Error 25 bei Adapterupdates nach Node.JS 16.15.1 Update
Auch hier an dieser Stelle ein grosses Danke. Nun scheint es ja erst einmal wieder zu funktionieren.
VG Mathias
pi@raspberrypi:/opt/iobroker $ iobroker update -i Used repository: Stable (default) Adapter "accuweather" : 1.2.1 , installed 1.2.4 Adapter "admin" : 5.3.8 , installed 5.4.9 Adapter "alexa2" : 3.11.2 , installed 3.12.0 Adapter "backitup" : 2.4.9 , installed 2.4.9 Adapter "birthdays" : 2.0.0 , installed 2.1.0 Adapter "ble" : 0.12.0 , installed 0.13.0 Adapter "cloud" : 4.1.1 , installed 4.1.1 Adapter "daswetter" : 3.1.2 , installed 3.1.3 Adapter "devices" : 1.0.12 , installed 1.0.12 Adapter "discovery" : 3.0.3 , installed 3.0.5 Adapter "dwd" : 2.8.3 , installed 2.8.3 Adapter "fahrplan" : 1.2.0 , installed 1.2.0 Adapter "fb-checkpresence": 1.1.14, installed 1.1.17 Adapter "feiertage" : 1.1.0 , installed 1.1.0 Adapter "flot" : 1.11.0 , installed 1.11.0 Adapter "fritzbox" : 0.2.1 , installed 0.5.0 Adapter "habpanel" : 0.5.0 , installed 0.5.0 Adapter "history" : 1.11.1 , installed 2.1.4 Adapter "hm-rega" : 3.0.40 , installed 3.0.40 Adapter "hm-rpc" : 1.15.12 , installed 1.15.12 Adapter "ical" : 1.12.1 , installed 1.13.0 Adapter "icons-addictive-flavour-png": 0.1.0, installed 0.1.0 Adapter "icons-fatcow-hosting": 0.1.0, installed 0.1.0 Adapter "icons-icons8" : 0.0.1 , installed 0.0.1 Adapter "icons-material-svg": 0.1.0, installed 0.1.0 Adapter "icons-mfd-png": 1.1.0 , installed 1.1.0 Adapter "icons-mfd-svg": 1.1.0 , installed 1.1.0 Adapter "icons-open-icon-library-png": 0.1.2, installed 0.1.3 Adapter "info" : 1.9.19 , installed 1.9.19 Adapter "iot" : 1.11.4 , installed 1.11.7 Adapter "iqontrol" : 2.0.0 , installed 2.0.1 Adapter "javascript" : 5.7.0 , installed 5.7.0 Controller "js-controller": 4.0.23 , installed 4.0.23 Adapter "lovelace" : 2.2.0 , installed 2.0.6 [Updatable] Adapter "luftdaten" : 2.2.4 , installed 2.2.4 Adapter "meteoalarm" : 2.1.3 , installed 2.1.5 Adapter "mihome" : 1.4.0 , installed 1.4.0 Adapter "mihome-vacuum": 3.4.2 , installed 3.4.2 Adapter "milight" : 0.3.6 , installed 0.3.6 Adapter "mqtt" : 3.0.6 , installed 4.0.6 Adapter "musiccast" : 0.1.5 , installed 0.2.2 Adapter "nina" : 0.0.25 , installed 0.0.25 Adapter "openweathermap": 0.2.4 , installed 0.2.5 Adapter "parser" : 1.1.7 , installed 1.1.7 Adapter "ping" : 1.5.3 , installed 1.5.3 Adapter "plex" : 0.9.1 , installed 0.9.1 Adapter "pollenflug" : 1.0.6 , installed 1.0.6 Adapter "radar2" : 2.0.3 , installed 2.0.3 Adapter "rpi2" : 1.3.2 , installed 1.3.2 Adapter "samsung" : 0.5.8 , installed 0.5.11 Adapter "sayit" : 1.12.3 , installed 1.12.6 Adapter "scenes" : 2.3.9 , installed 2.3.9 Adapter "shelly" : 5.3.2 , installed 5.3.2 Adapter "simple-api" : 2.7.0 , installed 2.7.0 Adapter "smartcontrol" : 1.2.1 , installed 1.2.1 Adapter "smartgarden" : 2.0.0 , installed 2.0.0 Adapter "snmp" : 1.0.0 , installed 1.0.0 Adapter "socketio" : 4.2.0 , installed 6.1.7 Adapter "sonoff" : 2.5.1 , installed 2.5.1 Adapter "sonos" : 2.1.7 , installed 2.2.2 Adapter "synology" : 2.1.7 , installed 2.1.8 Adapter "tankerkoenig" : 2.1.1 , installed 2.1.1 Adapter "tr-064" : 4.2.16 , installed 4.2.16 Adapter "trashschedule": 2.0.2 , installed 