  4. Test Adapter mihome-vacuum 3.8.x
    6.6k
129 Beiträge 19 Kommentatoren 25.6k Aufrufe 20 Beobachtet
  • D dirkhe
    @vumer wäre die frage, wie lange er das macht.
    ich vermute, diese woche kann ich nicht mehr viel machen, aber ich überlege mir noch was, wie ich das eindämmen kann. Ich glaube, ich werde so machen, dass ich einmalig eine warnung ins log schreibe, den adapter auf gelb setzte und sobald die verbindung wieder funktioniert, wieder auf grün und das spiel beginnt wieder von vorn
    VumerV Offline
    VumerV Offline
    Vumer
    #76
    @dirkhe
    Heute ist noch das dazugekommen
    mihome-vacuum.0 2022-11-02 10:03:08.847	error	sendMessage throws error ==>MIIO MESSAGE CANT PARSE ANSWER: error:06065064:digital envelope routines:EVP_DecryptFinal_ex:bad decrypt
    • VumerV Offline
      VumerV Offline
      Vumer
      #77
      Während der Reinigung
      mihome-vacuum.0 2022-11-02 10:36:19.670	warn	your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
      mihome-vacuum.0 2022-11-02 10:36:19.525	warn	your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
      mihome-vacuum.0 2022-11-02 10:36:17.552	error	sendMessage throws error ==>MIIO MESSAGE CANT PARSE ANSWER: {"id":4115,"result":[{"msg_ver":2,"msg_seq":7406,"state":18,"battery":84,"clean_time":673,"clean_area":8735000,"error_code":0,"map_present":1,"in_cleaning":3,"in_returning":0,"in_fresh_state":0,"lab_status":3,"water_box_status":1,"fan_power":103,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":201,"distance_off":60,"water_box_carriage_status":0,"mop_forbidden_enable"�n�ۅ�����h7V�6� <X�5��0�� �����!0R>���_collection_status":0,"auto_dust_collection":1,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1}],"exe_time":11}
      mihome-vacuum.0 2022-11-02 10:36:17.549	error	sendMessage throws error ==>MIIO MESSAGE CANT PARSE ANSWER: {"id":4115,"result":[{"msg_ver":2,"msg_seq":7406,"state":18,"battery":84,"clean_time":673,"clean_area":8735000,"error_code":0,"map_present":1,"in_cleaning":3,"in_returning":0,"in_fresh_state":0,"lab_status":3,"water_box_status":1,"fan_power":103,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":201,"distance_off":60,"water_box_carriage_status":0,"mop_forbidden_enable"�n�ۅ�����h7V�6� <X�5��0�� �����!0R>���_collection_status":0,"auto_dust_collection":1,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1}],"exe_time":11}
      • VumerV Vumer
        D Nicht stören
        D Nicht stören
        dirkhe
        #78
        @vumer Ja, ich denke, ich werde die alle auf warning setzten. Ich meine dass da Müll zurückkommt, sieht man ja...
        • G Offline
          gyle
          #79
          ich habe mal eine Frage:
          wie kann ich eine laufende zB Raum-Reinigung abbrechen - und zwar so, dass ich anschließend eine neue starten kann?
          Derzeit nutze ich dafür den Datenpunkt "pause" - das problem ist jedoch, dass er dann sozusagen noch in der Reinigung "hängt" und ich keine neue starten kann.
          In der App kommt dann der Hinweis, dass ich zuerst die laufende Reinigung beenden muss > wie mache ich das über den Adapter?
          • D3ltoroxpD Offline
            D3ltoroxpD Offline
            D3ltoroxp
            #80
            Hab jetzt leider auch nach dem neusten Update die Log voll mit folgenden Meldungen..
            • D3ltoroxpD D3ltoroxp
              DJMarc75D Offline
              DJMarc75D Offline
              DJMarc75
              #81
              @d3ltoroxp https://forum.iobroker.net/topic/59480/test-für-mihome-vacuum/20
              Lehrling seit 1975 !!!
              D3ltoroxpD 1 Antwort Letzte Antwort
              • DJMarc75D DJMarc75
                D3ltoroxpD Offline
                D3ltoroxpD Offline
                D3ltoroxp
                #82
                @djmarc75 Sorry werde daraus nicht schlau, hatte das ja schon gelesen. Was willst du mir damit sagen ?
