  4. Error 25 bei Adapterupdates nach Node.JS 16.15.1 Update
errormeldungnodejs 16.15.1
169 Beiträge 15 Kommentatoren 41.8k Aufrufe 12 Beobachtet
  • N nhbischo
    @nhbischo
    Nun scheint der Adapter installiert worden zu sein. Ich hatte den Tip thomas-braun mit der Umbennung ausgeführt. Dann mit der alten existierenden package-lick.json die Installation versucht.
    pi@raspberrypi:/opt/iobroker $ iobroker upgrade smartgarden --debug
    This upgrade of "smartgarden" will introduce the following changes:
    -> 2.0.0:
    support for new login procedure to Gardena webservice; admin5 is necessary
    BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
    Would you like to upgrade smartgarden from @1.0.6 to @2.0.0 now? [(y)es, (n)o]: y
    Update smartgarden from @1.0.6 to @2.0.0
    NPM version: 8.11.0
    Installing iobroker.smartgarden@2.0.0... (System call)
    npm WARN old lockfile
    npm WARN old lockfile The package-lock.json file was created with an old version of npm,
    npm WARN old lockfile so supplemental metadata must be fetched from the registry.
    npm WARN old lockfile This is a one-time fix-up, please be patient...
    npm WARN tarball tarball data for iobroker.icons-open-icon-library-png@https://github.com/ioBroker/ioBroker.icons-open-icon-library-png/tarball/master (sha512-qGFFRFfv/uSaVT+z3v01bwdZYjfIES0YwaHNOgy+OO28NMa8/8fh2rkBKGHNeHfFPBTo3juTeH+p6ngZ6s//7w==) seems to be corrupted. Trying again.
    npm WARN old lockfile Error: sha512-qGFFRFfv/uSaVT+z3v01bwdZYjfIES0YwaHNOgy+OO28NMa8/8fh2rkBKGHNeHfFPBTo3juTeH+p6ngZ6s//7w== integrity checksum failed when using sha512: wanted sha512-qGFFRFfv/uSaVT+z3v01bwdZYjfIES0YwaHNOgy+OO28NMa8/8fh2rkBKGHNeHfFPBTo3juTeH+p6ngZ6s//7w== but got sha512-ZH4lj95sM6IpZEL2H1HR0hXTo6GMqbUBPbQyylgdRd6TDEdU+fgohUVGW4gPI0UnrAzqM/kx5+mozLqCVh2DCg==. (64751136 bytes)
    npm WARN old lockfile     at IntegrityStream.[_onEnd] (/usr/lib/node_modules/npm/node_modules/ssri/lib/index.js:118:19)
    npm WARN old lockfile     at IntegrityStream.emit (/usr/lib/node_modules/npm/node_modules/ssri/lib/index.js:88:19)
    npm WARN old lockfile     at IntegrityStream.[maybeEmitEnd] (/usr/lib/node_modules/npm/node_modules/minipass/index.js:370:12)
    npm WARN old lockfile     at IntegrityStream.emit (/usr/lib/node_modules/npm/node_modules/minipass/index.js:434:29)
    npm WARN old lockfile     at IntegrityStream.emit (/usr/lib/node_modules/npm/node_modules/ssri/lib/index.js:90:18)
    npm WARN old lockfile     at IntegrityStream.[resume] (/usr/lib/node_modules/npm/node_modules/minipass/index.js:265:12)
    npm WARN old lockfile     at IntegrityStream.resume (/usr/lib/node_modules/npm/node_modules/minipass/index.js:269:24)
    npm WARN old lockfile     at CachingMinipassPipeline.emit (/usr/lib/node_modules/npm/node_modules/minipass-pipeline/index.js:105:19)
    npm WARN old lockfile     at CachingMinipassPipeline.emit (/usr/lib/node_modules/npm/node_modules/make-fetch-happen/lib/pipeline.js:37:18)
    npm WARN old lockfile     at CachingMinipassPipeline.[resume] (/usr/lib/node_modules/npm/node_modules/minipass/index.js:259:10)
