  4. [ESPHome] Beta release
591 Beiträge 48 Kommentatoren 238.9k Aufrufe 39 Beobachtet
  • E e-s
    @a200
    Du musst irgendetwas mit name= hinzufügen bevor überhaupt etwas im webif oder an den Adapter übergeben wird.
    Ein switch oder sowas in der Art müsste als input dazu.
    a200A Offline
    a200A Offline
    a200
    #510
    @e-s hier komplett:
    damit werden entsprechende Buttons von -100 bis 100 und STOP über die Web-GUI verfügbar.
    web_server:
      port: 80
    button:
      - platform: template
        on_press:
        - servo.write:
            level: 0.0%
        on_press:
        - servo.write:
            level: 10%
        on_press:
        - servo.write:
            level: 20%
        on_press:
        - servo.write:
            level: 30%
        on_press:
        - servo.write:
            level: 40%
        on_press:
        - servo.write:
            level: 50%
        on_press:
        - servo.write:
            level: 60%
        on_press:
        - servo.write:
            level: 70%
        on_press:
        - servo.write:
            level: 80%
        on_press:
        - servo.write:
            level: 90%
        on_press:
        - servo.write:
            level: 100%
        on_press:
        - servo.write:
            level: -10%
        on_press:
        - servo.write:
            level: -20%
        on_press:
        - servo.write:
            level: -30%
        on_press:
        - servo.write:
            level: -40%
        on_press:
        - servo.write:
            level: -50%
        on_press:
        - servo.write:
            level: -60%
        on_press:
        - servo.write:
            level: -70%
        on_press:
        - servo.write:
            level: -80%
        on_press:
        - servo.write:
            level: -90%
        on_press:
        - servo.write:
            level: -100%
        on_press:
          - servo.detach: my_servo
    servo:
      - id: my_servo
        output: pwm_output
    output:
      - platform: esp8266_pwm
        pin: D1
        frequency: 50 Hz
    IoBroker auf QNAP TS-451, Raspi und NUC
    OpenSourceNomadO M 2 Antworten Letzte Antwort
    • a200A a200
      @e-s hier komplett:
      web_server:
        port: 80
      button:
          on_press:
          - servo.write:
              level: 0.0%
          on_press:
          - servo.write:
              level: 10%
          on_press:
          - servo.write:
              level: 20%
          on_press:
          - servo.write:
              level: 30%
          on_press:
          - servo.write:
              level: 40%
          on_press:
          - servo.write:
              level: 50%
          on_press:
          - servo.write:
              level: 60%
          on_press:
          - servo.write:
              level: 70%
          on_press:
          - servo.write:
              level: 80%
          on_press:
          - servo.write:
              level: 90%
          on_press:
          - servo.write:
              level: 100%
          on_press:
          - servo.write:
              level: -10%
          on_press:
          - servo.write:
              level: -20%
          on_press:
          - servo.write:
              level: -30%
          on_press:
          - servo.write:
              level: -40%
          on_press:
          - servo.write:
              level: -50%
          on_press:
          - servo.write:
              level: -60%
          on_press:
          - servo.write:
              level: -70%
          on_press:
          - servo.write:
              level: -80%
          on_press:
          - servo.write:
              level: -90%
          on_press:
          - servo.write:
              level: -100%
          on_press:
      servo:
        - id: my_servo
          output: pwm_output
      output:
          pin: D1
          frequency: 50 Hz
      OpenSourceNomadO Offline
      OpenSourceNomad
      Most Active Gesperrt
      #511
      @a200 said in [ESPHome] Beta release:
      wahrscheinlich eignet sich hier ein select template besser anstelle der 20 buttons 🎛
      • OpenSourceNomadO OpenSourceNomad
        maxpd
        #512
        @opensourcenomad wie sähe es aus, wenn man den servo 1 minute (36000 Grad) am stück laufen lassen möchte und anschließend zurück? Ich denke über die Zeit gesteuert ist das besser als über die Anzahl der Grad?
