  4. [ESPHome] Beta release
591 Beiträge 48 Kommentatoren 238.9k Aufrufe 39 Beobachtet
  • M maxpd
    @Dutchman
    Ich hab meinen Servo, der bisher nur die Level Variable hat eingebunden.
    Das ist das esp script:
    esphome:
      platform: ESP8266
      board: d1_mini
    wifi:
      ssid: !secret wifi_ssid
      password: !secret wifi_password
      # Enable fallback hotspot (captive portal) in case wifi connection fails
      ap:
        ssid: "Little Wemos Fallback Hotspot"
        password: "************"
    captive_portal:
    # Enable logging
    logger:
    api:
      services:
        - service: control_servo
          variables:
            level: float
          then:
            - servo.write:
                level: !lambda 'return level / 1000.0;'
    ota:
    output:
      - platform: esp8266_pwm
        pin: D3
        frequency: 50 Hz
    servo:
      - id: my_servo
        output: pwm_output
    Das ist das Debug Log hierzu.
    esphome.0
    2022-03-17 15:42:40.693	debug	Create_state called for : C45BBEDDA7E1.info._online with value : true
    esphome.0
    2022-03-17 15:42:40.661	debug	MODIFY to hasDeepSleep: ""
    esphome.0
    2022-03-17 15:42:40.660	debug	Create_state called for : C45BBEDDA7E1.info.hasDeepSleep with value : false
    esphome.0
    2022-03-17 15:42:40.660	debug	create id C45BBEDDA7E1.info.hasDeepSleep with value false and name hasDeepSleep
    esphome.0
    2022-03-17 15:42:40.598	debug	MODIFY to model: ""
    esphome.0
    2022-03-17 15:42:40.597	debug	Create_state called for : C45BBEDDA7E1.info.model with value : d1_mini
    esphome.0
    2022-03-17 15:42:40.597	debug	create id C45BBEDDA7E1.info.model with value d1_mini and name model
    esphome.0
    2022-03-17 15:42:40.573	debug	MODIFY to compilationTime: ""
    esphome.0
    2022-03-17 15:42:40.572	debug	Create_state called for : C45BBEDDA7E1.info.compilationTime with value : Mar 17 2022, 15:38:01
    esphome.0
    2022-03-17 15:42:40.572	debug	create id C45BBEDDA7E1.info.compilationTime with value Mar 17 2022, 15:38:01 and name compilationTime
    esphome.0
    2022-03-17 15:42:40.551	debug	MODIFY to esphomeVersion: ""
    esphome.0
    2022-03-17 15:42:40.551	debug	Create_state called for : C45BBEDDA7E1.info.esphomeVersion with value : 2022.3.0
    esphome.0
    2022-03-17 15:42:40.550	debug	create id C45BBEDDA7E1.info.esphomeVersion with value 2022.3.0 and name esphomeVersion
    esphome.0
    2022-03-17 15:42:40.475	info	ESPHome client little_wemos on ip 192.168.178.53 initialized
    esphome.0
    2022-03-17 15:42:40.474	debug	192.168.178.53 client log ListEntitiesDoneResponse
    esphome.0
    2022-03-17 15:42:40.472	debug	192.168.178.53 client data
    esphome.0
    2022-03-17 15:42:40.460	debug	MODIFY to macAddress: ""
    esphome.0
    2022-03-17 15:42:40.459	debug	Create_state called for : C45BBEDDA7E1.info.macAddress with value : C4:5B:BE:DD:A7:E1
    esphome.0
    2022-03-17 15:42:40.459	debug	create id C45BBEDDA7E1.info.macAddress with value C4:5B:BE:DD:A7:E1 and name macAddress
    esphome.0
    2022-03-17 15:42:40.436	debug	MODIFY to name: ""
    esphome.0
    2022-03-17 15:42:40.435	debug	Create_state called for : C45BBEDDA7E1.info.name with value : little_wemos
    esphome.0
    2022-03-17 15:42:40.434	debug	create id C45BBEDDA7E1.info.name with value little_wemos and name name
    esphome.0
    2022-03-17 15:42:40.430	debug	192.168.178.53 client log ListEntitiesServicesResponse
    esphome.0
    2022-03-17 15:42:40.426	debug	192.168.178.53 client data ) control_servo>�S� level
    esphome.0
    2022-03-17 15:42:40.406	debug	MODIFY to usesPassword: ""
    esphome.0
    2022-03-17 15:42:40.405	debug	Create_state called for : C45BBEDDA7E1.info.usesPassword with value : false
    esphome.0
    2022-03-17 15:42:40.404	debug	create id C45BBEDDA7E1.info.usesPassword with value false and name usesPassword
    esphome.0
    2022-03-17 15:42:40.384	debug	192.168.178.53 client log DeviceInfoResponse
    esphome.0
    2022-03-17 15:42:40.380	debug	DeviceInfo little_wemos: {"192.168.178.53":{"ip":"192.168.178.53","mac":"C4:5B:BE:DD:A7:E1","deviceInfo":{"usesPassword":false,"name":"little_wemos","macAddress":"C4:5B:BE:DD:A7:E1","esphomeVersion":"2022.3.0","compilationTime":"Mar 17 2022, 15:38:01","model":"d1_mini","hasDeepSleep":false},"deviceName":"C45BBEDDA7E1","deviceInfoName":"little_wemos","passWord":""}}
    esphome.0
    2022-03-17 15:42:40.378	debug	DeviceData: {"usesPassword":false,"name":"little_wemos","macAddress":"C4:5B:BE:DD:A7:E1","esphomeVersion":"2022.3.0","compilationTime":"Mar 17 2022, 15:38:01","model":"d1_mini","hasDeepSleep":false}
    esphome.0
    2022-03-17 15:42:40.378	info	ESPHome Device info received for little_wemos
    esphome.0
    2022-03-17 15:42:40.375	debug	192.168.178.53 client data Klittle_wemosC4:5B:BE:DD:A7:E1"2022.3.0*Mar 17 2022, 15:38:012d1_mini
    esphome.0
    2022-03-17 15:42:40.359	info	ESPHome client 192.168.178.53 connected
    esphome.0
    2022-03-17 15:42:40.358	debug	192.168.178.53 client log ConnectResponse
    esphome.0
    2022-03-17 15:42:40.356	debug	192.168.178.53 client data
    esphome.0
    2022-03-17 15:42:40.341	debug	192.168.178.53 client log HelloResponse
    esphome.0
    2022-03-17 15:42:40.337	debug	192.168.178.53 client data 4 little_wemos (esphome v2022.3.0)"little_wemos
    esphome.0
    2022-03-17 15:42:40.323	debug	192.168.178.53 client log PingResponse
    esphome.0
    2022-03-17 15:42:40.320	debug	192.168.178.53 client data
    esphome.0
