  4. js-controller 4.0 jetzt im BETA/LATEST!
747 Beiträge 70 Kommentatoren 396.3k Aufrufe 60 Beobachtet
  • DiginixD
    DiginixD
    Diginix
    #180
    @apollon77 Update von 3.3.22 auf 4.0.5 lief durch mit folgender Ausgabe:
    Update js-controller from @3.3.22 to @4.0.5
    NPM version: 6.14.16
    npm install iobroker.js-controller@4.0.5 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
    In file included from ../../nan/nan.h:56,
                     from ../src/unix_dgram.cc:5:
    /home/iobroker/.cache/node-gyp/14.19.0/include/node/node.h:793:43: warning: cast between incompatible function types from âvoid (*)(v8::Local<v8::Object>)â to ânode::addon_register_funcâ {aka âvoid (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)â} [-Wcast-function-type]
      793 |       (node::addon_register_func) (regfunc),                          \
    /home/iobroker/.cache/node-gyp/14.19.0/include/node/node.h:827:3: note: in expansion of macro âNODE_MODULE_Xâ
      827 |   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
    ../src/unix_dgram.cc:404:1: note: in expansion of macro âNODE_MODULEâ
      404 | NODE_MODULE(unix_dgram, Initialize)
    Server Objects 127.0.0.1:51724 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets"]
    Server States 127.0.0.1:42094 Error from InMemDB: Error: GET-UNSUPPORTED for namespace meta.: Data=["meta.states.protocolVersion"]
    Server Objects 127.0.0.1:51724 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.protocolVersion"]
    Server States 127.0.0.1:42096 Error from InMemDB: Error: PSUBSCRIBE-UNSUPPORTED for namespace meta.: Data=["meta.*"]
    Server Objects 127.0.0.1:51724 Error from InMemDB: Error: Unknown LUA script load
    Server Objects 127.0.0.1:51724 Error from InMemDB: Error: SET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets",{"type":"Buffer","data":[49]}]
    Could not migrate objects to corresponding sets: Error SET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets",{"type":"Buffer","data":[49]}]
    Hoffentlich ok so.
    iobroker@iobroker:/opt/iobroker$ iobroker start
    iobroker@iobroker:/opt/iobroker$ iobroker status
    Objects type: jsonl
    States  type: jsonl
    /usr/bin/iobroker: line 8: 37859 Killed                  node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js "$@"
    Die letzte Zeile kam nur beim ersten mal status. Danach nicht mehr.
    Meine /opt/iobroker/iobroker-data/iobroker.json enthält aber deutlich weniger Blöcke als hier gezeigt:
    https://github.com/ioBroker/ioBroker.js-controller/blob/master/packages/controller/conf/iobroker-dist.json#L53-L71
      "system": {
        "memoryLimitMB": 0,
        "hostname": ""
      "multihostService": {
        "enabled": false,
        "secure": true
      "network": {
        "IPv4": true,
        "IPv6": true,
        "bindAddress": null,
        "useSystemNpm": true
      "objects": {
        "type": "jsonl",
        "typeComment": "Possible values: 'file' - [port 9001], redis - [port 6379], couch - [port 5984].",
        "host": "127.0.0.1",
        "port": 9001,
        "user": "",
        "pass": "",
        "noFileCache": false,
        "connectTimeout": 2000,
        "writeFileInterval": 3600000,
        "options": {
          "auth_pass": null,
          "retry_max_delay": 5000
      "states": {
        "type": "jsonl",
        "typeComment": "Possible values: 'file' - [port 9000], 'redis' - [port 6379].",
        "port": 9000,
        "maxQueue": 1000,
        "writeFileInterval": 60000,
        "options": {
          "auth_pass": null,
      "log": {
        "level": "warn",
        "maxDays": 14,
        "noStdout": true,
        "transport": {
          "file1": {
            "zippedArchive": false,
            "type": "file",
            "enabled": true,
            "filename": "log/iobroker",
            "fileext": ".log",
            "maxsize": null,
            "maxFiles": null
          "syslog1": {
            "type": "syslog",
            "enabled": false,
            "host": "localhost",
            "host_comment": "The host running syslogd, defaults to localhost.",
            "port_comment": "The port on the host that syslog is running on, defaults to syslogd's default port(514/UDP).",
            "protocol": "udp4",
            "protocol_comment": "The network protocol to log over (e.g. tcp4, udp4, unix, unix-connect, etc).",
            "path_comment": "The path to the syslog dgram socket (i.e. /dev/log or /var/run/syslog for OS X).",
            "facility_comment": "Syslog facility to use (Default: local0).",
            "localhost": "iobroker",
            "localhost_comment": "Host to indicate that log messages are coming from (Default: localhost).",
            "sysLogType_comment": "The type of the syslog protocol to use (Default: BSD).",
            "app_name_comment": "The name of the application (Default: process.title).",
            "eol_comment": "The end of line character to be added to the end of the message (Default: Message without modifications)."
      "dataDirComment": "Always relative to iobroker.js-controller/",
      "dataDir": "../../iobroker-data/"
    Wie bekommt man die mal auf den neusten Standard?
    Wird bei jsonl objects.writeFileInterval: 3600000 und states.writeFileInterval: 60000 ignoriert?
    ..:: So long! Tom ::..
    • AlligatorA
      AlligatorA
      Alligator
      #181
      Hallo an alle,
      auch bei mir funktionieren keine Updates mehr!
      Node.js
      v14.19.0
      NPM
      v6.14.16
      Dem JS-Controller hatte ich auf 4.0.4 geupdatet und alle Instanzen sind auf Grün und laufen.
      Aber beim Versuch eines Updates läuft es durch aber der Adapter startet immer wieder mit der alten Version. auch ein Downgrade geht nicht.
      Ein Update auf denn JS-Controller 4.0.5 ging auch nicht. Bei dem versuch den JS-Controller per Downgrade auf 3.3.22 zu bringen wurde mir stattdessen der 4.0.5 eingespielt . Aber auch mit dem Funktioniert weder Update noch Downgrade. Auch ein erneuter versuch auf JS-Controller 3.3.22 Downzugraden blieb erfolglos.
      Installations Verlauf:
      $ iobroker upgrade iot@1.9.5
      Update iot from @1.9.3 to @1.9.5
      host.SmartHomeServer Adapter "system.adapter.iot.0" is stopped.