    npm WARN old lockfile  Could not fetch metadata for iobroker.icons-open-icon-library-png@https://github.com/ioBroker/ioBroker.icons-open-icon-library-png/tarball/master Error: sha512-qGFFRFfv/uSaVT+z3v01bwdZYjfIES0YwaHNOgy+OO28NMa8/8fh2rkBKGHNeHfFPBTo3juTeH+p6ngZ6s//7w== integrity checksum failed when using sha512: wanted sha512-qGFFRFfv/uSaVT+z3v01bwdZYjfIES0YwaHNOgy+OO28NMa8/8fh2rkBKGHNeHfFPBTo3juTeH+p6ngZ6s//7w== but got sha512-ZH4lj95sM6IpZEL2H1HR0hXTo6GMqbUBPbQyylgdRd6TDEdU+fgohUVGW4gPI0UnrAzqM/kx5+mozLqCVh2DCg==. (64751136 bytes)
    npm WARN old lockfile     at CachingMinipassPipeline.[resume] (/usr/lib/node_modules/npm/node_modules/minipass/index.js:259:10) {
    npm WARN old lockfile   code: 'EINTEGRITY',
    npm WARN old lockfile   found: Integrity { sha512: [ [Hash] ] },
    npm WARN old lockfile   expected: [
    npm WARN old lockfile     Hash {
    npm WARN old lockfile       source: 'sha512-qGFFRFfv/uSaVT+z3v01bwdZYjfIES0YwaHNOgy+OO28NMa8/8fh2rkBKGHNeHfFPBTo3juTeH+p6ngZ6s//7w==',
    npm WARN old lockfile       digest: 'qGFFRFfv/uSaVT+z3v01bwdZYjfIES0YwaHNOgy+OO28NMa8/8fh2rkBKGHNeHfFPBTo3juTeH+p6ngZ6s//7w==',
    npm WARN old lockfile       algorithm: 'sha512',
    npm WARN old lockfile       options: []
    npm WARN old lockfile     }
    npm WARN old lockfile   ],
    npm WARN old lockfile   sri: Integrity { sha512: [ [Hash] ] }
    npm ERR! code ENOTEMPTY
    npm ERR! syscall rename
    npm ERR! path /opt/iobroker/node_modules/iobroker.javascript/node_modules/acorn-walk
    npm ERR! dest /opt/iobroker/node_modules/iobroker.javascript/node_modules/.acorn-walk-xHkEOJL1
    npm ERR! errno -39
    npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.javascript/node_modules/acorn-walk' -> '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.acorn-walk-xHkEOJL1'
    npm ERR!     /home/iobroker/.npm/_logs/2022-06-26T16_56_31_988Z-debug-0.log
    host.raspberrypi Cannot install iobroker.smartgarden@2.0.0: 217
    Da es nicht funktionierte hatte ich die Datei package-lock.json dann umbenannt. Dann den Updateprozess noch einmal angestossen und nun ist der Adapter installiert
    -> 2.0.0:
    NPM version: 8.11.0
    npm WARN skipping integrity check for git dependency ssh://git@github.com/dahuby/iobroker.samsung_tizen.git
    npm WARN skipping integrity check for git dependency ssh://git@github.com/ciddi89/ioBroker.device-watcher.git
    added 9 packages, removed 174 packages, and changed 14 packages in 4m
    104 packages are looking for funding
      run `npm fund` for details
    Update "system.adapter.smartgarden.0"
    upload [4] smartgarden.admin /opt/iobroker/node_modules/iobroker.smartgarden/admin/admin.d.ts admin.d.ts video/mp2t
    upload [3] smartgarden.admin /opt/iobroker/node_modules/iobroker.smartgarden/admin/index_m.html index_m.html text/html
    upload [2] smartgarden.admin /opt/iobroker/node_modules/iobroker.smartgarden/admin/jsonConfig.json jsonConfig.json application/json
    upload [1] smartgarden.admin /opt/iobroker/node_modules/iobroker.smartgarden/admin/smartgarden.png smartgarden.png image/png
    upload [0] smartgarden.admin /opt/iobroker/node_modules/iobroker.smartgarden/admin/tsconfig.json tsconfig.json application/json
    #106
    @nhbischo sagte in Error 25 bei Adapterupdates nach Node.JS 16.15.1 Update:
    steht ja auch drin
    P 1 Antwort Letzte Antwort
      steht ja auch drin
      P
      P
      paul.honka
      #107
      Hallo ,
      habe auch das Error 25 Problem.