    2022-03-17 15:42:40.286	debug	espHomeDashboard_Process {"_events":{},"_eventsCount":0,"_maxListeners":100,"_closesNeeded":3,"_closesGot":0,"connected":false,"signalCode":null,"exitCode":null,"killed":false,"spawnfile":"npm","_handle":{"pid":16308},"spawnargs":["npm","run","-s","nopy","/opt/iobroker/node_modules/iobroker.esphome/python_modules/bin/esphome","dashboard","/opt/iobroker/iobroker-data/esphome.0"],"pid":16308,"stdin":{"connecting":false,"_hadError":false,"_parent":null,"_host":null,"_readableState":{"objectMode":false,"highWaterMark":16384,"buffer":{"head":null,"tail":null,"length":0},"length":0,"pipes":[],"flowing":null,"ended":false,"endEmitted":false,"reading":false,"sync":true,"needReadable":false,"emittedReadable":false,"readableListening":false,"resumeScheduled":false,"errorEmitted":false,"emitClose":false,"autoDestroy":false,"destroyed":false,"errored":null,"closed":false,"closeEmitted":false,"defaultEncoding":"utf8","awaitDrainWriters":null,"multiAwaitDrain":false,"readingMore":false,"dataEmitted":false,"decoder":null,"encoding":null,"readable":false},"_events":{},"_eventsCount":1,"_maxListeners":100,"_writableState":{"objectMode":false,"highWaterMark":16384,"finalCalled":false,"needDrain":false,"ending":false,"ended":false,"finished":false,"destroyed":false,"decodeStrings":false,"defaultEncoding":"utf8","length":0,"writing":false,"corked":0,"sync":true,"bufferProcessing":false,"writecb":null,"writelen":0,"afterWriteTickInfo":null,"buffered":[],"bufferedIndex":0,"allBuffers":true,"allNoop":true,"pendingcb":0,"prefinished":false,"errorEmitted":false,"emitClose":false,"autoDestroy":false,"errored":null,"closed":false,"closeEmitted":false},"allowHalfOpen":false,"_sockname":null,"_pendingData":null,"_pendingEncoding":"","server":null,"_server":null},"stdout":{"connecting":false,"_hadError":false,"_parent":null,"_host":null,"_readableState":{"objectMode":false,"highWaterMark":16384,"buffer":{"head":null,"tail":null,"length":0},"length":0,"pipes":[],"flowing":null,"ended":false,"endEmitted":false,"reading":true,"sync":false,"needReadable":true,"emittedReadable":false,"readableListening":false,"resumeScheduled":false,"errorEmitted":false,"emitClose":false,"autoDestroy":false,"destroyed":false,"errored":null,"closed":false,"closeEmitted":false,"defaultEncoding":"utf8","awaitDrainWriters":null,"multiAwaitDrain":false,"readingMore":false,"dataEmitted":false,"decoder":null,"encoding":null},"_events":{},"_eventsCount":2,"_maxListeners":100,"_writableState":{"objectMode":false,"highWaterMark":16384,"finalCalled":false,"needDrain":false,"ending":false,"ended":false,"finished":false,"destroyed":false,"decodeStrings":false,"defaultEncoding":"utf8","length":0,"writing":false,"corked":0,"sync":true,"bufferProcessing":false,"writecb":null,"writelen":0,"afterWriteTickInfo":null,"buffered":[],"bufferedIndex":0,"allBuffers":true,"allNoop":true,"pendingcb":0,"prefinished":false,"errorEmitted":false,"emitClose":false,"autoDestroy":false,"errored":null,"closed":false,"writable":false,"closeEmitted":false},"allowHalfOpen":false,"_sockname":null,"_pendingData":null,"_pendingEncoding":"","server":null,"_server":null},"stderr":{"connecting":false,"_hadError":false,"_parent":null,"_host":null,"_readableState":{"objectMode":false,"highWaterMark":16384,"buffer":{"head":null,"tail":null,"length":0},"length":0,"pipes":[],"flowing":null,"ended":false,"endEmitted":false,"reading":true,"sync":false,"needReadable":true,"emittedReadable":false,"readableListening":false,"resumeScheduled":false,"errorEmitted":false,"emitClose":false,"autoDestroy":false,"destroyed":false,"errored":null,"closed":false,"closeEmitted":false,"defaultEncoding":"utf8","awaitDrainWriters":null,"multiAwaitDrain":false,"readingMore":false,"dataEmitted":false,"decoder":null,"encoding":null},"_events":{},"_eventsCount":2,"_maxListeners":100,"_writableState":{"objectMode":false,"highWaterMark":16384,"finalCalled":false,"needDrain":false,"ending":false,"ended":false,"finished":false,"destroyed":false,"decodeStrings":false,"defaultEncoding":"utf8","length":0,"writing":false,"corked":0,"sync":true,"bufferProcessing":false,"writecb":null,"writelen":0,"afterWriteTickInfo":null,"buffered":[],"bufferedIndex":0,"allBuffers":true,"allNoop":true,"pendingcb":0,"prefinished":false,"errorEmitted":false,"emitClose":false,"autoDestroy":false,"errored":null,"closed":false,"writable":false,"closeEmitted":false},"allowHalfOpen":false,"_sockname":null,"_pendingData":null,"_pendingEncoding":"","server":null,"_server":null},"stdio":[{"connecting":false,"_hadError":false,"_parent":null,"_host":null,"_readableState":{"objectMode":false,"highWaterMark":16384,"buffer":{"head":null,"tail":null,"length":0},"length":0,"pipes":[],"flowing":null,"ended":false,"endEmitted":false,"reading":false,"sync":true,"needReadable":false,"emittedReadable":false,"readableListening":false,"resumeScheduled":false,"errorEmitted":false,"emitClose":false,"autoDestroy":false,"destroyed":false,"errored":null,"closed":false,"closeEmitted":false,"defaultEncoding":"utf8","awaitDrainWriters":null,"multiAwaitDrain":false,"readingMore":false,"dataEmitted":false,"decoder":null,"encoding":null,"readable":false},"_events":{},"_eventsCount":1,"_maxListeners":100,"_writableState":{"objectMode":false,"highWaterMark":16384,"finalCalled":false,"needDrain":false,"ending":false,"ended":false,"finished":false,"destroyed":false,"decodeStrings":false,"defaultEncoding":"utf8","length":0,"writing":false,"corked":0,"sync":true,"bufferProcessing":false,"writecb":null,"writelen":0,"afterWriteTickInfo":null,"buffered":[],"bufferedIndex":0,"allBuffers":true,"allNoop":true,"pendingcb":0,"prefinished":false,"errorEmitted":false,"emitClose":false,"autoDestroy":false,"errored":null,"closed":false,"closeEmitted":false},"allowHalfOpen":false,"_sockname":null,"_pendingData":null,"_pendingEncoding":"","server":null,"_server":null},{"connecting":false,"_hadError":false,"_parent":null,"_host":null,"_readableState":{"objectMode":false,"highWaterMark":16384,"buffer":{"head":null,"tail":null,"length":0},"length":0,"pipes":[],"flowing":null,"ended":false,"endEmitted":false,"reading":true,"sync