      Installing iobroker.iot@1.9.5... (System call)
      Could not check npm version: This directory tree does not contain a package.json
      Assuming that correct version is installed.
      host.SmartHomeServer Adapter "system.adapter.iot.0" is started
      upload [18] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/actions.js actions.js application/javascript
      upload [17] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/alexalogo.png alexalogo.png image/png
      upload [16] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/asset-manifest.json asset-manifest.json application/json
      upload [15] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/blockly.js blockly.js application/javascript
      upload [14] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
      upload [13] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/index_m.html index_m.html text/html
      upload [12] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/iot.png iot.png image/png
      upload [11] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/manifest.json manifest.json application/json
      upload [10] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/2.faf2f676.chunk.css static/css/2.faf2f676.chunk.css text/css
      upload [9] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/2.faf2f676.chunk.css.map static/css/2.faf2f676.chunk.css.map application/json
      upload [8] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/main.e2d673ee.chunk.css static/css/main.e2d673ee.chunk.css text/css
      upload [7] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/main.e2d673ee.chunk.css.map static/css/main.e2d673ee.chunk.css.map application/json
      upload [6] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/2.1b9b16a0.chunk.js static/js/2.1b9b16a0.chunk.js application/javascript
      upload [5] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/2.1b9b16a0.chunk.js.LICENSE.txt static/js/2.1b9b16a0.chunk.js.LICENSE.txt text/plain
      upload [4] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/2.1b9b16a0.chunk.js.map static/js/2.1b9b16a0.chunk.js.map application/json
      upload [3] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/main.20d2f37b.chunk.js static/js/main.20d2f37b.chunk.js application/javascript
      upload [2] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/main.20d2f37b.chunk.js.map static/js/main.20d2f37b.chunk.js.map application/json
      upload [1] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/runtime-main.ef534f76.js static/js/runtime-main.ef534f76.js application/javascript
      upload [0] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/runtime-main.ef534f76.js.map static/js/runtime-main.ef534f76.js.map application/json
      Process exited with code 0
      und der dazugehörige LOG
      2022-02-09 12:05:01.891	info	instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2022-02-09 12:05:00.043	info	instance system.adapter.dwd.0 started with pid 19837
      iot.0
      2022-02-09 12:03:12.290	info	Connection changed: connect
      iot.0
      2022-02-09 12:03:11.887	warn	Cannot update api-secret: undefined
      iot.0
      2022-02-09 12:03:11.869	info	Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
      iot.0
      2022-02-09 12:03:11.846	info	starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.iot, node: v14.19.0, js-controller: 4.0.5
      2022-02-09 12:03:11.046	info	instance system.adapter.iot.0 started with pid 19205
      2022-02-09 12:03:09.408	info	iobroker exit 0
      2022-02-09 12:03:08.393	info	iobroker upload [0] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/runtime-main.ef534f76.js.map static/js/runtime-main.ef534f76.js.map application/json
      2022-02-09 12:03:08.389	info	iobroker upload [1] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/runtime-main.ef534f76.js static/js/runtime-main.ef534f76.js application/javascript
      2022-02-09 12:03:08.385	info	iobroker upload [2] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/main.20d2f37b.chunk.js.map static/js/main.20d2f37b.chunk.js.map application/json
      2022-02-09 12:03:08.380	info	iobroker upload [3] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/main.20d2f37b.chunk.js static/js/main.20d2f37b.chunk.js application/javascript
      2022-02-09 12:03:08.374	info	instance system.adapter.iot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2022-02-09 12:03:08.149	info	iobroker upload [4] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/2.1b9b16a0.chunk.js.map static/js/2.1b9b16a0.chunk.js.map application/json
      2022-02-09 12:03:08.147	info	iobroker upload [5] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/2.1b9b16a0.chunk.js.LICENSE.txt static/js/2.1b9b16a0.chunk.js.LICENSE.txt text/plain
      2022-02-09 12:03:08.136	info	iobroker upload [6] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/2.1b9b16a0.chunk.js static/js/2.1b9b16a0.chunk.js application/javascript
      2022-02-09 12:03:08.133	info	iobroker upload [7] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/main.e2d673ee.chunk.css.map static/css/main.e2d673ee.chunk.css.map application/json
      2022-02-09 12:03:08.131	info	iobroker upload [8] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/main.e2d673ee.chunk.css static/css/main.e2d673ee.chunk.css text/css
      2022-02-09 12:03:08.129	info	iobroker upload [9] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/2.faf2f676.chunk.css.map static/css/2.faf2f676.chunk.css.map application/json
      2022-02-09 12:03:08.126	info	iobroker upload [10] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/2.faf2f676.chunk.css static/css/2.faf2f676.chunk.css text/css
      2022-02-09 12:03:08.123	info	iobroker upload [11] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/manifest.json manifest.json application/json
      2022-02-09 12:03:08.120	info	iobroker upload [12] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/iot.png iot.png image/png
      2022-02-09 12:03:08.100	info	iobroker upload [13] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/index_m.html index_m.html text/html
      2022-02-09 12:03:08.097	info	iobroker upload [14] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
      2022-02-09 12:03:08.094	info	iobroker upload [15] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/blockly.js blockly.js application/javascript
      2022-02-09 12:03:08.091	info	iobroker upload [16] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/asset-manifest.json asset-manifest.json application/json
      2022-02-09 12:03:08.087	info	iobroker upload [17] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/alexalogo.png alexalogo.png image/png
      2022-02-09 12:03:08.079	info	iobroker upload [18] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/actions.js actions.js application/javascript
      iot.0
      2022-02-09 12:03:07.957	info	Got terminate signal TERMINATE_YOURSELF
      2022-02-09 12:03:07.957	info	stopInstance system.adapter.iot.0 send kill signal
      2022-02-09 12:03:07.955	info	stopInstance system.adapter.iot.0 (force=false, process=true)
      2022-02-09 12:03:07.954	info	"system.adapter.iot.0" enabled
      2022-02-09 12:03:07.943	info	iobroker host.SmartHomeServer Adapter "system.adapter.iot.0" is started
      2022-02-09 12:03:07.943	error	iobroker Assuming that correct version is installed.
      2022-02-09 12:03:07.942	error	iobroker Could not check npm version: This directory tree does not contain a package.json
      2022-02-09 12:03:07.940	info	iobroker Installing iobroker.iot@1.9.5... (System call)
      2022-02-09 12:03:07.938	info	iobroker NPM version: 6.14.16
      iot.0
      2022-02-09 12:03:07.829	info	Connection lost
      iot.0
      2022-02-09 12:03:07.828	info	Connection changed: disconnect
      iot.0
      2022-02-09 12:03:07.782	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      iot.0
      2022-02-09 12:03:07.781	info	terminating
      iot.0
      2022-02-09 12:03:07.778	info	Got terminate signal TERMINATE_YOURSELF
      2022-02-09 12:03:07.777	info	stopInstance system.adapter.iot.0 send kill signal
      2022-02-09 12:03:07.775	info	stopInstance system.adapter.iot.0 (force=false, process=true)
      2022-02-09 12:03:07.774	info	"system.adapter.iot.0" disabled
      2022-02-09 12:03:07.763	info	iobroker host.SmartHomeServer Adapter "system.adapter.iot.0" is stopped.
