  4. [ESPHome] Beta release
591 Beiträge 48 Kommentatoren 238.9k Aufrufe 39 Beobachtet
  • a200A a200
    @e-s hier komplett:
    damit werden entsprechende Buttons von -100 bis 100 und STOP über die Web-GUI verfügbar.
    web_server:
      port: 80
    button:
      - platform: template
        on_press:
        - servo.write:
            level: 0.0%
        on_press:
        - servo.write:
            level: 10%
        on_press:
        - servo.write:
            level: 20%
        on_press:
        - servo.write:
            level: 30%
        on_press:
        - servo.write:
            level: 40%
        on_press:
        - servo.write:
            level: 50%
        on_press:
        - servo.write:
            level: 60%
        on_press:
        - servo.write:
            level: 70%
        on_press:
        - servo.write:
            level: 80%
        on_press:
        - servo.write:
            level: 90%
        on_press:
        - servo.write:
            level: 100%
        on_press:
        - servo.write:
            level: -10%
        on_press:
        - servo.write:
            level: -20%
        on_press:
        - servo.write:
            level: -30%
        on_press:
        - servo.write:
            level: -40%
        on_press:
        - servo.write:
            level: -50%
        on_press:
        - servo.write:
            level: -60%
        on_press:
        - servo.write:
            level: -70%
        on_press:
        - servo.write:
            level: -80%
        on_press:
        - servo.write:
            level: -90%
        on_press:
        - servo.write:
            level: -100%
        on_press:
          - servo.detach: my_servo
    servo:
      - id: my_servo
        output: pwm_output
    output:
      - platform: esp8266_pwm
        pin: D1
        frequency: 50 Hz
    maxpd
    schrieb am zuletzt editiert von maxpd
    #515
    @a200 lieferst du @Dutchman noch das Log? Danke dir.
    maxpd
      maxpd
      #516
      @Dutchman
      Ich hab meinen Servo, der bisher nur die Level Variable hat eingebunden.
      Das ist das esp script:
      esphome:
        platform: ESP8266
        board: d1_mini
      wifi:
        ssid: !secret wifi_ssid
        password: !secret wifi_password
        # Enable fallback hotspot (captive portal) in case wifi connection fails
        ap:
          ssid: "Little Wemos Fallback Hotspot"
          password: "************"
      captive_portal:
      # Enable logging
      logger:
      api:
        services:
          - service: control_servo
            variables:
              level: float
            then:
              - servo.write:
                  level: !lambda 'return level / 1000.0;'
      ota:
      output:
          pin: D3
          frequency: 50 Hz
      servo:
        - id: my_servo
          output: pwm_output
      Das ist das Debug Log hierzu.
      esphome.0
      2022-03-17 15:42:40.693	debug	Create_state called for : C45BBEDDA7E1.info._online with value : true
      esphome.0
      2022-03-17 15:42:40.661	debug	MODIFY to hasDeepSleep: ""
      esphome.0
      2022-03-17 15:42:40.660	debug	Create_state called for : C45BBEDDA7E1.info.hasDeepSleep with value : false
      esphome.0
      2022-03-17 15:42:40.660	debug	create id C45BBEDDA7E1.info.hasDeepSleep with value false and name hasDeepSleep
      esphome.0
      2022-03-17 15:42:40.598	debug	MODIFY to model: ""
      esphome.0
      2022-03-17 15:42:40.597	debug	Create_state called for : C45BBEDDA7E1.info.model with value : d1_mini
      esphome.0
      2022-03-17 15:42:40.597	debug	create id C45BBEDDA7E1.info.model with value d1_mini and name model
      esphome.0
      2022-03-17 15:42:40.573	debug	MODIFY to compilationTime: ""
      esphome.0
      2022-03-17 15:42:40.572	debug	Create_state called for : C45BBEDDA7E1.info.compilationTime with value : Mar 17 2022, 15:38:01
      esphome.0
      2022-03-17 15:42:40.572	debug	create id C45BBEDDA7E1.info.compilationTime with value Mar 17 2022, 15:38:01 and name compilationTime
      esphome.0
      2022-03-17 15:42:40.551	debug	MODIFY to esphomeVersion: ""
      esphome.0