":false,"needReadable":true,"emittedReadable":false,"readableListening":false,"resumeScheduled":false,"errorEmitted":false,"emitClose":false,"autoDestroy":false,"destroyed":false,"errored":null,"closed":false,"closeEmitted":false,"defaultEncoding":"utf8","awaitDrainWriters":null,"multiAwaitDrain":false,"readingMore":false,"dataEmitted":false,"decoder":null,"encoding":null},"_events":{},"_eventsCount":2,"_maxListeners":100,"_writableState":{"objectMode":false,"highWaterMark":16384,"finalCalled":false,"needDrain":false,"ending":false,"ended":false,"finished":false,"destroyed":false,"decodeStrings":false,"defaultEncoding":"utf8","length":0,"writing":false,"corked":0,"sync":true,"bufferProcessing":false,"writecb":null,"writelen":0,"afterWriteTickInfo":null,"buffered":[],"bufferedIndex":0,"allBuffers":true,"allNoop":true,"pendingcb":0,"prefinished":false,"errorEmitted":false,"emitClose":false,"autoDestroy":false,"errored":null,"closed":false,"writable":false,"closeEmitted":false},"allowHalfOpen":false,"_sockname":null,"_pendingData":null,"_pendingEncoding":"","server":null,"_server":null},{"connecting":false,"_hadError":false,"_parent":null,"_host":null,"_readableState":{"objectMode":false,"highWaterMark":16384,"buffer":{"head":null,"tail":null,"length":0},"length":0,"pipes":[],"flowing":null,"ended":false,"endEmitted":false,"reading":true,"sync":false,"needReadable":true,"emittedReadable":false,"readableListening":false,"resumeScheduled":false,"errorEmitted":false,"emitClose":false,"autoDestroy":false,"destroyed":false,"errored":null,"closed":false,"closeEmitted":false,"defaultEncoding":"utf8","awaitDrainWriters":null,"multiAwaitDrain":false,"readingMore":false,"dataEmitted":false,"decoder":null,"encoding":null},"_events":{},"_eventsCount":2,"_maxListeners":100,"_writableState":{"objectMode":false,"highWaterMark":16384,"finalCalled":false,"needDrain":false,"ending":false,"ended":false,"finished":false,"destroyed":false,"decodeStrings":false,"defaultEncoding":"utf8","length":0,"writing":false,"corked":0,"sync":true,"bufferProcessing":false,"writecb":null,"writelen":0,"afterWriteTickInfo":null,"buffered":[],"bufferedIndex":0,"allBuffers":true,"allNoop":true,"pendingcb":0,"prefinished":false,"errorEmitted":false,"emitClose":false,"autoDestroy":false,"errored":null,"closed":false,"writable":false,"closeEmitted":false},"allowHalfOpen":false,"_sockname":null,"_pendingData":null,"_pendingEncoding":"","server":null,"_server":null}]}
    esphome.0
    2022-03-17 15:42:40.272	info	Native Integration of ESPHome Dashboard enabled
    esphome.0
    2022-03-17 15:42:40.268	info	Auto Discovery startet, new devices (or IP changes) will be detected automatically
    maxpd
    #539
    @Dutchman
    Wenn ich lediglich ein Script über 1 oder 2 Template Buttons
    https://esphome.io/components/button/template.html
    starten möchte und die gesamte restliche Logik und Variablen etc direkt auf dem ESP platziere, was benötigst du dann an Informationen?
    maxpd
    • M maxpd
      @Dutchman
      DutchmanD Offline
      DutchmanD Offline
      Dutchman
      #540
      @maxpd sagte in [ESPHome] Beta release:
      ich glaube nix :) die frage ist ob ein template Button Exposed wird.
      Mal mal bitte einen in der yaml (kan ich später erst probieren) und schaue was passiert.
      We der wert Pere Opi uebertragen wird koennen 2 Sachen passieren:
      • die daten passen in die jetzigen Adapter code
      • es ist eine neue, unbekannte entity
        Beim zweiten fall wuerde eine fehler/warnung in ioBroker log sichtbar sein und die infos brauche ich dan
      • DutchmanD Dutchman
        maxpd
        schrieb am zuletzt editiert von maxpd
        #541
        @dutchman Ich glaube dir hat die Spracheingabe den Text ein bissl versämmelt :D
        Aber ich hab die yaml hier gebaut
        esphome:
          platform: ESP8266
          board: d1_mini
        wifi:
          ap:
        captive_portal:
        # Enable logging
        logger:
        api:
          services:
              variables:
                level: float
              then:
                - servo.write:
                    level: !lambda 'return level / 100.0;'
        ota:
        output:
            pin: D3
            frequency: 50 Hz
        servo:
          - id: my_servo
            output: pwm_output
        button:
          - platform: template
            on_press:
              - logger.log: Button Pressed
              - cover.open: flying
              - delay: 8s
              - cover.close: flying
              - delay: 9s
        cover:
          - platform: time_based
            open_action:
        #      then:
              - servo.write:
                  level: 10.0%
            open_duration: 5s
            close_action:
        #      then:
              - servo.write:
                  level: -10.0%
            close_duration: 6s
            stop_action:
        #      then:
              - servo.write:
                  level: 0%
              - servo.detach: my_servo
        und bekomme die Ausgabe. Wobei mein wemos plötzlich immer disconnected. Liegt eventuell am Update auf die 2022.03?
        esphome.0
        2022-03-22 20:14:42.592	debug	192.168.178.53 client data 4 little_wemos (esphome v2022.3.0)"little_wemos
        esphome.0
        2022-03-22 20:14:42.575	error	ESPHome client 192.168.178.53 TypeError: Cannot read property 'deserializeBinary' of undefined
        esphome.0
        2022-03-22 20:14:42.574	debug	192.168.178.53 client data
        esphome.0
        2022-03-22 20:14:13.912	debug	esphome.0 (13292) [ESPHome - Console] 2022-03-22 20:14:13,912 INFO 304 GET /devices (192.168.178.146) 1.62ms
        esphome.0
        2022-03-22 20:14:12.535	warn	Client 192.168.178.53 Timeout, connection Lost, will reconnect automatically when device is available!
