  4. [Synology Docker]Iobroker startet nicht (no database)
130 Beiträge 11 Kommentatoren 22.7k Aufrufe 9 Beobachtet
  • GlasfaserG Glasfaser
    @simka
    iobroker status
    iobroker list instances
    SimKa
    @glasfaser said in [Synology Docker]Iobroker startet nicht (no database):
    root@iobroker-default:/opt/iobroker# iobroker status
    iobroker is not running on this host.
    Objects type: jsonl
    States  type: jsonl
    root@iobroker-default:/opt/iobroker# iobroker list instances
      system.adapter.admin.0                  : admin                 : iobroker-default                         -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
      system.adapter.backitup.0               : backitup              : iobroker-default                         -  enabled
      system.adapter.daswetter.0              : daswetter             : iobroker-default                         - disabled
      system.adapter.discovery.0              : discovery             : iobroker-default                         - disabled
      system.adapter.hm-rpc.0                 : hm-rpc                : iobroker-default                         - disabled, port: 42101
      system.adapter.hm-rpc.1                 : hm-rpc                : iobroker-default                         - disabled, port: 42102
      system.adapter.ical.0                   : ical                  : iobroker-default                         - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker-default                         - disabled
      system.adapter.slideshow.0              : slideshow             : iobroker-default                         - disabled
      system.adapter.slideshow.1              : slideshow             : iobroker-default                         - disabled
      system.adapter.slideshow.2              : slideshow             : iobroker-default                         - disabled
      system.adapter.synology.0               : synology              : iobroker-default                         - disabled, port: 5001
      system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker-default                         - disabled
      system.adapter.trashschedule.0          : trashschedule         : iobroker-default                         - disabled
      system.adapter.vis-bars.0               : vis-bars              : iobroker-default                         - disabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker-default                         - disabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker-default                         - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker-default                         - disabled
      system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker-default                         - disabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker-default                         - disabled
      system.adapter.vis-justgage.0           : vis-justgage          : iobroker-default                         - disabled
      system.adapter.vis-keyboard.0           : vis-keyboard          : iobroker-default                         - disabled
      system.adapter.vis-players.0            : vis-players           : iobroker-default                         - disabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker-default                         - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker-default                         - disabled
      system.adapter.vis-weather.0            : vis-weather           : iobroker-default                         - disabled
      system.adapter.vis.0                    : vis                   : iobroker-default                         - disabled
      system.adapter.web.0                    : web                   : iobroker-default                         - disabled, port: 8082, bind: 0.0.0.0, run as: admin
    + instance is alive
    iobroker-default (1).html
      @simka sagte in [Synology Docker]Iobroker startet nicht (no database):
      v16.15.1
      War das schon im Container oder hast du ein Update von 14 auf 16 gemacht !?
      Ich hab nur den Container erstellt, den Ordner gemountet und gestartet. Während der Container startete, sind einige Sachen installiert worden. Manuell habe ich nichts installiert.
      Das ist irgendwie verwirrend bei dir
      , denn der Container den du hast
      ist das :
      Image : v6.1.0
      mit :
      npm: 6.14.16
      node: v14.19.0
      und im ganzen Verlauf .... schreibst du , du hast nichts gemacht ,
      bist trotzdem
      " Iobroker startet nicht (no database) "
      mich hat es leider auch getroffen. Iobroker lässt sich nicht mehr starten.
      und hast ganz oben im Start-Thread wie ich schon mehere male erwähnt und auch nachgefragt Node in
      v16.15.1
      8.11.0
      , also das aktuelle.
      Von alleine geht das nicht !!
      SimKa
      v16.15.1
      ist das :
      Image : v6.1.0
      mit :
      npm: 6.14.16
      node: v14.19.0
      bist trotzdem
      v16.15.1
      8.11.0
      Da habe ich mich wohl falsch ausgedrückt. Entschuldige für die Verwirrung.
      Ich habe bereits nach dem Problem gegoogelt und auch hier im Forum danach gesucht. Ich habe am Anfang den iobroker fix und den curl Befehl mit dem fix ausgeführt, paar mal neu gestartet, dann den js-controller installiert usw. Da alles nichts geholfen hat, habe ich eine neue Instanz erstellt und dort das Backup eingespielt und wieder paar Sachen versucht, z.B. zu updaten usw.
      Als ich geschrieben habe, dass ich nichts gemacht habe, meinte ich damit, dass ich eine neue Instanz erstellt habe und nicht an dieser Instanz gemacht habe, z.B. habe ich kein Update des Dockers oder von iobroker durchgeführt.