      2022-03-17 15:42:40.551	debug	Create_state called for : C45BBEDDA7E1.info.esphomeVersion with value : 2022.3.0
      esphome.0
      2022-03-17 15:42:40.550	debug	create id C45BBEDDA7E1.info.esphomeVersion with value 2022.3.0 and name esphomeVersion
      esphome.0
      2022-03-17 15:42:40.475	info	ESPHome client little_wemos on ip 192.168.178.53 initialized
      esphome.0
      2022-03-17 15:42:40.474	debug	192.168.178.53 client log ListEntitiesDoneResponse
      esphome.0
      2022-03-17 15:42:40.472	debug	192.168.178.53 client data
      esphome.0
      2022-03-17 15:42:40.460	debug	MODIFY to macAddress: ""
      esphome.0
      2022-03-17 15:42:40.459	debug	Create_state called for : C45BBEDDA7E1.info.macAddress with value : C4:5B:BE:DD:A7:E1
      esphome.0
      2022-03-17 15:42:40.459	debug	create id C45BBEDDA7E1.info.macAddress with value C4:5B:BE:DD:A7:E1 and name macAddress
      esphome.0
      2022-03-17 15:42:40.436	debug	MODIFY to name: ""
      esphome.0
      2022-03-17 15:42:40.435	debug	Create_state called for : C45BBEDDA7E1.info.name with value : little_wemos
      esphome.0
      2022-03-17 15:42:40.434	debug	create id C45BBEDDA7E1.info.name with value little_wemos and name name
      esphome.0
      2022-03-17 15:42:40.430	debug	192.168.178.53 client log ListEntitiesServicesResponse
      esphome.0
      2022-03-17 15:42:40.426	debug	192.168.178.53 client data ) control_servo>�S� level
      esphome.0
      2022-03-17 15:42:40.406	debug	MODIFY to usesPassword: ""
      esphome.0
      2022-03-17 15:42:40.405	debug	Create_state called for : C45BBEDDA7E1.info.usesPassword with value : false
      esphome.0
      2022-03-17 15:42:40.404	debug	create id C45BBEDDA7E1.info.usesPassword with value false and name usesPassword
      esphome.0
      2022-03-17 15:42:40.384	debug	192.168.178.53 client log DeviceInfoResponse
      esphome.0
      2022-03-17 15:42:40.380	debug	DeviceInfo little_wemos: {"192.168.178.53":{"ip":"192.168.178.53","mac":"C4:5B:BE:DD:A7:E1","deviceInfo":{"usesPassword":false,"name":"little_wemos","macAddress":"C4:5B:BE:DD:A7:E1","esphomeVersion":"2022.3.0","compilationTime":"Mar 17 2022, 15:38:01","model":"d1_mini","hasDeepSleep":false},"deviceName":"C45BBEDDA7E1","deviceInfoName":"little_wemos","passWord":""}}
      esphome.0
      2022-03-17 15:42:40.378	debug	DeviceData: {"usesPassword":false,"name":"little_wemos","macAddress":"C4:5B:BE:DD:A7:E1","esphomeVersion":"2022.3.0","compilationTime":"Mar 17 2022, 15:38:01","model":"d1_mini","hasDeepSleep":false}
      esphome.0
      2022-03-17 15:42:40.378	info	ESPHome Device info received for little_wemos
      esphome.0
      2022-03-17 15:42:40.375	debug	192.168.178.53 client data Klittle_wemosC4:5B:BE:DD:A7:E1"2022.3.0*Mar 17 2022, 15:38:012d1_mini
      esphome.0
      2022-03-17 15:42:40.359	info	ESPHome client 192.168.178.53 connected
      esphome.0
      2022-03-17 15:42:40.358	debug	192.168.178.53 client log ConnectResponse
      esphome.0
      2022-03-17 15:42:40.356	debug	192.168.178.53 client data
      esphome.0
      2022-03-17 15:42:40.341	debug	192.168.178.53 client log HelloResponse
      esphome.0
      2022-03-17 15:42:40.337	debug	192.168.178.53 client data 4 little_wemos (esphome v2022.3.0)"little_wemos
      esphome.0
      2022-03-17 15:42:40.323	debug	192.168.178.53 client log PingResponse
      esphome.0
      2022-03-17 15:42:40.320	debug	192.168.178.53 client data
      esphome.0
      2022-03-17 15:42:40.286	debug	espHomeDashboard_Process {"_events":{},"_eventsCount":0,"_maxListeners":100,"_closesNeeded":3,"_closesGot":0,"connected":false,"signalCode":null,"exitCode":null,"killed":false,"spawnfile":"npm","_handle":{"pid":16308},"spawnargs":["npm","run","-s","nopy","/opt/iobroker/node_modules/iobroker.esphome/python_modules/bin/esphome","dashboard","/opt/iobroker/iobroker-data/esphome.0"],"pid":16308,"stdin":{"connecting":false,"_hadError":false,"_parent":null,"_host":null,"_readableState":{"objectMode":false,"highWaterMark":16384,"buffer":{"head":null,"tail":null,"length":0},"length":0,"pipes":[],"flowing":null,"ended":false,"endEmitted":false,"reading":false,"sync":true,"needReadable":false,"emittedReadable":false,"readableListening":false,"resumeScheduled":false,"errorEmitted":false,"emitClose":false,"autoDestroy":false,"destroyed":false,"errored":null,"closed":false,"closeEmitted":false,"defaultEncoding":"utf8","awaitDrainWriters":null,"multiAwaitDrain":false,"readingMore":false,"dataEmitted":false,"decoder":null,"encoding":null,"readable":false},"_events":{},"_eventsCount":1,"_maxListeners":100,"_writableState":{"objectMode":false,"highWaterMark":16384,"finalCalled":false,"needDrain":false,"ending":false,"ended":false,"finished":false,"destroyed":false,"decodeStrings":false,"defaultEncoding":"utf8","length":0,"writing":false,"corked":0,"sync":true,"bufferProcessing":false,"writecb":null,"writelen":0,"afterWriteTickInfo":null,"buffered":[],"bufferedIndex":0,"allBuffers":true,"allNoop":true,"pendingcb":0,"prefinished":false,"errorEmitted":false,"emitClose":false,"autoDestroy":false,"errored":null,"closed":false,"closeEmitted":false},"allowHalfOpen":false,"_sockname":null,"_pendingData":null,"_pendingEncoding":"","server":null,"_server":null},"stdout":{"connecting":false,"_hadError":false,"_parent":null,"_host":null,"_readableState":{"objectMode":false,"highWaterMark":16384,"buffer":{"head":null,"tail":null,"length":0},"length":0,"pipes":[],"flowing":null,"ended":false,"endEmitted":false,"reading":true,"sync":false,"needReadable":true,"emittedReadable":false,"readableListening":false,"resumeScheduled":false,"errorEmitted":false,"emitClose":false,"autoDestroy":false,"destroyed":false,"errored":null,"closed":false,"closeEmitted":false,"defaultEncoding":"utf8","awaitDrainWriters":null,"multiAwaitDrain":false,"readingMore":false,"dataEmitted":false,"decoder":null,"encoding":null},"_events":{},"_eventsCount":2,"_maxListeners":100,"_writableState":{"objectMode":false,"highWaterMark":16384,"finalCalled":false,"needDrain":false,"ending":false,"ended":false,"finished":false,"destroyed":false,"decodeStrings":false,"defaultEncoding":"utf8","length":0,"writing":false,"corked":0,"sync":true,"bufferProcessing":false,"writecb":null,"writelen":0,"afterWriteTickInfo":null,"buffered":[],"bufferedIndex":0,"allBuffers":true,"allNoop":true,"pendingcb":0,"prefinished":false,"errorEmitted":false,"emitClose":false,"autoDestroy":false,"errored":null,"closed":false,"writable":false,"closeEmitted":false},"allowHalfOpen":false,"_sockname":null,"_pendingData":null,"_pendingEncoding":"","server":null,"_server":null},"stderr":{"connecting":false,"_hadError":false,"_parent":null,"_host":null,"_readableState":{"objectMode":false,"highWaterMark":16384,"buffer":{"head":null,"tail":null,"length":0},"length":0,"pipes":[],"flowing":null,"ended":false,"endEmitted":false,"reading":true,"sync":false,"needReadable":true,"emittedReadable":false,"readableListening":false,"resumeScheduled":false,"errorEmitted":false,"emitClose":false,"autoDestroy":false,"destroyed":false,"errored":null,"closed":false,"closeEmitted":false,"defaultEncoding":"utf8","awaitDrainWriters":null,"multiAwaitDrain":false,"readingMore":false,"dataEmitted":false,"decoder":null,"encoding":null},"_events":{},"_eventsCount":2,"_maxListeners":100,"_writableState":{"objectMode":false,"highWaterMark":16384,"finalCalled":false,"needDrain":false,"ending":false,"ended":false,"finished":false,"destroyed":false,"decodeStrings":false,"defaultEncoding":"utf8","length":0,"writing":false,"corked":0,"sync":true,"bufferProcessing":false,"writecb":null,"writelen":0,"afterWriteTickInfo":null,"buffered":[],"bufferedIndex":0,"allBuffers":true,"allNoop":true,"pendingcb":0,"prefinished":false,"errorEmitted":false,"emitClose":false,"autoDestroy":false,"errored":null,"closed":false,"writable":false,"closeEmitted":false},"allowHalfOpen":false,"_sockname":null,"_pendingData":null,"_pendingEncoding":"","server":null,"_server":null},"stdio":[{"connecting":false,"_hadError":false,"_parent":null,"_host":null,"_readableState":{"objectMode":false,"highWaterMark":16384,"buffer":{"head":null,"tail":null,"length":0},"length":0,"pipes":[],"flowing":null,"ended":false,"endEmitted":false,"reading":false,"sync":true,"needReadable":false,"emittedReadable":false,"readableListening":false,"resumeScheduled