        esphome.0
        2022-03-22 20:14:09.061	debug	esphome.0 (13292) [ESPHome - Console] 2022-03-22 20:14:09,061 INFO Running command 'esphome --dashboard -q vscode --ace /opt/iobroker/iobroker-data/esphome.0'
        esphome.0
        2022-03-22 20:14:08.989	debug	esphome.0 (13292) [ESPHome - Console] 2022-03-22 20:14:08,989 INFO 101 GET /ace (192.168.178.146) 1.17ms
        esphome.0
        2022-03-22 20:14:08.971	debug	esphome.0 (13292) [ESPHome - Console] 2022-03-22 20:14:08,970 INFO 200 GET /static/fonts/material-icons/MaterialIcons-Regular.woff2 (192.168.178.146) 1.87ms
        esphome.0
        2022-03-22 20:14:08.913	debug	esphome.0 (13292) [ESPHome - Console] 2022-03-22 20:14:08,913 INFO 304 GET /devices (192.168.178.146) 1.58ms
        esphome.0
        2022-03-22 20:14:08.877	debug	esphome.0 (13292) [ESPHome - Console] 2022-03-22 20:14:08,876 INFO 200 GET /static/js/vendor/ace/mode-yaml.js (192.168.178.146) 2.07ms
        esphome.0
        2022-03-22 20:14:08.874	debug	esphome.0 (13292) [ESPHome - Console] 2022-03-22 20:14:08,873 INFO 200 GET /static/js/vendor/ace/theme-dreamweaver.js (192.168.178.146) 1.69ms
        esphome.0
        2022-03-22 20:14:08.696	debug	esphome.0 (13292) [ESPHome - Console] 2022-03-22 20:14:08,696 INFO 200 GET /static/js/vendor/jquery-ui/jquery-ui.min.js?hash=cab3392d (192.168.178.146) 189.47ms
        esphome.0
        2022-03-22 20:14:08.666	debug	esphome.0 (13292) [ESPHome - Console] 2022-03-22 20:14:08,666 INFO 200 GET /static/js/vendor/materialize/materialize.min.js?hash=4be20daf (192.168.178.146) 158.14ms
        esphome.0
        2022-03-22 20:14:08.636	debug	esphome.0 (13292) [ESPHome - Console] 2022-03-22 20:14:08,635 INFO 200 GET /static/js/esphome/index-92d154f2.js (192.168.178.146) 114.09ms
        esphome.0
        2022-03-22 20:14:08.633	debug	esphome.0 (13292) [ESPHome - Console] 2022-03-22 20:14:08,633 INFO 200 GET /static/js/vendor/ace/ace.js?hash=65322f49 (192.168.178.146) 124.26ms
        esphome.0
        2022-03-22 20:14:08.516	debug	esphome.0 (13292) [ESPHome - Console] 2022-03-22 20:14:08,515 INFO 200 GET /static/js/vendor/jquery-validate/jquery.validate.min.js?hash=aad785d4 (192.168.178.146) 8.16ms
        esphome.0
        2022-03-22 20:14:08.511	debug	esphome.0 (13292) [ESPHome - Console] 2022-03-22 20:14:08,511 INFO 200 GET /static/js/vendor/jquery/jquery.min.js?hash=12108007 (192.168.178.146) 5.14ms
        esphome.0
        2022-03-22 20:14:08.462	debug	esphome.0 (13292) [ESPHome - Console] 2022-03-22 20:14:08,461 INFO 200 GET /static/css/esphome-2.css?hash=b79b4733 (192.168.178.146) 7.20ms
        esphome.0
        2022-03-22 20:14:08.459	debug	esphome.0 (13292) [ESPHome - Console] 2022-03-22 20:14:08,459 INFO 200 GET /static/css/vendor/materialize/materialize.min.css?hash=ec1df3ba (192.168.178.146) 5.40ms
        esphome.0
        2022-03-22 20:14:08.452	debug	esphome.0 (13292) [ESPHome - Console] 2022-03-22 20:14:08,450 INFO 200 GET /static/fonts/material-icons/material-icons.css?hash=ead4c276 (192.168.178.146) 3.75ms
        esphome.0
        2022-03-22 20:14:08.449	debug	esphome.0 (13292) [ESPHome - Console] 2022-03-22 20:14:08,449 INFO 200 GET /static/fonts/material-icons/MaterialIcons-Regular.woff2?hash=570eb838 (192.168.178.146) 2.71ms
        esphome.0
        2022-03-22 20:14:08.412	debug	esphome.0 (13292) [ESPHome - Console] 2022-03-22 20:14:08,411 INFO 304 GET /?instance=0&newReact=true&0&react=colored (192.168.178.146) 2.16ms
        esphome.0
        2022-03-22 20:14:07.562	error	ESPHome client 192.168.178.53 TypeError: Cannot read property 'deserializeBinary' of undefined
        esphome.0
        2022-03-22 20:14:07.561	debug	192.168.178.53 client data 4 little_wemos (esphome v2022.3.0)"little_wemos
        esphome.0
        2022-03-22 20:14:07.543	error	ESPHome client 192.168.178.53 TypeError: Cannot read property 'deserializeBinary' of undefined
        esphome.0
        2022-03-22 20:14:07.542	debug	192.168.178.53 client data
        esphome.0
        2022-03-22 20:13:37.521	warn	Client 192.168.178.53 Timeout, connection Lost, will reconnect automatically when device is available!
        maxpd
          klassisch
          #542
          Kurze Zwischenfrage: Hat schon jemand Erfahrungen mit dem MCP23016 oder PCF8575 mit ESPHome?
          Ich möchte > 8 Eingänge abfragen. Nicht zeitkritsch, Abfrageintervall von einigen Sekunden wäre kein Problem.
          Die Eingänge werden mit open collector auf GND gezogen. Wenn man einen internen pull up nutzen könnte, wäre das einfacher. Beim MCP23ß16 scheint das nicht zu gehen.
          OpenSourceNomadO 1 Antwort Letzte Antwort
          • K klassisch
            OpenSourceNomadO Offline
            OpenSourceNomad
            Most Active Gesperrt
            schrieb am zuletzt editiert von OpenSourceNomad
            #543
            @klassisch said in [ESPHome] Beta release:
            Ich glaube (wenn ich mich recht erinnere) hat der PCF8575 die blöde Eigenschaft direkt nach dem starte/nbestromen alle GPIO auf Output und high zu setzen. Erst wenn esphome die init routine durchlaufen hat sind die GPIO's vom PCF8575 auf input gesetzt.
            Die MCP230xx haben diese Eigenheit soweit ich mich erinnere nicht.
            Dafür der MCP23008 und MCP23017 wenn ich die docs passend interpretiere 💡
            • OpenSourceNomadO OpenSourceNomad
              klassisch
              #544
              Vielen Dank!
              @opensourcenomad sagte in [ESPHome] Beta release:
              ugly! Dann zerschießt er u.U. die oc Ausgänge meiner Sensoren. Müßte man also jeweils noch einen Serienwiderstand einfügen, 330 Ohm
              Das wäre gut!
              Ja steht in der ESPHome Doku so beim MCP23016
              Zumindest die bei ESPHome angegebenen Beispiele zeigen mein 08 und beim 17 die Komentarzeile
              # One of INPUT or OUTPUT
              bzw.
                    mode:
                      input: true
                      pullup: true
                    inverted: false
              die Komentarzeile
              steht auch im Beispielprogramm des PCF8574 / 5.
