lovelace uinspanelsonoff
8.1k Beiträge 282 Kommentatoren 12.7m Aufrufe 261 Beobachtet
  • ArmilarA Armilar
    @andreas_z sagte in SONOFF NSPanel mit Lovelace UI:
    Grundsätzlich scheint etwas über MQTT anzukommen, das Schalten von POWER1 manuell über das Objekt SmartHome/NSPanel_1/cmnd/POWER funktioniert.
    Wenn ich CustomSend time~12:00 in der Konsole absende, wird aber nichts auf dem Display angezeigt.
    autexec.be:
    # Sonoff NSPanel Tasmota Lovelace UI Berry Driver | code by joBr99
    # based on;
    # Sonoff NSPanel Tasmota (Nextion with Flashing) driver | code by peepshow-21
    # based on;
    # Sonoff NSPanel Tasmota driver v0.47 | code by blakadder and s-hadinger
    # Example Flash
    # FlashNextion http://ip-address-of-your-homeassistant:8123/local/nspanel.tft
    # FlashNextion http://nspanel.pky.eu/lui.tft
    class Nextion : Driver
        static header = bytes('55BB')
        static flash_block_size = 4096
        var flash_mode
    	var flash_start_millis
        var flash_size
        var flash_written
        var flash_buff
        var flash_offset
        var awaiting_offset
        var tcp
        var ser
        var last_per
    	var url
        def split_55(b)
          var ret = []
          var s = size(b)
          var i = s-2   # start from last-1
          while i > 0
            if b[i] == 0x55 && b[i+1] == 0xBB
              ret.push(b[i..s-1]) # push last msg to list
              b = b[(0..i-1)]   # write the rest back to b
            end
            i -= 1
          end
          ret.push(b)
          return ret
        end
        def crc16(data, poly)
          if !poly  poly = 0xA001 end
          # CRC-16 MODBUS HASHING ALGORITHM
          var crc = 0xFFFF
          for i:0..size(data)-1
            crc = crc ^ data[i]
            for j:0..7
              if crc & 1
                crc = (crc >> 1) ^ poly
              else
                crc = crc >> 1
              end
            end
          end
          return crc
        end
    	# encode using custom protocol 55 BB [payload length] [payload length] [payload] [crc] [crc]
        def encode(payload)
          var b = bytes()
          b += self.header
          b.add(size(payload), 2)   # add size as 2 bytes, little endian
          b += bytes().fromstring(payload)
          var msg_crc = self.crc16(b)
          b.add(msg_crc, 2)       # crc 2 bytes, little endian
          return b
        end
        def encodenx(payload)
            var b = bytes().fromstring(payload)
            b += bytes('FFFFFF')
            return b
        end
        def sendnx(payload)
            import string
            var payload_bin = self.encodenx(payload)
            self.ser.write(payload_bin)
            log(string.format("NXP: Nextion command sent = %s",str(payload_bin)), 3)
        end
        def send(payload)
            var payload_bin = self.encode(payload)
            if self.flash_mode==1
                log("NXP: skipped command becuase still flashing", 3)
            else
                log("NXP: payload sent = " + str(payload_bin), 3)
            end
        end
        def write_to_nextion(b)
            self.ser.write(b)
        end
        def screeninit()
            log("NXP: Screen Initialized")
    		self.sendnx("recmod=1")
        end
        def write_block()
            import string
            log("FLH: Read block",3)
            while size(self.flash_buff)<self.flash_block_size && self.tcp.connected()
                if self.tcp.available()>0
                    self.flash_buff += self.tcp.readbytes()
                else
                    tasmota.delay(50)
                    log("FLH: Wait for available...",3)
                end
            end
            log("FLH: Buff size "+str(size(self.flash_buff)),3)
            var to_write
            if size(self.flash_buff)>self.flash_block_size
                to_write = self.flash_buff[0..self.flash_block_size-1]
                self.flash_buff = self.flash_buff[self.flash_block_size..]
