  4. JavaScript
  5. [Gelöst] TypeScript Kompilierfehler setObject
19 Beiträge 6 Kommentatoren 1.8k Aufrufe 4 Beobachtet
  • U uwe72
    Ich versuche mit TypeScript die Methode setObject() aufzurufen, aber bekomme einen Compilierfehler.
    const objId = 'shelly.0.SHPLG2-1#49FE33#1.online';
    let obj = getObject(objId);
    if (!obj.common.custom) {
      obj.common.custom = {};
    obj.common.custom['statistics.0'] = {
      "enabled": true,
      "count": false,
      "sumCount": false,
      "timeCount": true,
      "fiveMin": false,
      "impUnitPerImpulse": 1,
      "impUnit": "",
      "avg": false,
      "minmax": false,
      "sumDelta": false,
      "sumIgnoreMinus": false,
      "groupFactor": 1,
      "logName": "online_script_trockner"
    setObject(objId, obj);
    Hat jemand eine Idee was ich ändern kann oder was ich falsch mache?
    javascript.1 (486) script.js.common.Berechnungen.Test_Statistics: TypeScript compilation failed: setObject(objId, obj); ^ ERROR: Argument of type '{ common: { [x: string]: any; [x: number]: any; }; type: "state" \| "channel" \| "folder" \| "device"; acl: { object: number; state: number; owner: string; ownerGroup: string; }; _id: string; native: { [x: string]: any; }; enums: { ...; }; from: string; user: string; ts: number; }' is not assignable to parameter of type '(Omit<StateObject, "acl" \| "_id"> & { _id?: string; acl?: StateACL; }) \| (Omit<InstanceObject, "acl" \| "_id"> & { _id?: string; acl?: ObjectACL; }) \| ... 10 more ... \| (Omit<...> & { ...; })'. Type '{ common: { [x: string]: any; [x: number]: any; }; type: "state" \| "channel" \| "folder" \| "device"; acl: { object: number; state: number; owner: string; ownerGroup: string; }; _id: string; native: { [x: string]: any; }; enums: { ...; }; from: string; user: string; ts: number; }' is not assignable to type 'Omit<OtherObject, "acl" \| "_id"> & { _id?: string; acl?: ObjectACL; }'. Type '{ common: { [x: string]: any; [x: number]: any; }; type: "state" \| "channel" \| "folder" \| "device"; acl: { object: number; state: number; owner: string; ownerGroup: string; }; _id: string; native: { [x: string]: any; }; enums: { ...; }; from: string; user: string; ts: number; }' is not assignable to type 'Omit<OtherObject, "acl" \| "_id">'. Types of property 'common' are incompatible. Property 'name' is missing in type '{ [x: string]: any; [x: number]: any; }' but required in type 'OtherCommon'.
    @uwe72 sagte: mit TypeScript die Methode setObject() aufzurufen
    Das sieht nach Javascript aus. Mit TypeScript kenne ich mich nicht aus.
      @paul53 @AlCalzone nutzt IMHO TypeScript. Vielleicht kann der helfen
      • U uwe72
          "enabled": true,
          "count": false,
          "sumCount": false,
          "timeCount": true,
          "fiveMin": false,
          "impUnit": "",
          "avg": false,
          "minmax": false,
          "sumDelta": false,
          "groupFactor": 1,
        OliverIOO Offline
        OliverIOO Offline
        OliverIO
        @uwe72 sagte in TypeScript Kompilierfehler setObject:
        Property
        ganz exakt kann ich es dir nicht sagen.
        Typescript ist ja ein Aufsatz auf javascript um typensicherheit abbilden zu können.
        daher musst du beim schreiben von objekten ein paar dinge berücksichtigen, damit die typen zusammenpassen.
        der fehler der mir am ehesten auffällt, steht ganz am Ende des Fehlertextes
        es sieht so aus, als ob du in common das namens-attribut vergessen hast, den iobroker auf jeden fall haben will.
        genaueres, sollte man hier heraus lesen können
        https://github.com/ioBroker/ioBroker.docs/blob/master/docs/en/dev/objectsschema.md
        die lange liste am anfang des fehlertextes listet nur die verschiedenen typ-möglichkeiten auf, gegen die typescript geprüft hat. durch typ-überladung kann ein objekt auch verschiedene arten von Abbildungen annehmen.
        Meine Adapter und Widgets
        Links im Profil
        U 1 Antwort Letzte Antwort
        • OliverIOO OliverIO
          Property
          U Offline
          U Offline
          uwe72
          @oliverio Danke dir.
          Für mich ist dies allerdings auch ein Bug im TypeScript "Adapter", den dieser (sinnfreie) Code hier sollte eigentlich schon funktionieren?!
          Bringt aber den gleichen Fehler. Eigentlich hole ich mir ja die Struktur und möchte diese nur anreichern. Von dem her sollte das .name Property ja gefüllt bzw. vorhanden sein?!