        maxpd
        OpenSourceNomadO 1 Antwort Letzte Antwort
        • M maxpd
          OpenSourceNomad
          schrieb am zuletzt editiert von OpenSourceNomad
          #513
          @maxpd said in [ESPHome] Beta release:
          Das ist mit Sicherheit was für eine automation ⬅, welche wiederum durch einen template button gestartet werden kann wenn gewünscht 💡
            maxpd
            #514
            @opensourcenomad puhh, crazy, viel zu lernen, merci :)
            maxpd
            • a200A a200
              @e-s hier komplett:
              web_server:
                port: 80
              button:
                  on_press:
                  - servo.write:
                      level: 0.0%
                  on_press:
                  - servo.write:
                      level: 10%
                  on_press:
                  - servo.write:
                      level: 20%
                  on_press:
                  - servo.write:
                      level: 30%
                  on_press:
                  - servo.write:
                      level: 40%
                  on_press:
                  - servo.write:
                      level: 50%
                  on_press:
                  - servo.write:
                      level: 60%
                  on_press:
                  - servo.write:
                      level: 70%
                  on_press:
                  - servo.write:
                      level: 80%
                  on_press:
                  - servo.write:
                      level: 90%
                  on_press:
                  - servo.write:
                      level: 100%
                  on_press:
                  - servo.write:
                      level: -10%
                  on_press:
                  - servo.write:
                      level: -20%
                  on_press:
                  - servo.write:
                      level: -30%
                  on_press:
                  - servo.write:
                      level: -40%
                  on_press:
                  - servo.write:
                      level: -50%
                  on_press:
                  - servo.write:
                      level: -60%
                  on_press:
                  - servo.write:
                      level: -70%
                  on_press:
                  - servo.write:
                      level: -80%
                  on_press:
                  - servo.write:
                      level: -90%
                  on_press:
                  - servo.write:
                      level: -100%
                  on_press:
              servo:
                - id: my_servo
                  output: pwm_output
              output:
                  pin: D1
                  frequency: 50 Hz
              maxpd
              schrieb am zuletzt editiert von maxpd
              #515
              @a200 lieferst du @Dutchman noch das Log? Danke dir.
              maxpd
                maxpd
                #516
                @Dutchman
                Ich hab meinen Servo, der bisher nur die Level Variable hat eingebunden.
                Das ist das esp script:
                esphome:
                  platform: ESP8266
                  board: d1_mini
                wifi:
                  ssid: !secret wifi_ssid
                  password: !secret wifi_password
                  # Enable fallback hotspot (captive portal) in case wifi connection fails
                  ap:
                    ssid: "Little Wemos Fallback Hotspot"
                    password: "************"
                captive_portal:
                # Enable logging
                logger:
                api:
                  services:
                    - service: control_servo
                      variables:
                        level: float
                      then:
                        - servo.write:
                            level: !lambda 'return level / 1000.0;'
                ota:
                output:
                    pin: D3
                    frequency: 50 Hz
                servo:
                  - id: my_servo
                    output: pwm_output
                Das ist das Debug Log hierzu.