      • S SimKa
        Objects type: jsonl
        States  type: jsonl
        + instance is alive
        GlasfaserG Offline
        GlasfaserG Offline
        @simka
        ist das richtig , verschlüsselt !?
        iobroker start
        iobroker logs --watch
          @simka
          iobroker start
          SimKa
          Was meinst du mit richtig verschlüsselt? Ich habe Https/SSL damals beim Einrichten angehakt
          root@iobroker-default:/opt/iobroker# iobroker start
          Starting iobroker controller daemon...
          iobroker controller daemon started. PID: 16246
          root@iobroker-default:/opt/iobroker# iobroker logs --watch
          2022-07-05 09:17:00.349  - info: host.iobroker-default iobroker.js-controller version 4.0.21 js-controller starting
          2022-07-05 09:17:00.363  - info: host.iobroker-default Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
          2022-07-05 09:17:00.364  - info: host.iobroker-default hostname: iobroker-default, node: v14.19.3
          2022-07-05 09:17:00.365  - info: host.iobroker-default ip addresses: 172.17.0.2
          Failed to set capabilities on file `/usr/bin/node' (Operation not supported)
          The value of the capability argument is not permitted for a file. Or the file is not a regular (non-symlink) file
          2022-07-05 09:17:01.176  - info: host.iobroker-default added notifications configuration of host
          2022-07-05 09:17:01.646  - info: host.iobroker-default 3 instances found
          2022-07-05 09:17:01.769  - info: host.iobroker-default instance system.adapter.admin.0 started with pid 1866
          2022-07-05 09:17:01.669  - info: host.iobroker-default starting 3 instances
          2022-07-05 09:17:05.179  - info: admin.0 (1866) received all objects
          2022-07-05 09:17:05.230  - info: admin.0 (1866) Request actual repository...
          2022-07-05 09:17:05.259  - info: host.iobroker-default Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
          2022-07-05 09:17:01.002  - info: host.iobroker-default connected to Objects and States
          2022-07-05 09:17:01.049  - info: host.iobroker-default Node.js version has changed from unknown to 14.19.3
          2022-07-05 09:17:01.157  - warn: host.iobroker-default Error while trying to update capabilities after detecting new Node.js version: Command failed: sudo setcap cap_net_bind_service,cap_net_raw+e
          pi /usr/bin/node
          2022-07-05 09:17:02.109  - info: host.iobroker-default Created UUID: 36ffb7ca-2961-47dd-a566-a29dbe05f8ea
          2022-07-05 09:17:04.901  - info: admin.0 (1866) starting. Version 5.3.1 in /opt/iobroker/node_modules/iobroker.admin, node: v14.19.3, js-controller: 4.0.21
          2022-07-05 09:17:05.010  - info: admin.0 (1866) requesting all states
          2022-07-05 09:17:05.012  - info: admin.0 (1866) requesting all objects
          2022-07-05 09:17:05.277  - info: admin.0 (1866) http server listening on port 8081
          2022-07-05 09:17:05.279  - info: admin.0 (1866) Use link "http://localhost:8081" to configure.
          2022-07-05 09:17:05.541  - warn: admin.0 (1866) Repository cannot be read: Active repo - stable
          2022-07-05 09:17:05.543  - warn: admin.0 (1866) Active repository "stable cannot be read
          2022-07-05 09:17:05.778  - info: host.iobroker-default instance system.adapter.discovery.0 started with pid 1894
          2022-07-05 09:17:09.224  - info: admin.0 (1866) Repository received successfully.
          2022-07-05 09:17:09.639  - info: discovery.0 (1894) starting. Version 2.7.5 in /opt/iobroker/node_modules/iobroker.discovery, node: v14.19.3, js-controller: 4.0.21
          2022-07-05 09:17:09.761  - info: host.iobroker-default instance system.adapter.backitup.0 started with pid 1909
          2022-07-05 09:17:12.916  - info: backitup.0 (1909) starting. Version 2.3.3 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.19.3, js-controller: 4.0.21
          2022-07-05 09:17:13.036  - info: backitup.0 (1909) [iobroker] backup was activated at 02:40 every 1 day(s)
          2022-07-05 09:19:45.668  - info: admin.0 (1866) terminating http server on port 8081
          2022-07-05 09:19:45.670  - info: backitup.0 (1909) cleaned everything up...