2.0.3 Adapter "tuya" : 3.6.15 , installed 3.6.15 Adapter "tvprogram" : 1.1.2 , installed 1.1.2 Adapter "tvspielfilm" : 2.0.4 , installed 2.0.4 Adapter "upnp" : 1.0.21 , installed 1.0.21 Adapter "uv-protect" : 0.3.4 , installed 0.3.5 Adapter "vis" : 1.4.15 , installed 1.4.15 Adapter "vis-bars" : 0.1.4 , installed 0.1.4 Adapter "vis-canvas-gauges": 0.1.5, installed 0.1.5 Adapter "vis-colorpicker": 1.2.0 , installed 1.2.0 Adapter "vis-fancyswitch": 1.1.0 , installed 1.1.0 Adapter "vis-history" : 1.0.0 , installed 1.0.0 Adapter "vis-hqwidgets": 1.2.0 , installed 1.2.0 Adapter "vis-jqui-mfd" : 1.0.12 , installed 1.0.12 Adapter "vis-map" : 1.0.4 , installed 1.0.4 Adapter "vis-material-advanced": 1.7.2, installed 1.7.2 Adapter "vis-metro" : 1.2.0 , installed 1.2.0 Adapter "vis-players" : 0.1.6 , installed 0.1.6 Adapter "vis-timeandweather": 1.1.7, installed 1.1.7 Adapter "weatherunderground": 3.4.2, installed 3.4.2 Adapter "web" : 4.3.0 , installed 5.2.3 Adapter "withings" : 0.0.7 , installed 0.0.7 Adapter "ws" : 1.3.0 , installed 2.1.2 Adapter "yamaha" : 0.5.2 , installed 0.5.3 Adapter "zigbee" : 1.7.5 , installed 1.6.18 [Updatable] -
Ich war vorher schon auf beta unterwegs. Daher die unterschiedlichen Versionen. Bin nun wieder auf stable gegangen
VG Mathias
Dann zieh die beiden Adapter noch auf den aktuellen stable Stand.
Nun scheint der Adapter installiert worden zu sein. Ich hatte den Tip thomas-braun mit der Umbennung ausgeführt. Dann mit der alten existierenden package-lick.json die Installation versucht.
pi@raspberrypi:/opt/iobroker $ iobroker upgrade smartgarden --debug This upgrade of "smartgarden" will introduce the following changes: ========================================================================== -> 2.0.0: support for new login procedure to Gardena webservice; admin5 is necessary ========================================================================== BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES! Would you like to upgrade smartgarden from @1.0.6 to @2.0.0 now? [(y)es, (n)o]: y Update smartgarden from @1.0.6 to @2.0.0 NPM version: 8.11.0 Installing iobroker.smartgarden@2.0.0... (System call) npm WARN old lockfile npm WARN old lockfile The package-lock.json file was created with an old version of npm, npm WARN old lockfile so supplemental metadata must be fetched from the registry. npm WARN old lockfile npm WARN old lockfile This is a one-time fix-up, please be patient... npm WARN old lockfile npm WARN tarball tarball data for iobroker.icons-open-icon-library-png@https://github.com/ioBroker/ioBroker.icons-open-icon-library-png/tarball/master (sha512-qGFFRFfv/uSaVT+z3v01bwdZYjfIES0YwaHNOgy+OO28NMa8/8fh2rkBKGHNeHfFPBTo3juTeH+p6ngZ6s//7w==) seems to be corrupted. Trying again. npm WARN tarball tarball data for iobroker.icons-open-icon-library-png@https://github.com/ioBroker/ioBroker.icons-open-icon-library-png/tarball/master (sha512-qGFFRFfv/uSaVT+z3v01bwdZYjfIES0YwaHNOgy+OO28NMa8/8fh2rkBKGHNeHfFPBTo3juTeH+p6ngZ6s//7w==) seems to be corrupted. Trying again. npm WARN old lockfile Error: sha512-qGFFRFfv/uSaVT+z3v01bwdZYjfIES0YwaHNOgy+OO28NMa8/8fh2rkBKGHNeHfFPBTo3juTeH+p6ngZ6s//7w== integrity checksum failed when using sha512: wanted sha512-qGFFRFfv/uSaVT+z3v01bwdZYjfIES0YwaHNOgy+OO28NMa8/8fh2rkBKGHNeHfFPBTo3juTeH+p6ngZ6s//7w== but got sha512-ZH4lj95sM6IpZEL2H1HR0hXTo6GMqbUBPbQyylgdRd6TDEdU+fgohUVGW4gPI0UnrAzqM/kx5+mozLqCVh2DCg==. (64751136 bytes) npm WARN old lockfile at IntegrityStream.