            else
                self.flash_buff = bytes()
            end
            log("FLH: Writing "+str(size(to_write)),3)
            var per = (self.flash_written*100)/self.flash_size
            if (self.last_per!=per)
                self.last_per = per
                tasmota.publish_result(string.format("{\"Flashing\":{\"complete\": %d, \"time_elapsed\": %d}}",per , (tasmota.millis()-self.flash_start_millis)/1000), "RESULT")
            end
            if size(to_write)>0
                self.flash_written += size(to_write)
                self.ser.write(to_write)
            end
            log("FLH: Total "+str(self.flash_written),3)
            if (self.flash_written==self.flash_size)
                log("FLH: Flashing complete - Time elapsed: %d", (tasmota.millis()-self.flash_start_millis)/1000)
                self.flash_mode = 0
    			self.ser = nil
    			tasmota.gc()
    			self.ser = serial(17, 16, 115200, serial.SERIAL_8N1)
            end
        end
        def every_100ms()
            import string
            if self.ser.available() > 0
                var msg = self.ser.read()
                if size(msg) > 0
                    log(string.format("NXP: Received Raw = %s",str(msg)), 3)
                    if (self.flash_mode==1)
                        var strv = msg[0..-4].asstring()
                        if string.find(strv,"comok 2")>=0
                            log("FLH: Send (High Speed) flash start")
    						self.flash_start_millis = tasmota.millis()
                            #self.sendnx(string.format("whmi-wris %d,115200,res0",self.flash_size))
                            self.sendnx(string.format("whmi-wris %d,921600,res0",self.flash_size))
    						self.ser = serial(17, 16, 921600, serial.SERIAL_8N1)
                        elif size(msg)==1 && msg[0]==0x08
                            log("FLH: Waiting offset...",3)
                            self.awaiting_offset = 1
                        elif size(msg)==4 && self.awaiting_offset==1
                            self.awaiting_offset = 0
                            self.flash_offset = msg.get(0,4)
                            log("FLH: Flash offset marker "+str(self.flash_offset),3)
    						if self.flash_offset != 0
    							self.open_url_at(self.url, self.flash_offset)
    							self.flash_written = self.flash_offset
    						end
                            self.write_block()
                        elif size(msg)==1 && msg[0]==0x05
                            self.write_block()
                        else
                            log("FLH: Something has gone wrong flashing display firmware ["+str(msg)+"]",2)
                        end
                    else
                        var msg_list = self.split_55(msg)
                        for i:0..size(msg_list)-1
                            msg = msg_list[i]
                            if size(msg) > 0
                                if msg == bytes('000000FFFFFF88FFFFFF')
                                    self.screeninit()
                                elif size(msg)>=2 && msg[0]==0x55 && msg[1]==0xBB
                                    var jm = string.format("{\"CustomRecv\":\"%s\"}",msg[4..-3].asstring())
                                    tasmota.publish_result(jm, "RESULT")
                                elif msg[0]==0x07 && size(msg)==1 # BELL/Buzzer
                                    tasmota.cmd("buzzer 1,1")
                                else
                                    var jm = string.format("{\"nextion\":\"%s\"}",str(msg[0..-4]))
                                end
                            end
                        end
                    end
                end
            end
        end
        def begin_nextion_flash()
            self.flash_written = 0
            self.flash_offset = 0
            self.sendnx('DRAKJHSUYDGBNCJHGJKSHBDN')
            self.sendnx('recmod=0')
            self.flash_mode = 1
            self.sendnx("connect")
        end
        def open_url_at(url, pos)
    		self.url = url
            import string
            var host
            var port
            var s1 = string.split(url,7)[1]
            var i = string.find(s1,":")
            var sa
            if i<0
                port = 80
                i = string.find(s1,"/")
                sa = string.split(s1,i)
                host = sa[0]
            else
                host = sa[0]
                s1 = string.split(sa[1],1)[1]
                port = int(sa[0])
            end
            var get = sa[1]
            log(string.format("FLH: host: %s, port: %s, get: %s",host,port,get))
            self.tcp = tcpclient()
            self.tcp.connect(host,port)
            log("FLH: Connected:"+str(self.tcp.connected()),3)
            var get_req = "GET "+get+" HTTP/1.0\r\n"
    		get_req += string.format("Range: bytes=%d-\r\n", pos)
    		get_req += string.format("HOST: %s:%s\r\n\r\n",host,port)
            self.tcp.write(get_req)
            var a = self.tcp.available()
            i = 1
            while a==0 && i<5
              tasmota.delay(100*i)
              tasmota.yield()
              i += 1
              log("FLH: Retry "+str(i),3)
            end
            if a==0
                log("FLH: Nothing available to read!",3)
                return
            end
            var b = self.tcp.readbytes()
            i = 0
            var end_headers = false;
            var headers
            while i<size(b) && headers==nil
                if b[i..(i+3)]==bytes().fromstring("\r\n\r\n")
                    headers = b[0..(i+3)].asstring()
                    self.flash_buff = b[(i+4)..]
