  4. Error 25 bei Adapterupdates nach Node.JS 16.15.1 Update
errormeldungnodejs 16.15.1
169 Beiträge 15 Kommentatoren 41.4k Aufrufe 12 Beobachtet
    @nhbischo sagte in Error 25 bei Adapterupdates nach Node.JS 16.15.1 Update:
    Da es nicht funktionierte
    steht ja auch drin
    npm WARN old lockfile The package-lock.json file was created with an old version of npm,
    P
    P
    paul.honka
    #107
    Hallo ,
    habe auch das Error 25 Problem.
    Nach iob upgrade email --debug
    kamen diese Logs
    This upgrade of "email" will introduce the following changes:
    -> 1.1.3:
    Make sure the STARTTLS configuration field is displayed
    -> 1.1.2:
    Fix mail.ee settings
    -> 1.1.1:
    Allow to use connections to port 25 unencrypted
    -> 1.1.0:
    Adjust default settings for web.de and 1und1 and add ionos
    Add "Always use STARTTLS" option for custom SMTP settings
    Would you like to upgrade email from @1.0.10 to @1.1.3 now? [(y)es, (n)o]: y
    Update email from @1.0.10 to @1.1.3
    NPM version: 8.11.0
    Installing iobroker.email@1.1.3... (System call)
    npm WARN old lockfile so supplemental metadata must be fetched from the registry.
    npm WARN old lockfile This is a one-time fix-up, please be patient...
    npm ERR! code ENOTEMPTY
    npm ERR! syscall rename
    npm ERR! path /opt/iobroker/node_modules/define-properties
    npm ERR! dest /opt/iobroker/node_modules/.define-properties-gzFzeOn0
    npm ERR! errno -39
    npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/define-properties' -> '/opt/iobroker/node_modules/.define-properties-gzFzeOn0'
    npm ERR!     /home/iobroker/.npm/_logs/2022-06-28T04_51_01_894Z-debug-0.log
    host.IOBroker-Sted1 Cannot install iobroker.email@1.1.3: 217
    Danach
    mv /opt/iobroker/node_modules/define-properties /opt/iobroker/node_modules/.define-properties-gzFzeOn0
    und Nach iob upgrade email --debug
    dann diese logs
    -> 1.1.3:
    -> 1.1.2:
    -> 1.1.1:
    -> 1.1.0:
    NPM version: 8.11.0
    npm ERR! path /opt/iobroker/node_modules/follow-redirects
    npm ERR! dest /opt/iobroker/node_modules/.follow-redirects-vRGWWNjd
    npm ERR! errno -39
    npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/follow-redirects' -> '/opt/iobroker/node_modules/.follow-redirects-vRGWWNjd'
    npm ERR!     /home/iobroker/.npm/_logs/2022-06-28T04_53_25_440Z-debug-0.log
    Danach
    mv /opt/iobroker/node_modules/follow-redirects /opt/iobroker/node_modules/.follow-redirects-vRGWWNjd
    und wieder
    mit folgendem log
    node:internal/modules/cjs/loader:936
      throw err;
    Error: Cannot find module 'follow-redirects'
    Require stack:
    - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/adapters/http.js
    - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/defaults.js
    - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/core/transformData.js
    - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/core/dispatchRequest.js
    - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/core/Axios.js
    - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/axios.js
    - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/index.js
    - /opt/iobroker/node_modules/@alcalzone/pak/build/lib/package-managers/npm/index.js
    - /opt/iobroker/node_modules/@alcalzone/pak/build/lib/pak.js
    - /opt/iobroker/node_modules/@alcalzone/pak/build/index.js
    - /opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js
    - /opt/iobroker/node_modules/@iobroker/js-controller-common/index.js
    - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js
    - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
        at Function.Module._resolveFilename (node:internal/modules/cjs/loader:933:15)
        at Function.Module._load (node:internal/modules/cjs/loader:778:27)
        at Module.require (node:internal/modules/cjs/loader:1005:19)
        at require (node:internal/modules/cjs/helpers:102:18)
        at Object.<anonymous> (/opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/adapters/http.js:9:18)
        at Module._compile (node:internal/modules/cjs/loader:1105:14)
        at Object.Module._extensions..js (node:internal/modules/cjs/loader:1159:10)
        at Module.load (node:internal/modules/cjs/loader:981:32)
        at Function.Module._load (node:internal/modules/cjs/loader:822:12)
        at Module.require (node:internal/modules/cjs/loader:1005:19) {
      code: 'MODULE_NOT_FOUND',
      requireStack: [
        '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/adapters/http.js',
        '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/defaults.js',
        '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/core/transformData.js',
        '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/core/dispatchRequest.js',
        '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/core/Axios.js',
        '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/axios.js',
        '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/index.js',
        '/opt/iobroker/node_modules/@alcalzone/pak/build/lib/package-managers/npm/index.js',
        '/opt/iobroker/node_modules/@alcalzone/pak/build/lib/pak.js',
        '/opt/iobroker/node_modules/@alcalzone/pak/build/index.js',
        '/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js',
        '/opt/iobroker/node_modules/@iobroker/js-controller-common/index.js',
        '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js',
        '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
    Die Instanzen der Adapter laufen, nach Neustart bleiben die im Stop.