                esphome.0
                2022-03-17 15:42:40.693	debug	Create_state called for : C45BBEDDA7E1.info._online with value : true
                esphome.0
                2022-03-17 15:42:40.661	debug	MODIFY to hasDeepSleep: ""
                esphome.0
                2022-03-17 15:42:40.660	debug	Create_state called for : C45BBEDDA7E1.info.hasDeepSleep with value : false
                esphome.0
                2022-03-17 15:42:40.660	debug	create id C45BBEDDA7E1.info.hasDeepSleep with value false and name hasDeepSleep
                esphome.0
                2022-03-17 15:42:40.598	debug	MODIFY to model: ""
                esphome.0
                2022-03-17 15:42:40.597	debug	Create_state called for : C45BBEDDA7E1.info.model with value : d1_mini
                esphome.0
                2022-03-17 15:42:40.597	debug	create id C45BBEDDA7E1.info.model with value d1_mini and name model
                esphome.0
                2022-03-17 15:42:40.573	debug	MODIFY to compilationTime: ""
                esphome.0
                2022-03-17 15:42:40.572	debug	Create_state called for : C45BBEDDA7E1.info.compilationTime with value : Mar 17 2022, 15:38:01
                esphome.0
                2022-03-17 15:42:40.572	debug	create id C45BBEDDA7E1.info.compilationTime with value Mar 17 2022, 15:38:01 and name compilationTime
                esphome.0
                2022-03-17 15:42:40.551	debug	MODIFY to esphomeVersion: ""
                esphome.0
                2022-03-17 15:42:40.551	debug	Create_state called for : C45BBEDDA7E1.info.esphomeVersion with value : 2022.3.0
                esphome.0
                2022-03-17 15:42:40.550	debug	create id C45BBEDDA7E1.info.esphomeVersion with value 2022.3.0 and name esphomeVersion
                esphome.0
                2022-03-17 15:42:40.475	info	ESPHome client little_wemos on ip 192.168.178.53 initialized
                esphome.0
                2022-03-17 15:42:40.474	debug	192.168.178.53 client log ListEntitiesDoneResponse
                esphome.0
                2022-03-17 15:42:40.472	debug	192.168.178.53 client data
                esphome.0
                2022-03-17 15:42:40.460	debug	MODIFY to macAddress: ""
                esphome.0
                2022-03-17 15:42:40.459	debug	Create_state called for : C45BBEDDA7E1.info.macAddress with value : C4:5B:BE:DD:A7:E1
                esphome.0
                2022-03-17 15:42:40.459	debug	create id C45BBEDDA7E1.info.macAddress with value C4:5B:BE:DD:A7:E1 and name macAddress
                esphome.0
                2022-03-17 15:42:40.436	debug	MODIFY to name: ""
                esphome.0
                2022-03-17 15:42:40.435	debug	Create_state called for : C45BBEDDA7E1.info.name with value : little_wemos
                esphome.0
                2022-03-17 15:42:40.434	debug	create id C45BBEDDA7E1.info.name with value little_wemos and name name
                esphome.0
                2022-03-17 15:42:40.430	debug	192.168.178.53 client log ListEntitiesServicesResponse
                esphome.0
                2022-03-17 15:42:40.426	debug	192.168.178.53 client data ) control_servo>�S� level
                esphome.0
                2022-03-17 15:42:40.406	debug	MODIFY to usesPassword: ""
                esphome.0
                2022-03-17 15:42:40.405	debug	Create_state called for : C45BBEDDA7E1.info.usesPassword with value : false
                esphome.0
                2022-03-17 15:42:40.404	debug	create id C45BBEDDA7E1.info.usesPassword with value false and name usesPassword
                esphome.0
                2022-03-17 15:42:40.384	debug	192.168.178.53 client log DeviceInfoResponse
                esphome.0