                else
                    i += 1
                end
            end
            #print(headers)
    		# check http respose for code 200/206
            if string.find(headers,"200 OK")>0 || string.find(headers,"206 Partial Content")>0
                log("FLH: HTTP Respose is 200 OK or 206 Partial Content",3)
    		else
                log("FLH: HTTP Respose is not 200 OK or 206 Partial Content",3)
    			print(headers)
    			return -1
            end
    		# only set flash size if pos is zero
    		if pos == 0
    			# check http respose for content-length
    			var tag = "Content-Length: "
    			i = string.find(headers,tag)
    			if (i>0)
    				var i2 = string.find(headers,"\r\n",i)
    				var s = headers[i+size(tag)..i2-1]
    				self.flash_size=int(s)
    			end
    			log("FLH: Flash file size: "+str(self.flash_size),3)
    		end
        end
        def flash_nextion(url)
            self.flash_size = 0
            var res = self.open_url_at(url, 0)
    		if res != -1
    			self.begin_nextion_flash()
    		end
        end
        def init()
            log("NXP: Initializing Driver")
            self.flash_mode = 0
        end
    end
    var nextion = Nextion()
    tasmota.add_driver(nextion)
    def get_current_version(cmd, idx, payload, payload_json)
    	import string
    	var version_of_this_script = 4
    	var jm = string.format("{\"nlui_driver_version\":\"%s\"}", version_of_this_script)
    end
    tasmota.add_cmd('GetDriverVersion', get_current_version)
    def update_berry_driver(cmd, idx, payload, payload_json)
    	def task()
    		import string
    		var cl = webclient()
    		cl.begin(payload)
    		var r = cl.GET()
    		if r == 200
    			print("Sucessfully downloaded nspanel-lovelace-ui berry driver")
    		else
    			print("Error while downloading nspanel-lovelace-ui berry driver")
    		end
    		r = cl.write_file("autoexec.be")
    		if r < 0
    			print("Error while writeing nspanel-lovelace-ui berry driver")
    		else
    			print("Sucessfully written nspanel-lovelace-ui berry driver")
    			var s = load('autoexec.be')
    			if s == true
    				var jm = string.format("{\"nlui_driver_update\":\"%s\"}", "succeeded")
    			else
    				var jm = string.format("{\"nlui_driver_update\":\"%s\"}", "failed")
    			end
    		end
    	end
    	tasmota.set_timer(0,task)
    	tasmota.resp_cmnd_done()
    end
    tasmota.add_cmd('UpdateDriverVersion', update_berry_driver)
    def flash_nextion(cmd, idx, payload, payload_json)
        def task()
            nextion.flash_nextion(payload)
        end
    end
    def send_cmd(cmd, idx, payload, payload_json)
        nextion.sendnx(payload)
    end
    def send_cmd2(cmd, idx, payload, payload_json)
        nextion.send(payload)
    end
    tasmota.add_cmd('Nextion', send_cmd)
    tasmota.add_cmd('CustomSend', send_cmd2)
    tasmota.add_cmd('FlashNextion', flash_nextion)
    MQTT-Settings:
    Sonstige Einstellungen/Vorlage
    {"NAME":"NSPanel","GPIO":[0,0,0,0,3872,0,0,0,0,0,32,0,0,0,0,225,0,480,224,1,0,0,0,33,0,0,0,0,0,0,0,0,0,0,4736,0],"FLAG":0,"BASE":1}
    Das mqtt.1. muss in beide Richtungen kommunizieren. RESULT funktioniert. Teste es doch bitte so wie beschrieben. Deinen Mosquitto kannst du anschließend immer noch bemühen.