          ```javascript.1 (486) script.js.common.Berechnungen.Test_Statistics: TypeScript compilation failed: setObject(objId, obj); ^ ERROR: Argument of type '{ common: { [x: string]: any; [x: number]: any; }; type: "state" | "channel" | "folder" | "device"; acl: { object: number; state: number; owner: string; ownerGroup: string; }; _id: string; native: { [x: string]: any; }; enums: { ...; }; from: string; user: string; ts: number; }' is not assignable to parameter of type '(Omit<StateObject, "acl" | "_id"> & { _id?: string; acl?: StateACL; }) | (Omit<InstanceObject, "acl" | "_id"> & { _id?: string; acl?: ObjectACL; }) | ... 10 more ... | (Omit<...> & { ...; })'. Type '{ common: { [x: string]: any; [x: number]: any; }; type: "state" | "channel" | "folder" | "device"; acl: { object: number; state: number; owner: string; ownerGroup: string; }; _id: string; native: { [x: string]: any; }; enums: { ...; }; from: string; user: string; ts: number; }' is not assignable to type 'Omit<OtherObject, "acl" | "_id"> & { _id?: string; acl?: ObjectACL; }'. Type '{ common: { [x: string]: any; [x: number]: any; }; type: "state" | "channel" | "folder" | "device"; acl: { object: number; state: number; owner: string; ownerGroup: string; }; _id: string; native: { [x: string]: any; }; enums: { ...; }; from: string; user: string; ts: number; }' is not assignable to type 'Omit<OtherObject, "acl" | "_id">'. Types of property 'common' are incompatible. Property 'name' is missing in type '{ [x: string]: any; [x: number]: any; }' but required in type 'OtherCommon'.
          • U uwe72
            U Offline
            U Offline
            uwe72
            So scheint es zu funktionieren:
            const originalDatenpunkt = 'shelly.0.SHPLG2-1#49FE33#1.online';
            setObject(originalDatenpunkt, {
                type: 'state',
                    common: {
                    type: getObject(originalDatenpunkt).common.type,
                    unit: getObject(originalDatenpunkt).common.unit,
                    read: true,
                    write: true,
                    role: getObject(originalDatenpunkt).common.role,
                    alias: {
                    custom: {
                        "statistics.0": {
                            "enabled": true,
                            "count": false,
                            "fiveMin": false,
                            "sumCount": false,
                            "impUnit": "",
                            "timeCount": true,
                            "avg": false,
                            "minmax": false,
                            "sumDelta": false,
                            "groupFactor": 1,
                            "logName": "online2"
                native: {}
            • U uwe72
                  type: 'state',
                      common: {
                      read: true,
                      write: true,
                      alias: {
                      custom: {
                          "statistics.0": {
                              "enabled": true,
                              "count": false,
                              "fiveMin": false,
                              "sumCount": false,
                              "impUnit": "",
                              "timeCount": true,
                              "avg": false,
                              "minmax": false,
                              "sumDelta": false,
                              "groupFactor": 1,
                  native: {}
              haus-automatisierungH Offline
              Damit wäre ich aber vorsichtig, da Du die Objekte änderst (z.B. read und write) und auch andere custom settings verwirfst. Bitte produktiv nicht so verwenden.
              📚 Meine Dokumentation
                U Offline
                U Offline
                uwe72
                schrieb am zuletzt editiert von uwe72
                @haus-automatisierung
                Gebe ich dir recht, insbesondere bei read/write. Dies könnte ich noch analog den anderen Einstellungen ändern.
                Bei custom hatte ich auch die Sorge, dass wenn da schon andere Custom-Einstellungen existieren für andere Adapter, z.B. Telegram, dass dies dann überschrieben wird und somit entfernt wird. Der Test hatte aber funktioniert.
                So oder so, wäre es nur ein hässlicher Workarround, der ja, ggf. auch Schaden anrichtet.
                Hast Du mir ein Verbesserungsvorschlag für meinen initialen Versuch? Danke dir.
                Vermutlich aber gar nicht so einfach, siehe #5
                https://forum.iobroker.net/topic/57264/typescript-kompilierfehler-setobject/5
                Für mich sieht dies nach einem Bug im TypeScript "Adapter" aus.