      Nach iob upgrade email --debug
      kamen diese Logs
      This upgrade of "email" will introduce the following changes:
      -> 1.1.3:
      Make sure the STARTTLS configuration field is displayed
      -> 1.1.2:
      Fix mail.ee settings
      -> 1.1.1:
      Allow to use connections to port 25 unencrypted
      -> 1.1.0:
      Adjust default settings for web.de and 1und1 and add ionos
      Add "Always use STARTTLS" option for custom SMTP settings
      Would you like to upgrade email from @1.0.10 to @1.1.3 now? [(y)es, (n)o]: y
      Update email from @1.0.10 to @1.1.3
      NPM version: 8.11.0
      Installing iobroker.email@1.1.3... (System call)
      npm ERR! path /opt/iobroker/node_modules/define-properties
      npm ERR! dest /opt/iobroker/node_modules/.define-properties-gzFzeOn0
      npm ERR! errno -39
      npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/define-properties' -> '/opt/iobroker/node_modules/.define-properties-gzFzeOn0'
      npm ERR!     /home/iobroker/.npm/_logs/2022-06-28T04_51_01_894Z-debug-0.log
      host.IOBroker-Sted1 Cannot install iobroker.email@1.1.3: 217
      Danach
      mv /opt/iobroker/node_modules/define-properties /opt/iobroker/node_modules/.define-properties-gzFzeOn0
      und Nach iob upgrade email --debug
      dann diese logs
      -> 1.1.3:
      -> 1.1.2:
      -> 1.1.1:
      -> 1.1.0:
      NPM version: 8.11.0
      npm ERR! path /opt/iobroker/node_modules/follow-redirects
      npm ERR! dest /opt/iobroker/node_modules/.follow-redirects-vRGWWNjd
      npm ERR! errno -39
      npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/follow-redirects' -> '/opt/iobroker/node_modules/.follow-redirects-vRGWWNjd'
      npm ERR!     /home/iobroker/.npm/_logs/2022-06-28T04_53_25_440Z-debug-0.log
      Danach
      mv /opt/iobroker/node_modules/follow-redirects /opt/iobroker/node_modules/.follow-redirects-vRGWWNjd
      und wieder
      mit folgendem log
      node:internal/modules/cjs/loader:936
        throw err;
      Error: Cannot find module 'follow-redirects'
      Require stack:
      - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/adapters/http.js
      - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/defaults.js
      - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/core/transformData.js
      - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/core/dispatchRequest.js
      - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/core/Axios.js
      - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/axios.js
      - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/index.js
      - /opt/iobroker/node_modules/@alcalzone/pak/build/lib/package-managers/npm/index.js
      - /opt/iobroker/node_modules/@alcalzone/pak/build/lib/pak.js
      - /opt/iobroker/node_modules/@alcalzone/pak/build/index.js
      - /opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js
      - /opt/iobroker/node_modules/@iobroker/js-controller-common/index.js
      - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js
      - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
          at Function.Module._resolveFilename (node:internal/modules/cjs/loader:933:15)
          at Function.Module._load (node:internal/modules/cjs/loader:778:27)
          at Module.require (node:internal/modules/cjs/loader:1005:19)
          at require (node:internal/modules/cjs/helpers:102:18)
          at Object.<anonymous> (/opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/adapters/http.js:9:18)
          at Module._compile (node:internal/modules/cjs/loader:1105:14)
          at Object.Module._extensions..js (node:internal/modules/cjs/loader:1159:10)
          at Module.load (node:internal/modules/cjs/loader:981:32)
          at Function.Module._load (node:internal/modules/cjs/loader:822:12)
          at Module.require (node:internal/modules/cjs/loader:1005:19) {
        code: 'MODULE_NOT_FOUND',
        requireStack: [
          '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/adapters/http.js',
          '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/defaults.js',
          '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/core/transformData.js',
          '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/core/dispatchRequest.js',
          '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/core/Axios.js',
          '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/axios.js',
          '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/index.js',
          '/opt/iobroker/node_modules/@alcalzone/pak/build/lib/package-managers/npm/index.js',
          '/opt/iobroker/node_modules/@alcalzone/pak/build/lib/pak.js',
          '/opt/iobroker/node_modules/@alcalzone/pak/build/index.js',
          '/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js',
          '/opt/iobroker/node_modules/@iobroker/js-controller-common/index.js',
          '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js',
          '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
      Die Instanzen der Adapter laufen, nach Neustart bleiben die im Stop.
      armv7l
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      v16.15.1
      v16.15.1
      8.11.0
      Was lief da denn falsch.