    armv7l
    /usr/bin/nodejs
    /usr/bin/node
    /usr/bin/npm
    v16.15.1
    v16.15.1
    8.11.0
    Was lief da denn falsch.
    Gruss paul
    • P paul.honka
      Hallo ,
      kamen diese Logs
      -> 1.1.3:
      -> 1.1.2:
      -> 1.1.1:
      -> 1.1.0:
      NPM version: 8.11.0
      npm ERR! errno -39
      Danach
      dann diese logs
      -> 1.1.3:
      -> 1.1.2:
      -> 1.1.1:
      -> 1.1.0:
      NPM version: 8.11.0
      npm ERR! errno -39
      Danach
      und wieder
      mit folgendem log
        throw err;
      Require stack:
        requireStack: [
      armv7l
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      v16.15.1
      v16.15.1
      8.11.0
      Gruss paul
      apollon77A
      apollon77A
      #108
      @paul-honka Mach das letzte rename mal rückgängig .. du hast dasmit dem Axios eine Dep weggenommen.
      Ich bin nicht sivher das das ausführen der Renames die er selbst tun will und nicht kann wirklich die Lösung ist.
      Ich wäre eher dabei zu prüfen ob denn das ZIELVerzeichnis wohin er es renamen will vllt schon da ist und wenn ja dieses zu löschen.
      Im letzten Fall also /opt/iobroker/node_modules/.follow-redirects-vRGWWNjd ... aber das ist jetzt bei dir irrelevant.
      Auch die Frage ist ob es hilt "Iob fix" vorher auszuführen
      P 1 Antwort Letzte Antwort
      • apollon77A apollon77
        P
        P
        paul.honka
        schrieb am zuletzt editiert von paul.honka
        #109
        @apollon77 Habe das letzte mv wieder rückgangig gemacht und den iob fix gestartet.
        Dann wieder iob upgrade email --debug
        und diesmal kommt die folgende Meldung
        npm ERR! path /opt/iobroker/node_modules/node-telegram-bot-api
        npm ERR! dest /opt/iobroker/node_modules/.node-telegram-bot-api-1etpN2K2
        npm ERR! errno -39
        npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/node-telegram-bot-api' -> '/opt/iobroker/node_modules/.node-telegram-bot-api-1etpN2K2'
        Telegramm???
        Ich glaub ich spiel mal ein Backup ein.
        Gruss paul
        Thomas BraunT apollon77A 2 Antworten Letzte Antwort
        • P paul.honka
          npm ERR! errno -39
          Telegramm???
          Gruss paul
          Thomas BraunT
          Thomas BraunT
          Most Active Developer
          #110
          @paul-honka sagte in Error 25 bei Adapterupdates nach Node.JS 16.15.1 Update:
          Ich glaub ich spiel malt ein Backup ein.
          Das wird dir vermutlich nichts bringen.
            P
            P
            paul.honka
            #111
            Wieso, Warum? Vor einer Woche konnte ich noch einige Adapter updaten?
            Gruss paul
            GlasfaserG Thomas BraunT 2 Antworten Letzte Antwort
            • P paul.honka
              Gruss paul
              GlasfaserG
              GlasfaserG
              #112
              @paul-honka
              v16.15.1
              v16.15.1
              8.11.0
              vor oder nach dem Update auf 16 !?
              Zeige mal ( Ein/Ausgabe in Code-Tags setzen ) :
              iobroker update -u
              uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
              • P paul.honka
                Gruss paul
                Thomas BraunT
                Thomas BraunT
                #113
                Das war auch bestimmt vor einem Upgrade auf nodejs16/npm8.
                cd /opt/iobroker
                npm ls | grep -E 'ERR|github'
                liefert?