                • U uwe72
                  AlCalzoneA Offline
                  AlCalzoneA Offline
                  AlCalzone
                  @uwe72 Rein beim Drüberschauen würde ich vermuten, dass anhand der Objekt-ID nicht 100% klar ist, was das genau für ein Objekt ist. Wenn du TS auf die Sprünge hilfst, z.B.(
                  let obj: iobJS.StateObject = getObject(objId);
                  für einen State, oder
                  let obj: iobJS.ChannelObject = getObject(objId);
                  für einen Channel, etc., dann sollte die Zuweisung auch klappen (hoffentlich). Sonst muss ich nochmal schauen, ob das etwas weniger "auf die Fresse" geht :D
                  U 2 Antworten Letzte Antwort
                  • AlCalzoneA AlCalzone
                    U Offline
                    U Offline
                    uwe72
                    @alcalzone said in TypeScript Kompilierfehler setObject:
                    Ich habe es nun so:
                    let obj: iobJS.StateObject = getObject(originalDatenpunkt);
                    Bekomme diesen Fehler:
                    javascript.1 (486) script.js.common.Berechnungen.Test_Statistics: TypeScript compilation failed: let obj: iobJS.StateObject = getObject(originalDatenpunkt); ^ ERROR: Type '{ common: { [x: string]: any; [x: number]: any; }; type: "state" | "channel" | "folder" | "device"; acl: { object: number; state: number; owner: string; ownerGroup: string; }; _id: string; native: { [x: string]: any; }; enums: { ...; }; from: string; user: string; ts: number; }' is not assignable to type 'StateObject'. Types of property 'type' are incompatible. Type '"state" | "channel" | "folder" | "device"' is not assignable to type '"state"'. Type '"channel"' is not assignable to type '"state"'.
                    D.h. "obj" wird schon im Editor angemeckert:
                    • U uwe72
                      Ich habe es nun so:
                      OliverIOO Offline
                      OliverIOO Offline
                      OliverIO
                      @uwe72
                      Und was steht im iobroker was für ein Typ das Objekt ist?
                      Links im Profil
                        @uwe72
                        U Offline
                        U Offline
                        uwe72
                        @oliverio
                        Da steht das gleiche wie oben als Text gepostet:
                        • OliverIOO Offline
                          OliverIOO Offline
                          OliverIO
                          @uwe72
                          ich denke das in der Ansicht des Objektbaums bei Typ
                          channel dran steht.
                          Auf Typ channel kannst du kein typ state setzen., da channel kein attribut common.custom besitzt
                          oder es ist umgekehrt, das kann ich nicht so richtig rauslesen
                          warum willst du unbedingt in custom was reinschreiben? ganz davon abgesehen, das es schon gehen muss, aber wenn du eine objektstruktur in einem datenpunkt ablegen willst, dann würde ich einfach mit
                          getState und setState arbeiten und das Objekt dort einfach mit JSON.stringify und JSON.parse schreiben und lesen.
                          und was mir noch aufgefallen ist:
                          statistics.0 ist kein eigener datenpunkt
                          das erste richtige objekt in der hierarchie ist
                          statistics.0.save und
                          statistics.0.temp
                          statistics.0 sieht zwar so aus, existiert für sich aber nicht als eigenständiges objekt
                          dies ist erkennbar, das im objektbaum bei typ nix dran steht.
                          Links im Profil
                          U haus-automatisierungH 2 Antworten Letzte Antwort
                            @uwe72
                            channel dran steht.
                            statistics.0.temp
                            U Offline
                            U Offline
                            uwe72
                            @oliverio Ich möchte ja programmatisch für einen Datenpunkt den Statistic-Adapter aktivieren.
                            Habe ein Array mit allen Devices (ca. 200-250). So kann ich generisch wie gesagt für alle Devices den StatisticAdapter aktivieren.
                              U Offline
                              U Offline
                              uwe72
                              @alcalzone Siehe zuvor. Hättest Du mir noch einen Tipp? Grüße aus Brasilien. Uwe
                                @uwe72
                                channel dran steht.
                                statistics.0.temp
                                @oliverio sagte in TypeScript Kompilierfehler setObject:
                                Das ist normal und auch richtig so. Bei einigen Adaptern wird das als Objekt für den File-Meta-Storage angelegt (z.B. vis). Aber das ist ganz selten und hat mit dem Problem nichts zu tun.
                                • U uwe72
                                  AlCalzoneA Offline
                                  AlCalzoneA Offline
                                  AlCalzone
                                  @uwe72 Ok dann anders:
                                  let obj = getObject(originalDatenpunkt) as iobJS.StateObject;
                                  Der Unterschied zur vorherigen Variante ist dass du TS jetzt sagst: "Ich bin mir sicher, das ist ein StateObject". Das andere hat bedeutet: "obj ist ein State, lese mir da das Objekt xyz rein" (was nicht garantiert ein StateObject ist)
                                    U Offline
                                    U Offline
                                    uwe72
                                    @alcalzone Perfekt, danke dir! Bin wirklich sehr dankbar nun eine funktionierende programmatische Lösung zu haben (für das "Aktivieren" vom Statistikadapter, o.ä.) Hat nun funktioniert:
                                    let obj = getObject(objId) as iobJS.StateObject;
                                      "enabled": true,
                                      "count": false,
                                      "sumCount": false,
                                      "timeCount": true,
                                      "fiveMin": false,
                                      "impUnit": "",
                                      "avg": false,
                                      "minmax": false,
                                      "sumDelta": false,
                                      "groupFactor": 1,
                                      U Offline
                                      U Offline
                                      uwe72
                                      Bitte diesen Kommentar löschen, habe ein neues Ticket aufgemacht:
                                      https://forum.iobroker.net/topic/57367/typescript-zugriff-iobjs-stateobject-innerhalb-foreach