          2022-07-05 09:19:45.663  - info: host.iobroker-default received SIGTERM
          2022-07-05 09:19:45.693  - info: host.iobroker-default stopInstance system.adapter.admin.0 (force=false, process=true)
          2022-07-05 09:19:45.695  - info: host.iobroker-default stopInstance system.adapter.discovery.0 (force=false, process=true)
          2022-07-05 09:19:45.697  - info: host.iobroker-default stopInstance system.adapter.backitup.0 (force=false, process=true)
          2022-07-05 09:19:45.740  - info: admin.0 (1866) Got terminate signal TERMINATE_YOURSELF
          2022-07-05 09:19:45.744  - info: discovery.0 (1894) Got terminate signal TERMINATE_YOURSELF
          2022-07-05 09:19:45.747  - info: backitup.0 (1909) Got terminate signal TERMINATE_YOURSELF
          2022-07-05 09:19:45.761  - info: discovery.0 (1894) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
          2022-07-05 09:19:45.762  - info: host.iobroker-default stopInstance system.adapter.admin.0 send kill signal
          2022-07-05 09:19:45.767  - info: admin.0 (1866) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
          2022-07-05 09:19:45.770  - info: host.iobroker-default stopInstance system.adapter.discovery.0 send kill signal
          2022-07-05 09:19:45.772  - info: host.iobroker-default stopInstance system.adapter.backitup.0 send kill signal
          2022-07-05 09:19:45.803  - info: backitup.0 (1909) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
          2022-07-05 09:19:46.367  - info: host.iobroker-default instance system.adapter.discovery.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
          2022-07-05 09:19:46.412  - info: host.iobroker-default instance system.adapter.admin.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
          2022-07-05 09:19:46.434  - info: host.iobroker-default instance system.adapter.backitup.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
          2022-07-05 09:19:46.435  - info: host.iobroker-default All instances are stopped.
          2022-07-05 09:19:46.560  - info: host.iobroker-default terminated
          2022-07-05 14:05:38.950  - info: host.iobroker iobroker.js-controller version 4.0.21 js-controller starting
          2022-07-05 14:05:38.971  - info: host.iobroker Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
          2022-07-05 14:05:38.973  - info: host.iobroker hostname: iobroker, node: v14.19.3
          2022-07-05 14:05:38.974  - info: host.iobroker ip addresses: 172.17.0.2
          2022-07-05 14:05:40.838  - info: host.iobroker connected to Objects and States
          2022-07-05 14:05:40.907  - info: host.iobroker Node.js version has changed from unknown to 14.19.3
          2022-07-05 14:05:40.938  - info: host.iobroker added notifications configuration of host
          2022-07-05 14:05:41.613  - warn: host.iobroker Error while trying to update capabilities after detecting new Node.js version: Command failed: sudo setcap cap_net_bind_service,cap_net_raw+epi /usr/
          bin/node
          2022-07-05 14:05:41.778  - info: host.iobroker Delete host system.host.iobroker-default
          2022-07-05 14:05:41.970  - info: host.iobroker 28 instances found
          2022-07-05 14:05:41.999  - warn: host.iobroker does not start any instances on this host
          • S SimKa
            pi /usr/bin/node
            bin/node
            GlasfaserG Offline
            GlasfaserG Offline
            backups/iobroker_2022_05_07-02_40_10_backupiobroker.tar.gz
            hast du kein älteres Backup !?
            Hast du bei den neu erstellten Containern auch die Ports durchgereicht !?
            • andreA Offline
              andreA Offline
              andre
              @glasfaser sagte in [Synology Docker]Iobroker startet nicht (no database):
              Generell wäre mal das Setup interessant. Nutzt du das Bridge Netzwerk?
              Ich glaube das Backup ist schon ok. Aber es gibt offenbar Probleme beim Setzen der capabilities.
              bin/node
              MfG,
              André
                SimKa
                Ja 8081 Port ist durch gemappt. Der Wizard ist erreichbar, nachdem der Docker zum ersten Mal gestartet wurde.
                Was ist mit capabilities gemeint?
                • andreA andre
                  bin/node
                  MfG,
                  André
                  SimKa
                  @andre said in [Synology Docker]Iobroker startet nicht (no database):
                  bin/node
                  MfG,
                  André
                  2022-07-05 15_14_31-Window.png 2022-07-05 15_14_52-Window.png 2022-07-05 15_15_13-Window.png 2022-07-05 15_15_32-Window.png
                  Die Fenster, die ich nich fotografiert habe, bei denen ist nichts eingestellt.
