  4. Error 25 bei Adapterupdates nach Node.JS 16.15.1 Update
errormeldungnodejs 16.15.1
169 Beiträge 15 Kommentatoren 40.0k Aufrufe 12 Beobachtet
  • P paul.honka
    Hallo ,
    habe auch das Error 25 Problem.
    Nach iob upgrade email --debug
    kamen diese Logs
    This upgrade of "email" will introduce the following changes:
    -> 1.1.3:
    Make sure the STARTTLS configuration field is displayed
    -> 1.1.2:
    Fix mail.ee settings
    -> 1.1.1:
    Allow to use connections to port 25 unencrypted
    -> 1.1.0:
    Adjust default settings for web.de and 1und1 and add ionos
    Add "Always use STARTTLS" option for custom SMTP settings
    Would you like to upgrade email from @1.0.10 to @1.1.3 now? [(y)es, (n)o]: y
    Update email from @1.0.10 to @1.1.3
    NPM version: 8.11.0
    Installing iobroker.email@1.1.3... (System call)
    npm WARN old lockfile
    npm WARN old lockfile The package-lock.json file was created with an old version of npm,
    npm WARN old lockfile so supplemental metadata must be fetched from the registry.
    npm WARN old lockfile This is a one-time fix-up, please be patient...
    npm ERR! code ENOTEMPTY
    npm ERR! syscall rename
    npm ERR! path /opt/iobroker/node_modules/define-properties
    npm ERR! dest /opt/iobroker/node_modules/.define-properties-gzFzeOn0
    npm ERR! errno -39
    npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/define-properties' -> '/opt/iobroker/node_modules/.define-properties-gzFzeOn0'
    npm ERR!     /home/iobroker/.npm/_logs/2022-06-28T04_51_01_894Z-debug-0.log
    host.IOBroker-Sted1 Cannot install iobroker.email@1.1.3: 217
    Danach
    mv /opt/iobroker/node_modules/define-properties /opt/iobroker/node_modules/.define-properties-gzFzeOn0
    und Nach iob upgrade email --debug
    dann diese logs
    -> 1.1.3:
    -> 1.1.2:
    -> 1.1.1:
    -> 1.1.0:
    NPM version: 8.11.0
    npm ERR! path /opt/iobroker/node_modules/follow-redirects
    npm ERR! dest /opt/iobroker/node_modules/.follow-redirects-vRGWWNjd
    npm ERR! errno -39
    npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/follow-redirects' -> '/opt/iobroker/node_modules/.follow-redirects-vRGWWNjd'
    npm ERR!     /home/iobroker/.npm/_logs/2022-06-28T04_53_25_440Z-debug-0.log
    Danach
    mv /opt/iobroker/node_modules/follow-redirects /opt/iobroker/node_modules/.follow-redirects-vRGWWNjd
    und wieder
    mit folgendem log
    node:internal/modules/cjs/loader:936
      throw err;
    Error: Cannot find module 'follow-redirects'
    Require stack:
    - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/adapters/http.js
    - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/defaults.js
    - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/core/transformData.js
    - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/core/dispatchRequest.js
    - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/core/Axios.js
    - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/axios.js
    - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/index.js
    - /opt/iobroker/node_modules/@alcalzone/pak/build/lib/package-managers/npm/index.js
    - /opt/iobroker/node_modules/@alcalzone/pak/build/lib/pak.js
    - /opt/iobroker/node_modules/@alcalzone/pak/build/index.js
    - /opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js
    - /opt/iobroker/node_modules/@iobroker/js-controller-common/index.js
    - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js
    - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
        at Function.Module._resolveFilename (node:internal/modules/cjs/loader:933:15)
        at Function.Module._load (node:internal/modules/cjs/loader:778:27)
        at Module.require (node:internal/modules/cjs/loader:1005:19)
        at require (node:internal/modules/cjs/helpers:102:18)
        at Object.<anonymous> (/opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/adapters/http.js:9:18)
        at Module._compile (node:internal/modules/cjs/loader:1105:14)
        at Object.Module._extensions..js (node:internal/modules/cjs/loader:1159:10)
        at Module.load (node:internal/modules/cjs/loader:981:32)
        at Function.Module._load (node:internal/modules/cjs/loader:822:12)
        at Module.require (node:internal/modules/cjs/loader:1005:19) {
      code: 'MODULE_NOT_FOUND',
      requireStack: [
        '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/adapters/http.js',
        '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/defaults.js',
        '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/core/transformData.js',
        '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/core/dispatchRequest.js',
        '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/core/Axios.js',
        '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/axios.js',
        '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/index.js',
        '/opt/iobroker/node_modules/@alcalzone/pak/build/lib/package-managers/npm/index.js',
        '/opt/iobroker/node_modules/@alcalzone/pak/build/lib/pak.js',
        '/opt/iobroker/node_modules/@alcalzone/pak/build/index.js',
        '/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js',
        '/opt/iobroker/node_modules/@iobroker/js-controller-common/index.js',
        '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js',
        '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
    Die Instanzen der Adapter laufen, nach Neustart bleiben die im Stop.