              So richtig eindeutig ist die Doku leider nicht.
              und der MCP23017 kostet ein Vemögen!
              Und den MCP23008 gibt es derzeit nicht als brakout Modul.
              Bleibt wohl nur PCF8575 mit Reihenwiderstand und hoffen, dass der pull up funktioniert.
                kg36304
                #545
                ich habe ESPHome auf meinem Mac installiert.
                Auf meinem Pi läuft IObroker und es klappt einfach nicht den Adapter zu Installieren (Fehrler 25)
                Wenn ich es über die Konsole mache kommt das:
                npm ERR! code 1
                npm ERR! path /opt/iobroker/node_modules/iobroker.esphome
                npm ERR! command failed
                npm ERR! command sh -c npip install
                npm ERR! No python_modules directory; installing pip locally if needed.
                npm ERR! Successfully completed pip check.
                npm ERR! Collecting esphome>=2021.8
                npm ERR!   Using cached esphome-2022.2.6-py2.py3-none-any.whl (2.1 MB)
                npm ERR! Collecting tornado>=3.2
                npm ERR!   Using cached tornado-6.1.tar.gz (497 kB)
                npm ERR!   Preparing metadata (setup.py): started
                npm ERR!   Preparing metadata (setup.py): finished with status 'done'
                npm ERR! Collecting aioesphomeapi==10.8.2
                npm ERR!   Using cached aioesphomeapi-10.8.2-py2.py3-none-any.whl (49 kB)
                npm ERR! Collecting colorama==0.4.4
                npm ERR!   Using cached colorama-0.4.4-py2.py3-none-any.whl (16 kB)
                npm ERR! Collecting esphome-dashboard==20220209.0
                npm ERR!   Using cached esphome_dashboard-20220209.0-py3-none-any.whl (592 kB)
                npm ERR! Collecting PyYAML==6.0
                npm ERR!   Using cached PyYAML-6.0.tar.gz (124 kB)
                npm ERR!   Installing build dependencies: started
                npm ERR!   Installing build dependencies: finished with status 'done'
                npm ERR!   Getting requirements to build wheel: started
                npm ERR!   Getting requirements to build wheel: finished with status 'done'
                npm ERR!   Preparing metadata (pyproject.toml): started
                npm ERR!   Preparing metadata (pyproject.toml): finished with status 'done'
                npm ERR! Collecting esptool==3.2
                npm ERR!   Using cached esptool-3.2.tar.gz (206 kB)
                npm ERR! Collecting platformio==5.2.5
                npm ERR!   Using cached platformio-5.2.5.tar.gz (218 kB)
                npm ERR! Collecting kconfiglib==13.7.1
                npm ERR!   Using cached kconfiglib-13.7.1-py2.py3-none-any.whl (145 kB)
                npm ERR! Collecting tzdata>=2021.1
                npm ERR!   Using cached tzdata-2022.1-py2.py3-none-any.whl (339 kB)
                npm ERR! Collecting click==8.0.3
                npm ERR!   Using cached click-8.0.3-py3-none-any.whl (97 kB)
                npm ERR! Collecting tzlocal==4.1
                npm ERR!   Using cached tzlocal-4.1-py3-none-any.whl (19 kB)
                npm ERR! Collecting paho-mqtt==1.6.1
                npm ERR!   Using cached paho-mqtt-1.6.1.tar.gz (99 kB)
                npm ERR! Collecting zeroconf==0.38.3
                npm ERR!   Using cached zeroconf-0.38.3-py3-none-any.whl (106 kB)
                npm ERR! Collecting voluptuous==0.12.2
                npm ERR!   Using cached voluptuous-0.12.2.tar.gz (48 kB)
                npm ERR! Collecting pyserial==3.5
                npm ERR!   Using cached pyserial-3.5-py2.py3-none-any.whl (90 kB)
                npm ERR! Collecting protobuf<4.0,>=3.12.2
                npm ERR!   Using cached protobuf-3.19.4-py2.py3-none-any.whl (162 kB)
                npm ERR! Collecting noiseprotocol<1.0,>=0.3.1
                npm ERR!   Using cached noiseprotocol-0.3.1-py3-none-any.whl (20 kB)
                npm ERR! Collecting importlib-metadata
                npm ERR!   Using cached importlib_metadata-4.11.3-py3-none-any.whl (18 kB)
                npm ERR! Collecting bitstring>=3.1.6
                npm ERR!   Using cached bitstring-3.1.9-py3-none-any.whl (38 kB)
                npm ERR! Collecting cryptography>=2.1.4
                npm ERR!   Using cached cryptography-36.0.2.tar.gz (572 kB)
                npm ERR!   Installing build dependencies: finished with status 'error'
                npm ERR! Cache entry deserialization failed, entry ignored
                npm ERR!   error: subprocess-exited-with-error
                npm ERR!
                npm ERR!   × pip subprocess to install build dependencies did not run successfully.
                npm ERR!   │ exit code: 1
                npm ERR!   ╰─> [122 lines of output]
                npm ERR!       Collecting setuptools>=40.6.0
                npm ERR!         Using cached setuptools-61.0.0-py3-none-any.whl (1.1 MB)
                npm ERR!       Collecting wheel
                npm ERR!         Using cached wheel-0.37.1-py2.py3-none-any.whl (35 kB)
                npm ERR!       Collecting cffi>=1.12
                npm ERR!         Using cached cffi-1.15.0.tar.gz (484 kB)
                npm ERR!       Collecting setuptools-rust>=0.11.4
                npm ERR!         Using cached setuptools_rust-1.2.0-py3-none-any.whl (21 kB)
                npm ERR!       Collecting pycparser
                npm ERR!         Using cached pycparser-2.21-py2.py3-none-any.whl (118 kB)
                npm ERR!       Collecting semantic-version<3,>=2.8.2
                npm ERR!         Using cached semantic_version-2.9.0-py2.py3-none-any.whl (15 kB)
                npm ERR!       Collecting typing-extensions>=3.7.4.3
                npm ERR!         Using cached typing_extensions-4.1.1-py3-none-any.whl (26 kB)
                npm ERR!       Building wheels for collected packages: cffi
                npm ERR!         Building wheel for cffi (setup.py): started
                npm ERR!         Building wheel for cffi (setup.py): finished with status 'error'
                npm ERR!
                npm ERR!         × python setup.py bdist_wheel did not run successfully.