      2022-02-09 12:03:07.748	info	iobroker Update iot from @1.9.3 to @1.9.5
      2022-02-09 12:03:06.457	info	iobroker upgrade iot@1.9.5
      It's done when it's done, but it's never really finished!
      Lg euer Alligator :P
      System: Dell Wyse 5070 Thin Client mit Pentium® Silver J5005, 16gb Ram und 500gb SSD, Debian 13 Trixie mit ioBrocker
      PS: Wer Rechtschreibfehler findet darf sie gern behalten. Ich habe noch mehr davon. :)
      • E eXectiX
        @ice987 @ste_glei
        ich habe den selben fehler nun beim starten des Containers.
        Die Eingabe von iobroker fix bewirkt in der Konsole allerdings nichts und der Fehler bleibt beim erneuten versuch zu starten.
        Könnt ihr mir weiter helfen?
        ste_gleiS
        ste_gleiS
        ste_glei
        #182
        @exectix sagte in js-controller 4.0 jetzt im BETA/LATEST!:
        ich bin nur ein Nutzer der seine Erfahrungen weitergibt. Für Ratschläge oder genaue Hilfe reicht mein Wissen leider nicht.
        E 1 Antwort Letzte Antwort
          @apollon77 ich hab es jetzt mal gelöscht, iob gestoppt, nodejs minor update und iob gestartet( ohne fixer) mal schaun ob der js controller das richtig macht (setcap)
          crunchipC
          crunchipC
          Developer Global Moderator Most Active Forum Testing
          #183
          @crunchip sagte in js-controller 4.0 jetzt im BETA/LATEST!:
          nun habe ich v4.05 eingespielt, diesmal zum ersten mal passiert, das scheinbar noch Prozesse liefen(hatte nicht gegengeprüft) halbsowild
          allerdings, kamen mehrere Warnungen aus der influxdb.3 nach dem Start(ist eine Testinstanz v2.x, wo nur 2 Datenpunkte geloggt werden)
          die anderen 3 Instanzen sind v1.x, ohne Probleme
          2022-02-09 12:01:18.879 - warn: influxdb.3 (12514) Point could not be written to database: iobroker
          2022-02-09 12:01:18.880 - warn: influxdb.3 (12514) Error on writePoint("{"value":4.04,"time":"2022-02-09T11:01:07.510Z","from":"system.host.IoBroker","q":0,"ack":true}): RequestTimedOutError: Request timed out / "Request timed out""
          2022-02-09 12:01:18.881 - info: influxdb.3 (12514) Add point that had error for system.host.IoBroker.load to buffer again, error-count=1
          2022-02-09 12:01:20.360 - warn: influxdb.3 (12514) Point could not be written to database: iobroker
          2022-02-09 12:01:20.361 - warn: influxdb.3 (12514) Error on writePoint("{"value":82.83,"time":"2022-02-09T11:01:09.079Z","from":"system.host.IoBroker","q":0,"ack":true}): RequestTimedOutError: Request timed out / "Request timed out""
          2022-02-09 12:01:20.364 - info: influxdb.3 (12514) Add point that had error for system.host.IoBroker.cpu to buffer again, error-count=1
          2022-02-09 12:01:28.890 - warn: influxdb.3 (12514) Point could not be written to database: iobroker
          2022-02-09 12:01:28.891 - warn: influxdb.3 (12514) Error on writePoint("{"value":4.04,"time":"2022-02-09T11:01:07.510Z","from":"system.host.IoBroker","q":0,"ack":true}): RequestTimedOutError: Request timed out / "Request timed out""
          2022-02-09 12:01:28.892 - info: influxdb.3 (12514) Add point that had error for system.host.IoBroker.load to buffer again, error-count=2
          2022-02-09 12:01:30.369 - warn: influxdb.3 (12514) Point could not be written to database: iobroker
          2022-02-09 12:01:30.370 - warn: influxdb.3 (12514) Error on writePoint("{"value":82.83,"time":"2022-02-09T11:01:09.079Z","from":"system.host.IoBroker","q":0,"ack":true}): RequestTimedOutError: Request timed out / "Request timed out""
          2022-02-09 12:01:30.370 - info: influxdb.3 (12514) Add point that had error for system.host.IoBroker.cpu to buffer again, error-count=2
          2022-02-09 12:01:38.896 - warn: influxdb.3 (12514) Point could not be written to database: iobroker
          2022-02-09 12:01:38.897 - warn: influxdb.3 (12514) Error on writePoint("{"value":4.04,"time":"2022-02-09T11:01:07.510Z","from":"system.host.IoBroker","q":0,"ack":true}): RequestTimedOutError: Request timed out / "Request timed out""
          2022-02-09 12:01:38.898 - info: influxdb.3 (12514) Add point that had error for system.host.IoBroker.load to buffer again, error-count=3
          2022-02-09 12:01:40.380 - warn: influxdb.3 (12514) Point could not be written to database: iobroker
          2022-02-09 12:01:40.382 - warn: influxdb.3 (12514) Error on writePoint("{"value":82.83,"time":"2022-02-09T11:01:09.079Z","from":"system.host.IoBroker","q":0,"ack":true}): RequestTimedOutError: Request timed out / "Request timed out""
          2022-02-09 12:01:40.383 - info: influxdb.3 (12514) Add point that had error for system.host.IoBroker.cpu to buffer again, error-count=3
          jetzt die Frage, liegt das an v2, oder an den beiden geloggten DP's ?
          • ste_gleiS ste_glei
            E
            E
            eXectiX
            #184
            @ste_glei alles klar, ich habe es wieder zum laufen bekommen nachdem ich nochmal Node.js neu installiert habe. Muss wohl irgendwas beim Update des js-controllers kaputt gegangen sein. Trotzdem danke
            • apollon77A apollon77
              Hallo ioBroker-Community,
              nach längerer Entwicklungszeit kommt heute der neue js-controller 4.0 (Releasename "Isabelle") ins Beta/Latest Repository (sollte im laufe des Abends bei allen auftauchen). Dieser Artikel enthält alle wichtigen Infos zu diesem Release und im zweiten Post eine kleine FAQ.