      Gruss paul
      • P paul.honka
        Hallo ,
        kamen diese Logs
        -> 1.1.3:
        -> 1.1.2:
        -> 1.1.1:
        -> 1.1.0:
        NPM version: 8.11.0
        npm ERR! errno -39
        Danach
        dann diese logs
        -> 1.1.3:
        -> 1.1.2:
        -> 1.1.1:
        -> 1.1.0:
        NPM version: 8.11.0
        npm ERR! errno -39
        Danach
        und wieder
        mit folgendem log
          throw err;
        Require stack:
          requireStack: [
        armv7l
        /usr/bin/nodejs
        /usr/bin/node
        /usr/bin/npm
        v16.15.1
        v16.15.1
        8.11.0
        Gruss paul
        apollon77A
        apollon77A
        #108
        @paul-honka Mach das letzte rename mal rückgängig .. du hast dasmit dem Axios eine Dep weggenommen.
        Ich bin nicht sivher das das ausführen der Renames die er selbst tun will und nicht kann wirklich die Lösung ist.
        Ich wäre eher dabei zu prüfen ob denn das ZIELVerzeichnis wohin er es renamen will vllt schon da ist und wenn ja dieses zu löschen.
        Im letzten Fall also /opt/iobroker/node_modules/.follow-redirects-vRGWWNjd ... aber das ist jetzt bei dir irrelevant.
        Auch die Frage ist ob es hilt "Iob fix" vorher auszuführen
        • apollon77A apollon77
          P
          P
          paul.honka
          schrieb am zuletzt editiert von paul.honka
          #109
          @apollon77 Habe das letzte mv wieder rückgangig gemacht und den iob fix gestartet.
          Dann wieder iob upgrade email --debug
          und diesmal kommt die folgende Meldung
          npm ERR! path /opt/iobroker/node_modules/node-telegram-bot-api
          npm ERR! dest /opt/iobroker/node_modules/.node-telegram-bot-api-1etpN2K2
          npm ERR! errno -39
          npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/node-telegram-bot-api' -> '/opt/iobroker/node_modules/.node-telegram-bot-api-1etpN2K2'
          Telegramm???
          Ich glaub ich spiel mal ein Backup ein.
          Gruss paul
          Thomas BraunT apollon77A 2 Antworten Letzte Antwort
          • P paul.honka
            npm ERR! errno -39
            Telegramm???
            Gruss paul
            Thomas BraunT
            Thomas BraunT
            Most Active Developer
            #110
            @paul-honka sagte in Error 25 bei Adapterupdates nach Node.JS 16.15.1 Update:
            Ich glaub ich spiel malt ein Backup ein.
            Das wird dir vermutlich nichts bringen.
              P
              P
              paul.honka
              #111
              Wieso, Warum? Vor einer Woche konnte ich noch einige Adapter updaten?
              Gruss paul
              GlasfaserG Thomas BraunT 2 Antworten Letzte Antwort
              • P paul.honka
                Gruss paul
                GlasfaserG
                GlasfaserG
                #112
                @paul-honka
                v16.15.1
                v16.15.1
                8.11.0
                vor oder nach dem Update auf 16 !?
                Zeige mal ( Ein/Ausgabe in Code-Tags setzen ) :
                iobroker update -u
                uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                • P paul.honka
                  Gruss paul
                  Thomas BraunT
                  Thomas BraunT
                  #113
                  Das war auch bestimmt vor einem Upgrade auf nodejs16/npm8.
                  cd /opt/iobroker
                  npm ls | grep -E 'ERR|github'
                  liefert?
                  • P paul.honka
                    npm ERR! errno -39
                    Telegramm???
