  4. [neuer Adapter] smartgarden adapter for Gardena smart system
    6.3k
gardena smart systemsmartgarden
1.1k Beiträge 108 Kommentatoren 438.5k Aufrufe 101 Beobachtet
  • B BlueBook
    Folgendes konnte ich gerade aus dem lo fischen.
    Ping bei 100
    smartgarden.0 2022-04-10 13:35:13.281 info (2029) 3/ ---> State change by device: state sg.0.info.connection changed: false (ack = true)
    smartgarden.0 2022-04-10 13:35:13.260 info (2029) 3/ sgSetState: info.connection value=false ack=true
    smartgarden.0 2022-04-10 13:35:13.259 info (2029) 3/ on_close: ### closed ### close.code=1001 close.reason=Going away
    stevie77
    schrieb am zuletzt editiert von stevie77
    #771
    Kann ich bestätigen. Ich hatte das heruntergeladene Logfile anfangs falschherum gelesen. ;-)
    2022-04-10 04:12:35.352  - info: smartgarden.0 (16350) 2/ get_locations: successful / response.statusMessage: OK
    2022-04-10 04:12:35.353  - info: smartgarden.0 (16350) 2/ get_locations ... locations={"data":[{"id":"5feeadcd-2e5a[xyz]48f082f6","type":"LOCATION","attributes":{"name":"My Garden"}}]}
    2022-04-10 04:12:35.355  - info: smartgarden.0 (16350) 2/ get_websocket ...
    2022-04-10 04:12:35.694  - info: smartgarden.0 (16350) 2/ get_websocket successful: response.statusCode/Message=201/Created
    2022-04-10 04:12:35.707  - info: smartgarden.0 (16350) 2/ get_websocket ... websocket ok
    2022-04-10 04:12:35.912  - info: smartgarden.0 (16350) 2/ on_open: ### connected ###
    2022-04-10 04:12:36.459  - info: smartgarden.0 (16350) 2/ parseMessage: LOCATION found
    2022-04-10 04:12:36.466  - info: smartgarden.0 (16350) 2/ parseMessage: DEVICE found
    2022-04-10 04:12:36.472  - info: smartgarden.0 (16350) 2/ parseMessage: DEVICE found
    2022-04-10 04:12:36.482  - info: smartgarden.0 (16350) 2/ parseMessage: DEVICE found
    2022-04-10 04:12:36.496  - info: smartgarden.0 (16350) 2/ parseMessage: DEVICE found
    2022-04-10 04:12:36.615  - info: smartgarden.0 (16350) 2/ parseMessage: DEVICE found
    2022-04-10 04:12:36.626  - info: smartgarden.0 (16350) 2/ parseMessage: POWER_SOCKET found
    2022-04-10 04:12:36.642  - info: smartgarden.0 (16350) 2/ parseMessage: COMMON found
    2022-04-10 04:12:36.650  - info: smartgarden.0 (16350) 2/ parseMessage: SENSOR found
    2022-04-10 04:12:36.658  - info: smartgarden.0 (16350) 2/ parseMessage: COMMON found
    2022-04-10 04:12:36.673  - info: smartgarden.0 (16350) 2/ parseMessage: MOWER found
    2022-04-10 04:12:36.698  - info: smartgarden.0 (16350) 2/ parseMessage: COMMON found
    2022-04-10 04:12:36.723  - info: smartgarden.0 (16350) 2/ parseMessage: VALVE_SET found
    2022-04-10 04:12:36.729  - info: smartgarden.0 (16350) 2/ parseMessage: VALVE found
    2022-04-10 04:12:36.736  - info: smartgarden.0 (16350) 2/ parseMessage: COMMON found
    2022-04-10 04:12:36.742  - info: smartgarden.0 (16350) 2/ parseMessage: VALVE_SET found
    2022-04-10 04:12:36.748  - info: smartgarden.0 (16350) 2/ parseMessage: VALVE found
    2022-04-10 04:12:36.755  - info: smartgarden.0 (16350) 2/ parseMessage: COMMON found
    Danach wird gepongt und anderes...