":false,"errorEmitted":false,"emitClose":false,"autoDestroy":false,"destroyed":false,"errored":null,"closed":false,"closeEmitted":false,"defaultEncoding":"utf8","awaitDrainWriters":null,"multiAwaitDrain":false,"readingMore":false,"dataEmitted":false,"decoder":null,"encoding":null,"readable":false},"_events":{},"_eventsCount":1,"_maxListeners":100,"_writableState":{"objectMode":false,"highWaterMark":16384,"finalCalled":false,"needDrain":false,"ending":false,"ended":false,"finished":false,"destroyed":false,"decodeStrings":false,"defaultEncoding":"utf8","length":0,"writing":false,"corked":0,"sync":true,"bufferProcessing":false,"writecb":null,"writelen":0,"afterWriteTickInfo":null,"buffered":[],"bufferedIndex":0,"allBuffers":true,"allNoop":true,"pendingcb":0,"prefinished":false,"errorEmitted":false,"emitClose":false,"autoDestroy":false,"errored":null,"closed":false,"closeEmitted":false},"allowHalfOpen":false,"_sockname":null,"_pendingData":null,"_pendingEncoding":"","server":null,"_server":null},{"connecting":false,"_hadError":false,"_parent":null,"_host":null,"_readableState":{"objectMode":false,"highWaterMark":16384,"buffer":{"head":null,"tail":null,"length":0},"length":0,"pipes":[],"flowing":null,"ended":false,"endEmitted":false,"reading":true,"sync":false,"needReadable":true,"emittedReadable":false,"readableListening":false,"resumeScheduled":false,"errorEmitted":false,"emitClose":false,"autoDestroy":false,"destroyed":false,"errored":null,"closed":false,"closeEmitted":false,"defaultEncoding":"utf8","awaitDrainWriters":null,"multiAwaitDrain":false,"readingMore":false,"dataEmitted":false,"decoder":null,"encoding":null},"_events":{},"_eventsCount":2,"_maxListeners":100,"_writableState":{"objectMode":false,"highWaterMark":16384,"finalCalled":false,"needDrain":false,"ending":false,"ended":false,"finished":false,"destroyed":false,"decodeStrings":false,"defaultEncoding":"utf8","length":0,"writing":false,"corked":0,"sync":true,"bufferProcessing":false,"writecb":null,"writelen":0,"afterWriteTickInfo":null,"buffered":[],"bufferedIndex":0,"allBuffers":true,"allNoop":true,"pendingcb":0,"prefinished":false,"errorEmitted":false,"emitClose":false,"autoDestroy":false,"errored":null,"closed":false,"writable":false,"closeEmitted":false},"allowHalfOpen":false,"_sockname":null,"_pendingData":null,"_pendingEncoding":"","server":null,"_server":null},{"connecting":false,"_hadError":false,"_parent":null,"_host":null,"_readableState":{"objectMode":false,"highWaterMark":16384,"buffer":{"head":null,"tail":null,"length":0},"length":0,"pipes":[],"flowing":null,"ended":false,"endEmitted":false,"reading":true,"sync":false,"needReadable":true,"emittedReadable":false,"readableListening":false,"resumeScheduled":false,"errorEmitted":false,"emitClose":false,"autoDestroy":false,"destroyed":false,"errored":null,"closed":false,"closeEmitted":false,"defaultEncoding":"utf8","awaitDrainWriters":null,"multiAwaitDrain":false,"readingMore":false,"dataEmitted":false,"decoder":null,"encoding":null},"_events":{},"_eventsCount":2,"_maxListeners":100,"_writableState":{"objectMode":false,"highWaterMark":16384,"finalCalled":false,"needDrain":false,"ending":false,"ended":false,"finished":false,"destroyed":false,"decodeStrings":false,"defaultEncoding":"utf8","length":0,"writing":false,"corked":0,"sync":true,"bufferProcessing":false,"writecb":null,"writelen":0,"afterWriteTickInfo":null,"buffered":[],"bufferedIndex":0,"allBuffers":true,"allNoop":true,"pendingcb":0,"prefinished":false,"errorEmitted":false,"emitClose":false,"autoDestroy":false,"errored":null,"closed":false,"writable":false,"closeEmitted":false},"allowHalfOpen":false,"_sockname":null,"_pendingData":null,"_pendingEncoding":"","server":null,"_server":null}]}
      esphome.0
      2022-03-17 15:42:40.272	info	Native Integration of ESPHome Dashboard enabled
      esphome.0
      2022-03-17 15:42:40.268	info	Auto Discovery startet, new devices (or IP changes) will be detected automatically
      maxpd
      • OpenSourceNomadO OpenSourceNomad
        @maxpd said in [ESPHome] Beta release:
        wenn man den servo 1 minute (36000 Grad) am stück laufen lassen möchte und anschließend zurück?