              Node.js Versions-Anforderungen
              In diesem Release entfällt Node.js 10.x, welches seit April letztem Jahr nicht mehr gepflegt wird. Node.js 16.x ist dazugekommen. Die unterstützten Node.js Versionen sind damit: 12.x, 14.x und 16.x. Die empfohlene Node.js Version für ioBroker heben wir mit diesem Release auf 14.x an. Node.js 16.x wird mit js-controller 4.0 nun auch mit npm 7 bzw. 8 unterstützt.
              Bitte beachtet weiterhin bei Node.js Updates die Anleitung im Forum unter https://forum.iobroker.net/topic/44566/how-to-node-js-für-iobroker-richtig-updaten-2021-edition , welche NOCH NICHT für js-controller 4.0 aktualisiert wurde. Infos in der FAQ hier im Thread.
              Informationen zur Version
              Neben einigen Optimierungen und Verbesserungen stand der Haupt-Fokus dieser Version auf Performance-Verbesserungen. Ein paar neue Features sind aber ebenfalls hinzugekommen. Auch daran den Wildwuchs in der Umsetzung einiger Adapter etwas einzugrenzen wurde weiter gearbeitet, was ggf. zu neuen Log-Meldungen für bestimmte Fälle führt. Bitte unterstützt hier wieder und legt bei den relevanten Adaptern im GitHub Issues an, damit diese Dinge gefixt werden können.
              Mit dem js-controller 4.0 wird intern die Datenbank von "file" auf "jsonl" umgestellt. Dies geschieht bei der Installation automatisch ohne weitere Aktionen, wenn file genutzt wird. Weitere Details dazu sieht in der FAQ (Post #2)! Nach erfolgter Migration erscheint beim nächsten Öffnen (oder Reloads falls offen) des Admin5 auch eine Information dazu:
              Detailliertere Informationen zu allen Änderungen und Features findet Ihr weiter unten und im Changelog. Ich hoffe auch diesmal auf Eure tatkräftige Unterstützung, sodass der Stable-Release dann genau so reibungslos verläuft wie bei den letzten Versionen.
              In Summe sind in diese Version wieder über 100 Änderungen in über 300 commits eingeflossen. Dafür bedanke mich diesmal wieder besonders bei foxriver76, AlCalzone und natürlich Bluefox und auch ein paar weiteren Entwicklern für die aktive Mitarbeit an dieser Version!
              Der js-controller 4.0 ist generell kompatibel mit allen bestehenden ioBroker-Systemen. Ein Update von der 2.0/2.1/2.2/3.x ist problemlos möglich. Wir empfehlen allerings vor dem Update auf die 4.0 idealerweise ein Update auf die 3.3.x durchzuführen, da ein Downgrade nach einem erfolgten Update nur auf eine 3.3.x möglich ist (siehe FAQ)! Nur die Node.js Version muss weiterhin mindestens 12.x sein, wie oben bereits ausgeführt. Wer überlegt die Node.js Version anzuheben bitte weiter unten im Abschnitt "Was ist zu testen" lesen 🙂
              Es gibt aktuell keine bekannten inkompatiblem Adapter, aber einige Empfehlungen weiter unten.
              Installation
              VOR der Installation
              Wie der Thread-Name sagt ist diese version nur für die User verfügbar, die das Beta/Latest Repository nutzen! Bei Stable Systemen wird das Update noch nicht angeboten.
              Wie bei jedem Test dieser Art: Bitte macht ein Backup! iobroker backup bzw kopieren des iobroker-data Verzeichnisses reichen an sich aus. Bitte nicht das node_modules Verzeichnis einfach kopieren, da sonst symbolische Links kaputt gehen können, was zu größeren Problemen danach führt. Eine alte 3.3.x-Version des js-controller kann im Notfall einfach wieder per npm install iobroker.js-controller@version ("version" durch die gewünschte Versionsnummer ersetzen, vorher ins ioBroker Verzeichnis wechseln cd /opt/iobroker) installiert werden und sollte alles wieder herstellen.
              Für die User, welche die experimentelle JSONL-Datenbank bereits einsetzen, ändert sich nichts - ausser das dieser Datenbank-Typ nun die offizielle ist :-)
              Nötige Adapter-Aktualisierungen
              Aktuell sind zwei Adapter bekannt, welche Inkompatibel sind:
              • Backitup sollte auf 2.3.3+ aktualisiert sein, damit vor allem Restores mit js-controller 4 sauber funktionieren
              • Node-Red muss in Verson 2.4.2 Installiert sein, da der Adapter sonst nicht funktioniert
              • km200 (see https://github.com/frankjoke/ioBroker.km200/issues/69): Fix is described in https://forum.iobroker.net/post/760260
              Am besten dennoch VOR dem js-controller Update alle verfügbaren Adapter-Updates prüfen und alle Updates installieren, die im Changelog auf Optimierungen oder Anpassungen für den js-controller 3.3 oder höher hinweisen.
              Es werden aber, wie oben ausgeführt, einige Adapter ggf. Warnungen ins Log schreiben - und ggf kommen ein paar neue dazu, welche aber primär bei Objektanlagen interessant sind und weniger im Betrieb "nerven". Meldungen die vor dem Upgrade im Log waren sind jetzt auch noch da.
              Bitte zuerst versuchen die gemeldeten Objekt-IDs via Admin zu löschen und den Adapter neu zu starten. Wenn die Meldungen danach nicht weg sein sollten ist aktuell die einzige Option das Loglevel der betroffenen Instanz auf "Warning" zu setzen - aber erst nachdem die Logs idealerweise in einem GitHub-Issue beim entsprechendem Adapter gemeldet wurden!
              Achtung: MASTER-Systeme Reihenfolgen beachten!
              Bei einem Multi-Host-System, welches auf js-controller 2.2 oder 3.x läuft, ist es beim Update auf Version 4.0 empfohlen, zuerst das Master-System zu aktualisieren. Der Master muss dann wieder gestartet werden. Die Slaves werden danach aktualisiert!
              Bei Updates von Master/Slave-Systemen mit js-controller 1.5 oder früher auf die 4.0 müssen zwingend zuerst die Slaves und der Master als letztes aktualisiert werden. Beim Slave Update muss der alte Master aber noch laufen. Die Slaves bleiben nach dem Update offline und können sich nicht zum Master verbinden und werden erst wieder funktionieren wenn auch der Master auf die 4.0 aktualisiert wurde!
              Windows
              Aus der Community kommt von @sigi234 eine Anleitung für ein Windows Update https://forum.iobroker.net/topic/51574/windows-installation-update
              Für alle "alten manuellen" Installationen gilt
              • iobroker update
              • ioBroker muss gestoppt sein.