                  D Nicht stören
                  D Nicht stören
                  dirkhe
                  #83
                  Ich habe mal die 3.8.4 veröffentlicht, da sollte das Log ruhiger sein....
                  ? da_WoodyD 2 Antworten Letzte Antwort
                  • D dirkhe
                    #84
                    @dirkhe sagte in Test für mihome-vacuum:
                    Hallo, ja vielen Dank, ist es. Bis jetzt keine Fehler / Warnings im Log, meine vier S5 fahren nachher mal ne Runde, die Grundfunktionen hab ich getestet, gehen..
                    • D dirkhe
                      da_WoodyD Offline
                      da_WoodyD Offline
                      #85
                      • VumerV Offline
                        VumerV Offline
                        Vumer
                        #86
                        Heute Nacht
                        mihome-vacuum.0 2022-11-09 05:16:50.322	error	sendMessage throws error ==>MIIO MESSAGE CANT PARSE ANSWER: error:06065064:digital envelope routines:EVP_DecryptFinal_ex:bad decrypt
                        mihome-vacuum.0 2022-11-09 04:23:46.883	error	sendMessage throws error ==>MIIO MESSAGE CANT PARSE ANSWER: {"id":5047,"result":[{"msg_ver":2,"msg_seq":1535,"state":8,"battery":100,"clean_time":471,"clean_area":8785000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"fan_power":103,"dnd_enabled":1,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":207,"distance_off":60,"water_box_carriage_status":0,"mop_forbidden_enable":0,"adbumper_status":[0,0,0],"dock_type":0,"dust_collection_stat�Wiw�~ �j��r�k%���7TŕN��r��K���tA*��n9SWG f�t*U��J������vZ��p$;��j ڗ� ���k�^status":1}],"exe_time":11}
                        mihome-vacuum.0 2022-11-09 04:23:46.880	error	sendMessage throws error ==>MIIO MESSAGE CANT PARSE ANSWER: {"id":5047,"result":[{"msg_ver":2,"msg_seq":1535,"state":8,"battery":100,"clean_time":471,"clean_area":8785000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"fan_power":103,"dnd_enabled":1,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":207,"distance_off":60,"water_box_carriage_status":0,"mop_forbidden_enable":0,"adbumper_status":[0,0,0],"dock_type":0,"dust_collection_stat�Wiw�~ �j��r�k%���7TŕN��r��K���tA*��n9SWG f�t*U��J������vZ��p$;��j ڗ� ���k�^status":1}],"exe_time":11}
                        mihome-vacuum.0 2022-11-09 04:06:12.036	error	sendMessage throws error ==>MIIO MESSAGE CANT PARSE ANSWER: �j�>S&� �d��lt":["roboroommap%2F535262734%2F0"],"exe_time":10}
                        mihome-vacuum.0 2022-11-09 04:06:12.033	error	sendMessage throws error ==>MIIO MESSAGE CANT PARSE ANSWER: �j�>S&� �d��lt":["roboroommap%2F535262734%2F0"],"exe_time":10}
                        mihome-vacuum.0 2022-11-09 03:02:57.222	error	sendMessage throws error ==>MIIO MESSAGE CANT PARSE ANSWER: @50 r6�e���kVU��V7�Z�c]�l����(����������͍Y,��h���������\��L��Y�A �%�{�h⹟N��3_H0��U�xx:xx:xx:xx:xx:xx","rssi":-36},"exe_time":31}
                        mihome-vacuum.0 2022-11-09 03:02:57.220	error	sendMessage throws error ==>MIIO MESSAGE CANT PARSE ANSWER: @50 r6�e���kVU��V7�Z�c]�l����(����������͍Y,��h���������\��L��Y�A �%�{�h⹟N��3_H0��U�xx:xx:xx:xx:xx:xx","rssi":-36},"exe_time":31}
                        und während der Reinigung
                        mihome-vacuum.0 2022-11-09 11:32:16.306	error	sendMessage throws error ==>MIIO MESSAGE CANT PARSE ANSWER: error:06065064:digital envelope routines:EVP_DecryptFinal_ex:bad decrypt
                        mihome-vacuum.0 2022-11-09 11:32:16.303	error	sendMessage throws error ==>MIIO MESSAGE CANT PARSE ANSWER: error:06065064:digital envelope routines:EVP_DecryptFinal_ex:bad decrypt
                        mihome-vacuum.0 2022-11-09 11:15:55.415	error	sendMessage throws error ==>MIIO MESSAGE CANT PARSE ANSWER: error:06065064:digital envelope routines:EVP_DecryptFinal_ex:bad decrypt
                        mihome-vacuum.0 2022-11-09 11:15:55.412	error	sendMessage throws error ==>MIIO MESSAGE CANT PARSE ANSWER: error:06065064:digital envelope routines:EVP_DecryptFinal_ex:bad decrypt
                        • VumerV Vumer
                          Heute Nacht
                          D Nicht stören
                          D Nicht stören
                          dirkhe
                          #87
                          @vumer ja da sind parserfehler, könnre man ggf. Auch nur ins debug schreiben, weil er macht ja weiter.... oder zumindest ins info
                          @da_Woody mach mal debug an, die fehlermeldungen kommen da genauso häufig
                          • VumerV Offline
                            VumerV Offline
                            Vumer
                            #88
                            Ich hab auf rot Allergie und gelb macht mich nervös ;)
                            • C Offline
                              ChrisXY
                              #89
                              puhhh ich verzweifel an der Pause / Resume Ich will es per GUI steuern lassen.