        Das ist mit Sicherheit was für eine automation ⬅, welche wiederum durch einen template button gestartet werden kann wenn gewünscht 💡
        maxpd
        #517
        @opensourcenomad hast du das schon umgesetzt? Das letzte Update des Adapters liegt noch vor 12.2021.
        Home Assistant Core 2021.12 or higher is required for ESPHome button entities to work.
        Und kommt das Template nicht in die configuration.yaml oder template.yaml im Home Assistant? Aber die gibt es im iobroker esphome Adapter nicht. Habe die Ordnerstruktur durchwühlt.
        maxpd
        OpenSourceNomadO 1 Antwort Letzte Antwort
        • M maxpd
          OpenSourceNomadO Offline
          OpenSourceNomad
          Most Active Gesperrt
          schrieb am zuletzt editiert von OpenSourceNomad
          #518
          Du kannst lokal die aktuellste Version (2022.03) mittels pip oder docker installieren.
          Allerdings wird dir das in diesem Fall wohl nicht weiterhelfen weil esphome für die buttons vom iobroker eine neuere Version verlangt.
          Nein.
            steimi
            #519
            einfach unter "Adapter -> eine bestimmte Version" die aktuelle Version 0.2.4 nochmal installieren. Dabei zieht er sich die aktuelle ESPhome-Version 2022.03
            • S steimi
              maxpd
              #520
              @steimi Ja, lokal habe ich die 2022.03 im ESP.
              Hatte nur die Änderungsdaten der Files im ESPHome Adapter geprüft und die waren alle älter.
              also genau das was @OpenSourceNomad bestätigt hat.
              maxpd
              • a200A a200
                @johannes-bauerstatter Ein ESPHome Update innerhalb des USPHome-Adapters ist so einfach, dass es schon peinlich ist.
                1. IoBroker unter Adapter "Expertenmodus" aktivieren.
                2. Auf die Katze (installieren aus eigener URL) klicken.
                3. Im Tab "VON NPM" den ESphome-Adapter auswählen.
                Der Adapter wird reinstalliert, wobei die neuste Version von ESPHome gezogen und installiert wird. Alle Yamls und die Datenpunkte bleiben erhalten.
                bernd33-1
                #521
                @a200 said in [ESPHome] Beta release:
                bei mir wird der ESP-Home Adapter nicht aufgelistet. Muss man noch was beachten?
                Danke und Grüße, Bernd
                aktuell habe ich die ESPHome version 2021.8.2 compiled on Mar 14 2022, 09:07:40
                a200A 1 Antwort Letzte Antwort
                • B bernd33-1
                  a200A Offline
                  a200A Offline
                  a200
                  #522
                  @bernd33-1 Hast du dein Repository auf BETA umgestellt?
                  IoBroker auf QNAP TS-451, Raspi und NUC
                    bernd33-1
                    #523
                    @a200 :man-facepalming: Oh man, ja klar. Ich verwende ESPHome schon so selbstverständlich das ich garnicht mehr an Beta denke.
                    Ja klar, im Beta ist der Adapter da. Danke und schönen Sonntag noch, Bernd
                    • B bernd33-1
                      a200A Offline
                      a200A Offline
                      a200
                      #524
                      @bernd33-1 sagte in [ESPHome] Beta release:
                      Freut mich zu hören. Über einen + würde ich mich freuen. LG
                      • a200A a200
                        Beowolf
                        schrieb am zuletzt editiert von Beowolf
                        #525
                        Ich bekomme den Adapter nicht installiert.
                        Hier die Meldungen:
                        $ iobroker add esphome --host ioBroker-Master
                        NPM version: 6.14.16
                        Installing iobroker.esphome@0.2.4... (System call)
                        > iobroker.esphome@0.2.4 install /opt/iobroker/node_modules/iobroker.esphome> npip install
                        No python_modules directory; installing pip locally if needed.
                        Successfully completed pip check.