[_onEnd] (/usr/lib/node_modules/npm/node_modules/ssri/lib/index.js:118:19) npm WARN old lockfile at IntegrityStream.emit (/usr/lib/node_modules/npm/node_modules/ssri/lib/index.js:88:19) npm WARN old lockfile at IntegrityStream.[maybeEmitEnd] (/usr/lib/node_modules/npm/node_modules/minipass/index.js:370:12) npm WARN old lockfile at IntegrityStream.emit (/usr/lib/node_modules/npm/node_modules/minipass/index.js:434:29) npm WARN old lockfile at IntegrityStream.emit (/usr/lib/node_modules/npm/node_modules/ssri/lib/index.js:90:18) npm WARN old lockfile at IntegrityStream.[resume] (/usr/lib/node_modules/npm/node_modules/minipass/index.js:265:12) npm WARN old lockfile at IntegrityStream.resume (/usr/lib/node_modules/npm/node_modules/minipass/index.js:269:24) npm WARN old lockfile at CachingMinipassPipeline.emit (/usr/lib/node_modules/npm/node_modules/minipass-pipeline/index.js:105:19) npm WARN old lockfile at CachingMinipassPipeline.emit (/usr/lib/node_modules/npm/node_modules/make-fetch-happen/lib/pipeline.js:37:18) npm WARN old lockfile at CachingMinipassPipeline.[resume] (/usr/lib/node_modules/npm/node_modules/minipass/index.js:259:10) npm WARN old lockfile Could not fetch metadata for iobroker.icons-open-icon-library-png@https://github.com/ioBroker/ioBroker.icons-open-icon-library-png/tarball/master Error: sha512-qGFFRFfv/uSaVT+z3v01bwdZYjfIES0YwaHNOgy+OO28NMa8/8fh2rkBKGHNeHfFPBTo3juTeH+p6ngZ6s//7w== integrity checksum failed when using sha512: wanted sha512-qGFFRFfv/uSaVT+z3v01bwdZYjfIES0YwaHNOgy+OO28NMa8/8fh2rkBKGHNeHfFPBTo3juTeH+p6ngZ6s//7w== but got sha512-ZH4lj95sM6IpZEL2H1HR0hXTo6GMqbUBPbQyylgdRd6TDEdU+fgohUVGW4gPI0UnrAzqM/kx5+mozLqCVh2DCg==. (64751136 bytes) npm WARN old lockfile at IntegrityStream.[_onEnd] (/usr/lib/node_modules/npm/node_modules/ssri/lib/index.js:118:19) npm WARN old lockfile at IntegrityStream.emit (/usr/lib/node_modules/npm/node_modules/ssri/lib/index.js:88:19) npm WARN old lockfile at IntegrityStream.[maybeEmitEnd] (/usr/lib/node_modules/npm/node_modules/minipass/index.js:370:12) npm WARN old lockfile at IntegrityStream.emit (/usr/lib/node_modules/npm/node_modules/minipass/index.js:434:29) npm WARN old lockfile at IntegrityStream.emit (/usr/lib/node_modules/npm/node_modules/ssri/lib/index.js:90:18) npm WARN old lockfile at IntegrityStream.[resume] (/usr/lib/node_modules/npm/node_modules/minipass/index.js:265:12) npm WARN old lockfile at IntegrityStream.resume (/usr/lib/node_modules/npm/node_modules/minipass/index.js:269:24) npm WARN old lockfile at CachingMinipassPipeline.emit (/usr/lib/node_modules/npm/node_modules/minipass-pipeline/index.js:105:19) npm WARN old lockfile at CachingMinipassPipeline.emit (/usr/lib/node_modules/npm/node_modules/make-fetch-happen/lib/pipeline.js:37:18) npm WARN old lockfile at CachingMinipassPipeline.