  4. esphome - ERROR: Process exited with code 25
162 Beiträge 12 Kommentatoren 29.4k Aufrufe 5 Beobachtet
    @le-r-kelly
    Mit welchen Meldungen?
    LE-R.Kelly
    @thomas-braun sagte in esphome - ERROR: Process exited with code 25:
    @le-r-kelly
    $ iobroker add esphome auto --host raspberrypi
    NPM version: 6.14.16
    Installing iobroker.esphome@0.2.4... (System call)
    > iobroker.esphome@0.2.4 install /opt/iobroker/node_modules/iobroker.esphome> npip install
    No python_modules directory; installing pip locally if needed.
    Successfully completed pip check.
    Collecting esphome>=2021.8
    Using cached esphome-2022.2.6-py2.py3-none-any.whl (2.1 MB)
    Collecting tornado>=3.2
    Using cached tornado-6.1.tar.gz (497 kB)
    Preparing metadata (setup.py): started
    Preparing metadata (setup.py): finished with status 'done'
    Collecting platformio==5.2.5
    Using cached platformio-5.2.5.tar.gz (218 kB)
    Collecting aioesphomeapi==10.8.2
    Using cached aioesphomeapi-10.8.2-py2.py3-none-any.whl (49 kB)
    Collecting voluptuous==0.12.2
    Using cached voluptuous-0.12.2.tar.gz (48 kB)
    Collecting kconfiglib==13.7.1
    Using cached kconfiglib-13.7.1-py2.py3-none-any.whl (145 kB)
    Collecting esptool==3.2
    Using cached esptool-3.2.tar.gz (206 kB)
    Collecting tzdata>=2021.1
    Using cached tzdata-2022.1-py2.py3-none-any.whl (339 kB)
    Collecting click==8.0.3
    Using cached click-8.0.3-py3-none-any.whl (97 kB)
    Collecting paho-mqtt==1.6.1
    Using cached paho-mqtt-1.6.1.tar.gz (99 kB)
    Collecting esphome-dashboard==20220209.0
    Using cached esphome_dashboard-20220209.0-py3-none-any.whl (592 kB)
    Collecting tzlocal==4.1
    Using cached tzlocal-4.1-py3-none-any.whl (19 kB)
    Collecting colorama==0.4.4
    Using cached colorama-0.4.4-py2.py3-none-any.whl (16 kB)
    Collecting zeroconf==0.38.3
    Using cached zeroconf-0.38.3-py3-none-any.whl (106 kB)
    Collecting PyYAML==6.0
    Using cached PyYAML-6.0.tar.gz (124 kB)
    Installing build dependencies: started
    Installing build dependencies: finished with status 'done'
    Getting requirements to build wheel: started
    Getting requirements to build wheel: finished with status 'done'
    Preparing metadata (pyproject.toml): started
    Preparing metadata (pyproject.toml): finished with status 'done'
    Collecting pyserial==3.5
    Using cached pyserial-3.5-py2.py3-none-any.whl (90 kB)
    Collecting noiseprotocol<1.0,>=0.3.1
    Using cached noiseprotocol-0.3.1-py3-none-any.whl (20 kB)
    Collecting protobuf<4.0,>=3.12.2
    Using cached protobuf-3.20.0-py2.py3-none-any.whl (162 kB)
    Collecting importlib-metadata
    Using cached importlib_metadata-4.11.3-py3-none-any.whl (18 kB)
    Collecting bitstring>=3.1.6
    Using cached bitstring-3.1.9-py3-none-any.whl (38 kB)
    Collecting cryptography>=2.1.4
    Using cached cryptography-36.0.2.tar.gz (572 kB)
    Installing build dependencies: finished with status 'error'
    host.raspberrypi Cannot install iobroker.esphome@0.2.4: 1
    • L LE-R.Kelly
      @le-r-kelly
      Wenn ich das bei meiner Netzrecherche richtig verstanden habe ist Python = Python2 und auf einem Raspbian der Standard. Python3 ist zwar drauf, aber wird standardmäßig nicht verwendet, oder?
      Da die Version von Python3 genügt, reicht es diese zum Standard zu machen? Ich habe dazu diese Seite gefunden: https://raspberrytips.com/install-latest-python-raspberry-pi/ unter "Make Python 3 the Default Version on Raspberry Pi OS"
      haus-automatisierungH Offline
      @le-r-kelly sagte in esphome - ERROR: Process exited with code 25:
      Nicht unbedingt. Auf einer frischen Bullseye Installation ist python 3 installiert und der Befehl python führt dann auch python3 aus:
      python --version
      Python 3.9.2
      Das Problem ist, dass der ioBroker installer aktuell python-dev installiert.
      Das wiederum installiert python, was auf stable (aktuell bullseye) dazu führt, dass python-is-python2 installiert wird.
      Also hat man danach einen Symlink von python auf python2, obwohl vorher alles gut war:
      python --version
      Python 2.7.18
      Zu dem Thema habe ich gerade auch einen Issue geöffnet:
      https://github.com/ioBroker/ioBroker/issues/383
      (heute getestet mit Raspbian Lite OS 64-Bit)
      📚 Meine Dokumentation
      S HomoranH 2 Antworten Letzte Antwort
        python --version
        Python 3.9.2
        python --version
        Python 2.7.18
        Sushibomba
        @haus-automatisierung
        Verstehe ich noch nicht so ganz. Bei mir schlägt die Installation von ESP Home auch fehl.