                    Gruss paul
                    apollon77A
                    apollon77A
                    #114
                    gibt es opt/iobroker/node_modules/.node-telegram-bot-api-1etpN2K2 denn?
                      cd /opt/iobroker
                      liefert?
                      P
                      P
                      paul.honka
                      #115
                      @thomas-braun mal ohne code tak, ok mit
                      ├── iobroker.gartenbewaesserung@0.0.8 (git+ssh://git@github.com/TA2k/ioBroker.gartenbewaesserung.git#95bf9dcd60b595c7e59e2ed87b719bf564d9ba59)
                      ├── iobroker.mihome-airpurifier@0.1.8 (git+ssh://git@github.com/JoJ123/ioBroker.mihome-airpurifier.git#33aac153e52610c4362089bcf12ac40ed97d82f5)
                      npm ERR! code ELSPROBLEMS
                      npm ERR! invalid: iobroker.telegram@1.13.0 /opt/iobroker/node_modules/iobroker.telegram
                      npm ERR!     /home/iobroker/.npm/_logs/2022-06-28T08_15_02_392Z-debug-0.log
                      Gruss paul
                      Thomas BraunT GlasfaserG 2 Antworten Letzte Antwort
                      • P paul.honka
                        Gruss paul
                        Thomas BraunT
                        Thomas BraunT
                        #116
                        mal ohne code tak
                        Warum?
                        • GlasfaserG Glasfaser
                          @paul-honka
                          v16.15.1
                          v16.15.1
                          8.11.0
                          iobroker update -u
                          P
                          P
                          paul.honka
                          #117
                          @glasfaser
                           iobroker update -u
                          Adapter    "email"        : 1.1.3    , installed 1.0.10 [Updatable]
                          Adapter    "flot"         : 1.11.0   , installed 1.10.7 [Updatable]
                          Adapter    "simple-api"   : 2.7.0    , installed 2.6.5  [Updatable]
                          pi@IOBroker-Sted1:/opt/iobroker $
                          pi@IOBroker-Sted1:/opt/iobroker $ cd /opt/iobroker
                          pi@IOBroker-Sted1:/opt/iobroker $ npm ls | grep -E 'ERR|github'
                          pi@IOBroker-Sted1:/opt/iobroker $ iobroker update -u
                          pi@IOBroker-Sted1:/opt/iobroker $ sudo ln -s /usr/bin/node /usr/bin/nodejs
                          ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
                          pi@IOBroker-Sted1:/opt/iobroker $ uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                          armv7l
                          /usr/bin/nodejs
                          /usr/bin/node
                          /usr/bin/npm
                          v16.15.1
                          v16.15.1
                          8.11.0
                          pi
                          /opt/iobroker
                          OK:1 http://archive.raspberrypi.org/debian buster InRelease
                          OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                          OK:3 https://deb.nodesource.com/node_16.x buster InRelease
                          Alle Pakete sind aktuell.
                          nodejs:
                            Installiert:           16.15.1-deb-1nodesource1
                            Installationskandidat: 16.15.1-deb-1nodesource1
                            Versionstabelle:
                           *** 16.15.1-deb-1nodesource1 500
                                  500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
                               10.24.0~dfsg-1~deb10u1 500
                          Gruss paul
                          • P paul.honka
                            Gruss paul
                            GlasfaserG
                            GlasfaserG
                            #118
                            Bitte in Code-Tags setzten und auch nicht die Aus/Eingabe kürzen !
                            • P paul.honka
                              @glasfaser
                               iobroker update -u
                              armv7l
                              /usr/bin/nodejs
                              /usr/bin/node
                              /usr/bin/npm
                              v16.15.1
                              v16.15.1
                              8.11.0
                              pi
                              /opt/iobroker
                              nodejs:
                                Versionstabelle:
                              Gruss paul
                              GlasfaserG
                              GlasfaserG
                              #119
                              iobroker update -u
                              und wo ist der Rest .... kein Admin usw.
                              Thomas BraunT P 2 Antworten Letzte Antwort
                                iobroker update -u
                                Thomas BraunT
                                Thomas BraunT
                                #120
                                @glasfaser sagte in Error 25 bei Adapterupdates nach Node.JS 16.15.1 Update:
                                -u = Der Rest ist aktuell... :-)
                                  iobroker update -u
                                  P
                                  P
                                  paul.honka
                                  #121
                                  @glasfaser
                                  Das frage ich auch?