                2022-03-17 15:42:40.380	debug	DeviceInfo little_wemos: {"192.168.178.53":{"ip":"192.168.178.53","mac":"C4:5B:BE:DD:A7:E1","deviceInfo":{"usesPassword":false,"name":"little_wemos","macAddress":"C4:5B:BE:DD:A7:E1","esphomeVersion":"2022.3.0","compilationTime":"Mar 17 2022, 15:38:01","model":"d1_mini","hasDeepSleep":false},"deviceName":"C45BBEDDA7E1","deviceInfoName":"little_wemos","passWord":""}}
                esphome.0
                2022-03-17 15:42:40.378	debug	DeviceData: {"usesPassword":false,"name":"little_wemos","macAddress":"C4:5B:BE:DD:A7:E1","esphomeVersion":"2022.3.0","compilationTime":"Mar 17 2022, 15:38:01","model":"d1_mini","hasDeepSleep":false}
                esphome.0
                2022-03-17 15:42:40.378	info	ESPHome Device info received for little_wemos
                esphome.0
                2022-03-17 15:42:40.375	debug	192.168.178.53 client data Klittle_wemosC4:5B:BE:DD:A7:E1"2022.3.0*Mar 17 2022, 15:38:012d1_mini
                esphome.0
                2022-03-17 15:42:40.359	info	ESPHome client 192.168.178.53 connected
                esphome.0
                2022-03-17 15:42:40.358	debug	192.168.178.53 client log ConnectResponse
                esphome.0
                2022-03-17 15:42:40.356	debug	192.168.178.53 client data
                esphome.0
                2022-03-17 15:42:40.341	debug	192.168.178.53 client log HelloResponse
                esphome.0
                2022-03-17 15:42:40.337	debug	192.168.178.53 client data 4 little_wemos (esphome v2022.3.0)"little_wemos
                esphome.0
                2022-03-17 15:42:40.323	debug	192.168.178.53 client log PingResponse
                esphome.0
                2022-03-17 15:42:40.320	debug	192.168.178.53 client data
                esphome.0
                2022-03-17 15:42:40.286	debug	espHomeDashboard_Process {"_events":{},"_eventsCount":0,"_maxListeners":100,"_closesNeeded":3,"_closesGot":0,"connected":false,"signalCode":null,"exitCode":null,"killed":false,"spawnfile":"npm","_handle":{"pid":16308},"spawnargs":["npm","run","-s","nopy","/opt/iobroker/node_modules/iobroker.esphome/python_modules/bin/esphome","dashboard","/opt/iobroker/iobroker-data/esphome.0"],"pid":16308,"stdin":{"connecting":false,"_hadError":false,"_parent":null,"_host":null,"_readableState":{"objectMode":false,"highWaterMark":16384,"buffer":{"head":null,"tail":null,"length":0},"length":0,"pipes":[],"flowing":null,"ended":false,"endEmitted":false,"reading":false,"sync":true,"needReadable":false,"emittedReadable":false,"readableListening":false,"resumeScheduled":false,"errorEmitted":false,"emitClose":false,"autoDestroy":false,"destroyed":false,"errored":null,"closed":false,"closeEmitted":false,"defaultEncoding":"utf8","awaitDrainWriters":null,"multiAwaitDrain":false,"readingMore":false,"dataEmitted":false,"decoder":null,"encoding":null,"readable":false},"_events":{},"_eventsCount":1,"_maxListeners":100,"_writableState":{"objectMode":false,"highWaterMark":16384,"finalCalled":false,"needDrain":false,"ending":false,"ended":false,"finished":false,"destroyed":false,"decodeStrings":false,"defaultEncoding":"utf8","length":0,"writing":false,"corked":0,"sync":true,"bufferProcessing":false,"writecb":null,"writelen":0,"afterWriteTickInfo":null,"buffered":[],"bufferedIndex":0,"allBuffers":true,"allNoop":true,"pendingcb":0,"prefinished":false,"errorEmitted":false,"emitClose":false,"autoDestroy":false,"errored":null,"closed":false,"closeEmitted":false},"allowHalfOpen":false,"_sockname":null,"_pendingData":null,"_pendingEncoding":"","server":null,"_server":null},"stdout":{"connecting":false,"_hadError":false,"_parent":null,"_host":null,"_readableState":{"objectMode":false,"highWaterMark":16384,"buffer":{"head":null,"tail":null,"length":0},"length":0,"pipes":[],"flowing":null,"ended":false,"endEmitted":false,"reading