        Was muss ich denn jetzt tun um ESP Home installieren zu können? :-S
          python --version
          Python 3.9.2
          python --version
          Python 2.7.18
          HomoranH Offline
          HomoranH Offline
          @haus-automatisierung sagte in esphome - ERROR: Process exited with code 25:
          Nicht unbedingt.
          das wird eine ältere Information gewesen sein. Bei Aufkommen von python3 wurde noch von sehr vielen Programmen python2 benutzt, resp. waren diese nicht python3 kompatibel.
          Deswegen blieb der Aufruf python für python2 bestehen und python3 musste explizit so aufgerufen werden.
          Mittlerweile sieht dies anders aus.
          • S Sushibomba
            HomoranH Offline
            HomoranH Offline
            @sushibomba mach es mal in der konsole mit zusätzlichem --debug und poste den Output in code-tags
            • S Sushibomba
              @sushibomba
              sudo apt update
              sudo apt install python-is-python3 python-dev-is-python3
              S 2 Antworten Letzte Antwort
                Sushibomba
                schrieb am zuletzt editiert von Sushibomba
                @Homoran Soll ich das erst mal probieren was @Thomas-braun vorgeschlagen hat?
                  @sushibomba
                  sudo apt update
                  Sushibomba
                  Also das machen und danach nochmal versuchen über die Beta Repo zu installieren?
                  • S Sushibomba
                    @sushibomba python kannst du wie oben geschrieben sauber installieren.
                    Von Beta würde ich ohne triftigen Grund die Finger lassen. Versuch erstmal mit der stable Version dein Glück.
                    Die mit --debug-Option installieren.
                      FredFF Offline
                      FredFF Offline
                      FredF
                      Most Active Forum Testing
                      Den ESPHome Adapter gibt es nur als beta
                      2021.02.27
                      github:	0.2.4
                      latest:	0.2.4 for 11 months
                      stable:	-.-.-
                        @sushibomba
                        sudo apt update
                        Sushibomba
                        sudo apt install python-is-python3 python-dev-is-python3                  Reading package lists... Done
                        The following packages were automatically installed and are no longer required:
                          libpython2-dev libpython2.7 libpython2.7-dev python2-dev python2.7-dev
                        Use 'sudo apt autoremove' to remove them.
                        The following additional packages will be installed:
                          libpython3-dev libpython3.9-dev python3-dev python3.9-dev
                        The following packages will be REMOVED:
                          python-dev-is-python2 python-is-python2
                        The following NEW packages will be installed:
                          libpython3-dev libpython3.9-dev python-dev-is-python3 python-is-python3 python3-dev
                          python3.9-dev
                        0 upgraded, 6 newly installed, 2 to remove and 90 not upgraded.
                        Need to get 3,606 kB of archives.
                        After this operation, 14.7 MB of additional disk space will be used.
                        Do you want to continue? [Y/n]
                        Soll ich die Installation durchführen?
                        • S Sushibomba
                            python3.9-dev
                          @sushibomba
                          Ja.
                            @sushibomba
                            Ja.
                            Sushibomba
                            Ok hab ich. Muss ich danach noch irgendwelche Befehle ausführen um alte Dateien zu löschen oder so? Und sollte ich den Pi dann noch neustarten?
                            • S Sushibomba
                              @sushibomba
                              Aber lös den Update-Stau mal endlich auf:
                              iobroker stop
                              sudo apt update
                              sudo apt full-upgrade
                              sudo apt autoremove
                              sudo reboot
                                @sushibomba
                                iobroker stop
                                sudo apt update
                                sudo apt autoremove
                                sudo reboot
                                Sushibomba
                                sudo reboot
                                Hab ich gemacht.
                                Jetzt habe ich ein Problem dadurch in Grafana :(
                                InfluxDB plugin failed
                                ChunkLoadError: Loading chunk 5783 failed. (error: http://192.xxx.xxx.xx:3000/public/build/influxdbPlugin.94c35fd39f967eb67896.js)
                                • S Sushibomba
                                  sudo reboot
                                  Hab ich gemacht.
                                  @sushibomba sagte in esphome - ERROR: Process exited with code 25:
                                  Nein, nicht dadurch.
                                    Sushibomba
                                    Ok. Das heißt?
                                    Also wie bekomme ich es jetzt wieder zum laufen?
                                    InfluxDB nochmal neu starten?
                                    • S Sushibomba
                                      Ok. Das heißt?
                                      Welche influx wie installiert?
                                        Sushibomba
                                        Schon ne Zeit her und so firm bin ich mit dem ganzen leider nicht.
                                        Wie schaue ich das nochmal nach?
                                        Habe das damals nach einem youtube Video gemacht.
                                        • S Sushibomba
                                          HomoranH Offline
                                          HomoranH Offline
                                          dann mach einen neuen Thread auf mit vernünftigem Titel