                • P paul.honka
                  npm ERR! errno -39
                  Telegramm???
                  Gruss paul
                  apollon77A
                  apollon77A
                  #114
                  gibt es opt/iobroker/node_modules/.node-telegram-bot-api-1etpN2K2 denn?
                    cd /opt/iobroker
                    liefert?
                    P
                    P
                    paul.honka
                    #115
                    @thomas-braun mal ohne code tak, ok mit
                    ├── iobroker.gartenbewaesserung@0.0.8 (git+ssh://git@github.com/TA2k/ioBroker.gartenbewaesserung.git#95bf9dcd60b595c7e59e2ed87b719bf564d9ba59)
                    ├── iobroker.mihome-airpurifier@0.1.8 (git+ssh://git@github.com/JoJ123/ioBroker.mihome-airpurifier.git#33aac153e52610c4362089bcf12ac40ed97d82f5)
                    npm ERR! code ELSPROBLEMS
                    npm ERR! invalid: iobroker.telegram@1.13.0 /opt/iobroker/node_modules/iobroker.telegram
                    npm ERR!     /home/iobroker/.npm/_logs/2022-06-28T08_15_02_392Z-debug-0.log
                    Gruss paul
                    Thomas BraunT GlasfaserG 2 Antworten Letzte Antwort
                    • P paul.honka
                      Gruss paul
                      Thomas BraunT
                      Thomas BraunT
                      #116
                      mal ohne code tak
                      Warum?
                      • GlasfaserG Glasfaser
                        @paul-honka
                        v16.15.1
                        v16.15.1
                        8.11.0
                        iobroker update -u
                        P
                        P
                        paul.honka
                        #117
                        @glasfaser
                         iobroker update -u
                        Adapter    "email"        : 1.1.3    , installed 1.0.10 [Updatable]
                        Adapter    "flot"         : 1.11.0   , installed 1.10.7 [Updatable]
                        Adapter    "simple-api"   : 2.7.0    , installed 2.6.5  [Updatable]
                        pi@IOBroker-Sted1:/opt/iobroker $
                        pi@IOBroker-Sted1:/opt/iobroker $ cd /opt/iobroker
                        pi@IOBroker-Sted1:/opt/iobroker $ npm ls | grep -E 'ERR|github'
                        pi@IOBroker-Sted1:/opt/iobroker $ iobroker update -u
                        pi@IOBroker-Sted1:/opt/iobroker $ sudo ln -s /usr/bin/node /usr/bin/nodejs
                        ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
                        pi@IOBroker-Sted1:/opt/iobroker $ uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                        armv7l
                        /usr/bin/nodejs
                        /usr/bin/node
                        /usr/bin/npm
                        v16.15.1
                        v16.15.1
                        8.11.0
                        pi
                        /opt/iobroker
                        OK:1 http://archive.raspberrypi.org/debian buster InRelease
                        OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                        OK:3 https://deb.nodesource.com/node_16.x buster InRelease
                        Alle Pakete sind aktuell.
                        nodejs:
                          Installiert:           16.15.1-deb-1nodesource1
                          Installationskandidat: 16.15.1-deb-1nodesource1
                          Versionstabelle:
                         *** 16.15.1-deb-1nodesource1 500
                                500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
                             10.24.0~dfsg-1~deb10u1 500
                        Gruss paul
                        • P paul.honka
                          Gruss paul
                          GlasfaserG
                          GlasfaserG
                          #118
                          Bitte in Code-Tags setzten und auch nicht die Aus/Eingabe kürzen !
                          • P paul.honka
                            @glasfaser
                             iobroker update -u
                            armv7l
                            /usr/bin/nodejs
                            /usr/bin/node
                            /usr/bin/npm
                            v16.15.1
                            v16.15.1
                            8.11.0
                            pi
                            /opt/iobroker
                            nodejs:
                              Versionstabelle:
                            Gruss paul
                            GlasfaserG
                            GlasfaserG
                            #119
                            iobroker update -u
                            und wo ist der Rest .... kein Admin usw.
                            Thomas BraunT P 2 Antworten Letzte Antwort
                              iobroker update -u
                              Thomas BraunT
                              Thomas BraunT
                              #120
                              @glasfaser sagte in Error 25 bei Adapterupdates nach Node.JS 16.15.1 Update:
                              -u = Der Rest ist aktuell... :-)
                                iobroker update -u
                                P
                                P
                                paul.honka
                                #121
                                @glasfaser
                                Das frage ich auch?
