    1.0k
  • Dirk PeterD Dirk Peter
    @simatec
    Hallo simatec,
    wenn die Rollos Abends schon unten sind und dann erst der Frostschutz aktive true wird, so fahren die Rolläden nicht in den Frostschutz!
    Ist das so gewollt, oder noch ein Fehler.
    shuttercontrol.0   9890	2022-01-20 18:09:11.145	debug	insidetemperature changed: hm-rpc.1.001D5A498FDA1C.1.ACTUAL_TEMPERATURE Value: 22.6
    shuttercontrol.0   9890	2022-01-20 18:07:48.823	debug	status alarm pending for hm-rpc.1.00165BE99E4FEB.6.LEVEL: false
    shuttercontrol.0   9890	2022-01-20 18:07:48.777	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
    shuttercontrol.0   9890	2022-01-20 18:07:38.731	debug	status alarm pending for hm-rpc.1.00165BE99E4FEB.2.LEVEL: false
    shuttercontrol.0   9890	2022-01-20 18:07:38.686	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
    shuttercontrol.0   9890	2022-01-20 18:07:28.635	debug	status alarm pending for hm-rpc.1.00165BE99E4FF0.14.LEVEL: false
    shuttercontrol.0   9890	2022-01-20 18:07:28.588	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
    shuttercontrol.0   9890	2022-01-20 18:07:18.543	debug	status alarm pending for hm-rpc.1.00165BE99E4FF0.10.LEVEL: false
    shuttercontrol.0   9890	2022-01-20 18:07:18.496	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
    shuttercontrol.0   9890	2022-01-20 18:07:16.981	debug	Brightness State Down is: true
    shuttercontrol.0   9890	2022-01-20 18:07:08.451	debug	status alarm pending for hm-rpc.1.00165BE99E4FF0.6.LEVEL: false
    shuttercontrol.0   9890	2022-01-20 18:07:08.404	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
    shuttercontrol.0   9890	2022-01-20 18:07:06.978	debug	Brightness sensor value: 0
    shuttercontrol.0   9890	2022-01-20 18:06:58.355	debug	status alarm pending for hm-rpc.1.00165BE99E4FF0.2.LEVEL: false
    shuttercontrol.0   9890	2022-01-20 18:06:58.306	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
    shuttercontrol.0   9890	2022-01-20 18:06:48.259	debug	status alarm pending for hm-rpc.1.00165BE9944866.2.LEVEL: false
    shuttercontrol.0   9890	2022-01-20 18:06:48.211	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
    shuttercontrol.0   9890	2022-01-20 18:06:48.209	debug	start shutterAlarm
    shuttercontrol.0   9890	2022-01-20 18:06:48.204	debug	Alarm Frost changed: true
    mfg Dirk Peter
    mp3junkie
    #4407
    @dirk-peter sagte in Test Adapter shuttercontrol v1.4.x:
    @simatec
    Hallo simatec,
    mfg Dirk Peter
    gibt es hierzu schon eine Lösung?
    Habe ebenfalls dieses Problem.
    Gruß Andy
    Dirk PeterD 1 Antwort Letzte Antwort
    • M mp3junkie
      @simatec
      Hallo simatec,
      mfg Dirk Peter
      Gruß Andy
      Dirk PeterD Offline
      Dirk PeterD Offline
      Dirk Peter
      #4408
      @mp3junkie
      @FoxRo
      Nein hierzu gibt es noch keine Lösung, ich habe es an @FoxRo weitergeleitet, er ist wohl für die Entwicklung dieser Erweiterung zuständig.
      MfG Dirk Peter
      • simatecS simatec
        @weiserwolf Soweit scheint alles zu passen.
        Ich würde den Namen mal von "Büro" in "Buero" umbenennen.
        Umlaute sind nie so ideal.
        Ansonsten schalten den Adapter mal auf Debuglog und poste mal den Log, wenn morgen die Range erreicht wird
        W Offline
        W Offline
        WeiserWolf
        schrieb am zuletzt editiert von WeiserWolf
        #4409
        @simatec
        Ich hoffe ich habe das richtig gemacht mit dem Log:)
        So wie ich das sehe, werden die Daten berechnet, aber irgendwie fehlt mir die Auslösung.
        Anbei auch nochmal die aktuellen Einstellungen als JSON.
        LOG.txt
        system.adapter.shuttercontrol.0.json
        2022-02-28 08:00:00.004 - debug: shuttercontrol.0 (28987) calculate astrodata ...