":true,"sync":false,"needReadable":true,"emittedReadable":false,"readableListening":false,"resumeScheduled":false,"errorEmitted":false,"emitClose":false,"autoDestroy":false,"destroyed":false,"errored":null,"closed":false,"closeEmitted":false,"defaultEncoding":"utf8","awaitDrainWriters":null,"multiAwaitDrain":false,"readingMore":false,"dataEmitted":false,"decoder":null,"encoding":null},"_events":{},"_eventsCount":2,"_maxListeners":100,"_writableState":{"objectMode":false,"highWaterMark":16384,"finalCalled":false,"needDrain":false,"ending":false,"ended":false,"finished":false,"destroyed":false,"decodeStrings":false,"defaultEncoding":"utf8","length":0,"writing":false,"corked":0,"sync":true,"bufferProcessing":false,"writecb":null,"writelen":0,"afterWriteTickInfo":null,"buffered":[],"bufferedIndex":0,"allBuffers":true,"allNoop":true,"pendingcb":0,"prefinished":false,"errorEmitted":false,"emitClose":false,"autoDestroy":false,"errored":null,"closed":false,"writable":false,"closeEmitted":false},"allowHalfOpen":false,"_sockname":null,"_pendingData":null,"_pendingEncoding":"","server":null,"_server":null},"stderr":{"connecting":false,"_hadError":false,"_parent":null,"_host":null,"_readableState":{"objectMode":false,"highWaterMark":16384,"buffer":{"head":null,"tail":null,"length":0},"length":0,"pipes":[],"flowing":null,"ended":false,"endEmitted":false,"reading":true,"sync":false,"needReadable":true,"emittedReadable":false,"readableListening":false,"resumeScheduled":false,"errorEmitted":false,"emitClose":false,"autoDestroy":false,"destroyed":false,"errored":null,"closed":false,"closeEmitted":false,"defaultEncoding":"utf8","awaitDrainWriters":null,"multiAwaitDrain":false,"readingMore":false,"dataEmitted":false,"decoder":null,"encoding":null},"_events":{},"_eventsCount":2,"_maxListeners":100,"_writableState":{"objectMode":false,"highWaterMark":16384,"finalCalled":false,"needDrain":false,"ending":false,"ended":false,"finished":false,"destroyed":false,"decodeStrings":false,"defaultEncoding":"utf8","length":0,"writing":false,"corked":0,"sync":true,"bufferProcessing":false,"writecb":null,"writelen":0,"afterWriteTickInfo":null,"buffered":[],"bufferedIndex":0,"allBuffers":true,"allNoop":true,"pendingcb":0,"prefinished":false,"errorEmitted":false,"emitClose":false,"autoDestroy":false,"errored":null,"closed":false,"writable":false,"closeEmitted":false},"allowHalfOpen":false,"_sockname":null,"_pendingData":null,"_pendingEncoding":"","server":null,"_server":null},"stdio":[{"connecting":false,"_hadError":false,"_parent":null,"_host":null,"_readableState":{"objectMode":false,"highWaterMark":16384,"buffer":{"head":null,"tail":null,"length":0},"length":0,"pipes":[],"flowing":null,"ended":false,"endEmitted":false,"reading":false,"sync":true,"needReadable":false,"emittedReadable":false,"readableListening":false,"resumeScheduled":false,"errorEmitted":false,"emitClose":false,"autoDestroy":false,"destroyed":false,"errored":null,"closed":false,"closeEmitted":false,"defaultEncoding":"utf8","awaitDrainWriters":null,"multiAwaitDrain":false,"readingMore":false,"dataEmitted":false,"decoder":null,"encoding":null,"readable":false},"_events":{},"_eventsCount":1,"_maxListeners":100,"_writableState":{"objectMode":false,"highWaterMark":16384,"finalCalled":false,"needDrain":false,"ending":false,"ended":false,"finished":false,"destroyed":false,"decodeStrings":false,"defaultEncoding":"utf8","length":0,"writing":false,"corked":0,"sync":true,"bufferProcessing":false,"writecb":null,"writelen":0,"afterWriteTickInfo":null,"buffered":[],"bufferedIndex":0,"allBuffers":true,"allNoop":true,"pendingcb":0,"prefinished":false,"errorEmitted":false,"emitClose":false,"autoDestroy":false,"errored":null,"closed":false,"closeEmitted":false},"allowHalfOpen":false,"_sockname":null