                                Gruss paul
                                • P paul.honka
                                  @glasfaser
                                  Das frage ich auch?
                                  Gruss paul
                                  Thomas BraunT
                                  Thomas BraunT
                                  #122
                                  @paul-honka
                                  Soweit i. O.
                                  Dann folge den Vorschlägen des Systems:
                                    GlasfaserG
                                    GlasfaserG
                                    #123
                                    @thomas-braun sagte in Error 25 bei Adapterupdates nach Node.JS 16.15.1 Update:
                                    Mähh , habe -i mit -u vertauscht .... immer diese Autokorrektur :)
                                      P
                                      P
                                      paul.honka
                                      #124
                                      @glasfaser
                                      /opt/iobroker $ iobroker update -i
                                      Adapter    "admin"        : 5.3.8    , installed 5.3.8
                                      Adapter    "backitup"     : 2.4.9    , installed 2.4.9
                                      Adapter    "ble"          : 0.12.0   , installed 0.12.0
                                      Adapter    "cloud"        : 4.1.1    , installed 4.1.1
                                      Adapter    "discovery"    : 3.0.3    , installed 3.0.3
                                      Adapter    "echarts"      : 1.0.7    , installed 1.0.7
                                      Adapter    "fb-checkpresence": 1.1.14, installed 1.1.14
                                      Adapter    "history"      : 1.11.1   , installed 1.11.1
                                      Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
                                      Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
                                      Adapter    "info"         : 1.9.19   , installed 1.9.19
                                      Adapter    "iot"          : 1.11.4   , installed 1.11.4
                                      Adapter    "javascript"   : 5.7.0    , installed 5.7.0
                                      Controller "js-controller": 4.0.23   , installed 4.0.23
                                      Adapter    "luftdaten"    : 2.2.4    , installed 2.2.4
                                      Adapter    "mihome"       : 1.4.0    , installed 1.4.0
                                      Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
                                      Adapter    "pushover"     : 2.1.0    , installed 2.1.0
                                      Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
                                      Adapter    "sql"          : 1.16.2   , installed 1.16.2
                                      Adapter    "telegram"     : 1.13.0   , installed 1.13.0
                                      Adapter    "text2command" : 2.2.1    , installed 2.2.1
                                      Adapter    "vis-canvas-gauges": 0.1.5, installed 0.1.5
                                      Adapter    "vis-google-fonts": 1.0.3 , installed 1.0.3
                                      Adapter    "vis-hqwidgets": 1.2.0    , installed 1.2.0
                                      Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
                                      Adapter    "vis-timeandweather": 1.1.7, installed 1.1.7
                                      Adapter    "yr"           : 5.3.0    , installed 5.3.0
                                      Adapter    "zigbee"       : 1.7.5    , installed 1.7.5
                                      Gruss paul
                                        @paul-honka
                                        Soweit i. O.
                                        P
                                        P
                                        paul.honka
                                        #125
                                        gemacht
                                         mv /opt/iobroker/node_modules/node-telegram-bot-api /opt/iobroker/node_modules/.node-telegram-bot-api-1etpN2K2
                                        /opt/iobroker $  iob upgrade email --debug
                                        -> 1.1.3:
                                        -> 1.1.2:
                                        -> 1.1.1:
                                        -> 1.1.0:
                                        NPM version: 8.11.0
                                        npm ERR! path /opt/iobroker/node_modules/regexp.prototype.flags
                                        npm ERR! dest /opt/iobroker/node_modules/.regexp.prototype.flags-omxNhUlX
                                        npm ERR! errno -39
                                        npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/regexp.prototype.flags' -> '/opt/iobroker/node_modules/.regexp.prototype.flags-omxNhUlX'
                                        npm ERR!     /home/iobroker/.npm/_logs/2022-06-28T08_35_21_368Z-debug-0.log
                                        Drehen wir uns im Kreis ?
                                        Steht wieder ein rename drin? Immer weiter umbenennen?
                                        Gruss paul
                                        Thomas BraunT GlasfaserG 3 Antworten Letzte Antwort
                                        • P paul.honka
                                          gemacht
                                          -> 1.1.3:
                                          -> 1.1.2:
                                          -> 1.1.1:
                                          -> 1.1.0:
                                          NPM version: 8.11.0
                                          npm ERR! errno -39
                                          Gruss paul
                                          Thomas BraunT
                                          Thomas BraunT
                                          #126
                                          Ja.
                                          84.1k