                              Leider gibt es keine art toogle ..
                              Es gibt nur Pause für Pause.. dann muss man wissen was man gemacht hat.
                              Raumreinigung eines Raums läuft ..
                              Dann will ich PAUSE absenden. Schalter bleibt auf True ..
                              Was nun ? Für Raumreinigung weitermachen gibt es nur resumeroom
                              Start= Alles wird Gereinigt ..
                              Es gibt keinen toogle? Leider wird auch Pause nicht wieder auf false gesetzt. Somit ist der state von dem schalter auch immer falsch ..
                              Müsste das jetzt per Blockly wohl lösen. Oder gibt es da eine bessere Möglichkeit.
                              Will blos ein Schalter egal was er macht Pause/Weiter
                              • C ChrisXY
                                D Nicht stören
                                D Nicht stören
                                dirkhe
                                #90
                                @chrisxy conttol.pauseResume sollte das machen, der status eird sogar verändert, wenn du ssuger per hand losfährst, ist also der toggle
                                C 1 Antwort Letzte Antwort
                                • D dirkhe
                                  ChrisXY
                                  #91
                                  @dirkhe klappt nicht. Wenn ich ihn zu einem Raum schicke zum Reinigen. Kann ich nur mit "pause" stoppen und per "resumroom.." starten. Das pauseResume hat nie einen effekt :(
                                  • C ChrisXY
                                    D Nicht stören
                                    D Nicht stören
                                    dirkhe
                                    #92
                                    @chrisxy reden wir vom gleichen adapter? Resumeroom gibt es gar nicht.
                                    zeige mal ein debuglog, da kannst du dann mal psuseresum drücken, wichtig ack auf false
                                    • DiginixD Offline
                                      DiginixD Offline
                                      Diginix
                                      #93
                                      @dirkhe 3.8.5 hat heute beim Saugen von 7 Räumen mit zT 3 im queue immer den korrekten room.state angezeigt und auch die CPU Last sieht über 12 Stunden wie mit 3.6.0 aus. Denke du hast die richtige Stelle gefixt.
                                      Perfekt wäre es nun noch wenn man in den Instanzenstellungen die Farbwerte aus der mapcreator.js selbst einstellen könnte:
                                      alt bis 3.6.0
                                      neu seit 3.8.x (aber auf dunklem Hintergrund bei Saugern ohne Teppicherkennung nachteilig)
                                      ..:: So long! Tom ::..
                                      • DiginixD Diginix
                                        alt bis 3.6.0
                                        D Nicht stören
                                        D Nicht stören
                                        dirkhe
                                        #94
                                        @diginix ich würde da jetzt quasi eine farbthemen liste (mit 2 einträgen) machen wollen. Jetzt bist du gefragt, hast du einevidee, wie man jeweils die farbthemes benennen könnte? So könnte man demnächst noch weitere themes hinzufügen
                                        da_WoodyD DiginixD 2 Antworten Letzte Antwort
                                        • D dirkhe
                                          da_WoodyD Offline
                                          da_WoodyD Offline
                                          #95
                                          @dirkhe irgendwie versteh ich das nicht. da gibts im adapter ja
                                          hat aber 0 auswirkung. angezeigt wird ja
                                          wo bin ich da falsch abgebogen? 😵