    Andreas_ZA
    Andreas_ZA
    Andreas_Z
    @armilar
    Habe ich, MQTT.2 ist als Server (mit anderem Port) konfiguriert und identischem Resultat, es wird nichts auf dem Display angezeigt:
    mqtt.2	2022-09-23 19:32:17.692	info	Client [NSPanel_1] publishOnSubscribe send all known states
    mqtt.2	2022-09-23 19:32:17.691	info	Client [NSPanel_1] publishOnSubscribe send all known states
    mqtt.2	2022-09-23 19:32:17.689	info	Client [NSPanel_1] publishOnSubscribe send all known states
    mqtt.2	2022-09-23 19:32:17.492	info	Client [NSPanel_1] subscribes on "cmnd/NSPanel_1_fb/#" with regex /^mqtt\.2\.cmnd\.NSPanel_1_fb(\..*)?/
    mqtt.2	2022-09-23 19:32:17.492	info	Client [NSPanel_1] subscribes on "cmnd/NSPanel_1_fb/#" with regex /^cmnd\.NSPanel_1_fb(\..*)?/
    mqtt.2	2022-09-23 19:32:17.491	info	Client [NSPanel_1] subscribes on "SmartHome/tasmotas/cmnd/#" with regex /^mqtt\.2\.SmartHome\.tasmotas\.cmnd(\..*)?/
    mqtt.2	2022-09-23 19:32:17.490	info	Client [NSPanel_1] subscribes on "SmartHome/tasmotas/cmnd/#" with regex /^SmartHome\.tasmotas\.cmnd(\..*)?/
    mqtt.2	2022-09-23 19:32:17.489	info	Client [NSPanel_1] subscribes on "SmartHome/NSPanel_1/cmnd/#" with regex /^mqtt\.2\.SmartHome\.NSPanel_1\.cmnd(\..*)?/
    mqtt.2	2022-09-23 19:32:17.489	info	Client [NSPanel_1] subscribes on "SmartHome/NSPanel_1/cmnd/#" with regex /^SmartHome\.NSPanel_1\.cmnd(\..*)?/
    mqtt.2	2022-09-23 19:32:17.454	info	Client [NSPanel_1] connected with secret 1663954337450_1441
    mqtt.2	2022-09-23 19:32:07.977	info	Client [NSPanel_1] connection closed: closed
    javascript.0	2022-09-23 19:30:27.658	info	script.js.common.NSPanel_1: registered 12 subscriptions, 6 schedules, 0 messages, 0 logs and 0 file subscriptions
    javascript.0	2022-09-23 19:30:27.636	info	script.js.common.NSPanel_1: TypeScript compilation successful
    javascript.0	2022-09-23 19:30:25.964	info	script.js.common.NSPanel_1: compiling TypeScript source...
    javascript.0	2022-09-23 19:30:25.924	debug	File /home/Javascript/common/NSPanel_1.ts change
    javascript.0	2022-09-23 19:30:25.924	info	Stop script script.js.common.NSPanel_1
    javascript.0	2022-09-23 19:30:25.917	debug	Update /home/Javascript/common/NSPanel_1.ts on disk
    Werte im Script habe ich auf MQTT.2 geändert gehabt.
