SONOFF NSPanel mit Lovelace UI (TypeScript Version)
@andreas_z sagte in SONOFF NSPanel mit Lovelace UI:
@armilar
Habe ich, MQTT.2 ist als Server (mit anderem Port) konfiguriert und identischem Resultat, es wird nichts auf dem Display angezeigt:mqtt.2 2022-09-23 19:32:17.692 info Client [NSPanel_1] publishOnSubscribe send all known states mqtt.2 2022-09-23 19:32:17.691 info Client [NSPanel_1] publishOnSubscribe send all known states mqtt.2 2022-09-23 19:32:17.689 info Client [NSPanel_1] publishOnSubscribe send all known states mqtt.2 2022-09-23 19:32:17.492 info Client [NSPanel_1] subscribes on "cmnd/NSPanel_1_fb/#" with regex /^mqtt\.2\.cmnd\.NSPanel_1_fb(\..*)?/ mqtt.2 2022-09-23 19:32:17.492 info Client [NSPanel_1] subscribes on "cmnd/NSPanel_1_fb/#" with regex /^cmnd\.NSPanel_1_fb(\..*)?/ mqtt.2 2022-09-23 19:32:17.491 info Client [NSPanel_1] subscribes on "SmartHome/tasmotas/cmnd/#" with regex /^mqtt\.2\.SmartHome\.tasmotas\.cmnd(\..*)?/ mqtt.2 2022-09-23 19:32:17.490 info Client [NSPanel_1] subscribes on "SmartHome/tasmotas/cmnd/#" with regex /^SmartHome\.tasmotas\.cmnd(\..*)?/ mqtt.2 2022-09-23 19:32:17.489 info Client [NSPanel_1] subscribes on "SmartHome/NSPanel_1/cmnd/#" with regex /^mqtt\.2\.SmartHome\.NSPanel_1\.cmnd(\..*)?/ mqtt.2 2022-09-23 19:32:17.489 info Client [NSPanel_1] subscribes on "SmartHome/NSPanel_1/cmnd/#" with regex /^SmartHome\.NSPanel_1\.cmnd(\..*)?/ mqtt.2 2022-09-23 19:32:17.454 info Client [NSPanel_1] connected with secret 1663954337450_1441 mqtt.2 2022-09-23 19:32:07.977 info Client [NSPanel_1] connection closed: closed javascript.0 2022-09-23 19:30:27.658 info script.js.common.NSPanel_1: registered 12 subscriptions, 6 schedules, 0 messages, 0 logs and 0 file subscriptions javascript.0 2022-09-23 19:30:27.636 info script.js.common.NSPanel_1: TypeScript compilation successful javascript.0 2022-09-23 19:30:25.964 info script.js.common.NSPanel_1: compiling TypeScript source... javascript.0 2022-09-23 19:30:25.924 debug File /home/Javascript/common/NSPanel_1.ts change javascript.0 2022-09-23 19:30:25.924 info Stop script script.js.common.NSPanel_1 javascript.0 2022-09-23 19:30:25.917 debug Update /home/Javascript/common/NSPanel_1.ts on diskWerte im Script habe ich auf MQTT.2 geändert gehabt.
So und jetzt bitte mal die mqtt-Einstellungen aus dem mqtt.2. und aus Tasmota posten. Ich denke wir finden den Fehler noch
By the way, Respekt und dank für deine Geduld
Denke ich habe was ... Bitte nach und nach..
Haken "unbedingt" raus... und raus lassen
Haken rein...
Setze mal höher
Wärst so ziemlich der erste bei dem es nicht funktioniert. Können wir irgendwie nicht auf uns sitzen lassen... ;-)
und zum Schluss noch die beiden Zeilen aktualisieren, falls noch nicht geschehen...
panelRecvTopic: 'mqtt.2.SmartHome.NSPanel_1.tele.RESULT', // anpassen panelSendTopic: 'mqtt.2.SmartHome.NSPanel_1.cmnd.CustomSend', // anpassen -
Haken rein...
Setze mal höher
panelRecvTopic: 'mqtt.2.SmartHome.NSPanel_1.tele.RESULT', // anpassen panelSendTopic: 'mqtt.2.SmartHome.NSPanel_1.cmnd.CustomSend', // anpassen@armilar Alles Umgesetzt, ohne Erfolg, was aber bisher immer passiert (Mit Mosqitto und über Iobroker Intern MQTT), wenn ich das Script neu gestartet oder geändert habe, das "This is taking longer ....." verschwindet für einen Moment und erscheint danach wieder, also scheint es ja doch eine Gewisse Kommunikation zu geben
Okay ich gebe auf. Kannst noch mal versuchen die IP im Broker auf den Server zusetzten und beide Kisten iobroker und Panel durchstarten. Mehr geht eigentlich nicht...
Hallo Community,
wir haben viel zeit und Getippsel investiert und unserer Wiki ein bissel Glanz und Struktur gegönnt.
Ja, wir wissen wir sind am Anfang und eine Wiki ist ja bekanntlich nie zu Ende, bzw. lebt von dem was wir alle noch hinzufügen werden.Neben dem alten klassischen Menü, welches man noch aufklappen kann, gibt es jetzt links ein neues hübsches Menü, welches Euch mit einem kurzen Blick&Klick in den richtigen Bereich führt.