    armv7l
    /usr/bin/nodejs
    /usr/bin/node
    /usr/bin/npm
    v16.15.1
    v16.15.1
    8.11.0
    Was lief da denn falsch.
    Gruss paul
    apollon77A
    apollon77A
    #108
    @paul-honka Mach das letzte rename mal rückgängig .. du hast dasmit dem Axios eine Dep weggenommen.
    Ich bin nicht sivher das das ausführen der Renames die er selbst tun will und nicht kann wirklich die Lösung ist.
    Ich wäre eher dabei zu prüfen ob denn das ZIELVerzeichnis wohin er es renamen will vllt schon da ist und wenn ja dieses zu löschen.
    Im letzten Fall also /opt/iobroker/node_modules/.follow-redirects-vRGWWNjd ... aber das ist jetzt bei dir irrelevant.
    Auch die Frage ist ob es hilt "Iob fix" vorher auszuführen
    P 1 Antwort Letzte Antwort
    • apollon77A apollon77
      P
      P
      paul.honka
      schrieb am zuletzt editiert von paul.honka
      #109
      @apollon77 Habe das letzte mv wieder rückgangig gemacht und den iob fix gestartet.
      Dann wieder iob upgrade email --debug
      und diesmal kommt die folgende Meldung
      npm ERR! path /opt/iobroker/node_modules/node-telegram-bot-api
      npm ERR! dest /opt/iobroker/node_modules/.node-telegram-bot-api-1etpN2K2
      npm ERR! errno -39
      npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/node-telegram-bot-api' -> '/opt/iobroker/node_modules/.node-telegram-bot-api-1etpN2K2'
      Telegramm???
      Ich glaub ich spiel mal ein Backup ein.
      Gruss paul
      Thomas BraunT apollon77A 2 Antworten Letzte Antwort
      • P paul.honka
        npm ERR! errno -39
        Telegramm???
        Gruss paul
        Thomas BraunT
        Thomas BraunT
        #110
        @paul-honka sagte in Error 25 bei Adapterupdates nach Node.JS 16.15.1 Update:
        Ich glaub ich spiel malt ein Backup ein.
        Das wird dir vermutlich nichts bringen.
          P
          P
          paul.honka
          #111
          Wieso, Warum? Vor einer Woche konnte ich noch einige Adapter updaten?
          Gruss paul
          GlasfaserG Thomas BraunT 2 Antworten Letzte Antwort
          • P paul.honka
            Gruss paul
            GlasfaserG
            GlasfaserG
            #112
            @paul-honka
            v16.15.1
            v16.15.1
            8.11.0
            vor oder nach dem Update auf 16 !?
            Zeige mal ( Ein/Ausgabe in Code-Tags setzen ) :
            iobroker update -u
            uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
            • P paul.honka
              Gruss paul
              Thomas BraunT
              Thomas BraunT
              #113
              Das war auch bestimmt vor einem Upgrade auf nodejs16/npm8.
              cd /opt/iobroker
              npm ls | grep -E 'ERR|github'
              liefert?
              • P paul.honka
                npm ERR! errno -39
                Telegramm???
                Gruss paul
                apollon77A
                apollon77A
                #114
                gibt es opt/iobroker/node_modules/.node-telegram-bot-api-1etpN2K2 denn?
                  cd /opt/iobroker
                  liefert?