,"_pendingData":null,"_pendingEncoding":"","server":null,"_server":null},{"connecting":false,"_hadError":false,"_parent":null,"_host":null,"_readableState":{"objectMode":false,"highWaterMark":16384,"buffer":{"head":null,"tail":null,"length":0},"length":0,"pipes":[],"flowing":null,"ended":false,"endEmitted":false,"reading":true,"sync":false,"needReadable":true,"emittedReadable":false,"readableListening":false,"resumeScheduled":false,"errorEmitted":false,"emitClose":false,"autoDestroy":false,"destroyed":false,"errored":null,"closed":false,"closeEmitted":false,"defaultEncoding":"utf8","awaitDrainWriters":null,"multiAwaitDrain":false,"readingMore":false,"dataEmitted":false,"decoder":null,"encoding":null},"_events":{},"_eventsCount":2,"_maxListeners":100,"_writableState":{"objectMode":false,"highWaterMark":16384,"finalCalled":false,"needDrain":false,"ending":false,"ended":false,"finished":false,"destroyed":false,"decodeStrings":false,"defaultEncoding":"utf8","length":0,"writing":false,"corked":0,"sync":true,"bufferProcessing":false,"writecb":null,"writelen":0,"afterWriteTickInfo":null,"buffered":[],"bufferedIndex":0,"allBuffers":true,"allNoop":true,"pendingcb":0,"prefinished":false,"errorEmitted":false,"emitClose":false,"autoDestroy":false,"errored":null,"closed":false,"writable":false,"closeEmitted":false},"allowHalfOpen":false,"_sockname":null,"_pendingData":null,"_pendingEncoding":"","server":null,"_server":null},{"connecting":false,"_hadError":false,"_parent":null,"_host":null,"_readableState":{"objectMode":false,"highWaterMark":16384,"buffer":{"head":null,"tail":null,"length":0},"length":0,"pipes":[],"flowing":null,"ended":false,"endEmitted":false,"reading":true,"sync":false,"needReadable":true,"emittedReadable":false,"readableListening":false,"resumeScheduled":false,"errorEmitted":false,"emitClose":false,"autoDestroy":false,"destroyed":false,"errored":null,"closed":false,"closeEmitted":false,"defaultEncoding":"utf8","awaitDrainWriters":null,"multiAwaitDrain":false,"readingMore":false,"dataEmitted":false,"decoder":null,"encoding":null},"_events":{},"_eventsCount":2,"_maxListeners":100,"_writableState":{"objectMode":false,"highWaterMark":16384,"finalCalled":false,"needDrain":false,"ending":false,"ended":false,"finished":false,"destroyed":false,"decodeStrings":false,"defaultEncoding":"utf8","length":0,"writing":false,"corked":0,"sync":true,"bufferProcessing":false,"writecb":null,"writelen":0,"afterWriteTickInfo":null,"buffered":[],"bufferedIndex":0,"allBuffers":true,"allNoop":true,"pendingcb":0,"prefinished":false,"errorEmitted":false,"emitClose":false,"autoDestroy":false,"errored":null,"closed":false,"writable":false,"closeEmitted":false},"allowHalfOpen":false,"_sockname":null,"_pendingData":null,"_pendingEncoding":"","server":null,"_server":null}]}
                esphome.0
                2022-03-17 15:42:40.272	info	Native Integration of ESPHome Dashboard enabled
                esphome.0
                2022-03-17 15:42:40.268	info	Auto Discovery startet, new devices (or IP changes) will be detected automatically
                maxpd
                  maxpd
                  #517
                  @opensourcenomad hast du das schon umgesetzt? Das letzte Update des Adapters liegt noch vor 12.2021.
                  Home Assistant Core 2021.12 or higher is required for ESPHome button entities to work.
                  Und kommt das Template nicht in die configuration.yaml oder template.yaml im Home Assistant? Aber die gibt es im iobroker esphome Adapter nicht. Habe die Ordnerstruktur durchwühlt.
                  maxpd
                  • M maxpd
                    OpenSourceNomad
                    #518
                    Du kannst lokal die aktuellste Version (2022.03) mittels pip oder docker installieren.