[resume] (/usr/lib/node_modules/npm/node_modules/minipass/index.js:259:10) { npm WARN old lockfile code: 'EINTEGRITY', npm WARN old lockfile found: Integrity { sha512: [ [Hash] ] }, npm WARN old lockfile expected: [ npm WARN old lockfile Hash { npm WARN old lockfile source: 'sha512-qGFFRFfv/uSaVT+z3v01bwdZYjfIES0YwaHNOgy+OO28NMa8/8fh2rkBKGHNeHfFPBTo3juTeH+p6ngZ6s//7w==', npm WARN old lockfile digest: 'qGFFRFfv/uSaVT+z3v01bwdZYjfIES0YwaHNOgy+OO28NMa8/8fh2rkBKGHNeHfFPBTo3juTeH+p6ngZ6s//7w==', npm WARN old lockfile algorithm: 'sha512', npm WARN old lockfile options: [] npm WARN old lockfile } npm WARN old lockfile ], npm WARN old lockfile algorithm: 'sha512', npm WARN old lockfile sri: Integrity { sha512: [ [Hash] ] } npm WARN old lockfile } npm ERR! code ENOTEMPTY npm ERR! syscall rename npm ERR! path /opt/iobroker/node_modules/iobroker.javascript/node_modules/acorn-walk npm ERR! dest /opt/iobroker/node_modules/iobroker.javascript/node_modules/.acorn-walk-xHkEOJL1 npm ERR! errno -39 npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.javascript/node_modules/acorn-walk' -> '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.acorn-walk-xHkEOJL1' npm ERR! A complete log of this run can be found in: npm ERR! /home/iobroker/.npm/_logs/2022-06-26T16_56_31_988Z-debug-0.log host.raspberrypi Cannot install iobroker.smartgarden@2.0.0: 217Da es nicht funktionierte hatte ich die Datei package-lock.json dann umbenannt. Dann den Updateprozess noch einmal angestossen und nun ist der Adapter installiert
pi@raspberrypi:/opt/iobroker $ iobroker upgrade smartgarden --debug This upgrade of "smartgarden" will introduce the following changes: ========================================================================== -> 2.0.0: support for new login procedure to Gardena webservice; admin5 is necessary ========================================================================== BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES! Would you like to upgrade smartgarden from @1.0.6 to @2.0.0 now? [(y)es, (n)o]: y Update smartgarden from @1.0.6 to @2.0.0 NPM version: 8.11.0 Installing iobroker.smartgarden@2.0.0... (System call) npm WARN skipping integrity check for git dependency ssh://git@github.com/dahuby/iobroker.samsung_tizen.git npm WARN skipping integrity check for git dependency ssh://git@github.com/ciddi89/ioBroker.device-watcher.git added 9 packages, removed 174 packages, and changed 14 packages in 4m 104 packages are looking for funding run `npm fund` for details Update "system.adapter.smartgarden.0" upload [4] smartgarden.admin /opt/iobroker/node_modules/iobroker.smartgarden/admin/admin.d.ts admin.d.ts video/mp2t upload [3] smartgarden.admin /opt/iobroker/node_modules/iobroker.smartgarden/admin/index_m.html index_m.html text/html upload [2] smartgarden.admin /opt/iobroker/node_modules/iobroker.smartgarden/admin/jsonConfig.json jsonConfig.json application/json upload [1] smartgarden.admin /opt/iobroker/node_modules/iobroker.smartgarden/admin/smartgarden.png smartgarden.png image/png upload [0] smartgarden.admin /opt/iobroker/node_modules/iobroker.smartgarden/admin/tsconfig.json tsconfig.json application/json@nhbischo sagte in Error 25 bei Adapterupdates nach Node.JS 16.15.1 Update:
steht ja auch drin
steht ja auch drin
Hallo ,
habe auch das Error 25 Problem.