                  P
                  P
                  paul.honka
                  #115
                  @thomas-braun mal ohne code tak, ok mit
                  ├── iobroker.gartenbewaesserung@0.0.8 (git+ssh://git@github.com/TA2k/ioBroker.gartenbewaesserung.git#95bf9dcd60b595c7e59e2ed87b719bf564d9ba59)
                  ├── iobroker.mihome-airpurifier@0.1.8 (git+ssh://git@github.com/JoJ123/ioBroker.mihome-airpurifier.git#33aac153e52610c4362089bcf12ac40ed97d82f5)
                  npm ERR! code ELSPROBLEMS
                  npm ERR! invalid: iobroker.telegram@1.13.0 /opt/iobroker/node_modules/iobroker.telegram
                  npm ERR!     /home/iobroker/.npm/_logs/2022-06-28T08_15_02_392Z-debug-0.log
                  Gruss paul
                  Thomas BraunT GlasfaserG 2 Antworten Letzte Antwort
                  • P paul.honka
                    Gruss paul
                    Thomas BraunT
                    Thomas BraunT
                    #116
                    mal ohne code tak
                    Warum?
                    • GlasfaserG Glasfaser
                      @paul-honka
                      v16.15.1
                      v16.15.1
                      8.11.0
                      iobroker update -u
                      P
                      P
                      paul.honka
                      #117
                      @glasfaser
                       iobroker update -u
                      Adapter    "email"        : 1.1.3    , installed 1.0.10 [Updatable]
                      Adapter    "flot"         : 1.11.0   , installed 1.10.7 [Updatable]
                      Adapter    "simple-api"   : 2.7.0    , installed 2.6.5  [Updatable]
                      pi@IOBroker-Sted1:/opt/iobroker $
                      pi@IOBroker-Sted1:/opt/iobroker $ cd /opt/iobroker
                      pi@IOBroker-Sted1:/opt/iobroker $ npm ls | grep -E 'ERR|github'
                      pi@IOBroker-Sted1:/opt/iobroker $ iobroker update -u
                      pi@IOBroker-Sted1:/opt/iobroker $ sudo ln -s /usr/bin/node /usr/bin/nodejs
                      ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
                      pi@IOBroker-Sted1:/opt/iobroker $ uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                      armv7l
                      /usr/bin/nodejs
                      /usr/bin/node
                      /usr/bin/npm
                      v16.15.1
                      v16.15.1
                      8.11.0
                      pi
                      /opt/iobroker
                      OK:1 http://archive.raspberrypi.org/debian buster InRelease
                      OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                      OK:3 https://deb.nodesource.com/node_16.x buster InRelease
                      Alle Pakete sind aktuell.
                      nodejs:
                        Installiert:           16.15.1-deb-1nodesource1
                        Installationskandidat: 16.15.1-deb-1nodesource1
                        Versionstabelle:
                       *** 16.15.1-deb-1nodesource1 500
                              500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
                           10.24.0~dfsg-1~deb10u1 500
                      Gruss paul
                      • P paul.honka
                        Gruss paul
                        GlasfaserG
                        GlasfaserG
                        #118
                        Bitte in Code-Tags setzten und auch nicht die Aus/Eingabe kürzen !
                        • P paul.honka
                          @glasfaser
                           iobroker update -u
                          armv7l
                          /usr/bin/nodejs
                          /usr/bin/node
                          /usr/bin/npm
                          v16.15.1
                          v16.15.1
                          8.11.0
                          pi
                          /opt/iobroker
                          nodejs:
                            Versionstabelle:
                          Gruss paul
                          GlasfaserG
                          GlasfaserG
                          #119
                          iobroker update -u
                          und wo ist der Rest .... kein Admin usw.
                          Thomas BraunT P 2 Antworten Letzte Antwort
                            iobroker update -u
                            Thomas BraunT
                            Thomas BraunT
                            #120
                            @glasfaser sagte in Error 25 bei Adapterupdates nach Node.JS 16.15.1 Update:
                            -u = Der Rest ist aktuell... :-)
                              iobroker update -u
                              P
                              P
                              paul.honka
                              #121
                              @glasfaser
                              Das frage ich auch?
                              Gruss paul
                              • P paul.honka
                                @glasfaser
                                Das frage ich auch?
                                Gruss paul
                                Thomas BraunT
                                Thomas BraunT
                                #122
                                @paul-honka
                                Soweit i. O.