        2022-02-28 08:00:00.004 - debug: shuttercontrol.0 (28987) Sun Azimut: 109.7°
        2022-02-28 08:00:00.005 - debug: shuttercontrol.0 (28987) Sun Elevation: 4.9°
        2022-02-28 08:00:00.055 - info: shuttercontrol.0 (28987) Children Up #22 Set ID: Office value: 100%
        2022-02-28 08:00:00.063 - debug: shuttercontrol.0 (28987) last automatic Action for Office: up_ChidrenTime
        2022-02-28 08:00:00.063 - debug: shuttercontrol.0 (28987) shutterUpChildren #2 Office old height: 0% new height: 100%
        2022-02-28 08:00:01.066 - debug: shuttercontrol.0 (28987) save current height after State Check: 0% from Office
        2022-02-28 08:00:01.066 - debug: shuttercontrol.0 (28987) Shutter Office was moved manually to: 0% while window was open - prevent trigger from driving back
        2022-02-28 08:00:19.593 - debug: shuttercontrol.0 (28987) Shutter state changed: Office old value = 0 new value = 100
        2022-02-28 08:00:19.595 - debug: shuttercontrol.0 (28987) Office Updated trigger action to Manu_Mode to prevent moving after window close
        2022-02-28 08:00:19.596 - debug: shuttercontrol.0 (28987) Office drived manually to 100. Old value = 0. New value = 100
        2022-02-28 08:00:20.599 - debug: shuttercontrol.0 (28987) save current height after State Check: 100% from Office
        2022-02-28 08:00:20.600 - debug: shuttercontrol.0 (28987) Shutter Office was moved manually to: 100% while window was open - prevent trigger from driving back
        2022-02-28 08:05:00.004 - debug: shuttercontrol.0 (28987) calculate astrodata ...
        2022-02-28 08:05:00.005 - debug: shuttercontrol.0 (28987) Sun Azimut: 110.7°
        Hier noch mal ein Ausschnitt von heute morgen, die zeitliche Auslösung hat funktioniert
        • W WeiserWolf
          @simatec
          LOG.txt
          simatecS Offline
          simatecS Offline
          simatec
          #4410
          @weiserwolf Mehr war im Log nicht drin?
          • Besuche meine Github Seite
          • HowTo Restore ioBroker
          W 1 Antwort Letzte Antwort
          • simatecS simatec
            W Offline
            W Offline
            WeiserWolf
            #4411
            @simatec Von anderen Adaptern ja, aber ich habe nur nach diesem gefiltert. :man-shrugging:
            Vielleicht baue ich einfach wieder einen Gurt ein, das krieg selbst ich Vollpfosten hin 😂 😂
            • W WeiserWolf
              simatecS Offline
              simatecS Offline
              simatec
              #4412
              @weiserwolf
              Das bekommen wir schon hin.
              Zeige mal bitte die Objekte des Rollladens.
              Sun, up und Down
              • simatecS simatec
                @weiserwolf
                Sun, up und Down
                W Offline
                W Offline
                WeiserWolf
                #4413
                Ich zeige einfach mal alle :)
                • W WeiserWolf
                  simatecS Offline
                  simatecS Offline
                  simatec
                  #4414
                  @weiserwolf Da dein Rollladen State auf "none" Steht und du wie ich es gesehen habe shellys verwendest, solltest du die Überprüfung der Rollläden nach x Sekunden aktivieren.
                  • simatecS simatec
                    W Offline
                    W Offline
                    WeiserWolf
                    #4415
                    @simatec Ja ist aktuell ein Shelly mit dem ich noch rumspiele, der war über...
                    Aber verdammte Axt das hatte ich angeklickt, 100%ig, aber dann wohl nicht auf speichern gedrückt :man-shrugging:
                    Habe es noch einmal aktiviert und gespeichert, mal schauen was morgen passiert :)
                    • W WeiserWolf
                      simatecS Offline
                      simatecS Offline
                      simatec
                      #4416
                      @weiserwolf shellys schwanken während der Fahrt mit dem State etwas. Darum muss nach Ende der Fahrt von Shuttercontrol der Status noch einmal geprüft werden.
                      Ist leider ne doof Eigenschaft von den Shellys.
                      Habe aber gelesen, dass man dies wohl in der Config beheben kann.
                      Hab aber keine zum testen da
                      • simatecS simatec
                        W Offline
                        W Offline
                        WeiserWolf
                        #4417
                        @simatec Wenn es morgen läuft, schaue ich mal bei den Shelleys rein, was da so geht.
                        Das ist aber normal? Habe ich jetzt erstmalig im Log seit ich die Option aktiviert habe 😵
                        shuttercontrol.0
                        27253	2022-03-01 19:12:24.692	warn
                        This object will not be created in future versions. Please report this to the developer.