    • Andreas_ZA Andreas_Z
      @armilar
      ArmilarA
      ArmilarA
      Armilar
      Most Active Forum Testing
      @armilar
      So und jetzt bitte mal die mqtt-Einstellungen aus dem mqtt.2. und aus Tasmota posten. Ich denke wir finden den Fehler noch
      Andreas_ZA 1 Antwort Letzte Antwort
      • ArmilarA Armilar
        @armilar
        Andreas_ZA
        Andreas_ZA
        Andreas_Z
        @armilar
        By the way, Respekt und dank für deine Geduld 👍
          @armilar
          ArmilarA
          ArmilarA
          Armilar
          @armilar
          Denke ich habe was ... Bitte nach und nach..
          Haken "unbedingt" raus... und raus lassen
          Haken rein...
          Setze mal höher
          Wärst so ziemlich der erste bei dem es nicht funktioniert. Können wir irgendwie nicht auf uns sitzen lassen... ;-)
          und zum Schluss noch die beiden Zeilen aktualisieren, falls noch nicht geschehen...
              panelRecvTopic: 'mqtt.2.SmartHome.NSPanel_1.tele.RESULT',       // anpassen
              panelSendTopic: 'mqtt.2.SmartHome.NSPanel_1.cmnd.CustomSend',   // anpassen
          • ArmilarA Armilar
            @armilar
            Haken rein...
            Setze mal höher
            Andreas_ZA
            Andreas_ZA
            Andreas_Z
            @armilar Alles Umgesetzt, ohne Erfolg, was aber bisher immer passiert (Mit Mosqitto und über Iobroker Intern MQTT), wenn ich das Script neu gestartet oder geändert habe, das "This is taking longer ....." verschwindet für einen Moment und erscheint danach wieder, also scheint es ja doch eine Gewisse Kommunikation zu geben
            ArmilarA K 2 Antworten Letzte Antwort
              ArmilarA
              ArmilarA
              Armilar
              Okay ich gebe auf. Kannst noch mal versuchen die IP im Broker auf den Server zusetzten und beide Kisten iobroker und Panel durchstarten. Mehr geht eigentlich nicht...
              • K Kuckuckmann
                Hallo Community,
                wir haben viel zeit und Getippsel investiert und unserer Wiki ein bissel Glanz und Struktur gegönnt.
                Ja, wir wissen wir sind am Anfang und eine Wiki ist ja bekanntlich nie zu Ende, bzw. lebt von dem was wir alle noch hinzufügen werden.
                --> ZUR WIKI <--
                Neben dem alten klassischen Menü, welches man noch aufklappen kann, gibt es jetzt links ein neues hübsches Menü, welches Euch mit einem kurzen Blick&Klick in den richtigen Bereich führt.
                Am unteren Ende einer Seite gibt es einen "nach oben Scroll Button".
                Wir hoffen, die neue Struktur hilft Euch in der Zukunft euch noch besser zurecht zu finden.
                Viel Spaß :-)
                Euer NSPanel LUI Team :-)
                ArmilarA
                ArmilarA
                Armilar
                @kuckuckmann (nur für deine Tests)
                  K
                  K
                  Kuckuckmann
                  @andreas_z
                  Hi Andreas,
                  was ich bei dem ganzen vermisse, ist die Bestätigung, dass CustomSend funktioniert.
                  Da ich gerade selbst damit zu kämpfen hatte, stell bitte sicher, dass der entweder aus der Tasmota Konsole oder dem Mosquitto Explorer so wie in der Anleitung im Wiki auch passiert. Ich könnte mir vorstellen, dass dies die Lösung ist.