Nach iob upgrade email --debug
kamen diese LogsThis upgrade of "email" will introduce the following changes: ========================================================================== -> 1.1.3: Make sure the STARTTLS configuration field is displayed -> 1.1.2: Fix mail.ee settings -> 1.1.1: Allow to use connections to port 25 unencrypted -> 1.1.0: Adjust default settings for web.de and 1und1 and add ionos Add "Always use STARTTLS" option for custom SMTP settings ========================================================================== Would you like to upgrade email from @1.0.10 to @1.1.3 now? [(y)es, (n)o]: y Update email from @1.0.10 to @1.1.3 NPM version: 8.11.0 Installing iobroker.email@1.1.3... (System call) npm WARN old lockfile npm WARN old lockfile The package-lock.json file was created with an old version of npm, npm WARN old lockfile so supplemental metadata must be fetched from the registry. npm WARN old lockfile npm WARN old lockfile This is a one-time fix-up, please be patient... npm WARN old lockfile npm ERR! code ENOTEMPTY npm ERR! syscall rename npm ERR! path /opt/iobroker/node_modules/define-properties npm ERR! dest /opt/iobroker/node_modules/.define-properties-gzFzeOn0 npm ERR! errno -39 npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/define-properties' -> '/opt/iobroker/node_modules/.define-properties-gzFzeOn0' npm ERR! A complete log of this run can be found in: npm ERR! /home/iobroker/.npm/_logs/2022-06-28T04_51_01_894Z-debug-0.log host.IOBroker-Sted1 Cannot install iobroker.email@1.1.3: 217Danach
mv /opt/iobroker/node_modules/define-properties /opt/iobroker/node_modules/.define-properties-gzFzeOn0
und Nach iob upgrade email --debug
dann diese logsThis upgrade of "email" will introduce the following changes: ========================================================================== -> 1.1.3: Make sure the STARTTLS configuration field is displayed -> 1.1.2: Fix mail.ee settings -> 1.1.1: Allow to use connections to port 25 unencrypted -> 1.1.0: Adjust default settings for web.de and 1und1 and add ionos Add "Always use STARTTLS" option for custom SMTP settings ========================================================================== Would you like to upgrade email from @1.0.10 to @1.1.3 now? [(y)es, (n)o]: y Update email from @1.0.10 to @1.1.3 NPM version: 8.11.0 Installing iobroker.email@1.1.3... (System call) npm WARN old lockfile npm WARN old lockfile The package-lock.json file was created with an old version of npm, npm WARN old lockfile so supplemental metadata must be fetched from the registry. npm WARN old lockfile npm WARN old lockfile This is a one-time fix-up, please be patient... npm WARN old lockfile npm ERR! code ENOTEMPTY npm ERR! syscall rename npm ERR! path /opt/iobroker/node_modules/follow-redirects npm ERR! dest /opt/iobroker/node_modules/.follow-redirects-vRGWWNjd npm ERR! errno -39 npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/follow-redirects' -> '/opt/iobroker/node_modules/.follow-redirects-vRGWWNjd' npm ERR! A complete log of this run can be found in: npm ERR! /home/iobroker/.npm/_logs/2022-06-28T04_53_25_440Z-debug-0.log host.IOBroker-Sted1 Cannot install iobroker.email@1.1.3: 217Danach
mv /opt/iobroker/node_modules/follow-redirects /opt/iobroker/node_modules/.follow-redirects-vRGWWNjd
und wieder
mit folgendem lognode:internal/modules/cjs/loader:936 throw err; ^ Error: Cannot find module 'follow-redirects' Require stack: - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/adapters/http.js - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/defaults.js - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/core/transformData.js - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/core/dispatchRequest.js - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/core/Axios.js - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/axios.js - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/index.js - /opt/iobroker/node_modules/@alcalzone/pak/build/lib/package-managers/npm/index.js - /opt/iobroker/node_modules/@alcalzone/pak/build/lib/pak.js - /opt/iobroker/node_modules/@alcalzone/pak/build/index.js - /opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js - /opt/iobroker/node_modules/@iobroker/js-controller-common/index.js - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js at Function.Module._resolveFilename (node:internal/modules/cjs/loader:933:15) at Function.Module._load (node:internal/modules/cjs/loader:778:27) at Module.require (node:internal/modules/cjs/loader:1005:19) at require (node:internal/modules/cjs/helpers:102:18) at Object.<anonymous> (/opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/adapters/http.js:9:18) at Module._compile (node:internal/modules/cjs/loader:1105:14) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1159:10) at Module.load (node:internal/modules/cjs/loader:981:32) at Function.Module._load (node:internal/modules/cjs/loader:822:12) at Module.require (node:internal/modules/cjs/loader:1005:19) { code: 'MODULE_NOT_FOUND', requireStack: [ '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/adapters/http.js', '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/defaults.js', '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/core/transformData.js', '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/core/dispatchRequest.js', '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/core/Axios.js', '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/axios.js', '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/index.js', '/opt/iobroker/node_modules/@alcalzone/pak/build/lib/package-managers/npm/index.js', '/opt/iobroker/node_modules/@alcalzone/pak/build/lib/pak.js', '/opt/iobroker/node_modules/@alcalzone/pak/build/index.js', '/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js', '/opt/iobroker/node_modules/@iobroker/js-controller-common/index.js', '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js', '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'Die Instanzen der Adapter laufen, nach Neustart bleiben die im Stop.