                        Collecting esphome>=2021.8
                        Using cached esphome-2022.2.6-py2.py3-none-any.whl (2.1 MB)
                        Collecting tornado>=3.2
                        Using cached tornado-6.1.tar.gz (497 kB)
                        Preparing metadata (setup.py): started
                        Preparing metadata (setup.py): finished with status 'done'
                        Collecting tzdata>=2021.1
                        Using cached tzdata-2022.1-py2.py3-none-any.whl (339 kB)
                        Collecting esphome-dashboard==20220209.0
                        Using cached esphome_dashboard-20220209.0-py3-none-any.whl (592 kB)
                        Collecting click==8.0.3
                        Using cached click-8.0.3-py3-none-any.whl (97 kB)
                        Collecting PyYAML==6.0
                        Using cached PyYAML-6.0.tar.gz (124 kB)
                        Installing build dependencies: started
                        Installing build dependencies: finished with status 'done'
                        Getting requirements to build wheel: started
                        Getting requirements to build wheel: finished with status 'done' Preparing metadata (pyproject.toml): started
                        Preparing metadata (pyproject.toml): finished with status 'done'
                        Collecting aioesphomeapi==10.8.2
                        Using cached aioesphomeapi-10.8.2-py2.py3-none-any.whl (49 kB)
                        Collecting zeroconf==0.38.3
                        Using cached zeroconf-0.38.3-py3-none-any.whl (106 kB)
                        Collecting kconfiglib==13.7.1
                        Using cached kconfiglib-13.7.1-py2.py3-none-any.whl (145 kB)
                        Collecting esptool==3.2
                        Using cached esptool-3.2.tar.gz (206 kB)
                        Collecting colorama==0.4.4
                        Using cached colorama-0.4.4-py2.py3-none-any.whl (16 kB)
                        Collecting pyserial==3.5 Using cached pyserial-3.5-py2.py3-none-any.whl (90 kB)
                        Collecting tzlocal==4.1
                        Using cached tzlocal-4.1-py3-none-any.whl (19 kB)
                        Collecting platformio==5.2.5
                        Using cached platformio-5.2.5.tar.gz (218 kB)
                        Collecting voluptuous==0.12.2
                        Using cached voluptuous-0.12.2.tar.gz (48 kB)
                        Collecting paho-mqtt==1.6.1
                        Using cached paho-mqtt-1.6.1.tar.gz (99 kB)
                        Collecting protobuf<4.0,>=3.12.2
                        Using cached protobuf-3.19.4-py2.py3-none-any.whl (162 kB)
                        Collecting noiseprotocol<1.0,>=0.3.1
                        Using cached noiseprotocol-0.3.1-py3-none-any.whl (20 kB)
                        Collecting importlib-metadata
                        Using cached importlib_metadata-4.11.3-py3-none-any.whl (18 kB)
                        Collecting bitstring>=3.1.6
                        Using cached bitstring-3.1.9-py3-none-any.whl (38 kB)
                        Collecting cryptography>=2.1.4
                        Using cached cryptography-36.0.2.tar.gz (572 kB)
                        Installing build dependencies: finished with status 'error'
                        host.ioBroker-Master Cannot install iobroker.esphome@0.2.4: 1
                        ERROR: Process exited with code 25
                        Wo habe ich da einen Fehler?
                          maxpd
                          #526
                          @beowolf welche python version ist drauf?
                          maxpd
                          • M maxpd
                            Beowolf
                            #527
                            @maxpd
                            pi@ioBroker-Master:~ $ python --version
                            Python 2.7.16
                            pi@ioBroker-Master:~ $ python3 --version
                            Python 3.7.3
                            M DutchmanD OpenSourceNomadO Thomas BraunT 4 Antworten Letzte Antwort
                            • B Beowolf
                              @maxpd
                              Python 2.7.16
                              Python 3.7.3
                              maxpd
                              #528
                              @beowolf
                              Ich würde dir ein Update empfehlen:
                              https://forum.iobroker.net/topic/47213/upgrade-von-debian-10-buster-auf-11-bullseye
                              Danach gehts.
                              maxpd
                              • B Beowolf
                                @maxpd
                                Python 2.7.16
                                Python 3.7.3
                                DutchmanD Offline
                                DutchmanD Offline
                                Dutchman
                                #529
                                @beowolf sagte in [ESPHome] Beta release:
                                @maxpd
                                Python 2.7.16
                                Python 3.7.3
                                python muss nach 3.7 verweisen , da dies für jedes System anders ist kan ich die Python Installation selber leider nicht Supporten
                                • B Beowolf
                                  @maxpd
                                  Python 2.7.16
                                  Python 3.7.3
                                  OpenSourceNomad
                                  #530
                                  @beowolf said in [ESPHome] Beta release:
                                  Python 2.7.16
                                  Python 2 ist übrigens schon seit über 2 Jahren EOL. Wahrscheinlich gibt es so ziemliche keine (aktuelle) Software die nicht mit Python 3 kompatibel ist 💡
                                  • B Beowolf
                                    @maxpd
                                    Python 2.7.16
                                    Python 3.7.3
                                    #531
                                    @beowolf
                                    Debian? Bullseye?