                  LG
                  NSPanel Dokumentation im GitHub Wiki:
                  • K Kuckuckmann
                    @andreas_z
                    Hi Andreas,
                    LG
                    Andreas_ZA
                    Andreas_ZA
                    Andreas_Z
                    @kuckuckmann
                    Er funktioniert leider nicht mal aus der Konsole raus
                    20:23:10.191 CMD: CustomSend time~12:00
                    20:23:10.216 MQT: SmartHome/tasmota_E7EFAC/stat/RESULT = {"CustomSend":"Done"}
                    20:23:13.604 MQT: SmartHome/tasmota_E7EFAC/tele/RESULT = {"CustomRecv":"event,startup,42,eu"}
                    Es wird nichts auf dem Display angezeigt. Zwischenzeitlich habe ich noch einmal bei 0 Angefangen und komplett neu geflasht und konfiguriert, leider mit dem selben Ergebnis.
                      @kuckuckmann
                      K
                      K
                      Kuckuckmann
                      @andreas_z
                      Hast Du es via Mosquitto probiert?
                      • K Kuckuckmann
                        @andreas_z
                        Andreas_ZA
                        Andreas_ZA
                        Andreas_Z
                        @kuckuckmann
                        Aus der Konsole, über Iobroker, mit MQTT-Explorer, das blö.... Display hat keine Lust etwas anzuzeigen, außer "Waiting for content"
                          @kuckuckmann
                          K
                          K
                          Kuckuckmann
                          @andreas_z
                          CMD: CustomSend time~12:00 <--- hat das einen aktuellen Zeitstempel?
                          • S Skatbert
                            @jobr99 Eine 4. Seite eingebaut, Ergebnis ist gleich, man kann nur eine Seite blättern, egal welche Richtung. Weiter geht es nur mit Zwischenschritt über die Detailseite eines Schalters.
                            Erinnert mich irgendwie an unseren 1. LKW damals, konnte man auch nur mit ordentlich Zwischengas schalten...😀 😀
                            K
                            K
                            Kuckuckmann
                            @skatbert
                            Gibt es bei Dir schon was neues?
                            Ich habe noch eine Idee: Kannst Du mal die Seiten leer machen, so das keine PageItems drauf sind und dann mal das Blättern testen?
                            S 2 Antworten Letzte Antwort
                            • K Kuckuckmann
                              @andreas_z
                              Andreas_ZA
                              Andreas_ZA
                              Andreas_Z
                              @kuckuckmann @Armilar
                              OK warum auch immer, aus irgend einem nicht Erklärbaren Grund funktioniert auf einmal das Display und zeigt alles an, letzte Aktion war das erneute kopieren des Skripts aus Notepad++
                              Vielen vielen Dank für eure Geduld
                                ArmilarA
                                ArmilarA
                                Armilar
                                okay - ab jetzt ist es nur noch Fleißarbeit
                                  K
                                  K
                                  Kuckuckmann
                                  @andreas_z
                                  KONFETTI
                                  Super gut, viel Spass damit :-)
                                  • K Kuckuckmann
                                    @skatbert
                                    S
                                    S
                                    Skatbert
                                    @kuckuckmann ja kann ich nochmal probieren. Bin ab morgen erstmal für eine Woche im Urlaub. Teste es dann und melde mich.
                                    • K Kuckuckmann
                                      @skatbert
                                      S
                                      S
                                      Skatbert
                                      schrieb am zuletzt editiert von Skatbert
                                      #66
                                      @kuckuckmann Ich habe das ohne Items noch schnell mal probiert, nix neues, das Blätterverhalten ist gleich, maximal 1 Seite und dann einen Zwischenschritt über die Detailseite oder Screensaver.
                                      • S Skatbert
                                        K
                                        K
                                        Kuckuckmann
                                        #67
                                        @skatbert
                                        Mit welchem Editor bearbeitest Du dein Skript?
                                        S ArmilarA 2 Antworten Letzte Antwort
                                        • K Kuckuckmann
                                          @skatbert
                                          S
                                          S
                                          Skatbert
                                          #68
                                          @kuckuckmann mit notepad und auch direkt im script Adapter.
                                          33.2k
                                          84.3k