                npm ERR!         ╰─> [36 lines of output]
                npm ERR!             running bdist_wheel
                npm ERR!             running build
                npm ERR!             running build_py
                npm ERR!             creating build
                npm ERR!             creating build/lib.linux-armv7l-3.7
                npm ERR!             creating build/lib.linux-armv7l-3.7/cffi
                npm ERR!             copying cffi/commontypes.py -> build/lib.linux-armv7l-3.7/cffi
                npm ERR!             copying cffi/pkgconfig.py -> build/lib.linux-armv7l-3.7/cffi
                npm ERR!             copying cffi/api.py -> build/lib.linux-armv7l-3.7/cffi
                npm ERR!             copying cffi/ffiplatform.py -> build/lib.linux-armv7l-3.7/cffi
                npm ERR!             copying cffi/recompiler.py -> build/lib.linux-armv7l-3.7/cffi
                npm ERR!             copying cffi/setuptools_ext.py -> build/lib.linux-armv7l-3.7/cffi
                npm ERR!             copying cffi/model.py -> build/lib.linux-armv7l-3.7/cffi
                npm ERR!             copying cffi/vengine_gen.py -> build/lib.linux-armv7l-3.7/cffi
                npm ERR!             copying cffi/vengine_cpy.py -> build/lib.linux-armv7l-3.7/cffi
                npm ERR!             copying cffi/backend_ctypes.py -> build/lib.linux-armv7l-3.7/cffi
                npm ERR!             copying cffi/__init__.py -> build/lib.linux-armv7l-3.7/cffi
                npm ERR!             copying cffi/lock.py -> build/lib.linux-armv7l-3.7/cffi
                npm ERR!             copying cffi/verifier.py -> build/lib.linux-armv7l-3.7/cffi
                npm ERR!             copying cffi/cparser.py -> build/lib.linux-armv7l-3.7/cffi
                npm ERR!             copying cffi/error.py -> build/lib.linux-armv7l-3.7/cffi
                npm ERR!             copying cffi/cffi_opcode.py -> build/lib.linux-armv7l-3.7/cffi
                npm ERR!             copying cffi/_cffi_include.h -> build/lib.linux-armv7l-3.7/cffi
                npm ERR!             copying cffi/parse_c_type.h -> build/lib.linux-armv7l-3.7/cffi
                npm ERR!             copying cffi/_embedding.h -> build/lib.linux-armv7l-3.7/cffi
                npm ERR!             copying cffi/_cffi_errors.h -> build/lib.linux-armv7l-3.7/cffi
                npm ERR!             running build_ext
                npm ERR!             building '_cffi_backend' extension
                npm ERR!             creating build/temp.linux-armv7l-3.7
                npm ERR!             creating build/temp.linux-armv7l-3.7/c
                npm ERR!             arm-linux-gnueabihf-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -g -flto -fuse-linker-plugin -ffat-lto-objects -fPIC -DUSE__THREAD -DHAVE_SYNC_SYNCHRONIZE -I/usr/include/python3.7m -c c/_cffi_backend.c -o build/temp.linux-armv7l-3.7/c/_cffi_backend.o
                npm ERR!             c/_cffi_backend.c:2:10: fatal error: Python.h: Datei oder Verzeichnis nicht gefunden
                npm ERR!              #include <Python.h>
                npm ERR!                       ^~~~~~~~~~
                npm ERR!             compilation terminated.
                npm ERR!             error: command '/usr/bin/arm-linux-gnueabihf-gcc' failed with exit code 1
                npm ERR!             [end of output]
                npm ERR!
                npm ERR!         note: This error originates from a subprocess, and is likely not a problem with pip.
                npm ERR!         ERROR: Failed building wheel for cffi
                npm ERR!         Running setup.py clean for cffi
                npm ERR!       Failed to build cffi
                npm ERR!       Installing collected packages: wheel, typing-extensions, setuptools, semantic-version, pycparser, setuptools-rust, cffi
                npm ERR!         Running setup.py install for cffi: started
                npm ERR!         Running setup.py install for cffi: finished with status 'error'
                npm ERR!
                npm ERR!         × Running setup.py install for cffi did not run successfully.
                npm ERR!         ╰─> [38 lines of output]
                npm ERR!             running install
                npm ERR!             /opt/iobroker/node_modules/iobroker.esphome/python_modules/lib/python3.7/site-packages/setuptools/command/install.py:37: SetuptoolsDeprecationWarning: setup.py install is deprecated. Use build and pip and other standards-based tools.
                npm ERR!               setuptools.SetuptoolsDeprecationWarning,
                npm ERR!                       ^~~~~~~~~~
                npm ERR!
                npm ERR!       error: legacy-install-failure
                npm ERR!
                npm ERR!       × Encountered error while trying to install package.
                npm ERR!       ╰─> cffi
                npm ERR!
                npm ERR!       note: This is an issue with the package mentioned above, not pip.
                npm ERR!       hint: See above for output from the failure.
                npm ERR!
                npm ERR!
                npm ERR! ╰─> See above for output.
                npm ERR!
                npm ERR!     /home/iobroker/.npm/_logs/2022-03-25T13_16_24_023Z-debug.log
                ich weiß jetzt nicht mehr weiter was zu tun ist und will auch nichts zerschießen. Ich möchte später dann meine verschiedenen ESP´s einbinden (ESP32 Cam und verschiedene Sensoren sowie Lichtsteuerung).
                Ich danke Euch für Eure Hilfe.
                LG
                Kai
                • K kg36304
                  npm ERR! code 1
                  npm ERR!
                  npm ERR!
                  npm ERR!                       ^~~~~~~~~~
                  npm ERR!
                  npm ERR!
                  npm ERR!                       ^~~~~~~~~~
                  npm ERR!
                  npm ERR!
                  npm ERR!       ╰─> cffi
                  npm ERR!
                  npm ERR!
                  npm ERR!
                  npm ERR!
                  LG
                  Kai
                  DutchmanD Offline
                  DutchmanD Offline
                  Dutchman
                  #546
                  @kg36304 sagte in [ESPHome] Beta release:
                  "Python.h: Datei oder Verzeichnis nicht gefunden"
                  welche python version hast du auf deinem host ?
                    kg36304
                    #547
                    @dutchman
                    also auf dem Pi auf dem IObroker läuft zeigt er mir folgendes an
                    pi@raspberrypi:~ $ python3 --version
                    Python 3.7.3
                    pi@raspberrypi:~ $
                    und
                    pi@raspberrypi:~ $ python --version
                    Python 2.7.16
                    pi@raspberrypi:~ $
                    • K kg36304
                      @dutchman
                      Python 3.7.3
                      pi@raspberrypi:~ $
                      und
                      Python 2.7.16
                      pi@raspberrypi:~ $
                      kg36304
                      #548
                      @kg36304 said in [ESPHome] Beta release:
                      @dutchman
                      Python 3.7.3
                      pi@raspberrypi:~ $
                      und
                      Python 2.7.16
                      pi@raspberrypi:~ $
                      Hab wohl 2 Versionen drauf.
                      • K kg36304
                        @dutchman
                        Python 3.7.3
                        pi@raspberrypi:~ $
                        und
                        Python 2.7.16
                        pi@raspberrypi:~ $
                        OpenSourceNomad
                        #549
                        Schlecht, vor allem weil Python auf python2 (dürfte schon länger EOL sein) verlinkt.