Am unteren Ende einer Seite gibt es einen "nach oben Scroll Button".Wir hoffen, die neue Struktur hilft Euch in der Zukunft euch noch besser zurecht zu finden.
Viel Spaß :-)
Euer NSPanel LUI Team :-)
@kuckuckmann (nur für deine Tests)
@andreas_z
Hi Andreas,was ich bei dem ganzen vermisse, ist die Bestätigung, dass CustomSend funktioniert.
Da ich gerade selbst damit zu kämpfen hatte, stell bitte sicher, dass der entweder aus der Tasmota Konsole oder dem Mosquitto Explorer so wie in der Anleitung im Wiki auch passiert. Ich könnte mir vorstellen, dass dies die Lösung ist.LG
@andreas_z
Er funktioniert leider nicht mal aus der Konsole raus
20:23:10.191 CMD: CustomSend time~12:00
20:23:10.216 MQT: SmartHome/tasmota_E7EFAC/stat/RESULT = {"CustomSend":"Done"}
20:23:13.604 MQT: SmartHome/tasmota_E7EFAC/tele/RESULT = {"CustomRecv":"event,startup,42,eu"}Es wird nichts auf dem Display angezeigt. Zwischenzeitlich habe ich noch einmal bei 0 Angefangen und komplett neu geflasht und konfiguriert, leider mit dem selben Ergebnis.
@andreas_z
Hast Du es via Mosquitto probiert? -
@andreas_z
Hast Du es via Mosquitto probiert?@kuckuckmann
Aus der Konsole, über Iobroker, mit MQTT-Explorer, das blö.... Display hat keine Lust etwas anzuzeigen, außer "Waiting for content" -
@kuckuckmann
Aus der Konsole, über Iobroker, mit MQTT-Explorer, das blö.... Display hat keine Lust etwas anzuzeigen, außer "Waiting for content"@andreas_z
CMD: CustomSend time~12:00 <--- hat das einen aktuellen Zeitstempel? -
@jobr99 Eine 4. Seite eingebaut, Ergebnis ist gleich, man kann nur eine Seite blättern, egal welche Richtung. Weiter geht es nur mit Zwischenschritt über die Detailseite eines Schalters.
Erinnert mich irgendwie an unseren 1. LKW damals, konnte man auch nur mit ordentlich Zwischengas schalten...
@skatbert
Gibt es bei Dir schon was neues?
Ich habe noch eine Idee: Kannst Du mal die Seiten leer machen, so das keine PageItems drauf sind und dann mal das Blättern testen? -
@andreas_z
@kuckuckmann @Armilar
OK warum auch immer, aus irgend einem nicht Erklärbaren Grund funktioniert auf einmal das Display und zeigt alles an, letzte Aktion war das erneute kopieren des Skripts aus Notepad++Vielen vielen Dank für eure Geduld
okay - ab jetzt ist es nur noch Fleißarbeit
@andreas_z
KONFETTISuper gut, viel Spass damit :-)
@skatbert
Ich habe noch eine Idee: Kannst Du mal die Seiten leer machen, so das keine PageItems drauf sind und dann mal das Blättern testen?@kuckuckmann ja kann ich nochmal probieren. Bin ab morgen erstmal für eine Woche im Urlaub. Teste es dann und melde mich.
@skatbert
Ich habe noch eine Idee: Kannst Du mal die Seiten leer machen, so das keine PageItems drauf sind und dann mal das Blättern testen?@kuckuckmann Ich habe das ohne Items noch schnell mal probiert, nix neues, das Blätterverhalten ist gleich, maximal 1 Seite und dann einen Zwischenschritt über die Detailseite oder Screensaver.
@skatbert
Mit welchem Editor bearbeitest Du dein Skript? -
@skatbert
Mit welchem Editor bearbeitest Du dein Skript?@kuckuckmann mit notepad und auch direkt im script Adapter.
@skatbert
Mit welchem Editor bearbeitest Du dein Skript?@john5star sagte in Sonoff NSPanel:
ich habe das Abfallskript mal getestet. Bei mir wurden lediglich vier alias-Ordner angelegt, keine Geräte. Des weiteren habe ich versucht andere Farben für die Tonnen zu vergeben. Dabei habe ich festgestellt, dass die Farbe Gelb der "Gelben Tonne" bei mir auch in den Datenpunkt für die Farbe der Restmülltonne mit übernommen wird.
@john5star hast du das schon gesehen?
https://github.com/joBr99/nspanel-lovelace-ui/wiki/ioBroker---FAQ-&-Anleitungen#4-abfallkalender
@armilar
Die Anleitung bin ich schon durchgegangen. Ich habe das Skript V.3 von tt-tom getestet. Vorher alle Datenpunkte und Aliase gelöscht und das Skript mit der automatischen Anlage dieser laufen lassen. Wie gesagt es wurden keine Alias-Geräte sondern Alias-Ordner angelegt. Und der color Datenpunkt der Restmülltonne wird mit den color-Daten der gelben Tonne befüllt.