armv7l
/usr/bin/nodejs
/usr/bin/node
/usr/bin/npm
v16.15.1
v16.15.1
8.11.0
Was lief da denn falsch.
Gruss paul -
Hallo ,
und wieder
armv7l
/usr/bin/nodejs
/usr/bin/node
/usr/bin/npm
v16.15.1
v16.15.1
8.11.0
Gruss paul@paul-honka Mach das letzte rename mal rückgängig .. du hast dasmit dem Axios eine Dep weggenommen.
Ich bin nicht sivher das das ausführen der Renames die er selbst tun will und nicht kann wirklich die Lösung ist.
Ich wäre eher dabei zu prüfen ob denn das ZIELVerzeichnis wohin er es renamen will vllt schon da ist und wenn ja dieses zu löschen.
Im letzten Fall also /opt/iobroker/node_modules/.follow-redirects-vRGWWNjd ... aber das ist jetzt bei dir irrelevant.Auch die Frage ist ob es hilt "Iob fix" vorher auszuführen
@apollon77 Habe das letzte mv wieder rückgangig gemacht und den iob fix gestartet.
Dann wieder iob upgrade email --debug
und diesmal kommt die folgende Meldung
npm ERR! path /opt/iobroker/node_modules/node-telegram-bot-api
npm ERR! dest /opt/iobroker/node_modules/.node-telegram-bot-api-1etpN2K2
npm ERR! errno -39
npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/node-telegram-bot-api' -> '/opt/iobroker/node_modules/.node-telegram-bot-api-1etpN2K2'
Telegramm???
Ich glaub ich spiel mal ein Backup ein.
Gruss paul -
npm ERR! errno -39
Telegramm???
Gruss paul@paul-honka sagte in Error 25 bei Adapterupdates nach Node.JS 16.15.1 Update:
Ich glaub ich spiel malt ein Backup ein.
Das wird dir vermutlich nichts bringen.
Wieso, Warum? Vor einer Woche konnte ich noch einige Adapter updaten?
Gruss paul -
v16.15.1
v16.15.1
8.11.0vor oder nach dem Update auf 16 !?
Zeige mal ( Ein/Ausgabe in Code-Tags setzen ) :
iobroker update -u sudo ln -s /usr/bin/node /usr/bin/nodejs uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs -
Das war auch bestimmt vor einem Upgrade auf nodejs16/npm8.
cd /opt/iobroker npm ls | grep -E 'ERR|github'liefert?
npm ERR! errno -39
Telegramm???
gibt es opt/iobroker/node_modules/.node-telegram-bot-api-1etpN2K2 denn?