                                Dann folge den Vorschlägen des Systems:
                                  GlasfaserG
                                  GlasfaserG
                                  #123
                                  @thomas-braun sagte in Error 25 bei Adapterupdates nach Node.JS 16.15.1 Update:
                                  Mähh , habe -i mit -u vertauscht .... immer diese Autokorrektur :)
                                    P
                                    P
                                    paul.honka
                                    #124
                                    @glasfaser
                                    /opt/iobroker $ iobroker update -i
                                    Adapter    "admin"        : 5.3.8    , installed 5.3.8
                                    Adapter    "backitup"     : 2.4.9    , installed 2.4.9
                                    Adapter    "ble"          : 0.12.0   , installed 0.12.0
                                    Adapter    "cloud"        : 4.1.1    , installed 4.1.1
                                    Adapter    "discovery"    : 3.0.3    , installed 3.0.3
                                    Adapter    "echarts"      : 1.0.7    , installed 1.0.7
                                    Adapter    "fb-checkpresence": 1.1.14, installed 1.1.14
                                    Adapter    "history"      : 1.11.1   , installed 1.11.1
                                    Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
                                    Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
                                    Adapter    "info"         : 1.9.19   , installed 1.9.19
                                    Adapter    "iot"          : 1.11.4   , installed 1.11.4
                                    Adapter    "javascript"   : 5.7.0    , installed 5.7.0
                                    Controller "js-controller": 4.0.23   , installed 4.0.23
                                    Adapter    "luftdaten"    : 2.2.4    , installed 2.2.4
                                    Adapter    "mihome"       : 1.4.0    , installed 1.4.0
                                    Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
                                    Adapter    "pushover"     : 2.1.0    , installed 2.1.0
                                    Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
                                    Adapter    "sql"          : 1.16.2   , installed 1.16.2
                                    Adapter    "telegram"     : 1.13.0   , installed 1.13.0
                                    Adapter    "text2command" : 2.2.1    , installed 2.2.1
                                    Adapter    "vis-canvas-gauges": 0.1.5, installed 0.1.5
                                    Adapter    "vis-google-fonts": 1.0.3 , installed 1.0.3
                                    Adapter    "vis-hqwidgets": 1.2.0    , installed 1.2.0
                                    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
                                    Adapter    "vis-timeandweather": 1.1.7, installed 1.1.7
                                    Adapter    "yr"           : 5.3.0    , installed 5.3.0
                                    Adapter    "zigbee"       : 1.7.5    , installed 1.7.5
                                    Gruss paul
                                      @paul-honka
                                      Soweit i. O.
                                      P
                                      P
                                      paul.honka
                                      #125
                                      gemacht
                                       mv /opt/iobroker/node_modules/node-telegram-bot-api /opt/iobroker/node_modules/.node-telegram-bot-api-1etpN2K2
                                      /opt/iobroker $  iob upgrade email --debug
                                      -> 1.1.3:
                                      -> 1.1.2:
                                      -> 1.1.1:
                                      -> 1.1.0:
                                      NPM version: 8.11.0
                                      npm ERR! path /opt/iobroker/node_modules/regexp.prototype.flags
                                      npm ERR! dest /opt/iobroker/node_modules/.regexp.prototype.flags-omxNhUlX
                                      npm ERR! errno -39
                                      npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/regexp.prototype.flags' -> '/opt/iobroker/node_modules/.regexp.prototype.flags-omxNhUlX'
                                      npm ERR!     /home/iobroker/.npm/_logs/2022-06-28T08_35_21_368Z-debug-0.log
                                      Drehen wir uns im Kreis ?
                                      Steht wieder ein rename drin? Immer weiter umbenennen?
                                      Gruss paul
                                      Thomas BraunT GlasfaserG 3 Antworten Letzte Antwort
                                      • P paul.honka
                                        gemacht
                                        -> 1.1.3:
                                        -> 1.1.2:
                                        -> 1.1.1:
                                        -> 1.1.0:
                                        NPM version: 8.11.0
                                        npm ERR! errno -39
                                        Gruss paul
                                        Thomas BraunT
                                        Thomas BraunT
                                        #126
                                        Ja.
                                        • P paul.honka
                                          gemacht
                                          -> 1.1.3:
                                          -> 1.1.2:
                                          -> 1.1.1:
                                          -> 1.1.0:
                                          NPM version: 8.11.0
                                          npm ERR! errno -39
                                          Gruss paul
                                          Thomas BraunT
                                          Thomas BraunT
                                          #127
                                          Deutet auf verfummelte Rechte hin. Mal als root oder per sudo unterwegs gewesen?
                                          P 4 Antworten Letzte Antwort
                                          83.9k