    2022-04-10 05:57:35.973  - info: smartgarden.0 (16350) 2/ on_pong: ++ pong'ed ++
    2022-04-10 05:57:36.335  - info: smartgarden.0 (16350) 2/ parseMessage: MOWER found
    2022-04-10 05:57:36.335  - info: smartgarden.0 (16350) 2/ setServiceStates: relationship searching
    2022-04-10 05:57:36.348  - info: smartgarden.0 (16350) 2/ parseMessage: COMMON found
    2022-04-10 05:57:36.349  - info: smartgarden.0 (16350) 2/ setServiceStates: relationship searching
    Und dann exakt 2 Stunden nach dem Start nur die eine Zeile (und danach keine Pongs mehr):
    2022-04-10 06:12:35.884  - info: smartgarden.0 (16350) 2/ on_close: ### closed ### close.code=1001 close.reason=Going away
    • S stevie77
      @bluebook Genau das Problem habe ich auch seit ein paar Tagen. Läuft ein paar Stunden und dann geht die Instanz auf gelb. Log muss ich nachreichen, heute Nacht sah es so aus, als hätte ich einen Restart gemacht, bin mir aber nicht mehr ganz sicher.
      premoP Online
      premoP Online
      premo
      schrieb am zuletzt editiert von premo
      #772
      @stevie77 sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
      Hallo
      Habe auch das Problem und bis es eine Lösung gibt ein Blockly angelegt
      der den Datenpunkt Device or service connected von false auf true schaltet.
      Mit der Eventlist Instanz sehe wann die Verbindung abbricht.
      jpgorganizerJ 1 Antwort Letzte Antwort
      • premoP premo
        Hallo
        jpgorganizerJ Offline
        jpgorganizer
        #773
        @premo sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
        Hallo
        das nützt aber wohl nix, da hast du nur den Farbeimer rausgeholt.
        smartgarden Adapter für GARDENA smart system
        Plattform: Raspberry Pi OS Linux 12 (bookworm), Node.js: v18.18.2, NPM: 9.8.1
        • jpgorganizerJ jpgorganizer
          Hallo
          jpgorganizer
          #774
          schaut mal hier. Wäre hilfreich, wenn ihr mit-testen würdet
          https://github.com/jpgorganizer/ioBroker.smartgarden/issues/43#issuecomment-1094299783
            berndpehome
            #775
            Habe jetzt bei Version 1.0.5 die Api Version ausgetauscht, bleibt Gelb.
            Downgrade auf Version auf 1.0.4 macht den Adapter wieder Grün, wenn ich auf Aktualisieren der Instanz gehe wird er wieder Gelb und bleibt auch Gelb,
            neustarten macht ihn aber wieder Grün, das funktioniert bei Version 1.0.5 nicht.
            • C Offline
              Cosmicbase
              schrieb am zuletzt editiert von Cosmicbase
              #776
              Hallo, in der Gardena Smart Garden App kann man doch die aktuelle Temperatur und Bodenfeuchte durch "Swipe to Refresh" aktualisieren.
              Damit wird auch der Timestamp im Adapter neu gesetzt.
              Kann ich das Szenario auch im Adapter durchführen.
              Ich will den manuellen Refresh nicht immer in der App machen.
              Vielen Dank für die Hilfe.
              • C Cosmicbase
                jpgorganizer
                #777
                @cosmicbase sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
                da geht es um den Sensor? wenn ja, dann nein. Meines wissens hat der Sensor über die Public API keine Abfragemöglichkeit.
                C 1 Antwort Letzte Antwort
                • B berndpehome
                  jpgorganizer
                  #778
                  @berndpehome sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
                  sorry, aber das ist mir zu wirr
                    Cosmicbase
                    #779
                    @jpgorganizer
                    Ja ich meinte den Sensor. In der App kann man bei der Temp. und Bodenfeuchte einen refresh machen.
                    Hätte gedacht das es im Adapter auch möglich ist. Wäre durchaus sinnvoll um kurzfristig neue Werte zu bekommen.
                    • C Cosmicbase
                      @jpgorganizer
                      jpgorganizer
                      schrieb am zuletzt editiert von jpgorganizer
                      #780
                      @jpgorganizer
                      ob sinnvoll oder nicht sinnvoll. Darum geht es nicht. Es geht ums "möglich sein".
                      Aktuell gibt es in der API kein Kommando für den Sensor.