                        shuttercontrol.0
                        27253	2022-03-01 19:12:24.692	warn	Object shuttercontrol.0.info.Azimut
                        is invalid: Default value has to be type "number" but received type "string"
                        shuttercontrol.0
                        27253	2022-03-01 19:12:24.649	warn
                        shuttercontrol.0
                        27253	2022-03-01 19:12:24.649	warn	Object shuttercontrol.0.info.Elevation
                        • W WeiserWolf
                          shuttercontrol.0
                          shuttercontrol.0
                          shuttercontrol.0
                          shuttercontrol.0
                          simatecS Offline
                          simatecS Offline
                          simatec
                          #4418
                          @weiserwolf
                          Ja das Warnungen, die in der nächsten Version gefixt werden
                          • F Offline
                            Futty
                            #4419
                            ich habe seit ein paar Tagen das Problem, dass die Zeiten für das hochfahren nicht mehr passen und ich kann mir nach längerem suchen leider immer noch nicht erklären an was es liegt...
                            Es wird einfach immer die späteste Zeit zum hochfahren verwendet.
                            Shuttercontrol v1.4.10
                            Node.js v14.18.2
                            js-controller v4.0.15
                            Objects - Control:
                            Objects - Info:
                            Zeit-Einstellungen - Einstellungen für den Wohnbereich
                            Extra-Einstellungen - Astro-Einstellung:
                            Log (Debug) nach Adapterstart:
                            Jemand eine Idee / ein Tipp?
                            Falls noch weitere Infos benötigt werden stelle ich diese gerne bereit.
                            Vielen Dank schon einmal!
                            Gruß Futty
                            • F Futty
                              Node.js v14.18.2
                              Objects - Control:
                              Objects - Info:
                              Gruß Futty
                              Murphys234d
                              schrieb am zuletzt editiert von Murphys234d
                              #4420
                              @futty Bei mir ist es anders, aber doch ähnlich.
                              Ich nutze feste Zeiten, aber auch diese funktionieren jetzt nicht mehr.
                              Denkt er es sei Wochenende oder Feiertag?
                              Version 1.4.10, node: v14.19.0, js-controller: 4.0.15
                              edit: Er denkt es sei Wochenende. Zumindest übernimmt er für den gezeigten Datenpunkt nur die Wochenendangabe. Datum und Uhrzeit auf der Infoseite des iobrokers stimmen.
                              • M Murphys234d
                                Murphys234d
                                #4421
                                @murphys234d said in Test Adapter shuttercontrol v1.4.x:
                                Habe gestern einmal die gewünschte Zeit beim Wochenende eingetragen und heute morgen sind sie zu dem Zeitpunkt wieder hochgefahren. "Fehler" sehe ich nur die gleichen warnings wie futty
                                edit: hab ein issue erstellt: https://github.com/simatec/ioBroker.shuttercontrol/issues/383
                                F 1 Antwort Letzte Antwort
                                • simatecS Offline
                                  simatecS Offline
                                  simatec
                                  #4422
                                  @murphys234d Bitte die Config als json posten.
                                  Dein problem ist nicht reproduzierbar
                                  • M Murphys234d
                                    Futty
                                    #4423
                                    @murphys234d
                                    Ohne eine Änderung sind die Rollläden heute bei mir auch wieder korrekt hochgefahren.
                                    Ich beobachte es mal weiter. Vielleicht erkenne ich ein Muster.
                                    • F Futty
                                      @murphys234d
                                      Murphys234d
                                      #4424
                                      @futty Bei mir lag der Fehler vor dem Rechner, auch wenn ich mir erklären kann wann ich das umgestellt hätte.
                                      Wohnbereich (über den alle Fenster laufen) stand auf "Nur Zeit", statt "Zeit und Sonnenaufgang".
                                      In der Ansicht fehlt das "früheste Öffnen" und das war zeitlich hinter dem spätesten Öffnen eingestellt.
                                      Nochmal Danke @simatec für den schnellen, guten Support. Ein toller Adapter. Inzwischen hat er nur fast zu viele Features ;)
                                      • M Murphys234d
                                        Futty
                                        schrieb am zuletzt editiert von Futty
                                        #4425
                                        @murphys234d
                                        ich hab ja meine Einstellungen mit Bildern gepostet.
                                        Scheint meiner Meinung nach zu passen.
                                        Und laut den objects passt es nicht. Morgen ist Wochenende und die Rollos gehen normal hoch...
                                        anbei mal meine .json
                                          Android51
                                          #4426
                                          Ich habe gestern den Adapter auf die neuste Version aktualisiert. Seitdem fahren die Rolläden nicht mehr. Es wird im Protokoll alles korrekt protokolliert, jeder Rolladen sei angeblich gefahren, aber tatsächlich fährt nichts.
                                          Die Rolladen können manuell noch über den Rolladen-Adapter angesteuert werden. Finde irgendwie das Problem nicht. Könnt ihr mir helfen?