                                    Dann würde ich empfehlen:
                                    sudo apt update
                                    sudo apt install python-is-python3
                                    sudo apt autoremove
                                      @beowolf
                                      Debian? Bullseye?
                                      sudo apt update
                                      sudo apt autoremove
                                      Beowolf
                                      #532
                                      Hm.
                                      Ich habe jetzt alles neu aufgesetzt. Backup eingespielt usw.
                                      Es kommt immer noch diese Meldungen:
                                      pi@raspberrypi:~ $ cd /opt/iobroker
                                      pi@raspberrypi:/opt/iobroker $ npm i iobroker.esphome@latest
                                      > npip install
                                        Cache entry deserialization failed, entry ignored
                                        Using cached esphome-2022.3.0-py2.py3-none-any.whl (2.2 MB)
                                        Preparing metadata (setup.py) ... done
                                        Installing build dependencies ... done
                                        Getting requirements to build wheel ... done
                                        Preparing metadata (pyproject.toml) ... done
                                      Collecting esphome-dashboard==20220309.0
                                        Using cached esphome_dashboard-20220309.0-py3-none-any.whl (593 kB)
                                        Installing build dependencies ... error
                                        error: subprocess-exited-with-error
                                        × pip subprocess to install build dependencies did not run successfully.
                                        │ exit code: 1
                                        ╰─> [122 lines of output]
                                            Collecting setuptools>=40.6.0
                                              Using cached setuptools-60.10.0-py3-none-any.whl (1.1 MB)
                                            Collecting wheel
                                              Using cached wheel-0.37.1-py2.py3-none-any.whl (35 kB)
                                            Collecting cffi>=1.12
                                              Using cached cffi-1.15.0.tar.gz (484 kB)
                                            Collecting setuptools-rust>=0.11.4
                                              Using cached setuptools_rust-1.1.2-py3-none-any.whl (21 kB)
                                            Collecting pycparser
                                              Using cached pycparser-2.21-py2.py3-none-any.whl (118 kB)
                                            Collecting typing-extensions>=3.7.4.3
                                              Using cached typing_extensions-4.1.1-py3-none-any.whl (26 kB)
                                            Collecting semantic-version<3,>=2.8.2
                                              Using cached semantic_version-2.9.0-py2.py3-none-any.whl (15 kB)
                                            Building wheels for collected packages: cffi
                                              Building wheel for cffi (setup.py): started
                                              Building wheel for cffi (setup.py): finished with status 'error'
                                              × python setup.py bdist_wheel did not run successfully.
                                              │ exit code: 1
                                              ╰─> [36 lines of output]
                                                  running bdist_wheel
                                                  running build
                                                  running build_py
                                                  creating build
                                                  creating build/lib.linux-armv7l-3.9
                                                  creating build/lib.linux-armv7l-3.9/cffi
                                                  copying cffi/setuptools_ext.py -> build/lib.linux-armv7l-3.9/cffi
                                                  copying cffi/lock.py -> build/lib.linux-armv7l-3.9/cffi
                                                  copying cffi/vengine_gen.py -> build/lib.linux-armv7l-3.9/cffi
                                                  copying cffi/backend_ctypes.py -> build/lib.linux-armv7l-3.9/cffi
                                                  copying cffi/error.py -> build/lib.linux-armv7l-3.9/cffi
                                                  copying cffi/model.py -> build/lib.linux-armv7l-3.9/cffi
                                                  copying cffi/__init__.py -> build/lib.linux-armv7l-3.9/cffi
                                                  copying cffi/ffiplatform.py -> build/lib.linux-armv7l-3.9/cffi
                                                  copying cffi/api.py -> build/lib.linux-armv7l-3.9/cffi
                                                  copying cffi/cparser.py -> build/lib.linux-armv7l-3.9/cffi
                                                  copying cffi/vengine_cpy.py -> build/lib.linux-armv7l-3.9/cffi
                                                  copying cffi/cffi_opcode.py -> build/lib.linux-armv7l-3.9/cffi
                                                  copying cffi/commontypes.py -> build/lib.linux-armv7l-3.9/cffi
                                                  copying cffi/verifier.py -> build/lib.linux-armv7l-3.9/cffi
                                                  copying cffi/pkgconfig.py -> build/lib.linux-armv7l-3.9/cffi
                                                  copying cffi/recompiler.py -> build/lib.linux-armv7l-3.9/cffi
                                                  copying cffi/_cffi_include.h -> build/lib.linux-armv7l-3.9/cffi
                                                  copying cffi/parse_c_type.h -> build/lib.linux-armv7l-3.9/cffi
                                                  copying cffi/_embedding.h -> build/lib.linux-armv7l-3.9/cffi
                                                  copying cffi/_cffi_errors.h -> build/lib.linux-armv7l-3.9/cffi
                                                  running build_ext
                                                  building '_cffi_backend' extension
                                                  creating build/temp.linux-armv7l-3.9
                                                  creating build/temp.linux-armv7l-3.9/c
                                                  arm-linux-gnueabihf-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -fPIC -DUSE__THREAD -DHAVE_SYNC_SYNCHRONIZE -I/usr/include/python3.9 -c c/_cffi_backend.c -o build/temp.linux-armv7l-3.9/c/_cffi_backend.o
                                                  c/_cffi_backend.c:2:10: fatal error: Python.h: Datei oder Verzeichnis nicht gefunden
                                                      2 | #include <Python.h>
                                                  compilation terminated.