                      Bisher habe ich den Sensor auch immer so verstanden, dass er neue Werte schickt, wenn es neue Werte gibt. Wenn das so ist, dann braucht man nicht abfragen, bzw. man bekommt auch nichts anderes zurück als man schon weiß.
                      Aber ich hab keinen Sensor, somit kann ich es nicht prüfen.
                        @jpgorganizer
                        Cosmicbase
                        #781
                        @jpgorganizer
                        OK, danke dir. Dann weiß ich bescheid.
                          berndpehome
                          #782
                          @jpgorganizer said in [neuer Adapter] smartgarden adapter for Gardena smart system:
                          Haha, sorry von mir.
                          Ich habe gestern dann nochmal auf 1.0.5 aktuallisiert und deine neue Api eingespielt, wurde nícht sofort Grün aber als ich nach ca. 4 Stunden reingesehen habe war er Grün und ist jetzt seit ca. 22 Stunden Grün, scheint also mit der API zu funktionieren, danke.
                          • FlexerF Offline
                            FlexerF Offline
                            Flexer
                            schrieb am zuletzt editiert von Flexer
                            #783
                            Hallo in die Runde.
                            Ich bekomme aktuell folgende Meldung
                            Error: sendCommand: command not send, because not connected to Gardena Webservice
                            Sobald ich den Adapter neu starte geht wieder alles für ein paar Stunden. Hat jemand auch das Problem?
                            Unterm Strich ist alles besser.
                            Ja, voll geil hier!
                            S M premoP K 4 Antworten Letzte Antwort
                            • FlexerF Flexer
                              Hallo in die Runde.
                              stevie77
                              #784
                              @flexer Ja, klar. Hab ich auch, wenn der Adapter halt nicht verbunden ist. Dann können auch keine Kommandos an den Server gesendet werden. So erkläre ich mir das zumindest. Das ist ja gerade das Problem, das uns aktuell plagt. ;-)
                              FlexerF 1 Antwort Letzte Antwort
                              • FlexerF Flexer
                                Hallo in die Runde.
                                michihorn
                                #785
                                @flexer JAP ich schließe mich an
                                • FlexerF Flexer
                                  Hallo in die Runde.
                                  premoP Online
                                  premoP Online
                                  premo
                                  #786
                                  @flexer sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
                                  Bei mir auch so.
                                  @jpgorganizer sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
                                  Habe 2 Datenpunkte unter system.adapter.smartgarden.0 gefunden und lauten smartgarden.0 alive und smartgarden.0 is connected. Diese Datenpunkte von false auf true zurück steuern.
                                  Mit dieser Vorgehensweise wird der smartgarden Adapter gestoppt und neu gestartet werden. Danach werden die smartgarden Datenpunkt neu aktuallisiert.
                                  • S stevie77
                                    FlexerF Offline
                                    FlexerF Offline
                                    Flexer
                                    #787
                                    @stevie77 Ah ok wusste nicht was der aktuelle Stand ist. Habe die letzten 234 postings nicht gelesen. Dann ist das Problem wohl Gardenaseitig
                                    Ja, voll geil hier!
                                    • FlexerF Flexer
                                      Hallo in die Runde.
                                      KaiGu
                                      #788
                                      @flexer habe das identische Problem 😟 hoffe, dass es bald wieder stabil läuft und Gardena dran ist um es zu lösen
                                      • K KaiGu
                                        jpgorganizer
                                        #789
                                        Wer Problem mit dem Aufrechterhalten der Verbindung hat, möge mal hier weiterlesen: https://github.com/jpgorganizer/ioBroker.smartgarden/issues/43#issuecomment-1098956841
                                        FlexerF 2 Antworten Letzte Antwort
                                        • J Offline
                                          jupzup
                                          schrieb am zuletzt editiert von jupzup
                                          #790
                                          Habe schon seit einigen Wochen das Problem gehabt, dass der Adapter immer nach einigen Stunden die Verbindung verlor und die Instanz auf Gelb ging. Ein Neustart der Instanz hat dann wieder für ein paar Stunden geholfen.
                                          Der Austausch der neuen API scheint bei mir auch zu funktionieren seit gestern ist die Verbindung nicht mehr abgebrochen.