@thomas-braun mal ohne code tak, ok mit
npm ls | grep -E 'ERR|github' ├── iobroker.gartenbewaesserung@0.0.8 (git+ssh://git@github.com/TA2k/ioBroker.gartenbewaesserung.git#95bf9dcd60b595c7e59e2ed87b719bf564d9ba59) ├── iobroker.mihome-airpurifier@0.1.8 (git+ssh://git@github.com/JoJ123/ioBroker.mihome-airpurifier.git#33aac153e52610c4362089bcf12ac40ed97d82f5) npm ERR! code ELSPROBLEMS npm ERR! invalid: iobroker.telegram@1.13.0 /opt/iobroker/node_modules/iobroker.telegram npm ERR! A complete log of this run can be found in: npm ERR! /home/iobroker/.npm/_logs/2022-06-28T08_15_02_392Z-debug-0.logGruss paul
mal ohne code tak
Warum?
@paul-honka
v16.15.1
v16.15.1
iobroker update -u sudo ln -s /usr/bin/node /usr/bin/nodejs uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejsiobroker update -u Used repository: Stable (default) Adapter "email" : 1.1.3 , installed 1.0.10 [Updatable] Adapter "flot" : 1.11.0 , installed 1.10.7 [Updatable] Adapter "simple-api" : 2.7.0 , installed 2.6.5 [Updatable] pi@IOBroker-Sted1:/opt/iobroker $ pi@IOBroker-Sted1:/opt/iobroker $ pi@IOBroker-Sted1:/opt/iobroker $ pi@IOBroker-Sted1:/opt/iobroker $ pi@IOBroker-Sted1:/opt/iobroker $ cd /opt/iobroker pi@IOBroker-Sted1:/opt/iobroker $ npm ls | grep -E 'ERR|github' ├── iobroker.gartenbewaesserung@0.0.8 (git+ssh://git@github.com/TA2k/ioBroker.gartenbewaesserung.git#95bf9dcd60b595c7e59e2ed87b719bf564d9ba59) ├── iobroker.mihome-airpurifier@0.1.8 (git+ssh://git@github.com/JoJ123/ioBroker.mihome-airpurifier.git#33aac153e52610c4362089bcf12ac40ed97d82f5) npm ERR! code ELSPROBLEMS npm ERR! invalid: iobroker.telegram@1.13.0 /opt/iobroker/node_modules/iobroker.telegram npm ERR! A complete log of this run can be found in: npm ERR! /home/iobroker/.npm/_logs/2022-06-28T08_15_02_392Z-debug-0.log pi@IOBroker-Sted1:/opt/iobroker $ pi@IOBroker-Sted1:/opt/iobroker $ pi@IOBroker-Sted1:/opt/iobroker $ pi@IOBroker-Sted1:/opt/iobroker $ pi@IOBroker-Sted1:/opt/iobroker $ iobroker update -u Used repository: Stable (default) Adapter "email" : 1.1.3 , installed 1.0.10 [Updatable] Adapter "flot" : 1.11.0 , installed 1.10.7 [Updatable] Adapter "simple-api" : 2.7.0 , installed 2.6.5 [Updatable] pi@IOBroker-Sted1:/opt/iobroker $ sudo ln -s /usr/bin/node /usr/bin/nodejs ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits pi@IOBroker-Sted1:/opt/iobroker $ pi@IOBroker-Sted1:/opt/iobroker $ uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs armv7l /usr/bin/nodejs /usr/bin/node /usr/bin/npm v16.15.1 v16.15.1 8.11.0 pi /opt/iobroker OK:1 http://archive.raspberrypi.org/debian buster InRelease OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease OK:3 https://deb.nodesource.com/node_16.x buster InRelease Paketlisten werden gelesen... Fertig Abhängigkeitsbaum wird aufgebaut. Statusinformationen werden eingelesen.... Fertig Alle Pakete sind aktuell. nodejs: Installiert: 16.15.1-deb-1nodesource1 Installationskandidat: 16.15.1-deb-1nodesource1 Versionstabelle: *** 16.15.1-deb-1nodesource1 500 500 https://deb.nodesource.com/node_16.x buster/main armhf Packages 100 /var/lib/dpkg/status 10.24.0~dfsg-1~deb10u1 500 500 http://raspbian.raspberrypi.org/raspbian buster/main armhf PackagesGruss paul
Bitte in Code-Tags setzten und auch nicht die Aus/Eingabe kürzen !
iobroker update -u
und wo ist der Rest .... kein Admin usw.
iobroker update -u
@glasfaser sagte in Error 25 bei Adapterupdates nach Node.JS 16.15.1 Update:
-u = Der Rest ist aktuell... :-)