                  • andreA Offline
                    andreA Offline
                    andre
                    Was bekommst du hier:
                    getcap $(eval readlink -f `which node`)
                    MfG,
                    André
                    • andreA andre
                      MfG,
                      André
                      SimKa
                      getcap $(eval readlink -f which node)
                      root@iobroker-default:/opt/iobroker# getcap $(eval readlink -f `which node`)
                      Failed to get capabilities of file '/usr/bin/node' (Operation not supported)
                      andreA 1 Antwort Letzte Antwort
                      • S SimKa
                        andreA Offline
                        andreA Offline
                        andre
                        schrieb am zuletzt editiert von andre
                        @simka Das ist das Problem. So sollte es aussehen:
                        Wenn ich das Google, dann lande ich mehr oder weniger immer bei Problemen mit dem Filesystem...
                        Welche DSM Version hast du?
                        [EDIT] Hatte dazu sogar mal einen Issue (https://github.com/buanet/ioBroker.docker/issues/37) Aber leider ohne Lösung...
                        • andreA andre
                          SimKa
                          Hmm schade. Wundert mich, dass erst nach dem Update die Probleme auftreten.
                          • S SimKa
                            GlasfaserG Offline
                            GlasfaserG Offline
                            @simka
                            mach da mal einen Haken rein .
                            • S SimKa
                              GlasfaserG Offline
                              GlasfaserG Offline
                              @simka
                              Nur eine Idee
                              pkill -u iobroker
                              iobroker fix
                              sudo setcap cap_net_bind_service,cap_net_raw+epi /usr/bin/node
                              Container neu starten
                                @simka
                                Nur eine Idee
                                pkill -u iobroker
                                iobroker fix
                                SimKa
                                @simka
                                Nur eine Idee
                                pkill -u iobroker
                                iobroker fix
                                    Installing prerequisites (1/3)
                                Get:1 http://deb.debian.org/debian bullseye InRelease [116 kB]
                                Get:2 http://security.debian.org/debian-security bullseye-security InRelease [44,1 kB]
                                Get:3 http://deb.debian.org/debian bullseye-updates InRelease [39,4 kB]
                                Get:4 https://deb.nodesource.com/node_14.x bullseye InRelease [4.586 B]
                                Get:5 http://deb.debian.org/debian bullseye/main amd64 Packages [8.182 kB]
                                Get:6 http://security.debian.org/debian-security bullseye-security/main amd64 Packages [164 kB]
                                Get:7 https://deb.nodesource.com/node_14.x bullseye/main amd64 Packages [774 B]
                                Get:8 http://deb.debian.org/debian bullseye-updates/main amd64 Packages [2.592 B]
                                Fetched 8.553 kB in 8s (1.115 kB/s)
                                Reading package lists... Done
                                Installed gcc-c++
                                    Checking ioBroker user and directory permissions (2/3)
                                This system does not support setting default permissions.
                                Do not use npm to manually install adapters unless you know what you are doing!
                                    Checking autostart (3/3)
                                Unsupported init system, cannot enable autostart!
                                    Your installation was fixed successfully
                                    Run iobroker start to start ioBroker again!
                                root@iobroker-default:/opt/iobroker# sudo setcap cap_net_bind_service,cap_net_raw+epi /usr/bin/node
                                iobroker.2022-07-05 (1).log
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  @simka
                                  Was war jetzt hiermit ,
                                  denn .... wenn du iobroker neu installierst ist ja alles OK , nur bei einem Backup einspielen ist es so.
                                  S andreA 2 Antworten Letzte Antwort
                                    @simka
                                    SimKa
                                    #66
                                    @simka
                                    Habe eine neue Instanz gestartet und es mit einem anderen Backup versucht, gleiches Problem :-/
                                    iobroker.2022-07-05 (2).log
                                    • S SimKa
                                      @simka
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      #67
                                      @simka
                                      Bitte nicht immer den gleichen nutzen , auch eine anderen Mount Ordner nutzen !!!
                                      Hast du viele Container laufen , wenn nein dann:
                                      Docker ( Paket ) von Syn deinstallieren und neu installieren .
                                      • S SimKa
                                        @simka
                                        GlasfaserG Offline
                                        GlasfaserG Offline
                                        #68
                                        Was heißt das bei dir ...
                                        Eine Instanz ist im ioBroker !?
                                          @simka
                                          andreA Offline
                                          andreA Offline
                                          andre
                                          #69
                                          Sicher dass es so ist? Bitte mal nen ioBroker Container ohne Restore testen und den getcap Befehl ausführen.
                                          Ich würde nämlich tippen, dass das Problem grundsätzlich da ist. Ohne Restore wird nur eben nix an den capabilities gedreht. Das macht der ioBroker ja nur weil der js-controller nach dem Restore dies erkennt und korrigieren will:
                                          MfG,
                                          André