              • Vor dem Update bitte prüfen das keine Prozesse mehr laufen
              • iobroker upgrade self
              • ioBroker starten
              Linux
              • iobroker update
              • ioBroker stoppen (iobroker stop)
              • prüfen das keine Prozesse (Adapter, Backups) mehr laufen (ps auxww|grep io und auch ps auxww|grep backup ). Es passiert manchmal das trotz dem Stoppen noch Zombies zurückbleiben
              • iobroker fix
              • Wie üblich wird das Update dann per iobroker upgrade self ausgeführt.
              • ioBroker starten (iobroker start)
              Die Installation wird - wenn Sie von einem 2.x/3.x-System aus erfolgt einige Warnungen/Fehler loggen. Wenn diese aussgehen wie im folgenden Bild gezeigt (GET/SET-UNSUPPOTED bzw LUA script load error), ist dies erwartet und ok!
              Update js-controller from @3.3.22 to @4.0.4
              npm install iobroker.js-controller@4.0.4 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
              Server Objects 127.0.0.1:37942 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets"]
              Server Objects 127.0.0.1:37942 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.protocolVersion"]
              Server States 127.0.0.1:60678 Error from InMemDB: Error: GET-UNSUPPORTED for namespace meta.: Data=["meta.states.protocolVersion"]
              Server States 127.0.0.1:60680 Error from InMemDB: Error: PSUBSCRIBE-UNSUPPORTED for namespace meta.: Data=["meta.*"]
              Server Objects 127.0.0.1:37942 Error from InMemDB: Error: Unknown LUA script load
              Server Objects 127.0.0.1:37942 Error from InMemDB: Error: SET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets",{"type":"Buffer","data":[49]}]
              Server Objects 127.0.0.1:37942 Error from InMemDB: Error: multi NOT SUPPORTED
              Server Objects 127.0.0.1:37942 Error from InMemDB: Error: sadd NOT SUPPORTED
              Server Objects 127.0.0.1:37942 Error from InMemDB: Error: exec NOT SUPPORTED
              Wichtig: Falls es bei Updates von js-controller 3.2.x bei update oder upgrade einen Fehler gibt "No connection to database" dann bitte nochmals versuchen und wenn es wieder passiert folgende Schritte ausführen:
              • Editiere /opt/iobroker/iobroker-data/iobroker.json
              • Unter objects und states gibt es ein ' "connectTimeout": 2000,`
              • Zahl ändern in 5000
              • Neu versuchen
              • Nach dem Upgrade am besten den Wert wieder zurücketzen weil der js-controller 3.3+ hier optimiert und länger wartet
              Bei Fehlern:
              Wenn bei der Installation Fehler wegen fehlender Zugriffsrechte auftreten, am besten den Installation-Fixer (iobroker fix wer schon einen js-controller 2.x oder höher hat, alternativ weiterhin manuell via curl -sL https://iobroker.net/fix.sh | bash -) nutzen und die Installation wiederholen.
              Falls es auch danach noch Fehler gibt, bitte die Installation erneut mittels sudo -H -u iobroker npm install iobroker.js-controller versuchen. Bitte berichtet solche Fälle hier im Thread.
              Die Installation kann ggf. Warnungen ausspucken über potentiell "deprecated" NPM Module oder Compiler-Warnungen oder (bei optionalen Paketen auch -Fehler) anzeigen (z.B, unix_dgram, serialport, pam_authentication und ggf andere). Hier gilt wie immer: Ignorieren :-)
              Ebenso eine Aufforderung "npm audit fix" auszuführen kann ignoriert werden!
              NACH der Installation
              Nach der Installation sollte der ioBroker automatisch wiederder gestartet werden. Falls doch nicht bitte mittels iobroker start starten.
              Wenn alles klappt merkt Ihr ausser der höheren Versionsnummer in der Host-Ansicht im Admin keinen Unterschied. Alles funktioniert weiterhin wie vorher. Alle Adapterinstanzen starten und funktionieren. Wenn das so ist hat alles geklappt.
              Falls im Log Warn-Meldungen auftauchen mit dem Hinweis diese an den Entwickler zu senden, dann bitte schauen welcher Adapter es ist und entsprechend dort Issues bitte anlegen!
              Was hat sich geändert, was besonders ansehen/beachten?
              Neben einiger weiterer Bugfixes gibt es folgende Änderungen und Fixes zu erwähnen:
              • generell siehe Changelog, speziell auch für die Features
              • Prüfen das mit JSONL alles tut (Im Backup Dir werden die letzten "File DB Backups" liegen bleiben, kann man manuell löschen)
              • Bitte generell Augenmerk darauf legen das alle CLI Kommandos noch tun die man so nutzt. Da wurde einiges unter der Haube überarbeitet
              • Gern mal ein Nodejs update testen um zu schauen das das neue Rebuild tut wie es soll :-)
              • Einige Adapter werden Warnungen ausgeben wenn State-Werte gesetzt werden, da nun auch Datentypen und min/max-Werte geprüft werden. Bitte bei den Adapter-Repos melden
              Speziell die Entwickler sollten bitte die genannten Deprecations und neuen Features anschauen und beachten.
              Wie bereits gesagt, viele Änderungen fanden hinter den Kulissen statt. Hier für Interessierte als Spoiler eine Zusammenfassung:
              BREAKING CHANGES
              • Support for Node.js 10 is dropped! Supported are Node.js 12.x, 14.x and 16.x
              • CLI command iob update --updateable changed to iob update --updatable
              • CLI command iob update http://download.iobroker.net/sources-dist.json is not supported anymore
              • CLI command iob rebuild adaptername is no longer supported because of the new way of automatic rebuilds and some unwanted side effects
              • CLI command iob state get <id> will no longer handle binary state values (which was never really working before). We added iob state getBinary <id> <encoding> as new way.
              • Ensure that on a backup-restore the same adapters and adapter versions are restored as existing on backup time. Also check js-controller version and error on mismatch (is allowed to be forced accepted by --force parameter for restore)
              • The "file" database will be automatically converted into JSONL and the database types that use "file" are adjusted to "jsonl" on installation (and backup restore). This means that a rollback of js-controller is only possible to 3.3 after 4.0 was installed! Rollback to former versions require a manual migration to "file" DB before the downgrade! (COMMUNICATION, TESTFOKUS)
              Features
              • (bluefox) Added complexity rules for user passwords: New created passwords need to follow the following rules (TODO ADMIN UI INFO ISSUE):
                • minimum length is 8
                • contains at least one digit
                • contains at least one lower case letter
                • contains at least one upper case letter
              • (foxriver76) Introduce option "--custom" when deleting instances or adapter to also clean up relevant custom entries from all objects (TODO ADMIN ISSUE ADD CHECKBOX!, TESTFOKUS)
              • (foxriver76) Added new host objects to provide Node.js version and PID
              • (foxriver76) Updated the Linux capabilities on js-controller start when a Node.js version change was detected (and initial on first run)
              • (AlCalzone/foxriver76) Further optimize strategy for required Node.js module rebuilds. We first try to run rebuild in root package and if still packages are left (or it fails) we try to rebuild the really affected modules alone. Should give better results then former strategy (TESTFOKUS)
              • (bluefox) Added support for configuring multiple repositories (TODO LINK+INFO FLAG)
              • (Apollon77) Streamline logging configuration for all available transports: A set Loglevel in config means that this loglevel is pinned for the transport for all cases. An Empty/not set level ("Default" in Admin) means that logging is dynamic and can be adjusted per Instance controller or loglevel state on the fly.