                    Allerdings wird dir das in diesem Fall wohl nicht weiterhelfen weil esphome für die buttons vom iobroker eine neuere Version verlangt.
                    Nein.
                      steimi
                      #519
                      einfach unter "Adapter -> eine bestimmte Version" die aktuelle Version 0.2.4 nochmal installieren. Dabei zieht er sich die aktuelle ESPhome-Version 2022.03
                      • S steimi
                        maxpd
                        #520
                        @steimi Ja, lokal habe ich die 2022.03 im ESP.
                        Hatte nur die Änderungsdaten der Files im ESPHome Adapter geprüft und die waren alle älter.
                        also genau das was @OpenSourceNomad bestätigt hat.
                        maxpd
                        • a200A a200
                          @johannes-bauerstatter Ein ESPHome Update innerhalb des USPHome-Adapters ist so einfach, dass es schon peinlich ist.
                          1. IoBroker unter Adapter "Expertenmodus" aktivieren.
                          2. Auf die Katze (installieren aus eigener URL) klicken.
                          3. Im Tab "VON NPM" den ESphome-Adapter auswählen.
                          Der Adapter wird reinstalliert, wobei die neuste Version von ESPHome gezogen und installiert wird. Alle Yamls und die Datenpunkte bleiben erhalten.
                          bernd33-1
                          #521
                          bei mir wird der ESP-Home Adapter nicht aufgelistet. Muss man noch was beachten?
                          Danke und Grüße, Bernd
                          aktuell habe ich die ESPHome version 2021.8.2 compiled on Mar 14 2022, 09:07:40
                          a200A 1 Antwort Letzte Antwort
                          • B bernd33-1
                            a200A Offline
                            a200A Offline
                            a200
                            #522
                            @bernd33-1 Hast du dein Repository auf BETA umgestellt?
                              bernd33-1
                              #523
                              @a200 :man-facepalming: Oh man, ja klar. Ich verwende ESPHome schon so selbstverständlich das ich garnicht mehr an Beta denke.
                              Ja klar, im Beta ist der Adapter da. Danke und schönen Sonntag noch, Bernd
                              • B bernd33-1
                                a200A Offline
                                a200A Offline
                                a200
                                #524
                                @bernd33-1 sagte in [ESPHome] Beta release:
                                Freut mich zu hören. Über einen + würde ich mich freuen. LG
                                • a200A a200
                                  Beowolf
                                  schrieb am zuletzt editiert von Beowolf
                                  #525
                                  Ich bekomme den Adapter nicht installiert.
                                  Hier die Meldungen:
                                  $ iobroker add esphome --host ioBroker-Master
                                  NPM version: 6.14.16
                                  Installing iobroker.esphome@0.2.4... (System call)
                                  > iobroker.esphome@0.2.4 install /opt/iobroker/node_modules/iobroker.esphome> npip install
                                  No python_modules directory; installing pip locally if needed.
                                  Successfully completed pip check.