                        Wenn du sicher stellen kannst das du keine Kruden Abhängigkeiten auf dem System hast die noch python2 benötigen solltest du es einfach deinstallieren können. Dananch python3 updaten (3.7.3 ist schon 3 Jahre alt!) und pyhton sollte dann auch sauber auf python3 linken
                        • M maxpd
                          esphome:
                            platform: ESP8266
                            board: d1_mini
                          wifi:
                            ap:
                          captive_portal:
                          # Enable logging
                          logger:
                          api:
                            services:
                                variables:
                                  level: float
                                then:
                                  - servo.write:
                          ota:
                          output:
                              pin: D3
                              frequency: 50 Hz
                          servo:
                            - id: my_servo
                              output: pwm_output
                          button:
                              on_press:
                                - delay: 8s
                                - delay: 9s
                          cover:
                              open_action:
                          #      then:
                                - servo.write:
                                    level: 10.0%
                              open_duration: 5s
                              close_action:
                          #      then:
                                - servo.write:
                                    level: -10.0%
                              close_duration: 6s
                              stop_action:
                          #      then:
                                - servo.write:
                                    level: 0%
                          esphome.0
                          esphome.0
                          esphome.0
                          esphome.0
                          esphome.0
                          esphome.0
                          esphome.0
                          esphome.0
                          esphome.0
                          esphome.0
                          esphome.0
                          esphome.0
                          esphome.0
                          esphome.0
                          esphome.0
                          esphome.0
                          esphome.0
                          esphome.0
                          esphome.0
                          esphome.0
                          esphome.0
                          esphome.0
                          esphome.0
                          esphome.0
                          esphome.0
                          esphome.0
                          esphome.0
                          klassisch
                          #550
                          esphome:
                            platform: ESP8266
                            board: d1_mini
                          wifi:
                            ap:
                          captive_portal:
                          # Enable logging
                          logger:
                          api:
                            services:
                                variables:
                                  level: float
                                then:
                                  - servo.write:
                          ota:
                          output:
                              pin: D3
                              frequency: 50 Hz
                          servo:
                            - id: my_servo
                              output: pwm_output
                          button:
                              on_press:
                                - delay: 8s
                                - delay: 9s
                          cover:
                              open_action:
                          #      then:
                                - servo.write:
                                    level: 10.0%
                              open_duration: 5s
                              close_action:
                          #      then:
                                - servo.write:
                                    level: -10.0%
                              close_duration: 6s
                              stop_action:
                          #      then:
                                - servo.write:
                                    level: 0%
                          Sehr interessant. Ich möchte auch ein Servo ansteuern, welches einen Knopf drückt.
                          In der Primitivversion gleich nach dem Booten des ESP. In der Luxusversion auf ioBroker Befehl hin.
                          Wenn ich das richtig verstanden habe, führt Dein yaml auf einen Knopfdruck (Auslöser) hin eine Sequenz aus:
                          • es wird etwas geöffnet
                          • 8 Sekunden gewartet
                          • geschlossen
                          • 9 Sekunden gewartet
                          • Servo entlastet (PWM aus?)
                          Habe ich das richtig verstanden?
                          Was ist open_duration und close_duration? Verstellgeschwindigkeiten? so etwas wie transition length?
                          • K klassisch
                            esphome:
                              platform: ESP8266
                              board: d1_mini
                            wifi:
                              ap:
                            captive_portal:
                            # Enable logging
                            logger:
                            api:
                              services:
                                  variables:
                                    level: float
                                  then:
                                    - servo.write:
                            ota:
                            output:
                                pin: D3
                                frequency: 50 Hz
                            servo:
                              - id: my_servo
                                output: pwm_output
                            button:
                                on_press:
                                  - delay: 8s
                                  - delay: 9s
                            cover:
                                open_action:
                            #      then:
                                  - servo.write:
                                      level: 10.0%
                                open_duration: 5s
                                close_action:
                            #      then:
                                  - servo.write:
                                      level: -10.0%
                                close_duration: 6s
                                stop_action:
                            #      then:
                                  - servo.write:
                                      level: 0%
                            • geschlossen
                            maxpd
                            #551
                            @klassisch Hi, nee, nicht ganz.
                            Ich drücke mit iobroker quasi den virtuellen Button.
                            Dann wird etwas 5 Sekunden lang geöffnet (open_duration) und 3 Sekunden lang (8-5) gewartet.
                            Dann 6 Sekunden geschlossen (close duration) und 3 Sekunden gewartet.
                            Stop Action bislang nicht verwendet. Der Servo scheint nicht unter Last, wird zumindest nicht warm.
                            maxpd
                              klassisch
                              #552
                              Vielen Dank!
                              Habe heute etwas zusammengefrickelt.
                              button: wirft bei mir eine Fehlermeldung, unknown command
                              Habe die ESPHome Version 1.20.4 in der das eigentlich schon drin sein sollte. Das habe ich überhaupt nicht verstanden.
                              Um überhaupt was zustande zu bekommen, habe ich jetzt mit on_boot gearbeitet, was in meiner Applikation auch eine Möglichkeit wäre, wenn auch keine sehr elegante.
                              Dabei mußte ich *priority: 250 * setzen, sonst wurde PWM nicht gestartet. Auch mit Pin D1 hatte ich meine Mühe, D6 verwende ich generell lieber, da weniger Restriktionen.
                              Habe dann das ganze wifi-Zeugs und api erst mal deaktiviert. Damit geht die Servo-Bewegung recht zügig nach dem Booten los.
                              Also zumindest mal ein Teilerfolg und notfalls kann ich den ESP wie einen kommunikationslosen Arduino nano ohne Wifi betreiben. Bestromen, er macht seine Moves und danach wieder abschalten.
                              Vielen Dank jedenfalls für Deine Vorlage. Hat mich schon mal ein ganzes Stück weiter gebracht.
                              • K klassisch
                                Vielen Dank!
                                OpenSourceNomad
                                #553
                                Die Version esphome 1.20 ist vom Julie 2021 aber (template) buttons unterstützt esphome erst seit version 2021.12 (geänderte Versionierung) vom Ende letzten Jahres. Aktuell ist gerade 2022.03 und gleich ist 2022.04 fällig.
                                Die (template) switch component ermöglicht im Grunde das gleiche jedoch mit zwei actions wenn gewünscht.
                                Update zur aktuellsten esphome Version in iobroker ist trivial, wenn auch nicht ganz intuitiv:
                                @steimi said in [ESPHome] Beta release:
                                einfach unter "Adapter -> eine bestimmte Version" die aktuelle Version 0.2.4 nochmal installieren. Dabei zieht er sich die aktuelle ESPhome-Version
                                  klassisch
                                  schrieb am zuletzt editiert von klassisch
                                  #554
                                  Vieen Dank, werde das mal testen. Denke ich habe das beim CO2 Sensor zur Verarbeitung des physikalischen buttons zum Start der Kalibrierung verwendet
                                  Das mag bei mir etwas anders sein. Arbeite ja auch in ioBroker unter Win und da geht das Dashboard nicht.