              • (foxriver76) Added installedFrom info to adapter start log line when not installed from npm normally
              Optimizations and Fixes
              • (Apollon77/foxriver76) Improve performance of object deletions (also when deleting instances or adapters) significantly (file-db 4x faster, jsonl-db 14x faster, redis 360x% !! faster)
              • (foxriver76/Apollon77) Improve performance for redis object searches by up to 2,5x by using lookup structures for object types and custom object properties. This optimization is only active for single host redis systems automatically, but can be activated for multihost redis systems too after all hosts are (and stay!) on js-controller 4.0! (TODO DOCS)
              • (foxriver76/Apollon77) Improve performance for object searches in general by limiting search namespaces to the relevant ones automatically
              • (foxriver76) Improve handling of backup restores when custom hostnames were used (especially relevant for Docker usage)
              • (foxriver76) Optimize backup to make sure invalid user-generated JSONs do not prevent backups from being considered valid
              • (foxriver76/klein0r) Improved CLI help
              • (foxriver76) Preserve changed instance names also when updating adapter (name was reset before)
              • (foxriver76) stop adapters on Windows prior update to prevent EBUSY
              • (foxriver76) Prevent crashes for uploads with invalid adapter installations
              • (bluefox) Removed news from instance/adapter objects on install/update because taken from repository in Admin5 (TODO CHECK ADMIN4 EFFECTS)
              • (AlCalzone) Removed extraneous "npm install" inside adapter directory
              • (foxriver76/AlCalzone) reduce JSONL compression frequency to reduce I/O (relevant when experimental JSONL database modules are used)
              • (foxriver76) prevent uploading js-controller (creating system.adapter.js-controller object) and remove existing cases on setup first
              • (foxriver76) prevent crash when multihost password is invalid and multihost active
              • (bluefox/foxriver76) bigger internal refactorings in cli commands (TESTFOKUS)
              • (foxriver76) made logging of not fulfilled adapter dependencies more user-friendly
              • (foxriver76) Check user and group assignments and remove unknown users from groups (could have happened in earlier versions) in setup first
              • (foxriver76) Prevent crash on adapter install/update if version string in repo is invalid
              • (AlCalzone) Update and optimize JSONL database integration and configuration options
              • (foxriver76) make sure that settings for file/jsonl DB in configfile are also respected
              • (foxriver76) Update seq integration for logging
              • (foxriver76) If logging can not be initialized because of a fatal error do not start js-controller
              • (foxriver76) Prevent start of a debug session for an instance that is already running
              • (Apollon77) Fix an edge case for file db which could lead to main and backup file being broken in strange situations with multiple crashes in a row
              • (foxriver76) make sure that admin, backitup and discovery instances are created when update of controller happens if installed and no instance exists
              • (Apollon77) Optimize Stop Handling to prevent errors
              • (Apollon77) Optimize Adapter process initialization to prevent edge case errors
              • (foxriver76) Optimize meta object sync
              • (Apollon77, foxriver76, bluefox, AlCalzone) Several fixes and refactorings to prevent potential crash cases reported by Sentry and other sources
              Developer relevant DEPRECATIONS/WARNINGS
              • js-controller is no longer installable from GitHub because is now a monorepo. Use @dev tag on npm to get the nightly build of master js-controller!
              • log info when setState is used for an object of type file - use setBinaryState instead!
              • log info when default value of an object is invalid (e.g. does not match object type)
              • log info when common.states is used and not an object (deprecate String usage)
              • log info when common.min/common.max exists on non numbers and contain invalid values/types
              • add get/setForeignBinaryState methods as copy from get/setBinaryState allow adapter to migrate; get/setBinaryState will be changed in 4.1 to be "non Foreign"
              • Enhanced object checks: adapter need to have a name as string
              • Decline calls for getForeignObjects with non string pattern (was pot. crashing before)
              • adapter.tools is deprecated and replaced by a shim. Use methods in adapter class or adapter-core instead or open issues if you need more internal functions
                The object view definition "custom/state" is now removed from js-controller after being replaced by "system/custom" in js-controller 3.3. All relevant adapters are updated (COMMUNICATION)
              • remove all Fifo Methods from adapter.js because deprecated since 1.x
              • remove adapter.objects.* methods because deprecated since 2.x
              Developer relevant new Features
              • (jogibear9988) Add new "unload-safe" promise based "adapter.delay" method to delay further code execution, but still make sure code do not continue after unload was called. This method can not be used inside the "unload" method itself!
              • (jogibear9988/AlCalzone/foxriver76/Apollon77) Revamp adapter.*Timeout and adapter.*Interval methods to be "unload-safe" and also clear missing timeouts without warnings for more developer convenience! The methods to set a timeout or interval can not be used inside the "unload" method itself!
              • (foxriver76) Allow to set "null" for common.states and not log error for object (but has no effect on extend, so value does not get deleted!)
              • (AlCalzone) Introduce new methods in tools for Node.js module management: installNodeModule, uninstallNodeModule (TODO Issues adapter that use npm install -> Move))
              • (bluefox) Add license management functionality to host. Adapters can use adapter.getSuitableLicenses to get available relevant licenses (TODO DOCS)
              • (AlCalzone) Switch NPM relevant handling to library pak to be more flexible for the future which package manager we want to use. Important: There are still parts that rely on npm for now!