                                                  error: command '/usr/bin/arm-linux-gnueabihf-gcc' failed with exit code 1
                                                  [end of output]
                                              note: This error originates from a subprocess, and is likely not a problem with pip.
                                              ERROR: Failed building wheel for cffi
                                              Running setup.py clean for cffi
                                            Failed to build cffi
                                            Installing collected packages: wheel, typing-extensions, setuptools, semantic-version, pycparser, setuptools-rust, cffi
                                              Running setup.py install for cffi: started
                                              Running setup.py install for cffi: finished with status 'error'
                                              × Running setup.py install for cffi did not run successfully.
                                              │ exit code: 1
                                              ╰─> [38 lines of output]
                                                  running install
                                                  /opt/iobroker/node_modules/iobroker.esphome/python_modules/lib/python3.9/site-packages/setuptools/command/install.py:34: SetuptoolsDeprecationWarning: setup.py install is deprecated. Use build and pip and other standards-based tools.
                                                    warnings.warn(
                                                  running build
                                                  running build_py
                                                  creating build
                                                  running build_ext
                                                  [end of output]
                                            error: legacy-install-failure
                                            × Encountered error while trying to install package.
                                            ╰─> cffi
                                            note: This is an issue with the package mentioned above, not pip.
                                            hint: See above for output from the failure.
                                            [end of output]
                                      │ exit code: 1
                                      ╰─> See above for output.
                                      npm ERR! code ELIFECYCLE
                                      npm ERR! errno 1
                                      npm ERR! iobroker.esphome@0.2.4 install: `npip install`
                                      npm ERR! Exit status 1
                                      npm ERR!
                                      npm ERR! Failed at the iobroker.esphome@0.2.4 install script.
                                      npm ERR!     /home/iobroker/.npm/_logs/2022-03-21T16_38_52_555Z-debug.log
                                      Wo mache ich etwas falsch?
                                      • B Beowolf
                                        Hm.
                                        > npip install
                                          │ exit code: 1
                                              Collecting wheel
                                                │ exit code: 1
                                                    running bdist_wheel
                                                    running build
                                                    running build_py
                                                    creating build
                                                    running build_ext
                                                    [end of output]
                                                │ exit code: 1
                                                    running install
                                                      warnings.warn(
                                                    running build
                                                    running build_py
                                                    creating build
                                                    running build_ext
                                                    [end of output]
                                              ╰─> cffi
                                              [end of output]
                                        │ exit code: 1
                                        npm ERR! errno 1
                                        npm ERR!
                                        #533
                                        Wie ist denn python jetzt installiert?
                                        python --version
                                        python3 --version
                                        apt policy python3-pip
                                        apt policy python3-cffi
                                          python --version
                                          python3 --version
                                          Beowolf
                                          #534
                                          pi@raspberrypi:/opt/iobroker $ python --version
                                          Python 3.9.2
                                          pi@raspberrypi:/opt/iobroker $ python3 --version
                                          Python 3.9.2
                                          pi@raspberrypi:/opt/iobroker $ apt policy python3-pip
                                          python3-pip:
                                            Installiert:           (keine)
                                            Installationskandidat: 20.3.4-4+rpt1
                                            Versionstabelle:
                                               20.3.4-4+rpt1 500
                                                  500 http://archive.raspberrypi.org/debian bullseye/main armhf Packages
                                               20.3.4-4 500
                                          pi@raspberrypi:/opt/iobroker $ apt policy python3-cffi
                                          python3-cffi:
                                            Installationskandidat: 1.14.5-1
                                            Versionstabelle:
                                               1.14.5-1 500