                                  Gruss paul
                                  • P paul.honka
                                    @glasfaser
                                    Das frage ich auch?
                                    Gruss paul
                                    Thomas BraunT
                                    Thomas BraunT
                                    #122
                                    @paul-honka
                                    Soweit i. O.
                                    Dann folge den Vorschlägen des Systems:
                                      GlasfaserG
                                      GlasfaserG
                                      #123
                                      @thomas-braun sagte in Error 25 bei Adapterupdates nach Node.JS 16.15.1 Update:
                                      Mähh , habe -i mit -u vertauscht .... immer diese Autokorrektur :)
                                        P
                                        P
                                        paul.honka
                                        #124
                                        @glasfaser
                                        /opt/iobroker $ iobroker update -i
                                        Adapter    "admin"        : 5.3.8    , installed 5.3.8
                                        Adapter    "backitup"     : 2.4.9    , installed 2.4.9
                                        Adapter    "ble"          : 0.12.0   , installed 0.12.0
                                        Adapter    "cloud"        : 4.1.1    , installed 4.1.1
                                        Adapter    "discovery"    : 3.0.3    , installed 3.0.3
                                        Adapter    "echarts"      : 1.0.7    , installed 1.0.7
                                        Adapter    "fb-checkpresence": 1.1.14, installed 1.1.14
                                        Adapter    "history"      : 1.11.1   , installed 1.11.1
                                        Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
                                        Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
                                        Adapter    "info"         : 1.9.19   , installed 1.9.19
                                        Adapter    "iot"          : 1.11.4   , installed 1.11.4
                                        Adapter    "javascript"   : 5.7.0    , installed 5.7.0
                                        Controller "js-controller": 4.0.23   , installed 4.0.23
                                        Adapter    "luftdaten"    : 2.2.4    , installed 2.2.4
                                        Adapter    "mihome"       : 1.4.0    , installed 1.4.0
                                        Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
                                        Adapter    "pushover"     : 2.1.0    , installed 2.1.0
                                        Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
                                        Adapter    "sql"          : 1.16.2   , installed 1.16.2
                                        Adapter    "telegram"     : 1.13.0   , installed 1.13.0
                                        Adapter    "text2command" : 2.2.1    , installed 2.2.1
                                        Adapter    "vis-canvas-gauges": 0.1.5, installed 0.1.5
                                        Adapter    "vis-google-fonts": 1.0.3 , installed 1.0.3
                                        Adapter    "vis-hqwidgets": 1.2.0    , installed 1.2.0
                                        Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
                                        Adapter    "vis-timeandweather": 1.1.7, installed 1.1.7
                                        Adapter    "yr"           : 5.3.0    , installed 5.3.0
                                        Adapter    "zigbee"       : 1.7.5    , installed 1.7.5
                                        Gruss paul
                                          @paul-honka
                                          Soweit i. O.
                                          P
                                          P
                                          paul.honka
                                          #125
                                          gemacht
                                           mv /opt/iobroker/node_modules/node-telegram-bot-api /opt/iobroker/node_modules/.node-telegram-bot-api-1etpN2K2
                                          /opt/iobroker $  iob upgrade email --debug
                                          -> 1.1.3:
                                          -> 1.1.2:
                                          -> 1.1.1:
                                          -> 1.1.0:
                                          NPM version: 8.11.0
                                          npm ERR! path /opt/iobroker/node_modules/regexp.prototype.flags
                                          npm ERR! dest /opt/iobroker/node_modules/.regexp.prototype.flags-omxNhUlX
                                          npm ERR! errno -39
                                          npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/regexp.prototype.flags' -> '/opt/iobroker/node_modules/.regexp.prototype.flags-omxNhUlX'
                                          npm ERR!     /home/iobroker/.npm/_logs/2022-06-28T08_35_21_368Z-debug-0.log
                                          Drehen wir uns im Kreis ?
                                          Steht wieder ein rename drin? Immer weiter umbenennen?
                                          Gruss paul
                                          Thomas BraunT GlasfaserG 3 Antworten Letzte Antwort
                                          84.2k