              • (bluefox) Also report docker info when sending diag data
              • (foxriver76) Add server time to getHostInfo message
              • (foxriver76) For multihost clusters with js-controller 4.0+ the hosts automatically determine a "primary" host that can be used js-controller internally (right now, preparation for future topics)
              Developer relevant Optimizations and Fixes
              • (foxriver76) fixed permissionError on setBinaryState
              • (foxriver76) preserve "native" content for instanceObjects when updating the objects on adapter start
              • (Apollon77/foxriver76) Limit the search scope for object types host, adapter, instance, instanceStats, enum, script, group, user, config to the relevant namespaces when no search start/end is provided to speedup these calls in general
              • (foxriver76) Optimize deleteDevice/deleteChannel methods to just delete all objects the relevant device/channel
              • (foxriver76) Removed some magic path lookups to be compatible to npm 7/8. Appname of controller is now always "iobroker" ("ioBroker" in dev cases)
              • (foxriver76) Also use Sentry (if enabled/allowed) in CLI commands whenever database is initialized to report crashes from CLI if they happen
              • (foxriver76) Introduce a database protocol version number to allow detection of the available database features in multihost environments
              • (bluefox) Prevent issues when using adapter.addChannelToEnum because of missing callback
              • (foxriver76) make sure autoSubscribe works as expected in all cases
              • general dependency updates
              • code style optimizations and streamline code
              Generell ist zu testen, ob alles noch so funktioniert wie vorher auch. Das ist das wichtigste!
              Wie Fehler melden?
              Wer sich unsicher ist, ob ein Fehler vorliegt, sollte am besten hier im Thread das Problem beschreiben. So können wir alle versuchen, das Problem nachzuvollziehen und ggf. einzugrenzen.
              Bitte checkt auch die "Known issues Liste" (zweiter Post) mit den Dingen die aktuell während dem Beta-Test bekannt sind und bis zum Release noch angepasst werden.
              Sobald ein Fehler auftritt der in einer Fehlermeldung oder einen Crash mit Fehlerdetails im Log oder auf Kommandozeile endet, dann dazu am besten direkt ein GitHub-Issue im js-controller Projekt öffnen und zusätzlich hier im Thread posten. Je detaillierter die Angaben im Issue sind (genaue Fehlermeldungen/Logs, Infos zur OS- und Node.js-Umgebung sowie genaue Schritte zur Reproduktion des Problems), umso schneller können wir Fehler einkreisen und beheben.
              Wir wünschen allen viel Spaß beim Testen und vielen Dank für Eure Unterstützung!
              Ingo
              #185
              @apollon77
              js-controller 4.0.5 ist hier sehr dezent am werkeln, weniger Speicherverbrauch, keine Fehlermeldungen.
              Sowohl im lxc debian 10, Node 14.19.0, NPM 6.14.16, als auch auf dem Zeroberry Debian 10, Node 14.18.3, NPM 6.14.16, als auch auf mehreren lxc mit debian 11, Node 16 und NPM 8.
              Schnurrt!
              • AlligatorA
                AlligatorA
                Alligator
                #186
                So ich hab es jetzt nach zig versuchen geschafft den JS-Controller auf 3.3.22 zu downgraden. Jetzt gehen die Updates wieder.
                • B
                  B
                  bommel_030
                  schrieb am zuletzt editiert von bommel_030
                  #187
                  Hab einen Master und zwei Slaves problemlos von 3.3.x auf 4.0.4 aktualisiert.
                  Upgrade von 4.0.4 auf 4.0.5 lief auf Master und einem Slave problemlos durch.
                  Der zweite meldet mir jetzt:
                  pi@suissepi:/opt/iobroker $ iob upgrade self
                  Update js-controller from @4.0.4 to @4.0.5
                  Installing iobroker.js-controller@4.0.5... (System call)
                  EDIT:
                  Konnte den kleinen Eidgenossen damit wiederbeleben:
                  • B bommel_030
                    EDIT:
                    M
                    M
                    MartyBr
                    #188
                    @apollon77
                    Eine kurze Frage: Weiter oben berichte ein User, dass seine Redis-Einstellung durch das neue Format jsonl überschrieben wurde.
                    Ist das Problem nun in der 4.05 behoben?
                    Martin
                    Homematic und Homematic IP
                    • O
                      O
                      oFbEQnpoLKKl6mbY5e13
                      #189
                      @apollon77
                      Ich habe einen ganz frischen Buanet-Container gezogen. Backup eingespielt. Gewartet bis alle Adapter installiert wurden. Funktion geprüft. Dann iobroker upgrade self ausgeführt:
                      3544 verbose stack Error: iobroker.js-controller@4.0.5 install: `node iobroker.js setup first`
                      3544 verbose stack Exit status 6
                      3544 verbose stack     at EventEmitter.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:332:16)
                      3544 verbose stack     at EventEmitter.emit (events.js:400:28)
                      3544 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
                      3544 verbose stack     at ChildProcess.emit (events.js:400:28)
                      3544 verbose stack     at maybeClose (internal/child_process.js:1058:16)
                      3544 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:293:5)
                      3545 verbose pkgid iobroker.js-controller@4.0.5
                      3546 verbose cwd /opt/iobroker
                      3547 verbose Linux 5.10.60-qnap
                      3548 verbose argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.js-controller@4.0.5" "--loglevel" "error" "--unsafe-perm" "--prefix" "/opt/iobroker"
                      3549 verbose node v14.19.0
                      3550 verbose npm  v6.14.16
                      3551 error code ELIFECYCLE
                      3552 error errno 6
                      3553 error iobroker.js-controller@4.0.5 install: `node iobroker.js setup first`
                      3553 error Exit status 6
                      3554 error Failed at the iobroker.js-controller@4.0.5 install script.
                      3554 error This is probably not a problem with npm. There is likely additional logging output above.
                      3555 verbose exit [ 6, true ]
                      Danach ist der js-controller nicht mehr funktionsfähig. Dann den letzten 3er wieder installiert, was einwandfrei funktioniert.
                        @m0rph utzt Du vllt irgendwie NVM oder so nen Kram? Falls ja: nicht machen. Also fakt ist das ioBroker (und das bedeutet der ioBroker User unter dem alles läuft) kein npm findet
                        M
                        M
                        m0rph
                        schrieb am zuletzt editiert von m0rph
                        #190
                        @apollon77 sagte in js-controller 4.0 jetzt im BETA/LATEST!:
                        @apollon77 Wenn du mir sagt was du mit NVM meinst, sagt mir leider nichts, und warum findet die alte Version npm :(
                        sudo -H -u iobroker npm -v
                        sudo -u iobroker npm -v
                        bringt auch ein ergebnis
                        • C ChrisXY
                          @apollon77 said in js-controller 4.0 jetzt im BETA/LATEST!:
                          @chrisxy sagte in js-controller 4.0 jetzt im BETA/LATEST!:
                          EADDRNOTAVAIL: address not available 192.168.2.200:2001
                          Da scheint irgendetwas anderes auf Port 2001 zu Hören, und daher kann der Adapter nicht starten ... Stelle sicher das da nicht noch Zombie Prozesse laufen
                          Das ist was von Homematic. Laut Adapter ist dort meine neue IP 192.168.4.100 Hinterlegt die 192.168.2.200 ist ALT .. wo auch immer das her ist. Nach iob stop scheint alles aber aus zu sein,
                          @chrisxy Ääähmm ... was Hast Du genau hier getan? Das ist ist ein Migration-Prozess ... so mir scheint es als ob du aktiv über "iob setup custom" eine Migration zu "file" gemacht hast und dabei gab es einen Permission Fehler.
