIIO MESSAGE CANT PARSE ANSWER: @50 r6�e���kVU��V7�Z�c]�l����(����������͍Y,��h���������\��L��Y�A �%�{�h⹟N��3_H0��U�xx:xx:xx:xx:xx:xx","rssi":-36},"exe_time":31}
          und während der Reinigung
          mihome-vacuum.0 2022-11-09 11:32:16.306	error	sendMessage throws error ==>MIIO MESSAGE CANT PARSE ANSWER: error:06065064:digital envelope routines:EVP_DecryptFinal_ex:bad decrypt
          mihome-vacuum.0 2022-11-09 11:32:16.303	error	sendMessage throws error ==>MIIO MESSAGE CANT PARSE ANSWER: error:06065064:digital envelope routines:EVP_DecryptFinal_ex:bad decrypt
          mihome-vacuum.0 2022-11-09 11:15:55.415	error	sendMessage throws error ==>MIIO MESSAGE CANT PARSE ANSWER: error:06065064:digital envelope routines:EVP_DecryptFinal_ex:bad decrypt
          mihome-vacuum.0 2022-11-09 11:15:55.412	error	sendMessage throws error ==>MIIO MESSAGE CANT PARSE ANSWER: error:06065064:digital envelope routines:EVP_DecryptFinal_ex:bad decrypt
          • VumerV Vumer
            Heute Nacht
            dirkhe
            #87
            @vumer ja da sind parserfehler, könnre man ggf. Auch nur ins debug schreiben, weil er macht ja weiter.... oder zumindest ins info
            @da_Woody mach mal debug an, die fehlermeldungen kommen da genauso häufig
            • VumerV Offline
              VumerV Offline
              Vumer
              #88
              Ich hab auf rot Allergie und gelb macht mich nervös ;)
              • C Offline
                ChrisXY
                #89
                puhhh ich verzweifel an der Pause / Resume Ich will es per GUI steuern lassen.
                Leider gibt es keine art toogle ..
                Es gibt nur Pause für Pause.. dann muss man wissen was man gemacht hat.
                Raumreinigung eines Raums läuft ..
                Dann will ich PAUSE absenden. Schalter bleibt auf True ..
                Was nun ? Für Raumreinigung weitermachen gibt es nur resumeroom
                Start= Alles wird Gereinigt ..
                Es gibt keinen toogle? Leider wird auch Pause nicht wieder auf false gesetzt. Somit ist der state von dem schalter auch immer falsch ..
                Müsste das jetzt per Blockly wohl lösen. Oder gibt es da eine bessere Möglichkeit.
                Will blos ein Schalter egal was er macht Pause/Weiter
                • C ChrisXY
                  dirkhe
                  #90
                  @chrisxy conttol.pauseResume sollte das machen, der status eird sogar verändert, wenn du ssuger per hand losfährst, ist also der toggle
                  C 1 Antwort Letzte Antwort
                  • D dirkhe
                    ChrisXY
                    #91
                    @dirkhe klappt nicht. Wenn ich ihn zu einem Raum schicke zum Reinigen. Kann ich nur mit "pause" stoppen und per "resumroom.." starten. Das pauseResume hat nie einen effekt :(
                    • C ChrisXY
                      dirkhe
                      #92
                      @chrisxy reden wir vom gleichen adapter? Resumeroom gibt es gar nicht.
                      zeige mal ein debuglog, da kannst du dann mal psuseresum drücken, wichtig ack auf false
                      • DiginixD Offline
                        DiginixD Offline
                        Diginix
                        #93
                        @dirkhe 3.8.5 hat heute beim Saugen von 7 Räumen mit zT 3 im queue immer den korrekten room.state angezeigt und auch die CPU Last sieht über 12 Stunden wie mit 3.6.0 aus. Denke du hast die richtige Stelle gefixt.
                        Perfekt wäre es nun noch wenn man in den Instanzenstellungen die Farbwerte aus der mapcreator.js selbst einstellen könnte:
                        alt bis 3.6.0
                        neu seit 3.8.x (aber auf dunklem Hintergrund bei Saugern ohne Teppicherkennung nachteilig)
                        ..:: So long! Tom ::..
                        • DiginixD Diginix
                          alt bis 3.6.0
                          dirkhe
                          #94
                          @diginix ich würde da jetzt quasi eine farbthemen liste (mit 2 einträgen) machen wollen. Jetzt bist du gefragt, hast du einevidee, wie man jeweils die farbthemes benennen könnte? So könnte man demnächst noch weitere themes hinzufügen
                          da_WoodyD DiginixD 2 Antworten Letzte Antwort
                          • D dirkhe
                            da_WoodyD Offline
                            da_WoodyD Offline
                            #95
                            @dirkhe irgendwie versteh ich das nicht. da gibts im adapter ja
                            hat aber 0 auswirkung. angezeigt wird ja
                            wo bin ich da falsch abgebogen? 😵
                            • D dirkhe
                              DiginixD Offline
                              DiginixD Offline
                              Diginix
                              #96
                              @dirkhe Mir fällt nur "Light" und "Dark" ein für die zwei bisherigen Farbsets.
                              Farben bis v3.6.0 "Light"
                              Farben seit v3.8.0 "Dark"
                              Aber es ginge natürlich noch heller bzw. dunkler.
                              @da_woody Wenn du nur die eine feste Farbe für Boden und Wand haben willst, musst du den Haken bei "Use new Map format with room colors" entfernen. Dann haben aber eben auch alle Räume dieselbe Farbe.
                              • DiginixD Diginix
                                da_WoodyD Offline
                                da_WoodyD Offline
                                #97
                                @diginix warum das ding aus einem raum 2 gemacht hat, ist schon länger suspekt.
                                haken raus, gewartet bis das ding wieder grün ist, kein starten über iQontrol mehr möglich. jetzt komm ich nichtmal mehr auf die 3.6 zurück, da hatte ich die wenigsten probs... war ja eh immer ein bißchen problematisch. der s6pure stand ja nie wirklich in der liste.
                                langsam hoff ich echt auf den roborock adapter...
                                • da_WoodyD da_Woody
                                  dirkhe
                                  #98
                                  @da_woody kann es sein, dass der eine teil teppich ist? Das ist wohl neu reingekommen.
                                  Wenn er dich nicht starten läßt, debug, dann kann ich mal schauen
                                    DiginixD Offline
                                    DiginixD Offline
                                    Diginix
                                    #99
                                    @da_woody Die automatische Raumerkennung von Xiaomi ist nicht perfekt. Ich musste bei mir auch alle Räume manuell definieren. In der MiHome App kann man Räume zusammenfügen und teilen so dass es der realen Architektur entspricht.
                                    • D dirkhe
                                      da_WoodyD Offline
                                      da_WoodyD Offline
                                      #100
                                      @dirkhe nein, da ist definitiv kein teppich. nachdem ich den haken wieder reingetan hab, konnte ich heute wieder starten.
                                      vllt brauch das ding einfach nur ewig lange bis er wieder reagiert?
                                      hab den haken wieder raus und versuchs am abend nochmal.
                                      ich werd berichten... :)
                                      @Diginix thnx, schau ich mir an.
                                      • D dirkhe
                                        da_WoodyD Offline
                                        da_WoodyD Offline
                                        #101
                                        war wohl falscher alarm. muss wo anders geklemmt haben. die manuelle heizungssteuerung wollte gestern auch nicht. gerade getestet, jetzt klapperts...
                                        • DiginixD Diginix
                                          da_WoodyD Offline
                                          da_WoodyD Offline
                                          #102
                                          @diginix perfekt! jetzt klapps auch mit der nachbarin... ;)