                                  Und dann nutze ich meine ursprüngliche ESPHome Entwicklungsumgebung auf meinem Alltagsrechner (also nicht dem ioBroker Rechner) weiter und übersetze dort.
                                  Ich hatte heute auch mit pip3 unter python ESPHome neu installiert und bin wieder bei der 1.20.4 vom August gelandet. Deshalb wähnte ich mich da aktuell zu sein.
                                  Das Versionsmanagement und Updatemanagement vom ESPHome erschließt sich mir nicht so ganz.
                                  • OpenSourceNomadO Offline
                                    OpenSourceNomad
                                    #555
                                    https://esphome.io/guides/faq.html#how-do-i-update-to-the-latest-version
                                    Was wirft er denn in der Konsole aus wenn du das ☝ reinhämmerst? ⌨🔨
                                    Mit der Umstellung auf die Versionierung mit Jahr+Monat gibt es monatlich ein release (zzgl. bugfix releases).
                                    @opensourcenomad said in [ESPHome] Beta release:
                                      klassisch
                                      #556
                                      Vielen Dank hat jetzt funktioniert. Peinlicherweise war ich bereits mal auf dieser Seite. Hatte aber nur "Docker" gelesen und dann zu schnell gescippt.
                                      Hatte die üblichen Verdächtigen wie -update -upgrade schon durchprobiert
                                      Version: 2022.3.2
                                      Da bin ich gelandet.
                                      Vielen Dank nochmals!
                                      • K klassisch
                                        Version: 2022.3.2
                                        maxpd
                                        #557
                                        @klassisch Ich hatte es schlussendlich auch via Switch gelöst, fällt mir ein:
                                        https://github.com/DrozmotiX/ioBroker.esphome/issues/127
                                        maxpd
                                          Aktuelle Test Version 0.1.0
                                          Veröffentlichungsdatum 28-02-2021
                                          Github Link https://github.com/Drozmotix/ioBroker.esphome
                                          Dokumentation https://Drozmotix.github.io/languages/de/ESPHome/
                                          Der Adapter stellt über seine native API eine Verbindung zum von ESPHome verwalteten Gerät her und stellt sicher, dass alle Daten bei jeder Änderung synchronisiert werden
                                          Unterstützte Typen
                                          Der adapter unterstützt momentan folgende sensor typen
                                          Type Funktionalität mehr Informationen
                                          BinarySensor Sie können verschiedene Arten von Binärsensoren verwenden. Diese werden automatisch in ioBroker angezeigt und verfügen über mehrere Konfigurationsoptionen. Binary Sensor Component
                                          Climate ESPHome unterstützt Klimageräte. Klimageräte können verschiedene Arten von Hardware darstellen, aber der entscheidende Faktor ist, dass Klimageräte eine einstellbare Zieltemperatur haben und in verschiedene Modi wie HEAT, COOL, AUTO oder OFF geschaltet werden können. Climate Component
                                          Sensor ESPHome unterstützt viele verschiedene Sensoren. Jeder von ihnen ist eine Plattform der Sensordomäne und jeder Sensor verfügt über mehrere Basiskonfigurationsoptionen. Sensor Component
                                          TextSensor Textsensoren sind normalen Sensoren sehr ähnlich. Wenn die „normalen“ Sensoren jedoch nur Sensoren darstellen, die Zahlen ausgeben, kann diese Komponente einen beliebigen Text darstellen. Text Sensor Component
                                          Switch Mit der GPIO-Switch-Plattform können Sie einen beliebigen Pin auf Ihrem Knoten als Switch verwenden. Sie können beispielsweise ein Relais an einen GPIO-Pin anschließen und über diese Plattform verwenden. GPIO Switch
                                          Viel spass !
                                          PS: Habe diesmal sogar Doku geschrieben 🤓
                                          ZarelloZ Offline
                                          ZarelloZ Offline
                                          Zarello
                                          #558
                                          durch diesen Adapter wurde doch jetzt mein ESPEasy direkt durch ESPHome ersetzt.
                                          Aber dabei ist eine Frage aufgekommen: Wie kann ich Daten vom ioBroker zum ESP bekommen?
                                          Konkret geht es darum die Kalibrierung des CO2-Sensors auszulösen. Ich habe das bisher so versucht:
                                          esphome:
                                          esp8266:
                                           board: d1_mini
                                          wifi:
                                           ap:
                                             ssid: !secret ap_ssid
                                             password: !secret ap_password
                                          ota:
                                           password: !secret ota_password
                                          # Enable logging
                                          logger:
                                          # Enable Home Assistant API
                                          api:
                                           password: !secret api_password
                                           services:
                                             - service: calibrate_co2
                                               then:
                                                 - logger.log: CO2-Calibration started
                                                 - mhz19.calibrate_zero: mhz19_id
                                          button:
                                             on_press:
                                          web_server:
                                           port: 80
                                          uart:
                                           rx_pin: GPIO4
                                           tx_pin: GPIO5
                                           baud_rate: 9600
                                          i2c:
                                           sda: GPIO14
                                           scl: GPIO12
                                           scan: true
                                          ads1115:
                                           - address: 0x48
                                          sensor:
                                           - platform: mhz19
                                             co2:
                                             temperature:
                                             update_interval: 10s
                                             automatic_baseline_calibration: false
                                           - platform: ads1115
                                             multiplexer: 'A0_GND'
                                             gain: 4.096
                                             unit_of_measurement: "ppm"
                                             filters:
                                               - calibrate_linear:
                                                 - 0 -> 10.0
                                                 - 3.3 -> 1000.0
                                               - median:
                                                   window_size: 5
                                                   send_every: 1
                                                   send_first_at: 1
                                           - platform: ads1115
                                             multiplexer: 'A1_GND'
                                             gain: 6.144
                                             unit_of_measurement: "%"
                                             filters:
                                               - calibrate_linear:
                                                 - 3.83475 -> 0.0
                                                 - 2.25 -> 100.0
                                               - median:
                                                   window_size: 5
                                                   send_every: 1
                                                   send_first_at: 1
                                           - platform: ads1115
                                             multiplexer: 'A2_GND'
                                             gain: 6.144
                                             filters:
                                               - calibrate_linear:
                                                 - 3.8325 -> 0.0
                                                 - 2.2125 -> 100.0
                                               - median:
                                                   window_size: 5
                                                   send_every: 1
                                                   send_first_at: 1
                                          captive_portal:
                                          Über den button habe ich im Webinterface die Möglichkeit das auszulösen, aber eigentlich wollte ich auf Dauer den Webserver rauswerfen. Leider taucht bei mir bei den Datenpunkten im ESPHome-Adapter keine Möglichkeit auf, den service oder den button auszulösen. Was übersehe ich?