                          Um es jetzt zu fixen:
                          1.) iob fix um die Rechtefehler zu fixen
                          2.) Wenn DU zurück zum letzten Redis Stand willst editiere die /opt/iobroker/iobroker-data/iobroker.json und ändere bei objects und states jeweils den Typ in "redis" da wo jetzt scheinbar "file" steht.
                          Danach sollte erstmal alles wieder laufen
                          Also mein iob läuft mit Redis. Nach dem iob upgrade self und Neustart hat iob Status "file" vorher "redis"
                          Ich werde es nochmal versuchen und die Datei mal anpassen. Schauen was Passiert.
                          EDIT: Nach iob upgrade self sagt iob status : file .. wenn ich aber die iobroker,json öffne steht bei beiden Typ: redis ...
                          Folgende Meldung bekomme ich bei iob upgrade self:
                          root@iobroker:/# cd /opt/iobroker/
                          root@iobroker:/opt/iobroker# iob upgrade self
                          NPM version: 6.14.10
                          In file included from ../src/unix_dgram.cc:5:
                          ../../nan/nan.h: In function 'void Nan::AsyncQueueWorker(Nan::AsyncWorker*)':
                          ../../nan/nan.h:2298:62: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]
                               , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
                          In file included from ../../nan/nan.h:54,
                          ../src/unix_dgram.cc: At global scope:
                          /home/iobroker/.cache/node-gyp/14.15.4/include/node/node.h:758:43: warning: cast between incompatible function types from 'void (*)(v8::Local<v8::Object>)' to 'node::addon_register_func' {aka 'void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)'} [-Wcast-function-type]
                          /home/iobroker/.cache/node-gyp/14.15.4/include/node/node.h:792:3: note: in expansion of macro 'NODE_MODULE_X'
                          ../src/unix_dgram.cc:404:1: note: in expansion of macro 'NODE_MODULE'
                          apollon77A
                          apollon77A
                          #191
                          @chrisxy Ok, also das "iob status" file sagt wenn es redis sein sollte ist sehr komisch und hab ich noch nie erlebt. bei mir auf meinen Systemen geht alles wie geplant ... hm ..
                          DIe andere Meldung ist "Warnkram von npm". Ignorieren
                          • DiginixD Diginix
                            Hoffentlich ok so.
                            Objects type: jsonl
                            States  type: jsonl
                              "system": {
                                "memoryLimitMB": 0,
                                "hostname": ""
                                "enabled": false,
                                "secure": true
                              "network": {
                                "IPv4": true,
                                "IPv6": true,
                              "objects": {
                                "type": "jsonl",
                                "port": 9001,
                                "user": "",
                                "pass": "",
                                "options": {
                                  "auth_pass": null,
                              "states": {
                                "type": "jsonl",
                                "port": 9000,
                                "maxQueue": 1000,
                                "options": {
                                  "auth_pass": null,
                              "log": {
                                "level": "warn",
                                "maxDays": 14,
                                "noStdout": true,
                                "transport": {
                                  "file1": {
                                    "type": "file",
                                    "enabled": true,
                                    "fileext": ".log",
                                    "maxsize": null,
                                    "maxFiles": null
                                  "syslog1": {
                                    "type": "syslog",
                                    "enabled": false,
                                    "protocol": "udp4",
                            apollon77A
                            apollon77A
                            #192
                            @diginix Meldungen vom Update sind so ok. Die eine Zeile war wohl irgendwas komisches, wenn es nicht nochmal kommt. Ignorieren.
                            Im "Dist File" sind die Defaults drin - das heisst die sind auch im Code drin. Wenn es also bei Dir im File fehlt dann ist das "egal". Ansonsten ioBroker stoppen und selbst einbauen. Ist nur relevant wenn Du ändern willst.
                            Zu "writeFileInterval" bitte in der FAQ schauen (Post #2) (oder stück weiter oben hier im Thread) :-) Ja die ist bei Jsonl irrelevant und gilt nur bei der FileDB. Jsonl ticket komplett anders, daher irrelevant
                            DiginixD E 2 Antworten Letzte Antwort
                            • AlligatorA Alligator
                              Hallo an alle,
                              Node.js
                              v14.19.0
                              NPM
                              v6.14.16
                              iot.0
                              iot.0
                              iot.0
                              iot.0
                              iot.0
                              iot.0
                              iot.0
                              iot.0
                              iot.0
                              iot.0
                              apollon77A
                              apollon77A
                              #193
                              @alligator Ok, Du bist der zweite der dieses problem hat.
                              Bitte mal which npm ausführen und Ausgabe sagen. Scheinbar findet ioBroker bzw der ioBroker User dein npm nicht. DU nutt aber kein nvm oder sowas?
                              O 1 Antwort Letzte Antwort
                                O
                                O
                                #194
                                Hatte ich auch.
                                  apollon77A
                                  apollon77A
                                  #195
                                  @crunchip Request times out sagt das deine InfluxDB nicht innerhalb der Timeout Zeit geantwortet hat ... Am besten mal im InfluxDB log schauen bzw generell was bei der los war zu dem Zeitpunkt
                                    DiginixD
                                    DiginixD
                                    Diginix
                                    #196
                                    @apollon77 Super, dann passt alles und danke für die ausführliche Antwort. Hatte das mit dem writeFileInterval auch gelesen. War nur unsicher weil keine JSONL Settings in der iobroker.json sind. Aber wenn die defaults aus der dist gelten, dann ist ja alles bestens.
                                    DiskWrite in der iobroker VM ist bei mir direkt mal von 350 MB/h auf 158 MB/h gesunken. Und ich hatte ja schon höhere Writeintervalle bei den alten objects und states.
                                    • E eXectiX
                                      apollon77A
                                      apollon77A
                                      #197
                                      @exectix Was an sich nicht sein kann :-)
                                      • O oFbEQnpoLKKl6mbY5e13
                                        Hatte ich auch.
                                        apollon77A
                                        apollon77A
                                        #198
                                        @ofbeqnpolkkl6mby5e13 Und wie gefixt? Oder hast Du das Issue immer noch? Weil die Ursache ist vollständg unklar.
                                          apollon77A
                                          apollon77A
                                          #199
                                          @alligator Und was hast Du genau getan?
                                          AlligatorA 1 Antwort Letzte Antwort
                                          33.2k
                                          84.4k