                                  Collecting esphome>=2021.8
                                  Using cached esphome-2022.2.6-py2.py3-none-any.whl (2.1 MB)
                                  Collecting tornado>=3.2
                                  Using cached tornado-6.1.tar.gz (497 kB)
                                  Preparing metadata (setup.py): started
                                  Preparing metadata (setup.py): finished with status 'done'
                                  Collecting tzdata>=2021.1
                                  Using cached tzdata-2022.1-py2.py3-none-any.whl (339 kB)
                                  Collecting esphome-dashboard==20220209.0
                                  Using cached esphome_dashboard-20220209.0-py3-none-any.whl (592 kB)
                                  Collecting click==8.0.3
                                  Using cached click-8.0.3-py3-none-any.whl (97 kB)
                                  Collecting PyYAML==6.0
                                  Using cached PyYAML-6.0.tar.gz (124 kB)
                                  Installing build dependencies: started
                                  Installing build dependencies: finished with status 'done'
                                  Getting requirements to build wheel: started
                                  Getting requirements to build wheel: finished with status 'done' Preparing metadata (pyproject.toml): started
                                  Preparing metadata (pyproject.toml): finished with status 'done'
                                  Collecting aioesphomeapi==10.8.2
                                  Using cached aioesphomeapi-10.8.2-py2.py3-none-any.whl (49 kB)
                                  Collecting zeroconf==0.38.3
                                  Using cached zeroconf-0.38.3-py3-none-any.whl (106 kB)
                                  Collecting kconfiglib==13.7.1
                                  Using cached kconfiglib-13.7.1-py2.py3-none-any.whl (145 kB)
                                  Collecting esptool==3.2
                                  Using cached esptool-3.2.tar.gz (206 kB)
                                  Collecting colorama==0.4.4
                                  Using cached colorama-0.4.4-py2.py3-none-any.whl (16 kB)
                                  Collecting pyserial==3.5 Using cached pyserial-3.5-py2.py3-none-any.whl (90 kB)
                                  Collecting tzlocal==4.1
                                  Using cached tzlocal-4.1-py3-none-any.whl (19 kB)
                                  Collecting platformio==5.2.5
                                  Using cached platformio-5.2.5.tar.gz (218 kB)
                                  Collecting voluptuous==0.12.2
                                  Using cached voluptuous-0.12.2.tar.gz (48 kB)
                                  Collecting paho-mqtt==1.6.1
                                  Using cached paho-mqtt-1.6.1.tar.gz (99 kB)
                                  Collecting protobuf<4.0,>=3.12.2
                                  Using cached protobuf-3.19.4-py2.py3-none-any.whl (162 kB)
                                  Collecting noiseprotocol<1.0,>=0.3.1
                                  Using cached noiseprotocol-0.3.1-py3-none-any.whl (20 kB)
                                  Collecting importlib-metadata
                                  Using cached importlib_metadata-4.11.3-py3-none-any.whl (18 kB)
                                  Collecting bitstring>=3.1.6
                                  Using cached bitstring-3.1.9-py3-none-any.whl (38 kB)
                                  Collecting cryptography>=2.1.4
                                  Using cached cryptography-36.0.2.tar.gz (572 kB)
                                  Installing build dependencies: finished with status 'error'
                                  host.ioBroker-Master Cannot install iobroker.esphome@0.2.4: 1
                                  ERROR: Process exited with code 25
                                  Wo habe ich da einen Fehler?
                                    maxpd
                                    #526
                                    @beowolf welche python version ist drauf?
                                    maxpd
                                    • M maxpd
                                      Beowolf
                                      #527
                                      @maxpd
                                      pi@ioBroker-Master:~ $ python --version
                                      Python 2.7.16
                                      pi@ioBroker-Master:~ $ python3 --version
                                      Python 3.7.3
                                      M DutchmanD OpenSourceNomadO Thomas BraunT 4 Antworten Letzte Antwort
                                      • B Beowolf
                                        @maxpd
                                        Python 2.7.16
                                        Python 3.7.3
                                        maxpd
                                        #528
                                        @beowolf
                                        Ich würde dir ein Update empfehlen:
                                        https://forum.iobroker.net/topic/47213/upgrade-von-debian-10-buster-auf-11-bullseye
                                        Danach gehts.
                                        maxpd
                                        • B Beowolf
                                          @maxpd
                                          Python 2.7.16
                                          Python 3.7.3
                                          DutchmanD Offline
                                          DutchmanD Offline
                                          Dutchman
                                          #529
                                          @beowolf sagte in [ESPHome] Beta release:
                                          @maxpd
                                          Python 2.7.16
                                          Python 3.7.3
                                          python muss nach 3.7 verweisen , da dies für jedes System anders ist kan ich die Python Installation selber leider nicht Supporten
